[U-Boot] [PATCH v3 00/16] import x509/pkcs7 parsers from linux
# This patch set is a prerequisite for UEFI secure boot. # This patch set should be merged first prior to my rsa extension patch # due to some dependency.
Asn1 parsers of x509 certificates and pkcs7 messages are required to implement image authentication and variable authentication as part of UEFI secure boot feature.
As we discussed before in the thread[1], most people insisted that we should re-use corresponding source code from Linux repository for this purpose.
Here is my attempt to import all the necessary files from Linux; Those will eventually be part of UEFI secure boot implementation, but I'd like to get early feedback from other peoples before submitting the whole patchset so that they will be better formatted for merging.
My approach here is * files from the latest Linux * modify files as little as possible * mark/protect unavoidable changes with "#if(n)def __UBOOT__" so that future fixes/differences in Linux repository will easily be applied to U-Boot.
Known issues: * checkpatch.pl Checkpatch.pl will complain with a bunch of warnings/errors but I intentionally left them unchanged for the sake of better maintainability I said above.
-Takahiro Akashi
[1] https://lists.denx.de/pipermail/u-boot/2019-April/366423.html
Changes in v3 (Nov 13, 2019) * rebased to v2020.01-rc * improve function description of kmemdup() (patch#1) * remove test/lib/Kconfig (patch#16) * declare variables in unit test as static (patch#16)
Changes in v2 (Oct 25, 2019) * revise commit messages, describing what files are modified or not. * move kmemdump() in ubifs.c to linux_compat.c for general use (patch#1) * add patch#2 * move date.c to lib/ for general use (patch#3) * implement mktime64() with rtc_mktime() (patch#4) * move asn1_compiler.c to tools/ (patch#7) * change CONFIG_BUILD_ASN1 to CONFIG_ASN1_COMPILER (patch#7) * add clean rule to asn1_compiler-generated files to clean targets (patch#8) * change CONFIG_ASN1 to CONFIG_ASN1_DECODER (patch#9) * add README for asn1 compiler/decoder (patch#10) * move build_oid_registry to scripts/ (patch#11) * shuffle an order of patches (patch#13,#14,#15) * add a new config CONFIG_RSA_PUBLIC_KEY_PARSER so that it can be * modify Kconfig dependency (patch#13,#14,#15) compiled in independently (patch#13) * add unit test (patch#16,#17)
Changes in v1 (Oct 11, 2019) from RFC * change the kernel code base from v5.0 to v5.3 * add preparatory patches (#1, #2 and #3) * comment off x509_check_for_self_signed() which is not useful for UEFI secure boot (patch#9) * improve usages of "#if(n)def __UBOOT__* to minimize differences between U-Boot and linux kernel
AKASHI Takahiro (16): linux_compat: move kmemdup() from ubifs.c to linux_compat.c rtc.h: add struct udevice declaration rtc: move date.c from drivers/rtc/ to lib/ lib: add mktime64() for linux compatibility include: kernel.h: include printk.h linux/time.h: include vsprintf.h cmd: add asn1_compiler Makefile: add build script for asn1 parsers lib: add asn1 decoder doc: add README for asn1 compiler and decoder lib: add oid registry utility lib: crypto: add public key utility lib: crypto: add rsa public key parser lib: crypto: add x509 parser lib: crypto: add pkcs7 message parser test: add asn1 unit test
Makefile | 1 + cmd/Kconfig | 1 + doc/README.asn1 | 40 + drivers/rtc/Kconfig | 1 + drivers/rtc/Makefile | 1 - fs/ubifs/ubifs.c | 19 +- include/crypto/internal/rsa.h | 57 + include/crypto/pkcs7.h | 47 + include/crypto/public_key.h | 90 ++ include/keys/asymmetric-type.h | 88 ++ include/linux/asn1.h | 65 ++ include/linux/asn1_ber_bytecode.h | 89 ++ include/linux/asn1_decoder.h | 20 + include/linux/kernel.h | 2 +- include/linux/oid_registry.h | 117 +++ include/linux/time.h | 11 + include/rtc.h | 2 + lib/Kconfig | 17 + lib/Makefile | 20 + lib/asn1_decoder.c | 527 ++++++++++ lib/crypto/Kconfig | 52 + lib/crypto/Makefile | 49 + lib/crypto/asymmetric_type.c | 668 ++++++++++++ lib/crypto/pkcs7.asn1 | 135 +++ lib/crypto/pkcs7_parser.c | 693 +++++++++++++ lib/crypto/pkcs7_parser.h | 65 ++ lib/crypto/public_key.c | 376 +++++++ lib/crypto/rsa_helper.c | 198 ++++ lib/crypto/rsapubkey.asn1 | 4 + lib/crypto/x509.asn1 | 60 ++ lib/crypto/x509_akid.asn1 | 35 + lib/crypto/x509_cert_parser.c | 697 +++++++++++++ lib/crypto/x509_parser.h | 57 + lib/crypto/x509_public_key.c | 292 ++++++ {drivers/rtc => lib}/date.c | 23 +- lib/linux_compat.c | 19 + lib/oid_registry.c | 179 ++++ scripts/Makefile.build | 4 +- scripts/build_OID_registry | 203 ++++ test/Kconfig | 18 +- test/lib/Makefile | 1 + test/lib/asn1.c | 392 +++++++ tools/Makefile | 3 + tools/asn1_compiler.c | 1611 +++++++++++++++++++++++++++++ 44 files changed, 7024 insertions(+), 25 deletions(-) create mode 100644 doc/README.asn1 create mode 100644 include/crypto/internal/rsa.h create mode 100644 include/crypto/pkcs7.h create mode 100644 include/crypto/public_key.h create mode 100644 include/keys/asymmetric-type.h create mode 100644 include/linux/asn1.h create mode 100644 include/linux/asn1_ber_bytecode.h create mode 100644 include/linux/asn1_decoder.h create mode 100644 include/linux/oid_registry.h create mode 100644 lib/asn1_decoder.c create mode 100644 lib/crypto/Kconfig create mode 100644 lib/crypto/Makefile create mode 100644 lib/crypto/asymmetric_type.c create mode 100644 lib/crypto/pkcs7.asn1 create mode 100644 lib/crypto/pkcs7_parser.c create mode 100644 lib/crypto/pkcs7_parser.h create mode 100644 lib/crypto/public_key.c create mode 100644 lib/crypto/rsa_helper.c create mode 100644 lib/crypto/rsapubkey.asn1 create mode 100644 lib/crypto/x509.asn1 create mode 100644 lib/crypto/x509_akid.asn1 create mode 100644 lib/crypto/x509_cert_parser.c create mode 100644 lib/crypto/x509_parser.h create mode 100644 lib/crypto/x509_public_key.c rename {drivers/rtc => lib}/date.c (81%) create mode 100644 lib/oid_registry.c create mode 100755 scripts/build_OID_registry create mode 100644 test/lib/asn1.c create mode 100644 tools/asn1_compiler.c
linux_compat.c is the best place for kmemdup(), which is currenly used only in ubifs.c, but will also be used when other kernel files (in my case, lib/crypto/x509_cert_parser.c and pkcs7_parser.c) will be imported. So just move it.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- fs/ubifs/ubifs.c | 19 +------------------ lib/linux_compat.c | 19 +++++++++++++++++++ 2 files changed, 20 insertions(+), 18 deletions(-)
diff --git a/fs/ubifs/ubifs.c b/fs/ubifs/ubifs.c index 67a0e8caae70..1ffdfe0d9089 100644 --- a/fs/ubifs/ubifs.c +++ b/fs/ubifs/ubifs.c @@ -18,6 +18,7 @@ #include "ubifs.h" #include <u-boot/zlib.h>
+#include <linux/compat.h> #include <linux/err.h> #include <linux/lzo.h>
@@ -70,24 +71,6 @@ struct ubifs_compressor *ubifs_compressors[UBIFS_COMPR_TYPES_CNT];
#ifdef __UBOOT__ -/* from mm/util.c */ - -/** - * kmemdup - duplicate region of memory - * - * @src: memory region to duplicate - * @len: memory region length - * @gfp: GFP mask to use - */ -void *kmemdup(const void *src, size_t len, gfp_t gfp) -{ - void *p; - - p = kmalloc(len, gfp); - if (p) - memcpy(p, src, len); - return p; -}
struct crypto_comp { int compressor; diff --git a/lib/linux_compat.c b/lib/linux_compat.c index 81ea8fb126fa..3f440deaa0d8 100644 --- a/lib/linux_compat.c +++ b/lib/linux_compat.c @@ -40,3 +40,22 @@ void *kmem_cache_alloc(struct kmem_cache *obj, int flag) { return malloc_cache_aligned(obj->sz); } + +/** + * kmemdup - duplicate region of memory + * + * @src: memory region to duplicate + * @len: memory region length + * @gfp: GFP mask to use + * + * Return: newly allocated copy of @src or %NULL in case of error + */ +void *kmemdup(const void *src, size_t len, gfp_t gfp) +{ + void *p; + + p = kmalloc(len, gfp); + if (p) + memcpy(p, src, len); + return p; +}
Signed-off-by: AKASHI Takahirotakahiro.akashi@linaro.org
km_kirkwood_defconfig with CONFIG_UBIFS=y compiles.
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
Without this change, including rtc.h solely will cause a build error.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- include/rtc.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/rtc.h b/include/rtc.h index 7386d52db1d7..8aabfc1162a4 100644 --- a/include/rtc.h +++ b/include/rtc.h @@ -18,6 +18,8 @@
#ifdef CONFIG_DM_RTC
+struct udevice; + struct rtc_ops { /** * get() - get the current time
In the next commit, rtc_mktime(), for compatibility with linux, will be implemented using rtc_mktime(), which is no longer drivers/rtc specific. So move this file under lib/.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- cmd/Kconfig | 1 + drivers/rtc/Kconfig | 1 + drivers/rtc/Makefile | 1 - lib/Kconfig | 3 +++ lib/Makefile | 2 ++ {drivers/rtc => lib}/date.c | 5 ++--- 6 files changed, 9 insertions(+), 4 deletions(-) rename {drivers/rtc => lib}/date.c (96%)
diff --git a/cmd/Kconfig b/cmd/Kconfig index b08a7098579b..1b9045696267 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1620,6 +1620,7 @@ config CMD_LED config CMD_DATE bool "date" default y if DM_RTC + select LIB_DATE help Enable the 'date' command for getting/setting the time/date in RTC devices. diff --git a/drivers/rtc/Kconfig b/drivers/rtc/Kconfig index 8778cc7b264c..89e71cc7ebef 100644 --- a/drivers/rtc/Kconfig +++ b/drivers/rtc/Kconfig @@ -7,6 +7,7 @@ menu "Real Time Clock" config DM_RTC bool "Enable Driver Model for RTC drivers" depends on DM + select LIB_DATE help Enable drver model for real-time-clock drivers. The RTC uclass then provides the rtc_get()/rtc_set() interface, delegating to diff --git a/drivers/rtc/Makefile b/drivers/rtc/Makefile index f97a6699820e..e8875ce10f5e 100644 --- a/drivers/rtc/Makefile +++ b/drivers/rtc/Makefile @@ -7,7 +7,6 @@ obj-$(CONFIG_$(SPL_TPL_)DM_RTC) += rtc-uclass.o
obj-$(CONFIG_RTC_AT91SAM9_RTT) += at91sam9_rtt.o -obj-y += date.o obj-y += rtc-lib.o obj-$(CONFIG_RTC_DAVINCI) += davinci.o obj-$(CONFIG_RTC_DS1302) += ds1302.o diff --git a/lib/Kconfig b/lib/Kconfig index b8a8509d720f..642dc1ac872e 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -574,4 +574,7 @@ config TEST_FDTDEC bool "enable fdtdec test" depends on OF_LIBFDT
+config LIB_DATE + bool + endmenu diff --git a/lib/Makefile b/lib/Makefile index d248d8626cea..8d0b9d9513f0 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -117,4 +117,6 @@ else obj-y += vsprintf.o strto.o strmhz.o endif
+obj-y += date.o + subdir-ccflags-$(CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED) += -O2 diff --git a/drivers/rtc/date.c b/lib/date.c similarity index 96% rename from drivers/rtc/date.c rename to lib/date.c index c57317d2c267..63af4a142612 100644 --- a/drivers/rtc/date.c +++ b/lib/date.c @@ -9,8 +9,7 @@ #include <errno.h> #include <rtc.h>
-#if defined(CONFIG_CMD_DATE) || defined(CONFIG_DM_RTC) || \ - defined(CONFIG_TIMESTAMP) +#if defined(CONFIG_LIB_DATE) || defined(CONFIG_TIMESTAMP)
#define FEBRUARY 2 #define STARTOFTIME 1970 @@ -97,4 +96,4 @@ unsigned long rtc_mktime(const struct rtc_time *tm) return (hours * 60 + tm->tm_min) * 60 + tm->tm_sec; }
-#endif +#endif /* CONFIG_LIB_DATE || CONFIG_TIMESTAMP */
This function will be used in lib/crypto/x509_cert_parser.c, which will also be imported from linux code in a later commit.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- include/linux/time.h | 10 ++++++++++ lib/date.c | 20 ++++++++++++++++++++ 2 files changed, 30 insertions(+)
diff --git a/include/linux/time.h b/include/linux/time.h index b8d298eb4d68..dc9344a6d97b 100644 --- a/include/linux/time.h +++ b/include/linux/time.h @@ -1,6 +1,7 @@ #ifndef _LINUX_TIME_H #define _LINUX_TIME_H
+#include <rtc.h> #include <linux/types.h>
#define _DEFUN(a,b,c) a(c) @@ -150,4 +151,13 @@ _DEFUN (ctime_r, (tim_p, result), return asctime_r (localtime_r (tim_p, &tm), result); }
+/* for compatibility with linux code */ +typedef __s64 time64_t; + +#ifdef CONFIG_LIB_DATE +time64_t mktime64(const unsigned int year, const unsigned int mon, + const unsigned int day, const unsigned int hour, + const unsigned int min, const unsigned int sec); +#endif + #endif diff --git a/lib/date.c b/lib/date.c index 63af4a142612..0456de78ab14 100644 --- a/lib/date.c +++ b/lib/date.c @@ -8,6 +8,7 @@ #include <command.h> #include <errno.h> #include <rtc.h> +#include <linux/time.h>
@@ -97,3 +98,22 @@ unsigned long rtc_mktime(const struct rtc_time *tm) }
#endif /* CONFIG_LIB_DATE || CONFIG_TIMESTAMP */ + +#ifdef CONFIG_LIB_DATE +/* for compatibility with linux code */ +time64_t mktime64(const unsigned int year, const unsigned int mon, + const unsigned int day, const unsigned int hour, + const unsigned int min, const unsigned int sec) +{ + struct rtc_time time; + + time.tm_year = year; + time.tm_mon = mon; + time.tm_mday = day; + time.tm_hour = hour; + time.tm_min = min; + time.tm_sec = sec; + + return (time64_t)rtc_mktime((const struct rtc_time *)&time); +} +#endif
Adding "printk.h" will help improve portability from linux kernel code (in my case, lib/asn1_decoder.c and others) where printf and pr_* variant functions are used.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- include/linux/kernel.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/linux/kernel.h b/include/linux/kernel.h index 5c7e5f635b1a..564819a1c0a7 100644 --- a/include/linux/kernel.h +++ b/include/linux/kernel.h @@ -1,8 +1,8 @@ #ifndef _LINUX_KERNEL_H #define _LINUX_KERNEL_H
- #include <linux/types.h> +#include <linux/printk.h> /* for printf/pr_* utilities */
#define USHRT_MAX ((u16)(~0U)) #define SHRT_MAX ((s16)(USHRT_MAX>>1))
nits:
%s/printf/printk/g
You anyway change the includes in lib/crypto/public_key.c in patch 12/16 and lib/asn1_decoder in patch 09/16. So why not add linux/printk.h there?
