[PATCH 1/4] powerpc: dts: p2020: Define MPIC nodes
Copy definition of MPIC nodes from upstream Linux kernel P2020 dts files.
Signed-off-by: Pali Rohár pali@kernel.org --- arch/powerpc/dts/p2020-post.dtsi | 3 + arch/powerpc/dts/pq3-mpic-timer-B.dtsi | 42 ++++++++++++++ arch/powerpc/dts/pq3-mpic.dtsi | 79 ++++++++++++++++++++++++++ 3 files changed, 124 insertions(+) create mode 100644 arch/powerpc/dts/pq3-mpic-timer-B.dtsi create mode 100644 arch/powerpc/dts/pq3-mpic.dtsi
diff --git a/arch/powerpc/dts/p2020-post.dtsi b/arch/powerpc/dts/p2020-post.dtsi index 1c3f78798eff..dd878bf555f4 100644 --- a/arch/powerpc/dts/p2020-post.dtsi +++ b/arch/powerpc/dts/p2020-post.dtsi @@ -73,6 +73,9 @@
/include/ "pq3-etsec1-1.dtsi" /include/ "pq3-etsec1-2.dtsi" + +/include/ "pq3-mpic.dtsi" +/include/ "pq3-mpic-timer-B.dtsi" };
/* PCIe controller base address 0x8000 */ diff --git a/arch/powerpc/dts/pq3-mpic-timer-B.dtsi b/arch/powerpc/dts/pq3-mpic-timer-B.dtsi new file mode 100644 index 000000000000..8734cffae1a1 --- /dev/null +++ b/arch/powerpc/dts/pq3-mpic-timer-B.dtsi @@ -0,0 +1,42 @@ +/* + * PQ3 MPIC Timer (Group B) device tree stub [ controller @ offset 0x42100 ] + * + * Copyright 2011 Freescale Semiconductor Inc. + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions are met: + * * Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * * Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in the + * documentation and/or other materials provided with the distribution. + * * Neither the name of Freescale Semiconductor nor the + * names of its contributors may be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * + * ALTERNATIVELY, this software may be distributed under the terms of the + * GNU General Public License ("GPL") as published by the Free Software + * Foundation, either version 2 of that License or (at your option) any + * later version. + * + * THIS SOFTWARE IS PROVIDED BY Freescale Semiconductor ``AS IS'' AND ANY + * EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED + * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE + * DISCLAIMED. IN NO EVENT SHALL Freescale Semiconductor BE LIABLE FOR ANY + * DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES + * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; + * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND + * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS + * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + */ + +timer@42100 { + compatible = "fsl,mpic-global-timer"; + reg = <0x42100 0x100 0x42300 4>; + interrupts = <4 0 3 0 + 5 0 3 0 + 6 0 3 0 + 7 0 3 0>; +}; diff --git a/arch/powerpc/dts/pq3-mpic.dtsi b/arch/powerpc/dts/pq3-mpic.dtsi new file mode 100644 index 000000000000..71c30eb10056 --- /dev/null +++ b/arch/powerpc/dts/pq3-mpic.dtsi @@ -0,0 +1,79 @@ +/* + * PQ3 MPIC device tree stub [ controller @ offset 0x40000 ] + * + * Copyright 2011 Freescale Semiconductor Inc. + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions are met: + * * Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * * Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in the + * documentation and/or other materials provided with the distribution. + * * Neither the name of Freescale Semiconductor nor the + * names of its contributors may be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * + * ALTERNATIVELY, this software may be distributed under the terms of the + * GNU General Public License ("GPL") as published by the Free Software + * Foundation, either version 2 of that License or (at your option) any + * later version. + * + * THIS SOFTWARE IS PROVIDED BY Freescale Semiconductor ``AS IS'' AND ANY + * EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED + * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE + * DISCLAIMED. IN NO EVENT SHALL Freescale Semiconductor BE LIABLE FOR ANY + * DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES + * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; + * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND + * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS + * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + */ + +mpic: pic@40000 { + interrupt-controller; + #address-cells = <0>; + #interrupt-cells = <4>; + reg = <0x40000 0x40000>; + compatible = "fsl,mpic"; + device_type = "open-pic"; + big-endian; + single-cpu-affinity; + last-interrupt-source = <255>; +}; + +timer@41100 { + compatible = "fsl,mpic-global-timer"; + reg = <0x41100 0x100 0x41300 4>; + interrupts = <0 0 3 0 + 1 0 3 0 + 2 0 3 0 + 3 0 3 0>; +}; + +message@41400 { + compatible = "fsl,mpic-v3.1-msgr"; + reg = <0x41400 0x200>; + interrupts = < + 0xb0 2 0 0 + 0xb1 2 0 0 + 0xb2 2 0 0 + 0xb3 2 0 0>; +}; + +msi@41600 { + compatible = "fsl,mpic-msi"; + reg = <0x41600 0x80>; + msi-available-ranges = <0 0x100>; + interrupts = < + 0xe0 0 0 0 + 0xe1 0 0 0 + 0xe2 0 0 0 + 0xe3 0 0 0 + 0xe4 0 0 0 + 0xe5 0 0 0 + 0xe6 0 0 0 + 0xe7 0 0 0>; +};
Copy definition of crypto node from upstream Linux kernel P2020 dts files.
