[U-Boot] [PATCH] treewide: fix "followings" to "following"
Most of them are my mistakes.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/mach-uniphier/dram/cmd_ddrmphy.c | 2 +- arch/arm/mach-uniphier/dram/cmd_ddrphy.c | 2 +- board/freescale/ls2080aqds/README | 2 +- doc/README.kconfig | 2 +- tools/moveconfig.py | 4 ++-- 5 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-uniphier/dram/cmd_ddrmphy.c b/arch/arm/mach-uniphier/dram/cmd_ddrmphy.c index 7ac9378..47cee6f 100644 --- a/arch/arm/mach-uniphier/dram/cmd_ddrmphy.c +++ b/arch/arm/mach-uniphier/dram/cmd_ddrmphy.c @@ -304,7 +304,7 @@ static int do_ddrm(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) U_BOOT_CMD( ddrm, 2, 1, do_ddrm, "UniPhier DDR PHY parameters dumper", - "- dump all of the followings\n" + "- dump all of the following\n" "ddrm zq - dump Impedance Data\n" "ddrm wbdl - dump Write Bit Delay\n" "ddrm rbdl - dump Read Bit Delay\n" diff --git a/arch/arm/mach-uniphier/dram/cmd_ddrphy.c b/arch/arm/mach-uniphier/dram/cmd_ddrphy.c index 0a5a73d..6ac261d 100644 --- a/arch/arm/mach-uniphier/dram/cmd_ddrphy.c +++ b/arch/arm/mach-uniphier/dram/cmd_ddrphy.c @@ -258,7 +258,7 @@ static int do_ddr(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) U_BOOT_CMD( ddr, 2, 1, do_ddr, "UniPhier DDR PHY parameters dumper", - "- dump all of the followings\n" + "- dump all of the following\n" "ddr wbdl - dump Write Bit Delay\n" "ddr rbdl - dump Read Bit Delay\n" "ddr wld - dump Write Leveling\n" diff --git a/board/freescale/ls2080aqds/README b/board/freescale/ls2080aqds/README index 5c98866..f288750 100644 --- a/board/freescale/ls2080aqds/README +++ b/board/freescale/ls2080aqds/README @@ -112,7 +112,7 @@ X-QSGMII-16PORT riser card ---------------------------- The X-QSGMII-16PORT is a 4xQSGMII/8xSGMII riser card with eighth SerDes interfaces implemented in PCIe form factor board. -It supports followings +It supports following: - Card can operate with up to 4 QSGMII lane simultaneously - Card can operate with up to 8 SGMII lane simultaneously
diff --git a/doc/README.kconfig b/doc/README.kconfig index 288d17d..0689f66 100644 --- a/doc/README.kconfig +++ b/doc/README.kconfig @@ -22,7 +22,7 @@ Here are some worth-mentioning configuration targets. - silentoldconfig
This target updates .config, include/generated/autoconf.h and - include/configs/* as in Linux. In U-Boot, it also does the followings + include/configs/* as in Linux. In U-Boot, it also does the following for the compatibility with the old configuration system:
* create a symbolic link "arch/${ARCH}/include/asm/arch" pointing to diff --git a/tools/moveconfig.py b/tools/moveconfig.py index aaa8e96..5374065 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -41,7 +41,7 @@ The log is printed for each defconfig as follows: <defconfig_name> is the name of the defconfig.
<action*> shows what the tool did for that defconfig. -It looks like one of the followings: +It looks like one of the following:
- Move 'CONFIG_... ' This config option was moved to the defconfig @@ -179,7 +179,7 @@ SLEEP_TIME=0.03
# Here is the list of cross-tools I use. # Most of them are available at kernel.org -# (https://www.kernel.org/pub/tools/crosstool/files/bin/), except the followings: +# (https://www.kernel.org/pub/tools/crosstool/files/bin/), except the following: # arc: https://github.com/foss-for-synopsys-dwc-arc-processors/toolchain/releases # blackfin: http://sourceforge.net/projects/adi-toolchain/files/ # nds32: http://osdk.andestech.com/packages/nds32le-linux-glibc-v1.tgz
Masahiro Yamada