Otherwise I would expect this patch to remove #include <linux/printk.h> in all files where it becomes obsolete due to this patch, e.g.
board/synopsys/hsdk/hsdk.c arch/arm/mach-uniphier/fdt-fixup.c arch/arm/mach-uniphier/dram_init.c arch/arm/mach-uniphier/arm32/psci.c arch/arm/mach-uniphier/dram/ddrphy-training.c
Best regards
Heinrich
Heinrich,
nits:
%s/printf/printk/g
Okay.
I would rather disagree here as I have good reasons. First, adding "printk.h" to "linux/kernel.h" makes sense simply as Linux's original "linux/kernel.h" also has it. So when you will import any files from linux in the future, you will probably get *less* bothered with missing include files in .c file. Second, I would like to change linux code at the very minimum if possible. In lib/crypto/public_key.c, for example, I simply deleted not-used and non-existing include files or just replaced any with its counterpart in U-Boot (module.h -> compat.h).
I don't fully understand that why those files include "linux/kernel.h". Different source files may include "linux/kernel.h" for different reasons. Take board/synopsys/hsdk/hsdk.c, for example. It uses ARRAY_SIZE macro for its convenience, *not* for printk. I believe that including any include files *directly & explicitly* for its own use of any definitions or functions is a good practice even if such include files may be included *indirectly* via another include file.
So I want to keep this patch unchanged.
-Takahiro Akashi
Best regards
Heinrich
Thank you for the merge. Heinrich pointed out a typo in the commit message (not in the code): %s/printf/printk/g
Please correct it if you have a chance.
Thanks, -Takahiro Akashi
-- Tom
Without this commit, time.h possibly causes a build error as asctime_r() uses sprintf().
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- include/linux/time.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/linux/time.h b/include/linux/time.h index dc9344a6d97b..702dd276aea5 100644 --- a/include/linux/time.h +++ b/include/linux/time.h @@ -2,6 +2,7 @@ #define _LINUX_TIME_H
#include <rtc.h> +#include <vsprintf.h> #include <linux/types.h>
asctime_r() is not a Linux symbol (as of next-20191119)
ctime_r() and asctime_r() are defined as inline functions. ctime_r() is used in multiple places and so we may end up duplicating code. So I would prefer the inline functions in time.h to be moved to a separate C file in lib/.
Best regards
Heinrich
Best regards
Heinrich
Could it be that in one of your C files you simply didn't follow the U-Boot coding style convention to include common.h first and we don't need this patch at all?
https://www.denx.de/wiki/U-Boot/CodingStyle#Include_files
Best regards
Heinrich
Heinrich,
I simply don't get your point here.
Basically I'm reluctant to do so. I have never touched ctime_r() nor asctime_r() as they were introduced by Wolfgang in 2002. Since then, nobody complained. So why now?
Best regards
Heinrich
I will address this issue in general in the future.
I commented against this above. I believe that *hidden* dependency of include files should not be exposed to users. In this case, for example, any code that uses asctime_r() should not be bothered with such a dependency as the code doesn't know what functions asctime_r() internally uses or even if that function is inline or not. I also mentioned this in another thread in different words: https://lists.denx.de/pipermail/u-boot/2019-November/391959.html
Best regards
Heinrich
Imported from linux kernel v5.3: asn1.h without changes asn1_ber_bytecode.h without changes asn1_decoder.h without changes asn1_compiler.c without changes
This host command will be used to create a ASN1 parser, for example, for pkcs7 messages or x509 certificates. More specifically, it will generate *byte code* which will be interpreted by asn1 decoder library.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de --- include/linux/asn1.h | 65 ++ include/linux/asn1_ber_bytecode.h | 89 ++ include/linux/asn1_decoder.h | 20 + lib/Kconfig | 3 + scripts/Makefile.build | 4 +- tools/Makefile | 3 + tools/asn1_compiler.c | 1611 +++++++++++++++++++++++++++++ 7 files changed, 1793 insertions(+), 2 deletions(-) create mode 100644 include/linux/asn1.h create mode 100644 include/linux/asn1_ber_bytecode.h create mode 100644 include/linux/asn1_decoder.h create mode 100644 tools/asn1_compiler.c
diff --git a/include/linux/asn1.h b/include/linux/asn1.h new file mode 100644 index 000000000000..a4d0bdd10711 --- /dev/null +++ b/include/linux/asn1.h @@ -0,0 +1,65 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* ASN.1 BER/DER/CER encoding definitions + * + * Copyright (C) 2012 Red Hat, Inc. All Rights Reserved. + * Written by David Howells (dhowells@redhat.com) + */ + +#ifndef _LINUX_ASN1_H +#define _LINUX_ASN1_H + +/* Class */ +enum asn1_class { + ASN1_UNIV = 0, /* Universal */ + ASN1_APPL = 1, /* Application */ + ASN1_CONT = 2, /* Context */ + ASN1_PRIV = 3 /* Private */ +}; +#define ASN1_CLASS_BITS 0xc0 + + +enum asn1_method { + ASN1_PRIM = 0, /* Primitive */ + ASN1_CONS = 1 /* Constructed */ +}; +#define ASN1_CONS_BIT 0x20 + +/* Tag */ +enum asn1_tag { + ASN1_EOC = 0, /* End Of Contents or N/A */ + ASN1_BOOL = 1, /* Boolean */ + ASN1_INT = 2, /* Integer */ + ASN1_BTS = 3, /* Bit String */ + ASN1_OTS = 4, /* Octet String */ + ASN1_NULL = 5, /* Null */ + ASN1_OID = 6, /* Object Identifier */ + ASN1_ODE = 7, /* Object Description */ + ASN1_EXT = 8, /* External */ + ASN1_REAL = 9, /* Real float */ + ASN1_ENUM = 10, /* Enumerated */ + ASN1_EPDV = 11, /* Embedded PDV */ + ASN1_UTF8STR = 12, /* UTF8 String */ + ASN1_RELOID = 13, /* Relative OID */ + /* 14 - Reserved */ + /* 15 - Reserved */ + ASN1_SEQ = 16, /* Sequence and Sequence of */ + ASN1_SET = 17, /* Set and Set of */ + ASN1_NUMSTR = 18, /* Numerical String */ + ASN1_PRNSTR = 19, /* Printable String */ + ASN1_TEXSTR = 20, /* T61 String / Teletext String */ + ASN1_VIDSTR = 21, /* Videotex String */ + ASN1_IA5STR = 22, /* IA5 String */ + ASN1_UNITIM = 23, /* Universal Time */ + ASN1_GENTIM = 24, /* General Time */ + ASN1_GRASTR = 25, /* Graphic String */ + ASN1_VISSTR = 26, /* Visible String */ + ASN1_GENSTR = 27, /* General String */ + ASN1_UNISTR = 28, /* Universal String */ + ASN1_CHRSTR = 29, /* Character String */ + ASN1_BMPSTR = 30, /* BMP String */ + ASN1_LONG_TAG = 31 /* Long form tag */ +}; + +#define ASN1_INDEFINITE_LENGTH 0x80 + +#endif /* _LINUX_ASN1_H */ diff --git a/include/linux/asn1_ber_bytecode.h b/include/linux/asn1_ber_bytecode.h new file mode 100644 index 000000000000..b38361953a48 --- /dev/null +++ b/include/linux/asn1_ber_bytecode.h @@ -0,0 +1,89 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* ASN.1 BER/DER/CER parsing state machine internal definitions + * + * Copyright (C) 2012 Red Hat, Inc. All Rights Reserved. + * Written by David Howells (dhowells@redhat.com) + */ + +#ifndef _LINUX_ASN1_BER_BYTECODE_H +#define _LINUX_ASN1_BER_BYTECODE_H + +#ifdef __KERNEL__ +#include <linux/types.h> +#endif +#include <linux/asn1.h> + +typedef int (*asn1_action_t)(void *context, + size_t hdrlen, /* In case of ANY type */ + unsigned char tag, /* In case of ANY type */ + const void *value, size_t vlen); + +struct asn1_decoder { + const unsigned char *machine; + size_t machlen; + const asn1_action_t *actions; +}; + +enum asn1_opcode { + /* The tag-matching ops come first and the odd-numbered slots + * are for OR_SKIP ops. + */ +#define ASN1_OP_MATCH__SKIP 0x01 +#define ASN1_OP_MATCH__ACT 0x02 +#define ASN1_OP_MATCH__JUMP 0x04 +#define ASN1_OP_MATCH__ANY 0x08 +#define ASN1_OP_MATCH__COND 0x10 + + ASN1_OP_MATCH = 0x00, + ASN1_OP_MATCH_OR_SKIP = 0x01, + ASN1_OP_MATCH_ACT = 0x02, + ASN1_OP_MATCH_ACT_OR_SKIP = 0x03, + ASN1_OP_MATCH_JUMP = 0x04, + ASN1_OP_MATCH_JUMP_OR_SKIP = 0x05, + ASN1_OP_MATCH_ANY = 0x08, + ASN1_OP_MATCH_ANY_OR_SKIP = 0x09, + ASN1_OP_MATCH_ANY_ACT = 0x0a, + ASN1_OP_MATCH_ANY_ACT_OR_SKIP = 0x0b, + /* Everything before here matches unconditionally */ + + ASN1_OP_COND_MATCH_OR_SKIP = 0x11, + ASN1_OP_COND_MATCH_ACT_OR_SKIP = 0x13, + ASN1_OP_COND_MATCH_JUMP_OR_SKIP = 0x15, + ASN1_OP_COND_MATCH_ANY = 0x18, + ASN1_OP_COND_MATCH_ANY_OR_SKIP = 0x19, + ASN1_OP_COND_MATCH_ANY_ACT = 0x1a, + ASN1_OP_COND_MATCH_ANY_ACT_OR_SKIP = 0x1b, + + /* Everything before here will want a tag from the data */ +#define ASN1_OP__MATCHES_TAG ASN1_OP_COND_MATCH_ANY_ACT_OR_SKIP + + /* These are here to help fill up space */ + ASN1_OP_COND_FAIL = 0x1c, + ASN1_OP_COMPLETE = 0x1d, + ASN1_OP_ACT = 0x1e, + ASN1_OP_MAYBE_ACT = 0x1f, + + /* The following eight have bit 0 -> SET, 1 -> OF, 2 -> ACT */ + ASN1_OP_END_SEQ = 0x20, + ASN1_OP_END_SET = 0x21, + ASN1_OP_END_SEQ_OF = 0x22, + ASN1_OP_END_SET_OF = 0x23, + ASN1_OP_END_SEQ_ACT = 0x24, + ASN1_OP_END_SET_ACT = 0x25, + ASN1_OP_END_SEQ_OF_ACT = 0x26, + ASN1_OP_END_SET_OF_ACT = 0x27, +#define ASN1_OP_END__SET 0x01 +#define ASN1_OP_END__OF 0x02 +#define ASN1_OP_END__ACT 0x04 + + ASN1_OP_RETURN = 0x28, + + ASN1_OP__NR +}; + +#define _tag(CLASS, CP, TAG) ((ASN1_##CLASS << 6) | (ASN1_##CP << 5) | ASN1_##TAG) +#define _tagn(CLASS, CP, TAG) ((ASN1_##CLASS << 6) | (ASN1_##CP << 5) | TAG) +#define _jump_target(N) (N) +#define _action(N) (N) + +#endif /* _LINUX_ASN1_BER_BYTECODE_H */ diff --git a/include/linux/asn1_decoder.h b/include/linux/asn1_decoder.h new file mode 100644 index 000000000000..83f9c6e1e5e9 --- /dev/null +++ b/include/linux/asn1_decoder.h @@ -0,0 +1,20 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* ASN.1 decoder + * + * Copyright (C) 2012 Red Hat, Inc. All Rights Reserved. + * Written by David Howells (dhowells@redhat.com) + */ + +#ifndef _LINUX_ASN1_DECODER_H +#define _LINUX_ASN1_DECODER_H + +#include <linux/asn1.h> + +struct asn1_decoder; + +extern int asn1_ber_decoder(const struct asn1_decoder *decoder, + void *context, + const unsigned char *data, + size_t datalen); + +#endif /* _LINUX_ASN1_DECODER_H */ diff --git a/lib/Kconfig b/lib/Kconfig index 642dc1ac872e..a76ceb67c03e 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -566,6 +566,9 @@ config SMBIOS_PRODUCT_NAME
endmenu
+config ASN1_COMPILER + bool + source lib/efi/Kconfig source lib/efi_loader/Kconfig source lib/optee/Kconfig diff --git a/scripts/Makefile.build b/scripts/Makefile.build index f7a041296d3d..26eb701f8dea 100644 --- a/scripts/Makefile.build +++ b/scripts/Makefile.build @@ -328,10 +328,10 @@ $(obj)/%.lds: $(src)/%.lds.S FORCE # ASN.1 grammar # --------------------------------------------------------------------------- quiet_cmd_asn1_compiler = ASN.1 $@ - cmd_asn1_compiler = $(objtree)/scripts/asn1_compiler $< \ + cmd_asn1_compiler = $(objtree)/tools/asn1_compiler $< \ $(subst .h,.c,$@) $(subst .c,.h,$@)
-$(obj)/%-asn1.c $(obj)/%-asn1.h: $(src)/%.asn1 $(objtree)/scripts/asn1_compiler +$(obj)/%.asn1.c $(obj)/%.asn1.h: $(src)/%.asn1 $(objtree)/tools/asn1_compiler $(call cmd,asn1_compiler)
