[U-Boot] [PATCH 1/3] Add LSDMR (SDRAM Mode Register) definition on localbus
The masks for various bit defines of LSDMR are common and thus we can define them in one place rather than replicating them in each config.h
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- include/asm-ppc/fsl_lbc.h | 27 +++++++++++++++++++++++++++ 1 files changed, 27 insertions(+), 0 deletions(-)
diff --git a/include/asm-ppc/fsl_lbc.h b/include/asm-ppc/fsl_lbc.h index 9fa0b65..bc1ebe6 100644 --- a/include/asm-ppc/fsl_lbc.h +++ b/include/asm-ppc/fsl_lbc.h @@ -397,6 +397,33 @@ #define FPAR_LP_CI 0x000007FF #define FPAR_LP_CI_SHIFT 0
+/* LSDMR - SDRAM Machine Mode Register + */ +#define LSDMR_RFEN (1 << (31 - 1)) +#define LSDMR_BSMA1516 (3 << (31 - 10)) +#define LSDMR_BSMA1617 (4 << (31 - 10)) +#define LSDMR_RFCR5 (3 << (31 - 16)) +#define LSDMR_RFCR16 (7 << (31 - 16)) +#define LSDMR_PRETOACT3 (3 << (31 - 19)) +#define LSDMR_PRETOACT7 (7 << (31 - 19)) +#define LSDMR_ACTTORW3 (3 << (31 - 22)) +#define LSDMR_ACTTORW7 (7 << (31 - 22)) +#define LSDMR_ACTTORW6 (6 << (31 - 22)) +#define LSDMR_BL8 (1 << (31 - 23)) +#define LSDMR_WRC2 (2 << (31 - 27)) +#define LSDMR_WRC4 (0 << (31 - 27)) +#define LSDMR_BUFCMD (1 << (31 - 29)) +#define LSDMR_CL3 (3 << (31 - 31)) + +#define LSDMR_OP_NORMAL (0 << (31 - 4)) +#define LSDMR_OP_ARFRSH (1 << (31 - 4)) +#define LSDMR_OP_SRFRSH (2 << (31 - 4)) +#define LSDMR_OP_MRW (3 << (31 - 4)) +#define LSDMR_OP_PRECH (4 << (31 - 4)) +#define LSDMR_OP_PCHALL (5 << (31 - 4)) +#define LSDMR_OP_ACTBNK (6 << (31 - 4)) +#define LSDMR_OP_RWINV (7 << (31 - 4)) + /* LTESR - Transfer Error Status Register */ #define LTESR_BM 0x80000000
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/mpc8541cds/mpc8541cds.c | 14 ++++---- board/freescale/mpc8548cds/mpc8548cds.c | 10 +++--- board/freescale/mpc8555cds/mpc8555cds.c | 14 ++++---- board/freescale/mpc8560ads/mpc8560ads.c | 1 + board/freescale/mpc8568mds/mpc8568mds.c | 10 +++--- board/sbc8548/sbc8548.c | 10 +++--- include/configs/MPC8540ADS.h | 59 +++++++------------------------ include/configs/MPC8541CDS.h | 37 ++++---------------- include/configs/MPC8548CDS.h | 37 ++++---------------- include/configs/MPC8555CDS.h | 37 ++++---------------- include/configs/MPC8560ADS.h | 59 +++++++------------------------ include/configs/MPC8568MDS.h | 37 ++++---------------- include/configs/sbc8548.h | 37 ++++---------------- 13 files changed, 91 insertions(+), 271 deletions(-)
diff --git a/board/freescale/mpc8541cds/mpc8541cds.c b/board/freescale/mpc8541cds/mpc8541cds.c index e6025c8..c30d966 100644 --- a/board/freescale/mpc8541cds/mpc8541cds.c +++ b/board/freescale/mpc8541cds/mpc8541cds.c @@ -372,21 +372,21 @@ sdram_init(void) cpu_board_rev = get_cpu_board_revision(); lsdmr_common = CONFIG_SYS_LBC_LSDMR_COMMON; if (cpu_board_rev == MPC85XX_CPU_BOARD_REV_1_0) { - lsdmr_common |= CONFIG_SYS_LBC_LSDMR_BSMA1617; + lsdmr_common |= LSDMR_BSMA1617; } else if (cpu_board_rev == MPC85XX_CPU_BOARD_REV_1_1) { - lsdmr_common |= CONFIG_SYS_LBC_LSDMR_BSMA1516; + lsdmr_common |= LSDMR_BSMA1516; } else { /* * Assume something unable to identify itself is * really old, and likely has lines 16/17 mapped. */ - lsdmr_common |= CONFIG_SYS_LBC_LSDMR_BSMA1617; + lsdmr_common |= LSDMR_BSMA1617; }
