[U-Boot] [PATCH 3/5] x86: qemu: Wrap E1000 driver only when DM_PCI is not used
E1000 driver has not been converted to driver model, so wrap it only when DM_PCI is not used.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
include/configs/qemu-x86.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/qemu-x86.h b/include/configs/qemu-x86.h index 463620d..281aaa5 100644 --- a/include/configs/qemu-x86.h +++ b/include/configs/qemu-x86.h @@ -32,7 +32,9 @@ #define CONFIG_PCI_IO_SIZE 0xe000
#define CONFIG_PCI_PNP +#ifndef CONFIG_DM_PCI #define CONFIG_E1000 +#endif
#define CONFIG_STD_DEVICES_SETTINGS "stdin=serial\0" \ "stdout=serial\0" \
Hi Simon,
This is because E1000 driver is using pci_hose_phys_to_bus() API which DM_PCI does not provide. Do you plan to fix this?
#define CONFIG_STD_DEVICES_SETTINGS "stdin=serial\0" \ "stdout=serial\0" \ --
Regards, Bin
Hi Bin,
On 5 May 2015 at 09:35, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
That function can be moved to pci_compat.c to get things building.
However I believe it does not work and I don't have hardware to test it. Do you have time to take a look?
Hi Simon,
On Tue, May 5, 2015 at 11:43 PM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
Hi Simon,
Looks like moving it to pci_common.c can fix this and the driver still works. I will send a v2 soon.
Regards, Bin
Bin Meng
