[PATCH] lib: rsa: cosmetic: fix building warning
add initialization of variable 'node',this can aviod the building warning:
'node' may be used uninitialized [-Wmaybe-uninitialized]
Signed-off-by: Haijun Qin qinhaijun@eswincomputing.com --- lib/rsa/rsa-sign.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/rsa/rsa-sign.c b/lib/rsa/rsa-sign.c index b2a21199e4..d20bdb58a5 100644 --- a/lib/rsa/rsa-sign.c +++ b/lib/rsa/rsa-sign.c @@ -608,7 +608,7 @@ int rsa_add_verify_data(struct image_sign_info *info, void *keydest) BIGNUM *modulus, *r_squared; uint64_t exponent; uint32_t n0_inv; - int parent, node; + int parent, node = -FDT_ERR_NOTFOUND; char name[100]; int ret; int bits;
base-commit: d2c5607edde2544e059fa871927877213f6bd532
What toolchain is this?
int parent, node;
2.17.1
Hi,Simon
The toolchain source code we use comes from here(https://github.com/riscv-collab/riscv-gnu-toolchain), but we have made some changes.
int parent, node;
2.17.1
Signed-off-by: Haijun Qin qinhaijun@eswincomputing.com Reviewed-by: Simon Glass sjg@chromium.org
Haijun Qin
