[PATCH v1 0/1] sunxi: h3: Add initial ZeroPi support
This commit adds support to FriendlyARM ZeroPi board.
Board Schematic: http://wiki.friendlyarm.com/wiki/images/7/71/ZeroPi_20190731_Schematic.pdf
- v1 . fix trailing whitespace
Yu-Tung Chang (1): sunxi: h3: Add initial ZeroPi support
arch/arm/dts/Makefile | 3 +- arch/arm/dts/sun8i-h3-zeropi.dts | 48 ++++++++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 6 ++++ configs/zeropi_defconfig | 13 +++++++++ 4 files changed, 69 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/sun8i-h3-zeropi.dts create mode 100644 configs/zeropi_defconfig
ZeroPi is a new board of high performance with low cost designed by FriendlyElec., using the Allwinner H3 SOC.
ZeroPi features - Allwinner H3, Quad-core Cortex-A7@1.2GHz - 256MB/512MB DDR3 RAM - microsd slot - 10/100/1000Mbps Ethernet - Debug Serial Port - DC 5V/2A power-supply
Signed-off-by: Yu-Tung Chang mtwget@gmail.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/sun8i-h3-zeropi.dts | 48 ++++++++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 6 ++++ configs/zeropi_defconfig | 13 +++++++++ 4 files changed, 69 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/sun8i-h3-zeropi.dts create mode 100644 configs/zeropi_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 096068261d..7c8e253350 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -607,7 +607,8 @@ dtb-$(CONFIG_MACH_SUN8I_H3) += \ sun8i-h3-orangepi-plus.dtb \ sun8i-h3-orangepi-plus2e.dtb \ sun8i-h3-orangepi-zero-plus2.dtb \ - sun8i-h3-rervision-dvk.dtb + sun8i-h3-rervision-dvk.dtb \ + sun8i-h3-zeropi.dtb dtb-$(CONFIG_MACH_SUN8I_R40) += \ sun8i-r40-bananapi-m2-ultra.dtb \ sun8i-v40-bananapi-m2-berry.dtb diff --git a/arch/arm/dts/sun8i-h3-zeropi.dts b/arch/arm/dts/sun8i-h3-zeropi.dts new file mode 100644 index 0000000000..e36381f11b --- /dev/null +++ b/arch/arm/dts/sun8i-h3-zeropi.dts @@ -0,0 +1,48 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2021 Yu-Tung Chang mtwget@gmail.com + */ + +#include "sun8i-h3-nanopi.dtsi" + +/ { + model = "FriendlyARM ZeroPi"; + compatible = "friendlyarm,zeropi", "allwinner,sun8i-h3"; + + aliases { + ethernet0 = &emac; + }; + + reg_gmac_3v3: gmac-3v3 { + compatible = "regulator-fixed"; + regulator-name = "gmac-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <100000>; + enable-active-high; + gpio = <&pio 3 6 GPIO_ACTIVE_HIGH>; /* PD6 */ + }; +}; + +&external_mdio { + ext_rgmii_phy: ethernet-phy@7 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <7>; + }; +}; + +&emac { + pinctrl-names = "default"; + pinctrl-0 = <&emac_rgmii_pins>; + phy-supply = <®_gmac_3v3>; + phy-handle = <&ext_rgmii_phy>; + phy-mode = "rgmii-id"; + + allwinner,leds-active-low; + status = "okay"; +}; + +&usb_otg { + status = "okay"; + dr_mode = "host"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 76eba2ad20..4fc26077b2 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -529,3 +529,9 @@ YONES TOPTECH BS1078 V2 BOARD M: Peter Korsgaard peter@korsgaard.com S: Maintained F: configs/Yones_Toptech_BS1078_V2_defconfig + +ZEROPI BOARD +M: Yu-Tung Chang mtwget@gmail.com +S: Maintained +F: configs/zeropi_defconfig +F: arch/arm/dts/sun8i-h3-zeropi.dts diff --git a/configs/zeropi_defconfig b/configs/zeropi_defconfig new file mode 100644 index 0000000000..f921b09892 --- /dev/null +++ b/configs/zeropi_defconfig @@ -0,0 +1,13 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_SPL=y +CONFIG_MACH_SUN8I_H3=y +CONFIG_DRAM_CLK=408 +CONFIG_MACPWR="PD6" +# CONFIG_VIDEO_DE2 is not set +CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-zeropi" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y +CONFIG_SUN8I_EMAC=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OHCI_HCD=y
Yu-Tung Chang
