[U-Boot] [PATCH] sunxi: Explicitly call fdt_fixup_ethernet() in our ft_board_setup()
The sunxi platform relies on the core boot sequence to load and process device tree blobs, including writing back any MAC addresses we generate by an implicit call to fdt_fixup_ethernet() within the image loading mechanism. This call was removed in commit 3f66149d9fb4 ("Remove extra fdt_fixup_ethernet() call"), resuling in Linux using random MAC addresses.
This patch adds an explicit call to fdt_fixup_ethernet() in our ft_board_setup() function.
Fixes: 3f66149d9fb4 ("Remove extra fdt_fixup_ethernet() call") Signed-off-by: Chen-Yu Tsai wens@csie.org ---
I wonder, if every platform wants or needs to do this, maybe we should just do this in a central place instead.
--- board/sunxi/board.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 04a629125e0f..e10239ca4550 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -29,6 +29,7 @@ #include <asm/io.h> #include <crc.h> #include <environment.h> +#include <fdt_support.h> #include <libfdt.h> #include <nand.h> #include <net.h> @@ -743,6 +744,8 @@ int ft_board_setup(void *blob, bd_t *bd) */ setup_environment(blob);
+ fdt_fixup_ethernet(blob); + #ifdef CONFIG_VIDEO_DT_SIMPLEFB r = sunxi_simplefb_setup(blob); if (r)
I would just revert that commit. The function mentionned in the commit log is platform specific, it just doesn't make any sense to remove some generic code just because it would work on your platform.
Maxime
It's not quite that easy. Part of the issue here is that in PowerPC we expect to have ft_cpu_setup and ft_board_setup populated and performing various fix-ups.
That said, 3f66149d9fb4 is fixing a problem we introduced in 13d06981a982. But, lets try again, Joakim, what is the problem of calling fdt_fixup_ethernet a second time? And why not just drop the call from the other locations? I don't see a problem with that, in a quick read over of the other callers. Thanks!
The Generic code was both added later and wrong so no need to restore that.
One could remove the platform specific code and add back a generic one but then make sure it is called BEFORE any board setup.
Jocke
OK, let me see if I can come up with something then, test patch shortly.
Chen-Yu Tsai
Joakim Tjernlund
Maxime Ripard
