[PATCH v2 06/21] mips: mtmips: make use of sysreset-resetctrl for mt7628 soc
This patch replaces sysreset-syscon with sysreset-resetctrl for mt7628 soc.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- Changes since v1: splitted from another patch. --- arch/mips/dts/mt7628a.dtsi | 10 +++++----- arch/mips/mach-mtmips/Kconfig | 1 + configs/gardena-smart-gateway-mt7688-ram_defconfig | 1 - configs/gardena-smart-gateway-mt7688_defconfig | 1 - configs/linkit-smart-7688-ram_defconfig | 1 - configs/linkit-smart-7688_defconfig | 1 - 6 files changed, 6 insertions(+), 9 deletions(-)
diff --git a/arch/mips/dts/mt7628a.dtsi b/arch/mips/dts/mt7628a.dtsi index 76a80c8952..cdc643fe37 100644 --- a/arch/mips/dts/mt7628a.dtsi +++ b/arch/mips/dts/mt7628a.dtsi @@ -46,11 +46,11 @@ reg = <0x0 0x100>; };
- syscon-reboot { - compatible = "syscon-reboot"; - regmap = <&sysc>; - offset = <0x34>; - mask = <0x1>; + resetctl-reboot { + compatible = "resetctl-reboot"; + + resets = <&rstctrl MT7628_SYS_RST>; + reset-names = "sysreset"; };
clkctrl: clkctrl@0x2c { diff --git a/arch/mips/mach-mtmips/Kconfig b/arch/mips/mach-mtmips/Kconfig index 8e10719b27..8cb76c4560 100644 --- a/arch/mips/mach-mtmips/Kconfig +++ b/arch/mips/mach-mtmips/Kconfig @@ -27,6 +27,7 @@ config SOC_MT7628 select MIPS_L1_CACHE_SHIFT_5 select PINCTRL_MT7628 select MTK_SERIAL + select SYSRESET_RESETCTL help This supports MediaTek MT7628/MT7688.
diff --git a/configs/gardena-smart-gateway-mt7688-ram_defconfig b/configs/gardena-smart-gateway-mt7688-ram_defconfig index 979dcb5920..01fbc6e1a2 100644 --- a/configs/gardena-smart-gateway-mt7688-ram_defconfig +++ b/configs/gardena-smart-gateway-mt7688-ram_defconfig @@ -68,7 +68,6 @@ CONFIG_MT7628_ETH=y CONFIG_PHY=y CONFIG_SPI=y CONFIG_MT7621_SPI=y -CONFIG_SYSRESET_SYSCON=y CONFIG_WDT=y CONFIG_WDT_MT7621=y CONFIG_LZMA=y diff --git a/configs/gardena-smart-gateway-mt7688_defconfig b/configs/gardena-smart-gateway-mt7688_defconfig index e8403a88fb..9156c70155 100644 --- a/configs/gardena-smart-gateway-mt7688_defconfig +++ b/configs/gardena-smart-gateway-mt7688_defconfig @@ -71,7 +71,6 @@ CONFIG_MT7628_ETH=y CONFIG_PHY=y CONFIG_SPI=y CONFIG_MT7621_SPI=y -CONFIG_SYSRESET_SYSCON=y CONFIG_WDT=y CONFIG_WDT_MT7621=y CONFIG_LZMA=y diff --git a/configs/linkit-smart-7688-ram_defconfig b/configs/linkit-smart-7688-ram_defconfig index 6d2e9e4298..10a0438245 100644 --- a/configs/linkit-smart-7688-ram_defconfig +++ b/configs/linkit-smart-7688-ram_defconfig @@ -53,7 +53,6 @@ CONFIG_PHY=y CONFIG_MT76X8_USB_PHY=y CONFIG_SPI=y CONFIG_MT7621_SPI=y -CONFIG_SYSRESET_SYSCON=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/linkit-smart-7688_defconfig b/configs/linkit-smart-7688_defconfig index 28c8be2d53..9e12d164e1 100644 --- a/configs/linkit-smart-7688_defconfig +++ b/configs/linkit-smart-7688_defconfig @@ -57,7 +57,6 @@ CONFIG_PHY=y CONFIG_MT76X8_USB_PHY=y CONFIG_SPI=y CONFIG_MT7621_SPI=y -CONFIG_SYSRESET_SYSCON=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y
Am 17.01.20 um 08:45 schrieb Weijie Gao:
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
Daniel Schwierzeck
Weijie Gao
