[U-Boot] [PATCH 2/6 v2] 8xx, icache: enabling ICache not before running from RAM
with the new CONFIG_SYS_DELAYED_ICACHE config option, ICache is not enabled before code runs from RAM.
Signed-off-by: Heiko Schocher hs@denx.de --- README | 5 +++++ cpu/mpc8xx/start.S | 2 +- include/configs/FLAGADM.h | 3 +++ include/configs/IP860.h | 3 +++ include/configs/pcu_e.h | 3 +++ lib_ppc/board.c | 3 +-- 6 files changed, 16 insertions(+), 3 deletions(-)
diff --git a/README b/README index 43fb1c0..46181a4 100644 --- a/README +++ b/README @@ -318,6 +318,11 @@ The following options need to be configured: that this requires a (stable) reference clock (32 kHz RTC clock or CONFIG_SYS_8XX_XIN)
+ CONFIG_SYS_DELAYED_ICACHE + + Define this option if you want to enable the + ICache only when Code runs from RAM. + - Intel Monahans options: CONFIG_SYS_MONAHANS_RUN_MODE_OSC_RATIO
diff --git a/cpu/mpc8xx/start.S b/cpu/mpc8xx/start.S index 45c902e..8864c37 100644 --- a/cpu/mpc8xx/start.S +++ b/cpu/mpc8xx/start.S @@ -142,7 +142,7 @@ boot_warm: lis r3, IDC_DISABLE@h /* Disable data cache */ mtspr DC_CST, r3
-#if !(defined(CONFIG_IP860) || defined(CONFIG_PCU_E) || defined (CONFIG_FLAGADM)) +#if !defined(CONFIG_SYS_DELAYED_ICACHE) /* On IP860 and PCU E, * we cannot enable IC yet */ diff --git a/include/configs/FLAGADM.h b/include/configs/FLAGADM.h index d831238..0f4277c 100644 --- a/include/configs/FLAGADM.h +++ b/include/configs/FLAGADM.h @@ -173,6 +173,9 @@ #if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif +#define CONFIG_SYS_DELAYED_ICACHE 1 /* enable ICache not before + * running in RAM. + */
/*----------------------------------------------------------------------- * SYPCR - System Protection Control 11-9 diff --git a/include/configs/IP860.h b/include/configs/IP860.h index b9c5713..125aa6c 100644 --- a/include/configs/IP860.h +++ b/include/configs/IP860.h @@ -209,6 +209,9 @@ #if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif +#define CONFIG_SYS_DELAYED_ICACHE 1 /* enable ICache not before + * running in RAM. + */
/*----------------------------------------------------------------------- * SYPCR - System Protection Control 11-9 diff --git a/include/configs/pcu_e.h b/include/configs/pcu_e.h index 9214519..7c2bf1b 100644 --- a/include/configs/pcu_e.h +++ b/include/configs/pcu_e.h @@ -246,6 +246,9 @@ */ #define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ #define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ +#define CONFIG_SYS_DELAYED_ICACHE 1 /* enable ICache not before + * running in RAM. + */
/*----------------------------------------------------------------------- * SYPCR - System Protection Control 11-9 diff --git a/lib_ppc/board.c b/lib_ppc/board.c index 6d29303..f69c5f4 100644 --- a/lib_ppc/board.c +++ b/lib_ppc/board.c @@ -736,8 +736,7 @@ void board_init_r (gd_t *id, ulong dest_addr)
WATCHDOG_RESET();
-#if defined(CONFIG_IP860) || defined(CONFIG_PCU_E) || \ - defined (CONFIG_FLAGADM) || defined(CONFIG_MPC83XX) +#if defined(CONFIG_SYS_DELAYED_ICACHE) || defined(CONFIG_MPC83XX) icache_enable (); /* it's time to enable the instruction cache */ #endif
Dear Heiko Schocher,
Applied, thanks.
Heiko Schocher
