[U-Boot] [PATCH 0/2] Fastboot OEM commands
This series adds fastboot oem sub-command infrastructure and support for "oem format" command which partitions and formats the storage device. The partition layout is set within the u-boot env and is implemented using the "gpt write" command.
Rob
Michael Scott (1): fastboot: add "fastboot oem" command support
Rob Herring (1): fastboot: add support for "oem format" command
drivers/usb/gadget/f_fastboot.c | 26 ++++++++++++++++++++++++++ 1 file changed, 26 insertions(+)
Add code stub to handle "fastboot oem __" command. As unlock is a common fastboot command, distinguish that it is not implemented.
Signed-off-by: Michael Scott michael.scott@linaro.org Signed-off-by: Rob Herring robh@kernel.org --- drivers/usb/gadget/f_fastboot.c | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index 310175a..e2fda86 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -513,6 +513,17 @@ static void cb_flash(struct usb_ep *ep, struct usb_request *req) } #endif
+static void cb_oem(struct usb_ep *ep, struct usb_request *req) +{ + char *cmd = req->buf; + if (strncmp("unlock", cmd + 4, 8) == 0) { + fastboot_tx_write_str("FAILnot implemented"); + } + else { + fastboot_tx_write_str("FAILunknown oem command"); + } +} + struct cmd_dispatch_info { char *cmd; void (*cb)(struct usb_ep *ep, struct usb_request *req); @@ -541,6 +552,10 @@ static const struct cmd_dispatch_info cmd_dispatch_info[] = { .cb = cb_flash, }, #endif + { + .cmd = "oem", + .cb = cb_oem, + }, };
static void rx_handler_command(struct usb_ep *ep, struct usb_request *req)
Hi Rob,
- char *cmd = req->buf;
- if (strncmp("unlock", cmd + 4, 8) == 0) {
- else {
Just a minor comment - those braces could be removed.
BTW: Marek shall I take those patches to dfu tree or would you take them to -usb tree ?
.cmd = "oem",
.cb = cb_oem,
On Thursday, January 29, 2015 at 09:30:27 AM, Lukasz Majewski wrote:
Hi Rob,
Hi all!
#endif
- else {
Take them through DFU please, thank you!
Best regards, Marek Vasut
On Thu, Jan 29, 2015 at 2:30 AM, Lukasz Majewski l.majewski@samsung.com wrote:
Hi Rob,
else {
When the format command is added in the next patch, then they need to be added back if you want all clauses to be the same (braces or not).
Rob
.cmd = "oem",
.cb = cb_oem,
-- Best regards,
Lukasz Majewski
Samsung R&D Institute Poland (SRPOL) | Linux Platform Group
Hi Rob,
Hi Rob,
else {
Then the patch can stay as it is. Thanks for explanation :-)
Rob
.cmd = "oem",
.cb = cb_oem,
-- Best regards,
Lukasz Majewski
- else {
- struct cmd_dispatch_info { char *cmd; void (*cb)(struct usb_ep *ep, struct usb_request *req);
.cmd = "oem",
.cb = cb_oem,
Tested-by: Steve Rae srae@broadcom.com
Hi Rob,
- else {
.cmd = "oem",
.cb = cb_oem,
Applied to u-boot-dfu.
Thanks.
Add "oem format" command to write partition table. This relies on the env variable partitions to contain the list of partitions as required by the gpt command.
Note that this does not erase any data other than the partition table.
Signed-off-by: Rob Herring robh@kernel.org --- drivers/usb/gadget/f_fastboot.c | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index e2fda86..f7d84bf 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -516,6 +516,17 @@ static void cb_flash(struct usb_ep *ep, struct usb_request *req) static void cb_oem(struct usb_ep *ep, struct usb_request *req) { char *cmd = req->buf; +#ifdef CONFIG_FASTBOOT_FLASH + if (strncmp("format", cmd + 4, 6) == 0) { + char cmdbuf[32]; + sprintf(cmdbuf, "gpt write mmc %x $partitions", + CONFIG_FASTBOOT_FLASH_MMC_DEV); + if (run_command(cmdbuf, 0)) + fastboot_tx_write_str("FAIL"); + else + fastboot_tx_write_str("OKAY"); + } else +#endif if (strncmp("unlock", cmd + 4, 8) == 0) { fastboot_tx_write_str("FAILnot implemented"); }
Hi Rob,
- if (strncmp("format", cmd + 4, 6) == 0) {
char cmdbuf[32];
else
- } else
Reviewed-by: Lukasz Majewski l.majewski@samsung.com
char cmdbuf[32];
else
- } else
Reviewed-by: Steve Rae srae@broadcom.com
Hi Rob,
char cmdbuf[32];
else
- } else
Thanks.
char cmdbuf[32];
else
- } else
Please clarify the "partitions" env variable. For example, if I have (snippet from the 'mmc part' command): 3 0x00011000 0x000117ff "u-boot" attrs: 0x0000000000000000 type: ebcf4a1c-b9e7-8f06-9885-3bd8b4a46cff guid: d5b495eb-57aa-fc70-23bb-d1897fa4e840 7 0x0001c000 0x00023fff "kernel" attrs: 0x0000000000000000 type: 3c3ea4a6-5eaa-7f7c-1cb7-9374b8191c5d guid: 43b9c433-a106-68bf-aff4-890416fc87d7 what would the corresponding "partitions" env variable look like?
Thanks, Steve PS. from doc/README.gpt:
148 Creating GPT partitions in U-Boot: 149 ============== 150 151 To restore GUID partition table one needs to: 152 1. Define partition layout in the environment. 153 Format of partitions layout: 154 "partitions=uuid_disk=...;name=u-boot,size=60MiB,uuid=...; 155 name=kernel,size=60MiB,uuid=...;" 156 or 157 "partitions=uuid_disk=${uuid_gpt_disk};name=${uboot_name}, 158 size=${uboot_size},uuid=${uboot_uuid};" 159 160 Fields 'name', 'size' and 'uuid' are mandatory for every partition. 161 The field 'start' is optional. 162 163 option: CONFIG_RANDOM_UUID 164 If any partition "UUID" no exists then it is randomly generated. 165 166 2. Define 'CONFIG_EFI_PARTITION' and 'CONFIG_CMD_GPT' 167 168 2. From u-boot prompt type: 169 gpt write mmc 0 $partitions
How can dump the current "uuid_disk=" (not in the 'mmc part' command?) Is the "uuid=" parameter the 'type:' or the 'guid:' in the 'mmc part' command?
char cmdbuf[32];
else
} else
Here is what I have:
"partitions=" \ "name=DTIM,start=0x00200000,size=0x200000;" \ "name=recovery,start=0x00400000,size=0xb00000;" \ "name=bootloader,start=0x00F00000,size=0x100000;" \ "name=boot,start=0x01000000,size=0x1000000;" \ "name=dtb,start=0x02000000,size=0x1000000;" \ "name=system,start=0x03000000,size=0x30000000;" \ "name=vendor,start=0x33000000,size=0x10000000;" \ "name=cache,start=0x43000000,size=0x20000000;" \ "name=userdata,start=0x63000000,size=0x15d000000\0"
The main difference from mmc partition dump is start and size in bytes rather than start and end in blocks.
There may not be a way to get the disk uuid currently other than dumping the raw partition table hex. The uuid is the guid. The type used is something corresponds "Windows data" which seems strange. Probably that should be configurable, but it doesn't seem to really matter.
Rob
Lukasz Majewski
Rob Herring
Steve Rae
