[U-Boot] [PATCH v3] OMAP3: Add serial number based on die ID
Add serial number based on OMAP3 die ID.
Signed-off-by: Dirk Behme dirk.behme@googlemail.com
Changes in v3:
- Rename 'serial#' to 'dieid#' - Rebase against U-Boot mainline commit 00cc5595a7caac8066b408774383a956c2e26797 'lcd: Fix compilation warning in common/lcd.c' This patch replaces all older versions of this patch (which where part of OMAP3 5/7 patch series)
Changes in v2:
- Rename 'serial' to 'serial#' - Don't copy from a memory to an other, instead just update the pointer
board/omap3/beagle/beagle.c | 2 ++ board/omap3/evm/evm.c | 2 ++ board/omap3/overo/overo.c | 2 ++ board/omap3/pandora/pandora.c | 2 ++ board/omap3/zoom1/zoom1.c | 1 + cpu/arm_cortexa8/omap3/sys_info.c | 26 ++++++++++++++++++++++++++ include/asm-arm/arch-omap3/cpu.h | 13 +++++++++++++ include/asm-arm/arch-omap3/omap3.h | 1 + include/asm-arm/arch-omap3/sys_proto.h | 1 + 9 files changed, 50 insertions(+)
Index: u-boot-main/cpu/arm_cortexa8/omap3/sys_info.c =================================================================== --- u-boot-main.orig/cpu/arm_cortexa8/omap3/sys_info.c +++ u-boot-main/cpu/arm_cortexa8/omap3/sys_info.c @@ -36,6 +36,32 @@ static gpmc_csx_t *gpmc_cs_base = (gpmc_ static sdrc_t *sdrc_base = (sdrc_t *)OMAP34XX_SDRC_BASE; static ctrl_t *ctrl_base = (ctrl_t *)OMAP34XX_CTRL_BASE;
+/***************************************************************** + * dieid_num_r(void) - read and set serial number based on DIE ID + *****************************************************************/ +void dieid_num_r(void) +{ + ctrl_id_t *id_base = (ctrl_id_t *)OMAP34XX_ID_L4_IO_BASE; + char *uid_s, die_id[34]; + u32 id[4]; + + memset(die_id, 0, sizeof(die_id)); + + uid_s = getenv("dieid#"); + + if (uid_s == NULL) { + id[3] = readl(&id_base->die_id_0); + id[2] = readl(&id_base->die_id_1); + id[1] = readl(&id_base->die_id_2); + id[0] = readl(&id_base->die_id_3); + sprintf(die_id, "%08x%08x%08x%08x", id[0], id[1], id[2], id[3]); + setenv("dieid#", die_id); + uid_s = die_id; + } + + printf("Die ID #%s\n", uid_s); +} + /****************************************** * get_cpu_type(void) - extract cpu info ******************************************/ Index: u-boot-main/include/asm-arm/arch-omap3/cpu.h =================================================================== --- u-boot-main.orig/include/asm-arm/arch-omap3/cpu.h +++ u-boot-main/include/asm-arm/arch-omap3/cpu.h @@ -60,6 +60,19 @@ typedef struct ctrl { #define OMAP3525 0x4c00 #define OMAP3530 0x0c00
+#ifndef __ASSEMBLY__ +typedef struct ctrl_id { + unsigned char res1[0x4]; + unsigned int idcode; /* 0x04 */ + unsigned int prod_id; /* 0x08 */ + unsigned char res2[0x0C]; + unsigned int die_id_0; /* 0x18 */ + unsigned int die_id_1; /* 0x1C */ + unsigned int die_id_2; /* 0x20 */ + unsigned int die_id_3; /* 0x24 */ +} ctrl_id_t; +#endif /* __ASSEMBLY__ */ + /* device type */ #define DEVICE_MASK (0x7 << 8) #define SYSBOOT_MASK 0x1F Index: u-boot-main/include/asm-arm/arch-omap3/omap3.h =================================================================== --- u-boot-main.orig/include/asm-arm/arch-omap3/omap3.h +++ u-boot-main/include/asm-arm/arch-omap3/omap3.h @@ -43,6 +43,7 @@ */ #define OMAP34XX_CORE_L4_IO_BASE 0x48000000 #define OMAP34XX_WAKEUP_L4_IO_BASE 0x48300000 +#define OMAP34XX_ID_L4_IO_BASE 0x4830A200 #define OMAP34XX_L4_PER 0x49000000 #define OMAP34XX_L4_IO_BASE OMAP34XX_CORE_L4_IO_BASE
Index: u-boot-main/board/omap3/overo/overo.c =================================================================== --- u-boot-main.orig/board/omap3/overo/overo.c +++ u-boot-main/board/omap3/overo/overo.c @@ -60,6 +60,8 @@ int misc_init_r(void) { power_init_r();
+ dieid_num_r(); + return 0; }
Index: u-boot-main/board/omap3/beagle/beagle.c =================================================================== --- u-boot-main.orig/board/omap3/beagle/beagle.c +++ u-boot-main/board/omap3/beagle/beagle.c @@ -116,6 +116,8 @@ int misc_init_r(void)
beagle_identify();
Index: u-boot-main/board/omap3/evm/evm.c =================================================================== --- u-boot-main.orig/board/omap3/evm/evm.c +++ u-boot-main/board/omap3/evm/evm.c @@ -68,6 +68,8 @@ int misc_init_r(void) setup_net_chip(); #endif
Index: u-boot-main/include/asm-arm/arch-omap3/sys_proto.h =================================================================== --- u-boot-main.orig/include/asm-arm/arch-omap3/sys_proto.h +++ u-boot-main/include/asm-arm/arch-omap3/sys_proto.h @@ -66,5 +66,6 @@ void sdelay(unsigned long); void make_cs1_contiguous(void); void omap_nand_switch_ecc(int); void power_init_r(void); +void dieid_num_r(void);
#endif Index: u-boot-main/board/omap3/pandora/pandora.c =================================================================== --- u-boot-main.orig/board/omap3/pandora/pandora.c +++ u-boot-main/board/omap3/pandora/pandora.c @@ -77,6 +77,8 @@ int misc_init_r(void) writel(GPIO28, &gpio5_base->setdataout); writel(GPIO4, &gpio6_base->setdataout);
Index: u-boot-main/board/omap3/zoom1/zoom1.c =================================================================== --- u-boot-main.orig/board/omap3/zoom1/zoom1.c +++ u-boot-main/board/omap3/zoom1/zoom1.c @@ -61,6 +61,7 @@ int board_init(void) int misc_init_r(void) { power_init_r(); + dieid_num_r(); return 0; }
Dear Dirk Behme,
In message 1236195272-26733-1-git-send-email-dirk.behme@googlemail.com you wrote:
Should the commit message not also reflect that this has nothing to do any more with the serial number (serial#) ?
Dear Wolfgang,
Wolfgang Denk wrote:
Dear Dirk Behme,
Hmm, well, it seems that some people like to _use_ this number we report here as serial number of the board independent of any naming convention U-Boot has. ;)
Anyhow, do you like the commit message to be changed to get this patch applied?
Best regards
Dirk
Dear Dirk Behme,
Maybe documentation is poor and fails to explain the difference between a die ID and a board serial number ?
Yes, please.
Dirk Behme
