[PATCH v2 0/2] cmd: acpi: fix acpi list command
The size of the ACPI table header is not a multiple of 8. We have to mark struct acpi_xsdt as packed to correctly access field Entry.
Add a unit test for the offsets of field Entry in the RSDT and XSDT tables.
ACPI tables may comprise either RSDT, XSDT, or both. The current code fails to check the presence of the RSDT table before accessing it. This leads to an exception if the RSDT table is not provided.
The XSDT table takes precedence over the RSDT table.
Addresses in the XSDT table are 64-bit. Adjust the output accordingly.
As the RSDT table has to be ignored if the XSDT command is present there is no need to compare the tables in a display command. Anyway the specification does not require that the sequence of addresses in the RSDT and XSDT table are the same.
The FACS table header does not provide revision information. Correct the description of dump_hdr().
Adjust the ACPI test to match the changed output format of the 'acpi list' command.
v2: merge patch 2 and 3 remove leading zeros from address output
Heinrich Schuchardt (2): acpi: fix struct acpi_xsdt cmd: acpi: fix acpi list command
cmd/acpi.c | 48 +++++++++++++++++++++++---------------- include/acpi/acpi_table.h | 2 +- test/dm/acpi.c | 28 +++++++++++++++-------- 3 files changed, 49 insertions(+), 29 deletions(-)
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- v2: add unit test --- include/acpi/acpi_table.h | 2 +- test/dm/acpi.c | 10 ++++++++++ 2 files changed, 11 insertions(+), 1 deletion(-)
diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index a3b67259e6..20ac3b51ba 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -80,7 +80,7 @@ struct acpi_rsdt { };
/* XSDT (Extended System Description Table) */ -struct acpi_xsdt { +struct __packed acpi_xsdt { struct acpi_table_header header; u64 entry[MAX_ACPI_TABLES]; }; diff --git a/test/dm/acpi.c b/test/dm/acpi.c index 5997bda649..559cf1693b 100644 --- a/test/dm/acpi.c +++ b/test/dm/acpi.c @@ -651,3 +651,13 @@ static int dm_test_acpi_cmd_set(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_acpi_cmd_set, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT); + +/* Test offsets in RSDT, XSDT */ +static int dm_test_acpi_offsets(struct unit_test_state *uts) +{ + ut_asserteq(36, offsetof(struct acpi_rsdt, entry)); + ut_asserteq(36, offsetof(struct acpi_xsdt, entry)); + + return 0; +} +DM_TEST(dm_test_acpi_offsets, 0);
On Sun, 12 Nov 2023 at 00:03, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
v2: add unit test
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- v2: add unit test for offset of field Entry in RSDT, XSDT merge patch 2 and 3 remove leading zeros from address output --- cmd/acpi.c | 48 +++++++++++++++++++++++++++++------------------- test/dm/acpi.c | 18 +++++++++--------- 2 files changed, 38 insertions(+), 28 deletions(-)
diff --git a/cmd/acpi.c b/cmd/acpi.c index 7e397d1a74..bf3fd08857 100644 --- a/cmd/acpi.c +++ b/cmd/acpi.c @@ -17,7 +17,8 @@ DECLARE_GLOBAL_DATA_PTR; /** * dump_hdr() - Dump an ACPI header * - * If the header is for FACS then it shows the revision information as well + * Except for the Firmware ACPI Control Structure (FACS) + * additionally show the revision information. * * @hdr: ACPI header to dump */ @@ -25,7 +26,7 @@ static void dump_hdr(struct acpi_table_header *hdr) { bool has_hdr = memcmp(hdr->signature, "FACS", ACPI_NAME_LEN);
- printf("%.*s %08lx %5x", ACPI_NAME_LEN, hdr->signature, + printf("%.*s %16lx %5x", ACPI_NAME_LEN, hdr->signature, (ulong)map_to_sysmem(hdr), hdr->length); if (has_hdr) { printf(" v%02d %.6s %.8s %x %.4s %x\n", hdr->revision, @@ -43,7 +44,7 @@ static int dump_table_name(const char *sig) hdr = acpi_find_table(sig); if (!hdr) return -ENOENT; - printf("%.*s @ %08lx\n", ACPI_NAME_LEN, hdr->signature, + printf("%.*s @ %16lx\n", ACPI_NAME_LEN, hdr->signature, (ulong)map_to_sysmem(hdr)); print_buffer(0, hdr, 1, hdr->length, 0);
@@ -62,26 +63,34 @@ static int list_rsdt(struct acpi_rsdt *rsdt, struct acpi_xsdt *xsdt) { int len, i, count;
