[U-Boot] [PATCH 1/2] mxs: spi: Fix the MXS SPI for mx23
The MX23 has slightly different register layout. Adjust the SPI driver to match the layout, both the PIO and DMA part.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Otavio Salvador otavio@ossystems.com.br Cc: Stefano Babic sbabic@denx.de --- drivers/spi/mxs_spi.c | 19 +++++++++++++++++-- 1 file changed, 17 insertions(+), 2 deletions(-)
NOTE: COMPILE TESTED ONLY!!! Someone please test before applying!
diff --git a/drivers/spi/mxs_spi.c b/drivers/spi/mxs_spi.c index 5f2fd18..5a737a1 100644 --- a/drivers/spi/mxs_spi.c +++ b/drivers/spi/mxs_spi.c @@ -168,7 +168,12 @@ static int mxs_spi_xfer_pio(struct mxs_spi_slave *slave,
while (length--) { /* We transfer 1 byte */ +#if defined(CONFIG_MX23) + writel(SSP_CTRL0_XFER_COUNT_MASK, &ssp_regs->hw_ssp_ctrl0_clr); + writel(1, &ssp_regs->hw_ssp_ctrl0_set); +#elif defined(CONFIG_MX28) writel(1, &ssp_regs->hw_ssp_xfer_size); +#endif
if ((flags & SPI_XFER_END) && !length) mxs_spi_end_xfer(ssp_regs); @@ -226,6 +231,12 @@ static int mxs_spi_xfer_dma(struct mxs_spi_slave *slave, int tl; int ret = 0;
+#if defined(CONFIG_MX23) + const int mxs_spi_pio_words = 1; +#elif defined(CONFIG_MX28) + const int mxs_spi_pio_words = 4; +#endif + ALLOC_CACHE_ALIGN_BUFFER(struct mxs_dma_desc, desc, desc_count);
memset(desc, 0, sizeof(struct mxs_dma_desc) * desc_count); @@ -281,7 +292,7 @@ static int mxs_spi_xfer_dma(struct mxs_spi_slave *slave,
dp->cmd.data |= ((tl & 0xffff) << MXS_DMA_DESC_BYTES_OFFSET) | - (4 << MXS_DMA_DESC_PIO_WORDS_OFFSET) | + (mxs_spi_pio_words << MXS_DMA_DESC_PIO_WORDS_OFFSET) | MXS_DMA_DESC_HALT_ON_TERMINATE | MXS_DMA_DESC_TERMINATE_FLUSH;
@@ -298,15 +309,19 @@ static int mxs_spi_xfer_dma(struct mxs_spi_slave *slave, }
/* - * Write CTRL0, CMD0, CMD1, XFER_SIZE registers. It is + * Write CTRL0, CMD0, CMD1 and XFER_SIZE registers in + * case of MX28, write only CTRL0 in case of MX23 due + * to the difference in register layout. It is utterly * essential that the XFER_SIZE register is written on * a per-descriptor basis with the same size as is the * descriptor! */ dp->cmd.pio_words[0] = ctrl0; +#ifdef CONFIG_MX28 dp->cmd.pio_words[1] = 0; dp->cmd.pio_words[2] = 0; dp->cmd.pio_words[3] = tl; +#endif
mxs_dma_desc_append(dmach, dp);
The CONFIG_MXS_SPI_DMA_ENABLE is no longer relevant as the SPI DMA has proven to work correctly. Remove this configuration option.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Otavio Salvador otavio@ossystems.com.br Cc: Stefano Babic sbabic@denx.de --- drivers/spi/mxs_spi.c | 16 ---------------- include/configs/m28evk.h | 1 - include/configs/mx28evk.h | 1 - 3 files changed, 18 deletions(-)
diff --git a/drivers/spi/mxs_spi.c b/drivers/spi/mxs_spi.c index 5a737a1..ca87180 100644 --- a/drivers/spi/mxs_spi.c +++ b/drivers/spi/mxs_spi.c @@ -40,17 +40,6 @@
#define MXSSSP_SMALL_TRANSFER 512
-/* - * CONFIG_MXS_SPI_DMA_ENABLE: Experimental mixed PIO/DMA support for MXS SPI - * host. Use with utmost caution! - * - * Enabling this is not yet recommended since this - * still doesn't support transfers to/from unaligned - * addresses. Therefore this driver will not work - * for example with saving environment. This is - * caused by DMA alignment constraints on MXS. - */ - struct mxs_spi_slave { struct spi_slave slave; uint32_t max_khz; @@ -347,12 +336,7 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, char dummy; int write = 0; char *data = NULL; - -#ifdef CONFIG_MXS_SPI_DMA_ENABLE int dma = 1; -#else - int dma = 0; -#endif
if (bitlen == 0) { if (flags & SPI_XFER_END) { diff --git a/include/configs/m28evk.h b/include/configs/m28evk.h index 1b51fe2..59a7be9 100644 --- a/include/configs/m28evk.h +++ b/include/configs/m28evk.h @@ -244,7 +244,6 @@ #ifdef CONFIG_CMD_SPI #define CONFIG_HARD_SPI #define CONFIG_MXS_SPI -#define CONFIG_MXS_SPI_DMA_ENABLE #define CONFIG_SPI_HALF_DUPLEX #define CONFIG_DEFAULT_SPI_BUS 2 #define CONFIG_DEFAULT_SPI_CS 0 diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index 71447d9..6a46f3c 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -202,7 +202,6 @@ #ifdef CONFIG_CMD_SPI #define CONFIG_HARD_SPI #define CONFIG_MXS_SPI -#define CONFIG_MXS_SPI_DMA_ENABLE #define CONFIG_SPI_HALF_DUPLEX #define CONFIG_DEFAULT_SPI_BUS 2 #define CONFIG_DEFAULT_SPI_MODE SPI_MODE_0
