[U-Boot] [PATCH 0/7] ARM: uniphier: support drive-strength pin configuration
I will merge this series after the release.
Masahiro Yamada (7): pinctrl: uniphier: remove unneeded pin data of LD6b pinctrl: uniphier: replace printf() with dev_err() pinctrl: uniphier: include <linux/build_bug.h> instead of <linux/bug.h> pinctrl: uniphier: support per-pin configuration via DT pinctrl: uniphier: support drive-strength configuration pinctrl: uniphier: add ethernet TX pin data for LD20 ARM: uniphier: enable CONFIG_PINCONF
configs/uniphier_v8_defconfig | 1 + drivers/pinctrl/uniphier/pinctrl-uniphier-core.c | 140 ++++++++++++++++++++++- drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c | 11 ++ drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c | 13 --- drivers/pinctrl/uniphier/pinctrl-uniphier.h | 49 ++++++-- 5 files changed, 190 insertions(+), 24 deletions(-)
Since commit f73cfb4d0dee ("pinctrl: uniphier: simplify input enable and delete pin arrays"), these data are no longer used in any useful way. Remove.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c | 13 ------------- 1 file changed, 13 deletions(-)
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c index 6ade131..ed702c6 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c @@ -11,17 +11,6 @@
#include "pinctrl-uniphier.h"
-static const struct uniphier_pinctrl_pin uniphier_ld6b_pins[] = { - UNIPHIER_PINCTRL_PIN(113, 0), - UNIPHIER_PINCTRL_PIN(114, 0), - UNIPHIER_PINCTRL_PIN(115, 0), - UNIPHIER_PINCTRL_PIN(116, 0), - UNIPHIER_PINCTRL_PIN(217, 0), - UNIPHIER_PINCTRL_PIN(218, 0), - UNIPHIER_PINCTRL_PIN(219, 0), - UNIPHIER_PINCTRL_PIN(220, 0), -}; - static const unsigned emmc_pins[] = {36, 37, 38, 39, 40, 41, 42}; static const int emmc_muxvals[] = {1, 1, 1, 1, 1, 1, 1}; static const unsigned emmc_dat8_pins[] = {43, 44, 45, 46}; @@ -135,8 +124,6 @@ static const char * const uniphier_ld6b_functions[] = { };
static struct uniphier_pinctrl_socdata uniphier_ld6b_pinctrl_socdata = { - .pins = uniphier_ld6b_pins, - .pins_count = ARRAY_SIZE(uniphier_ld6b_pins), .groups = uniphier_ld6b_groups, .groups_count = ARRAY_SIZE(uniphier_ld6b_groups), .functions = uniphier_ld6b_functions,
dev_err() is more suitable for printing error messages.
drivers/pinctrl/uniphier/pinctrl-uniphier-core.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c index 215b19e..ac6c82d 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c @@ -174,7 +174,7 @@ static int uniphier_pinconf_set_one(struct udevice *dev, unsigned int pin, ret = uniphier_pinconf_input_enable(dev, pin, arg); break; default: - printf("unsupported configuration parameter %u\n", param); + dev_err(dev, "unsupported configuration parameter %u\n", param); return -EINVAL; }
The #include <linux/bug.h> is here to use BUILD_BUG_ON_ZERO().
By replacing it with <linux/build_bug.h>, we can reduce the number of headers pulled in.
drivers/pinctrl/uniphier/pinctrl-uniphier.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier.h b/drivers/pinctrl/uniphier/pinctrl-uniphier.h index a0eccf8..40e5ad7 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier.h +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier.h @@ -9,7 +9,7 @@ #define __PINCTRL_UNIPHIER_H__
#include <linux/bitops.h> -#include <linux/bug.h> +#include <linux/build_bug.h> #include <linux/kernel.h> #include <linux/types.h>
Currently, the UniPhier pinctrl drivers expose only the pin-group interface to device tree.
Provide .get_pins_count, .get_pin_name, .pinconf_set hooks to support pin configuration via 'pins' DT property.
