[U-Boot] [PATCH] arm: dts: amX/draX: fix DTC unit name warnings
Fi all DTC warnings for TI boards.
Signed-off-by: Heiko Schocher hs@denx.de --- This warnings pop up with the DTC compiler: $ /tmp/dtc/dtc -v Version: DTC 1.4.1-gbeef80b8
This fixes the compile warnings for: https://travis-ci.org/hsdenx/u-boot/jobs/123238798
see: https://travis-ci.org/hsdenx/u-boot/jobs/123254198
arch/arm/dts/am335x-bone-common.dtsi | 12 +- arch/arm/dts/am335x-evm.dts | 16 +- arch/arm/dts/am33xx-clocks.dtsi | 90 ++++----- arch/arm/dts/am33xx.dtsi | 4 +- arch/arm/dts/am4372.dtsi | 10 +- arch/arm/dts/am437x-gp-evm.dts | 4 +- arch/arm/dts/am437x-sk-evm.dts | 12 +- arch/arm/dts/am43xx-clocks.dtsi | 114 +++++------ arch/arm/dts/am57xx-beagle-x15.dts | 10 +- arch/arm/dts/dra7-evm.dts | 2 +- arch/arm/dts/dra7.dtsi | 16 +- arch/arm/dts/dra72-evm.dts | 2 +- arch/arm/dts/dra74x.dtsi | 2 +- arch/arm/dts/dra7xx-clocks.dtsi | 370 +++++++++++++++++------------------ arch/arm/dts/k2e-clocks.dtsi | 8 +- arch/arm/dts/k2e-netcp.dtsi | 6 +- arch/arm/dts/k2e.dtsi | 2 +- arch/arm/dts/k2g-netcp.dtsi | 6 +- arch/arm/dts/k2g.dtsi | 4 +- arch/arm/dts/k2hk-clocks.dtsi | 74 +++---- arch/arm/dts/k2hk-netcp.dtsi | 8 +- arch/arm/dts/k2hk.dtsi | 16 +- arch/arm/dts/k2l-clocks.dtsi | 44 ++--- arch/arm/dts/k2l-netcp.dtsi | 6 +- arch/arm/dts/k2l.dtsi | 8 +- arch/arm/dts/keystone-clocks.dtsi | 52 ++--- arch/arm/dts/keystone.dtsi | 6 +- 27 files changed, 452 insertions(+), 452 deletions(-)
diff --git a/arch/arm/dts/am335x-bone-common.dtsi b/arch/arm/dts/am335x-bone-common.dtsi index fec7834..68d87ca 100644 --- a/arch/arm/dts/am335x-bone-common.dtsi +++ b/arch/arm/dts/am335x-bone-common.dtsi @@ -13,7 +13,7 @@ }; };
- memory { + memory@80000000 { device_type = "memory"; reg = <0x80000000 0x10000000>; /* 256 MB */ }; @@ -24,28 +24,28 @@
compatible = "gpio-leds";
- led@2 { + led2 { label = "beaglebone:green:heartbeat"; gpios = <&gpio1 21 GPIO_ACTIVE_HIGH>; linux,default-trigger = "heartbeat"; default-state = "off"; };
- led@3 { + led3 { label = "beaglebone:green:mmc0"; gpios = <&gpio1 22 GPIO_ACTIVE_HIGH>; linux,default-trigger = "mmc0"; default-state = "off"; };
- led@4 { + led4 { label = "beaglebone:green:usr2"; gpios = <&gpio1 23 GPIO_ACTIVE_HIGH>; linux,default-trigger = "cpu0"; default-state = "off"; };
- led@5 { + led5 { label = "beaglebone:green:usr3"; gpios = <&gpio1 24 GPIO_ACTIVE_HIGH>; linux,default-trigger = "mmc1"; @@ -53,7 +53,7 @@ }; };
- vmmcsd_fixed: fixedregulator@0 { + vmmcsd_fixed: fixedregulator { compatible = "regulator-fixed"; regulator-name = "vmmcsd_fixed"; regulator-min-microvolt = <3300000>; diff --git a/arch/arm/dts/am335x-evm.dts b/arch/arm/dts/am335x-evm.dts index c0bc2af..f9cdcdb 100644 --- a/arch/arm/dts/am335x-evm.dts +++ b/arch/arm/dts/am335x-evm.dts @@ -25,12 +25,12 @@ }; };
- vbat: fixedregulator@0 { + vbat: fixedregulator0 { compatible = "regulator-fixed"; regulator-name = "vbat"; regulator-min-microvolt = <5000000>; @@ -38,13 +38,13 @@ regulator-boot-on; };
- lis3_reg: fixedregulator@1 { + lis3_reg: fixedregulator1 { compatible = "regulator-fixed"; regulator-name = "lis3_reg"; regulator-boot-on; };
- wlan_en_reg: fixedregulator@2 { + wlan_en_reg: fixedregulator2 { compatible = "regulator-fixed"; regulator-name = "wlan-en-regulator"; regulator-min-microvolt = <1800000>; @@ -58,7 +58,7 @@ enable-active-high; };
- matrix_keypad: matrix_keypad@0 { + matrix_keypad: matrix_keypad { compatible = "gpio-matrix-keypad"; debounce-delay-ms = <5>; col-scan-delay-us = <2>; @@ -78,20 +78,20 @@ 0x0201006c>; /* DOWN */ };
- gpio_keys: volume_keys@0 { + gpio_keys: volume_keys0 { compatible = "gpio-keys"; #address-cells = <1>; #size-cells = <0>; autorepeat;
- switch@9 { + switch9 { label = "volume-up"; linux,code = <115>; gpios = <&gpio0 2 GPIO_ACTIVE_LOW>; gpio-key,wakeup; };
- switch@10 { + switch10 { label = "volume-down"; linux,code = <114>; gpios = <&gpio0 3 GPIO_ACTIVE_LOW>; diff --git a/arch/arm/dts/am33xx-clocks.dtsi b/arch/arm/dts/am33xx-clocks.dtsi index afb4b3a..7f65ba6 100644 --- a/arch/arm/dts/am33xx-clocks.dtsi +++ b/arch/arm/dts/am33xx-clocks.dtsi @@ -8,7 +8,7 @@ * published by the Free Software Foundation. */ &scm_clocks { - sys_clkin_ck: sys_clkin_ck { + sys_clkin_ck: sys_clkin_ck@40{ #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&virt_19200000_ck>, <&virt_24000000_ck>, <&virt_25000000_ck>, <&virt_26000000_ck>; @@ -163,7 +163,7 @@ clock-frequency = <12000000>; };
- dpll_core_ck: dpll_core_ck { + dpll_core_ck: dpll_core_ck@490 { #clock-cells = <0>; compatible = "ti,am3-dpll-core-clock"; clocks = <&sys_clkin_ck>, <&sys_clkin_ck>; @@ -176,7 +176,7 @@ clocks = <&dpll_core_ck>; };
- dpll_core_m4_ck: dpll_core_m4_ck { + dpll_core_m4_ck: dpll_core_m4_ck@480 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_core_x2_ck>; @@ -185,7 +185,7 @@ ti,index-starts-at-one; };
- dpll_core_m5_ck: dpll_core_m5_ck { + dpll_core_m5_ck: dpll_core_m5_ck@484 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_core_x2_ck>; @@ -194,7 +194,7 @@ ti,index-starts-at-one; };
- dpll_core_m6_ck: dpll_core_m6_ck { + dpll_core_m6_ck: dpll_core_m6_ck@4d8 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_core_x2_ck>; @@ -203,14 +203,14 @@ ti,index-starts-at-one; };
- dpll_mpu_ck: dpll_mpu_ck { + dpll_mpu_ck: dpll_mpu_ck@488 { #clock-cells = <0>; compatible = "ti,am3-dpll-clock"; clocks = <&sys_clkin_ck>, <&sys_clkin_ck>; reg = <0x0488>, <0x0420>, <0x042c>; };
- dpll_mpu_m2_ck: dpll_mpu_m2_ck { + dpll_mpu_m2_ck: dpll_mpu_m2_ck@4a8 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_mpu_ck>; @@ -219,14 +219,14 @@ ti,index-starts-at-one; };
- dpll_ddr_ck: dpll_ddr_ck { + dpll_ddr_ck: dpll_ddr_ck@494 { #clock-cells = <0>; compatible = "ti,am3-dpll-no-gate-clock"; clocks = <&sys_clkin_ck>, <&sys_clkin_ck>; reg = <0x0494>, <0x0434>, <0x0440>; };
- dpll_ddr_m2_ck: dpll_ddr_m2_ck { + dpll_ddr_m2_ck: dpll_ddr_m2_ck@4a0 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_ddr_ck>; @@ -243,14 +243,14 @@ clock-div = <2>; };
- dpll_disp_ck: dpll_disp_ck { + dpll_disp_ck: dpll_disp_ck@498 { #clock-cells = <0>; compatible = "ti,am3-dpll-no-gate-clock"; clocks = <&sys_clkin_ck>, <&sys_clkin_ck>; reg = <0x0498>, <0x0448>, <0x0454>; };
- dpll_disp_m2_ck: dpll_disp_m2_ck { + dpll_disp_m2_ck: dpll_disp_m2_ck@4a4 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_disp_ck>; @@ -260,14 +260,14 @@ ti,set-rate-parent; };
- dpll_per_ck: dpll_per_ck { + dpll_per_ck: dpll_per_ck@48c { #clock-cells = <0>; compatible = "ti,am3-dpll-no-gate-j-type-clock"; clocks = <&sys_clkin_ck>, <&sys_clkin_ck>; reg = <0x048c>, <0x0470>, <0x049c>; };
- dpll_per_m2_ck: dpll_per_m2_ck { + dpll_per_m2_ck: dpll_per_m2_ck@4ac { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_per_ck>; @@ -292,7 +292,7 @@ clock-div = <4>; };
- cefuse_fck: cefuse_fck { + cefuse_fck: cefuse_fck@a20 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&sys_clkin_ck>; @@ -316,7 +316,7 @@ clock-div = <732>; };
- clkdiv32k_ick: clkdiv32k_ick { + clkdiv32k_ick: clkdiv32k_ick@14c { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&clkdiv32k_ck>; @@ -332,14 +332,14 @@ clock-div = <1>; };
- pruss_ocp_gclk: pruss_ocp_gclk { + pruss_ocp_gclk: pruss_ocp_gclk@530 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&l3_gclk>, <&dpll_disp_m2_ck>; reg = <0x0530>; };
- mmu_fck: mmu_fck { + mmu_fck: mmu_fck@914 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&dpll_core_m4_ck>; @@ -347,56 +347,56 @@ reg = <0x0914>; };
- timer1_fck: timer1_fck { + timer1_fck: timer1_fck@528 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sys_clkin_ck>, <&clkdiv32k_ick>, <&tclkin_ck>, <&clk_rc32k_ck>, <&clk_32768_ck>; reg = <0x0528>; };
- timer2_fck: timer2_fck { + timer2_fck: timer2_fck@508 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&tclkin_ck>, <&sys_clkin_ck>, <&clkdiv32k_ick>; reg = <0x0508>; };
- timer3_fck: timer3_fck { + timer3_fck: timer3_fck@50c { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&tclkin_ck>, <&sys_clkin_ck>, <&clkdiv32k_ick>; reg = <0x050c>; };
- timer4_fck: timer4_fck { + timer4_fck: timer4_fck@510 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&tclkin_ck>, <&sys_clkin_ck>, <&clkdiv32k_ick>; reg = <0x0510>; };
- timer5_fck: timer5_fck { + timer5_fck: timer5_fck@518 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&tclkin_ck>, <&sys_clkin_ck>, <&clkdiv32k_ick>; reg = <0x0518>; };
- timer6_fck: timer6_fck { + timer6_fck: timer6_fck@51c { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&tclkin_ck>, <&sys_clkin_ck>, <&clkdiv32k_ick>; reg = <0x051c>; };
- timer7_fck: timer7_fck { + timer7_fck: timer7_fck@504 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&tclkin_ck>, <&sys_clkin_ck>, <&clkdiv32k_ick>; reg = <0x0504>; };
- usbotg_fck: usbotg_fck { + usbotg_fck: usbotg_fck@47c { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&dpll_per_ck>; @@ -412,7 +412,7 @@ clock-div = <2>; };
- ieee5000_fck: ieee5000_fck { + ieee5000_fck: ieee5000_fck@e4 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&dpll_core_m4_div2_ck>; @@ -420,7 +420,7 @@ reg = <0x00e4>; };
- wdt1_fck: wdt1_fck { + wdt1_fck: wdt1_fck@538 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&clk_rc32k_ck>, <&clkdiv32k_ick>; @@ -483,21 +483,21 @@ clock-div = <2>; };
- cpsw_cpts_rft_clk: cpsw_cpts_rft_clk { + cpsw_cpts_rft_clk: cpsw_cpts_rft_clk@520 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&dpll_core_m5_ck>, <&dpll_core_m4_ck>; reg = <0x0520>; };
- gpio0_dbclk_mux_ck: gpio0_dbclk_mux_ck { + gpio0_dbclk_mux_ck: gpio0_dbclk_mux_ck@530 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&clk_rc32k_ck>, <&clk_32768_ck>, <&clkdiv32k_ick>; reg = <0x053c>; };
- gpio0_dbclk: gpio0_dbclk { + gpio0_dbclk: gpio0_dbclk@408 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&gpio0_dbclk_mux_ck>; @@ -505,7 +505,7 @@ reg = <0x0408>; };
- gpio1_dbclk: gpio1_dbclk { + gpio1_dbclk: gpio1_dbclk@ac { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&clkdiv32k_ick>; @@ -513,7 +513,7 @@ reg = <0x00ac>; };
- gpio2_dbclk: gpio2_dbclk { + gpio2_dbclk: gpio2_dbclk@b0 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&clkdiv32k_ick>; @@ -521,7 +521,7 @@ reg = <0x00b0>; };
- gpio3_dbclk: gpio3_dbclk { + gpio3_dbclk: gpio3_dbclk@b4 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&clkdiv32k_ick>; @@ -529,7 +529,7 @@ reg = <0x00b4>; };
- lcd_gclk: lcd_gclk { + lcd_gclk: lcd_gclk@534 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&dpll_disp_m2_ck>, <&dpll_core_m5_ck>, <&dpll_per_m2_ck>; @@ -545,7 +545,7 @@ clock-div = <2>; };
- gfx_fclk_clksel_ck: gfx_fclk_clksel_ck { + gfx_fclk_clksel_ck: gfx_fclk_clksel_ck@52c { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&dpll_core_m4_ck>, <&dpll_per_m2_ck>; @@ -553,7 +553,7 @@ reg = <0x052c>; };
- gfx_fck_div_ck: gfx_fck_div_ck { + gfx_fck_div_ck: gfx_fck_div_ck@52c { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&gfx_fclk_clksel_ck>; @@ -561,14 +561,14 @@ ti,max-div = <2>; };
- sysclkout_pre_ck: sysclkout_pre_ck { + sysclkout_pre_ck: sysclkout_pre_ck@700 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&clk_32768_ck>, <&l3_gclk>, <&dpll_ddr_m2_ck>, <&dpll_per_m2_ck>, <&lcd_gclk>; reg = <0x0700>; };
- clkout2_div_ck: clkout2_div_ck { + clkout2_div_ck: clkout2_div_ck@700 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&sysclkout_pre_ck>; @@ -577,7 +577,7 @@ reg = <0x0700>; };
- dbg_sysclk_ck: dbg_sysclk_ck { + dbg_sysclk_ck: dbg_sysclk_ck@414 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&sys_clkin_ck>; @@ -585,7 +585,7 @@ reg = <0x0414>; };
- dbg_clka_ck: dbg_clka_ck { + dbg_clka_ck: dbg_clka_ck@414 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&dpll_core_m4_ck>; @@ -593,7 +593,7 @@ reg = <0x0414>; };
