[U-Boot] [PATCH] Save environment data to mmc.
This patch is to save environment data to mmc card. It uses interfaces defined in generic mmc.
Signed-off-by: Terry Lv r65388@freescale.com --- common/Makefile | 1 + common/cmd_nvedit.c | 3 +- common/env_mmc.c | 359 +++++++++++++++++++++++++++++++++++++++++++++++++ include/environment.h | 18 +++ lib_arm/board.c | 10 +- lib_ppc/board.c | 12 +- 6 files changed, 391 insertions(+), 12 deletions(-) create mode 100644 common/env_mmc.c
diff --git a/common/Makefile b/common/Makefile index a92a75f..e92a2ce 100644 --- a/common/Makefile +++ b/common/Makefile @@ -58,6 +58,7 @@ COBJS-$(CONFIG_ENV_IS_IN_NAND) += env_nand.o COBJS-$(CONFIG_ENV_IS_IN_NVRAM) += env_nvram.o COBJS-$(CONFIG_ENV_IS_IN_ONENAND) += env_onenand.o COBJS-$(CONFIG_ENV_IS_IN_SPI_FLASH) += env_sf.o +COBJS-$(CONFIG_ENV_IS_IN_MMC) += env_mmc.o COBJS-$(CONFIG_ENV_IS_NOWHERE) += env_nowhere.o
# command diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 9f8d531..9168241 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -60,9 +60,10 @@ DECLARE_GLOBAL_DATA_PTR; !defined(CONFIG_ENV_IS_IN_NVRAM) && \ !defined(CONFIG_ENV_IS_IN_ONENAND) && \ !defined(CONFIG_ENV_IS_IN_SPI_FLASH) && \ + !defined(CONFIG_ENV_IS_IN_MMC) && \ !defined(CONFIG_ENV_IS_NOWHERE) # error Define one of CONFIG_ENV_IS_IN_{EEPROM|FLASH|DATAFLASH|ONENAND|\ -SPI_FLASH|MG_DISK|NVRAM|NOWHERE} +SPI_FLASH|MG_DISK|NVRAM|MMC|NOWHERE} #endif
#define XMK_STR(x) #x diff --git a/common/env_mmc.c b/common/env_mmc.c new file mode 100644 index 0000000..9ef7c40 --- /dev/null +++ b/common/env_mmc.c @@ -0,0 +1,359 @@ +/* + * (C) Copyright 2008-2009 Freescale Semiconductor, Inc. + + * (C) Copyright 2000-2006 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * (C) Copyright 2001 Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Andreas Heppel aheppel@sysgo.de + + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* #define DEBUG */ + +#include <common.h> + +#if defined(CONFIG_ENV_IS_IN_MMC) /* Environment is in MMC Flash */ + +#include <command.h> +#include <environment.h> +#include <linux/stddef.h> +#include <malloc.h> +#include <mmc.h> + +#if defined(CONFIG_CMD_ENV) && defined(CONFIG_CMD_MMC) +#define CMD_SAVEENV +#elif defined(CONFIG_ENV_OFFSET_REDUND) +#error Cannot use CONFIG_ENV_OFFSET_REDUND without CONFIG_CMD_ENV & CONFIG_CMD_MMC +#endif + +#if defined(CONFIG_ENV_SIZE_REDUND) && (CONFIG_ENV_SIZE_REDUND < CONFIG_ENV_SIZE) +#error CONFIG_ENV_SIZE_REDUND should not be less then CONFIG_ENV_SIZE +#endif + +#ifdef CONFIG_INFERNO +#error CONFIG_INFERNO not supported yet +#endif + +/* references to names in env_common.c */ +extern uchar default_environment[]; +extern int default_environment_size; + +char *env_name_spec = "MMC"; + +#ifdef ENV_IS_EMBEDDED +extern uchar environment[]; +env_t *env_ptr = (env_t *)(&environment[0]); +#else /* ! ENV_IS_EMBEDDED */ +env_t *env_ptr; +#endif /* ENV_IS_EMBEDDED */ + +/* local functions */ +#if !defined(ENV_IS_EMBEDDED) +static void use_default(void); +#endif + +DECLARE_GLOBAL_DATA_PTR; + +uchar env_get_char_spec(int index) +{ + return *((uchar *)(gd->env_addr + index)); +} + +int env_init(void) +{ +#if defined(CONFIG_IS_EMBEDDED) + size_t total; + int crc1_ok = 0, crc2_ok = 0; + env_t *tmp_env1, *tmp_env2; + + total = CONFIG_ENV_SIZE; + + tmp_env1 = env_ptr; + tmp_env2 = (env_t *)((ulong)env_ptr + CONFIG_ENV_SIZE); + + crc1_ok = (crc32(0, tmp_env1->data, ENV_SIZE) == tmp_env1->crc); + crc2_ok = (crc32(0, tmp_env2->data, ENV_SIZE) == tmp_env2->crc); + + if (!crc1_ok && !crc2_ok) + gd->env_valid = 0; + else if (crc1_ok && !crc2_ok) + gd->env_valid = 1; + else if (!crc1_ok && crc2_ok) + gd->env_valid = 2; + else { + /* both ok - check serial */ + if (tmp_env1->flags == 255 && tmp_env2->flags == 0) + gd->env_valid = 2; + else if (tmp_env2->flags == 255 && tmp_env1->flags == 0) + gd->env_valid = 1; + else if (tmp_env1->flags > tmp_env2->flags) + gd->env_valid = 1; + else if (tmp_env2->flags > tmp_env1->flags) + gd->env_valid = 2; + else /* flags are equal - almost impossible */ + gd->env_valid = 1; + } + + if (gd->env_valid == 1) + env_ptr = tmp_env1; + else if (gd->env_valid == 2) + env_ptr = tmp_env2; + +#else /* ENV_IS_EMBEDDED */ + gd->env_addr = (ulong)&default_environment[0]; + gd->env_valid = 1; + +#endif /* ENV_IS_EMBEDDED */ + + return 0; +} + +#ifdef CMD_SAVEENV +#ifdef CONFIG_ENV_OFFSET_REDUND +int saveenv(void) +{ + size_t total; + uint blk_start = 0, blk_cnt = 0, n = 0; + struct mmc *mmc = find_mmc_device(0); + + env_ptr->flags++; + total = CONFIG_ENV_SIZE; + + if (!mmc) { + puts("No MMC card found\n"); + return; + } + + if (mmc_init(mmc)) { + puts("MMC init failed\n"); + return 1; + } + + if (gd->env_valid == 1) { + puts("Writing to redundant MMC... "); + blk_start = (CONFIG_ENV_OFFSET_REDUND % 512) ? \ + ((CONFIG_ENV_OFFSET_REDUND / 512) + 1) : (CONFIG_ENV_OFFSET_REDUND / 512); + blk_cnt = (total % 512) ? ((total / 512) + 1) : (total / 512); + n = mmc->block_dev.block_write(0, blk_start , blk_cnt, (u_char *)env_ptr); + } else { + puts("Writing to MMC... "); + blk_start = (CONFIG_ENV_OFFSET % 512) ? \ + ((CONFIG_ENV_OFFSET / 512) + 1) : (CONFIG_ENV_OFFSET / 512); + blk_cnt = (total % 512) ? ((total / 512) + 1) : (total / 512); + n = mmc->block_dev.block_write(0, blk_start , blk_cnt, (u_char *)env_ptr); + } + if ((n != blk_cnt) || (total != CONFIG_ENV_SIZE)) { + puts("failed\n"); + return 1; + } + + puts("done\n"); + gd->env_valid = (gd->env_valid == 2 ? 