/* * Issue PRECHARGE ALL command. */ - lbc->lsdmr = lsdmr_common | CONFIG_SYS_LBC_LSDMR_OP_PCHALL; + lbc->lsdmr = lsdmr_common | LSDMR_OP_PCHALL; asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); @@ -396,7 +396,7 @@ sdram_init(void) * Issue 8 AUTO REFRESH commands. */ for (idx = 0; idx < 8; idx++) { - lbc->lsdmr = lsdmr_common | CONFIG_SYS_LBC_LSDMR_OP_ARFRSH; + lbc->lsdmr = lsdmr_common | LSDMR_OP_ARFRSH; asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); @@ -406,7 +406,7 @@ sdram_init(void) /* * Issue 8 MODE-set command. */ - lbc->lsdmr = lsdmr_common | CONFIG_SYS_LBC_LSDMR_OP_MRW; + lbc->lsdmr = lsdmr_common | LSDMR_OP_MRW; asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); @@ -415,7 +415,7 @@ sdram_init(void) /* * Issue NORMAL OP command. */ - lbc->lsdmr = lsdmr_common | CONFIG_SYS_LBC_LSDMR_OP_NORMAL; + lbc->lsdmr = lsdmr_common | LSDMR_OP_NORMAL; asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); diff --git a/board/freescale/mpc8548cds/mpc8548cds.c b/board/freescale/mpc8548cds/mpc8548cds.c index 70320ea..efb2c5b 100644 --- a/board/freescale/mpc8548cds/mpc8548cds.c +++ b/board/freescale/mpc8548cds/mpc8548cds.c @@ -185,12 +185,12 @@ sdram_init(void) */ cpu_board_rev = get_cpu_board_revision(); lsdmr_common = CONFIG_SYS_LBC_LSDMR_COMMON; - lsdmr_common |= CONFIG_SYS_LBC_LSDMR_BSMA1516; + lsdmr_common |= LSDMR_BSMA1516;
/* * Issue PRECHARGE ALL command. */ - lbc->lsdmr = lsdmr_common | CONFIG_SYS_LBC_LSDMR_OP_PCHALL; + lbc->lsdmr = lsdmr_common | LSDMR_OP_PCHALL; asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); @@ -200,7 +200,7 @@ sdram_init(void) * Issue 8 AUTO REFRESH commands. */ for (idx = 0; idx < 8; idx++) { - lbc->lsdmr = lsdmr_common | CONFIG_SYS_LBC_LSDMR_OP_ARFRSH; + lbc->lsdmr = lsdmr_common | LSDMR_OP_ARFRSH; asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); @@ -210,7 +210,7 @@ sdram_init(void) /* * Issue 8 MODE-set command. */ - lbc->lsdmr = lsdmr_common | CONFIG_SYS_LBC_LSDMR_OP_MRW; + lbc->lsdmr = lsdmr_common | LSDMR_OP_MRW; asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); @@ -219,7 +219,7 @@ sdram_init(void) /* * Issue NORMAL OP command. */ - lbc->lsdmr = lsdmr_common | CONFIG_SYS_LBC_LSDMR_OP_NORMAL; + lbc->lsdmr = lsdmr_common | LSDMR_OP_NORMAL; asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); diff --git a/board/freescale/mpc8555cds/mpc8555cds.c b/board/freescale/mpc8555cds/mpc8555cds.c index 53d5a93..ecddd0d 100644 --- a/board/freescale/mpc8555cds/mpc8555cds.c +++ b/board/freescale/mpc8555cds/mpc8555cds.c @@ -371,21 +371,21 @@ sdram_init(void) cpu_board_rev = get_cpu_board_revision(); lsdmr_common = CONFIG_SYS_LBC_LSDMR_COMMON; if (cpu_board_rev == MPC85XX_CPU_BOARD_REV_1_0) { - lsdmr_common |= CONFIG_SYS_LBC_LSDMR_BSMA1617; + lsdmr_common |= LSDMR_BSMA1617; } else if (cpu_board_rev == MPC85XX_CPU_BOARD_REV_1_1) { - lsdmr_common |= CONFIG_SYS_LBC_LSDMR_BSMA1516; + lsdmr_common |= LSDMR_BSMA1516; } else { /* * Assume something unable to identify itself is * really old, and likely has lines 16/17 mapped. */ - lsdmr_common |= CONFIG_SYS_LBC_LSDMR_BSMA1617; + lsdmr_common |= LSDMR_BSMA1617; }
/* * Issue PRECHARGE ALL command. */ - lbc->lsdmr = lsdmr_common | CONFIG_SYS_LBC_LSDMR_OP_PCHALL; + lbc->lsdmr = lsdmr_common | LSDMR_OP_PCHALL; asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); @@ -395,7 +395,7 @@ sdram_init(void) * Issue 8 AUTO REFRESH commands. */ for (idx = 0; idx < 8; idx++) { - lbc->lsdmr = lsdmr_common | CONFIG_SYS_LBC_LSDMR_OP_ARFRSH; + lbc->lsdmr = lsdmr_common | LSDMR_OP_ARFRSH; asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); @@ -405,7 +405,7 @@ sdram_init(void) /* * Issue 8 MODE-set command. */ - lbc->lsdmr = lsdmr_common | CONFIG_SYS_LBC_LSDMR_OP_MRW; + lbc->lsdmr = lsdmr_common | LSDMR_OP_MRW; asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); @@ -414,7 +414,7 @@ sdram_init(void) /* * Issue NORMAL OP command. */ - lbc->lsdmr = lsdmr_common | CONFIG_SYS_LBC_LSDMR_OP_NORMAL; + lbc->lsdmr = lsdmr_common | LSDMR_OP_NORMAL; asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); diff --git a/board/freescale/mpc8560ads/mpc8560ads.c b/board/freescale/mpc8560ads/mpc8560ads.c index ac7778e..2bca0f2 100644 --- a/board/freescale/mpc8560ads/mpc8560ads.c +++ b/board/freescale/mpc8560ads/mpc8560ads.c @@ -36,6 +36,7 @@ #include <miiphy.h> #include <libfdt.h> #include <fdt_support.h> +#include <asm/fsl_lbc.h>
#if defined(CONFIG_DDR_ECC) && !defined(CONFIG_ECC_INIT_VIA_DDRCONTROLLER) extern void ddr_enable_ecc(unsigned int dram_size); diff --git a/board/freescale/mpc8568mds/mpc8568mds.c b/board/freescale/mpc8568mds/mpc8568mds.c index 915fae7..97f4651 100644 --- a/board/freescale/mpc8568mds/mpc8568mds.c +++ b/board/freescale/mpc8568mds/mpc8568mds.c @@ -243,12 +243,12 @@ sdram_init(void) * MPC8568 uses "new" 15-16 style addressing. */ lsdmr_common = CONFIG_SYS_LBC_LSDMR_COMMON; - lsdmr_common |= CONFIG_SYS_LBC_LSDMR_BSMA1516; + lsdmr_common |= LSDMR_BSMA1516;
/* * Issue PRECHARGE ALL command. */ - lbc->lsdmr = lsdmr_common | CONFIG_SYS_LBC_LSDMR_OP_PCHALL; + lbc->lsdmr = lsdmr_common | LSDMR_OP_PCHALL; asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); @@ -258,7 +258,7 @@ sdram_init(void) * Issue 8 AUTO REFRESH commands. */ for (idx = 0; idx < 8; idx++) { - lbc->lsdmr = lsdmr_common | CONFIG_SYS_LBC_LSDMR_OP_ARFRSH; + lbc->lsdmr = lsdmr_common | LSDMR_OP_ARFRSH; asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); @@ -268,7 +268,7 @@ sdram_init(void) /* * Issue 8 MODE-set