[U-Boot] [PATCH 1/2] mmc: at91: add multi block read/write support.
Since the at91sam9263, the mmc hardware support multi blocks read/write. So this driver enable it. This patch also change delay time to max value, which can avoid the timeout error in rare case.
Signed-off-by: Josh Wu josh.wu@atmel.com --- drivers/mmc/gen_atmel_mci.c | 16 +++++++++++++--- include/atmel_mci.h | 5 ++++- 2 files changed, 17 insertions(+), 4 deletions(-)
diff --git a/drivers/mmc/gen_atmel_mci.c b/drivers/mmc/gen_atmel_mci.c index 4968c5e..ec075f7 100644 --- a/drivers/mmc/gen_atmel_mci.c +++ b/drivers/mmc/gen_atmel_mci.c @@ -24,7 +24,6 @@ * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA */ - #include <common.h> #include <mmc.h> #include <part.h> @@ -87,6 +86,11 @@ static void mci_set_mode(struct mmc *mmc, u32 hz, u32 blklen) | MMCI_BF(BLKLEN, blklen) | MMCI_BIT(RDPROOF) | MMCI_BIT(WRPROOF)), &mci->mr); + /* + * On some new platforms BLKLEN in mci->mr is ignored. + * Should use the BLKLEN in the block register. + */ + writel(blklen << MMCI_BLKLEN_OFFSET, &mci->blkr); initialized = 1; }
@@ -183,6 +187,12 @@ mci_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, struct mmc_data *data) /* Figure out the transfer arguments */ cmdr = mci_encode_cmd(cmd, data, &error_flags);
+ /* For multi blocks read/write, set the block register */ + if ((cmd->cmdidx == MMC_CMD_READ_MULTIPLE_BLOCK) + || (cmd->cmdidx == MMC_CMD_WRITE_MULTIPLE_BLOCK)) + writel(data->blocks | mmc->read_bl_len << MMCI_BLKLEN_OFFSET, + &mci->blkr); + /* Send the command */ writel(cmd->cmdarg, &mci->argr); writel(cmdr, &mci->cmdr); @@ -310,8 +320,8 @@ static int mci_init(struct mmc *mmc) writel(MMCI_BIT(MCIEN), &mci->cr); /* enable mci */ writel(MMCI_BF(SCDSEL, MCI_BUS), &mci->sdcr); /* select port */
- /* Initial Time-outs */ - writel(0x5f, &mci->dtor); + /* This delay can be optimized, but stick with max value */ + writel(0x7f, &mci->dtor); /* Disable Interrupts */ writel(~0UL, &mci->idr);
diff --git a/include/atmel_mci.h b/include/atmel_mci.h index 3dd5d67..85468d4 100644 --- a/include/atmel_mci.h +++ b/include/atmel_mci.h @@ -38,7 +38,7 @@ typedef struct atmel_mci { u32 sdcr; /* 0x0c */ u32 argr; /* 0x10 */ u32 cmdr; /* 0x14 */ - u32 _18; /* 0x18 */ + u32 blkr; /* 0x18 */ u32 _1c; /* 0x1c */ u32 rspr; /* 0x20 */ u32 rspr1; /* 0x24 */ @@ -118,6 +118,9 @@ typedef struct atmel_mci { #define MMCI_TRTYP_OFFSET 19 #define MMCI_TRTYP_SIZE 2
+/* Bitfields in BLKR */ +#define MMCI_BLKLEN_OFFSET 16 + /* Bitfields in RSPRx */ #define MMCI_RSP_OFFSET 0 #define MMCI_RSP_SIZE 32
Signed-off-by: Josh Wu josh.wu@atmel.com --- arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c | 13 +++++++++++++ board/atmel/at91sam9x5ek/at91sam9x5ek.c | 16 ++++++++++++++++ include/configs/at91sam9x5ek.h | 8 ++++++++ 3 files changed, 37 insertions(+)
diff --git a/arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c b/arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c index 6d77219..3608e7c 100644 --- a/arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c +++ b/arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c @@ -230,3 +230,16 @@ void at91_macb_hw_init(void) #endif } #endif + +#if defined(CONFIG_GENERIC_ATMEL_MCI) +void at91_mci_hw_init(void) +{ + /* Initialize the MCI0 */ + at91_set_a_periph(AT91_PIO_PORTA, 17, 1); /* MCCK */ + at91_set_a_periph(AT91_PIO_PORTA, 16, 1); /* MCCDA */ + at91_set_a_periph(AT91_PIO_PORTA, 15, 1); /* MCDA0 */ + at91_set_a_periph(AT91_PIO_PORTA, 18, 1); /* MCDA1 */ + at91_set_a_periph(AT91_PIO_PORTA, 19, 1); /* MCDA2 */ + at91_set_a_periph(AT91_PIO_PORTA, 20, 1); /* MCDA3 */ +} +#endif diff --git a/board/atmel/at91sam9x5ek/at91sam9x5ek.c b/board/atmel/at91sam9x5ek/at91sam9x5ek.c index 06028aa..d1f05ef 100644 --- a/board/atmel/at91sam9x5ek/at91sam9x5ek.c +++ b/board/atmel/at91sam9x5ek/at91sam9x5ek.c @@ -42,6 +42,9 @@ #ifdef CONFIG_ATMEL_SPI #include <spi.h> #endif +#ifdef CONFIG_GENERIC_ATMEL_MCI +#include <mmc.h> +#endif