# Build the compiled-in targets diff --git a/tools/Makefile b/tools/Makefile index 24581adccd4b..345bc84e48db 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -207,6 +207,9 @@ endif
hostprogs-$(CONFIG_MIPS) += mips-relocs
+hostprogs-$(CONFIG_ASN1_COMPILER) += asn1_compiler +HOSTCFLAGS_asn1_compiler.o = -idirafter $(srctree)/include + # We build some files with extra pedantic flags to try to minimize things # that won't build on some weird host compiler -- though there are lots of # exceptions for files that aren't complaint. diff --git a/tools/asn1_compiler.c b/tools/asn1_compiler.c new file mode 100644 index 000000000000..adabd4145264 --- /dev/null +++ b/tools/asn1_compiler.c @@ -0,0 +1,1611 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* Simplified ASN.1 notation parser + * + * Copyright (C) 2012 Red Hat, Inc. All Rights Reserved. + * Written by David Howells (dhowells@redhat.com) + */ + +#include <stdarg.h> +#include <stdio.h> +#include <stdlib.h> +#include <stdint.h> +#include <stdbool.h> +#include <string.h> +#include <ctype.h> +#include <unistd.h> +#include <fcntl.h> +#include <sys/stat.h> +#include <linux/asn1_ber_bytecode.h> + +enum token_type { + DIRECTIVE_ABSENT, + DIRECTIVE_ALL, + DIRECTIVE_ANY, + DIRECTIVE_APPLICATION, + DIRECTIVE_AUTOMATIC, + DIRECTIVE_BEGIN, + DIRECTIVE_BIT, + DIRECTIVE_BMPString, + DIRECTIVE_BOOLEAN, + DIRECTIVE_BY, + DIRECTIVE_CHARACTER, + DIRECTIVE_CHOICE, + DIRECTIVE_CLASS, + DIRECTIVE_COMPONENT, + DIRECTIVE_COMPONENTS, + DIRECTIVE_CONSTRAINED, + DIRECTIVE_CONTAINING, + DIRECTIVE_DEFAULT, + DIRECTIVE_DEFINED, + DIRECTIVE_DEFINITIONS, + DIRECTIVE_EMBEDDED, + DIRECTIVE_ENCODED, + DIRECTIVE_ENCODING_CONTROL, + DIRECTIVE_END, + DIRECTIVE_ENUMERATED, + DIRECTIVE_EXCEPT, + DIRECTIVE_EXPLICIT, + DIRECTIVE_EXPORTS, + DIRECTIVE_EXTENSIBILITY, + DIRECTIVE_EXTERNAL, + DIRECTIVE_FALSE, + DIRECTIVE_FROM, + DIRECTIVE_GeneralString, + DIRECTIVE_GeneralizedTime, + DIRECTIVE_GraphicString, + DIRECTIVE_IA5String, + DIRECTIVE_IDENTIFIER, + DIRECTIVE_IMPLICIT, + DIRECTIVE_IMPLIED, + DIRECTIVE_IMPORTS, + DIRECTIVE_INCLUDES, + DIRECTIVE_INSTANCE, + DIRECTIVE_INSTRUCTIONS, + DIRECTIVE_INTEGER, + DIRECTIVE_INTERSECTION, + DIRECTIVE_ISO646String, + DIRECTIVE_MAX, + DIRECTIVE_MIN, + DIRECTIVE_MINUS_INFINITY, + DIRECTIVE_NULL, + DIRECTIVE_NumericString, + DIRECTIVE_OBJECT, + DIRECTIVE_OCTET, + DIRECTIVE_OF, + DIRECTIVE_OPTIONAL, + DIRECTIVE_ObjectDescriptor, + DIRECTIVE_PATTERN, + DIRECTIVE_PDV, + DIRECTIVE_PLUS_INFINITY, + DIRECTIVE_PRESENT, + DIRECTIVE_PRIVATE, + DIRECTIVE_PrintableString, + DIRECTIVE_REAL, + DIRECTIVE_RELATIVE_OID, + DIRECTIVE_SEQUENCE, + DIRECTIVE_SET, + DIRECTIVE_SIZE, + DIRECTIVE_STRING, + DIRECTIVE_SYNTAX, + DIRECTIVE_T61String, + DIRECTIVE_TAGS, + DIRECTIVE_TRUE, + DIRECTIVE_TeletexString, + DIRECTIVE_UNION, + DIRECTIVE_UNIQUE, + DIRECTIVE_UNIVERSAL, + DIRECTIVE_UTCTime, + DIRECTIVE_UTF8String, + DIRECTIVE_UniversalString, + DIRECTIVE_VideotexString, + DIRECTIVE_VisibleString, + DIRECTIVE_WITH, + NR__DIRECTIVES, + TOKEN_ASSIGNMENT = NR__DIRECTIVES, + TOKEN_OPEN_CURLY, + TOKEN_CLOSE_CURLY, + TOKEN_OPEN_SQUARE, + TOKEN_CLOSE_SQUARE, + TOKEN_OPEN_ACTION, + TOKEN_CLOSE_ACTION, + TOKEN_COMMA, + TOKEN_NUMBER, + TOKEN_TYPE_NAME, + TOKEN_ELEMENT_NAME, + NR__TOKENS +}; + +static const unsigned char token_to_tag[NR__TOKENS] = { + /* EOC goes first */ + [DIRECTIVE_BOOLEAN] = ASN1_BOOL, + [DIRECTIVE_INTEGER] = ASN1_INT, + [DIRECTIVE_BIT] = ASN1_BTS, + [DIRECTIVE_OCTET] = ASN1_OTS, + [DIRECTIVE_NULL] = ASN1_NULL, + [DIRECTIVE_OBJECT] = ASN1_OID, + [DIRECTIVE_ObjectDescriptor] = ASN1_ODE, + [DIRECTIVE_EXTERNAL] = ASN1_EXT, + [DIRECTIVE_REAL] = ASN1_REAL, + [DIRECTIVE_ENUMERATED] = ASN1_ENUM, + [DIRECTIVE_EMBEDDED] = 0, + [DIRECTIVE_UTF8String] = ASN1_UTF8STR, + [DIRECTIVE_RELATIVE_OID] = ASN1_RELOID, + /* 14 */ + /* 15 */ + [DIRECTIVE_SEQUENCE] = ASN1_SEQ, + [DIRECTIVE_SET] = ASN1_SET, + [DIRECTIVE_NumericString] = ASN1_NUMSTR, + [DIRECTIVE_PrintableString] = ASN1_PRNSTR, + [DIRECTIVE_T61String] = ASN1_TEXSTR, + [DIRECTIVE_TeletexString] = ASN1_TEXSTR, + [DIRECTIVE_VideotexString] = ASN1_VIDSTR, + [DIRECTIVE_IA5String] = ASN1_IA5STR, + [DIRECTIVE_UTCTime] = ASN1_UNITIM, + [DIRECTIVE_GeneralizedTime] = ASN1_GENTIM, + [DIRECTIVE_GraphicString] = ASN1_GRASTR, + [DIRECTIVE_VisibleString] = ASN1_VISSTR, + [DIRECTIVE_GeneralString] = ASN1_GENSTR, + [DIRECTIVE_UniversalString] = ASN1_UNITIM, + [DIRECTIVE_CHARACTER] = ASN1_CHRSTR, + [DIRECTIVE_BMPString] = ASN1_BMPSTR, +}; + +static const char asn1_classes[4][5] = { + [ASN1_UNIV] = "UNIV", + [ASN1_APPL] = "APPL", + [ASN1_CONT] = "CONT", + [ASN1_PRIV] = "PRIV" +}; + +static const char asn1_methods[2][5] = { + [ASN1_UNIV] = "PRIM", + [ASN1_APPL] = "CONS" +}; + +static const char *const asn1_universal_tags[32] = { + "EOC", + "BOOL", + "INT", + "BTS", + "OTS", + "NULL", + "OID", + "ODE", + "EXT", + "REAL", + "ENUM", + "EPDV", + "UTF8STR", + "RELOID", + NULL, /* 14 */ + NULL, /* 15 */ + "SEQ", + "SET", + "NUMSTR", + "PRNSTR", + "TEXSTR", + "VIDSTR", + "IA5STR", + "UNITIM", + "GENTIM", + "GRASTR", + "VISSTR", + "GENSTR", + "UNISTR", + "CHRSTR", + "BMPSTR", + NULL /* 31 */ +}; + +static const char *filename; +static const char *grammar_name; +static const char *outputname; +static const char *headername; + +static const char *const directives[NR__DIRECTIVES] = { +#define _(X) [DIRECTIVE_##X] = #X + _(ABSENT), + _(ALL), + _(ANY), + _(APPLICATION), + _(AUTOMATIC), + _(BEGIN), + _(BIT), + _(BMPString), + _(BOOLEAN), + _(BY), + _(CHARACTER), + _(CHOICE), + _(CLASS), + _(COMPONENT), + _(COMPONENTS), + _(CONSTRAINED), + _(CONTAINING), + _(DEFAULT), + _(DEFINED), + _(DEFINITIONS), + _(EMBEDDED), + _(ENCODED), + [DIRECTIVE_ENCODING_CONTROL] = "ENCODING-CONTROL", + _(END), + _(ENUMERATED), + _(EXCEPT), + _(EXPLICIT), + _(EXPORTS), + _(EXTENSIBILITY), + _(EXTERNAL), + _(FALSE), + _(FROM), + _(GeneralString), + _(GeneralizedTime), + _(GraphicString), + _(IA5String), + _(IDENTIFIER), + _(IMPLICIT), + _(IMPLIED), + _(IMPORTS), + _(INCLUDES), + _(INSTANCE), + _(INSTRUCTIONS), + _(INTEGER), + _(INTERSECTION), + _(ISO646String), + _(MAX), + _(MIN), + [DIRECTIVE_MINUS_INFINITY] = "MINUS-INFINITY", + [DIRECTIVE_NULL] = "NULL", + _(NumericString), + _(OBJECT), + _(OCTET), + _(OF), + _(OPTIONAL), + _(ObjectDescriptor), + _(PATTERN), + _(PDV), + [DIRECTIVE_PLUS_INFINITY] = "PLUS-INFINITY", + _(PRESENT), + _(PRIVATE), + _(PrintableString), + _(REAL), + [DIRECTIVE_RELATIVE_OID] = "RELATIVE-OID", + _(SEQUENCE), + _(SET), + _(SIZE), + _(STRING), + _(SYNTAX), + _(T61String), + _(TAGS), + _(TRUE), + _(TeletexString), + _(UNION), + _(UNIQUE), + _(UNIVERSAL), + _(UTCTime), + _(UTF8String), + _(UniversalString), + _(VideotexString), + _(VisibleString), + _(WITH) +}; + +struct action { + struct action *next; + char *name; + unsigned char index; +}; + +static struct action *action_list; +static unsigned nr_actions; + +struct token { + unsigned short line; + enum token_type token_type : 8; + unsigned char size; + struct action *action; + char *content; + struct type *type; +}; + +static struct token *token_list; +static unsigned nr_tokens; +static bool verbose_opt; +static bool debug_opt; + +#define verbose(fmt, ...) do { if (verbose_opt) printf(fmt, ## __VA_ARGS__); } while (0) +#define debug(fmt, ...) do { if (debug_opt) printf(fmt, ## __VA_ARGS__); } while (0) + +static int directive_compare(const void *_key, const void *_pdir) +{ + const struct token *token = _key; + const char *const *pdir = _pdir, *dir = *pdir; + size_t dlen, clen; + int val; + + dlen = strlen(dir); + clen = (dlen < token->size) ? dlen : token->size; + + //debug("cmp(%s,%s) = ", token->content, dir); + + val = memcmp(token->content, dir, clen); + if (val != 0) { + //debug("%d [cmp]\n", val); + return val; + } + + if (dlen == token->size) { + //debug("0\n"); + return 0; + } + //debug("%d\n", (int)dlen - (int)token->size); + return dlen - token->size; /* shorter -> negative */ +} + +/* + * Tokenise an ASN.1 grammar + */ +static void tokenise(char *buffer, char *end) +{ + struct token *tokens; + char *line, *nl, *start, *p, *q; + unsigned tix, lineno; + + /* Assume we're going to have half as many tokens as we have + * characters + */ + token_list = tokens = calloc((end - buffer) / 2, sizeof(struct token)); + if (!tokens) { + perror(NULL); + exit(1); + } + tix = 0; + + lineno = 0; + while (buffer < end) { + /* First of all, break out a line */ + lineno++; + line = buffer; + nl = memchr(line, '\n', end - buffer); + if (!nl) { + buffer = nl = end; + } else { + buffer = nl + 1; + *nl = '\0'; + } + + /* Remove "--" comments */ + p = line; + next_comment: + while ((p = memchr(p, '-', nl - p))) { + if (p[1] == '-') { + /* Found a comment; see if there's a terminator */ + q = p + 2; + while ((q = memchr(q, '-', nl - q))) { + if (q[1] == '-') { + /* There is - excise the comment */ + q += 2; + memmove(p, q, nl - q); + goto next_comment; + } + q++; + } + *p = '\0'; + nl = p; + break; + } else { + p++; + } + } + + p = line; + while (p < nl) { + /* Skip white space */ + while (p < nl && isspace(*p)) + *(p++) = 0; + if (p >= nl) + break; + + tokens[tix].line = lineno; + start = p; + + /* Handle string tokens */ + if (isalpha(*p)) { + const char **dir; + + /* Can be a directive, type name or element + * name. Find the end of the name. + */ + q = p + 1; + while (q < nl && (isalnum(*q) || *q == '-' || *q == '_')) + q++; + tokens[tix].size = q - p; + p = q; + + tokens[tix].content = malloc(tokens[tix].size + 1); + if (!tokens[tix].content) { + perror(NULL); + exit(1); + } + memcpy(tokens[tix].content, start, tokens[tix].size); + tokens[tix].content[tokens[tix].size] = 0; + + /* If it begins with a lowercase letter then + * it's an element name + */ + if (islower(tokens[tix].content[0])) { + tokens[tix++].token_type = TOKEN_ELEMENT_NAME; + continue; + } + + /* Otherwise we need to search the directive + * table + */ + dir = bsearch(&tokens[tix], directives, + sizeof(directives) / sizeof(directives[1]), + sizeof(directives[1]), + directive_compare); + if (dir) { + tokens[tix++].token_type = dir - directives; + continue; + } + + tokens[tix++].token_type = TOKEN_TYPE_NAME; + continue; + } + + /* Handle numbers */ + if (isdigit(*p)) { + /* Find the end of the number */ + q = p + 1; + while (q < nl && (isdigit(*q))) + q++; + tokens[tix].size = q - p; + p = q; + tokens[tix].content = malloc(tokens[tix].size + 1); + if (!tokens[tix].content) { + perror(NULL); + exit(1); + } + memcpy(tokens[tix].content, start, tokens[tix].size); + tokens[tix].content[tokens[tix].size] = 0; + tokens[tix++].token_type = TOKEN_NUMBER; + continue; + } + + if (nl - p >= 3) { + if (memcmp(p, "::=", 3) == 0) { + p += 3; + tokens[tix].size = 3; + tokens[tix].content = "::="; + tokens[tix++].token_type = TOKEN_ASSIGNMENT; + continue; + } + } + + if (nl - p >= 2) { + if (memcmp(p, "({", 2) == 0) { + p += 2; + tokens[tix].size = 2; + tokens[tix].content = "({"; + tokens[tix++].token_type = TOKEN_OPEN_ACTION; + continue; + } + if (memcmp(p, "})", 2) == 0) { + p += 