1 : 2); + return 0; +} + +#else /* ! CONFIG_ENV_OFFSET_REDUND */ + +int saveenv(void) +{ + size_t total; + uint blk_start = 0, blk_cnt = 0, n = 0; + struct mmc *mmc = find_mmc_device(0); + + if (!mmc) { + puts("No MMC card found\n"); + return; + } + + if (mmc_init(mmc)) { + puts("MMC init failed\n"); + return 1; + } + + puts("Writing to MMC... "); + total = CONFIG_ENV_SIZE; + blk_start = (CONFIG_ENV_OFFSET % 512) ? \ + ((CONFIG_ENV_OFFSET / 512) + 1) : (CONFIG_ENV_OFFSET / 512); + blk_cnt = (total % 512) ? ((total / 512) + 1) : (total / 512); + n = mmc->block_dev.block_write(0, blk_start , blk_cnt, (u_char *)env_ptr); + if ((n != blk_cnt) || (total != CONFIG_ENV_SIZE)) { + puts("failed\n"); + return 1; + } + + puts("done\n"); + return 0; +} +#endif /* CONFIG_ENV_OFFSET_REDUND */ +#endif /* CMD_SAVEENV */ + +#ifdef CONFIG_ENV_OFFSET_REDUND +void env_relocate_spec(void) +{ +#if !defined(ENV_IS_EMBEDDED) + size_t total; + int crc1_ok = 0, crc2_ok = 0; + env_t *tmp_env1 = NULL, *tmp_env2 = NULL; + uint blk_start = 0, blk_cnt = 0, n = 0; + struct mmc *mmc = find_mmc_device(0); + + if (!mmc) { + puts("No MMC card found\n"); + return; + } + + if (mmc_init(mmc)) { + puts("MMC init failed\n"); + goto use_default; + } + + total = CONFIG_ENV_SIZE; + + tmp_env1 = (env_t *)malloc(CONFIG_ENV_SIZE); + if (!tmp_env1) { + puts("Not enough memory!\n"); + goto use_default; + } + memset(tmp_env1, 0, CONFIG_ENV_SIZE); + + tmp_env2 = (env_t *)malloc(CONFIG_ENV_SIZE); + if (!tmp_env2) { + puts("Not enough memory!\n"); + goto use_default; + } + memset(tmp_env2, 0, CONFIG_ENV_SIZE); + + puts("Loading environment from mmc... "); + + blk_start = (CONFIG_ENV_OFFSET % 512) ? \ + ((CONFIG_ENV_OFFSET / 512) + 1) : (CONFIG_ENV_OFFSET / 512); + blk_cnt = (total % 512) ? ((total / 512) + 1) : (total / 512); + + n = mmc->block_dev.block_read(0, blk_start, blk_cnt, (uchar *)tmp_env1); + + if (n != blk_cnt) { + puts("failed\n"); + goto use_default; + } + puts("done\n"); + + puts("Loading redundant environment from mmc... "); + + blk_start = (CONFIG_ENV_OFFSET_REDUND % 512) ? \ + ((CONFIG_ENV_OFFSET_REDUND / 512) + 1) : (CONFIG_ENV_OFFSET_REDUND / 512); + blk_cnt = (total % 512) ? ((total / 512) + 1) : (total / 512); + + n = mmc->block_dev.block_read(0, blk_start, blk_cnt, (uchar *)tmp_env2); + + if (n != blk_cnt) { + puts("failed\n"); + goto use_default; + } + puts("done\n"); + + crc1_ok = (crc32(0, tmp_env1->data, ENV_SIZE) == tmp_env1->crc); + crc2_ok = (crc32(0, tmp_env2->data, ENV_SIZE) == tmp_env2->crc); + + if (!crc1_ok && !crc2_ok) + goto use_default; + else if (crc1_ok && !crc2_ok) + gd->env_valid = 1; + else if (!crc1_ok && crc2_ok) + gd->env_valid = 2; + else { + /* both ok - check serial */ + if (tmp_env1->flags == 255 && tmp_env2->flags == 0) + gd->env_valid = 2; + else if (tmp_env2->flags == 255 && tmp_env1->flags == 0) + gd->env_valid = 1; + else if (tmp_env1->flags > tmp_env2->flags) + gd->env_valid = 1; + else if (tmp_env2->flags > tmp_env1->flags) + gd->env_valid = 2; + else /* flags are equal - almost impossible */ + gd->env_valid = 1; + } + + free(env_ptr); + if (gd->env_valid == 1) { + env_ptr = tmp_env1; + free(tmp_env2); + } else { + env_ptr = tmp_env2; + free(tmp_env1); + } + + return; + +use_default: + if (tmp_env1) + free(tmp_env1); + if (tmp_env2) + free(tmp_env2); + return use_default(); + +#endif /* ! ENV_IS_EMBEDDED */ +} +#else /* ! CONFIG_ENV_OFFSET_REDUND */ + +void env_relocate_spec(void) +{ +#if !defined(ENV_IS_EMBEDDED) + size_t total; + uint blk_start = 0, blk_cnt = 0, n = 0; + struct mmc *mmc = find_mmc_device(0); + + if (!mmc) { + puts("No MMC card found\n"); + return; + } + + if (mmc_init(mmc)) { + puts("MMC init failed\n"); + return; + } + + total = CONFIG_ENV_SIZE; + + blk_start = (CONFIG_ENV_OFFSET % 512) ? \ + ((CONFIG_ENV_OFFSET / 512) + 1) : (CONFIG_ENV_OFFSET / 512); + blk_cnt = (total % 512) ? ((total / 512) + 1) : (total / 512); + + n = mmc->block_dev.block_read(0, blk_start, blk_cnt, (uchar *)env_ptr); + + if ((n != blk_cnt) || (total != CONFIG_ENV_SIZE)) + return use_default(); + + if (crc32(0, env_ptr->data, ENV_SIZE) != env_ptr->crc) + return use_default(); +#endif /* ! ENV_IS_EMBEDDED */ +} +#endif /* CONFIG_ENV_OFFSET_REDUND */ + +#if !defined(ENV_IS_EMBEDDED) +static void use_default() +{ + puts ("*** Warning - bad CRC or MMC, using default environment\n\n"); + set_default_env(); +} +#endif + +#endif /* CONFIG_ENV_IS_IN_MMC */ diff --git a/include/environment.h b/include/environment.h index b9924fd..0b72e0b 100644 --- a/include/environment.h +++ b/include/environment.h @@ -94,6 +94,24 @@ # endif #endif /* CONFIG_ENV_IS_IN_MG_DISK */
+#if defined(CONFIG_ENV_IS_IN_MMC) +# ifndef CONFIG_ENV_OFFSET +# error "Need to define CONFIG_ENV_OFFSET when using CONFIG_ENV_IS_IN_MMC" +# endif +# ifndef CONFIG_ENV_ADDR +# define CONFIG_ENV_ADDR (CONFIG_ENV_OFFSET) +# endif +# ifndef CONFIG_ENV_OFFSET +# define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) +# endif +# ifdef CONFIG_ENV_OFFSET_REDUND +# define CONFIG_SYS_REDUNDAND_ENVIRONMENT +# endif +# ifdef CONFIG_ENV_IS_EMBEDDED +# define ENV_IS_EMBEDDED 1 +# endif +#endif /* CONFIG_ENV_IS_IN_MMC */ + /* Embedded env is only supported for some flash types */ #ifdef CONFIG_ENV_IS_EMBEDDED # if !defined(CONFIG_ENV_IS_IN_FLASH) && \ diff --git a/lib_arm/board.c b/lib_arm/board.c index 5e3d7f6..bece7d7 100644 --- a/lib_arm/board.c +++ b/lib_arm/board.c @@ -335,6 +335,11 @@ void start_armboot (void) nand_init(); /* go init the NAND */ #endif
+#ifdef CONFIG_GENERIC_MMC + puts ("MMC: "); + mmc_initialize (gd->bd); +#endif + #if defined(CONFIG_CMD_ONENAND) onenand_init(); #endif @@ -416,11 +421,6 @@ extern void davinci_eth_set_mac_addr (const u_int8_t *addr); board_late_init (); #endif
