[U-Boot] u-boot and xupv2p problem
Hi all,
I want to install u-boot on the xupv2p board embedding a ppc405 processor.
I have some questions before doing this:
1. Which configuration do I have to use:
make ml300_config or
make xupv2p_config
2. Do I have to change the ~/u-boot/board/xilinx/ml300/xparameters.h file
in accordance to informations generated by EDK.
Thanks
Hi all,
make xupv2p_config
Thanks
Hi Xavier,
Hi all,
First of all - do not send your messages twice.
- Which configuration do I have to use:
make xupv2p_config
If is xupv2p_config available you use old version. Please update to latest version. xupv2p board was for Microblaze CPU. ml300 is the right starting platform for you.
- Do I have to change the ~/u-boot/board/xilinx/ml300/xparameters.h file
:-) EDK generate a lot of information. It depends on your design. But IMHO in 99,9% you have to change it. There is generic ppc405 platform too.
Regards, Michal
Thanks
Michal Simek
xavier vvv