command. */ - lbc->lsdmr = lsdmr_common | CONFIG_SYS_LBC_LSDMR_OP_MRW; + lbc->lsdmr = lsdmr_common | LSDMR_OP_MRW; asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); @@ -277,7 +277,7 @@ sdram_init(void) /* * Issue NORMAL OP command. */ - lbc->lsdmr = lsdmr_common | CONFIG_SYS_LBC_LSDMR_OP_NORMAL; + lbc->lsdmr = lsdmr_common | LSDMR_OP_NORMAL; asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); diff --git a/board/sbc8548/sbc8548.c b/board/sbc8548/sbc8548.c index a779420..088f804 100644 --- a/board/sbc8548/sbc8548.c +++ b/board/sbc8548/sbc8548.c @@ -184,12 +184,12 @@ sdram_init(void) * MPC8548 uses "new" 15-16 style addressing. */ lsdmr_common = CONFIG_SYS_LBC_LSDMR_COMMON; - lsdmr_common |= CONFIG_SYS_LBC_LSDMR_BSMA1516; + lsdmr_common |= LSDMR_BSMA1516;
/* * Issue PRECHARGE ALL command. */ - lbc->lsdmr = lsdmr_common | CONFIG_SYS_LBC_LSDMR_OP_PCHALL; + lbc->lsdmr = lsdmr_common | LSDMR_OP_PCHALL; asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); @@ -199,7 +199,7 @@ sdram_init(void) * Issue 8 AUTO REFRESH commands. */ for (idx = 0; idx < 8; idx++) { - lbc->lsdmr = lsdmr_common | CONFIG_SYS_LBC_LSDMR_OP_ARFRSH; + lbc->lsdmr = lsdmr_common | LSDMR_OP_ARFRSH; asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); @@ -209,7 +209,7 @@ sdram_init(void) /* * Issue 8 MODE-set command. */ - lbc->lsdmr = lsdmr_common | CONFIG_SYS_LBC_LSDMR_OP_MRW; + lbc->lsdmr = lsdmr_common | LSDMR_OP_MRW; asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); @@ -218,7 +218,7 @@ sdram_init(void) /* * Issue NORMAL OP command. */ - lbc->lsdmr = lsdmr_common | CONFIG_SYS_LBC_LSDMR_OP_NORMAL; + lbc->lsdmr = lsdmr_common | LSDMR_OP_NORMAL; asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); diff --git a/include/configs/MPC8540ADS.h b/include/configs/MPC8540ADS.h index 4aaad55..5253611 100644 --- a/include/configs/MPC8540ADS.h +++ b/include/configs/MPC8540ADS.h @@ -197,57 +197,24 @@ #define CONFIG_SYS_LBC_LSRT 0x20000000 /* LB sdram refresh timer */ #define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal*/
-/* - * LSDMR masks - */ -#define CONFIG_SYS_LBC_LSDMR_RFEN (1 << (31 - 1)) -#define CONFIG_SYS_LBC_LSDMR_BSMA1516 (3 << (31 - 10)) -#define CONFIG_SYS_LBC_LSDMR_BSMA1617 (4 << (31 - 10)) -#define CONFIG_SYS_LBC_LSDMR_RFCR5 (3 << (31 - 16)) -#define CONFIG_SYS_LBC_LSDMR_RFCR16 (7 << (31 - 16)) -#define CONFIG_SYS_LBC_LSDMR_PRETOACT3 (3 << (31 - 19)) -#define CONFIG_SYS_LBC_LSDMR_PRETOACT7 (7 << (31 - 19)) -#define CONFIG_SYS_LBC_LSDMR_ACTTORW3 (3 << (31 - 22)) -#define CONFIG_SYS_LBC_LSDMR_ACTTORW7 (7 << (31 - 22)) -#define CONFIG_SYS_LBC_LSDMR_ACTTORW6 (6 << (31 - 22)) -#define CONFIG_SYS_LBC_LSDMR_BL8 (1 << (31 - 23)) -#define CONFIG_SYS_LBC_LSDMR_WRC2 (2 << (31 - 27)) -#define CONFIG_SYS_LBC_LSDMR_WRC4 (0 << (31 - 27)) -#define CONFIG_SYS_LBC_LSDMR_BUFCMD (1 << (31 - 29)) -#define CONFIG_SYS_LBC_LSDMR_CL3 (3 << (31 - 31)) - -#define