[U-Boot] [PATCH] ARM: at91sam9m10/9g10: increase the size for u-boot
As to more features are added into the u-boot, which cause the u-boot size larger than 0x40000 (256KiB), so increase the size for u-boot through move offset of the u-boot environment. Or else, when execute saveenv command, which will erase the end of the u-boot causing it can not boot up again.
Signed-off-by: Bo Shen voice.shen@atmel.com --- include/configs/at91sam9261ek.h | 4 ++-- include/configs/at91sam9m10g45ek.h | 4 ++-- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 611e3e2..aeefbb3 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -212,8 +212,8 @@
/* bootstrap + u-boot + env + linux in nandflash */ #define CONFIG_ENV_IS_IN_NAND -#define CONFIG_ENV_OFFSET 0x60000 -#define CONFIG_ENV_OFFSET_REDUND 0x80000 +#define CONFIG_ENV_OFFSET 0xc0000 +#define CONFIG_ENV_OFFSET_REDUND 0xe0000 #define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ #define CONFIG_BOOTCOMMAND "nand read 0x22000000 0xA0000 0x200000; bootm" #define CONFIG_BOOTARGS "console=ttyS0,115200 " \ diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index e988d81..8cefa99 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -149,8 +149,8 @@
/* bootstrap + u-boot + env in nandflash */ #define CONFIG_ENV_IS_IN_NAND -#define CONFIG_ENV_OFFSET 0x60000 -#define CONFIG_ENV_OFFSET_REDUND 0x80000 +#define CONFIG_ENV_OFFSET 0xc0000 +#define CONFIG_ENV_OFFSET_REDUND 0xe0000 #define CONFIG_ENV_SIZE 0x20000
#define CONFIG_BOOTCOMMAND "nand read 0x70000000 0x100000 0x200000;" \
Bo Shen