drivers/pinctrl/uniphier/pinctrl-uniphier-core.c | 37 ++++++++++++++++++++++-- drivers/pinctrl/uniphier/pinctrl-uniphier.h | 3 +- 2 files changed, 36 insertions(+), 4 deletions(-)
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c index ac6c82d..03103b3 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c @@ -22,6 +22,34 @@
static const char *uniphier_pinctrl_dummy_name = "_dummy";
+static int uniphier_pinctrl_get_pins_count(struct udevice *dev) +{ + struct uniphier_pinctrl_priv *priv = dev_get_priv(dev); + const struct uniphier_pinctrl_pin *pins = priv->socdata->pins; + int pins_count = priv->socdata->pins_count; + + /* + * We do not list all pins in the pin table to save memory footprint. + * Report the max pin number + 1 to fake the framework. + */ + return pins[pins_count - 1].number + 1; +} + +static const char *uniphier_pinctrl_get_pin_name(struct udevice *dev, + unsigned int selector) +{ + struct uniphier_pinctrl_priv *priv = dev_get_priv(dev); + const struct uniphier_pinctrl_pin *pins = priv->socdata->pins; + int pins_count = priv->socdata->pins_count; + int i; + + for (i = 0; i < pins_count; i++) + if (pins[i].number == selector) + return pins[i].name; + + return uniphier_pinctrl_dummy_name; +} + static int uniphier_pinctrl_get_groups_count(struct udevice *dev) { struct uniphier_pinctrl_priv *priv = dev_get_priv(dev); @@ -158,8 +186,8 @@ static int uniphier_pinconf_bias_set(struct udevice *dev, unsigned int pin, return 0; }
-static int uniphier_pinconf_set_one(struct udevice *dev, unsigned int pin, - unsigned int param, unsigned int arg) +static int uniphier_pinconf_set(struct udevice *dev, unsigned int pin, + unsigned int param, unsigned int arg) { int ret;
@@ -191,7 +219,7 @@ static int uniphier_pinconf_group_set(struct udevice *dev, int i, ret;
for (i = 0; i < grp->num_pins; i++) { - ret = uniphier_pinconf_set_one(dev, grp->pins[i], param, arg); + ret = uniphier_pinconf_set(dev, grp->pins[i], param, arg); if (ret) return ret; } @@ -269,6 +297,8 @@ static int uniphier_pinmux_group_set(struct udevice *dev, }
const struct pinctrl_ops uniphier_pinctrl_ops = { + .get_pins_count = uniphier_pinctrl_get_pins_count, + .get_pin_name = uniphier_pinctrl_get_pin_name, .get_groups_count = uniphier_pinctrl_get_groups_count, .get_group_name = uniphier_pinctrl_get_group_name, .get_functions_count = uniphier_pinmux_get_functions_count, @@ -277,6 +307,7 @@ const struct pinctrl_ops uniphier_pinctrl_ops = { #if CONFIG_IS_ENABLED(PINCONF) .pinconf_num_params = ARRAY_SIZE(uniphier_pinconf_params), .pinconf_params = uniphier_pinconf_params, + .pinconf_set = uniphier_pinconf_set, .pinconf_group_set = uniphier_pinconf_group_set, #endif .set_state = pinctrl_generic_set_state, diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier.h b/drivers/pinctrl/uniphier/pinctrl-uniphier.h index 40e5ad7..8884b08 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier.h +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier.h @@ -28,7 +28,8 @@ static inline unsigned int uniphier_pin_get_iectrl(unsigned long data) */ struct uniphier_pinctrl_pin { unsigned number; - unsigned long data; + const char *name; + unsigned int data; };
This allows our DT to specify drive-strength property.
drivers/pinctrl/uniphier/pinctrl-uniphier-core.c | 101 +++++++++++++++++++++++ drivers/pinctrl/uniphier/pinctrl-uniphier.h | 44 ++++++++-- 2 files changed, 140 insertions(+), 5 deletions(-)
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c index 03103b3..39b5366 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c @@ -17,6 +17,9 @@
#define UNIPHIER_PINCTRL_PINMUX_BASE 0x1000 #define UNIPHIER_PINCTRL_LOAD_PINMUX 0x1700 +#define UNIPHIER_PINCTRL_DRVCTRL_BASE 0x1800 +#define UNIPHIER_PINCTRL_DRV2CTRL_BASE 0x1900 +#define UNIPHIER_PINCTRL_DRV3CTRL_BASE 0x1980 #define UNIPHIER_PINCTRL_PUPDCTRL_BASE 0x1a00 #define UNIPHIER_PINCTRL_IECTRL 0x1d00