CONFIG_SYS_LBC_LSDMR_OP_NORMAL (0 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_ARFRSH (1 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_SRFRSH (2 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_MRW (3 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_PRECH (4 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_PCHALL (5 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_ACTBNK (6 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_RWINV (7 << (31 - 4)) - -#define CONFIG_SYS_LBC_LSDMR_COMMON ( CONFIG_SYS_LBC_LSDMR_BSMA1516 \ - | CONFIG_SYS_LBC_LSDMR_RFCR5 \ - | CONFIG_SYS_LBC_LSDMR_PRETOACT3 \ - | CONFIG_SYS_LBC_LSDMR_ACTTORW3 \ - | CONFIG_SYS_LBC_LSDMR_BL8 \ - | CONFIG_SYS_LBC_LSDMR_WRC2 \ - | CONFIG_SYS_LBC_LSDMR_CL3 \ - | CONFIG_SYS_LBC_LSDMR_RFEN \ +#define CONFIG_SYS_LBC_LSDMR_COMMON ( LSDMR_BSMA1516 \ + | LSDMR_RFCR5 \ + | LSDMR_PRETOACT3 \ + | LSDMR_ACTTORW3 \ + | LSDMR_BL8 \ + | LSDMR_WRC2 \ + | LSDMR_CL3 \ + | LSDMR_RFEN \ )
/* * SDRAM Controller configuration sequence. */ -#define CONFIG_SYS_LBC_LSDMR_1 ( CONFIG_SYS_LBC_LSDMR_COMMON \ - | CONFIG_SYS_LBC_LSDMR_OP_PCHALL) -#define CONFIG_SYS_LBC_LSDMR_2 ( CONFIG_SYS_LBC_LSDMR_COMMON \ - | CONFIG_SYS_LBC_LSDMR_OP_ARFRSH) -#define CONFIG_SYS_LBC_LSDMR_3 ( CONFIG_SYS_LBC_LSDMR_COMMON \ - | CONFIG_SYS_LBC_LSDMR_OP_ARFRSH) -#define CONFIG_SYS_LBC_LSDMR_4 ( CONFIG_SYS_LBC_LSDMR_COMMON \ - | CONFIG_SYS_LBC_LSDMR_OP_MRW) -#define CONFIG_SYS_LBC_LSDMR_5 ( CONFIG_SYS_LBC_LSDMR_COMMON \ - | CONFIG_SYS_LBC_LSDMR_OP_NORMAL) +#define CONFIG_SYS_LBC_LSDMR_1 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_PCHALL) +#define CONFIG_SYS_LBC_LSDMR_2 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_ARFRSH) +#define CONFIG_SYS_LBC_LSDMR_3 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_ARFRSH) +#define CONFIG_SYS_LBC_LSDMR_4 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_MRW) +#define CONFIG_SYS_LBC_LSDMR_5 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_NORMAL)
/* diff --git a/include/configs/MPC8541CDS.h b/include/configs/MPC8541CDS.h index fa82fbc..813512c 100644 --- a/include/configs/MPC8541CDS.h +++ b/include/configs/MPC8541CDS.h @@ -207,41 +207,18 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_LBC_MRTPR 0x00000000 /* LB refresh timer prescal*/
/* - * LSDMR masks - */ -#define CONFIG_SYS_LBC_LSDMR_RFEN (1 << (31 - 1)) -#define CONFIG_SYS_LBC_LSDMR_BSMA1516 (3 << (31 - 10)) -#define CONFIG_SYS_LBC_LSDMR_BSMA1617 (4 << (31 - 10)) -#define CONFIG_SYS_LBC_LSDMR_RFCR16 (7 << (31 - 16)) -#define CONFIG_SYS_LBC_LSDMR_PRETOACT7 (7 << (31 - 19)) -#define CONFIG_SYS_LBC_LSDMR_ACTTORW7 (7 << (31 - 22)) -#define CONFIG_SYS_LBC_LSDMR_ACTTORW6 (6 << (31 - 22)) -#define CONFIG_SYS_LBC_LSDMR_BL8 (1 << (31 - 23)) -#define CONFIG_SYS_LBC_LSDMR_WRC4 (0 << (31 - 27)) -#define CONFIG_SYS_LBC_LSDMR_CL3 (3 << (31 - 31)) - -#define CONFIG_SYS_LBC_LSDMR_OP_NORMAL (0 