RE: [U-Boot-Users] U-Boot on 440EP Bamboo board, anybody succeed?
You have to set the MAC addresse(s) and reset the board. After this both enet devices will be available.
Thanks, it helps.
In PIBS works. 2. When trying to boot uImage (loaded via
USB, as eth
doesn't work), it just hang after "Uncompressing Kernel
Image ... OK".
The same bzImage runs in PIBS. U-Boot 1.1.4, Linux 2.6.16, compiled with gcc 3.4.5.
Please give the DENX linux images a try:
ftp://ftp.denx.de/pub/linux/images/amcc/bamboo/
U-Boot 1.1.4 (Dec 5 2005 - 16:21:22) (binary image downloaded from above URL) No success, hangs afret "Uncompressing Kernel Image ... OK"
Regards, Andriy Korud
Hi Andriy,
Thanks, it helps.
OK.
Hmmm. Should work. What is the content of the env variable bootargs upon booting the kernel. Did you pass all needed info to the kernel (ttySx, baudrate...)?
Best regards, Stefan
Thanks for the tips. bootargs was no set at all (I was using plain bootm).
regards, Andriy Korud
In message 60E856FD577CC04BA3727AF4122D3F160106FDD9@3bit.vector.com.pl you wrote:
But this is most probably not an U-Boot probl;em. Where did you get your kernel image from? [Hint: there is a working image just in the neigbour directory on the same server; just s/u-boot/linux/ ].
Andriy Korud
Stefan Roese
