[U-Boot] SPL Platdata howto?
while searching for bytes to save in SPL in order to add FIT signature handling, I am currently trying to get socfpga-gen5 to use OF_PLATDATA.
To begin, I stripped down socfpga_socrates_defconfig to absolutely nothing but serial drivers in SPL (with some modifications to the Kconfig) and enabled DEBUG_UART to see what's going on.
Now while this config runs OK with a dtb (it just won't boot as drivers are missing -> "failed to boot from all boot devices"), it does not find the serial driver after enabling OF_PLATDATA.
So since serial_rockchip.c already uses OF_PLATDATA and is based on ns16550 that my socfpga-gen5 platform is using: what do I have to do besides enabling OF_PLATDATA to get this working?
I just seems like uclass_first_device does not find any UCLASS_SERIAL deivce when OF_PLATDATA is enabled.
(And when answering this, keep in mind I need to get MMC and QSPI drivers working with OF_PLATDATA - I already fixed compiler errors in those, nothing more.)
Thanks, Simon
Hi Simon,
On Wed, 19 Dec 2018 at 14:06, Simon Goldschmidt simon.k.r.goldschmidt@gmail.com wrote:
There is the of-plat.txt README.
Basically the dtoc tool creates U_BOOT_DEVICE() declarations and links them with SPL. These should show up in your image and therefore be bound. You can call dm_dump_all() in SPL to see what what devices are bound. I presume you are calling spl_init()?
You can look at what dtoc produces. The example serial driver for Rockchip is serial_rockchip.c
Yes MMC should be OK, but QSPI might be blazing a bit of a trail.
Am 20.12.2018 um 15:49 schrieb Simon Glass:
Hi Simon,
Yes, I should have mentioned I already read that and still had those questions. Kconfig help says README.platdata though. We probably should update that link.
I saw that as an example (because I also have an ns16550 compatible on my board) but couldn't figure out why it is not bound. By debugging 'dm_scan_platdata', 'lists_bind_drivers' and 'device_bind_by_name', by now I know the driver names don't match. That is something I did not get just by reading of-plat.txt. I'll work on a patch to clarify that document.
Right now, serial works. I had to add a new platform specific driver just like serial_rockchip though. For DTS, we can pass multiple 'compatible' strings, but for platdata, we have to create multiple drivers. That's a bit strange when porting boards...
I just wanted to start with QSPI, maybe I'll do MMC first now ;-)
Thanks for your hints!
Hi Simon,
On Thu, 20 Dec 2018 at 08:03, Simon Goldschmidt simon.k.r.goldschmidt@gmail.com wrote:
Hi Simon,
Yes I'd really appreciate some patches here. It is hard to know what people won't understand and this feature could really do with a more details docs or a walk-through.
Yes it is. I'm not sure how to solve that though. Probably dtoc can be made smarter. Ideally you only need one device of each uclass in SPL.
You're welcome, happy hunting.
Am 20.12.2018 um 18:37 schrieb Simon Glass:
Hi Simon,
Hi Simon,
Would it work to use the unchanged 'compatible' string for the '.name' of U_BOOT_DEVICE generated by dtoc? Then the binding of such drivers could change from comparing names to comparing to compatibles. That would make it more DTS-like.
Then, I think we could need some kind of fallback code for properties that are optional in the DTS. Maybe we can create defines for each dtd struct so that drivers can test the existence of dtd sturct fields using #ifdef. [Given the special usage, I guess it's OK to assume that theses structs are only used once per DTS so that we don't have to worry about how to solve this for multiple occurrences with different optional parameters?]
Oh, and then I think dtb_platdata.py should create the dtd instances as const. I'll prepare a patch for that.
And now MMC is working just fine with very small adaptions to the current socfpga_dw_mmc driver! I only hope that this whole thing gives me the bytes I need to implement FIT signatures in SPL...
Am 20.12.2018 um 21:53 schrieb Simon Goldschmidt:
Hi Simon,
Hi Simon,
Hmm, QSPI works as well when hacking the things that the driver wants to parse from subnode properties. However, I haven't found a way to access the platform data of the spi-flash from the driver.
Maybe we need to somehow make subnodes available in the dt-platdata structs to make that work?
Hi Simon,
On Thu, 20 Dec 2018 at 14:32, Simon Goldschmidt simon.k.r.goldschmidt@gmail.com wrote:
Hi Simon,
Hi Simon,
There is support for phandles but not for parent relationships. I suppose it would not be impossible to add that in dtoc with a 'parent' pointer.
Am Fr., 21. Dez. 2018, 22:16 hat Simon Glass sjg@chromium.org geschrieben:
Hi Simon,
Hi Simon,
Hi Simon,
On Wed, 19 Dec 2018 at 14:06, Simon Goldschmidt simon.k.r.goldschmidt@gmail.com wrote: > > Hi, > > while searching for bytes to save in SPL in order to add FIT
signature
OF_PLATDATA.
