[U-Boot] [PATCH] net: fec: Avoid MX28 bus sync issue
Dear Fabio,
Hi Robert and Hector,
On Fri, Sep 13, 2013 at 2:46 PM, Wolfgang Denk <[hidden email]> wrote:
That's ALLOC_CACHE_ALIGN_BUFFER. Thanks.
Could you please let us know wthether the change below fix the problem?
Thanks,
Fabio Estevam
--- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -794,7 +794,7 @@ static int fec_recv(struct eth_device *dev) uint16_t bd_status; uint32_t addr, size, end; int i;
uchar buff[FEC_MAX_PKT_SIZE] __aligned(ARCH_DMA_MINALIGN);
ALLOC_CACHE_ALIGN_BUFFER(uchar, buff, FEC_MAX_PKT_SIZE); /* * Check if any critical events have happened
I can confirm that this patch fixes the issue for me on the mx28 board. Before the patch transmitting a linux kernel archive failed many times. With the patch applied the file was transfered successfully with the first try.
Used gcc version: gcc version 4.5.4 20110808 (prerelease) (Linaro GCC 4.5-2011.08)
Regards Oliver
Hi Oliver,
Thanks for testing.
Will submit it as a patch and will add your Tested-by tag.
Thanks,
Fabio Estevam
Fabio Estevam
Oliver Metz
