[U-Boot] [PATCH] efi_loader: fix bug in efi_get_memory_map
When booting shim -> fallback -> shim -> grub -> linux the memory map is a bit larger than the size linux passes in on the first call. But in the EFI_BUFFER_TOO_SMALL case we were not passing back the updated size to linux so it would loop forever.
Signed-off-by: Rob Clark robdclark@gmail.com --- lib/efi_loader/efi_memory.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index f59e3ea327..9e079f1fa3 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -407,11 +407,11 @@ efi_status_t efi_get_memory_map(unsigned long *memory_map_size,
map_size = map_entries * sizeof(struct efi_mem_desc);
+ *memory_map_size = map_size; + if (provided_map_size < map_size) return EFI_BUFFER_TOO_SMALL;
- *memory_map_size = map_size; - if (descriptor_size) *descriptor_size = sizeof(struct efi_mem_desc);
The spec is actually very explicit about this case. It says in the EFI_BUFFER_TOO_SMALL case, we *have* to return the map size.
Alex
yes, that is what I fixed. We *weren't* returning the required buffer size before :-)
BR, -R
Sigh, yes, this was correct in the first 3 versions of the patch series, but unfortunately broken in v4 which was actually committed ...
See: https://lists.denx.de/pipermail/u-boot/2016-October/268766.html
Actually, the map_size variable is no longer needed, if you assign to *memory_map_size directly.
Anyway, this patch is: Reviewed-by: Stefan Brüns stefan.bruens@rwth-aachen.de
Kind regards,
Stefan
Thanks, applied to efi-next
Alex
Alexander Graf
Brüns, Stefan
Rob Clark
