[U-Boot] Please pull u-boot-fsl-qoriq master
Tom,
The following changes since commit 4ed6ed3c27a069a00c8a557d606a05276cc4653e:
Merge branch 'master' of git://www.denx.de/git/u-boot-microblaze (2016-04-04 14:34:09 -0400)
git://git.denx.de/u-boot-fsl-qoriq.git master
for you to fetch changes up to 3c1d218a1d3048fb576677c47eab43049d0b7778:
armv8: LS2080A: Consolidate LS2080A and LS2085A (2016-04-06 10:26:46 -0700)
---------------------------------------------------------------- Codrin Ciubotariu (2): drivers: net: vsc9953: Do not configure disabled ports drivers: net: vsc9953: Fix bug when PVID is shown for disabled ports only
Ed Swarthout (1): armv8: LSCH2 early and final mmu needs matching NS attribute
Peng Fan (2): fsl: esdhc: support driver model fsl: esdhc: consolidate fsl_esdhc_cfg structure
Qianyu Gong (2): armv8: ls1043a: load Fman ucode from NAND flash under NAND boot armv8: ls1043a: load Fman ucode from SD/MMC under SD boot
Shaohui Xie (1): armv8: ls1043aqds: make sure fixed-link property is big endian
Vincent Siles (1): arm: ls102xa: Fix order of CSU indexes in ns_access.h
Wenbin Song (1): armv8/ls1043aqds: modify CONFIG_SYS_MAX_FLASH_BANKS to 1
York Sun (1): armv8: LS2080A: Consolidate LS2080A and LS2085A
arch/arm/cpu/armv8/fsl-layerscape/Makefile | 4 - arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 9 +- .../arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c | 6 +- arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 2 +- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 26 +- arch/arm/cpu/armv8/fsl-layerscape/spl.c | 4 +- arch/arm/include/asm/arch-fsl-layerscape/config.h | 9 +- arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 14 +- .../include/asm/arch-fsl-layerscape/fsl_serdes.h | 2 +- arch/arm/include/asm/arch-fsl-layerscape/soc.h | 3 + arch/arm/include/asm/arch-ls102xa/ns_access.h | 6 +- arch/arm/include/asm/fsl_secure_boot.h | 12 +- board/freescale/ls1043aqds/eth.c | 12 +- board/freescale/ls2080a/MAINTAINERS | 2 - board/freescale/ls2080a/ddr.c | 27 ++- board/freescale/ls2080a/ls2080a.c | 2 +- board/freescale/ls2080aqds/MAINTAINERS | 3 - board/freescale/ls2080aqds/ddr.c | 27 ++- board/freescale/ls2080aqds/ls2080aqds.c | 2 +- board/freescale/ls2080ardb/MAINTAINERS | 3 - board/freescale/ls2080ardb/ddr.c | 27 ++- board/freescale/ls2080ardb/ls2080ardb.c | 2 +- configs/ls2085a_emu_defconfig | 20 -- configs/ls2085a_simu_defconfig | 21 -- configs/ls2085aqds_SECURE_BOOT_defconfig | 20 -- configs/ls2085aqds_defconfig | 19 -- configs/ls2085aqds_nand_defconfig | 14 -- configs/ls2085ardb_SECURE_BOOT_defconfig | 20 -- configs/ls2085ardb_defconfig | 19 -- configs/ls2085ardb_nand_defconfig | 14 -- doc/device-tree-bindings/serial/8250.txt | 2 +- drivers/crypto/fsl/jr.c | 6 +- drivers/mmc/fsl_esdhc.c | 253 ++++++++++++++++---- drivers/net/fsl-mc/mc.c | 10 + drivers/net/ldpaa_eth/Makefile | 1 - drivers/net/vsc9953.c | 14 +- include/configs/ls1043a_common.h | 14 +- include/configs/ls1043aqds.h | 2 +- include/configs/ls2080a_common.h | 7 +- include/configs/ls2080a_emu.h | 7 - include/configs/ls2080a_simu.h | 7 - include/fsl_esdhc.h | 6 +- include/linux/usb/xhci-fsl.h | 2 +- 43 files changed, 369 insertions(+), 313 deletions(-) delete mode 100644 configs/ls2085a_emu_defconfig delete mode 100644 configs/ls2085a_simu_defconfig delete mode 100644 configs/ls2085aqds_SECURE_BOOT_defconfig delete mode 100644 configs/ls2085aqds_defconfig delete mode 100644 configs/ls2085aqds_nand_defconfig delete mode 100644 configs/ls2085ardb_SECURE_BOOT_defconfig delete mode 100644 configs/ls2085ardb_defconfig delete mode 100644 configs/ls2085ardb_nand_defconfig
Thanks.
York
On Wed, Apr 06, 2016 at 10:35:25AM -0700, York Sun wrote:
Tom,
York Sun