2; + tokens[tix].size = 2; + tokens[tix].content = "})"; + tokens[tix++].token_type = TOKEN_CLOSE_ACTION; + continue; + } + } + + if (nl - p >= 1) { + tokens[tix].size = 1; + switch (*p) { + case '{': + p += 1; + tokens[tix].content = "{"; + tokens[tix++].token_type = TOKEN_OPEN_CURLY; + continue; + case '}': + p += 1; + tokens[tix].content = "}"; + tokens[tix++].token_type = TOKEN_CLOSE_CURLY; + continue; + case '[': + p += 1; + tokens[tix].content = "["; + tokens[tix++].token_type = TOKEN_OPEN_SQUARE; + continue; + case ']': + p += 1; + tokens[tix].content = "]"; + tokens[tix++].token_type = TOKEN_CLOSE_SQUARE; + continue; + case ',': + p += 1; + tokens[tix].content = ","; + tokens[tix++].token_type = TOKEN_COMMA; + continue; + default: + break; + } + } + + fprintf(stderr, "%s:%u: Unknown character in grammar: '%c'\n", + filename, lineno, *p); + exit(1); + } + } + + nr_tokens = tix; + verbose("Extracted %u tokens\n", nr_tokens); + +#if 0 + { + int n; + for (n = 0; n < nr_tokens; n++) + debug("Token %3u: '%s'\n", n, token_list[n].content); + } +#endif +} + +static void build_type_list(void); +static void parse(void); +static void dump_elements(void); +static void render(FILE *out, FILE *hdr); + +/* + * + */ +int main(int argc, char **argv) +{ + struct stat st; + ssize_t readlen; + FILE *out, *hdr; + char *buffer, *p; + char *kbuild_verbose; + int fd; + + kbuild_verbose = getenv("KBUILD_VERBOSE"); + if (kbuild_verbose) + verbose_opt = atoi(kbuild_verbose); + + while (argc > 4) { + if (strcmp(argv[1], "-v") == 0) + verbose_opt = true; + else if (strcmp(argv[1], "-d") == 0) + debug_opt = true; + else + break; + memmove(&argv[1], &argv[2], (argc - 2) * sizeof(char *)); + argc--; + } + + if (argc != 4) { + fprintf(stderr, "Format: %s [-v] [-d] <grammar-file> <c-file> <hdr-file>\n", + argv[0]); + exit(2); + } + + filename = argv[1]; + outputname = argv[2]; + headername = argv[3]; + + fd = open(filename, O_RDONLY); + if (fd < 0) { + perror(filename); + exit(1); + } + + if (fstat(fd, &st) < 0) { + perror(filename); + exit(1); + } + + if (!(buffer = malloc(st.st_size + 1))) { + perror(NULL); + exit(1); + } + + if ((readlen = read(fd, buffer, st.st_size)) < 0) { + perror(filename); + exit(1); + } + + if (close(fd) < 0) { + perror(filename); + exit(1); + } + + if (readlen != st.st_size) { + fprintf(stderr, "%s: Short read\n", filename); + exit(1); + } + + p = strrchr(argv[1], '/'); + p = p ? p + 1 : argv[1]; + grammar_name = strdup(p); + if (!p) { + perror(NULL); + exit(1); + } + p = strchr(grammar_name, '.'); + if (p) + *p = '\0'; + + buffer[readlen] = 0; + tokenise(buffer, buffer + readlen); + build_type_list(); + parse(); + dump_elements(); + + out = fopen(outputname, "w"); + if (!out) { + perror(outputname); + exit(1); + } + + hdr = fopen(headername, "w"); + if (!hdr) { + perror(headername); + exit(1); + } + + render(out, hdr); + + if (fclose(out) < 0) { + perror(outputname); + exit(1); + } + + if (fclose(hdr) < 0) { + perror(headername); + exit(1); + } + + return 0; +} + +enum compound { + NOT_COMPOUND, + SET, + SET_OF, + SEQUENCE, + SEQUENCE_OF, + CHOICE, + ANY, + TYPE_REF, + TAG_OVERRIDE +}; + +struct element { + struct type *type_def; + struct token *name; + struct token *type; + struct action *action; + struct element *children; + struct element *next; + struct element *render_next; + struct element *list_next; + uint8_t n_elements; + enum compound compound : 8; + enum asn1_class class : 8; + enum asn1_method method : 8; + uint8_t tag; + unsigned entry_index; + unsigned flags; +#define ELEMENT_IMPLICIT 0x0001 +#define ELEMENT_EXPLICIT 0x0002 +#define ELEMENT_TAG_SPECIFIED 0x0004 +#define ELEMENT_RENDERED 0x0008 +#define ELEMENT_SKIPPABLE 0x0010 +#define ELEMENT_CONDITIONAL 0x0020 +}; + +struct type { + struct token *name; + struct token *def; + struct element *element; + unsigned ref_count; + unsigned flags; +#define TYPE_STOP_MARKER 0x0001 +#define TYPE_BEGIN 0x0002 +}; + +static struct type *type_list; +static struct type **type_index; +static unsigned nr_types; + +static int type_index_compare(const void *_a, const void *_b) +{ + const struct type *const *a = _a, *const *b = _b; + + if ((*a)->name->size != (*b)->name->size) + return (*a)->name->size - (*b)->name->size; + else + return memcmp((*a)->name->content, (*b)->name->content, + (*a)->name->size); +} + +static int type_finder(const void *_key, const void *_ti) +{ + const struct token *token = _key; + const struct type *const *ti = _ti; + const struct type *type = *ti; + + if (token->size != type->name->size) + return token->size - type->name->size; + else + return memcmp(token->content, type->name->content, + token->size); +} + +/* + * Build up a list of types and a sorted index to that list. + */ +static void build_type_list(void) +{ + struct type *types; + unsigned nr, t, n; + + nr = 0; + for (n = 0; n < nr_tokens - 1; n++) + if (token_list[n + 0].token_type == TOKEN_TYPE_NAME && + token_list[n + 1].token_type == TOKEN_ASSIGNMENT) + nr++; + + if (nr == 0) { + fprintf(stderr, "%s: No defined types\n", filename); + exit(1); + } + + nr_types = nr; + types = type_list = calloc(nr + 1, sizeof(type_list[0])); + if (!type_list) { + perror(NULL); + exit(1); + } + type_index = calloc(nr, sizeof(type_index[0])); + if (!type_index) { + perror(NULL); + exit(1); + } + + t = 0; + types[t].flags |= TYPE_BEGIN; + for (n = 0; n < nr_tokens - 1; n++) { + if (token_list[n + 0].token_type == TOKEN_TYPE_NAME && + token_list[n + 1].token_type == TOKEN_ASSIGNMENT) { + types[t].name = &token_list[n]; + type_index[t] = &types[t]; + t++; + } + } + types[t].name = &token_list[n + 1]; + types[t].flags |= TYPE_STOP_MARKER; + + qsort(type_index, nr, sizeof(type_index[0]), type_index_compare); + + verbose("Extracted %u types\n", nr_types); +#if 0 + for (n = 0; n < nr_types; n++) { + struct type *type = type_index[n]; + debug("- %*.*s\n", type->name->content); + } +#endif +} + +static struct element *parse_type(struct token **_cursor, struct token *stop, + struct token *name); + +/* + * Parse the token stream + */ +static void parse(void) +{ + struct token *cursor; + struct type *type; + + /* Parse one type definition statement at a time */ + type = type_list; + do { + cursor = type->name; + + if (cursor[0].token_type != TOKEN_TYPE_NAME || + cursor[1].token_type != TOKEN_ASSIGNMENT) + abort(); + cursor += 2; + + type->element = parse_type(&cursor, type[1].name, NULL); + type->element->type_def = type; + + if (cursor != type[1].name) { + fprintf(stderr, "%s:%d: Parse error at token '%s'\n", + filename, cursor->line, cursor->content); + exit(1); + } + + } while (type++, !(type->flags & TYPE_STOP_MARKER)); + + verbose("Extracted %u actions\n", nr_actions); +} + +static struct element *element_list; + +static struct element *alloc_elem(struct token *type) +{ + struct element *e = calloc(1, sizeof(*e)); + if (!e) { + perror(NULL); + exit(1); + } + e->list_next = element_list; + element_list = e; + return e; +} + +static struct element *parse_compound(struct token **_cursor, struct token *end, + int alternates); + +/* + * Parse one type definition statement + */ +static struct element *parse_type(struct token **_cursor, struct token *end, + struct token *name) +{ + struct element *top, *element; + struct action *action, **ppaction; + struct token *cursor = *_cursor; + struct type **ref; + char *p; + int labelled = 0, implicit = 0; + + top = element = alloc_elem(cursor); + element->class = ASN1_UNIV; + element->method = ASN1_PRIM; + element->tag = token_to_tag[cursor->token_type]; + element->name = name; + + /* Extract the tag value if one given */ + if (cursor->token_type == TOKEN_OPEN_SQUARE) { + cursor++; + if (cursor >= end) + goto overrun_error; + switch (cursor->token_type) { + case DIRECTIVE_UNIVERSAL: + element->class = ASN1_UNIV; + cursor++; + break; + case DIRECTIVE_APPLICATION: + element->class = ASN1_APPL; + cursor++; + break; + case TOKEN_NUMBER: + element->class = ASN1_CONT; + break; + case DIRECTIVE_PRIVATE: + element->class = ASN1_PRIV; + cursor++; + break; + default: + fprintf(stderr, "%s:%d: Unrecognised tag class token '%s'\n", + filename, cursor->line, cursor->content); + exit(1); + } + + if (cursor >= end) + goto overrun_error; + if (cursor->token_type != TOKEN_NUMBER) { + fprintf(stderr, "%s:%d: Missing tag number '%s'\n", + filename, cursor->line, cursor->content); + exit(1); + } + + element->tag &= ~0x1f; + element->tag |= strtoul(cursor->content, &p, 10); + element->flags |= ELEMENT_TAG_SPECIFIED; + if (p - cursor->content != cursor->size) + abort(); + cursor++; + + if (cursor >= end) + goto overrun_error; + if (cursor->token_type != TOKEN_CLOSE_SQUARE) { + fprintf(stderr, "%s:%d: Missing closing square bracket '%s'\n", + filename, cursor->line, cursor->content); + exit(1); + } + cursor++; + if (cursor >= end) + goto overrun_error; + labelled = 1; + } + + /* Handle implicit and explicit markers */ + if (cursor->token_type == DIRECTIVE_IMPLICIT) { + element->flags |= ELEMENT_IMPLICIT; + implicit = 1; + cursor++; + if (cursor >= end) + goto overrun_error; + } else if (cursor->token_type == DIRECTIVE_EXPLICIT) { + element->flags |= ELEMENT_EXPLICIT; + cursor++; + if (cursor >= end) + goto overrun_error; + } + + if (labelled) { + if (!implicit) + element->method |= ASN1_CONS; + element->compound = implicit ? TAG_OVERRIDE : SEQUENCE; + element->children = alloc_elem(cursor); + element = element->children; + element->class = ASN1_UNIV; + element->method = ASN1_PRIM; + element->tag = token_to_tag[cursor->token_type]; + element->name = name; + } + + /* Extract the type we're expecting here */ + element->type = cursor; + switch (cursor->token_type) { + case DIRECTIVE_ANY: + element->compound = ANY; + cursor++; + break; + + case DIRECTIVE_NULL: + case DIRECTIVE_BOOLEAN: + case DIRECTIVE_ENUMERATED: + case DIRECTIVE_INTEGER: + element->compound = NOT_COMPOUND; + cursor++; + break; + + case DIRECTIVE_EXTERNAL: + element->method = ASN1_CONS; + + case DIRECTIVE_BMPString: + case DIRECTIVE_GeneralString: + case DIRECTIVE_GraphicString: + case DIRECTIVE_IA5String: + case DIRECTIVE_ISO646String: + case DIRECTIVE_NumericString: + case DIRECTIVE_PrintableString: + case DIRECTIVE_T61String: + case DIRECTIVE_TeletexString: + case DIRECTIVE_UniversalString: + case DIRECTIVE_UTF8String: + case DIRECTIVE_VideotexString: + case DIRECTIVE_VisibleString: + case DIRECTIVE_ObjectDescriptor: + case DIRECTIVE_GeneralizedTime: + case DIRECTIVE_UTCTime: + element->compound = NOT_COMPOUND; + cursor++; + break; + + case DIRECTIVE_BIT: + case DIRECTIVE_OCTET: + element->compound = NOT_COMPOUND; + cursor++; + if (cursor >= end) + goto overrun_error; + if (cursor->token_type != DIRECTIVE_STRING) + goto parse_error; + cursor++; + break; + + case DIRECTIVE_OBJECT: + element->compound = NOT_COMPOUND; + cursor++; + if (cursor >= end) + goto overrun_error; + if (cursor->token_type != DIRECTIVE_IDENTIFIER) + goto