[PATCH v2 1/3] pinctrl: rzg2l: Support 2.5V PVDD for Ethernet interfaces
The Ethenet interfaces on the Renesas RZ/G2L SoC family can operate at multiple power supply voltages: 3.3V (default value), 2.5V and 1.8V.
rzg2l_pinconf_set() is extended to support the 2.5V setting, with a check to ensure this is only used on Ethernet interfaces as it is not supported on the SD & QSPI interfaces.
While we're modifying rzg2l_pinconf_set(), drop the unnecessary default value for pwr_reg as it is set in every branch of the following if condition.
Signed-off-by: Paul Barker paul.barker.ct@bp.renesas.com --- Changes v1->v2: - Split out of series adding RZ/G2L Ethernet support [1]
[1]: https://lore.kernel.org/all/20241024152448.102-1-paul.barker.ct@bp.renesas.c...
drivers/pinctrl/renesas/rzg2l-pfc.c | 49 ++++++++++++++++++++--------- include/renesas/rzg2l-pfc.h | 2 ++ 2 files changed, 37 insertions(+), 14 deletions(-)
diff --git a/drivers/pinctrl/renesas/rzg2l-pfc.c b/drivers/pinctrl/renesas/rzg2l-pfc.c index e88ec1c18373..0098e2d52d57 100644 --- a/drivers/pinctrl/renesas/rzg2l-pfc.c +++ b/drivers/pinctrl/renesas/rzg2l-pfc.c @@ -394,18 +394,10 @@ static int rzg2l_pinconf_set(struct udevice *dev, unsigned int pin_selector, }
case PIN_CONFIG_POWER_SOURCE: { - u32 pwr_reg = 0x0; + bool support_2500 = false; + u32 pwr_reg; + u32 value;
- /* argument is in mV */ - if (argument != 1800 && argument != 3300) { - dev_err(dev, "Invalid mV %u\n", argument); - return -EINVAL; - } - - /* - * TODO: PIN_CFG_IO_VMC_ETH0 & PIN_CFG_IO_VMC_ETH1 will be - * handled when the RZ/G2L Ethernet driver is added. - */ if (cfg & PIN_CFG_IO_VMC_SD0) { dev_dbg(dev, "port off %u:%u set SD_CH 0 PVDD=%u\n", port_offset, pin, argument); @@ -418,13 +410,42 @@ static int rzg2l_pinconf_set(struct udevice *dev, unsigned int pin_selector, dev_dbg(dev, "port off %u:%u set QSPI PVDD=%u\n", port_offset, pin, argument); pwr_reg = QSPI; + } else if (cfg & PIN_CFG_IO_VMC_ETH0) { + dev_dbg(dev, "port off %u:%u set ETH0 PVDD=%u\n", + port_offset, pin, argument); + pwr_reg = ETH_POC(0); + support_2500 = true; + } else if (cfg & PIN_CFG_IO_VMC_ETH1) { + dev_dbg(dev, "port off %u:%u set ETH1 PVDD=%u\n", + port_offset, pin, argument); + pwr_reg = ETH_POC(1); + support_2500 = true; } else { - dev_dbg(dev, "pin power source is not selectable\n"); + dev_dbg(dev, "port off %u:%u PVDD is not selectable\n", + port_offset, pin); + return -EINVAL; + } + + /* argument is in mV */ + switch (argument) { + case 1800: + value = PVDD_1800; + break; + case 3300: + value = PVDD_3300; + break; + case 2500: + if (support_2500) { + value = PVDD_2500; + break; + } + fallthrough; + default: + dev_err(dev, "Invalid mV %u\n", argument); return -EINVAL; }
- writel((argument == 1800) ? PVDD_1800 : PVDD_3300, - data->base + pwr_reg); + writel(value, data->base + pwr_reg); break; }
diff --git a/include/renesas/rzg2l-pfc.h b/include/renesas/rzg2l-pfc.h index 2df17ece2a31..d1015b1d2ac1 100644 --- a/include/renesas/rzg2l-pfc.h +++ b/include/renesas/rzg2l-pfc.h @@ -77,9 +77,11 @@ #define IEN(n) (0x1800 + (n) * 8) #define PWPR 0x3014 #define SD_CH(n) (0x3000 + (n) * 4) +#define ETH_POC(ch) (0x300c + (ch) * 4) #define QSPI 0x3008
#define PVDD_1800 1 /* I/O domain voltage <= 1.8V */ +#define PVDD_2500 2 /* I/O domain voltage 2.5V */ #define PVDD_3300 0 /* I/O domain voltage >= 3.3V */
#define PWPR_B0WI BIT(7) /* Bit Write Disable */
On the RZ/G2L SoC family, the direction of the Ethernet TXC/TX_CLK signal is selectable to support an Ethernet PHY operating in either MII or RGMII mode. By default, the signal is configured as an input and MII mode is supported. The ETH_MODE register can be modified to configure this signal as an output to support RGMII mode.
