[PATCH] usb: gadget: Fix controller index in UMS
The usb mass storage (f_mass_storage.c) uses fixed usb index 0, this causes problem while CDNS3 USB controller index is 1. Modify the API of fsg to pass the controller index.
Reviewed-by: Jun Li jun.li@nxp.com Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- cmd/usb_mass_storage.c | 2 +- drivers/usb/gadget/f_mass_storage.c | 6 ++++-- include/usb_mass_storage.h | 2 +- 3 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/cmd/usb_mass_storage.c b/cmd/usb_mass_storage.c index d565635c6c..cf2f55994e 100644 --- a/cmd/usb_mass_storage.c +++ b/cmd/usb_mass_storage.c @@ -170,7 +170,7 @@ static int do_usb_mass_storage(struct cmd_tbl *cmdtp, int flag, goto cleanup_ums_init; }
- rc = fsg_init(ums, ums_count); + rc = fsg_init(ums, ums_count, controller_index); if (rc) { pr_err("fsg_init failed\n"); rc = CMD_RET_FAILURE; diff --git a/drivers/usb/gadget/f_mass_storage.c b/drivers/usb/gadget/f_mass_storage.c index 439a31c255..45f0504b6e 100644 --- a/drivers/usb/gadget/f_mass_storage.c +++ b/drivers/usb/gadget/f_mass_storage.c @@ -435,6 +435,7 @@ static void set_bulk_out_req_length(struct fsg_common *common, static struct ums *ums; static int ums_count; static struct fsg_common *the_fsg_common; +static unsigned int controller_index;
static int fsg_set_halt(struct fsg_dev *fsg, struct usb_ep *ep) { @@ -679,7 +680,7 @@ static int sleep_thread(struct fsg_common *common) k = 0; }
- usb_gadget_handle_interrupts(0); + usb_gadget_handle_interrupts(controller_index); } common->thread_wakeup_needed = 0; return rc; @@ -2764,10 +2765,11 @@ int fsg_add(struct usb_configuration *c) return fsg_bind_config(c->cdev, c, fsg_common); }
-int fsg_init(struct ums *ums_devs, int count) +int fsg_init(struct ums *ums_devs, int count, unsigned int controller_idx) { ums = ums_devs; ums_count = count; + controller_index = controller_idx;
return 0; } diff --git a/include/usb_mass_storage.h b/include/usb_mass_storage.h index c7b770fa3e..08ccc97cf2 100644 --- a/include/usb_mass_storage.h +++ b/include/usb_mass_storage.h @@ -25,7 +25,7 @@ struct ums { struct blk_desc block_dev; };
-int fsg_init(struct ums *ums_devs, int count); +int fsg_init(struct ums *ums_devs, int count, unsigned int controller_idx); void fsg_cleanup(void); int fsg_main_thread(void *); int fsg_add(struct usb_configuration *c);
Peng Fan