- stm_pmd_clock_mux_ck: stm_pmd_clock_mux_ck { + stm_pmd_clock_mux_ck: stm_pmd_clock_mux_ck@414 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&dbg_sysclk_ck>, <&dbg_clka_ck>; @@ -601,7 +601,7 @@ reg = <0x0414>; };
- trace_pmd_clk_mux_ck: trace_pmd_clk_mux_ck { + trace_pmd_clk_mux_ck: trace_pmd_clk_mux_ck@414 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&dbg_sysclk_ck>, <&dbg_clka_ck>; @@ -609,7 +609,7 @@ reg = <0x0414>; };
- stm_clk_div_ck: stm_clk_div_ck { + stm_clk_div_ck: stm_clk_div_ck@414 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&stm_pmd_clock_mux_ck>; @@ -619,7 +619,7 @@ ti,index-power-of-two; };
- trace_clk_div_ck: trace_clk_div_ck { + trace_clk_div_ck: trace_clk_div_ck@414 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&trace_pmd_clk_mux_ck>; @@ -629,7 +629,7 @@ ti,index-power-of-two; };
- clkout2_ck: clkout2_ck { + clkout2_ck: clkout2_ck@700 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&clkout2_div_ck>; diff --git a/arch/arm/dts/am33xx.dtsi b/arch/arm/dts/am33xx.dtsi index b26e21b..5b77389 100644 --- a/arch/arm/dts/am33xx.dtsi +++ b/arch/arm/dts/am33xx.dtsi @@ -746,12 +746,12 @@ status = "disabled"; };
- cpsw_emac0: slave@4a100200 { + cpsw_emac0: slave_4a100200 { /* Filled in by U-Boot */ mac-address = [ 00 00 00 00 00 00 ]; };
- cpsw_emac1: slave@4a100300 { + cpsw_emac1: slave_4a100300 { /* Filled in by U-Boot */ mac-address = [ 00 00 00 00 00 00 ]; }; diff --git a/arch/arm/dts/am4372.dtsi b/arch/arm/dts/am4372.dtsi index c95d1d3..2611579 100644 --- a/arch/arm/dts/am4372.dtsi +++ b/arch/arm/dts/am4372.dtsi @@ -67,7 +67,7 @@ cache-level = <2>; };
- ocp { + ocp@0 { compatible = "ti,am4372-l3-noc", "simple-bus"; #address-cells = <1>; #size-cells = <1>; @@ -559,12 +559,12 @@ status = "disabled"; };
- cpsw_emac1: slave@4a100300 { + cpsw_emac1: slave_4a100300 { /* Filled in by U-Boot */ mac-address = [ 00 00 00 00 00 00 ]; }; @@ -821,7 +821,7 @@ reg-names = "power"; };
- ocp2scp0: ocp2scp@483a8000 { + ocp2scp0: ocp2scp_483a8000 { compatible = "ti,am437x-ocp2scp", "ti,omap-ocp2scp"; #address-cells = <1>; #size-cells = <1>; @@ -840,7 +840,7 @@ }; };
- ocp2scp1: ocp2scp@483e8000 { + ocp2scp1: ocp2scp_483e8000 { compatible = "ti,am437x-ocp2scp", "ti,omap-ocp2scp"; #address-cells = <1>; #size-cells = <1>; diff --git a/arch/arm/dts/am437x-gp-evm.dts b/arch/arm/dts/am437x-gp-evm.dts index 8e23b96..3f74f22 100644 --- a/arch/arm/dts/am437x-gp-evm.dts +++ b/arch/arm/dts/am437x-gp-evm.dts @@ -64,7 +64,7 @@ default-brightness-level = <8>; };
- matrix_keypad: matrix_keypad@0 { + matrix_keypad: matrix_keypad { compatible = "gpio-matrix-keypad"; debounce-delay-ms = <5>; col-scan-delay-us = <2>; @@ -744,7 +744,7 @@ pinctrl-0 = <&dss_pins>;
port { - dpi_out: endpoint@0 { + dpi_out: endpoint { remote-endpoint = <&lcd_in>; data-lines = <24>; }; diff --git a/arch/arm/dts/am437x-sk-evm.dts b/arch/arm/dts/am437x-sk-evm.dts index 260edb9..2d92526 100644 --- a/arch/arm/dts/am437x-sk-evm.dts +++ b/arch/arm/dts/am437x-sk-evm.dts @@ -47,7 +47,7 @@ "Headphone Jack", "HPROUT"; };
pinctrl-names = "default"; @@ -76,28 +76,28 @@ pinctrl-names = "default"; pinctrl-0 = <&leds_pins>;
- led@0 { + led_0 { label = "am437x-sk:red:heartbeat"; gpios = <&gpio5 0 GPIO_ACTIVE_HIGH>; /* Bank 5, pin 0 */ linux,default-trigger = "heartbeat"; default-state = "off"; };
- led@1 { + led_1 { label = "am437x-sk:green:mmc1"; gpios = <&gpio5 1 GPIO_ACTIVE_HIGH>; /* Bank 5, pin 1 */ linux,default-trigger = "mmc0"; default-state = "off"; };
- led@2 { + led_2 { label = "am437x-sk:blue:cpu0"; gpios = <&gpio5 2 GPIO_ACTIVE_HIGH>; /* Bank 5, pin 2 */ linux,default-trigger = "cpu0"; default-state = "off"; };
- led@3 { + led_3 { label = "am437x-sk:blue:usr3"; gpios = <&gpio5 3 GPIO_ACTIVE_HIGH>; /* Bank 5, pin 3 */ default-state = "off"; @@ -667,7 +667,7 @@ pinctrl-0 = <&dss_pins>;
port { - dpi_out: endpoint@0 { + dpi_out: endpoint { remote-endpoint = <&lcd_in>; data-lines = <24>; }; diff --git a/arch/arm/dts/am43xx-clocks.dtsi b/arch/arm/dts/am43xx-clocks.dtsi index d0c0dfa..fdc8d2b 100644 --- a/arch/arm/dts/am43xx-clocks.dtsi +++ b/arch/arm/dts/am43xx-clocks.dtsi @@ -8,7 +8,7 @@ * published by the Free Software Foundation. */ &scm_clocks { - sys_clkin_ck: sys_clkin_ck { + sys_clkin_ck: sys_clkin_ck@40 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sysboot_freq_sel_ck>, <&crystal_freq_sel_ck>; @@ -16,7 +16,7 @@ reg = <0x0040>; };
- crystal_freq_sel_ck: crystal_freq_sel_ck { + crystal_freq_sel_ck: crystal_freq_sel_ck@40 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&virt_19200000_ck>, <&virt_24000000_ck>, <&virt_25000000_ck>, <&virt_26000000_ck>; @@ -104,7 +104,7 @@ clock-div = <1>; };
- ehrpwm0_tbclk: ehrpwm0_tbclk { + ehrpwm0_tbclk: ehrpwm0_tbclk@664 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&l4ls_gclk>; @@ -112,7 +112,7 @@ reg = <0x0664>; };
- ehrpwm1_tbclk: ehrpwm1_tbclk { + ehrpwm1_tbclk: ehrpwm1_tbclk@664 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&l4ls_gclk>; @@ -120,7 +120,7 @@ reg = <0x0664>; };
- ehrpwm2_tbclk: ehrpwm2_tbclk { + ehrpwm2_tbclk: ehrpwm2_tbclk@664 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&l4ls_gclk>; @@ -128,7 +128,7 @@ reg = <0x0664>; };
- ehrpwm3_tbclk: ehrpwm3_tbclk { + ehrpwm3_tbclk: ehrpwm3_tbclk@664 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&l4ls_gclk>; @@ -136,7 +136,7 @@ reg = <0x0664>; };
- ehrpwm4_tbclk: ehrpwm4_tbclk { + ehrpwm4_tbclk: ehrpwm4_tbclk@664 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&l4ls_gclk>; @@ -144,7 +144,7 @@ reg = <0x0664>; };
- ehrpwm5_tbclk: ehrpwm5_tbclk { + ehrpwm5_tbclk: ehrpwm5_tbclk@664 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&l4ls_gclk>; @@ -195,7 +195,7 @@ clock-frequency = <26000000>; };
- dpll_core_ck: dpll_core_ck { + dpll_core_ck: dpll_core_ck@2d20 { #clock-cells = <0>; compatible = "ti,am3-dpll-core-clock"; clocks = <&sys_clkin_ck>, <&sys_clkin_ck>; @@ -208,7 +208,7 @@ clocks = <&dpll_core_ck>; };
- dpll_core_m4_ck: dpll_core_m4_ck { + dpll_core_m4_ck: dpll_core_m4_ck@2d38 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_core_x2_ck>; @@ -219,7 +219,7 @@ ti,invert-autoidle-bit; };
- dpll_core_m5_ck: dpll_core_m5_ck { + dpll_core_m5_ck: dpll_core_m5_ck@2d3c { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_core_x2_ck>; @@ -230,7 +230,7 @@ ti,invert-autoidle-bit; };
- dpll_core_m6_ck: dpll_core_m6_ck { + dpll_core_m6_ck: dpll_core_m6_ck@2d40 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_core_x2_ck>; @@ -241,14 +241,14 @@ ti,invert-autoidle-bit; };
- dpll_mpu_ck: dpll_mpu_ck { + dpll_mpu_ck: dpll_mpu_ck@2d60 { #clock-cells = <0>; compatible = "ti,am3-dpll-clock"; clocks = <&sys_clkin_ck>, <&sys_clkin_ck>; reg = <0x2d60>, <0x2d64>, <0x2d6c>; };
- dpll_mpu_m2_ck: dpll_mpu_m2_ck { + dpll_mpu_m2_ck: dpll_mpu_m2_ck@2d70 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_mpu_ck>; @@ -259,14 +259,14 @@ ti,invert-autoidle-bit; };
- dpll_ddr_ck: dpll_ddr_ck { + dpll_ddr_ck: dpll_ddr_ck@2da0 { #clock-cells = <0>; compatible = "ti,am3-dpll-clock"; clocks = <&sys_clkin_ck>, <&sys_clkin_ck>; reg = <0x2da0>, <0x2da4>, <0x2dac>; };
- dpll_ddr_m2_ck: dpll_ddr_m2_ck { + dpll_ddr_m2_ck: dpll_ddr_m2_ck@2db0 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_ddr_ck>; @@ -277,14 +277,14 @@ ti,invert-autoidle-bit; };
- dpll_disp_ck: dpll_disp_ck { + dpll_disp_ck: dpll_disp_ck@2e20 { #clock-cells = <0>; compatible = "ti,am3-dpll-clock"; clocks = <&sys_clkin_ck>, <&sys_clkin_ck>; reg = <0x2e20>, <0x2e24>, <0x2e2c>; };
- dpll_disp_m2_ck: dpll_disp_m2_ck { + dpll_disp_m2_ck: dpll_disp_m2_ck@2e30 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_disp_ck>; @@ -296,14 +296,14 @@ ti,set-rate-parent; };
- dpll_per_ck: dpll_per_ck { + dpll_per_ck: dpll_per_ck@2de0 { #clock-cells = <0>; compatible = "ti,am3-dpll-j-type-clock"; clocks = <&sys_clkin_ck>, <&sys_clkin_ck>; reg = <0x2de0>, <0x2de4>, <0x2dec>; };
- dpll_per_m2_ck: dpll_per_m2_ck { + dpll_per_m2_ck: dpll_per_m2_ck@2df0 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_per_ck>; @@ -346,7 +346,7 @@ clock-div = <732>; };
- clkdiv32k_ick: clkdiv32k_ick { + clkdiv32k_ick: clkdiv32k_ick@2a38 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&clkdiv32k_ck>; @@ -362,7 +362,7 @@ clock-div = <1>; };
- pruss_ocp_gclk: pruss_ocp_gclk { + pruss_ocp_gclk: pruss_ocp_gclk@4248 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sysclk_div>, <&dpll_disp_m2_ck>; @@ -375,56 +375,56 @@ clock-frequency = <32768>; };
- timer1_fck: timer1_fck { + timer1_fck: timer1_fck@4200 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sys_clkin_ck>, <&clkdiv32k_ick>, <&tclkin_ck>, <&clk_rc32k_ck>, <&clk_32768_ck>, <&clk_32k_tpm_ck>; reg = <0x4200>; };
- timer2_fck: timer2_fck { + timer2_fck: timer2_fck@4204 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&tclkin_ck>, <&sys_clkin_ck>, <&clkdiv32k_ick>; reg = <0x4204>; };
- timer3_fck: timer3_fck { + timer3_fck: timer3_fck@4208 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&tclkin_ck>, <&sys_clkin_ck>, <&clkdiv32k_ick>; reg = <0x4208>; };
- timer4_fck: timer4_fck { + timer4_fck: timer4_fck@420c { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&tclkin_ck>, <&sys_clkin_ck>, <&clkdiv32k_ick>; reg = <0x420c>; };
- timer5_fck: timer5_fck { + timer5_fck: timer5_fck@4210 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&tclkin_ck>, <&sys_clkin_ck>, <&clkdiv32k_ick>; reg = <0x4210>; };
- timer6_fck: timer6_fck { + timer6_fck: timer6_fck@4214 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&tclkin_ck>, <&sys_clkin_ck>, <&clkdiv32k_ick>; reg = <0x4214>; };
- timer7_fck: timer7_fck { + timer7_fck: timer7_fck@4218 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&tclkin_ck>, <&sys_clkin_ck>, <&clkdiv32k_ick>; reg = <0x4218>; };
- wdt1_fck: wdt1_fck { + wdt1_fck: wdt1_fck@422c { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&clk_rc32k_ck>, <&clkdiv32k_ick>; @@ -479,7 +479,7 @@ clock-div = <2>; };
- cpsw_cpts_rft_clk: cpsw_cpts_rft_clk { + cpsw_cpts_rft_clk: cpsw_cpts_rft_clk@4238 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sysclk_div>, <&dpll_core_m5_ck>, <&dpll_disp_m2_ck>; @@ -492,14 +492,14 @@ clock-frequency = <32768>; };
- gpio0_dbclk_mux_ck: gpio0_dbclk_mux_ck { + gpio0_dbclk_mux_ck: gpio0_dbclk_mux_ck@4240 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&clk_rc32k_ck>, <&clk_32768_ck>, <&clkdiv32k_ick>, <&clk_32k_mosc_ck>, <&clk_32k_tpm_ck>; reg = <0x4240>; };
- gpio0_dbclk: gpio0_dbclk { + gpio0_dbclk: gpio0_dbclk@2b68 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&gpio0_dbclk_mux_ck>; @@ -507,7 +507,7 @@ reg = <0x2b68>; };
- gpio1_dbclk: gpio1_dbclk { + gpio1_dbclk: gpio1_dbclk@8c78 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&clkdiv32k_ick>; @@ -515,7 +515,7 @@ reg = <0x8c78>; };
- gpio2_dbclk: gpio2_dbclk { + gpio2_dbclk: gpio2_dbclk@8c80 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&clkdiv32k_ick>; @@ -523,7 +523,7 @@ reg = <0x8c80>; };
- gpio3_dbclk: gpio3_dbclk { + gpio3_dbclk: gpio3_dbclk@8c88 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&clkdiv32k_ick>; @@ -531,7 +531,7 @@ reg = <0x8c88>; };
- gpio4_dbclk: gpio4_dbclk { + gpio4_dbclk: gpio4_dbclk@8c90 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&clkdiv32k_ick>; @@ -539,7 +539,7 @@ reg = <0x8c90>; };
- gpio5_dbclk: gpio5_dbclk { + gpio5_dbclk: gpio5_dbclk@8c98 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&clkdiv32k_ick>; @@ -555,7 +555,7 @@ clock-div = <2>; };
- gfx_fclk_clksel_ck: gfx_fclk_clksel_ck { + gfx_fclk_clksel_ck: gfx_fclk_clksel_ck@423c { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sysclk_div>, <&dpll_per_m2_ck>; @@ -563,7 +563,7 @@ reg = <0x423c>; };
- gfx_fck_div_ck: gfx_fck_div_ck { + gfx_fck_div_ck: gfx_fck_div_ck@423c { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&gfx_fclk_clksel_ck>; @@ -571,7 +571,7 @@ ti,max-div = <2>; };
