[U-Boot] [PATCH 1/4] mmc: fsl_esdhc: make GPIO support optional
There would be compiling error as below when enable driver model for esdhc. undefined reference to `dm_gpio_get_value' undefined reference to `gpio_request_by_name_nodev' This patch is to make GPIO support optional with CONFIG_DM_GPIO. Because all boards of QorIQ platform don't need it and they just check register for CD/WP status, only some boards of i.MX platform require this.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- drivers/mmc/fsl_esdhc.c | 10 ++++++++-- 1 file changed, 8 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 9796d39..da3a151 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -104,8 +104,10 @@ struct fsl_esdhc_priv { struct udevice *dev; int non_removable; int wp_enable; +#ifdef CONFIG_DM_GPIO struct gpio_desc cd_gpio; struct gpio_desc wp_gpio; +#endif };
/* Return the XFERTYP flags for a given command and data packet */ @@ -687,10 +689,11 @@ static int esdhc_getcd(struct mmc *mmc) #ifdef CONFIG_DM_MMC if (priv->non_removable) return 1; - +#ifdef CONFIG_DM_GPIO if (dm_gpio_is_valid(&priv->cd_gpio)) return dm_gpio_get_value(&priv->cd_gpio); #endif +#endif
while (!(esdhc_read32(®s->prsstat) & PRSSTAT_CINS) && --timeout) udelay(1000); @@ -967,17 +970,20 @@ static int fsl_esdhc_probe(struct udevice *dev) priv->non_removable = 1; } else { priv->non_removable = 0; +#ifdef CONFIG_DM_GPIO gpio_request_by_name_nodev(fdt, node, "cd-gpios", 0, &priv->cd_gpio, GPIOD_IS_IN); +#endif }
priv->wp_enable = 1;
+#ifdef CONFIG_DM_GPIO ret = gpio_request_by_name_nodev(fdt, node, "wp-gpios", 0, &priv->wp_gpio, GPIOD_IS_IN); if (ret) priv->wp_enable = 0; - +#endif /* * TODO: * Because lack of clk driver, if SDHC clk is not enabled,
This patch is to add 'fsl,esdhc' into of_match table to support driver model for QorIQ eSDHC.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- drivers/mmc/fsl_esdhc.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index da3a151..0ae1cfd 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -1027,6 +1027,7 @@ static const struct udevice_id fsl_esdhc_ids[] = { { .compatible = "fsl,imx6sl-usdhc", }, { .compatible = "fsl,imx6q-usdhc", }, { .compatible = "fsl,imx7d-usdhc", }, + { .compatible = "fsl,esdhc", }, { /* sentinel */ } };
This patch is to add eSDHC nodes for ls1012a.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- arch/arm/dts/fsl-ls1012a.dtsi | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/arch/arm/dts/fsl-ls1012a.dtsi b/arch/arm/dts/fsl-ls1012a.dtsi index 024527e..f8b341d 100644 --- a/arch/arm/dts/fsl-ls1012a.dtsi +++ b/arch/arm/dts/fsl-ls1012a.dtsi @@ -103,5 +103,22 @@ status = "disabled"; };
+ esdhc0: esdhc@1560000 { + compatible = "fsl,esdhc"; + reg = <0x0 0x1560000 0x0 0x10000>; + interrupts = <0 62 0x4>; + big-endian; + bus-width = <4>; + }; + + esdhc1: esdhc@1580000 { + compatible = "fsl,esdhc"; + reg = <0x0 0x1580000 0x0 0x10000>; + interrupts = <0 65 0x4>; + big-endian; + non-removable; + bus-width = <4>; + }; + }; };
Enable driver model for eSDHC on ls1012a rdb and qds boards.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- configs/ls1012aqds_qspi_defconfig | 3 +++ configs/ls1012ardb_qspi_defconfig | 3 +++ 2 files changed, 6 insertions(+)
diff --git a/configs/ls1012aqds_qspi_defconfig b/configs/ls1012aqds_qspi_defconfig index 27bccd1..7b015a0 100644 --- a/configs/ls1012aqds_qspi_defconfig +++ b/configs/ls1012aqds_qspi_defconfig @@ -33,6 +33,9 @@ CONFIG_E1000=y CONFIG_PCI=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y +CONFIG_DM_MMC=y +CONFIG_DM_MMC_OPS=n +CONFIG_BLK=n CONFIG_FSL_DSPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y diff --git a/configs/ls1012ardb_qspi_defconfig b/configs/ls1012ardb_qspi_defconfig index 459682d..d86cb0f 100644 --- a/configs/ls1012ardb_qspi_defconfig +++ b/configs/ls1012ardb_qspi_defconfig @@ -33,6 +33,9 @@ CONFIG_E1000=y CONFIG_PCI=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y +CONFIG_DM_MMC=y +CONFIG_DM_MMC_OPS=n +CONFIG_BLK=n CONFIG_FSL_DSPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y
Jaehoon,
This set looks OK to me. Please review and comment. I can merge it with your ack.
Yangbo,
For MMC or SD patches, please CC Jaehoon.
York
Jaehoon,
Sorry for late. I missed this patch. It looks good to me.
Acked-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
Yangbo,
York
-----Original Message----- From: Jaehoon Chung [mailto:jh80.chung@samsung.com] Sent: Thursday, January 05, 2017 8:33 AM To: york sun; Y.B. Lu Cc: u-boot@lists.denx.de Subject: Re: [PATCH 1/4] mmc: fsl_esdhc: make GPIO support optional
esdhc.
require this.
Jaehoon,
[Lu Yangbo-B47093] Thanks a lot for your reviewing, Jaehoon :)
Yangbo,
York
Hi York,
Could you help to merge this patchset if there is no any changes needed? Thanks :)
Best regards, Yangbo Lu
esdhc.
require this.
Jaehoon,
Yangbo,
York
-----Original Message----- From: york sun Sent: Thursday, January 05, 2017 3:52 AM To: Y.B. Lu Cc: u-boot@lists.denx.de; Jaehoon Chung Subject: Re: [PATCH 1/4] mmc: fsl_esdhc: make GPIO support optional
esdhc.
this.
Jaehoon,
Yangbo,
[Lu Yangbo-B47093] Ok, York. And sorry for that.
York
This set is applied to fsl-qoriq master, awaiting upstream. Thanks.
York
Jaehoon Chung
Y.B. Lu
Yangbo Lu
york sun