DECLARE_GLOBAL_DATA_PTR;
@@ -258,6 +261,19 @@ void spi_cs_deactivate(struct spi_slave *slave) } #endif /* CONFIG_ATMEL_SPI */
+#ifdef CONFIG_GENERIC_ATMEL_MCI +int board_mmc_init(bd_t *bd) +{ + /* Enable clock */ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + writel(1 << ATMEL_ID_HSMCI0, &pmc->pcer); + + at91_mci_hw_init(); + + return atmel_mci_init((void *)ATMEL_BASE_HSMCI0); +} +#endif + int board_early_init_f(void) { at91_seriald_hw_init(); diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 1ceb31a..974e08f 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -136,6 +136,14 @@ #define CONFIG_CMD_UBIFS #endif
+/* MMC */ +#define CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_CMD_FAT +#define CONFIG_GENERIC_MMC +#define CONFIG_GENERIC_ATMEL_MCI +#define CONFIG_DOS_PARTITION + /* Ethernet */ #define CONFIG_MACB #define CONFIG_RMII
Hi Josh,
I think add MCI1 support at the same time will be better. Otherwise,
Acked-by: voice.shen@atmel.com Tested-by: voice.shen@atmel.com
- /* Initialize the MCI0 */
- at91_set_a_periph(AT91_PIO_PORTA, 17, 1); /* MCCK */
- at91_set_a_periph(AT91_PIO_PORTA, 16, 1); /* MCCDA */
- at91_set_a_periph(AT91_PIO_PORTA, 15, 1); /* MCDA0 */
- at91_set_a_periph(AT91_PIO_PORTA, 18, 1); /* MCDA1 */
- at91_set_a_periph(AT91_PIO_PORTA, 19, 1); /* MCDA2 */
- at91_set_a_periph(AT91_PIO_PORTA, 20, 1); /* MCDA3 */
- /* Enable clock */
- struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
- writel(1 << ATMEL_ID_HSMCI0, &pmc->pcer);
- at91_mci_hw_init();
- return atmel_mci_init((void *)ATMEL_BASE_HSMCI0);
+} +#endif
- int board_early_init_f(void) { at91_seriald_hw_init();
- /* Ethernet */ #define CONFIG_MACB #define CONFIG_RMII
Hi, Voice
On 9/10/2012 4:07 PM, Bo Shen wrote:
Hi Josh,
Thanks for the testing. If this patch will be accepted. then I will add MCI1 support in later patch.
Best Regards, Josh Wu
+} +#endif
Hi, Voice
On 9/12/2012 6:21 PM, Josh Wu wrote:
Hi, Voice
Hi Josh,
After checking the datasheet, The SPI0 has conflict with MCI1 in pin PA11, PA12, PA13. So I decide NOT enable MCI1 in 9x5ek u-boot since SPI0 is maybe most used for common cases.
+} +#endif
Dear Josh Wu,
This define is not necessary, we have -ffunction-sections and --gc-sections.
I favor initializing the required clocks here.
This define is not necessary at all, we should be able to include header without any impact if their functionality is not required.
I favor moving the clock enable to at91_mci_hw_init()
+} +#endif
Dear Josh Wu,
sorry for beeing late. Bu2013.01 release.t this submission was way after merge window close so it will anyhow end up in 2013.01 release.
- MA 02111-1307 USA
please leave this line untouched.
- writel(blklen << MMCI_BLKLEN_OFFSET, &mci->blkr);
please use the MMCI_BF macro here
initialized = 1; }
- /* For multi blocks read/write, set the block register */
- if ((cmd->cmdidx == MMC_CMD_READ_MULTIPLE_BLOCK)
&mci->blkr);
please use the MMCI_BF macros here.
- /* Send the command */ writel(cmd->cmdarg, &mci->argr); writel(cmdr, &mci->cmdr);
- /* This delay can be optimized, but stick with max value */
- writel(0x7f, &mci->dtor);
can we split this in a separate patch?
- u32 blkr; /* 0x18 */ u32 _1c; /* 0x1c */ u32 rspr; /* 0x20 */ u32 rspr1; /* 0x24 */
NAK, this is defined some lines up (under MR), please add an reminder here that it is defined under MR. I wonder if this will produce 'defined previously' warnings.
Best regards
Andreas Bießmann
On 9/13/2012 7:11 PM, Andreas Bießmann wrote:
Dear Josh Wu,
OK, no problem.
According to your comments I made the v2 patch and already sent it out. Thank you.
- MA 02111-1307 USA
initialized = 1; }
&mci->blkr);
- /* Bitfields in RSPRx */ #define MMCI_RSP_OFFSET 0 #define MMCI_RSP_SIZE 32
Best regards
Andreas Bießmann
Andreas Bießmann
Bo Shen
Josh Wu