- disp_clk: disp_clk { + disp_clk: disp_clk@4244 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&dpll_disp_m2_ck>, <&dpll_core_m5_ck>, <&dpll_per_m2_ck>; @@ -579,14 +579,14 @@ ti,set-rate-parent; };
- dpll_extdev_ck: dpll_extdev_ck { + dpll_extdev_ck: dpll_extdev_ck@2e60 { #clock-cells = <0>; compatible = "ti,am3-dpll-clock"; clocks = <&sys_clkin_ck>, <&sys_clkin_ck>; reg = <0x2e60>, <0x2e64>, <0x2e6c>; };
- dpll_extdev_m2_ck: dpll_extdev_m2_ck { + dpll_extdev_m2_ck: dpll_extdev_m2_ck@2e70 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_extdev_ck>; @@ -597,14 +597,14 @@ ti,invert-autoidle-bit; };
- mux_synctimer32k_ck: mux_synctimer32k_ck { + mux_synctimer32k_ck: mux_synctimer32k_ck@4230 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&clk_32768_ck>, <&clk_32k_tpm_ck>, <&clkdiv32k_ick>; reg = <0x4230>; };
- synctimer_32kclk: synctimer_32kclk { + synctimer_32kclk: synctimer_32kclk@2a30 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&mux_synctimer32k_ck>; @@ -612,28 +612,28 @@ reg = <0x2a30>; };
- timer8_fck: timer8_fck { + timer8_fck: timer8_fck@421c { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&tclkin_ck>, <&sys_clkin_ck>, <&clkdiv32k_ick>, <&clk_32k_tpm_ck>; reg = <0x421c>; };
- timer9_fck: timer9_fck { + timer9_fck: timer9_fck@4220 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&tclkin_ck>, <&sys_clkin_ck>, <&clkdiv32k_ick>, <&clk_32k_tpm_ck>; reg = <0x4220>; };
- timer10_fck: timer10_fck { + timer10_fck: timer10_fck@4224 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&tclkin_ck>, <&sys_clkin_ck>, <&clkdiv32k_ick>, <&clk_32k_tpm_ck>; reg = <0x4224>; };
- timer11_fck: timer11_fck { + timer11_fck: timer11_fck@4228 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&tclkin_ck>, <&sys_clkin_ck>, <&clkdiv32k_ick>, <&clk_32k_tpm_ck>; @@ -662,7 +662,7 @@ clocks = <&dpll_ddr_ck>; };
- dpll_ddr_m4_ck: dpll_ddr_m4_ck { + dpll_ddr_m4_ck: dpll_ddr_m4_ck@2db8 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_ddr_x2_ck>; @@ -673,7 +673,7 @@ ti,invert-autoidle-bit; };
- dpll_per_clkdcoldo: dpll_per_clkdcoldo { + dpll_per_clkdcoldo: dpll_per_clkdcoldo@2e14 { #clock-cells = <0>; compatible = "ti,fixed-factor-clock"; clocks = <&dpll_per_ck>; @@ -684,7 +684,7 @@ ti,invert-autoidle-bit; };
- dll_aging_clk_div: dll_aging_clk_div { + dll_aging_clk_div: dll_aging_clk_div@4250 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&sys_clkin_ck>; @@ -716,14 +716,14 @@ clock-div = <2>; };
- usbphy_32khz_clkmux: usbphy_32khz_clkmux { + usbphy_32khz_clkmux: usbphy_32khz_clkmux@4260 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&clk_32768_ck>, <&clk_32k_tpm_ck>; reg = <0x4260>; };
- usb_phy0_always_on_clk32k: usb_phy0_always_on_clk32k { + usb_phy0_always_on_clk32k: usb_phy0_always_on_clk32k@2a40 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&usbphy_32khz_clkmux>; @@ -731,7 +731,7 @@ reg = <0x2a40>; };
- usb_phy1_always_on_clk32k: usb_phy1_always_on_clk32k { + usb_phy1_always_on_clk32k: usb_phy1_always_on_clk32k@2a48 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&usbphy_32khz_clkmux>; @@ -739,7 +739,7 @@ reg = <0x2a48>; };
- usb_otg_ss0_refclk960m: usb_otg_ss0_refclk960m { + usb_otg_ss0_refclk960m: usb_otg_ss0_refclk960m@8a60 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&dpll_per_clkdcoldo>; @@ -747,7 +747,7 @@ reg = <0x8a60>; };
- usb_otg_ss1_refclk960m: usb_otg_ss1_refclk960m { + usb_otg_ss1_refclk960m: usb_otg_ss1_refclk960m@8a68 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&dpll_per_clkdcoldo>; diff --git a/arch/arm/dts/am57xx-beagle-x15.dts b/arch/arm/dts/am57xx-beagle-x15.dts index e424562..981c8eb 100644 --- a/arch/arm/dts/am57xx-beagle-x15.dts +++ b/arch/arm/dts/am57xx-beagle-x15.dts @@ -26,7 +26,7 @@ display0 = &hdmi0; };
- memory { + memory@80000000 { device_type = "memory"; reg = <0x80000000 0x80000000>; }; @@ -57,28 +57,28 @@ pinctrl-names = "default"; pinctrl-0 = <&leds_pins_default>;
- led@0 { + led_0 { label = "beagle-x15:usr0"; gpios = <&gpio7 9 GPIO_ACTIVE_HIGH>; linux,default-trigger = "heartbeat"; default-state = "off"; };
- led@1 { + led_1 { label = "beagle-x15:usr1"; gpios = <&gpio7 8 GPIO_ACTIVE_HIGH>; linux,default-trigger = "cpu0"; default-state = "off"; };
- led@2 { + led_2 { label = "beagle-x15:usr2"; gpios = <&gpio7 14 GPIO_ACTIVE_HIGH>; linux,default-trigger = "mmc0"; default-state = "off"; };
- led@3 { + led_3 { label = "beagle-x15:usr3"; gpios = <&gpio7 15 GPIO_ACTIVE_HIGH>; linux,default-trigger = "ide-disk"; diff --git a/arch/arm/dts/dra7-evm.dts b/arch/arm/dts/dra7-evm.dts index 242fd53..bbf16b8 100644 --- a/arch/arm/dts/dra7-evm.dts +++ b/arch/arm/dts/dra7-evm.dts @@ -19,7 +19,7 @@ tick-timer = &timer2; };
- memory { + memory@80000000 { device_type = "memory"; reg = <0x80000000 0x60000000>; /* 1536 MB */ }; diff --git a/arch/arm/dts/dra7.dtsi b/arch/arm/dts/dra7.dtsi index e7fecf7..59e07d2 100644 --- a/arch/arm/dts/dra7.dtsi +++ b/arch/arm/dts/dra7.dtsi @@ -92,7 +92,7 @@ * the moment, just use a fake OCP bus entry to represent the whole bus * hierarchy. */ - ocp { + ocp@0 { compatible = "ti,dra7-l3-noc", "simple-bus"; #address-cells = <1>; #size-cells = <1>; @@ -122,7 +122,7 @@ #address-cells = <1>; #size-cells = <1>;
- pbias_regulator: pbias_regulator { + pbias_regulator: pbias_regulator@e00 { compatible = "ti,pbias-omap"; reg = <0xe00 0x4>; syscon = <&scm_conf>; @@ -917,7 +917,7 @@ status = "disabled"; };
- abb_mpu: regulator-abb-mpu { + abb_mpu: regulator-abb-mpu@0 { compatible = "ti,abb-v3"; regulator-name = "abb_mpu"; #address-cells = <0>; @@ -950,7 +950,7 @@ >; };
- abb_ivahd: regulator-abb-ivahd { + abb_ivahd: regulator-abb-ivahd@0 { compatible = "ti,abb-v3"; regulator-name = "abb_ivahd"; #address-cells = <0>; @@ -983,7 +983,7 @@ >; };
- abb_dspeve: regulator-abb-dspeve { + abb_dspeve: regulator-abb-dspeve@0 { compatible = "ti,abb-v3"; regulator-name = "abb_dspeve"; #address-cells = <0>; @@ -1016,7 +1016,7 @@ >; };
- abb_gpu: regulator-abb-gpu { + abb_gpu: regulator-abb-gpu@0 { compatible = "ti,abb-v3"; regulator-name = "abb_gpu"; #address-cells = <0>; @@ -1452,12 +1452,12 @@ reg = <0x48485000 0x100>; };
- cpsw_emac0: slave@48480200 { + cpsw_emac0: slave_48480200 { /* Filled in by U-Boot */ mac-address = [ 00 00 00 00 00 00 ]; };
- cpsw_emac1: slave@48480300 { + cpsw_emac1: slave_48480300 { /* Filled in by U-Boot */ mac-address = [ 00 00 00 00 00 00 ]; }; diff --git a/arch/arm/dts/dra72-evm.dts b/arch/arm/dts/dra72-evm.dts index fc2d167..59276aa 100644 --- a/arch/arm/dts/dra72-evm.dts +++ b/arch/arm/dts/dra72-evm.dts @@ -19,7 +19,7 @@ tick-timer = &timer2; };
- memory { + memory@80000000 { device_type = "memory"; reg = <0x80000000 0x40000000>; /* 1024 MB */ }; diff --git a/arch/arm/dts/dra74x.dtsi b/arch/arm/dts/dra74x.dtsi index fa995d0..b5d91e5 100644 --- a/arch/arm/dts/dra74x.dtsi +++ b/arch/arm/dts/dra74x.dtsi @@ -51,7 +51,7 @@ <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>; };
- ocp { + ocp@0 { omap_dwc3_4: omap_dwc3_4@48940000 { compatible = "ti,dwc3"; ti,hwmods = "usb_otg_ss4"; diff --git a/arch/arm/dts/dra7xx-clocks.dtsi b/arch/arm/dts/dra7xx-clocks.dtsi index 357bede..49890d2 100644 --- a/arch/arm/dts/dra7xx-clocks.dtsi +++ b/arch/arm/dts/dra7xx-clocks.dtsi @@ -188,7 +188,7 @@ clock-frequency = <0>; };
- dpll_abe_ck: dpll_abe_ck { + dpll_abe_ck: dpll_abe_ck@1e0 { #clock-cells = <0>; compatible = "ti,omap4-dpll-m4xen-clock"; clocks = <&abe_dpll_clk_mux>, <&abe_dpll_bypass_clk_mux>; @@ -201,7 +201,7 @@ clocks = <&dpll_abe_ck>; };
- dpll_abe_m2x2_ck: dpll_abe_m2x2_ck { + dpll_abe_m2x2_ck: dpll_abe_m2x2_ck@1f0 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_abe_x2_ck>; @@ -212,7 +212,7 @@ ti,invert-autoidle-bit; };
- abe_clk: abe_clk { + abe_clk: abe_clk@108 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_abe_m2x2_ck>; @@ -221,7 +221,7 @@ ti,index-power-of-two; };
- dpll_abe_m2_ck: dpll_abe_m2_ck { + dpll_abe_m2_ck: dpll_abe_m2_ck@1f0 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_abe_ck>; @@ -232,7 +232,7 @@ ti,invert-autoidle-bit; };
- dpll_abe_m3x2_ck: dpll_abe_m3x2_ck { + dpll_abe_m3x2_ck: dpll_abe_m3x2_ck@1f4 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_abe_x2_ck>; @@ -243,7 +243,7 @@ ti,invert-autoidle-bit; };
- dpll_core_byp_mux: dpll_core_byp_mux { + dpll_core_byp_mux: dpll_core_byp_mux@12c { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sys_clkin1>, <&dpll_abe_m3x2_ck>; @@ -251,7 +251,7 @@ reg = <0x012c>; };
- dpll_core_ck: dpll_core_ck { + dpll_core_ck: dpll_core_ck@120 { #clock-cells = <0>; compatible = "ti,omap4-dpll-core-clock"; clocks = <&sys_clkin1>, <&dpll_core_byp_mux>; @@ -264,7 +264,7 @@ clocks = <&dpll_core_ck>; };
- dpll_core_h12x2_ck: dpll_core_h12x2_ck { + dpll_core_h12x2_ck: dpll_core_h12x2_ck@13c { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_core_x2_ck>; @@ -283,14 +283,14 @@ clock-div = <1>; };
- dpll_mpu_ck: dpll_mpu_ck { + dpll_mpu_ck: dpll_mpu_ck@160 { #clock-cells = <0>; compatible = "ti,omap5-mpu-dpll-clock"; clocks = <&sys_clkin1>, <&mpu_dpll_hs_clk_div>; reg = <0x0160>, <0x0164>, <0x016c>, <0x0168>; };
- dpll_mpu_m2_ck: dpll_mpu_m2_ck { + dpll_mpu_m2_ck: dpll_mpu_m2_ck@170 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_mpu_ck>; @@ -317,7 +317,7 @@ clock-div = <1>; };
- dpll_dsp_byp_mux: dpll_dsp_byp_mux { + dpll_dsp_byp_mux: dpll_dsp_byp_mux@240 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sys_clkin1>, <&dsp_dpll_hs_clk_div>; @@ -325,14 +325,14 @@ reg = <0x0240>; };
- dpll_dsp_ck: dpll_dsp_ck { + dpll_dsp_ck: dpll_dsp_ck@234 { #clock-cells = <0>; compatible = "ti,omap4-dpll-clock"; clocks = <&sys_clkin1>, <&dpll_dsp_byp_mux>; reg = <0x0234>, <0x0238>, <0x0240>, <0x023c>; };
- dpll_dsp_m2_ck: dpll_dsp_m2_ck { + dpll_dsp_m2_ck: dpll_dsp_m2_ck@244 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_dsp_ck>; @@ -351,7 +351,7 @@ clock-div = <1>; };
- dpll_iva_byp_mux: dpll_iva_byp_mux { + dpll_iva_byp_mux: dpll_iva_byp_mux@1ac { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sys_clkin1>, <&iva_dpll_hs_clk_div>; @@ -359,14 +359,14 @@ reg = <0x01ac>; };
- dpll_iva_ck: dpll_iva_ck { + dpll_iva_ck: dpll_iva_ck@1a0 { #clock-cells = <0>; compatible = "ti,omap4-dpll-clock"; clocks = <&sys_clkin1>, <&dpll_iva_byp_mux>; reg = <0x01a0>, <0x01a4>, <0x01ac>, <0x01a8>; };
- dpll_iva_m2_ck: dpll_iva_m2_ck { + dpll_iva_m2_ck: dpll_iva_m2_ck@1b0 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_iva_ck>; @@ -385,7 +385,7 @@ clock-div = <1>; };
- dpll_gpu_byp_mux: dpll_gpu_byp_mux { + dpll_gpu_byp_mux: dpll_gpu_byp_mux@2e4 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sys_clkin1>, <&dpll_abe_m3x2_ck>; @@ -393,14 +393,14 @@ reg = <0x02e4>; };
- dpll_gpu_ck: dpll_gpu_ck { + dpll_gpu_ck: dpll_gpu_ck@2d8 { #clock-cells = <0>; compatible = "ti,omap4-dpll-clock"; clocks = <&sys_clkin1>, <&dpll_gpu_byp_mux>; reg = <0x02d8>, <0x02dc>, <0x02e4>, <0x02e0>; };
- dpll_gpu_m2_ck: dpll_gpu_m2_ck { + dpll_gpu_m2_ck: dpll_gpu_m2_ck@2e8 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_gpu_ck>; @@ -411,7 +411,7 @@ ti,invert-autoidle-bit; };
- dpll_core_m2_ck: dpll_core_m2_ck { + dpll_core_m2_ck: dpll_core_m2_ck@130 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_core_ck>; @@ -430,7 +430,7 @@ clock-div = <1>; };
- dpll_ddr_byp_mux: dpll_ddr_byp_mux { + dpll_ddr_byp_mux: dpll_ddr_byp_mux@21c { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sys_clkin1>, <&dpll_abe_m3x2_ck>; @@ -438,14 +438,14 @@ reg = <0x021c>; };
- dpll_ddr_ck: dpll_ddr_ck { + dpll_ddr_ck: dpll_ddr_ck@210 { #clock-cells = <0>; compatible = "ti,omap4-dpll-clock"; clocks = <&sys_clkin1>, <&dpll_ddr_byp_mux>; reg = <0x0210>, <0x0214>, <0x021c>, <0x0218>; };
- dpll_ddr_m2_ck: dpll_ddr_m2_ck { + dpll_ddr_m2_ck: dpll_ddr_m2_ck@220 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_ddr_ck>; @@ -456,7 +456,7 @@ ti,invert-autoidle-bit; };