-#ifdef CONFIG_GENERIC_MMC - puts ("MMC: "); - mmc_initialize (gd->bd); -#endif - #ifdef CONFIG_BITBANGMII bb_miiphy_init(); #endif diff --git a/lib_ppc/board.c b/lib_ppc/board.c index 765f97a..fac5c29 100644 --- a/lib_ppc/board.c +++ b/lib_ppc/board.c @@ -776,6 +776,12 @@ void board_init_r (gd_t *id, ulong dest_addr) nand_init(); /* go init the NAND */ #endif
+#ifdef CONFIG_GENERIC_MMC + WATCHDOG_RESET (); + puts ("MMC: "); + mmc_initialize (bd); +#endif + /* relocate environment function pointers etc. */ env_relocate ();
@@ -932,12 +938,6 @@ void board_init_r (gd_t *id, ulong dest_addr) scsi_init (); #endif
-#ifdef CONFIG_GENERIC_MMC - WATCHDOG_RESET (); - puts ("MMC: "); - mmc_initialize (bd); -#endif - #if defined(CONFIG_CMD_DOC) WATCHDOG_RESET (); puts ("DOC: ");
this list is attempting to stay in order according to the CONFIG name, so you should add this above the NAND ENV entry
--- /dev/null +++ b/common/env_mmc.c @@ -0,0 +1,359 @@ +#if defined(CONFIG_ENV_IS_IN_MMC) /* Environment is in MMC Flash */
you dont need this line anymore as it's in the Makefile
is this really needed ?
this looks like another useless line copy & pasted from whatever file you based this on -mike
Hi Mike,
I will fix the two issues you pointed. Thanks a lot.
Actually, env_mmc.c is written based on env_nand.c in u-boot 1.3.3.
I have modified it according to the latest changes in environment code. But seems there's still a lot of issue. Sorry for that.
It works well in our project. So I want to add it to u-boot mainline.
Thanks~~
Yours Terry
-----Original Message----- From: Mike Frysinger [mailto:vapier@gentoo.org] Sent: 2009年11月5日 20:10 To: u-boot@lists.denx.de Cc: Lv Terry-R65388 Subject: Re: [U-Boot] [PATCH] Save environment data to mmc.
+#ifdef CONFIG_INFERNO +#error CONFIG_INFERNO not supported yet #endif
Dear Terry Lv,
- if (!crc1_ok && !crc2_ok)
gd->env_valid = 0;
- else if (crc1_ok && !crc2_ok)
gd->env_valid = 1;
- else if (!crc1_ok && crc2_ok)
gd->env_valid = 2;
- else {
gd->env_valid = 2;
gd->env_valid = 1;
gd->env_valid = 1;
gd->env_valid = 2;
gd->env_valid = 1;
Please check if this logic is really working on MMC - do you really "erase" (i. e. fill with 0xFF bytes) the data blocks when "erasing"?
- if (!mmc) {
return;
- if (mmc_init(mmc)) {
return 1;
This code repeats a number of times. Make it a (inline?) function?
- tmp_env1 = (env_t *)malloc(CONFIG_ENV_SIZE);
- if (!tmp_env1) {
goto use_default;
Please print where we are, and how many bytes you attempted to allocate.
- if (!tmp_env2) {
goto use_default;
Ditto . Again - repeated code!
Does this make sense on MMC?
Would it not be better to define block numbers instead?
puts ("MMC: ");
Indentation by TABs, please.
Are you sure movin the MMC initialization here has no negative impact on any of the existing boards?
WATCHDOG_RESET ();
puts ("MMC: ");
Ditto, for both remarks.
Lv Terry-R65388
Mike Frysinger
Terry Lv
