[PATCH 1/2] ARM: dts: sama5d4: fix gadget endpoint address warning
arch/arm/dts/at91-sama5d4ek.dtb: Warning (graph_endpoint): /ahb/gadget@00400000/endpoint@10: graph node unit address error, expected "a" arch/arm/dts/at91-sama5d4ek.dtb: Warning (graph_endpoint): /ahb/gadget@00400000/endpoint@11: graph node unit address error, expected "b" arch/arm/dts/at91-sama5d4ek.dtb: Warning (graph_endpoint): /ahb/gadget@00400000/endpoint@12: graph node unit address error, expected "c" arch/arm/dts/at91-sama5d4ek.dtb: Warning (graph_endpoint): /ahb/gadget@00400000/endpoint@13: graph node unit address error, expected "d" arch/arm/dts/at91-sama5d4ek.dtb: Warning (graph_endpoint): /ahb/gadget@00400000/endpoint@14: graph node unit address error, expected "e" arch/arm/dts/at91-sama5d4ek.dtb: Warning (graph_endpoint): /ahb/gadget@00400000/endpoint@15: graph node unit address error, expected "f"
Fixed by changing address in node name to hex.
Signed-off-by: Eugen Hristev eugen.hristev@microchip.com --- arch/arm/dts/sama5d4.dtsi | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/arm/dts/sama5d4.dtsi b/arch/arm/dts/sama5d4.dtsi index 8875d7ba76..e1df24cdbe 100644 --- a/arch/arm/dts/sama5d4.dtsi +++ b/arch/arm/dts/sama5d4.dtsi @@ -212,42 +212,42 @@ atmel,can-isoc; };
- ep10: endpoint@10 { + ep10: endpoint@a { reg = <10>; atmel,fifo-size = <1024>; atmel,nb-banks = <2>; atmel,can-isoc; };
- ep11: endpoint@11 { + ep11: endpoint@b { reg = <11>; atmel,fifo-size = <1024>; atmel,nb-banks = <2>; atmel,can-isoc; };
- ep12: endpoint@12 { + ep12: endpoint@c { reg = <12>; atmel,fifo-size = <1024>; atmel,nb-banks = <2>; atmel,can-isoc; };
- ep13: endpoint@13 { + ep13: endpoint@d { reg = <13>; atmel,fifo-size = <1024>; atmel,nb-banks = <2>; atmel,can-isoc; };
- ep14: endpoint@14 { + ep14: endpoint@e { reg = <14>; atmel,fifo-size = <1024>; atmel,nb-banks = <2>; atmel,can-isoc; };
- ep15: endpoint@15 { + ep15: endpoint@f { reg = <15>; atmel,fifo-size = <1024>; atmel,nb-banks = <2>;
arch/arm/dts/sama5d36ek.dtb: Warning (graph_endpoint): /ahb/gadget@00500000/endpoint@10: graph node unit address error, expected "a" arch/arm/dts/sama5d36ek.dtb: Warning (graph_endpoint): /ahb/gadget@00500000/endpoint@11: graph node unit address error, expected "b" arch/arm/dts/sama5d36ek.dtb: Warning (graph_endpoint): /ahb/gadget@00500000/endpoint@12: graph node unit address error, expected "c" arch/arm/dts/sama5d36ek.dtb: Warning (graph_endpoint): /ahb/gadget@00500000/endpoint@13: graph node unit address error, expected "d" arch/arm/dts/sama5d36ek.dtb: Warning (graph_endpoint): /ahb/gadget@00500000/endpoint@14: graph node unit address error, expected "e" arch/arm/dts/sama5d36ek.dtb: Warning (graph_endpoint): /ahb/gadget@00500000/endpoint@15: graph node unit address error, expected "f"
Signed-off-by: Eugen Hristev eugen.hristev@microchip.com --- arch/arm/dts/sama5d3.dtsi | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/arm/dts/sama5d3.dtsi b/arch/arm/dts/sama5d3.dtsi index 7db66c5d50..6ed218eaad 100644 --- a/arch/arm/dts/sama5d3.dtsi +++ b/arch/arm/dts/sama5d3.dtsi @@ -1447,37 +1447,37 @@ atmel,nb-banks = <2>; };
- ep10: endpoint@10 { + ep10: endpoint@a { reg = <10>; atmel,fifo-size = <1024>; atmel,nb-banks = <2>; };
- ep11: endpoint@11 { + ep11: endpoint@b { reg = <11>; atmel,fifo-size = <1024>; atmel,nb-banks = <2>; };
- ep12: endpoint@12 { + ep12: endpoint@c { reg = <12>; atmel,fifo-size = <1024>; atmel,nb-banks = <2>; };
- ep13: endpoint@13 { + ep13: endpoint@d { reg = <13>; atmel,fifo-size = <1024>; atmel,nb-banks = <2>; };
- ep14: endpoint@14 { + ep14: endpoint@e { reg = <14>; atmel,fifo-size = <1024>; atmel,nb-banks = <2>; };
Applied both to u-boot-atmel/master
Eugen Hristev
Eugen.Hristev@microchip.com