parse_error; + cursor++; + break; + + case TOKEN_TYPE_NAME: + element->compound = TYPE_REF; + ref = bsearch(cursor, type_index, nr_types, sizeof(type_index[0]), + type_finder); + if (!ref) { + fprintf(stderr, "%s:%d: Type '%s' undefined\n", + filename, cursor->line, cursor->content); + exit(1); + } + cursor->type = *ref; + (*ref)->ref_count++; + cursor++; + break; + + case DIRECTIVE_CHOICE: + element->compound = CHOICE; + cursor++; + element->children = parse_compound(&cursor, end, 1); + break; + + case DIRECTIVE_SEQUENCE: + element->compound = SEQUENCE; + element->method = ASN1_CONS; + cursor++; + if (cursor >= end) + goto overrun_error; + if (cursor->token_type == DIRECTIVE_OF) { + element->compound = SEQUENCE_OF; + cursor++; + if (cursor >= end) + goto overrun_error; + element->children = parse_type(&cursor, end, NULL); + } else { + element->children = parse_compound(&cursor, end, 0); + } + break; + + case DIRECTIVE_SET: + element->compound = SET; + element->method = ASN1_CONS; + cursor++; + if (cursor >= end) + goto overrun_error; + if (cursor->token_type == DIRECTIVE_OF) { + element->compound = SET_OF; + cursor++; + if (cursor >= end) + goto parse_error; + element->children = parse_type(&cursor, end, NULL); + } else { + element->children = parse_compound(&cursor, end, 1); + } + break; + + default: + fprintf(stderr, "%s:%d: Token '%s' does not introduce a type\n", + filename, cursor->line, cursor->content); + exit(1); + } + + /* Handle elements that are optional */ + if (cursor < end && (cursor->token_type == DIRECTIVE_OPTIONAL || + cursor->token_type == DIRECTIVE_DEFAULT) + ) { + cursor++; + top->flags |= ELEMENT_SKIPPABLE; + } + + if (cursor < end && cursor->token_type == TOKEN_OPEN_ACTION) { + cursor++; + if (cursor >= end) + goto overrun_error; + if (cursor->token_type != TOKEN_ELEMENT_NAME) { + fprintf(stderr, "%s:%d: Token '%s' is not an action function name\n", + filename, cursor->line, cursor->content); + exit(1); + } + + action = malloc(sizeof(struct action)); + if (!action) { + perror(NULL); + exit(1); + } + action->index = 0; + action->name = cursor->content; + + for (ppaction = &action_list; + *ppaction; + ppaction = &(*ppaction)->next + ) { + int cmp = strcmp(action->name, (*ppaction)->name); + if (cmp == 0) { + free(action); + action = *ppaction; + goto found; + } + if (cmp < 0) { + action->next = *ppaction; + *ppaction = action; + nr_actions++; + goto found; + } + } + action->next = NULL; + *ppaction = action; + nr_actions++; + found: + + element->action = action; + cursor->action = action; + cursor++; + if (cursor >= end) + goto overrun_error; + if (cursor->token_type != TOKEN_CLOSE_ACTION) { + fprintf(stderr, "%s:%d: Missing close action, got '%s'\n", + filename, cursor->line, cursor->content); + exit(1); + } + cursor++; + } + + *_cursor = cursor; + return top; + +parse_error: + fprintf(stderr, "%s:%d: Unexpected token '%s'\n", + filename, cursor->line, cursor->content); + exit(1); + +overrun_error: + fprintf(stderr, "%s: Unexpectedly hit EOF\n", filename); + exit(1); +} + +/* + * Parse a compound type list + */ +static struct element *parse_compound(struct token **_cursor, struct token *end, + int alternates) +{ + struct element *children, **child_p = &children, *element; + struct token *cursor = *_cursor, *name; + + if (cursor->token_type != TOKEN_OPEN_CURLY) { + fprintf(stderr, "%s:%d: Expected compound to start with brace not '%s'\n", + filename, cursor->line, cursor->content); + exit(1); + } + cursor++; + if (cursor >= end) + goto overrun_error; + + if (cursor->token_type == TOKEN_OPEN_CURLY) { + fprintf(stderr, "%s:%d: Empty compound\n", + filename, cursor->line); + exit(1); + } + + for (;;) { + name = NULL; + if (cursor->token_type == TOKEN_ELEMENT_NAME) { + name = cursor; + cursor++; + if (cursor >= end) + goto overrun_error; + } + + element = parse_type(&cursor, end, name); + if (alternates) + element->flags |= ELEMENT_SKIPPABLE | ELEMENT_CONDITIONAL; + + *child_p = element; + child_p = &element->next; + + if (cursor >= end) + goto overrun_error; + if (cursor->token_type != TOKEN_COMMA) + break; + cursor++; + if (cursor >= end) + goto overrun_error; + } + + children->flags &= ~ELEMENT_CONDITIONAL; + + if (cursor->token_type != TOKEN_CLOSE_CURLY) { + fprintf(stderr, "%s:%d: Expected compound closure, got '%s'\n", + filename, cursor->line, cursor->content); + exit(1); + } + cursor++; + + *_cursor = cursor; + return children; + +overrun_error: + fprintf(stderr, "%s: Unexpectedly hit EOF\n", filename); + exit(1); +} + +static void dump_element(const struct element *e, int level) +{ + const struct element *c; + const struct type *t = e->type_def; + const char *name = e->name ? e->name->content : "."; + const char *tname = t && t->name ? t->name->content : "."; + char tag[32]; + + if (e->class == 0 && e->method == 0 && e->tag == 0) + strcpy(tag, "<...>"); + else if (e->class == ASN1_UNIV) + sprintf(tag, "%s %s %s", + asn1_classes[e->class], + asn1_methods[e->method], + asn1_universal_tags[e->tag]); + else + sprintf(tag, "%s %s %u", + asn1_classes[e->class], + asn1_methods[e->method], + e->tag); + + printf("%c%c%c%c%c %c %*s[*] \e[33m%s\e[m %s %s \e[35m%s\e[m\n", + e->flags & ELEMENT_IMPLICIT ? 'I' : '-', + e->flags & ELEMENT_EXPLICIT ? 'E' : '-', + e->flags & ELEMENT_TAG_SPECIFIED ? 'T' : '-', + e->flags & ELEMENT_SKIPPABLE ? 'S' : '-', + e->flags & ELEMENT_CONDITIONAL ? 'C' : '-', + "-tTqQcaro"[e->compound], + level, "", + tag, + tname, + name, + e->action ? e->action->name : ""); + if (e->compound == TYPE_REF) + dump_element(e->type->type->element, level + 3); + else + for (c = e->children; c; c = c->next) + dump_element(c, level + 3); +} + +static void dump_elements(void) +{ + if (debug_opt) + dump_element(type_list[0].element, 0); +} + +static void render_element(FILE *out, struct element *e, struct element *tag); +static void render_out_of_line_list(FILE *out); + +static int nr_entries; +static int render_depth = 1; +static struct element *render_list, **render_list_p = &render_list; + +__attribute__((format(printf, 2, 3))) +static void render_opcode(FILE *out, const char *fmt, ...) +{ + va_list va; + + if (out) { + fprintf(out, "\t[%4d] =%*s", nr_entries, render_depth, ""); + va_start(va, fmt); + vfprintf(out, fmt, va); + va_end(va); + } + nr_entries++; +} + +__attribute__((format(printf, 2, 3))) +static void render_more(FILE *out, const char *fmt, ...) +{ + va_list va; + + if (out) { + va_start(va, fmt); + vfprintf(out, fmt, va); + va_end(va); + } +} + +/* + * Render the grammar into a state machine definition. + */ +static void render(FILE *out, FILE *hdr) +{ + struct element *e; + struct action *action; + struct type *root; + int index; + + fprintf(hdr, "/*\n"); + fprintf(hdr, " * Automatically generated by asn1_compiler. Do not edit\n"); + fprintf(hdr, " *\n"); + fprintf(hdr, " * ASN.1 parser for %s\n", grammar_name); + fprintf(hdr, " */\n"); + fprintf(hdr, "#include <linux/asn1_decoder.h>\n"); + fprintf(hdr, "\n"); + fprintf(hdr, "extern const struct asn1_decoder %s_decoder;\n", grammar_name); + if (ferror(hdr)) { + perror(headername); + exit(1); + } + + fprintf(out, "/*\n"); + fprintf(out, " * Automatically generated by asn1_compiler. Do not edit\n"); + fprintf(out, " *\n"); + fprintf(out, " * ASN.1 parser for %s\n", grammar_name); + fprintf(out, " */\n"); + fprintf(out, "#include <linux/asn1_ber_bytecode.h>\n"); + fprintf(out, "#include "%s.asn1.h"\n", grammar_name); + fprintf(out, "\n"); + if (ferror(out)) { + perror(outputname); + exit(1); + } + + /* Tabulate the action functions we might have to call */ + fprintf(hdr, "\n"); + index = 0; + for (action = action_list; action; action = action->next) { + action->index = index++; + fprintf(hdr, + "extern int %s(void *, size_t, unsigned char," + " const void *, size_t);\n", + action->name); + } + fprintf(hdr, "\n"); + + fprintf(out, "enum %s_actions {\n", grammar_name); + for (action = action_list; action; action = action->next) + fprintf(out, "\tACT_%s = %u,\n", + action->name, action->index); + fprintf(out, "\tNR__%s_actions = %u\n", grammar_name, nr_actions); + fprintf(out, "};\n"); + + fprintf(out, "\n"); + fprintf(out, "static const asn1_action_t %s_action_table[NR__%s_actions] = {\n", + grammar_name, grammar_name); + for (action = action_list; action; action = action->next) + fprintf(out, "\t[%4u] = %s,\n", action->index, action->name); + fprintf(out, "};\n"); + + if (ferror(out)) { + perror(outputname); + exit(1); + } + + /* We do two passes - the first one calculates all the offsets */ + verbose("Pass 1\n"); + nr_entries = 0; + root = &type_list[0]; + render_element(NULL, root->element, NULL); + render_opcode(NULL, "ASN1_OP_COMPLETE,\n"); + render_out_of_line_list(NULL); + + for (e = element_list; e; e = e->list_next) + e->flags &= ~ELEMENT_RENDERED; + + /* And then we actually render */ + verbose("Pass 2\n"); + fprintf(out, "\n"); + fprintf(out, "static const unsigned char %s_machine[] = {\n", + grammar_name); + + nr_entries = 0; + root = &type_list[0]; + render_element(out, root->element, NULL); + render_opcode(out, "ASN1_OP_COMPLETE,\n"); + render_out_of_line_list(out); + + fprintf(out, "};\n"); + + fprintf(out, "\n"); + fprintf(out, "const struct asn1_decoder %s_decoder = {\n", grammar_name); + fprintf(out, "\t.machine = %s_machine,\n", grammar_name); + fprintf(out, "\t.machlen = sizeof(%s_machine),\n", grammar_name); + fprintf(out, "\t.actions = %s_action_table,\n", grammar_name); + fprintf(out, "};\n"); +} + +/* + * Render the out-of-line elements + */ +static void render_out_of_line_list(FILE *out) +{ + struct element *e, *ce; + const char *act; + int entry; + + while ((e = render_list)) { + render_list = e->render_next; + if (!render_list) + render_list_p = &render_list; + + render_more(out, "\n"); + e->entry_index = entry = nr_entries; + render_depth++; + for (ce = e->children; ce; ce = ce->next) + render_element(out, ce, NULL); + render_depth--; + + act = e->action ? "_ACT" : ""; + switch (e->compound) { + case SEQUENCE: + render_opcode(out, "ASN1_OP_END_SEQ%s,\n", act); + break; + case SEQUENCE_OF: + render_opcode(out, "ASN1_OP_END_SEQ_OF%s,\n", act); + render_opcode(out, "_jump_target(%u),\n", entry); + break; + case SET: + render_opcode(out, "ASN1_OP_END_SET%s,\n", act); + break; + case SET_OF: + render_opcode(out, "ASN1_OP_END_SET_OF%s,\n", act); + render_opcode(out, "_jump_target(%u),\n", entry); + break; + default: + break; + } + if (e->action) + render_opcode(out, "_action(ACT_%s),\n", + e->action->name); + render_opcode(out, "ASN1_OP_RETURN,\n"); + } +} + +/* + * Render an element. + */ +static void render_element(FILE *out, struct element *e, struct element *tag) +{ + struct element *ec, *x; + const char *cond, *act; + int entry, skippable = 0, outofline = 0; + + if (e->flags & ELEMENT_SKIPPABLE || + (tag && tag->flags & ELEMENT_SKIPPABLE)) + skippable = 1; + + if ((e->type_def && e->type_def->ref_count > 1) || + skippable) + outofline = 1; + + if (e->type_def && out) { + render_more(out, "\t// %s\n", e->type_def->name->content); + } + + /* Render the operation */ + cond = (e->flags & ELEMENT_CONDITIONAL || + (tag && tag->flags & ELEMENT_CONDITIONAL)) ? "COND_" : ""; + act = e->action ? "_ACT" : ""; + switch (e->compound) { + case ANY: + render_opcode(out, "ASN1_OP_%sMATCH_ANY%s%s,", + cond, act, skippable ? "_OR_SKIP" : ""); + if (e->name) + render_more(out, "\t\t// %s", e->name->content); + render_more(out, "\n"); + goto dont_render_tag; + + case TAG_OVERRIDE: + render_element(out, e->children, e); + return; + + case SEQUENCE: + case SEQUENCE_OF: + case SET: + case SET_OF: + render_opcode(out, "ASN1_OP_%sMATCH%s%s,", + cond, + outofline ? "_JUMP" : "", + skippable ? "_OR_SKIP" : ""); + break; + + case CHOICE: + goto dont_render_tag; + + case TYPE_REF: + if (e->class == ASN1_UNIV && e->method == ASN1_PRIM && e->tag == 0) + goto dont_render_tag; + default: + render_opcode(out, "ASN1_OP_%sMATCH%s%s,", + cond, act, + skippable ? "_OR_SKIP" : ""); + break; + } + + x = tag ?: e; + if (x->name) + render_more(out, "\t\t// %s", x->name->content); + render_more(out, "\n"); + + /* Render the tag */ + if (!tag || !