- dpll_gmac_byp_mux: dpll_gmac_byp_mux { + dpll_gmac_byp_mux: dpll_gmac_byp_mux@2b4 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sys_clkin1>, <&dpll_abe_m3x2_ck>; @@ -464,14 +464,14 @@ reg = <0x02b4>; };
- dpll_gmac_ck: dpll_gmac_ck { + dpll_gmac_ck: dpll_gmac_ck@2a8 { #clock-cells = <0>; compatible = "ti,omap4-dpll-clock"; clocks = <&sys_clkin1>, <&dpll_gmac_byp_mux>; reg = <0x02a8>, <0x02ac>, <0x02b4>, <0x02b0>; };
- dpll_gmac_m2_ck: dpll_gmac_m2_ck { + dpll_gmac_m2_ck: dpll_gmac_m2_ck@2b8 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_gmac_ck>; @@ -530,7 +530,7 @@ clock-div = <1>; };
- dpll_eve_byp_mux: dpll_eve_byp_mux { + dpll_eve_byp_mux: dpll_eve_byp_mux@290 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sys_clkin1>, <&eve_dpll_hs_clk_div>; @@ -538,14 +538,14 @@ reg = <0x0290>; };
- dpll_eve_ck: dpll_eve_ck { + dpll_eve_ck: dpll_eve_ck@284 { #clock-cells = <0>; compatible = "ti,omap4-dpll-clock"; clocks = <&sys_clkin1>, <&dpll_eve_byp_mux>; reg = <0x0284>, <0x0288>, <0x0290>, <0x028c>; };
- dpll_eve_m2_ck: dpll_eve_m2_ck { + dpll_eve_m2_ck: dpll_eve_m2_ck@294 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_eve_ck>; @@ -564,7 +564,7 @@ clock-div = <1>; };
- dpll_core_h13x2_ck: dpll_core_h13x2_ck { + dpll_core_h13x2_ck: dpll_core_h13x2_ck@140 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_core_x2_ck>; @@ -575,7 +575,7 @@ ti,invert-autoidle-bit; };
- dpll_core_h14x2_ck: dpll_core_h14x2_ck { + dpll_core_h14x2_ck: dpll_core_h14x2_ck@144 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_core_x2_ck>; @@ -586,7 +586,7 @@ ti,invert-autoidle-bit; };
- dpll_core_h22x2_ck: dpll_core_h22x2_ck { + dpll_core_h22x2_ck: dpll_core_h22x2_ck@154 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_core_x2_ck>; @@ -597,7 +597,7 @@ ti,invert-autoidle-bit; };
- dpll_core_h23x2_ck: dpll_core_h23x2_ck { + dpll_core_h23x2_ck: dpll_core_h23x2_ck@158 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_core_x2_ck>; @@ -608,7 +608,7 @@ ti,invert-autoidle-bit; };
- dpll_core_h24x2_ck: dpll_core_h24x2_ck { + dpll_core_h24x2_ck: dpll_core_h24x2_ck@15c { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_core_x2_ck>; @@ -625,7 +625,7 @@ clocks = <&dpll_ddr_ck>; };
- dpll_ddr_h11x2_ck: dpll_ddr_h11x2_ck { + dpll_ddr_h11x2_ck: dpll_ddr_h11x2_ck@228 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_ddr_x2_ck>; @@ -642,7 +642,7 @@ clocks = <&dpll_dsp_ck>; };
- dpll_dsp_m3x2_ck: dpll_dsp_m3x2_ck { + dpll_dsp_m3x2_ck: dpll_dsp_m3x2_ck@248 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_dsp_x2_ck>; @@ -659,7 +659,7 @@ clocks = <&dpll_gmac_ck>; };
- dpll_gmac_h11x2_ck: dpll_gmac_h11x2_ck { + dpll_gmac_h11x2_ck: dpll_gmac_h11x2_ck@2c0 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_gmac_x2_ck>; @@ -670,7 +670,7 @@ ti,invert-autoidle-bit; };
- dpll_gmac_h12x2_ck: dpll_gmac_h12x2_ck { + dpll_gmac_h12x2_ck: dpll_gmac_h12x2_ck@2c4 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_gmac_x2_ck>; @@ -681,7 +681,7 @@ ti,invert-autoidle-bit; };
- dpll_gmac_h13x2_ck: dpll_gmac_h13x2_ck { + dpll_gmac_h13x2_ck: dpll_gmac_h13x2_ck@2c8 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_gmac_x2_ck>; @@ -692,7 +692,7 @@ ti,invert-autoidle-bit; };
- dpll_gmac_m3x2_ck: dpll_gmac_m3x2_ck { + dpll_gmac_m3x2_ck: dpll_gmac_m3x2_ck@2bc { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_gmac_x2_ck>; @@ -727,7 +727,7 @@ clock-div = <1>; };
- l3_iclk_div: l3_iclk_div { + l3_iclk_div: l3_iclk_div@100 { #clock-cells = <0>; compatible = "ti,divider-clock"; ti,max-div = <2>; @@ -777,7 +777,7 @@ clock-div = <1>; };
- ipu1_gfclk_mux: ipu1_gfclk_mux { + ipu1_gfclk_mux: ipu1_gfclk_mux@520 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&dpll_abe_m2x2_ck>, <&dpll_core_h22x2_ck>; @@ -785,7 +785,7 @@ reg = <0x0520>; };
- mcasp1_ahclkr_mux: mcasp1_ahclkr_mux { + mcasp1_ahclkr_mux: mcasp1_ahclkr_mux@550 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&abe_24m_fclk>, <&abe_sys_clk_div>, <&func_24m_clk>, <&atl_clkin3_ck>, <&atl_clkin2_ck>, <&atl_clkin1_ck>, <&atl_clkin0_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&mlb_clk>, <&mlbp_clk>; @@ -793,7 +793,7 @@ reg = <0x0550>; };
- mcasp1_ahclkx_mux: mcasp1_ahclkx_mux { + mcasp1_ahclkx_mux: mcasp1_ahclkx_mux@550 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&abe_24m_fclk>, <&abe_sys_clk_div>, <&func_24m_clk>, <&atl_clkin3_ck>, <&atl_clkin2_ck>, <&atl_clkin1_ck>, <&atl_clkin0_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&mlb_clk>, <&mlbp_clk>; @@ -801,7 +801,7 @@ reg = <0x0550>; };
- mcasp1_aux_gfclk_mux: mcasp1_aux_gfclk_mux { + mcasp1_aux_gfclk_mux: mcasp1_aux_gfclk_mux@550 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&per_abe_x1_gfclk2_div>, <&video1_clk2_div>, <&video2_clk2_div>, <&hdmi_clk2_div>; @@ -809,7 +809,7 @@ reg = <0x0550>; };
- timer5_gfclk_mux: timer5_gfclk_mux { + timer5_gfclk_mux: timer5_gfclk_mux@558 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&timer_sys_clk_div>, <&sys_32k_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&abe_giclk_div>, <&video1_div_clk>, <&video2_div_clk>, <&hdmi_div_clk>, <&clkoutmux0_clk_mux>; @@ -817,7 +817,7 @@ reg = <0x0558>; };
- timer6_gfclk_mux: timer6_gfclk_mux { + timer6_gfclk_mux: timer6_gfclk_mux@560 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&timer_sys_clk_div>, <&sys_32k_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&abe_giclk_div>, <&video1_div_clk>, <&video2_div_clk>, <&hdmi_div_clk>, <&clkoutmux0_clk_mux>; @@ -825,7 +825,7 @@ reg = <0x0560>; };
- timer7_gfclk_mux: timer7_gfclk_mux { + timer7_gfclk_mux: timer7_gfclk_mux@568 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&timer_sys_clk_div>, <&sys_32k_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&abe_giclk_div>, <&video1_div_clk>, <&video2_div_clk>, <&hdmi_div_clk>, <&clkoutmux0_clk_mux>; @@ -833,7 +833,7 @@ reg = <0x0568>; };
- timer8_gfclk_mux: timer8_gfclk_mux { + timer8_gfclk_mux: timer8_gfclk_mux@570 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&timer_sys_clk_div>, <&sys_32k_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&abe_giclk_div>, <&video1_div_clk>, <&video2_div_clk>, <&hdmi_div_clk>, <&clkoutmux0_clk_mux>; @@ -841,7 +841,7 @@ reg = <0x0570>; };
- uart6_gfclk_mux: uart6_gfclk_mux { + uart6_gfclk_mux: uart6_gfclk_mux@580 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&func_48m_fclk>, <&dpll_per_m2x2_ck>; @@ -856,7 +856,7 @@ }; }; &prm_clocks { - sys_clkin1: sys_clkin1 { + sys_clkin1: sys_clkin1@110 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&virt_12000000_ck>, <&virt_20000000_ck>, <&virt_16800000_ck>, <&virt_19200000_ck>, <&virt_26000000_ck>, <&virt_27000000_ck>, <&virt_38400000_ck>; @@ -864,28 +864,28 @@ ti,index-starts-at-one; };
- abe_dpll_sys_clk_mux: abe_dpll_sys_clk_mux { + abe_dpll_sys_clk_mux: abe_dpll_sys_clk_mux@118 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sys_clkin1>, <&sys_clkin2>; reg = <0x0118>; };
- abe_dpll_bypass_clk_mux: abe_dpll_bypass_clk_mux { + abe_dpll_bypass_clk_mux: abe_dpll_bypass_clk_mux@114 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&abe_dpll_sys_clk_mux>, <&sys_32k_ck>; reg = <0x0114>; };
- abe_dpll_clk_mux: abe_dpll_clk_mux { + abe_dpll_clk_mux: abe_dpll_clk_mux@10c { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&abe_dpll_sys_clk_mux>, <&sys_32k_ck>; reg = <0x010c>; };
- abe_24m_fclk: abe_24m_fclk { + abe_24m_fclk: abe_24m_fclk@11c { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_abe_m2x2_ck>; @@ -893,7 +893,7 @@ ti,dividers = <8>, <16>; };
- aess_fclk: aess_fclk { + aess_fclk: aess_fclk@178 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&abe_clk>; @@ -901,7 +901,7 @@ ti,max-div = <2>; };
- abe_giclk_div: abe_giclk_div { + abe_giclk_div: abe_giclk_div@174 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&aess_fclk>; @@ -909,7 +909,7 @@ ti,max-div = <2>; };
- abe_lp_clk_div: abe_lp_clk_div { + abe_lp_clk_div: abe_lp_clk_div@1d8 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_abe_m2x2_ck>; @@ -917,7 +917,7 @@ ti,dividers = <16>, <32>; };
- abe_sys_clk_div: abe_sys_clk_div { + abe_sys_clk_div: abe_sys_clk_div@120 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&sys_clkin1>; @@ -925,14 +925,14 @@ ti,max-div = <2>; };
- adc_gfclk_mux: adc_gfclk_mux { + adc_gfclk_mux: adc_gfclk_mux@1dc { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sys_clkin1>, <&sys_clkin2>, <&sys_32k_ck>; reg = <0x01dc>; };
- sys_clk1_dclk_div: sys_clk1_dclk_div { + sys_clk1_dclk_div: sys_clk1_dclk_div@1c8 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&sys_clkin1>; @@ -941,7 +941,7 @@ ti,index-power-of-two; };
- sys_clk2_dclk_div: sys_clk2_dclk_div { + sys_clk2_dclk_div: sys_clk2_dclk_div@1cc { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&sys_clkin2>; @@ -950,7 +950,7 @@ ti,index-power-of-two; };
- per_abe_x1_dclk_div: per_abe_x1_dclk_div { + per_abe_x1_dclk_div: per_abe_x1_dclk_div@1bc { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_abe_m2_ck>; @@ -959,7 +959,7 @@ ti,index-power-of-two; };
- dsp_gclk_div: dsp_gclk_div { + dsp_gclk_div: dsp_gclk_div@18c { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_dsp_m2_ck>; @@ -968,7 +968,7 @@ ti,index-power-of-two; };
- gpu_dclk: gpu_dclk { + gpu_dclk: gpu_dclk@1a0 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_gpu_m2_ck>; @@ -977,7 +977,7 @@ ti,index-power-of-two; };
- emif_phy_dclk_div: emif_phy_dclk_div { + emif_phy_dclk_div: emif_phy_dclk_div@190 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_ddr_m2_ck>; @@ -986,7 +986,7 @@ ti,index-power-of-two; };
- gmac_250m_dclk_div: gmac_250m_dclk_div { + gmac_250m_dclk_div: gmac_250m_dclk_div@19c { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_gmac_m2_ck>; @@ -995,7 +995,7 @@ ti,index-power-of-two; };
- l3init_480m_dclk_div: l3init_480m_dclk_div { + l3init_480m_dclk_div: l3init_480m_dclk_div@1ac { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_usb_m2_ck>; @@ -1004,7 +1004,7 @@ ti,index-power-of-two; };
- usb_otg_dclk_div: usb_otg_dclk_div { + usb_otg_dclk_div: usb_otg_dclk_div@184 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&usb_otg_clkin_ck>; @@ -1013,7 +1013,7 @@ ti,index-power-of-two; };
- sata_dclk_div: sata_dclk_div { + sata_dclk_div: sata_dclk_div@1c0 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&sys_clkin1>; @@ -1022,7 +1022,7 @@ ti,index-power-of-two; };
- pcie2_dclk_div: pcie2_dclk_div { + pcie2_dclk_div: pcie2_dclk_div@1b8 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_pcie_ref_m2_ck>; @@ -1031,7 +1031,7 @@ ti,index-power-of-two; };
- pcie_dclk_div: pcie_dclk_div { + pcie_dclk_div: pcie_dclk_div@1b4 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&apll_pcie_m2_ck>; @@ -1040,7 +1040,7 @@ ti,index-power-of-two; };
- emu_dclk_div: emu_dclk_div { + emu_dclk_div: emu_dclk_div@194 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&sys_clkin1>; @@ -1049,7 +1049,7 @@ ti,index-power-of-two; };
- secure_32k_dclk_div: secure_32k_dclk_div { + secure_32k_dclk_div: secure_32k_dclk_div@1c4 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&secure_32k_clk_src_ck>; @@ -1058,21 +1058,21 @@ ti,index-power-of-two; };
- clkoutmux0_clk_mux: clkoutmux0_clk_mux { + clkoutmux0_clk_mux: clkoutmux0_clk_mux@158 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sys_clk1_dclk_div>, <&sys_clk2_dclk_div>, <&per_abe_x1_dclk_div>, <&mpu_dclk_div>, <&dsp_gclk_div>, <&iva_dclk>, <&gpu_dclk>, <&core_dpll_out_dclk_div>, <&emif_phy_dclk_div>, <&gmac_250m_dclk_div>, <&video2_dclk_div>, <&video1_dclk_div>, <&hdmi_dclk_div>, <&func_96m_aon_dclk_div>, <&l3init_480m_dclk_div>, <&usb_otg_dclk_div>, <&sata_dclk_div>, <&pcie2_dclk_div>, <&pcie_dclk_div>, <&emu_dclk_div>, <&secure_32k_dclk_div>, <&eve_dclk_div>; reg = <0x0158>; };
