[U-Boot] [Patch v2] spl: Fix compiling warning on gunzip argument
common/spl/spl_fit.c:201:12: warning: passing argument 4 of ‘gunzip’ from incompatible pointer type [-Wincompatible-pointer-types] src, &length))
Signed-off-by: York Sun york.sun@nxp.com Reported-by: Heinrich Schuchardt xypron.glpk@gmx.de CC: Jean-Jacques Hiblot jjhiblot@ti.com --- Change log v2: Update length after gunzip
common/spl/spl_fit.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 49ccf1c..32d9ee5 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -135,6 +135,7 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, int offset; size_t length; int len; + ulong size; ulong load_addr, load_ptr; void *src; ulong overhead; @@ -197,11 +198,13 @@ static int spl_load_fit_image(struct spl_load_info *info, ulong sector, IS_ENABLED(CONFIG_SPL_GZIP) && image_comp == IH_COMP_GZIP && type == IH_TYPE_KERNEL) { + size = length; if (gunzip((void *)load_addr, CONFIG_SYS_BOOTM_LEN, - src, &length)) { + src, &size)) { puts("Uncompressing error\n"); return -EIO; } + length = size; } else { memcpy((void *)load_addr, src, length); }
Tom,
Will you bring in this patch or you prefer a PR? I am about to send a PR in a day or two (pending travis-ci testing).
York
Tom,
I'll be picking this up shortly, thanks.
York Sun