(tag->flags & ELEMENT_TAG_SPECIFIED)) + tag = e; + + if (tag->class == ASN1_UNIV && + tag->tag != 14 && + tag->tag != 15 && + tag->tag != 31) + render_opcode(out, "_tag(%s, %s, %s),\n", + asn1_classes[tag->class], + asn1_methods[tag->method | e->method], + asn1_universal_tags[tag->tag]); + else + render_opcode(out, "_tagn(%s, %s, %2u),\n", + asn1_classes[tag->class], + asn1_methods[tag->method | e->method], + tag->tag); + tag = NULL; +dont_render_tag: + + /* Deal with compound types */ + switch (e->compound) { + case TYPE_REF: + render_element(out, e->type->type->element, tag); + if (e->action) + render_opcode(out, "ASN1_OP_%sACT,\n", + skippable ? "MAYBE_" : ""); + break; + + case SEQUENCE: + if (outofline) { + /* Render out-of-line for multiple use or + * skipability */ + render_opcode(out, "_jump_target(%u),", e->entry_index); + if (e->type_def && e->type_def->name) + render_more(out, "\t\t// --> %s", + e->type_def->name->content); + render_more(out, "\n"); + if (!(e->flags & ELEMENT_RENDERED)) { + e->flags |= ELEMENT_RENDERED; + *render_list_p = e; + render_list_p = &e->render_next; + } + return; + } else { + /* Render inline for single use */ + render_depth++; + for (ec = e->children; ec; ec = ec->next) + render_element(out, ec, NULL); + render_depth--; + render_opcode(out, "ASN1_OP_END_SEQ%s,\n", act); + } + break; + + case SEQUENCE_OF: + case SET_OF: + if (outofline) { + /* Render out-of-line for multiple use or + * skipability */ + render_opcode(out, "_jump_target(%u),", e->entry_index); + if (e->type_def && e->type_def->name) + render_more(out, "\t\t// --> %s", + e->type_def->name->content); + render_more(out, "\n"); + if (!(e->flags & ELEMENT_RENDERED)) { + e->flags |= ELEMENT_RENDERED; + *render_list_p = e; + render_list_p = &e->render_next; + } + return; + } else { + /* Render inline for single use */ + entry = nr_entries; + render_depth++; + render_element(out, e->children, NULL); + render_depth--; + if (e->compound == SEQUENCE_OF) + render_opcode(out, "ASN1_OP_END_SEQ_OF%s,\n", act); + else + render_opcode(out, "ASN1_OP_END_SET_OF%s,\n", act); + render_opcode(out, "_jump_target(%u),\n", entry); + } + break; + + case SET: + /* I can't think of a nice way to do SET support without having + * a stack of bitmasks to make sure no element is repeated. + * The bitmask has also to be checked that no non-optional + * elements are left out whilst not preventing optional + * elements from being left out. + */ + fprintf(stderr, "The ASN.1 SET type is not currently supported.\n"); + exit(1); + + case CHOICE: + for (ec = e->children; ec; ec = ec->next) + render_element(out, ec, ec); + if (!skippable) + render_opcode(out, "ASN1_OP_COND_FAIL,\n"); + if (e->action) + render_opcode(out, "ASN1_OP_ACT,\n"); + break; + + default: + break; + } + + if (e->action) + render_opcode(out, "_action(ACT_%s),\n", e->action->name); +}
This rule will be used to build x509 and pkcs7 parsers.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- Makefile | 1 + scripts/Makefile.build | 4 +++- 2 files changed, 4 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index 3000d30be23c..3fb3ce51be82 100644 --- a/Makefile +++ b/Makefile @@ -1921,6 +1921,7 @@ clean: $(clean-dirs) -o -name '*.ko.*' -o -name '*.su' -o -name '*.pyc' \ -o -name '.*.d' -o -name '.*.tmp' -o -name '*.mod.c' \ -o -name '*.lex.c' -o -name '*.tab.[ch]' \ + -o -name '*.asn1.[ch]' \ -o -name '*.symtypes' -o -name 'modules.order' \ -o -name modules.builtin -o -name '.tmp_*.o.*' \ -o -name 'dsdt.aml' -o -name 'dsdt.asl.tmp' -o -name 'dsdt.c' \ diff --git a/scripts/Makefile.build b/scripts/Makefile.build index 26eb701f8dea..6d59ea91fac3 100644 --- a/scripts/Makefile.build +++ b/scripts/Makefile.build @@ -419,9 +419,11 @@ targets += $(multi-used-y) $(multi-used-m) intermediate_targets = $(foreach sfx, $(2), \ $(patsubst %$(strip $(1)),%$(sfx), \ $(filter %$(strip $(1)), $(targets)))) +# %.asn1.o <- %.asn1.[ch] <- %.asn1 # %.lex.o <- %.lex.c <- %.l # %.tab.o <- %.tab.[ch] <- %.y -targets += $(call intermediate_targets, .lex.o, .lex.c) \ +targets += $(call intermediate_targets, .asn1.o, .asn1.c .asn1.h) \ + $(call intermediate_targets, .lex.o, .lex.c) \ $(call intermediate_targets, .tab.o, .tab.c .tab.h)
# Descending
Imported from linux kernel v5.3: lib/asn1_decoder.c with changes marked as __UBOOT__
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- lib/Kconfig | 5 + lib/Makefile | 1 + lib/asn1_decoder.c | 527 +++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 533 insertions(+) create mode 100644 lib/asn1_decoder.c
diff --git a/lib/Kconfig b/lib/Kconfig index a76ceb67c03e..66ac598ed759 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -569,6 +569,11 @@ endmenu config ASN1_COMPILER bool
+config ASN1_DECODER + bool + help + Enable asn1 decoder library. + source lib/efi/Kconfig source lib/efi_loader/Kconfig source lib/optee/Kconfig diff --git a/lib/Makefile b/lib/Makefile index 8d0b9d9513f0..6e019fd0581d 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -17,6 +17,7 @@ obj-$(CONFIG_OF_LIVE) += of_live.o obj-$(CONFIG_CMD_DHRYSTONE) += dhry/ obj-$(CONFIG_ARCH_AT91) += at91/ obj-$(CONFIG_OPTEE) += optee/ +obj-$(CONFIG_ASN1_DECODER) += asn1_decoder.o
obj-$(CONFIG_AES) += aes.o
diff --git a/lib/asn1_decoder.c b/lib/asn1_decoder.c new file mode 100644 index 000000000000..db222625dd0f --- /dev/null +++ b/lib/asn1_decoder.c @@ -0,0 +1,527 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* Decoder for ASN.1 BER/DER/CER encoded bytestream + * + * Copyright (C) 2012 Red Hat, Inc. All Rights Reserved. + * Written by David Howells (dhowells@redhat.com) + */ + +#ifdef __UBOOT__ +#include <linux/compat.h> +#else +#include <linux/export.h> +#endif +#include <linux/kernel.h> +#include <linux/errno.h> +#ifndef __UBOOT__ +#include <linux/module.h> +#endif +#include <linux/asn1_decoder.h> +#include <linux/asn1_ber_bytecode.h> + +static const unsigned char asn1_op_lengths[ASN1_OP__NR] = { + /* OPC TAG JMP ACT */ + [ASN1_OP_MATCH] = 1 + 1, + [ASN1_OP_MATCH_OR_SKIP] = 1 + 1, + [ASN1_OP_MATCH_ACT] = 1 + 1 + 1, + [ASN1_OP_MATCH_ACT_OR_SKIP] = 1 + 1 + 1, + [ASN1_OP_MATCH_JUMP] = 1 + 1 + 1, + [ASN1_OP_MATCH_JUMP_OR_SKIP] = 1 + 1 + 1, + [ASN1_OP_MATCH_ANY] = 1, + [ASN1_OP_MATCH_ANY_OR_SKIP] = 1, + [ASN1_OP_MATCH_ANY_ACT] = 1 + 1, + [ASN1_OP_MATCH_ANY_ACT_OR_SKIP] = 1 + 1, + [ASN1_OP_COND_MATCH_OR_SKIP] = 1 + 1, + [ASN1_OP_COND_MATCH_ACT_OR_SKIP] = 1 + 1 + 1, + [ASN1_OP_COND_MATCH_JUMP_OR_SKIP] = 1 + 1 + 1, + [ASN1_OP_COND_MATCH_ANY] = 1, + [ASN1_OP_COND_MATCH_ANY_OR_SKIP] = 1, + [ASN1_OP_COND_MATCH_ANY_ACT] = 1 + 1, + [ASN1_OP_COND_MATCH_ANY_ACT_OR_SKIP] = 1 + 1, + [ASN1_OP_COND_FAIL] = 1, + [ASN1_OP_COMPLETE] = 1, + [ASN1_OP_ACT] = 1 + 1, + [ASN1_OP_MAYBE_ACT] = 1 + 1, + [ASN1_OP_RETURN] = 1, + [ASN1_OP_END_SEQ] = 1, + [ASN1_OP_END_SEQ_OF] = 1 + 1, + [ASN1_OP_END_SET] = 1, + [ASN1_OP_END_SET_OF] = 1 + 1, + [ASN1_OP_END_SEQ_ACT] = 1 + 1, + [ASN1_OP_END_SEQ_OF_ACT] = 1 + 1 + 1, + [ASN1_OP_END_SET_ACT] = 1 + 1, + [ASN1_OP_END_SET_OF_ACT] = 1 + 1 + 1, +}; + +/* + * Find the length of an indefinite length object + * @data: The data buffer + * @datalen: The end of the innermost containing element in the buffer + * @_dp: The data parse cursor (updated before returning) + * @_len: Where to return the size of the element. + * @_errmsg: Where to return a pointer to an error message on error + */ +static int asn1_find_indefinite_length(const unsigned char *data, size_t datalen, + size_t *_dp, size_t *_len, + const char **_errmsg) +{ + unsigned char tag, tmp; + size_t dp = *_dp, len, n; + int indef_level = 1; + +next_tag: + if (unlikely(datalen - dp < 2)) { + if (datalen == dp) + goto missing_eoc; + goto data_overrun_error; + } + + /* Extract a tag from the data */ + tag = data[dp++]; + if (tag == ASN1_EOC) { + /* It appears to be an EOC. */ + if (data[dp++] != 0) + goto invalid_eoc; + if (--indef_level <= 0) { + *_len = dp - *_dp; + *_dp = dp; + return 0; + } + goto next_tag; + } + + if (unlikely((tag & 0x1f) == ASN1_LONG_TAG)) { + do { + if (unlikely(datalen - dp < 2)) + goto data_overrun_error; + tmp = data[dp++]; + } while (tmp & 0x80); + } + + /* Extract the length */ + len = data[dp++]; + if (len <= 0x7f) + goto check_length; + + if (unlikely(len == ASN1_INDEFINITE_LENGTH)) { + /* Indefinite length */ + if (unlikely((tag & ASN1_CONS_BIT) == ASN1_PRIM << 5)) + goto indefinite_len_primitive; + indef_level++; + goto next_tag; + } + + n = len - 0x80; + if (unlikely(n > sizeof(len) - 1)) + goto length_too_long; + if (unlikely(n > datalen - dp)) + goto data_overrun_error; + len = 0; + for (; n > 0; n--) { + len <<= 8; + len |= data[dp++]; + } +check_length: + if (len > datalen - dp) + goto data_overrun_error; + dp += len; + goto next_tag; + +length_too_long: + *_errmsg = "Unsupported length"; + goto error; +indefinite_len_primitive: + *_errmsg = "Indefinite len primitive not permitted"; + goto error; +invalid_eoc: + *_errmsg = "Invalid length EOC"; + goto error; +data_overrun_error: + *_errmsg = "Data overrun error"; + goto error; +missing_eoc: + *_errmsg = "Missing EOC in indefinite len cons"; +error: + *_dp = dp; + return -1; +} + +/** + * asn1_ber_decoder - Decoder BER/DER/CER ASN.1 according to pattern + * @decoder: The decoder definition (produced by asn1_compiler) + * @context: The caller's context (to be passed to the action functions) + * @data: The encoded data + * @datalen: The size of the encoded data + * + * Decode BER/DER/CER encoded ASN.1 data according to a bytecode pattern + * produced by asn1_compiler. Action functions are called on marked tags to + * allow the caller to retrieve significant data. + * + * LIMITATIONS: + * + * To keep down the amount of stack used by this function, the following limits + * have been imposed: + * + * (1) This won't handle datalen > 65535 without increasing the size of the + * cons stack elements and length_too_long checking. + * + * (2) The stack of constructed types is 10 deep. If the depth of non-leaf + * constructed types exceeds this, the decode will fail. + * + * (3) The SET type (not the SET OF type) isn't really supported as tracking + * what members of the set have been seen is a pain. + */ +int asn1_ber_decoder(const struct asn1_decoder *decoder, + void *context, + const unsigned char *data, + size_t datalen) +{ + const unsigned char *machine = decoder->machine; + const asn1_action_t *actions = decoder->actions; + size_t machlen = decoder->machlen; + enum asn1_opcode op; + unsigned char tag = 0, csp = 0, jsp = 0, optag = 0, hdr = 0; + const char *errmsg; + size_t pc = 0, dp = 0, tdp = 0, len = 0; + int ret; + + unsigned char flags = 0; +#define FLAG_INDEFINITE_LENGTH 0x01 +#define FLAG_MATCHED 0x02 +#define FLAG_LAST_MATCHED 0x04 /* Last tag matched */ +#define FLAG_CONS 0x20 /* Corresponds to CONS bit in the opcode tag + * - ie. whether or not we are going to parse + * a compound type. + */ + +#define NR_CONS_STACK 10 + unsigned short cons_dp_stack[NR_CONS_STACK]; + unsigned short cons_datalen_stack[NR_CONS_STACK]; + unsigned char cons_hdrlen_stack[NR_CONS_STACK]; +#define NR_JUMP_STACK 10 + unsigned char jump_stack[NR_JUMP_STACK]; + + if (datalen > 65535) + return -EMSGSIZE; + +next_op: + pr_debug("next_op: pc=\e[32m%zu\e[m/%zu dp=\e[33m%zu\e[m/%zu C=%d J=%d\n", + pc, machlen, dp, datalen, csp, jsp); + if (unlikely(pc >= machlen)) + goto machine_overrun_error; + op = machine[pc]; + if (unlikely(pc + asn1_op_lengths[op] > machlen)) + goto machine_overrun_error; + + /* If this command is meant to match a tag, then do that before + * evaluating the command. + */ + if (op <= ASN1_OP__MATCHES_TAG) { + unsigned char tmp; + + /* Skip conditional matches if possible */ + if ((op & ASN1_OP_MATCH__COND && flags & FLAG_MATCHED) || + (op & ASN1_OP_MATCH__SKIP && dp == datalen)) { + flags &= ~FLAG_LAST_MATCHED; + pc += asn1_op_lengths[op]; + goto next_op; + } + + flags = 0; + hdr = 2; + + /* Extract a tag from the data */ + if (unlikely(datalen - dp < 2)) + goto data_overrun_error; + tag = data[dp++]; + if (unlikely((tag & 0x1f) == ASN1_LONG_TAG)) + goto long_tag_not_supported; + + if (op & ASN1_OP_MATCH__ANY) { + pr_debug("- any %02x\n", tag); + } else { + /* Extract the tag from the machine + * - Either CONS or PRIM are permitted in the data if + * CONS is not set in the op stream, otherwise CONS + * is mandatory. + */ + optag = machine[pc + 1]; + flags |= optag & FLAG_CONS; + + /* Determine whether the tag matched */ + tmp = optag ^ tag; + tmp &= ~(optag & ASN1_CONS_BIT); + pr_debug("- match? %02x %02x %02x\n", tag, optag, tmp); + if (tmp != 0) { + /* All odd-numbered tags are MATCH_OR_SKIP. */ + if (op & ASN1_OP_MATCH__SKIP) { + pc += asn1_op_lengths[op]; + dp--; + goto next_op; + } + goto tag_mismatch; + } + } + flags |= FLAG_MATCHED; + + len = data[dp++]; + if (len > 0x7f) { + if (unlikely(len == ASN1_INDEFINITE_LENGTH)) { + /* Indefinite length */ + if (unlikely(!(tag & ASN1_CONS_BIT))) + goto indefinite_len_primitive; + flags |= FLAG_INDEFINITE_LENGTH; + if (unlikely(2 > datalen - dp)) + goto data_overrun_error; + } else { + int n = len - 0x80; + if (unlikely(n > 2)) + goto length_too_long; + if (unlikely(n > datalen - dp)) + goto data_overrun_error; + hdr += n; + for (len = 0; n > 0; n--) { + len <<= 8; + len |= data[dp++]; + } + if (unlikely(len > datalen - dp)) + goto data_overrun_error; + } + } else { + if (unlikely(len > datalen - dp)) + goto data_overrun_error; + } + + if (flags & FLAG_CONS) { + /* For expected compound forms, we stack the positions + * of the start and end of the data. + */ + if (unlikely(csp >= NR_CONS_STACK)) + goto cons_stack_overflow; + cons_dp_stack[csp] = dp; + cons_hdrlen_stack[csp] = hdr; + if (!(flags & FLAG_INDEFINITE_LENGTH)) { + cons_datalen_stack[csp] = datalen; + datalen = dp + len; + } else { + cons_datalen_stack[csp] = 0; + } + csp++; + } + + pr_debug("- TAG: %02x %zu%s\n", + tag, len, flags & FLAG_CONS ? " CONS" : ""); + tdp = dp; + } + + /* Decide how to handle the operation */ + switch (op) { + case ASN1_OP_MATCH: + case ASN1_OP_MATCH_OR_SKIP: + case ASN1_OP_MATCH_ACT: + case ASN1_OP_MATCH_ACT_OR_SKIP: + case ASN1_OP_MATCH_ANY: + case ASN1_OP_MATCH_ANY_OR_SKIP: + case ASN1_OP_MATCH_ANY_ACT: + case ASN1_OP_MATCH_ANY_ACT_OR_SKIP: + case ASN1_OP_COND_MATCH_OR_SKIP: + case ASN1_OP_COND_MATCH_ACT_OR_SKIP: + case ASN1_OP_COND_MATCH_ANY: + case ASN1_OP_COND_MATCH_ANY_OR_SKIP: + case ASN1_OP_COND_MATCH_ANY_ACT: + case ASN1_OP_COND_MATCH_ANY_ACT_OR_SKIP: + + if (!(flags & FLAG_CONS)) { + if (flags & FLAG_INDEFINITE_LENGTH) { + size_t tmp = dp; + + ret = asn1_find_indefinite_length( + data, datalen, &tmp, &len, &errmsg); + if (ret < 0) + goto error; + } + pr_debug("- LEAF: %zu\n", len); + } + + if (op & ASN1_OP_MATCH__ACT) { + unsigned char act; + + if (op & ASN1_OP_MATCH__ANY) + act = machine[pc + 1]; + else + act = machine[pc + 2]; + ret = actions[act](context, hdr, tag, data + dp, len); + if (ret < 0) + return ret; + } + + if (!(flags & FLAG_CONS)) + dp += len; + pc += asn1_op_lengths[op]; + goto next_op; + + case ASN1_OP_MATCH_JUMP: + case ASN1_OP_MATCH_JUMP_OR_SKIP: + case ASN1_OP_COND_MATCH_JUMP_OR_SKIP: + pr_debug("- MATCH_JUMP\n"); + if (unlikely(jsp == NR_JUMP_STACK)) + goto jump_stack_overflow; + jump_stack[jsp++] = pc + asn1_op_lengths[op]; + pc = machine[pc + 2]; + goto next_op; + + case ASN1_OP_COND_FAIL: + if (unlikely(!(flags & FLAG_MATCHED))) + goto tag_mismatch; + pc += asn1_op_lengths[op]; + goto next_op; + + case ASN1_OP_COMPLETE: + if (unlikely(jsp != 0 || csp != 0)) { + pr_err("ASN.1 decoder error: Stacks not empty at completion (%u, %u)\n", + jsp, csp); + return -EBADMSG; + } + return 0; + + case ASN1_OP_END_SET: + case ASN1_OP_END_SET_ACT: + if (unlikely(!(flags & FLAG_MATCHED))) + goto tag_mismatch; + /* fall through */ + + case ASN1_OP_END_SEQ: + case ASN1_OP_END_SET_OF: + case ASN1_OP_END_SEQ_OF: + case ASN1_OP_END_SEQ_ACT: + case ASN1_OP_END_SET_OF_ACT: + case ASN1_OP_END_SEQ_OF_ACT: + if (unlikely(csp <= 0)) + goto cons_stack_underflow; + csp--; + tdp = cons_dp_stack[csp]; + hdr = cons_hdrlen_stack[csp]; + len = datalen; + datalen = cons_datalen_stack[csp]; + pr_debug("- end cons t=%zu dp=%zu l=%zu/%zu\n", + tdp, dp, len, datalen); + if (datalen == 0) { + /* Indefinite length - check for the EOC. */ + datalen = len; + if (unlikely(datalen - dp < 2)) + goto data_overrun_error; + if (data[dp++] != 0) { + if (op & ASN1_OP_END__OF) { + dp--; + csp++; + pc = machine[pc + 1]; + pr_debug("- continue\n"); + goto next_op; + } + goto missing_eoc; + } + if (data[dp++] != 0) + goto invalid_eoc; + len = dp - tdp - 2; + } else { + if (dp < len && (op & ASN1_OP_END__OF)) { + datalen = len; + csp++; + pc = machine[pc + 1]; + pr_debug("- continue\n"); + goto next_op; + } + if (dp != len) + goto cons_length_error; + len -= tdp; + pr_debug("- cons len l=%zu d=%zu\n", len, dp - tdp); + } + + if (op & ASN1_OP_END__ACT) { + unsigned char act; + if (op & ASN1_OP_END__OF) + act = machine[pc + 2]; + else + act = machine[pc + 1]; + ret = actions[act](context, hdr, 0, data + tdp, len); + if (ret < 0) + return ret; + } + pc += asn1_op_lengths[op]; + goto next_op; + + case ASN1_OP_MAYBE_ACT: + if (!(flags & FLAG_LAST_MATCHED)) { + pc += asn1_op_lengths[op]; + goto next_op; + } + /* fall through */ + + case ASN1_OP_ACT: + ret = actions[machine[pc + 1]](context, hdr, tag, data + tdp, len); + if (ret < 0) + return ret; + pc += asn1_op_lengths[op]; + goto next_op; + + case ASN1_OP_RETURN: + if (unlikely(jsp <= 0)) + goto jump_stack_underflow; + pc = jump_stack[--jsp]; + flags |= FLAG_MATCHED | FLAG_LAST_MATCHED; + goto next_op; + + default: + break; + } + + /* Shouldn't reach here */ + pr_err("ASN.1 decoder error: Found reserved opcode (%u) pc=%zu\n", + op, pc); + return -EBADMSG; + +data_overrun_error: + errmsg = "Data overrun error"; + goto error; +machine_overrun_error: + errmsg = "Machine overrun error"; + goto error; +jump_stack_underflow: + errmsg = "Jump stack underflow"; + goto error; +jump_stack_overflow: + errmsg = "Jump stack overflow"; + goto error; +cons_stack_underflow: + errmsg = "Cons stack underflow"; + goto error; +cons_stack_overflow: + errmsg = "Cons stack overflow"; + goto error; +cons_length_error: + errmsg = "Cons length error"; + goto error; +missing_eoc: + errmsg = "Missing EOC in indefinite len cons"; + goto error; +invalid_eoc: + errmsg = "Invalid length EOC"; + goto error; +length_too_long: + errmsg = "Unsupported length"; + goto error; +indefinite_len_primitive: + errmsg = "Indefinite len primitive not permitted"; + goto error; +tag_mismatch: + errmsg = "Unexpected tag"; + goto error; +long_tag_not_supported: + errmsg = "Long tag not supported"; +error: + pr_debug("\nASN1: %s [m=%zu d=%zu ot=%02x t=%02x l=%zu]\n", + errmsg, pc, dp, optag, tag, len); + return -EBADMSG; +} +EXPORT_SYMBOL_GPL(asn1_ber_decoder); + +MODULE_LICENSE("GPL");
This document gives a brief description about ASN1 compiler as well as ASN1 decoder.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- doc/README.asn1 | 40 ++++++++++++++++++++++++++++++++++++++++ 1 file changed, 40 insertions(+) create mode 100644 doc/README.asn1
diff --git a/doc/README.asn1 b/doc/README.asn1 new file mode 100644 index 000000000000..1359b93aef0b --- /dev/null +++ b/doc/README.asn1 @@ -0,0 +1,40 @@ +ASN1 +==== + +Abstract Syntax Notation One (or ASN1) is a standard by ITU-T and ISO/IEC +and used as a description language for defining data structure in +an independent manner. +Any data described in ASN1 notation can be serialized (or encoded) and +de-serialized (or decoded) with well-defined encoding rules. + +A combination of ASN1 compiler and ASN1 decoder library function will +provide a function interface for parsing encoded binary into specific +data structure: +1) define data structure in a text file (*.asn1) +2) define "action" routines for specific "tags" defined in (1) +3) generate bytecode as a C file (*.asn1.[ch]) from *.asn1 file + with ASN1 compiler (tools/asn1_compiler) +4) call a ASN1 decoder (asn1_ber_decoder()) with bytecode and data + +Usage of ASN1 compiler +---------------------- + asn1_compiler [-v] [-d] <grammar-file> <c-file> <hdr-file> + + <grammar-file>: ASN1 input file + <c-file>: generated C file + <hdr-file>: generated include file + +Usage of ASN1 decoder +--------------------- + int asn1_ber_decoder(const struct asn1_decoder *decoder, void *context, + const unsigned char *data, size_t datalen); + + @decoder: bytecode binary + @context: context for decoder + @data: data to be parsed + @datalen: size of data + + +As of writing this, ASN1 compiler and decoder are used to implement +X509 certificate parser, pcks7 message parser and RSA public key parser +for UEFI secure boot.