> > To begin, I stripped down socfpga_socrates_defconfig to absolutely > nothing but serial drivers in SPL (with some modifications to the > Kconfig) and enabled DEBUG_UART to see what's going on. > > Now while this config runs OK with a dtb (it just won't boot as
drivers
not find
> the serial driver after enabling OF_PLATDATA. > > So since serial_rockchip.c already uses OF_PLATDATA and is based on > ns16550 that my socfpga-gen5 platform is using: what do I have to
do
> besides enabling OF_PLATDATA to get this working? > > I just seems like uclass_first_device does not find any
UCLASS_SERIAL
should
update that link.
links
are
on
by
get
document.
using
> > (And when answering this, keep in mind I need to get MMC and QSPI > drivers working with OF_PLATDATA - I already fixed compiler errors
in
SPI flash actually needs it the other way round. At least the cadence qspi driver I'm using checks for a subnode that describes the flash chip.
I'll see if I can add that to dtoc.
On Fri, Dec 21, 2018 at 10:20 PM Simon Goldschmidt simon.k.r.goldschmidt@gmail.com wrote:
Hi Simon,
Hi Simon,
Am 20.12.2018 um 15:49 schrieb Simon Glass: > Hi Simon, > > On Wed, 19 Dec 2018 at 14:06, Simon Goldschmidt > simon.k.r.goldschmidt@gmail.com wrote: >> >> Hi, >> >> while searching for bytes to save in SPL in order to add FIT signature >> handling, I am currently trying to get socfpga-gen5 to use OF_PLATDATA. >> >> To begin, I stripped down socfpga_socrates_defconfig to absolutely >> nothing but serial drivers in SPL (with some modifications to the >> Kconfig) and enabled DEBUG_UART to see what's going on. >> >> Now while this config runs OK with a dtb (it just won't boot as drivers >> are missing -> "failed to boot from all boot devices"), it does not find >> the serial driver after enabling OF_PLATDATA. >> >> So since serial_rockchip.c already uses OF_PLATDATA and is based on >> ns16550 that my socfpga-gen5 platform is using: what do I have to do >> besides enabling OF_PLATDATA to get this working? >> >> I just seems like uclass_first_device does not find any UCLASS_SERIAL >> deivce when OF_PLATDATA is enabled. > > There is the of-plat.txt README.
> Basically the dtoc tool creates U_BOOT_DEVICE() declarations and links > them with SPL. These should show up in your image and therefore be > bound. You can call dm_dump_all() in SPL to see what what devices are > bound. I presume you are calling spl_init()? > > You can look at what dtoc produces. The example serial driver for > Rockchip is serial_rockchip.c
> >> >> (And when answering this, keep in mind I need to get MMC and QSPI >> drivers working with OF_PLATDATA - I already fixed compiler errors in >> those, nothing more.) > > Yes MMC should be OK, but QSPI might be blazing a bit of a trail.
By now I have SPI successfully running with platdata by adding child arrays to the platdata struct via dtoc.
However, probing the flash chip is not found in 'spi_get_bus_and_cs' and so the transfer falls back to 100 kHz, which is of course bad. That code expects a udevice child under the spi udevice. Looks like that needs more changes than just in dtoc?
Did you have SPI running with platdata on any board, yet?
Hi Simon,
On Fri, 4 Jan 2019 at 00:15, Simon Goldschmidt simon.k.r.goldschmidt@gmail.com wrote:
Hi Simon,
Hi Simon,
On Thu, 20 Dec 2018 at 08:03, Simon Goldschmidt simon.k.r.goldschmidt@gmail.com wrote: > > Am 20.12.2018 um 15:49 schrieb Simon Glass: >> Hi Simon, >> >> On Wed, 19 Dec 2018 at 14:06, Simon Goldschmidt >> simon.k.r.goldschmidt@gmail.com wrote: >>> >>> Hi, >>> >>> while searching for bytes to save in SPL in order to add FIT signature >>> handling, I am currently trying to get socfpga-gen5 to use OF_PLATDATA. >>> >>> To begin, I stripped down socfpga_socrates_defconfig to absolutely >>> nothing but serial drivers in SPL (with some modifications to the >>> Kconfig) and enabled DEBUG_UART to see what's going on. >>> >>> Now while this config runs OK with a dtb (it just won't boot as drivers >>> are missing -> "failed to boot from all boot devices"), it does not find >>> the serial driver after enabling OF_PLATDATA. >>> >>> So since serial_rockchip.c already uses OF_PLATDATA and is based on >>> ns16550 that my socfpga-gen5 platform is using: what do I have to do >>> besides enabling OF_PLATDATA to get this working? >>> >>> I just seems like uclass_first_device does not find any UCLASS_SERIAL >>> deivce when OF_PLATDATA is enabled. >> >> There is the of-plat.txt README. > > Yes, I should have mentioned I already read that and still had those > questions. Kconfig help says README.platdata though. We probably should > update that link. > >> Basically the dtoc tool creates U_BOOT_DEVICE() declarations and links >> them with SPL. These should show up in your image and therefore be >> bound. You can call dm_dump_all() in SPL to see what what devices are >> bound. I presume you are calling spl_init()? >> >> You can look at what dtoc produces. The example serial driver for >> Rockchip is serial_rockchip.c > > I saw that as an example (because I also have an ns16550 compatible on > my board) but couldn't figure out why it is not bound. By debugging > 'dm_scan_platdata', 'lists_bind_drivers' and 'device_bind_by_name', by > now I know the driver names don't match. That is something I did not get > just by reading of-plat.txt. I'll work on a patch to clarify that document.