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_ARFRSH (1 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_SRFRSH (2 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_MRW (3 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_PRECH (4 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_PCHALL (5 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_ACTBNK (6 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_RWINV (7 << (31 - 4)) - -/* * Common settings for all Local Bus SDRAM commands. * At run time, either BSMA1516 (for CPU 1.1) * or BSMA1617 (for CPU 1.0) (old) * is OR'ed in too. */ -#define CONFIG_SYS_LBC_LSDMR_COMMON ( CONFIG_SYS_LBC_LSDMR_RFCR16 \ - | CONFIG_SYS_LBC_LSDMR_PRETOACT7 \ - | CONFIG_SYS_LBC_LSDMR_ACTTORW7 \ - | CONFIG_SYS_LBC_LSDMR_BL8 \ - | CONFIG_SYS_LBC_LSDMR_WRC4 \ - | CONFIG_SYS_LBC_LSDMR_CL3 \ - | CONFIG_SYS_LBC_LSDMR_RFEN \ +#define CONFIG_SYS_LBC_LSDMR_COMMON ( LSDMR_RFCR16 \ + | LSDMR_PRETOACT7 \ + | LSDMR_ACTTORW7 \ + | LSDMR_BL8 \ + | LSDMR_WRC4 \ + | LSDMR_CL3 \ + | LSDMR_RFEN \ )
/* diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index 95bce95..7089ac7 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -229,41 +229,18 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_LBC_MRTPR 0x00000000 /* LB refresh timer prescal*/
/* diff --git a/include/configs/MPC8555CDS.h b/include/configs/MPC8555CDS.h index 6bf0961..ef95118 100644 --- a/include/configs/MPC8555CDS.h +++ b/include/configs/MPC8555CDS.h @@ -205,41 +205,18 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_LBC_MRTPR 0x00000000 /* LB refresh timer prescal*/
/* diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index a41f50a..761a370 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -193,57 +193,24 @@ #define CONFIG_SYS_LBC_LSRT 0x20000000 /* LB sdram refresh timer */ #define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal*/
/* diff --git a/include/configs/MPC8568MDS.h b/include/configs/MPC8568MDS.h index 58ff52b..77224d9 100644 --- a/include/configs/MPC8568MDS.h +++ b/include/configs/MPC8568MDS.h @@ -188,41 +188,18 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_LBC_MRTPR 0x00000000 /* LB refresh timer prescal*/
/* diff --git a/include/configs/sbc8548.h b/include/configs/sbc8548.h index 8141a46..a2ff955 100644 --- a/include/configs/sbc8548.h +++ b/include/configs/sbc8548.h @@ -242,41 +242,18 @@ #define CONFIG_SYS_LBC_MRTPR 0x00000000 /* LB refresh timer prescal*/
#define CONFIG_SYS_INIT_RAM_LOCK 1
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- include/configs/MPC8323ERDB.h | 26 ----------------- include/configs/MPC832XEMDS.h | 26 ----------------- include/configs/MPC8349EMDS.h | 62 ++++++++-------------------------------- include/configs/MPC8360EMDS.h | 27 +++-------------- include/configs/sbc8349.h | 62 ++++++++-------------------------------- 5 files changed, 31 insertions(+), 172 deletions(-)
diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index 4eab285..9b8b033 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -248,34 +248,8 @@ #define CONFIG_SYS_LBC_LSRT 0x32000000 /* LB sdram refresh timer, about 6us */ #define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal, 266MHz/32 */
-/* - * LSDMR masks - */ -#define CONFIG_SYS_LBC_LSDMR_OP_NORMAL (0 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_ARFRSH (1 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_SRFRSH (2 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_MRW (3 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_PRECH (4 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_PCHALL (5 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_ACTBNK (6 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_RWINV (7 << (31 - 4)) - #define CONFIG_SYS_LBC_LSDMR_COMMON 0x0063b723
-/* - * SDRAM Controller configuration sequence. - */ -#define CONFIG_SYS_LBC_LSDMR_1 ( CONFIG_SYS_LBC_LSDMR_COMMON \ - | CONFIG_SYS_LBC_LSDMR_OP_PCHALL) -#define CONFIG_SYS_LBC_LSDMR_2 ( CONFIG_SYS_LBC_LSDMR_COMMON \ - | CONFIG_SYS_LBC_LSDMR_OP_ARFRSH) -#define CONFIG_SYS_LBC_LSDMR_3 ( CONFIG_SYS_LBC_LSDMR_COMMON \ - | CONFIG_SYS_LBC_LSDMR_OP_ARFRSH) -#define CONFIG_SYS_LBC_LSDMR_4 ( CONFIG_SYS_LBC_LSDMR_COMMON \ - | CONFIG_SYS_LBC_LSDMR_OP_MRW) -#define CONFIG_SYS_LBC_LSDMR_5 ( CONFIG_SYS_LBC_LSDMR_COMMON \ - | CONFIG_SYS_LBC_LSDMR_OP_NORMAL) - #endif
/* diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index ea1928e..c82cda2 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -246,34 +246,8 @@ #define CONFIG_SYS_LBC_LSRT 0x32000000 /* LB sdram refresh timer, about 6us */ #define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal, 266MHz/32 */
/* diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index b3c0e2d..6cc27cb 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -262,60 +262,24 @@ #define CONFIG_SYS_LBC_LSRT 0x32000000 /* LB sdram refresh timer, about 6us */ #define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal, 266MHz/32 */
-/* - * LSDMR masks - */ -#define CONFIG_SYS_LBC_LSDMR_RFEN (1 << (31 - 1)) -#define CONFIG_SYS_LBC_LSDMR_BSMA1516 (3 << (31 - 10)) -#define CONFIG_SYS_LBC_LSDMR_BSMA1617 (4 << (31 - 10)) -#define CONFIG_SYS_LBC_LSDMR_RFCR5 (3 << (31 - 16)) -#define CONFIG_SYS_LBC_LSDMR_RFCR8 (5 << (31 - 16)) -#define CONFIG_SYS_LBC_LSDMR_RFCR16 (7 << (31 - 16)) -#define CONFIG_SYS_LBC_LSDMR_PRETOACT3 (3 << (31 - 19)) -#define CONFIG_SYS_LBC_LSDMR_PRETOACT6 (5 << (31 - 19)) -#define CONFIG_SYS_LBC_LSDMR_PRETOACT7 (7 << (31 - 19)) -#define CONFIG_SYS_LBC_LSDMR_ACTTORW3 (3 << (31 - 22)) -#define CONFIG_SYS_LBC_LSDMR_ACTTORW7 (7 << (31 - 22)) -#define CONFIG_SYS_LBC_LSDMR_ACTTORW6 (6 << (31 - 22)) -#define CONFIG_SYS_LBC_LSDMR_BL8 (1 << (31 - 23)) -#define CONFIG_SYS_LBC_LSDMR_WRC2 (2 << (31 - 27)) -#define CONFIG_SYS_LBC_LSDMR_WRC3 (3 << (31 - 27)) -#define CONFIG_SYS_LBC_LSDMR_WRC4 (0 << (31 - 27)) -#define