[GIT PULL] Please pull u-boot-imx-next-20240330
Hi Tom,
Please pull this material for next from u-boot-imx, thanks.
The following changes since commit 6e2228fb052b68c84688d5baff06e2ebc787a4a5:
Merge patch series "Clean up arm linker scripts" (2024-03-29 10:39:38 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-next-20240330
for you to fetch changes up to f21b3e2cd954634d405fb522198d099879f3f1e7:
config: xea: Add limits for SPL and u-boot proper sizes (2024-03-30 15:12:22 -0300)
u-boot-imx-next-20240330 --------------------------
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/20128
- Allow accessing job-rings from non-TrustZone on colibri-imx7. - Add support for reading XEA hardware revision. - Convert imx8mq/8mm/8mn/8mp-evk to OF_UPSTREAM. - Add TMP support on imx8m*-venice-gw72xx. - Miscellaneous fixes and improvements. ---------------------------------------------------------------- Emanuele Ghidoli (3): crypto/fsl: allow accessing Job Ring from non-TrustZone configs: colibri-imx7: set non-secure boot mode as default configs: colibri-imx7: allow accessing job-rings from non-TrustZone
Fabio Estevam (3): phycore_pcl063: Drop leading zero from USB vendor number imx8: Add a default reset_cpu() implementation imx8mq_evk: Remove FEC and Ethernet PHY board code
Hiago De Franco (1): board: toradex: colibri-imx8x: Remove board_gpio_init
Lukasz Majewski (4): arm: spl: xea: Remove I2S pins configuration from early initialization arm: spl: Add definition for PHY reset GPIO for XEA HW rev. 2 arm: xea: Add support for reading SoM (CPU) board HW revision config: xea: Add limits for SPL and u-boot proper sizes
Peng Fan (4): imx: imx8mq_evk: convert to OF_UPSTREAM imx: imx8mm_evk: convert to OF_UPSTREAM imx: imx8mn-evk: convert to OF_UPSTREAM imx: imx8mp_evk: convert to OF_UPSTREAM
Tim Harvey (2): arm: dts: imx8mm-venice-gw7901: add digital I/O direction control GPIO's arm: dts: imx8m*-venice-gw72xx: add TPM device
Ye Li (4): arm: imx9: Fix MMU map table overlap thermal: imx_tmu: Fix TMU error on iMX8MQ image-container: Fix incorrect return value net: fec_mxc: Avoid enable regulator failure
arch/arm/dts/Makefile | 5 - arch/arm/dts/imx8mm-evk.dts | 128 ---- arch/arm/dts/imx8mm-evk.dtsi | 615 ------------------ arch/arm/dts/imx8mm-venice-gw71xx-0x-u-boot.dtsi | 7 + arch/arm/dts/imx8mm-venice-gw7901-u-boot.dtsi | 14 + arch/arm/dts/imx8mn-ddr4-evk.dts | 160 ----- arch/arm/dts/imx8mn-evk.dts | 128 ---- arch/arm/dts/imx8mp-evk.dts | 684 -------------------- arch/arm/dts/imx8mp-venice-gw71xx-2x-u-boot.dtsi | 9 + arch/arm/dts/imx8mq-evk.dts | 712 --------------------- arch/arm/mach-imx/image-container.c | 2 +- arch/arm/mach-imx/imx8/cpu.c | 4 + arch/arm/mach-imx/imx8m/Kconfig | 5 + arch/arm/mach-imx/imx9/soc.c | 2 +- .../imx8qm_dmsse20_a1/imx8qm_dmsse20_a1.c | 11 - .../imx8qm_rom7720_a1/imx8qm_rom7720_a1.c | 8 - board/congatec/cgtqmx8/cgtqmx8.c | 7 - board/freescale/imx8mq_evk/imx8mq_evk.c | 30 - board/freescale/imx8qm_mek/imx8qm_mek.c | 8 - board/freescale/imx8qxp_mek/imx8qxp_mek.c | 8 - board/liebherr/xea/spl_xea.c | 21 +- board/liebherr/xea/xea.c | 49 ++ board/toradex/apalis-imx8/apalis-imx8.c | 8 - board/toradex/colibri-imx8x/colibri-imx8x.c | 19 - configs/colibri_imx7_defconfig | 1 + configs/colibri_imx7_emmc_defconfig | 2 +- configs/imx28_xea_defconfig | 4 + configs/imx28_xea_sb_defconfig | 1 + configs/imx8mm_evk_defconfig | 2 +- configs/imx8mm_evk_fspi_defconfig | 2 +- configs/imx8mn_ddr4_evk_defconfig | 2 +- configs/imx8mn_evk_defconfig | 2 +- configs/imx8mp_evk_defconfig | 2 +- configs/imx8mq_evk_defconfig | 2 +- configs/phycore_pcl063_defconfig | 2 +- configs/phycore_pcl063_ull_defconfig | 2 +- drivers/crypto/fsl/Kconfig | 6 + drivers/crypto/fsl/jr.c | 19 + drivers/crypto/fsl/jr.h | 2 + drivers/net/fec_mxc.c | 2 +- drivers/thermal/imx_tmu.c | 3 + 41 files changed, 149 insertions(+), 2551 deletions(-) delete mode 100644 arch/arm/dts/imx8mm-evk.dts delete mode 100644 arch/arm/dts/imx8mm-evk.dtsi delete mode 100644 arch/arm/dts/imx8mn-ddr4-evk.dts delete mode 100644 arch/arm/dts/imx8mn-evk.dts delete mode 100644 arch/arm/dts/imx8mp-evk.dts delete mode 100644 arch/arm/dts/imx8mq-evk.dts
On Sat, Mar 30, 2024 at 04:40:31PM -0300, Fabio Estevam wrote:
Hi Tom,
Fabio Estevam