> > Right now, serial works. I had to add a new platform specific driver > just like serial_rockchip though. For DTS, we can pass multiple > 'compatible' strings, but for platdata, we have to create multiple > drivers. That's a bit strange when porting boards...
> >> >>> >>> (And when answering this, keep in mind I need to get MMC and QSPI >>> drivers working with OF_PLATDATA - I already fixed compiler errors in >>> those, nothing more.) >> >> Yes MMC should be OK, but QSPI might be blazing a bit of a trail.
No. The implementation does not deal well with parent/child relationships, as with buses, and in every case we need to make changes.
That said, spi_get_bus_and_cs() is only used if you don't have the SPI device in the DT.
On Thu, Jan 10, 2019 at 1:57 PM Simon Glass sjg@chromium.org wrote:
Hi Simon,
Hi Simon,
Am 20.12.2018 um 18:37 schrieb Simon Glass: > Hi Simon, > > On Thu, 20 Dec 2018 at 08:03, Simon Goldschmidt > simon.k.r.goldschmidt@gmail.com wrote: >> >> Am 20.12.2018 um 15:49 schrieb Simon Glass: >>> Hi Simon, >>> >>> On Wed, 19 Dec 2018 at 14:06, Simon Goldschmidt >>> simon.k.r.goldschmidt@gmail.com wrote: >>>> >>>> Hi, >>>> >>>> while searching for bytes to save in SPL in order to add FIT signature >>>> handling, I am currently trying to get socfpga-gen5 to use OF_PLATDATA. >>>> >>>> To begin, I stripped down socfpga_socrates_defconfig to absolutely >>>> nothing but serial drivers in SPL (with some modifications to the >>>> Kconfig) and enabled DEBUG_UART to see what's going on. >>>> >>>> Now while this config runs OK with a dtb (it just won't boot as drivers >>>> are missing -> "failed to boot from all boot devices"), it does not find >>>> the serial driver after enabling OF_PLATDATA. >>>> >>>> So since serial_rockchip.c already uses OF_PLATDATA and is based on >>>> ns16550 that my socfpga-gen5 platform is using: what do I have to do >>>> besides enabling OF_PLATDATA to get this working? >>>> >>>> I just seems like uclass_first_device does not find any UCLASS_SERIAL >>>> deivce when OF_PLATDATA is enabled. >>> >>> There is the of-plat.txt README. >> >> Yes, I should have mentioned I already read that and still had those >> questions. Kconfig help says README.platdata though. We probably should >> update that link. >> >>> Basically the dtoc tool creates U_BOOT_DEVICE() declarations and links >>> them with SPL. These should show up in your image and therefore be >>> bound. You can call dm_dump_all() in SPL to see what what devices are >>> bound. I presume you are calling spl_init()? >>> >>> You can look at what dtoc produces. The example serial driver for >>> Rockchip is serial_rockchip.c >> >> I saw that as an example (because I also have an ns16550 compatible on >> my board) but couldn't figure out why it is not bound. By debugging >> 'dm_scan_platdata', 'lists_bind_drivers' and 'device_bind_by_name', by >> now I know the driver names don't match. That is something I did not get >> just by reading of-plat.txt. I'll work on a patch to clarify that document. > > Yes I'd really appreciate some patches here. It is hard to know what > people won't understand and this feature could really do with a more > details docs or a walk-through. > >> >> Right now, serial works. I had to add a new platform specific driver >> just like serial_rockchip though. For DTS, we can pass multiple >> 'compatible' strings, but for platdata, we have to create multiple >> drivers. That's a bit strange when porting boards... > > Yes it is. I'm not sure how to solve that though. Probably dtoc can be > made smarter. Ideally you only need one device of each uclass in SPL.
> >> >>> >>>> >>>> (And when answering this, keep in mind I need to get MMC and QSPI >>>> drivers working with OF_PLATDATA - I already fixed compiler errors in >>>> those, nothing more.) >>> >>> Yes MMC should be OK, but QSPI might be blazing a bit of a trail.
I had done those changes to dtoc, but as Marek seems so opposed to getting this integrated for socfpga, I don't know if I'll continue down that road...
Hmm, I thought the way that spl_spi.c uses the spi flash framework would result in spi_get_bus_and_cs() being used. I'll need to check that again.
Simon Goldschmidt