As this signal is be default an input, and can optionally be switched to an output, it maps neatly onto an `output-enable` property in the device tree.
drivers/pinctrl/renesas/rzg2l-pfc.c | 31 +++++++++++++++++++++++++++-- include/renesas/rzg2l-pfc.h | 2 ++ 2 files changed, 31 insertions(+), 2 deletions(-)
diff --git a/drivers/pinctrl/renesas/rzg2l-pfc.c b/drivers/pinctrl/renesas/rzg2l-pfc.c index 0098e2d52d57..af371bd0ff1e 100644 --- a/drivers/pinctrl/renesas/rzg2l-pfc.c +++ b/drivers/pinctrl/renesas/rzg2l-pfc.c @@ -180,7 +180,7 @@ static const u32 r9a07g044_gpio_configs[] = { RZG2L_GPIO_PORT_PACK(3, 0x21, RZG2L_MPXED_PIN_FUNCS), RZG2L_GPIO_PORT_PACK(2, 0x22, RZG2L_MPXED_PIN_FUNCS), RZG2L_GPIO_PORT_PACK(2, 0x23, RZG2L_MPXED_PIN_FUNCS), - RZG2L_GPIO_PORT_PACK(3, 0x24, RZG2L_MPXED_ETH_PIN_FUNCS(PIN_CFG_IO_VMC_ETH0)), + RZG2L_GPIO_PORT_PACK(3, 0x24, RZG2L_MPXED_ETH_PIN_FUNCS(PIN_CFG_IO_VMC_ETH0) | PIN_CFG_OEN), RZG2L_GPIO_PORT_PACK(2, 0x25, RZG2L_MPXED_ETH_PIN_FUNCS(PIN_CFG_IO_VMC_ETH0)), RZG2L_GPIO_PORT_PACK(2, 0x26, RZG2L_MPXED_ETH_PIN_FUNCS(PIN_CFG_IO_VMC_ETH0)), RZG2L_GPIO_PORT_PACK(2, 0x27, RZG2L_MPXED_ETH_PIN_FUNCS(PIN_CFG_IO_VMC_ETH0)), @@ -189,7 +189,7 @@ static const u32 r9a07g044_gpio_configs[] = { RZG2L_GPIO_PORT_PACK(2, 0x2a, RZG2L_MPXED_ETH_PIN_FUNCS(PIN_CFG_IO_VMC_ETH0)), RZG2L_GPIO_PORT_PACK(2, 0x2b, RZG2L_MPXED_ETH_PIN_FUNCS(PIN_CFG_IO_VMC_ETH0)), RZG2L_GPIO_PORT_PACK(2, 0x2c, RZG2L_MPXED_ETH_PIN_FUNCS(PIN_CFG_IO_VMC_ETH0)), - RZG2L_GPIO_PORT_PACK(2, 0x2d, RZG2L_MPXED_ETH_PIN_FUNCS(PIN_CFG_IO_VMC_ETH1)), + RZG2L_GPIO_PORT_PACK(2, 0x2d, RZG2L_MPXED_ETH_PIN_FUNCS(PIN_CFG_IO_VMC_ETH1) | PIN_CFG_OEN), RZG2L_GPIO_PORT_PACK(2, 0x2e, RZG2L_MPXED_ETH_PIN_FUNCS(PIN_CFG_IO_VMC_ETH1)), RZG2L_GPIO_PORT_PACK(2, 0x2f, RZG2L_MPXED_ETH_PIN_FUNCS(PIN_CFG_IO_VMC_ETH1)), RZG2L_GPIO_PORT_PACK(2, 0x30, RZG2L_MPXED_ETH_PIN_FUNCS(PIN_CFG_IO_VMC_ETH1)), @@ -449,6 +449,32 @@ static int rzg2l_pinconf_set(struct udevice *dev, unsigned int pin_selector, break; }
+ case PIN_CONFIG_OUTPUT_ENABLE: { + u8 ch; + + if (!(cfg & PIN_CFG_OEN)) { + dev_err(dev, "pin does not support OEN\n"); + return -EINVAL; + } + + /* + * We can determine which Ethernet interface we're dealing with from + * the caps. + */ + if (cfg & PIN_CFG_IO_VMC_ETH0) + ch = 0; + else /* PIN_CFG_IO_VMC_ETH1 */ + ch = 1; + + dev_dbg(dev, "set ETH%u TXC OEN=%u\n", ch, argument); + if (argument) + clrbits_8(data->base + ETH_MODE, BIT(ch)); + else + setbits_8(data->base + ETH_MODE, BIT(ch)); + + break; + } + default: dev_err(dev, "Invalid pinconf parameter\n"); return -EOPNOTSUPP; @@ -542,6 +568,7 @@ static int rzg2l_get_pin_muxing(struct udevice *dev, unsigned int selector,
static const struct pinconf_param rzg2l_pinconf_params[] = { { "input-enable", PIN_CONFIG_INPUT_ENABLE, 1 }, + { "output-enable", PIN_CONFIG_OUTPUT_ENABLE, 1 }, { "power-source", PIN_CONFIG_POWER_SOURCE, 3300 /* mV */ }, };