- clkoutmux1_clk_mux: clkoutmux1_clk_mux { + clkoutmux1_clk_mux: clkoutmux1_clk_mux@15c { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sys_clk1_dclk_div>, <&sys_clk2_dclk_div>, <&per_abe_x1_dclk_div>, <&mpu_dclk_div>, <&dsp_gclk_div>, <&iva_dclk>, <&gpu_dclk>, <&core_dpll_out_dclk_div>, <&emif_phy_dclk_div>, <&gmac_250m_dclk_div>, <&video2_dclk_div>, <&video1_dclk_div>, <&hdmi_dclk_div>, <&func_96m_aon_dclk_div>, <&l3init_480m_dclk_div>, <&usb_otg_dclk_div>, <&sata_dclk_div>, <&pcie2_dclk_div>, <&pcie_dclk_div>, <&emu_dclk_div>, <&secure_32k_dclk_div>, <&eve_dclk_div>; reg = <0x015c>; };
- clkoutmux2_clk_mux: clkoutmux2_clk_mux { + clkoutmux2_clk_mux: clkoutmux2_clk_mux@160 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sys_clk1_dclk_div>, <&sys_clk2_dclk_div>, <&per_abe_x1_dclk_div>, <&mpu_dclk_div>, <&dsp_gclk_div>, <&iva_dclk>, <&gpu_dclk>, <&core_dpll_out_dclk_div>, <&emif_phy_dclk_div>, <&gmac_250m_dclk_div>, <&video2_dclk_div>, <&video1_dclk_div>, <&hdmi_dclk_div>, <&func_96m_aon_dclk_div>, <&l3init_480m_dclk_div>, <&usb_otg_dclk_div>, <&sata_dclk_div>, <&pcie2_dclk_div>, <&pcie_dclk_div>, <&emu_dclk_div>, <&secure_32k_dclk_div>, <&eve_dclk_div>; @@ -1087,21 +1087,21 @@ clock-div = <2>; };
- eve_clk: eve_clk { + eve_clk: eve_clk@180 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&dpll_eve_m2_ck>, <&dpll_dsp_m3x2_ck>; reg = <0x0180>; };
- hdmi_dpll_clk_mux: hdmi_dpll_clk_mux { + hdmi_dpll_clk_mux: hdmi_dpll_clk_mux@164 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sys_clkin1>, <&sys_clkin2>; reg = <0x0164>; };
- mlb_clk: mlb_clk { + mlb_clk: mlb_clk@134 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&mlb_clkin_ck>; @@ -1110,7 +1110,7 @@ ti,index-power-of-two; };
- mlbp_clk: mlbp_clk { + mlbp_clk: mlbp_clk@130 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&mlbp_clkin_ck>; @@ -1119,7 +1119,7 @@ ti,index-power-of-two; };
- per_abe_x1_gfclk2_div: per_abe_x1_gfclk2_div { + per_abe_x1_gfclk2_div: per_abe_x1_gfclk2_div@138 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_abe_m2_ck>; @@ -1128,7 +1128,7 @@ ti,index-power-of-two; };
- timer_sys_clk_div: timer_sys_clk_div { + timer_sys_clk_div: timer_sys_clk_div@144 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&sys_clkin1>; @@ -1136,28 +1136,28 @@ ti,max-div = <2>; };
- video1_dpll_clk_mux: video1_dpll_clk_mux { + video1_dpll_clk_mux: video1_dpll_clk_mux@168 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sys_clkin1>, <&sys_clkin2>; reg = <0x0168>; };
- video2_dpll_clk_mux: video2_dpll_clk_mux { + video2_dpll_clk_mux: video2_dpll_clk_mux@16c { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sys_clkin1>, <&sys_clkin2>; reg = <0x016c>; };
- wkupaon_iclk_mux: wkupaon_iclk_mux { + wkupaon_iclk_mux: wkupaon_iclk_mux@108 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sys_clkin1>, <&abe_lp_clk_div>; reg = <0x0108>; };
- gpio1_dbclk: gpio1_dbclk { + gpio1_dbclk: gpio1_dbclk@1838 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&sys_32k_ck>; @@ -1165,7 +1165,7 @@ reg = <0x1838>; };
- dcan1_sys_clk_mux: dcan1_sys_clk_mux { + dcan1_sys_clk_mux: dcan1_sys_clk_mux@1888 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sys_clkin1>, <&sys_clkin2>; @@ -1173,7 +1173,7 @@ reg = <0x1888>; };
- timer1_gfclk_mux: timer1_gfclk_mux { + timer1_gfclk_mux: timer1_gfclk_mux@1840 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&timer_sys_clk_div>, <&sys_32k_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&abe_giclk_div>, <&video1_div_clk>, <&video2_div_clk>, <&hdmi_div_clk>; @@ -1181,7 +1181,7 @@ reg = <0x1840>; };
- uart10_gfclk_mux: uart10_gfclk_mux { + uart10_gfclk_mux: uart10_gfclk_mux@1880 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&func_48m_fclk>, <&dpll_per_m2x2_ck>; @@ -1190,14 +1190,14 @@ }; }; &cm_core_clocks { - dpll_pcie_ref_ck: dpll_pcie_ref_ck { + dpll_pcie_ref_ck: dpll_pcie_ref_ck@200 { #clock-cells = <0>; compatible = "ti,omap4-dpll-clock"; clocks = <&sys_clkin1>, <&sys_clkin1>; reg = <0x0200>, <0x0204>, <0x020c>, <0x0208>; };
- dpll_pcie_ref_m2ldo_ck: dpll_pcie_ref_m2ldo_ck { + dpll_pcie_ref_m2ldo_ck: dpll_pcie_ref_m2ldo_ck@210 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_pcie_ref_ck>; @@ -1216,7 +1216,7 @@ ti,bit-shift = <7>; };
- apll_pcie_ck: apll_pcie_ck { + apll_pcie_ck: apll_pcie_ck@21c { #clock-cells = <0>; compatible = "ti,dra7-apll-clock"; clocks = <&apll_pcie_in_clk_mux>, <&dpll_pcie_ref_ck>; @@ -1305,7 +1305,7 @@ clock-div = <1>; };
- dpll_per_byp_mux: dpll_per_byp_mux { + dpll_per_byp_mux: dpll_per_byp_mux@14c { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sys_clkin1>, <&per_dpll_hs_clk_div>; @@ -1313,14 +1313,14 @@ reg = <0x014c>; };
- dpll_per_ck: dpll_per_ck { + dpll_per_ck: dpll_per_ck@140 { #clock-cells = <0>; compatible = "ti,omap4-dpll-clock"; clocks = <&sys_clkin1>, <&dpll_per_byp_mux>; reg = <0x0140>, <0x0144>, <0x014c>, <0x0148>; };
- dpll_per_m2_ck: dpll_per_m2_ck { + dpll_per_m2_ck: dpll_per_m2_ck@150 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_per_ck>; @@ -1339,7 +1339,7 @@ clock-div = <1>; };
- dpll_usb_byp_mux: dpll_usb_byp_mux { + dpll_usb_byp_mux: dpll_usb_byp_mux@18c { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sys_clkin1>, <&usb_dpll_hs_clk_div>; @@ -1347,14 +1347,14 @@ reg = <0x018c>; };
- dpll_usb_ck: dpll_usb_ck { + dpll_usb_ck: dpll_usb_ck@180 { #clock-cells = <0>; compatible = "ti,omap4-dpll-j-type-clock"; clocks = <&sys_clkin1>, <&dpll_usb_byp_mux>; reg = <0x0180>, <0x0184>, <0x018c>, <0x0188>; };
- dpll_usb_m2_ck: dpll_usb_m2_ck { + dpll_usb_m2_ck: dpll_usb_m2_ck@190 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_usb_ck>; @@ -1365,7 +1365,7 @@ ti,invert-autoidle-bit; };
- dpll_pcie_ref_m2_ck: dpll_pcie_ref_m2_ck { + dpll_pcie_ref_m2_ck: dpll_pcie_ref_m2_ck@210 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_pcie_ref_ck>; @@ -1382,7 +1382,7 @@ clocks = <&dpll_per_ck>; };
- dpll_per_h11x2_ck: dpll_per_h11x2_ck { + dpll_per_h11x2_ck: dpll_per_h11x2_ck@158 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_per_x2_ck>; @@ -1393,7 +1393,7 @@ ti,invert-autoidle-bit; };
- dpll_per_h12x2_ck: dpll_per_h12x2_ck { + dpll_per_h12x2_ck: dpll_per_h12x2_ck@15c { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_per_x2_ck>; @@ -1404,7 +1404,7 @@ ti,invert-autoidle-bit; };
- dpll_per_h13x2_ck: dpll_per_h13x2_ck { + dpll_per_h13x2_ck: dpll_per_h13x2_ck@160 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_per_x2_ck>; @@ -1415,7 +1415,7 @@ ti,invert-autoidle-bit; };
- dpll_per_h14x2_ck: dpll_per_h14x2_ck { + dpll_per_h14x2_ck: dpll_per_h14x2_ck@164 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_per_x2_ck>; @@ -1426,7 +1426,7 @@ ti,invert-autoidle-bit; };
- dpll_per_m2x2_ck: dpll_per_m2x2_ck { + dpll_per_m2x2_ck: dpll_per_m2x2_ck@150 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_per_x2_ck>; @@ -1485,7 +1485,7 @@ clock-div = <2>; };
- l3init_60m_fclk: l3init_60m_fclk { + l3init_60m_fclk: l3init_60m_fclkq104@104 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_usb_m2_ck>; @@ -1493,7 +1493,7 @@ ti,dividers = <1>, <8>; };
- clkout2_clk: clkout2_clk { + clkout2_clk: clkout2_clk@6b0 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&clkoutmux2_clk_mux>; @@ -1501,7 +1501,7 @@ reg = <0x06b0>; };
- l3init_960m_gfclk: l3init_960m_gfclk { + l3init_960m_gfclk: l3init_960m_gfclk@6c0 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&dpll_usb_clkdcoldo>; @@ -1509,7 +1509,7 @@ reg = <0x06c0>; };
- dss_32khz_clk: dss_32khz_clk { + dss_32khz_clk: dss_32khz_clk@1120 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&sys_32k_ck>; @@ -1517,7 +1517,7 @@ reg = <0x1120>; };
- dss_48mhz_clk: dss_48mhz_clk { + dss_48mhz_clk: dss_48mhz_clk@1120 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&func_48m_fclk>; @@ -1525,7 +1525,7 @@ reg = <0x1120>; };
- dss_dss_clk: dss_dss_clk { + dss_dss_clk: dss_dss_clk@1120 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&dpll_per_h12x2_ck>; @@ -1534,7 +1534,7 @@ ti,set-rate-parent; };
- dss_hdmi_clk: dss_hdmi_clk { + dss_hdmi_clk: dss_hdmi_clk@1120 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&hdmi_dpll_clk_mux>; @@ -1542,7 +1542,7 @@ reg = <0x1120>; };
- dss_video1_clk: dss_video1_clk { + dss_video1_clk: dss_video1_clk@1120 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&video1_dpll_clk_mux>; @@ -1550,7 +1550,7 @@ reg = <0x1120>; };
- dss_video2_clk: dss_video2_clk { + dss_video2_clk: dss_video2_clk@1120 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&video2_dpll_clk_mux>; @@ -1558,7 +1558,7 @@ reg = <0x1120>; };
- gpio2_dbclk: gpio2_dbclk { + gpio2_dbclk: gpio2_dbclkq1760@1760 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&sys_32k_ck>; @@ -1566,7 +1566,7 @@ reg = <0x1760>; };
- gpio3_dbclk: gpio3_dbclk { + gpio3_dbclk: gpio3_dbclk@1768 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&sys_32k_ck>; @@ -1574,7 +1574,7 @@ reg = <0x1768>; };
- gpio4_dbclk: gpio4_dbclk { + gpio4_dbclk: gpio4_dbclk@1770 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&sys_32k_ck>; @@ -1582,7 +1582,7 @@ reg = <0x1770>; };
- gpio5_dbclk: gpio5_dbclk { + gpio5_dbclk: gpio5_dbclk@1778 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&sys_32k_ck>; @@ -1590,7 +1590,7 @@ reg = <0x1778>; };
- gpio6_dbclk: gpio6_dbclk { + gpio6_dbclk: gpio6_dbclk@1780 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&sys_32k_ck>; @@ -1598,7 +1598,7 @@ reg = <0x1780>; };
- gpio7_dbclk: gpio7_dbclk { + gpio7_dbclk: gpio7_dbclk@1810 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&sys_32k_ck>; @@ -1606,7 +1606,7 @@ reg = <0x1810>; };
- gpio8_dbclk: gpio8_dbclk { + gpio8_dbclk: gpio8_dbclk@1818 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&sys_32k_ck>; @@ -1614,7 +1614,7 @@ reg = <0x1818>; };
- mmc1_clk32k: mmc1_clk32k { + mmc1_clk32k: mmc1_clk32k@1328 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&sys_32k_ck>; @@ -1622,7 +1622,7 @@ reg = <0x1328>; };
- mmc2_clk32k: mmc2_clk32k { + mmc2_clk32k: mmc2_clk32k@1330 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&sys_32k_ck>; @@ -1630,7 +1630,7 @@ reg = <0x1330>; };
- mmc3_clk32k: mmc3_clk32k { + mmc3_clk32k: mmc3_clk32k@1820 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&sys_32k_ck>; @@ -1638,7 +1638,7 @@ reg = <0x1820>; };
- mmc4_clk32k: mmc4_clk32k { + mmc4_clk32k: mmc4_clk32k@1828 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&sys_32k_ck>; @@ -1646,7 +1646,7 @@ reg = <0x1828>; };
- sata_ref_clk: sata_ref_clk { + sata_ref_clk: sata_ref_clk@1388 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&sys_clkin1>; @@ -1654,7 +1654,7 @@ reg = <0x1388>; };
- usb_otg_ss1_refclk960m: usb_otg_ss1_refclk960m { + usb_otg_ss1_refclk960m: usb_otg_ss1_refclk960m@13f0 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&l3init_960m_gfclk>; @@ -1662,7 +1662,7 @@ reg = <0x13f0>; };
- usb_otg_ss2_refclk960m: usb_otg_ss2_refclk960m { + usb_otg_ss2_refclk960m: usb_otg_ss2_refclk960m@1340 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&l3init_960m_gfclk>; @@ -1670,7 +1670,7 @@ reg = <0x1340>; };
- usb_phy1_always_on_clk32k: usb_phy1_always_on_clk32k { + usb_phy1_always_on_clk32k: usb_phy1_always_on_clk32k@640 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&sys_32k_ck>; @@ -1678,7 +1678,7 @@ reg = <0x0640>; };
- usb_phy2_always_on_clk32k: usb_phy2_always_on_clk32k { + usb_phy2_always_on_clk32k: usb_phy2_always_on_clk32k@688 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&sys_32k_ck>; @@ -1686,7 +1686,7 @@ reg = <0x0688>; };
- usb_phy3_always_on_clk32k: usb_phy3_always_on_clk32k { + usb_phy3_always_on_clk32k: usb_phy3_always_on_clk32k@698 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&sys_32k_ck>; @@ -1694,7 +1694,7 @@ reg = <0x0698>; };
