[PATCH] Revert "dm: fdt: scan for devices under /firmware too"
Subnodes under "/firmware" node are scanned twice in dm_scan_fdt_node() and dm_extended_scan_fdt(). This patch removes the scanning in dm_scan_fdt_node() to avoid double scanning.
This reverts commit 747558d014577526bf2e8d9fe9ca748fdbf75d8a.
Signed-off-by: Thirupathaiah Annapureddy thiruan@linux.microsoft.com --- drivers/core/root.c | 15 +++++---------- 1 file changed, 5 insertions(+), 10 deletions(-)
diff --git a/drivers/core/root.c b/drivers/core/root.c index e85643819e..cb695e933a 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -254,15 +254,9 @@ static int dm_scan_fdt_node(struct udevice *parent, const void *blob, for (offset = fdt_first_subnode(blob, offset); offset > 0; offset = fdt_next_subnode(blob, offset)) { - const char *node_name = fdt_get_name(blob, offset, NULL); - - /* - * The "chosen" and "firmware" nodes aren't devices - * themselves but may contain some: - */ - if (!strcmp(node_name, "chosen") || - !strcmp(node_name, "firmware")) { - pr_debug("parsing subnodes of "%s"\n", node_name); + /* "chosen" node isn't a device itself but may contain some: */ + if (!strcmp(fdt_get_name(blob, offset, NULL), "chosen")) { + pr_debug("parsing subnodes of "chosen"\n");
err = dm_scan_fdt_node(parent, blob, offset, pre_reloc_only); @@ -279,7 +273,8 @@ static int dm_scan_fdt_node(struct udevice *parent, const void *blob, pre_reloc_only); if (err && !ret) { ret = err; - debug("%s: ret=%d\n", node_name, ret); + debug("%s: ret=%d\n", fdt_get_name(blob, offset, NULL), + ret); } }
pr_debug("parsing subnodes of \"%s\"\n", node_name);
pr_debug("parsing subnodes of \"chosen\"\n"); err = dm_scan_fdt_node(parent, blob, offset, pre_reloc_only);
} }ret);
This has come up several times. Please join this thread which is fixing this issue. https://lists.denx.de/pipermail/u-boot/2020-February/400165.html
Thanks, Michal
Michal Simek