CONFIG_SYS_LBC_LSDMR_BUFCMD (1 << (31 - 29)) -#define CONFIG_SYS_LBC_LSDMR_CL3 (3 << (31 - 31)) - -#define CONFIG_SYS_LBC_LSDMR_OP_NORMAL (0 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_ARFRSH (1 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_SRFRSH (2 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_MRW (3 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_PRECH (4 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_PCHALL (5 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_ACTBNK (6 << (31 - 4)) -#define CONFIG_SYS_LBC_LSDMR_OP_RWINV (7 << (31 - 4)) - -#define CONFIG_SYS_LBC_LSDMR_COMMON ( CONFIG_SYS_LBC_LSDMR_RFEN \ - | CONFIG_SYS_LBC_LSDMR_BSMA1516 \ - | CONFIG_SYS_LBC_LSDMR_RFCR8 \ - | CONFIG_SYS_LBC_LSDMR_PRETOACT6 \ - | CONFIG_SYS_LBC_LSDMR_ACTTORW3 \ - | CONFIG_SYS_LBC_LSDMR_BL8 \ - | CONFIG_SYS_LBC_LSDMR_WRC3 \ - | CONFIG_SYS_LBC_LSDMR_CL3 \ +#define CONFIG_SYS_LBC_LSDMR_COMMON ( LSDMR_RFEN \ + | LSDMR_BSMA1516 \ + | LSDMR_RFCR8 \ + | LSDMR_PRETOACT6 \ + | LSDMR_ACTTORW3 \ + | LSDMR_BL8 \ + | LSDMR_WRC3 \ + | LSDMR_CL3 \ )
/* * SDRAM Controller configuration sequence. */ -#define CONFIG_SYS_LBC_LSDMR_1 ( CONFIG_SYS_LBC_LSDMR_COMMON \ - | CONFIG_SYS_LBC_LSDMR_OP_PCHALL) -#define CONFIG_SYS_LBC_LSDMR_2 ( CONFIG_SYS_LBC_LSDMR_COMMON \ - | CONFIG_SYS_LBC_LSDMR_OP_ARFRSH) -#define CONFIG_SYS_LBC_LSDMR_3 ( CONFIG_SYS_LBC_LSDMR_COMMON \ - | CONFIG_SYS_LBC_LSDMR_OP_ARFRSH) -#define CONFIG_SYS_LBC_LSDMR_4 ( CONFIG_SYS_LBC_LSDMR_COMMON \ - | CONFIG_SYS_LBC_LSDMR_OP_MRW) -#define CONFIG_SYS_LBC_LSDMR_5 ( CONFIG_SYS_LBC_LSDMR_COMMON \ - | CONFIG_SYS_LBC_LSDMR_OP_NORMAL) +#define CONFIG_SYS_LBC_LSDMR_1 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_PCHALL) +#define CONFIG_SYS_LBC_LSDMR_2 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_ARFRSH) +#define CONFIG_SYS_LBC_LSDMR_3 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_ARFRSH) +#define CONFIG_SYS_LBC_LSDMR_4 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_MRW) +#define CONFIG_SYS_LBC_LSDMR_5 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_NORMAL) #endif
/* diff --git a/include/configs/MPC8360EMDS.h b/include/configs/MPC8360EMDS.h index bdd6b87..4b09de1 100644 --- a/include/configs/MPC8360EMDS.h +++ b/include/configs/MPC8360EMDS.h @@ -271,33 +271,16 @@ #define CONFIG_SYS_LBC_LSRT 0x32000000 /* LB sdram refresh timer, about 6us */ #define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal, 266MHz/32 */
#endif
diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index f476e3e..db1d4ac 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -227,60 +227,24 @@ #define CONFIG_SYS_LBC_LSRT 0x32000000 /* LB sdram refresh timer, about 6us */ #define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal, 266MHz/32 */
On Thu, 26 Mar 2009 01:34:39 -0500 Kumar Gala galak@kernel.crashing.org wrote:
ack.
to go through Andy, I presume.
Thanks,
Kim
Kim Phillips
Kumar Gala
