[PATCH] net: sun8i_emac: Drop DM_GPIO checks
DM_GPIO is always enable in U-Boot proper for ARCH_SUNXI, and this driver is never enabled in SPL, so the condition is always true.
Signed-off-by: Samuel Holland samuel@sholland.org ---
drivers/net/sun8i_emac.c | 10 ---------- 1 file changed, 10 deletions(-)
diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index 4ba9ee1529e..a12f7e32e8f 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -168,9 +168,7 @@ struct emac_eth_dev { struct clk ephy_clk; struct reset_ctl tx_rst; struct reset_ctl ephy_rst; -#if CONFIG_IS_ENABLED(DM_GPIO) struct gpio_desc reset_gpio; -#endif struct udevice *phy_reg; };
@@ -617,7 +615,6 @@ err_tx_clk: return ret; }
-#if CONFIG_IS_ENABLED(DM_GPIO) static int sun8i_mdio_reset(struct mii_dev *bus) { struct udevice *dev = bus->priv; @@ -649,7 +646,6 @@ static int sun8i_mdio_reset(struct mii_dev *bus)
return 0; } -#endif
static int sun8i_mdio_init(const char *name, struct udevice *priv) { @@ -664,9 +660,7 @@ static int sun8i_mdio_init(const char *name, struct udevice *priv) bus->write = sun8i_mdio_write; snprintf(bus->name, sizeof(bus->name), name); bus->priv = (void *)priv; -#if CONFIG_IS_ENABLED(DM_GPIO) bus->reset = sun8i_mdio_reset; -#endif
return mdio_register(bus); } @@ -783,9 +777,7 @@ static int sun8i_emac_eth_of_to_plat(struct udevice *dev) const fdt32_t *reg; int node = dev_of_offset(dev); int offset = 0; -#if CONFIG_IS_ENABLED(DM_GPIO) int reset_flags = GPIOD_IS_OUT; -#endif int ret;
pdata->iobase = dev_read_addr(dev); @@ -872,7 +864,6 @@ static int sun8i_emac_eth_of_to_plat(struct udevice *dev) printf("%s: Invalid RX delay value %d\n", __func__, sun8i_pdata->rx_delay_ps);
-#if CONFIG_IS_ENABLED(DM_GPIO) if (fdtdec_get_bool(gd->fdt_blob, dev_of_offset(dev), "snps,reset-active-low")) reset_flags |= GPIOD_ACTIVE_LOW; @@ -887,7 +878,6 @@ static int sun8i_emac_eth_of_to_plat(struct udevice *dev) } else if (ret == -ENOENT) { ret = 0; } -#endif
return 0; }
Yes indeed, the u-boot.bin binaries of all sunxi boards are identical with and without this patch.
Reviewed-by: Andre Przywara andre.przywara@arm.com
Who is going to take this, does this go via some network tree?
Thanks, Andre
return 0; } -#endif
return 0; }
Andre Przywara
Samuel Holland