- atl_dpll_clk_mux: atl_dpll_clk_mux { + atl_dpll_clk_mux: atl_dpll_clk_mux@c00 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&sys_32k_ck>, <&video1_clkin_ck>, <&video2_clkin_ck>, <&hdmi_clkin_ck>; @@ -1702,7 +1702,7 @@ reg = <0x0c00>; };
- atl_gfclk_mux: atl_gfclk_mux { + atl_gfclk_mux: atl_gfclk_mux@c00 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&l3_iclk_div>, <&dpll_abe_m2_ck>, <&atl_dpll_clk_mux>; @@ -1710,7 +1710,7 @@ reg = <0x0c00>; };
- gmac_gmii_ref_clk_div: gmac_gmii_ref_clk_div { + gmac_gmii_ref_clk_div: gmac_gmii_ref_clk_div@13d0 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&dpll_gmac_m2_ck>; @@ -1719,7 +1719,7 @@ ti,dividers = <2>; };
- gmac_rft_clk_mux: gmac_rft_clk_mux { + gmac_rft_clk_mux: gmac_rft_clk_mux@13d0 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&video1_clkin_ck>, <&video2_clkin_ck>, <&dpll_abe_m2_ck>, <&hdmi_clkin_ck>, <&l3_iclk_div>; @@ -1727,7 +1727,7 @@ reg = <0x13d0>; };
- gpu_core_gclk_mux: gpu_core_gclk_mux { + gpu_core_gclk_mux: gpu_core_gclk_mux@1220 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&dpll_core_h14x2_ck>, <&dpll_per_h14x2_ck>, <&dpll_gpu_m2_ck>; @@ -1735,7 +1735,7 @@ reg = <0x1220>; };
- gpu_hyd_gclk_mux: gpu_hyd_gclk_mux { + gpu_hyd_gclk_mux: gpu_hyd_gclk_mux@1220 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&dpll_core_h14x2_ck>, <&dpll_per_h14x2_ck>, <&dpll_gpu_m2_ck>; @@ -1743,7 +1743,7 @@ reg = <0x1220>; };
- l3instr_ts_gclk_div: l3instr_ts_gclk_div { + l3instr_ts_gclk_div: l3instr_ts_gclk_div@e50 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&wkupaon_iclk_mux>; @@ -1752,7 +1752,7 @@ ti,dividers = <8>, <16>, <32>; };
- mcasp2_ahclkr_mux: mcasp2_ahclkr_mux { + mcasp2_ahclkr_mux: mcasp2_ahclkr_mux@1860 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&abe_24m_fclk>, <&abe_sys_clk_div>, <&func_24m_clk>, <&atl_clkin3_ck>, <&atl_clkin2_ck>, <&atl_clkin1_ck>, <&atl_clkin0_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&mlb_clk>, <&mlbp_clk>; @@ -1760,7 +1760,7 @@ reg = <0x1860>; };
- mcasp2_ahclkx_mux: mcasp2_ahclkx_mux { + mcasp2_ahclkx_mux: mcasp2_ahclkx_mux@1860 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&abe_24m_fclk>, <&abe_sys_clk_div>, <&func_24m_clk>, <&atl_clkin3_ck>, <&atl_clkin2_ck>, <&atl_clkin1_ck>, <&atl_clkin0_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&mlb_clk>, <&mlbp_clk>; @@ -1768,7 +1768,7 @@ reg = <0x1860>; };
- mcasp2_aux_gfclk_mux: mcasp2_aux_gfclk_mux { + mcasp2_aux_gfclk_mux: mcasp2_aux_gfclk_mux@1860 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&per_abe_x1_gfclk2_div>, <&video1_clk2_div>, <&video2_clk2_div>, <&hdmi_clk2_div>; @@ -1776,7 +1776,7 @@ reg = <0x1860>; };
- mcasp3_ahclkx_mux: mcasp3_ahclkx_mux { + mcasp3_ahclkx_mux: mcasp3_ahclkx_mux@1868 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&abe_24m_fclk>, <&abe_sys_clk_div>, <&func_24m_clk>, <&atl_clkin3_ck>, <&atl_clkin2_ck>, <&atl_clkin1_ck>, <&atl_clkin0_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&mlb_clk>, <&mlbp_clk>; @@ -1784,7 +1784,7 @@ reg = <0x1868>; };
- mcasp3_aux_gfclk_mux: mcasp3_aux_gfclk_mux { + mcasp3_aux_gfclk_mux: mcasp3_aux_gfclk_mux@1868 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&per_abe_x1_gfclk2_div>, <&video1_clk2_div>, <&video2_clk2_div>, <&hdmi_clk2_div>; @@ -1792,7 +1792,7 @@ reg = <0x1868>; };
- mcasp4_ahclkx_mux: mcasp4_ahclkx_mux { + mcasp4_ahclkx_mux: mcasp4_ahclkx_mux@1898 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&abe_24m_fclk>, <&abe_sys_clk_div>, <&func_24m_clk>, <&atl_clkin3_ck>, <&atl_clkin2_ck>, <&atl_clkin1_ck>, <&atl_clkin0_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&mlb_clk>, <&mlbp_clk>; @@ -1800,7 +1800,7 @@ reg = <0x1898>; };
- mcasp4_aux_gfclk_mux: mcasp4_aux_gfclk_mux { + mcasp4_aux_gfclk_mux: mcasp4_aux_gfclk_mux@1898 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&per_abe_x1_gfclk2_div>, <&video1_clk2_div>, <&video2_clk2_div>, <&hdmi_clk2_div>; @@ -1808,7 +1808,7 @@ reg = <0x1898>; };
- mcasp5_ahclkx_mux: mcasp5_ahclkx_mux { + mcasp5_ahclkx_mux: mcasp5_ahclkx_mux@1878 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&abe_24m_fclk>, <&abe_sys_clk_div>, <&func_24m_clk>, <&atl_clkin3_ck>, <&atl_clkin2_ck>, <&atl_clkin1_ck>, <&atl_clkin0_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&mlb_clk>, <&mlbp_clk>; @@ -1816,7 +1816,7 @@ reg = <0x1878>; };
- mcasp5_aux_gfclk_mux: mcasp5_aux_gfclk_mux { + mcasp5_aux_gfclk_mux: mcasp5_aux_gfclk_mux@1878 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&per_abe_x1_gfclk2_div>, <&video1_clk2_div>, <&video2_clk2_div>, <&hdmi_clk2_div>; @@ -1824,7 +1824,7 @@ reg = <0x1878>; };
- mcasp6_ahclkx_mux: mcasp6_ahclkx_mux { + mcasp6_ahclkx_mux: mcasp6_ahclkx_mux@1904 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&abe_24m_fclk>, <&abe_sys_clk_div>, <&func_24m_clk>, <&atl_clkin3_ck>, <&atl_clkin2_ck>, <&atl_clkin1_ck>, <&atl_clkin0_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&mlb_clk>, <&mlbp_clk>; @@ -1832,7 +1832,7 @@ reg = <0x1904>; };
- mcasp6_aux_gfclk_mux: mcasp6_aux_gfclk_mux { + mcasp6_aux_gfclk_mux: mcasp6_aux_gfclk_mux@1904 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&per_abe_x1_gfclk2_div>, <&video1_clk2_div>, <&video2_clk2_div>, <&hdmi_clk2_div>; @@ -1840,7 +1840,7 @@ reg = <0x1904>; };
- mcasp7_ahclkx_mux: mcasp7_ahclkx_mux { + mcasp7_ahclkx_mux: mcasp7_ahclkx_mux@1908 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&abe_24m_fclk>, <&abe_sys_clk_div>, <&func_24m_clk>, <&atl_clkin3_ck>, <&atl_clkin2_ck>, <&atl_clkin1_ck>, <&atl_clkin0_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&mlb_clk>, <&mlbp_clk>; @@ -1848,7 +1848,7 @@ reg = <0x1908>; };
- mcasp7_aux_gfclk_mux: mcasp7_aux_gfclk_mux { + mcasp7_aux_gfclk_mux: mcasp7_aux_gfclk_mux@1908 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&per_abe_x1_gfclk2_div>, <&video1_clk2_div>, <&video2_clk2_div>, <&hdmi_clk2_div>; @@ -1856,7 +1856,7 @@ reg = <0x1908>; };
- mcasp8_ahclk_mux: mcasp8_ahclk_mux { + mcasp8_ahclk_mux: mcasp8_ahclk_mux@1890 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&abe_24m_fclk>, <&abe_sys_clk_div>, <&func_24m_clk>, <&atl_clkin3_ck>, <&atl_clkin2_ck>, <&atl_clkin1_ck>, <&atl_clkin0_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&mlb_clk>, <&mlbp_clk>; @@ -1864,7 +1864,7 @@ reg = <0x1890>; };
- mcasp8_aux_gfclk_mux: mcasp8_aux_gfclk_mux { + mcasp8_aux_gfclk_mux: mcasp8_aux_gfclk_mux@1890 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&per_abe_x1_gfclk2_div>, <&video1_clk2_div>, <&video2_clk2_div>, <&hdmi_clk2_div>; @@ -1872,7 +1872,7 @@ reg = <0x1890>; };
- mmc1_fclk_mux: mmc1_fclk_mux { + mmc1_fclk_mux: mmc1_fclk_mux@1328 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&func_128m_clk>, <&dpll_per_m2x2_ck>; @@ -1880,7 +1880,7 @@ reg = <0x1328>; };
- mmc1_fclk_div: mmc1_fclk_div { + mmc1_fclk_div: mmc1_fclk_div@1328 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&mmc1_fclk_mux>; @@ -1890,7 +1890,7 @@ ti,index-power-of-two; };
- mmc2_fclk_mux: mmc2_fclk_mux { + mmc2_fclk_mux: mmc2_fclk_mux@1330 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&func_128m_clk>, <&dpll_per_m2x2_ck>; @@ -1898,7 +1898,7 @@ reg = <0x1330>; };
- mmc2_fclk_div: mmc2_fclk_div { + mmc2_fclk_div: mmc2_fclk_div@1330 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&mmc2_fclk_mux>; @@ -1908,7 +1908,7 @@ ti,index-power-of-two; };
- mmc3_gfclk_mux: mmc3_gfclk_mux { + mmc3_gfclk_mux: mmc3_gfclk_mux@1820 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&func_48m_fclk>, <&dpll_per_m2x2_ck>; @@ -1916,7 +1916,7 @@ reg = <0x1820>; };
- mmc3_gfclk_div: mmc3_gfclk_div { + mmc3_gfclk_div: mmc3_gfclk_div@1820 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&mmc3_gfclk_mux>; @@ -1926,7 +1926,7 @@ ti,index-power-of-two; };
- mmc4_gfclk_mux: mmc4_gfclk_mux { + mmc4_gfclk_mux: mmc4_gfclk_mux@1828 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&func_48m_fclk>, <&dpll_per_m2x2_ck>; @@ -1934,7 +1934,7 @@ reg = <0x1828>; };
- mmc4_gfclk_div: mmc4_gfclk_div { + mmc4_gfclk_div: mmc4_gfclk_div@1828 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&mmc4_gfclk_mux>; @@ -1944,7 +1944,7 @@ ti,index-power-of-two; };
- qspi_gfclk_mux: qspi_gfclk_mux { + qspi_gfclk_mux: qspi_gfclk_mux@1838 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&func_128m_clk>, <&dpll_per_h13x2_ck>; @@ -1952,7 +1952,7 @@ reg = <0x1838>; };
- qspi_gfclk_div: qspi_gfclk_div { + qspi_gfclk_div: qspi_gfclk_div@1838 { #clock-cells = <0>; compatible = "ti,divider-clock"; clocks = <&qspi_gfclk_mux>; @@ -1962,7 +1962,7 @@ ti,index-power-of-two; };
- timer10_gfclk_mux: timer10_gfclk_mux { + timer10_gfclk_mux: timer10_gfclk_mux@1728 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&timer_sys_clk_div>, <&sys_32k_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&abe_giclk_div>, <&video1_div_clk>, <&video2_div_clk>, <&hdmi_div_clk>; @@ -1970,7 +1970,7 @@ reg = <0x1728>; };
- timer11_gfclk_mux: timer11_gfclk_mux { + timer11_gfclk_mux: timer11_gfclk_mux@1730 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&timer_sys_clk_div>, <&sys_32k_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&abe_giclk_div>, <&video1_div_clk>, <&video2_div_clk>, <&hdmi_div_clk>; @@ -1978,7 +1978,7 @@ reg = <0x1730>; };
- timer13_gfclk_mux: timer13_gfclk_mux { + timer13_gfclk_mux: timer13_gfclk_mux@17c8 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&timer_sys_clk_div>, <&sys_32k_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&abe_giclk_div>, <&video1_div_clk>, <&video2_div_clk>, <&hdmi_div_clk>; @@ -1986,7 +1986,7 @@ reg = <0x17c8>; };
- timer14_gfclk_mux: timer14_gfclk_mux { + timer14_gfclk_mux: timer14_gfclk_mux@17d0 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&timer_sys_clk_div>, <&sys_32k_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&abe_giclk_div>, <&video1_div_clk>, <&video2_div_clk>, <&hdmi_div_clk>; @@ -1994,7 +1994,7 @@ reg = <0x17d0>; };
- timer15_gfclk_mux: timer15_gfclk_mux { + timer15_gfclk_mux: timer15_gfclk_mux@17d8 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&timer_sys_clk_div>, <&sys_32k_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&abe_giclk_div>, <&video1_div_clk>, <&video2_div_clk>, <&hdmi_div_clk>; @@ -2002,7 +2002,7 @@ reg = <0x17d8>; };
- timer16_gfclk_mux: timer16_gfclk_mux { + timer16_gfclk_mux: timer16_gfclk_mux@1830 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&timer_sys_clk_div>, <&sys_32k_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&abe_giclk_div>, <&video1_div_clk>, <&video2_div_clk>, <&hdmi_div_clk>; @@ -2010,7 +2010,7 @@ reg = <0x1830>; };
- timer2_gfclk_mux: timer2_gfclk_mux { + timer2_gfclk_mux: timer2_gfclk_mux@1738 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&timer_sys_clk_div>, <&sys_32k_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&abe_giclk_div>, <&video1_div_clk>, <&video2_div_clk>, <&hdmi_div_clk>; @@ -2018,7 +2018,7 @@ reg = <0x1738>; };
- timer3_gfclk_mux: timer3_gfclk_mux { + timer3_gfclk_mux: timer3_gfclk_mux@1740 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&timer_sys_clk_div>, <&sys_32k_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&abe_giclk_div>, <&video1_div_clk>, <&video2_div_clk>, <&hdmi_div_clk>; @@ -2026,7 +2026,7 @@ reg = <0x1740>; };
- timer4_gfclk_mux: timer4_gfclk_mux { + timer4_gfclk_mux: timer4_gfclk_mux@1748 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&timer_sys_clk_div>, <&sys_32k_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&abe_giclk_div>, <&video1_div_clk>, <&video2_div_clk>, <&hdmi_div_clk>; @@ -2034,7 +2034,7 @@ reg = <0x1748>; };
- timer9_gfclk_mux: timer9_gfclk_mux { + timer9_gfclk_mux: timer9_gfclk_mux@1750 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&timer_sys_clk_div>, <&sys_32k_ck>, <&sys_clkin2>, <&ref_clkin0_ck>, <&ref_clkin1_ck>, <&ref_clkin2_ck>, <&ref_clkin3_ck>, <&abe_giclk_div>, <&video1_div_clk>, <&video2_div_clk>, <&hdmi_div_clk>; @@ -2042,7 +2042,7 @@ reg = <0x1750>; };