diff --git a/include/renesas/rzg2l-pfc.h b/include/renesas/rzg2l-pfc.h index d1015b1d2ac1..36fa8da8e2e4 100644 --- a/include/renesas/rzg2l-pfc.h +++ b/include/renesas/rzg2l-pfc.h @@ -22,6 +22,7 @@ #define PIN_CFG_FILONOFF BIT(10) #define PIN_CFG_FILNUM BIT(11) #define PIN_CFG_FILCLKSEL BIT(12) +#define PIN_CFG_OEN BIT(13)
#define RZG2L_MPXED_PIN_FUNCS (PIN_CFG_IOLH_A | \ PIN_CFG_SR | \ @@ -79,6 +80,7 @@ #define SD_CH(n) (0x3000 + (n) * 4) #define ETH_POC(ch) (0x300c + (ch) * 4) #define QSPI 0x3008 +#define ETH_MODE (0x3018)
#define PVDD_1800 1 /* I/O domain voltage <= 1.8V */ #define PVDD_2500 2 /* I/O domain voltage 2.5V */
Changes v1->v2:
- RZG2L_GPIO_PORT_PACK(3, 0x24, RZG2L_MPXED_ETH_PIN_FUNCS(PIN_CFG_IO_VMC_ETH0) | PIN_CFG_OEN), RZG2L_GPIO_PORT_PACK(2, 0x25, RZG2L_MPXED_ETH_PIN_FUNCS(PIN_CFG_IO_VMC_ETH0)), RZG2L_GPIO_PORT_PACK(2, 0x26, RZG2L_MPXED_ETH_PIN_FUNCS(PIN_CFG_IO_VMC_ETH0)), RZG2L_GPIO_PORT_PACK(2, 0x27, RZG2L_MPXED_ETH_PIN_FUNCS(PIN_CFG_IO_VMC_ETH0)),
- RZG2L_GPIO_PORT_PACK(2, 0x2d, RZG2L_MPXED_ETH_PIN_FUNCS(PIN_CFG_IO_VMC_ETH1) | PIN_CFG_OEN), RZG2L_GPIO_PORT_PACK(2, 0x2e, RZG2L_MPXED_ETH_PIN_FUNCS(PIN_CFG_IO_VMC_ETH1)), RZG2L_GPIO_PORT_PACK(2, 0x2f, RZG2L_MPXED_ETH_PIN_FUNCS(PIN_CFG_IO_VMC_ETH1)), RZG2L_GPIO_PORT_PACK(2, 0x30, RZG2L_MPXED_ETH_PIN_FUNCS(PIN_CFG_IO_VMC_ETH1)),
- case PIN_CONFIG_OUTPUT_ENABLE: {
u8 ch;
return -EINVAL;
* the caps.
ch = 0;
ch = 1;
if (argument)
else
break;
- default: dev_err(dev, "Invalid pinconf parameter\n"); return -EOPNOTSUPP;
- { "output-enable", PIN_CONFIG_OUTPUT_ENABLE, 1 }, { "power-source", PIN_CONFIG_POWER_SOURCE, 3300 /* mV */ }, };
Parenthesis unnecessary around the 0x3018 , I can fix it while applying?
In any case, with that fixed:
Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org
Changes v1->v2:
u8 ch;
return -EINVAL;
* the caps.
ch = 0;
ch = 1;
if (argument)
else
break;
Thanks for fixing this up!
In rzg2l_pinconf_set(), there are no new variables defined in the case statement for PIN_CONFIG_INPUT_ENABLE so no additional scope is needed.
Signed-off-by: Paul Barker paul.barker.ct@bp.renesas.com Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Changes v1->v2: - Split out of series adding RZ/G2L Ethernet support [1] - Added Marek's Reviewed-by tag
drivers/pinctrl/renesas/rzg2l-pfc.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/pinctrl/renesas/rzg2l-pfc.c b/drivers/pinctrl/renesas/rzg2l-pfc.c index af371bd0ff1e..3c751e9473a5 100644 --- a/drivers/pinctrl/renesas/rzg2l-pfc.c +++ b/drivers/pinctrl/renesas/rzg2l-pfc.c @@ -381,7 +381,7 @@ static int rzg2l_pinconf_set(struct udevice *dev, unsigned int pin_selector, }
switch (param) { - case PIN_CONFIG_INPUT_ENABLE: { + case PIN_CONFIG_INPUT_ENABLE: if (!(cfg & PIN_CFG_IEN)) { dev_err(dev, "pin does not support IEN\n"); return -EINVAL; @@ -391,7 +391,6 @@ static int rzg2l_pinconf_set(struct udevice *dev, unsigned int pin_selector, port_offset, pin, argument); rzg2l_rmw_pin_config(data, IEN(port_offset), pin, IEN_MASK, !!argument); break; - }
case PIN_CONFIG_POWER_SOURCE: { bool support_2500 = false;
Paul Barker
