[PATCH] arm64: versal: Let U-Boot to update memory node by default
There is no reason not to let U-Boot to update memory node by default. In past this was disabled by purpose to be able to test different memory configurations from one U-Boot instance.
configs/xilinx_versal_virt_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/xilinx_versal_virt_defconfig b/configs/xilinx_versal_virt_defconfig index b629f8ba698c..7c20123b66fa 100644 --- a/configs/xilinx_versal_virt_defconfig +++ b/configs/xilinx_versal_virt_defconfig @@ -7,7 +7,6 @@ CONFIG_COUNTER_FREQUENCY=62500000 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y -# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_BOOTDELAY=5 # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y
Ășt 12. 5. 2020 v 8:18 odesĂlatel Michal Simek michal.simek@xilinx.com napsal:
diff --git a/configs/xilinx_versal_virt_defconfig b/configs/xilinx_versal_virt_defconfig index b629f8ba698c..7c20123b66fa 100644 --- a/configs/xilinx_versal_virt_defconfig +++ b/configs/xilinx_versal_virt_defconfig @@ -7,7 +7,6 @@ CONFIG_COUNTER_FREQUENCY=62500000 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y -# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_BOOTDELAY=5 # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y -- 2.26.2
Applied. M
Michal Simek
Michal Simek