- uart1_gfclk_mux: uart1_gfclk_mux { + uart1_gfclk_mux: uart1_gfclk_mux@1840 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&func_48m_fclk>, <&dpll_per_m2x2_ck>; @@ -2050,7 +2050,7 @@ reg = <0x1840>; };
- uart2_gfclk_mux: uart2_gfclk_mux { + uart2_gfclk_mux: uart2_gfclk_mux@1848 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&func_48m_fclk>, <&dpll_per_m2x2_ck>; @@ -2058,7 +2058,7 @@ reg = <0x1848>; };
- uart3_gfclk_mux: uart3_gfclk_mux { + uart3_gfclk_mux: uart3_gfclk_mux@1850 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&func_48m_fclk>, <&dpll_per_m2x2_ck>; @@ -2066,7 +2066,7 @@ reg = <0x1850>; };
- uart4_gfclk_mux: uart4_gfclk_mux { + uart4_gfclk_mux: uart4_gfclk_mux@1858 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&func_48m_fclk>, <&dpll_per_m2x2_ck>; @@ -2074,7 +2074,7 @@ reg = <0x1858>; };
- uart5_gfclk_mux: uart5_gfclk_mux { + uart5_gfclk_mux: uart5_gfclk_mux@1870 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&func_48m_fclk>, <&dpll_per_m2x2_ck>; @@ -2082,7 +2082,7 @@ reg = <0x1870>; };
- uart7_gfclk_mux: uart7_gfclk_mux { + uart7_gfclk_mux: uart7_gfclk_mux@18d0 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&func_48m_fclk>, <&dpll_per_m2x2_ck>; @@ -2090,7 +2090,7 @@ reg = <0x18d0>; };
- uart8_gfclk_mux: uart8_gfclk_mux { + uart8_gfclk_mux: uart8_gfclk_mux@18e0 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&func_48m_fclk>, <&dpll_per_m2x2_ck>; @@ -2098,7 +2098,7 @@ reg = <0x18e0>; };
- uart9_gfclk_mux: uart9_gfclk_mux { + uart9_gfclk_mux: uart9_gfclk_mux@18e8 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&func_48m_fclk>, <&dpll_per_m2x2_ck>; @@ -2106,7 +2106,7 @@ reg = <0x18e8>; };
- vip1_gclk_mux: vip1_gclk_mux { + vip1_gclk_mux: vip1_gclk_mux@1020 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&l3_iclk_div>, <&dpll_core_h23x2_ck>; @@ -2114,7 +2114,7 @@ reg = <0x1020>; };
- vip2_gclk_mux: vip2_gclk_mux { + vip2_gclk_mux: vip2_gclk_mux@1028 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&l3_iclk_div>, <&dpll_core_h23x2_ck>; @@ -2122,7 +2122,7 @@ reg = <0x1028>; };
- vip3_gclk_mux: vip3_gclk_mux { + vip3_gclk_mux: vip3_gclk_mux@1030 { #clock-cells = <0>; compatible = "ti,mux-clock"; clocks = <&l3_iclk_div>, <&dpll_core_h23x2_ck>; @@ -2139,7 +2139,7 @@ };
&scm_conf_clocks { - dss_deshdcp_clk: dss_deshdcp_clk { + dss_deshdcp_clk: dss_deshdcp_clk@558 { #clock-cells = <0>; compatible = "ti,gate-clock"; clocks = <&l3_iclk_div>; diff --git a/arch/arm/dts/k2e-clocks.dtsi b/arch/arm/dts/k2e-clocks.dtsi index d56d68f..4b79bde 100644 --- a/arch/arm/dts/k2e-clocks.dtsi +++ b/arch/arm/dts/k2e-clocks.dtsi @@ -35,7 +35,7 @@ clocks { reg-names = "control"; };
- clkusb1: clkusb1 { + clkusb1: clkusb1@2350004 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk16>; @@ -45,7 +45,7 @@ clocks { domain-id = <0>; };
- clkhyperlink0: clkhyperlink0 { + clkhyperlink0: clkhyperlink0@2350030 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk12>; @@ -55,7 +55,7 @@ clocks { domain-id = <5>; };
- clkpcie1: clkpcie1 { + clkpcie1: clkpcie1@235006c { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk12>; @@ -65,7 +65,7 @@ clocks { domain-id = <18>; };
- clkxge: clkxge { + clkxge: clkxge@23500c8 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; diff --git a/arch/arm/dts/k2e-netcp.dtsi b/arch/arm/dts/k2e-netcp.dtsi index b13b3c9..01a44c5 100644 --- a/arch/arm/dts/k2e-netcp.dtsi +++ b/arch/arm/dts/k2e-netcp.dtsi @@ -8,7 +8,7 @@ * published by the Free Software Foundation. */
-qmss: qmss@2a40000 { +qmss: qmss_2a40000 { compatible = "ti,keystone-navigator-qmss"; dma-coherent; #address-cells = <1>; @@ -23,7 +23,7 @@ qmss: qmss@2a40000 { #address-cells = <1>; #size-cells = <1>; ranges; - qmgr0 { + qmgr0@0 { managed-queues = <0 0x2000>; reg = <0x2a40000 0x20000>, <0x2a06000 0x400>, @@ -85,7 +85,7 @@ qmss: qmss@2a40000 { }; }; /* qmss */
-knav_dmas: knav_dmas@0 { +knav_dmas: knav_dmas0 { compatible = "ti,keystone-navigator-dma"; clocks = <&papllclk>; #address-cells = <1>; diff --git a/arch/arm/dts/k2e.dtsi b/arch/arm/dts/k2e.dtsi index 675fb8e..f9be2ae 100644 --- a/arch/arm/dts/k2e.dtsi +++ b/arch/arm/dts/k2e.dtsi @@ -79,7 +79,7 @@ }; };
- dspgpio0: keystone_dsp_gpio@02620240 { + dspgpio0: keystone_dsp_gpio_02620240 { compatible = "ti,keystone-dsp-gpio"; gpio-controller; #gpio-cells = <2>; diff --git a/arch/arm/dts/k2g-netcp.dtsi b/arch/arm/dts/k2g-netcp.dtsi index 6f0ff86..879aa03 100644 --- a/arch/arm/dts/k2g-netcp.dtsi +++ b/arch/arm/dts/k2g-netcp.dtsi @@ -8,7 +8,7 @@ * published by the Free Software Foundation. */
-qmss: qmss@4020000 { +qmss: qmss_4020000 { compatible = "ti,keystone-navigator-qmss-l"; dma-coherent; #address-cells = <1>; @@ -24,7 +24,7 @@ qmss: qmss@4020000 { #address-cells = <1>; #size-cells = <1>; ranges; - qmgr0 { + qmgr0@0 { managed-queues = <0 0x80>; reg = <0x4100000 0x800>, <0x4040000 0x100>, @@ -68,7 +68,7 @@ qmss: qmss@4020000 { }; }; /* qmss */
-knav_dmas: knav_dmas@0 { +knav_dmas: knav_dmas0 { compatible = "ti,keystone-navigator-dma"; #address-cells = <1>; #size-cells = <1>; diff --git a/arch/arm/dts/k2g.dtsi b/arch/arm/dts/k2g.dtsi index a3ed444..1eaab0a 100644 --- a/arch/arm/dts/k2g.dtsi +++ b/arch/arm/dts/k2g.dtsi @@ -21,7 +21,7 @@ serial0 = &uart0; };
- memory { + memory@80000000 { device_type = "memory"; reg = <0x80000000 0x80000000>; }; @@ -39,7 +39,7 @@ }; };
- gic: interrupt-controller { + gic: interrupt-controller@0 { compatible = "arm,cortex-a15-gic"; #interrupt-cells = <3>; interrupt-controller; diff --git a/arch/arm/dts/k2hk-clocks.dtsi b/arch/arm/dts/k2hk-clocks.dtsi index af9b719..63d3d2c 100644 --- a/arch/arm/dts/k2hk-clocks.dtsi +++ b/arch/arm/dts/k2hk-clocks.dtsi @@ -53,7 +53,7 @@ clocks { reg-names = "control"; };
- clktsip: clktsip { + clktsip: clktsip@2350000 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk16>; @@ -63,7 +63,7 @@ clocks { domain-id = <0>; };
- clksrio: clksrio { + clksrio: clksrio@235002c { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk1rstiso13>; @@ -73,7 +73,7 @@ clocks { domain-id = <4>; };
- clkhyperlink0: clkhyperlink0 { + clkhyperlink0: clkhyperlink0@2350030 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk12>; @@ -83,7 +83,7 @@ clocks { domain-id = <5>; };
- clkgem1: clkgem1 { + clkgem1: clkgem1@2350040 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk1>; @@ -93,7 +93,7 @@ clocks { domain-id = <9>; };
- clkgem2: clkgem2 { + clkgem2: clkgem2@2350044 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk1>; @@ -103,7 +103,7 @@ clocks { domain-id = <10>; };
- clkgem3: clkgem3 { + clkgem3: clkgem3@2350048 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk1>; @@ -113,7 +113,7 @@ clocks { domain-id = <11>; };
- clkgem4: clkgem4 { + clkgem4: clkgem4@235004c { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk1>; @@ -123,7 +123,7 @@ clocks { domain-id = <12>; };
- clkgem5: clkgem5 { + clkgem5: clkgem5@2350050 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk1>; @@ -133,7 +133,7 @@ clocks { domain-id = <13>; };
- clkgem6: clkgem6 { + clkgem6: clkgem6@2350054 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk1>; @@ -143,7 +143,7 @@ clocks { domain-id = <14>; };
- clkgem7: clkgem7 { + clkgem7: clkgem7@2350058 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk1>; @@ -153,7 +153,7 @@ clocks { domain-id = <15>; };
- clkddr31: clkddr31 { + clkddr31: clkddr31@2350060 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -163,7 +163,7 @@ clocks { domain-id = <16>; };
- clktac: clktac { + clktac: clktac@2350064 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -173,7 +173,7 @@ clocks { domain-id = <17>; };
- clkrac01: clkrac01 { + clkrac01: clkrac01@2350068 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -183,7 +183,7 @@ clocks { domain-id = <17>; };
- clkrac23: clkrac23 { + clkrac23: clkrac23@235006c { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -193,7 +193,7 @@ clocks { domain-id = <18>; };
- clkfftc0: clkfftc0 { + clkfftc0: clkfftc0@2350070 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -203,7 +203,7 @@ clocks { domain-id = <19>; };
- clkfftc1: clkfftc1 { + clkfftc1: clkfftc1@2350074 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -213,7 +213,7 @@ clocks { domain-id = <19>; };
- clkfftc2: clkfftc2 { + clkfftc2: clkfftc2@2350078 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -223,7 +223,7 @@ clocks { domain-id = <20>; };
- clkfftc3: clkfftc3 { + clkfftc3: clkfftc3@235007c { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -233,7 +233,7 @@ clocks { domain-id = <20>; };
- clkfftc4: clkfftc4 { + clkfftc4: clkfftc4@2350080 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -243,7 +243,7 @@ clocks { domain-id = <20>; };
- clkfftc5: clkfftc5 { + clkfftc5: clkfftc5@2350084 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -253,7 +253,7 @@ clocks { domain-id = <20>; };
- clkaif: clkaif { + clkaif: clkaif@2350088 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -263,7 +263,7 @@ clocks { domain-id = <21>; };
- clktcp3d0: clktcp3d0 { + clktcp3d0: clktcp3d0@235008c { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -273,7 +273,7 @@ clocks { domain-id = <22>; };
- clktcp3d1: clktcp3d1 { + clktcp3d1: clktcp3d1@2350090 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -283,7 +283,7 @@ clocks { domain-id = <22>; };
- clktcp3d2: clktcp3d2 { + clktcp3d2: clktcp3d2@2350094 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -293,7 +293,7 @@ clocks { domain-id = <23>; };
- clktcp3d3: clktcp3d3 { + clktcp3d3: clktcp3d3@2350098 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -303,7 +303,7 @@ clocks { domain-id = <23>; };
- clkvcp0: clkvcp0 { + clkvcp0: clkvcp0@235009c { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -313,7 +313,7 @@ clocks { domain-id = <24>; };
- clkvcp1: clkvcp1 { + clkvcp1: clkvcp1@23500a0 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -323,7 +323,7 @@ clocks { domain-id = <24>; };
- clkvcp2: clkvcp2 { + clkvcp2: clkvcp2@23500a4 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -333,7 +333,7 @@ clocks { domain-id = <24>; };
- clkvcp3: clkvcp3 { + clkvcp3: clkvcp3@23500a8 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -343,7 +343,7 @@ clocks { domain-id = <24>; };
- clkvcp4: clkvcp4 { + clkvcp4: clkvcp4@23500ac { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -353,7 +353,7 @@ clocks { domain-id = <25>; };
- clkvcp5: clkvcp5 { + clkvcp5: clkvcp5@23500b0 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -363,7 +363,7 @@ clocks { domain-id = <25>; };
- clkvcp6: clkvcp6 { + clkvcp6: clkvcp6@23500b4 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -373,7 +373,7 @@ clocks { domain-id = <25>; };
- clkvcp7: clkvcp7 { + clkvcp7: clkvcp7@23500b8 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -383,7 +383,7 @@ clocks { domain-id = <25>; };
- clkbcp: clkbcp { + clkbcp: clkbcp@23500bc { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -393,7 +393,7 @@ clocks { domain-id = <26>; };
- clkdxb: clkdxb { + clkdxb: clkdxb@23500c0 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -403,7 +403,7 @@ clocks { domain-id = <27>; };
- clkhyperlink1: clkhyperlink1 { + clkhyperlink1: clkhyperlink1@23500c4 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk12>; @@ -413,7 +413,7 @@ clocks { domain-id = <28>; };
- clkxge: clkxge { + clkxge: clkxge@23500c8 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; diff --git a/arch/arm/dts/k2hk-netcp.dtsi b/arch/arm/dts/k2hk-netcp.dtsi index 77a32c3..f974e1f 100644 --- a/arch/arm/dts/k2hk-netcp.dtsi +++ b/arch/arm/dts/k2hk-netcp.dtsi @@ -8,7 +8,7 @@ * published by the Free Software Foundation. */
