[U-Boot] [PATCH] arm: socfpga: Make the DT mmc node consistent
The socfpga_cyclone5.dtsi has an mmc0 node, socrates has mmc node. This makes aliases not very usable, so make everything into mmc0. Moreover, zap the useless mmc alias while at this.
Signed-off-by: Marek Vasut marex@denx.de --- arch/arm/dts/socfpga.dtsi | 3 +-- arch/arm/dts/socfpga_cyclone5_socrates.dts | 2 +- 2 files changed, 2 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/socfpga.dtsi b/arch/arm/dts/socfpga.dtsi index 125034b..8588221 100644 --- a/arch/arm/dts/socfpga.dtsi +++ b/arch/arm/dts/socfpga.dtsi @@ -23,7 +23,6 @@ spi0 = &qspi; spi1 = &spi0; spi2 = &spi1; - mmc = &mmc; };
cpus { @@ -624,7 +623,7 @@ arm,data-latency = <2 1 1>; };
- mmc: dwmmc0@ff704000 { + mmc0: dwmmc0@ff704000 { compatible = "altr,socfpga-dw-mshc"; reg = <0xff704000 0x1000>; interrupts = <0 139 4>; diff --git a/arch/arm/dts/socfpga_cyclone5_socrates.dts b/arch/arm/dts/socfpga_cyclone5_socrates.dts index 00b1830..3c98558 100644 --- a/arch/arm/dts/socfpga_cyclone5_socrates.dts +++ b/arch/arm/dts/socfpga_cyclone5_socrates.dts @@ -34,7 +34,7 @@ }; };
-&mmc { +&mmc0 { status = "okay"; };
Acked-by: Dinh Nguyen dinguyen@opensource.altera.com
Thanks, Dinh
Applied to u-boot-socfpga/master, thanks!
Best regards, Marek Vasut
Dinh Nguyen