- dump_hdr(&rsdt->header); - if (xsdt) + if (rsdt) + dump_hdr(&rsdt->header); + if (xsdt) { dump_hdr(&xsdt->header); - len = rsdt->header.length - sizeof(rsdt->header); - count = len / sizeof(u32); + len = xsdt->header.length - sizeof(xsdt->header); + count = len / sizeof(u64); + } else if (rsdt) { + len = rsdt->header.length - sizeof(rsdt->header); + count = len / sizeof(u32); + } else { + return 0; + } + for (i = 0; i < count; i++) { struct acpi_table_header *hdr;
- if (!rsdt->entry[i]) - break; - hdr = map_sysmem(rsdt->entry[i], 0); + if (xsdt) { + if (!xsdt->entry[i]) + break; + hdr = map_sysmem(xsdt->entry[i], 0); + } else { + if (!rsdt->entry[i]) + break; + hdr = map_sysmem(rsdt->entry[i], 0); + } dump_hdr(hdr); if (!memcmp(hdr->signature, "FACP", ACPI_NAME_LEN)) list_fadt((struct acpi_fadt *)hdr); - if (xsdt) { - if (xsdt->entry[i] != rsdt->entry[i]) { - printf(" (xsdt mismatch %llx)\n", - xsdt->entry[i]); - } - } }
return 0; @@ -92,10 +101,11 @@ static int list_rsdp(struct acpi_rsdp *rsdp) struct acpi_rsdt *rsdt; struct acpi_xsdt *xsdt;
- printf("RSDP %08lx %5x v%02d %.6s\n", (ulong)map_to_sysmem(rsdp), + printf("RSDP %16lx %5x v%02d %.6s\n", (ulong)map_to_sysmem(rsdp), rsdp->length, rsdp->revision, rsdp->oem_id); rsdt = map_sysmem(rsdp->rsdt_address, 0); xsdt = map_sysmem(rsdp->xsdt_address, 0); + list_rsdt(rsdt, xsdt);
return 0; @@ -111,8 +121,8 @@ static int do_acpi_list(struct cmd_tbl *cmdtp, int flag, int argc, printf("No ACPI tables present\n"); return 0; } - printf("Name Base Size Detail\n"); - printf("---- -------- ----- ------\n"); + printf("Name Base Size Detail\n" + "---- ---------------- ----- ----------------------------\n"); list_rsdp(rsdp);
return 0; diff --git a/test/dm/acpi.c b/test/dm/acpi.c index 559cf1693b..89b8ef513a 100644 --- a/test/dm/acpi.c +++ b/test/dm/acpi.c @@ -395,26 +395,26 @@ static int dm_test_acpi_cmd_list(struct unit_test_state *uts)
console_record_reset(); run_command("acpi list", 0); - ut_assert_nextline("Name Base Size Detail"); - ut_assert_nextline("---- -------- ----- ------"); - ut_assert_nextline("RSDP %08lx %5zx v02 U-BOOT", addr, + ut_assert_nextline("Name Base Size Detail"); + ut_assert_nextline("---- ---------------- ----- ----------------------------"); + ut_assert_nextline("RSDP %16lx %5zx v02 U-BOOT", addr, sizeof(struct acpi_rsdp)); addr = ALIGN(addr + sizeof(struct acpi_rsdp), 16); - ut_assert_nextline("RSDT %08lx %5zx v01 U-BOOT U-BOOTBL %x INTL 0", + ut_assert_nextline("RSDT %16lx %5zx v01 U-BOOT U-BOOTBL %x INTL 0", addr, sizeof(struct acpi_table_header) + 3 * sizeof(u32), OEM_REVISION); addr = ALIGN(addr + sizeof(struct acpi_rsdt), 16); - ut_assert_nextline("XSDT %08lx %5zx v01 U-BOOT U-BOOTBL %x INTL 0", + ut_assert_nextline("XSDT %16lx %5zx v01 U-BOOT U-BOOTBL %x INTL 0", addr, sizeof(struct acpi_table_header) + 3 * sizeof(u64), OEM_REVISION); addr = ALIGN(addr + sizeof(struct acpi_xsdt), 64); - ut_assert_nextline("DMAR %08lx %5zx v01 U-BOOT U-BOOTBL %x INTL 0", + ut_assert_nextline("DMAR %16lx %5zx v01 U-BOOT U-BOOTBL %x INTL 0", addr, sizeof(struct acpi_dmar), OEM_REVISION); addr = ALIGN(addr + sizeof(struct acpi_dmar), 16); - ut_assert_nextline("DMAR %08lx %5zx v01 U-BOOT U-BOOTBL %x INTL 0", + ut_assert_nextline("DMAR %16lx %5zx v01 U-BOOT U-BOOTBL %x INTL 0", addr, sizeof(struct acpi_dmar), OEM_REVISION); addr = ALIGN(addr + sizeof(struct acpi_dmar), 16); - ut_assert_nextline("DMAR %08lx %5zx v01 U-BOOT U-BOOTBL %x INTL 0", + ut_assert_nextline("DMAR %16lx %5zx v01 U-BOOT U-BOOTBL %x INTL 0", addr, sizeof(struct acpi_dmar), OEM_REVISION); ut_assert_console_end();
@@ -446,7 +446,7 @@ static int dm_test_acpi_cmd_dump(struct unit_test_state *uts) console_record_reset(); run_command("acpi dump dmar", 0); addr = ALIGN(map_to_sysmem(ctx.xsdt) + sizeof(struct acpi_xsdt), 64); - ut_assert_nextline("DMAR @ %08lx", addr); + ut_assert_nextline("DMAR @ %16lx", addr); ut_assert_nextlines_are_dump(0x30); ut_assert_console_end();
The patch does not consider that
map_sysmem(0, 0) != NULL
on the sandbox.
list_rsdp() needs to be changed to pass rsdt or xsdt as NULL if rsdt_address or xsdt_address is zero when invoking list_rsdt().
So this needs a respin.
Best regards
Heinrich