-qmss: qmss@2a40000 { +qmss: qmss_2a40000 { compatible = "ti,keystone-navigator-qmss"; dma-coherent; #address-cells = <1>; @@ -23,7 +23,7 @@ qmss: qmss@2a40000 { #address-cells = <1>; #size-cells = <1>; ranges; - qmgr0 { + qmgr0@0 { managed-queues = <0 0x2000>; reg = <0x2a40000 0x20000>, <0x2a06000 0x400>, @@ -35,7 +35,7 @@ qmss: qmss@2a40000 { "region", "push", "pop"; };
- qmgr1 { + qmgr1@1 { managed-queues = <0x2000 0x2000>; reg = <0x2a60000 0x20000>, <0x2a06400 0x400>, @@ -101,7 +101,7 @@ qmss: qmss@2a40000 { }; }; /* qmss */
-knav_dmas: knav_dmas@0 { +knav_dmas: knav_dmas0 { compatible = "ti,keystone-navigator-dma"; clocks = <&papllclk>; #address-cells = <1>; diff --git a/arch/arm/dts/k2hk.dtsi b/arch/arm/dts/k2hk.dtsi index d0810a5..609c6cd 100644 --- a/arch/arm/dts/k2hk.dtsi +++ b/arch/arm/dts/k2hk.dtsi @@ -43,56 +43,56 @@ soc { /include/ "k2hk-clocks.dtsi"
- dspgpio0: keystone_dsp_gpio@02620240 { + dspgpio0: keystone_dsp_gpio_02620240 { compatible = "ti,keystone-dsp-gpio"; gpio-controller; #gpio-cells = <2>; gpio,syscon-dev = <&devctrl 0x240>; };
- dspgpio1: keystone_dsp_gpio@2620244 { + dspgpio1: keystone_dsp_gpio_2620244 { compatible = "ti,keystone-dsp-gpio"; gpio-controller; #gpio-cells = <2>; gpio,syscon-dev = <&devctrl 0x244>; };
- dspgpio2: keystone_dsp_gpio@2620248 { + dspgpio2: keystone_dsp_gpio_2620248 { compatible = "ti,keystone-dsp-gpio"; gpio-controller; #gpio-cells = <2>; gpio,syscon-dev = <&devctrl 0x248>; };
- dspgpio3: keystone_dsp_gpio@262024c { + dspgpio3: keystone_dsp_gpio_262024c { compatible = "ti,keystone-dsp-gpio"; gpio-controller; #gpio-cells = <2>; gpio,syscon-dev = <&devctrl 0x24c>; };
- dspgpio4: keystone_dsp_gpio@2620250 { + dspgpio4: keystone_dsp_gpio_2620250 { compatible = "ti,keystone-dsp-gpio"; gpio-controller; #gpio-cells = <2>; gpio,syscon-dev = <&devctrl 0x250>; };
- dspgpio5: keystone_dsp_gpio@2620254 { + dspgpio5: keystone_dsp_gpio_2620254 { compatible = "ti,keystone-dsp-gpio"; gpio-controller; #gpio-cells = <2>; gpio,syscon-dev = <&devctrl 0x254>; };
- dspgpio6: keystone_dsp_gpio@2620258 { + dspgpio6: keystone_dsp_gpio_2620258 { compatible = "ti,keystone-dsp-gpio"; gpio-controller; #gpio-cells = <2>; gpio,syscon-dev = <&devctrl 0x258>; };
- dspgpio7: keystone_dsp_gpio@262025c { + dspgpio7: keystone_dsp_gpio_262025c { compatible = "ti,keystone-dsp-gpio"; gpio-controller; #gpio-cells = <2>; diff --git a/arch/arm/dts/k2l-clocks.dtsi b/arch/arm/dts/k2l-clocks.dtsi index ef8464b..6d20d71 100644 --- a/arch/arm/dts/k2l-clocks.dtsi +++ b/arch/arm/dts/k2l-clocks.dtsi @@ -44,7 +44,7 @@ clocks { reg-names = "control"; };
- clkdfeiqnsys: clkdfeiqnsys { + clkdfeiqnsys: clkdfeiqnsys@2350004 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk12>; @@ -54,7 +54,7 @@ clocks { domain-id = <0>; };
- clkpcie1: clkpcie1 { + clkpcie1: clkpcie1@235002c { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk12>; @@ -64,7 +64,7 @@ clocks { domain-id = <4>; };
- clkgem1: clkgem1 { + clkgem1: clkgem1@2350040 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk1>; @@ -74,7 +74,7 @@ clocks { domain-id = <9>; };
- clkgem2: clkgem2 { + clkgem2: clkgem2@2350044 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk1>; @@ -84,7 +84,7 @@ clocks { domain-id = <10>; };
- clkgem3: clkgem3 { + clkgem3: clkgem3@2350048 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk1>; @@ -94,7 +94,7 @@ clocks { domain-id = <11>; };
- clktac: clktac { + clktac: clktac@2350068 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -104,7 +104,7 @@ clocks { domain-id = <17>; };
- clkrac: clkrac { + clkrac: clkrac@235006c { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -114,7 +114,7 @@ clocks { domain-id = <17>; };
- clkdfepd0: clkdfepd0 { + clkdfepd0: clkdfepd0@235006c { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -124,7 +124,7 @@ clocks { domain-id = <18>; };
- clkfftc0: clkfftc0 { + clkfftc0: clkfftc0@2350070 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -134,7 +134,7 @@ clocks { domain-id = <19>; };
- clkosr: clkosr { + clkosr: clkosr@2350088 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -144,7 +144,7 @@ clocks { domain-id = <21>; };
- clktcp3d0: clktcp3d0 { + clktcp3d0: clktcp3d0@235008c { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -154,7 +154,7 @@ clocks { domain-id = <22>; };
- clktcp3d1: clktcp3d1 { + clktcp3d1: clktcp3d1@2350094 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -164,7 +164,7 @@ clocks { domain-id = <23>; };
- clkvcp0: clkvcp0 { + clkvcp0: clkvcp0@235009c { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -174,7 +174,7 @@ clocks { domain-id = <24>; };
- clkvcp1: clkvcp1 { + clkvcp1: clkvcp1@23500a0 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -184,7 +184,7 @@ clocks { domain-id = <24>; };
- clkvcp2: clkvcp2 { + clkvcp2: clkvcp2@23500a4 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -194,7 +194,7 @@ clocks { domain-id = <24>; };
- clkvcp3: clkvcp3 { + clkvcp3: clkvcp3@23500a8 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -204,7 +204,7 @@ clocks { domain-id = <24>; };
- clkbcp: clkbcp { + clkbcp: clkbcp@23500bc { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -214,7 +214,7 @@ clocks { domain-id = <26>; };
- clkdfepd1: clkdfepd1 { + clkdfepd1: clkdfepd1@23500c0 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -224,7 +224,7 @@ clocks { domain-id = <27>; };
- clkfftc1: clkfftc1 { + clkfftc1: clkfftc1@23500c4 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -234,7 +234,7 @@ clocks { domain-id = <28>; };
- clkiqnail: clkiqnail { + clkiqnail: clkiqnail@23500c8 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -244,7 +244,7 @@ clocks { domain-id = <29>; };
- clkuart2: clkuart2 { + clkuart2: clkuart2@2350000 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&clkmodrst0>; @@ -254,7 +254,7 @@ clocks { domain-id = <0>; };
- clkuart3: clkuart3 { + clkuart3: clkuart3@2350000 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&clkmodrst0>; diff --git a/arch/arm/dts/k2l-netcp.dtsi b/arch/arm/dts/k2l-netcp.dtsi index 6b95284..f99945a 100644 --- a/arch/arm/dts/k2l-netcp.dtsi +++ b/arch/arm/dts/k2l-netcp.dtsi @@ -8,7 +8,7 @@ * published by the Free Software Foundation. */
-knav_dmas: knav_dmas@0 { +knav_dmas: knav_dmas0 { compatible = "ti,keystone-navigator-dma"; clocks = <&papllclk>; #address-cells = <1>; diff --git a/arch/arm/dts/k2l.dtsi b/arch/arm/dts/k2l.dtsi index 49fd414..a7e3a8a 100644 --- a/arch/arm/dts/k2l.dtsi +++ b/arch/arm/dts/k2l.dtsi @@ -51,28 +51,28 @@ interrupts = <GIC_SPI 435 IRQ_TYPE_EDGE_RISING>; };
- dspgpio3: keystone_dsp_gpio@262024c { + dspgpio3: keystone_dsp_gpio_262024c { compatible = "ti,keystone-dsp-gpio"; gpio-controller; #gpio-cells = <2>; diff --git a/arch/arm/dts/keystone-clocks.dtsi b/arch/arm/dts/keystone-clocks.dtsi index 0c334b2..becb331 100644 --- a/arch/arm/dts/keystone-clocks.dtsi +++ b/arch/arm/dts/keystone-clocks.dtsi @@ -51,7 +51,7 @@ clocks { clock-output-names = "gemtraceclk"; };
- chipstmxptclk: chipstmxptclk { + chipstmxptclk: chipstmxptclk@2310164 { #clock-cells = <0>; compatible = "ti,keystone,pll-divider-clock"; clocks = <&mainmuxclk>; @@ -160,7 +160,7 @@ clocks { clock-output-names = "chipclk1rstiso112"; };
- clkmodrst0: clkmodrst0 { + clkmodrst0: clkmodrst0@2350000 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk16>; @@ -171,7 +171,7 @@ clocks { };
- clkusb: clkusb { + clkusb: clkusb@2350008 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk16>; @@ -181,7 +181,7 @@ clocks { domain-id = <0>; };
- clkaemifspi: clkaemifspi { + clkaemifspi: clkaemifspi@235000c { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk16>; @@ -192,7 +192,7 @@ clocks { };
- clkdebugsstrc: clkdebugsstrc { + clkdebugsstrc: clkdebugsstrc@2350014 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -202,7 +202,7 @@ clocks { domain-id = <1>; };
- clktetbtrc: clktetbtrc { + clktetbtrc: clktetbtrc@2350018 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk13>; @@ -212,7 +212,7 @@ clocks { domain-id = <1>; };
- clkpa: clkpa { + clkpa: clkpa@235001c { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&paclk13>; @@ -222,7 +222,7 @@ clocks { domain-id = <2>; };
- clkcpgmac: clkcpgmac { + clkcpgmac: clkcpgmac@2350020 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&clkpa>; @@ -232,7 +232,7 @@ clocks { domain-id = <2>; };
- clksa: clksa { + clksa: clksa@2350024 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&clkpa>; @@ -242,7 +242,7 @@ clocks { domain-id = <2>; };
- clkpcie: clkpcie { + clkpcie: clkpcie@2350028 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk12>; @@ -252,7 +252,7 @@ clocks { domain-id = <3>; };
- clksr: clksr { + clksr: clksr@2350034 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk1rstiso112>; @@ -262,7 +262,7 @@ clocks { domain-id = <6>; };
- clkgem0: clkgem0 { + clkgem0: clkgem0@235003c { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk1>; @@ -272,7 +272,7 @@ clocks { domain-id = <8>; };
- clkddr30: clkddr30 { + clkddr30: clkddr30@235005c { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&chipclk12>; @@ -282,7 +282,7 @@ clocks { domain-id = <16>; };
- clkwdtimer0: clkwdtimer0 { + clkwdtimer0: clkwdtimer0@2350000 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&clkmodrst0>; @@ -292,7 +292,7 @@ clocks { domain-id = <0>; };
- clkwdtimer1: clkwdtimer1 { + clkwdtimer1: clkwdtimer1@2350000 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&clkmodrst0>; @@ -302,7 +302,7 @@ clocks { domain-id = <0>; };
- clkwdtimer2: clkwdtimer2 { + clkwdtimer2: clkwdtimer2@2350000 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&clkmodrst0>; @@ -312,7 +312,7 @@ clocks { domain-id = <0>; };
- clkwdtimer3: clkwdtimer3 { + clkwdtimer3: clkwdtimer3@2350000 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&clkmodrst0>; @@ -322,7 +322,7 @@ clocks { domain-id = <0>; };
- clktimer15: clktimer15 { + clktimer15: clktimer15@2350000 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&clkmodrst0>; @@ -332,7 +332,7 @@ clocks { domain-id = <0>; };
- clkuart0: clkuart0 { + clkuart0: clkuart0@2350000 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&clkmodrst0>; @@ -342,7 +342,7 @@ clocks { domain-id = <0>; };
- clkuart1: clkuart1 { + clkuart1: clkuart1@2350000 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&clkmodrst0>; @@ -352,7 +352,7 @@ clocks { domain-id = <0>; };
- clkaemif: clkaemif { + clkaemif: clkaemif@2350000 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&clkaemifspi>; @@ -362,7 +362,7 @@ clocks { domain-id = <0>; };
- clkusim: clkusim { + clkusim: clkusim@2350000 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&clkmodrst0>; @@ -372,7 +372,7 @@ clocks { domain-id = <0>; };
- clki2c: clki2c { + clki2c: clki2c@2350000 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&clkmodrst0>; @@ -382,7 +382,7 @@ clocks { domain-id = <0>; };
- clkspi: clkspi { + clkspi: clkspi@2350000 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&clkaemifspi>; @@ -392,7 +392,7 @@ clocks { domain-id = <0>; };
- clkgpio: clkgpio { + clkgpio: clkgpio@2350000 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&clkmodrst0>; @@ -402,7 +402,7 @@ clocks { domain-id = <0>; };
- clkkeymgr: clkkeymgr { + clkkeymgr: clkkeymgr@2350000 { #clock-cells = <0>; compatible = "ti,keystone,psc-clock"; clocks = <&clkmodrst0>; diff --git a/arch/arm/dts/keystone.dtsi b/arch/arm/dts/keystone.dtsi index f39b969..f8375f4 100644 --- a/arch/arm/dts/keystone.dtsi +++ b/arch/arm/dts/keystone.dtsi @@ -25,11 +25,11 @@ stdout-path = &uart0; };
- memory { + memory@80000000 { reg = <0x80000000 0x40000000>; };
- gic: interrupt-controller { + gic: interrupt-controller@0 { compatible = "arm,cortex-a15-gic"; #interrupt-cells = <3>; interrupt-controller; @@ -270,7 +270,7 @@ 1 0 0x21000A00 0x00000100>; };
- kirq0: keystone_irq@26202a0 { + kirq0: keystone_irq_26202a0 { compatible = "ti,keystone-irq"; interrupts = <GIC_SPI 4 IRQ_TYPE_EDGE_RISING>; interrupt-controller;
Heiko Schocher