Signed-off-by: Pali Rohár pali@kernel.org --- arch/powerpc/dts/p2020-post.dtsi | 1 + arch/powerpc/dts/pq3-sec3.1-0.dtsi | 45 ++++++++++++++++++++++++++++++ 2 files changed, 46 insertions(+) create mode 100644 arch/powerpc/dts/pq3-sec3.1-0.dtsi
diff --git a/arch/powerpc/dts/p2020-post.dtsi b/arch/powerpc/dts/p2020-post.dtsi index dd878bf555f4..e0f1f999ac63 100644 --- a/arch/powerpc/dts/p2020-post.dtsi +++ b/arch/powerpc/dts/p2020-post.dtsi @@ -74,6 +74,7 @@ /include/ "pq3-etsec1-1.dtsi" /include/ "pq3-etsec1-2.dtsi"
+/include/ "pq3-sec3.1-0.dtsi" /include/ "pq3-mpic.dtsi" /include/ "pq3-mpic-timer-B.dtsi" }; diff --git a/arch/powerpc/dts/pq3-sec3.1-0.dtsi b/arch/powerpc/dts/pq3-sec3.1-0.dtsi new file mode 100644 index 000000000000..8f0a5669bee5 --- /dev/null +++ b/arch/powerpc/dts/pq3-sec3.1-0.dtsi @@ -0,0 +1,45 @@ +/* + * PQ3 Sec/Crypto 3.1 device tree stub [ controller @ offset 0x30000 ] + * + * Copyright 2011 Freescale Semiconductor Inc. + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions are met: + * * Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * * Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in the + * documentation and/or other materials provided with the distribution. + * * Neither the name of Freescale Semiconductor nor the + * names of its contributors may be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * + * ALTERNATIVELY, this software may be distributed under the terms of the + * GNU General Public License ("GPL") as published by the Free Software + * Foundation, either version 2 of that License or (at your option) any + * later version. + * + * THIS SOFTWARE IS PROVIDED BY Freescale Semiconductor ``AS IS'' AND ANY + * EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED + * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE + * DISCLAIMED. IN NO EVENT SHALL Freescale Semiconductor BE LIABLE FOR ANY + * DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES + * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; + * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND + * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS + * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + */ + +crypto@30000 { + compatible = "fsl,sec3.1", "fsl,sec3.0", + "fsl,sec2.4", "fsl,sec2.2", "fsl,sec2.1", + "fsl,sec2.0"; + reg = <0x30000 0x10000>; + interrupts = <45 2 0 0 58 2 0 0>; + fsl,num-channels = <4>; + fsl,channel-fifo-len = <24>; + fsl,exec-units-mask = <0xbfe>; + fsl,descriptor-types-mask = <0x3ab0ebf>; +};
Copy definition of DMA nodes from upstream Linux kernel P2020 dts files.
Signed-off-by: Pali Rohár pali@kernel.org --- arch/powerpc/dts/p2020-post.dtsi | 3 ++ arch/powerpc/dts/pq3-dma-0.dtsi | 66 ++++++++++++++++++++++++++++++++ arch/powerpc/dts/pq3-dma-1.dtsi | 66 ++++++++++++++++++++++++++++++++ 3 files changed, 135 insertions(+) create mode 100644 arch/powerpc/dts/pq3-dma-0.dtsi create mode 100644 arch/powerpc/dts/pq3-dma-1.dtsi
diff --git a/arch/powerpc/dts/p2020-post.dtsi b/arch/powerpc/dts/p2020-post.dtsi index e0f1f999ac63..d6bad4118c24 100644 --- a/arch/powerpc/dts/p2020-post.dtsi +++ b/arch/powerpc/dts/p2020-post.dtsi @@ -64,6 +64,9 @@ interrupts = <16 2 0 0>; };
+/include/ "pq3-dma-0.dtsi" +/include/ "pq3-dma-1.dtsi" + /include/ "pq3-etsec1-0.dtsi" /include/ "pq3-etsec1-timer-0.dtsi"
diff --git a/arch/powerpc/dts/pq3-dma-0.dtsi b/arch/powerpc/dts/pq3-dma-0.dtsi new file mode 100644 index 000000000000..b5b37ad30e75 --- /dev/null +++ b/arch/powerpc/dts/pq3-dma-0.dtsi @@ -0,0 +1,66 @@ +/* + * PQ3 DMA device tree stub [ controller @ offset 0x21000 ] + * + * Copyright 2011 Freescale Semiconductor Inc. + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions are met: + * * Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * * Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in the + * documentation and/or other materials provided with the distribution. + * * Neither the name of Freescale Semiconductor nor the + * names of its contributors may be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * + * ALTERNATIVELY, this software may be distributed under the terms of the + * GNU General Public License ("GPL") as published by the Free Software + * Foundation, either version 2 of that License or (at your option) any + * later version. + * + * THIS SOFTWARE IS PROVIDED BY Freescale Semiconductor ``AS IS'' AND ANY + * EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED + * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE + * DISCLAIMED. IN NO EVENT SHALL Freescale Semiconductor BE LIABLE FOR ANY + * DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES + * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; + * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND + * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS + * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + */ + +dma@21300 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "fsl,eloplus-dma"; + reg = <0x21300 0x4>; + ranges = <0x0 0x21100 0x200>; + cell-index = <0>; + dma-channel@0 { + compatible = "fsl,eloplus-dma-channel"; + reg = <0x0 0x80>; + cell-index = <0>; + interrupts = <20 2 0 0>; + }; + dma-channel@80 { + compatible = "fsl,eloplus-dma-channel"; + reg = <0x80 0x80>; + cell-index = <1>; + interrupts = <21 2 0 0>; + }; + dma-channel@100 { + compatible = "fsl,eloplus-dma-channel"; + reg = <0x100 0x80>; + cell-index = <2>; + interrupts = <22 2 0 0>; + }; + dma-channel@180 { + compatible = "fsl,eloplus-dma-channel"; + reg = <0x180 0x80>; + cell-index = <3>; + interrupts = <23 2 0 0>; + }; +}; diff --git a/arch/powerpc/dts/pq3-dma-1.dtsi b/arch/powerpc/dts/pq3-dma-1.dtsi new file mode 100644 index 000000000000..28cb8a55d807 --- /dev/null +++ b/arch/powerpc/dts/pq3-dma-1.dtsi @@ -0,0 +1,66 @@ +/* + * PQ3 DMA device tree stub [ controller @ offset 0xc300 ] + * + * Copyright 2011 Freescale Semiconductor Inc. + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions are met: + * * Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * * Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in the + * documentation and/or other materials provided with the distribution. + * * Neither the name of Freescale Semiconductor nor the + * names of its contributors may be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * + * ALTERNATIVELY, this software may be distributed under the terms of the + * GNU General Public License ("GPL") as published by the Free Software + * Foundation, either version 2 of that License or (at your option) any + * later version. + * + * THIS SOFTWARE IS PROVIDED BY Freescale Semiconductor ``AS IS'' AND ANY + * EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED + * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE + * DISCLAIMED. IN NO EVENT SHALL Freescale Semiconductor BE LIABLE FOR ANY + * DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES + * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; + * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND + * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS + * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + */ + +dma@c300 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "fsl,eloplus-dma"; + reg = <0xc300 0x4>; + ranges = <0x0 0xc100 0x200>; + cell-index = <1>; + dma-channel@0 { + compatible = "fsl,eloplus-dma-channel"; + reg = <0x0 0x80>; + cell-index = <0>; + interrupts = <76 2 0 0>; + }; + dma-channel@80 { + compatible = "fsl,eloplus-dma-channel"; + reg = <0x80 0x80>; + cell-index = <1>; + interrupts = <77 2 0 0>; + }; + dma-channel@100 { + compatible = "fsl,eloplus-dma-channel"; + reg = <0x100 0x80>; + cell-index = <2>; + interrupts = <78 2 0 0>; + }; + dma-channel@180 { + compatible = "fsl,eloplus-dma-channel"; + reg = <0x180 0x80>; + cell-index = <3>; + interrupts = <79 2 0 0>; + }; +};
Copy definition of these nodes from upstream Linux kernel P2020 dts files.
Signed-off-by: Pali Rohár pali@kernel.org --- arch/powerpc/dts/p2020-post.dtsi | 24 ++++++++++++++++++++++++ 1 file changed, 24 insertions(+)
diff --git a/arch/powerpc/dts/p2020-post.dtsi b/arch/powerpc/dts/p2020-post.dtsi index d6bad4118c24..d281bed5afd5 100644 --- a/arch/powerpc/dts/p2020-post.dtsi +++ b/arch/powerpc/dts/p2020-post.dtsi @@ -56,6 +56,24 @@ /include/ "pq3-duart-0.dtsi" /include/ "pq3-gpio-0.dtsi"
+ ecm-law@0 { + compatible = "fsl,ecm-law"; + reg = <0x0 0x1000>; + fsl,num-laws = <12>; + }; + + ecm@1000 { + compatible = "fsl,p2020-ecm", "fsl,ecm"; + reg = <0x1000 0x1000>; + interrupts = <17 2 0 0>; + }; + + memory-controller@2000 { + compatible = "fsl,p2020-memory-controller"; + reg = <0x2000 0x1000>; + interrupts = <18 2 0 0>; + }; + L2: l2-cache-controller@20000 { compatible = "fsl,p2020-l2-cache-controller"; reg = <0x20000 0x1000>; @@ -80,6 +98,12 @@ /include/ "pq3-sec3.1-0.dtsi" /include/ "pq3-mpic.dtsi" /include/ "pq3-mpic-timer-B.dtsi" + + global-utilities@e0000 { + compatible = "fsl,p2020-guts"; + reg = <0xe0000 0x1000>; + fsl,has-rstcr; + }; };
Pali Rohár