@@ -142,10 +145,25 @@ static const struct pinconf_param uniphier_pinconf_params[] = { { "bias-pull-up", PIN_CONFIG_BIAS_PULL_UP, 1 }, { "bias-pull-down", PIN_CONFIG_BIAS_PULL_DOWN, 1 }, { "bias-pull-pin-default", PIN_CONFIG_BIAS_PULL_PIN_DEFAULT, 1 }, + { "drive-strength", PIN_CONFIG_DRIVE_STRENGTH, 0 }, { "input-enable", PIN_CONFIG_INPUT_ENABLE, 1 }, { "input-disable", PIN_CONFIG_INPUT_ENABLE, 0 }, };
+static const struct uniphier_pinctrl_pin * +uniphier_pinctrl_pin_get(struct uniphier_pinctrl_priv *priv, unsigned int pin) +{ + const struct uniphier_pinctrl_pin *pins = priv->socdata->pins; + int pins_count = priv->socdata->pins_count; + int i; + + for (i = 0; i < pins_count; i++) + if (pins[i].number == pin) + return &pins[i]; + + return NULL; +} + static int uniphier_pinconf_bias_set(struct udevice *dev, unsigned int pin, unsigned int param, unsigned int arg) { @@ -186,6 +204,86 @@ static int uniphier_pinconf_bias_set(struct udevice *dev, unsigned int pin, return 0; }
+static const unsigned int uniphier_pinconf_drv_strengths_1bit[] = { + 4, 8, +}; + +static const unsigned int uniphier_pinconf_drv_strengths_2bit[] = { + 8, 12, 16, 20, +}; + +static const unsigned int uniphier_pinconf_drv_strengths_3bit[] = { + 4, 5, 7, 9, 11, 12, 14, 16, +}; + +static int uniphier_pinconf_drive_set(struct udevice *dev, unsigned int pin, + unsigned int strength) +{ + struct uniphier_pinctrl_priv *priv = dev_get_priv(dev); + const struct uniphier_pinctrl_pin *desc; + const unsigned int *strengths; + unsigned int base, stride, width, drvctrl, reg, shift; + u32 val, mask, tmp; + + desc = uniphier_pinctrl_pin_get(priv, pin); + if (WARN_ON(!desc)) + return -EINVAL; + + switch (uniphier_pin_get_drv_type(desc->data)) { + case UNIPHIER_PIN_DRV_1BIT: + strengths = uniphier_pinconf_drv_strengths_1bit; + base = UNIPHIER_PINCTRL_DRVCTRL_BASE; + stride = 1; + width = 1; + break; + case UNIPHIER_PIN_DRV_2BIT: + strengths = uniphier_pinconf_drv_strengths_2bit; + base = UNIPHIER_PINCTRL_DRV2CTRL_BASE; + stride = 2; + width = 2; + break; + case UNIPHIER_PIN_DRV_3BIT: + strengths = uniphier_pinconf_drv_strengths_3bit; + base = UNIPHIER_PINCTRL_DRV3CTRL_BASE; + stride = 4; + width = 3; + break; + default: + /* drive strength control is not supported for this pin */ + return -EINVAL; + } + + drvctrl = uniphier_pin_get_drvctrl(desc->data); + drvctrl *= stride; + + reg = base + drvctrl / 32 * 4; + shift = drvctrl % 32; + mask = (1U << width) - 1; + + for (val = 0; val <= mask; val++) { + if (strengths[val] > strength) + break; + } + + if (val == 0) { + dev_err(dev, "unsupported drive strength %u mA for pin %s\n", + strength, desc->name); + return -EINVAL; + } + + if (!mask) + return 0; + + val--; + + tmp = readl(priv->base + reg); + tmp &= ~(mask << shift); + tmp |= (mask & val) << shift; + writel(tmp, priv->base + reg); + + return 0; +} + static int uniphier_pinconf_set(struct udevice *dev, unsigned int pin, unsigned int param, unsigned int arg) { @@ -198,6 +296,9 @@ static int uniphier_pinconf_set(struct udevice *dev, unsigned int pin, case PIN_CONFIG_BIAS_PULL_PIN_DEFAULT: ret = uniphier_pinconf_bias_set(dev, pin, param, arg); break; + case PIN_CONFIG_DRIVE_STRENGTH: + ret = uniphier_pinconf_drive_set(dev, pin, arg); + break; case PIN_CONFIG_INPUT_ENABLE: ret = uniphier_pinconf_input_enable(dev, pin, arg); break; diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier.h b/drivers/pinctrl/uniphier/pinctrl-uniphier.h index 8884b08..3f47693 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier.h +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier.h @@ -13,11 +13,44 @@ #include <linux/kernel.h> #include <linux/types.h>
-#define UNIPHIER_PIN_ATTR_PACKED(iectrl) (iectrl) +/* drive strength control register number */ +#define UNIPHIER_PIN_DRVCTRL_SHIFT 0 +#define UNIPHIER_PIN_DRVCTRL_BITS 9 +#define UNIPHIER_PIN_DRVCTRL_MASK ((1U << (UNIPHIER_PIN_DRVCTRL_BITS)) \ + - 1) + +/* drive control type */ +#define UNIPHIER_PIN_DRV_TYPE_SHIFT ((UNIPHIER_PIN_DRVCTRL_SHIFT) + \ + (UNIPHIER_PIN_DRVCTRL_BITS)) +#define UNIPHIER_PIN_DRV_TYPE_BITS 2 +#define UNIPHIER_PIN_DRV_TYPE_MASK ((1U << (UNIPHIER_PIN_DRV_TYPE_BITS)) \ + - 1) + +/* drive control type */ +enum uniphier_pin_drv_type { + UNIPHIER_PIN_DRV_1BIT, /* 2 level control: 4/8 mA */ + UNIPHIER_PIN_DRV_2BIT, /* 4 level control: 8/12/16/20 mA */ + UNIPHIER_PIN_DRV_3BIT, /* 8 level control: 4/5/7/9/11/12/14/16 mA */ +}; + +#define UNIPHIER_PIN_DRVCTRL(x) \ + (((x) & (UNIPHIER_PIN_DRVCTRL_MASK)) << (UNIPHIER_PIN_DRVCTRL_SHIFT)) +#define UNIPHIER_PIN_DRV_TYPE(x) \ + (((x) & (UNIPHIER_PIN_DRV_TYPE_MASK)) << (UNIPHIER_PIN_DRV_TYPE_SHIFT)) + +#define UNIPHIER_PIN_ATTR_PACKED(drvctrl, drv_type) \ + UNIPHIER_PIN_DRVCTRL(drvctrl) | \ + UNIPHIER_PIN_DRV_TYPE(drv_type) + +static inline unsigned int uniphier_pin_get_drvctrl(unsigned int data) +{ + return (data >> UNIPHIER_PIN_DRVCTRL_SHIFT) & UNIPHIER_PIN_DRVCTRL_MASK; +}
-static inline unsigned int uniphier_pin_get_iectrl(unsigned long data) +static inline unsigned int uniphier_pin_get_drv_type(unsigned int data) { - return data; + return (data >> UNIPHIER_PIN_DRV_TYPE_SHIFT) & + UNIPHIER_PIN_DRV_TYPE_MASK; }
/** @@ -74,10 +107,11 @@ struct uniphier_pinctrl_socdata { #define UNIPHIER_PINCTRL_CAPS_MUX_4BIT BIT(0) };
-#define UNIPHIER_PINCTRL_PIN(a, b) \ +#define UNIPHIER_PINCTRL_PIN(a, b, c, d) \ { \ .number = a, \ - .data = UNIPHIER_PIN_ATTR_PACKED(b), \ + .name = b, \ + .data = UNIPHIER_PIN_ATTR_PACKED(c, d), \ }
#define __UNIPHIER_PINCTRL_GROUP(grp) \
These are necessary to optimize the drive-strength of the pins.
drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c index 11d5d98..116d1da 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c @@ -11,6 +11,15 @@
+static const struct uniphier_pinctrl_pin uniphier_ld20_pins[] = { + UNIPHIER_PINCTRL_PIN(40, "RGMII_TXCLK", 28, UNIPHIER_PIN_DRV_3BIT), + UNIPHIER_PINCTRL_PIN(41, "RGMII_TXD0", 29, UNIPHIER_PIN_DRV_3BIT), + UNIPHIER_PINCTRL_PIN(42, "RGMII_TXD1", 30, UNIPHIER_PIN_DRV_3BIT), + UNIPHIER_PINCTRL_PIN(43, "RGMII_TXD2", 31, UNIPHIER_PIN_DRV_3BIT), + UNIPHIER_PINCTRL_PIN(44, "RGMII_TXD3", 32, UNIPHIER_PIN_DRV_3BIT), + UNIPHIER_PINCTRL_PIN(45, "RGMII_TXCTL", 33, UNIPHIER_PIN_DRV_3BIT), +}; + static const unsigned emmc_pins[] = {18, 19, 20, 21, 22, 23, 24, 25}; static const int emmc_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0}; static const unsigned emmc_dat8_pins[] = {26, 27, 28, 29}; @@ -103,6 +112,8 @@ static const char * const uniphier_ld20_functions[] = { };
static struct uniphier_pinctrl_socdata uniphier_ld20_pinctrl_socdata = { + .pins = uniphier_ld20_pins, + .pins_count = ARRAY_SIZE(uniphier_ld20_pins), .groups = uniphier_ld20_groups, .groups_count = ARRAY_SIZE(uniphier_ld20_groups), .functions = uniphier_ld20_functions,
Enable the pin configuration feature for UniPhier 64 bit SoCs.
configs/uniphier_v8_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/uniphier_v8_defconfig b/configs/uniphier_v8_defconfig index 45c9080..93df2f6 100644 --- a/configs/uniphier_v8_defconfig +++ b/configs/uniphier_v8_defconfig @@ -41,6 +41,7 @@ CONFIG_NAND_DENALI_DT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 CONFIG_DM_ETH=y CONFIG_SNI_AVE=y +CONFIG_PINCONF=y CONFIG_SYSRESET=y CONFIG_SYSRESET_PSCI=y CONFIG_USB=y
2018-05-05 19:53 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Series, applied to u-boot-uniphier.
Masahiro Yamada