Imported from linux kernel v5.3: build_OID_registry without changes oid_registry.h without changes oid_registry.c with changes marked as __UBOOT__
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- include/linux/oid_registry.h | 117 ++++++++++++++++++++ lib/Kconfig | 5 + lib/Makefile | 16 +++ lib/oid_registry.c | 179 ++++++++++++++++++++++++++++++ scripts/build_OID_registry | 203 +++++++++++++++++++++++++++++++++++ 5 files changed, 520 insertions(+) create mode 100644 include/linux/oid_registry.h create mode 100644 lib/oid_registry.c create mode 100755 scripts/build_OID_registry
diff --git a/include/linux/oid_registry.h b/include/linux/oid_registry.h new file mode 100644 index 000000000000..657d6bf2c064 --- /dev/null +++ b/include/linux/oid_registry.h @@ -0,0 +1,117 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* ASN.1 Object identifier (OID) registry + * + * Copyright (C) 2012 Red Hat, Inc. All Rights Reserved. + * Written by David Howells (dhowells@redhat.com) + */ + +#ifndef _LINUX_OID_REGISTRY_H +#define _LINUX_OID_REGISTRY_H + +#include <linux/types.h> + +/* + * OIDs are turned into these values if possible, or OID__NR if not held here. + * + * NOTE! Do not mess with the format of each line as this is read by + * build_OID_registry.pl to generate the data for look_up_OID(). + */ +enum OID { + OID_id_dsa_with_sha1, /* 1.2.840.10030.4.3 */ + OID_id_dsa, /* 1.2.840.10040.4.1 */ + OID_id_ecdsa_with_sha1, /* 1.2.840.10045.4.1 */ + OID_id_ecPublicKey, /* 1.2.840.10045.2.1 */ + + /* PKCS#1 {iso(1) member-body(2) us(840) rsadsi(113549) pkcs(1) pkcs-1(1)} */ + OID_rsaEncryption, /* 1.2.840.113549.1.1.1 */ + OID_md2WithRSAEncryption, /* 1.2.840.113549.1.1.2 */ + OID_md3WithRSAEncryption, /* 1.2.840.113549.1.1.3 */ + OID_md4WithRSAEncryption, /* 1.2.840.113549.1.1.4 */ + OID_sha1WithRSAEncryption, /* 1.2.840.113549.1.1.5 */ + OID_sha256WithRSAEncryption, /* 1.2.840.113549.1.1.11 */ + OID_sha384WithRSAEncryption, /* 1.2.840.113549.1.1.12 */ + OID_sha512WithRSAEncryption, /* 1.2.840.113549.1.1.13 */ + OID_sha224WithRSAEncryption, /* 1.2.840.113549.1.1.14 */ + /* PKCS#7 {iso(1) member-body(2) us(840) rsadsi(113549) pkcs(1) pkcs-7(7)} */ + OID_data, /* 1.2.840.113549.1.7.1 */ + OID_signed_data, /* 1.2.840.113549.1.7.2 */ + /* PKCS#9 {iso(1) member-body(2) us(840) rsadsi(113549) pkcs(1) pkcs-9(9)} */ + OID_email_address, /* 1.2.840.113549.1.9.1 */ + OID_contentType, /* 1.2.840.113549.1.9.3 */ + OID_messageDigest, /* 1.2.840.113549.1.9.4 */ + OID_signingTime, /* 1.2.840.113549.1.9.5 */ + OID_smimeCapabilites, /* 1.2.840.113549.1.9.15 */ + OID_smimeAuthenticatedAttrs, /* 1.2.840.113549.1.9.16.2.11 */ + + /* {iso(1) member-body(2) us(840) rsadsi(113549) digestAlgorithm(2)} */ + OID_md2, /* 1.2.840.113549.2.2 */ + OID_md4, /* 1.2.840.113549.2.4 */ + OID_md5, /* 1.2.840.113549.2.5 */ + + /* Microsoft Authenticode & Software Publishing */ + OID_msIndirectData, /* 1.3.6.1.4.1.311.2.1.4 */ + OID_msStatementType, /* 1.3.6.1.4.1.311.2.1.11 */ + OID_msSpOpusInfo, /* 1.3.6.1.4.1.311.2.1.12 */ + OID_msPeImageDataObjId, /* 1.3.6.1.4.1.311.2.1.15 */ + OID_msIndividualSPKeyPurpose, /* 1.3.6.1.4.1.311.2.1.21 */ + OID_msOutlookExpress, /* 1.3.6.1.4.1.311.16.4 */ + + OID_certAuthInfoAccess, /* 1.3.6.1.5.5.7.1.1 */ + OID_sha1, /* 1.3.14.3.2.26 */ + OID_sha256, /* 2.16.840.1.101.3.4.2.1 */ + OID_sha384, /* 2.16.840.1.101.3.4.2.2 */ + OID_sha512, /* 2.16.840.1.101.3.4.2.3 */ + OID_sha224, /* 2.16.840.1.101.3.4.2.4 */ + + /* Distinguished Name attribute IDs [RFC 2256] */ + OID_commonName, /* 2.5.4.3 */ + OID_surname, /* 2.5.4.4 */ + OID_countryName, /* 2.5.4.6 */ + OID_locality, /* 2.5.4.7 */ + OID_stateOrProvinceName, /* 2.5.4.8 */ + OID_organizationName, /* 2.5.4.10 */ + OID_organizationUnitName, /* 2.5.4.11 */ + OID_title, /* 2.5.4.12 */ + OID_description, /* 2.5.4.13 */ + OID_name, /* 2.5.4.41 */ + OID_givenName, /* 2.5.4.42 */ + OID_initials, /* 2.5.4.43 */ + OID_generationalQualifier, /* 2.5.4.44 */ + + /* Certificate extension IDs */ + OID_subjectKeyIdentifier, /* 2.5.29.14 */ + OID_keyUsage, /* 2.5.29.15 */ + OID_subjectAltName, /* 2.5.29.17 */ + OID_issuerAltName, /* 2.5.29.18 */ + OID_basicConstraints, /* 2.5.29.19 */ + OID_crlDistributionPoints, /* 2.5.29.31 */ + OID_certPolicies, /* 2.5.29.32 */ + OID_authorityKeyIdentifier, /* 2.5.29.35 */ + OID_extKeyUsage, /* 2.5.29.37 */ + + /* EC-RDSA */ + OID_gostCPSignA, /* 1.2.643.2.2.35.1 */ + OID_gostCPSignB, /* 1.2.643.2.2.35.2 */ + OID_gostCPSignC, /* 1.2.643.2.2.35.3 */ + OID_gost2012PKey256, /* 1.2.643.7.1.1.1.1 */ + OID_gost2012PKey512, /* 1.2.643.7.1.1.1.2 */ + OID_gost2012Digest256, /* 1.2.643.7.1.1.2.2 */ + OID_gost2012Digest512, /* 1.2.643.7.1.1.2.3 */ + OID_gost2012Signature256, /* 1.2.643.7.1.1.3.2 */ + OID_gost2012Signature512, /* 1.2.643.7.1.1.3.3 */ + OID_gostTC26Sign256A, /* 1.2.643.7.1.2.1.1.1 */ + OID_gostTC26Sign256B, /* 1.2.643.7.1.2.1.1.2 */ + OID_gostTC26Sign256C, /* 1.2.643.7.1.2.1.1.3 */ + OID_gostTC26Sign256D, /* 1.2.643.7.1.2.1.1.4 */ + OID_gostTC26Sign512A, /* 1.2.643.7.1.2.1.2.1 */ + OID_gostTC26Sign512B, /* 1.2.643.7.1.2.1.2.2 */ + OID_gostTC26Sign512C, /* 1.2.643.7.1.2.1.2.3 */ + + OID__NR +}; + +extern enum OID look_up_OID(const void *data, size_t datasize); +extern int sprint_oid(const void *, size_t, char *, size_t); +extern int sprint_OID(enum OID, char *, size_t); + +#endif /* _LINUX_OID_REGISTRY_H */ diff --git a/lib/Kconfig b/lib/Kconfig index 66ac598ed759..0431cfbd21f8 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -574,6 +574,11 @@ config ASN1_DECODER help Enable asn1 decoder library.
+config OID_REGISTRY + bool + help + Enable fast lookup object identifier registry. + source lib/efi/Kconfig source lib/efi_loader/Kconfig source lib/optee/Kconfig diff --git a/lib/Makefile b/lib/Makefile index 6e019fd0581d..9b8305e3190f 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -120,4 +120,20 @@ endif
obj-y += date.o
+# +# Build a fast OID lookup registry from include/linux/oid_registry.h +# +obj-$(CONFIG_OID_REGISTRY) += oid_registry.o + +$(obj)/oid_registry.o: $(obj)/oid_registry_data.c + +$(obj)/oid_registry_data.c: $(srctree)/include/linux/oid_registry.h \ + $(srctree)/scripts/build_OID_registry + $(call cmd,build_OID_registry) + +quiet_cmd_build_OID_registry = GEN $@ + cmd_build_OID_registry = perl $(srctree)/scripts/build_OID_registry $< $@ + +clean-files += oid_registry_data.c + subdir-ccflags-$(CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED) += -O2 diff --git a/lib/oid_registry.c b/lib/oid_registry.c new file mode 100644 index 000000000000..209edc73b99f --- /dev/null +++ b/lib/oid_registry.c @@ -0,0 +1,179 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* ASN.1 Object identifier (OID) registry + * + * Copyright (C) 2012 Red Hat, Inc. All Rights Reserved. + * Written by David Howells (dhowells@redhat.com) + */ + +#ifdef __UBOOT__ +#include <linux/compat.h> +#else +#include <linux/module.h> +#include <linux/export.h> +#endif +#include <linux/oid_registry.h> +#include <linux/kernel.h> +#include <linux/errno.h> +#include <linux/bug.h> +#include "oid_registry_data.c" + +MODULE_DESCRIPTION("OID Registry"); +MODULE_AUTHOR("Red Hat, Inc."); +MODULE_LICENSE("GPL"); + +/** + * look_up_OID - Find an OID registration for the specified data + * @data: Binary representation of the OID + * @datasize: Size of the binary representation + */ +enum OID look_up_OID(const void *data, size_t datasize) +{ + const unsigned char *octets = data; + enum OID oid; + unsigned char xhash; + unsigned i, j, k, hash; + size_t len; + + /* Hash the OID data */ + hash = datasize - 1; + + for (i = 0; i < datasize; i++) + hash += octets[i] * 33; + hash = (hash >> 24) ^ (hash >> 16) ^ (hash >> 8) ^ hash; + hash &= 0xff; + + /* Binary search the OID registry. OIDs are stored in ascending order + * of hash value then ascending order of size and then in ascending + * order of reverse value. + */ + i = 0; + k = OID__NR; + while (i < k) { + j = (i + k) / 2; + + xhash = oid_search_table[j].hash; + if (xhash > hash) { + k = j; + continue; + } + if (xhash < hash) { + i = j + 1; + continue; + } + + oid = oid_search_table[j].oid; + len = oid_index[oid + 1] - oid_index[oid]; + if (len > datasize) { + k = j; + continue; + } + if (len < datasize) { + i = j + 1; + continue; + } + + /* Variation is most likely to be at the tail end of the + * OID, so do the comparison in reverse. + */ + while (len > 0) { + unsigned char a = oid_data[oid_index[oid] + --len]; + unsigned char b = octets[len]; + if (a > b) { + k = j; + goto next; + } + if (a < b) { + i = j + 1; + goto next; + } + } + return oid; + next: + ; + } + + return OID__NR; +} +EXPORT_SYMBOL_GPL(look_up_OID); + +/* + * sprint_OID - Print an Object Identifier into a buffer + * @data: The encoded OID to print + * @datasize: The size of the encoded OID + * @buffer: The buffer to render into + * @bufsize: The size of the buffer + * + * The OID is rendered into the buffer in "a.b.c.d" format and the number of + * bytes is returned. -EBADMSG is returned if the data could not be intepreted + * and -ENOBUFS if the buffer was too small. + */ +int sprint_oid(const void *data, size_t datasize, char *buffer, size_t bufsize) +{ + const unsigned char *v = data, *end = v + datasize; + unsigned long num; + unsigned char n; + size_t ret; + int count; + + if (v >= end) + goto bad; + + n = *v++; + ret = count = snprintf(buffer, bufsize, "%u.%u", n / 40, n % 40); + if (count >= bufsize) + return -ENOBUFS; + buffer += count; + bufsize -= count; + + while (v < end) { + num = 0; + n = *v++; + if (!(n & 0x80)) { + num = n; + } else { + num = n & 0x7f; + do { + if (v >= end) + goto bad; + n = *v++; + num <<= 7; + num |= n & 0x7f; + } while (n & 0x80); + } + ret += count = snprintf(buffer, bufsize, ".%lu", num); + if (count >= bufsize) + return -ENOBUFS; + buffer += count; + bufsize -= count; + } + + return ret; + +bad: + snprintf(buffer, bufsize, "(bad)"); + return -EBADMSG; +} +EXPORT_SYMBOL_GPL(sprint_oid); + +/** + * sprint_OID - Print an Object Identifier into a buffer + * @oid: The OID to print + * @buffer: The buffer to render into + * @bufsize: The size of the buffer + * + * The OID is rendered into the buffer in "a.b.c.d" format and the number of + * bytes is returned. + */ +int sprint_OID(enum OID oid, char *buffer, size_t bufsize) +{ + int ret; + + BUG_ON(oid >= OID__NR); + + ret = sprint_oid(oid_data + oid_index[oid], + oid_index[oid + 1] - oid_index[oid], + buffer, bufsize); + BUG_ON(ret == -EBADMSG); + return ret; +} +EXPORT_SYMBOL_GPL(sprint_OID); diff --git a/scripts/build_OID_registry b/scripts/build_OID_registry new file mode 100755 index 000000000000..d7fc32ea8ac2 --- /dev/null +++ b/scripts/build_OID_registry @@ -0,0 +1,203 @@ +#!/usr/bin/perl -w +# SPDX-License-Identifier: GPL-2.0-or-later +# +# Build a static ASN.1 Object Identified (OID) registry +# +# Copyright (C) 2012 Red Hat, Inc. All Rights Reserved. +# Written by David Howells (dhowells@redhat.com) +# + +use strict; + +my @names = (); +my @oids = (); + +if ($#ARGV != 1) { + print STDERR "Format: ", $0, " <in-h-file> <out-c-file>\n"; + exit(2); +} + +# +# Open the file to read from +# +open IN_FILE, "<$ARGV[0]" || die; +while (<IN_FILE>) { + chomp; + if (m!\s+OID_([a-zA-z][a-zA-Z0-9_]+),\s+/[*]\s+([012][.0-9]*)\s+[*]/!) { + push @names, $1; + push @oids, $2; + } +} +close IN_FILE || die; + +# +# Open the files to write into +# +open C_FILE, ">$ARGV[1]" or die; +print C_FILE "/*\n"; +print C_FILE " * Automatically generated by ", $0, ". Do not edit\n"; +print C_FILE " */\n"; + +# +# Split the data up into separate lists and also determine the lengths of the +# encoded data arrays. +# +my @indices = (); +my @lengths = (); +my $total_length = 0; + +for (my $i = 0; $i <= $#names; $i++) { + my $name = $names[$i]; + my $oid = $oids[$i]; + + my @components = split(/[.]/, $oid); + + # Determine the encoded length of this OID + my $size = $#components; + for (my $loop = 2; $loop <= $#components; $loop++) { + my $c = $components[$loop]; + + # We will base128 encode the number + my $tmp = ($c == 0) ? 0 : int(log($c)/log(2)); + $tmp = int($tmp / 7); + $size += $tmp; + } + push @lengths, $size; + push @indices, $total_length; + $total_length += $size; +} + +# +# Emit the look-up-by-OID index table +# +print C_FILE "\n"; +if ($total_length <= 255) { + print C_FILE "static const unsigned char oid_index[OID__NR + 1] = {\n"; +} else { + print C_FILE "static const unsigned short oid_index[OID__NR + 1] = {\n"; +} +for (my $i = 0; $i <= $#names; $i++) { + print C_FILE "\t[OID_", $names[$i], "] = ", $indices[$i], ",\n" +} +print C_FILE "\t[OID__NR] = ", $total_length, "\n"; +print C_FILE "};\n"; + +# +# Encode the OIDs +# +my @encoded_oids = (); + +for (my $i = 0; $i <= $#names; $i++) { + my @octets = (); + + my @components = split(/[.]/, $oids[$i]); + + push @octets, $components[0] * 40 + $components[1]; + + for (my $loop = 2; $loop <= $#components; $loop++) { + my $c = $components[$loop]; + + # Base128 encode the number + my $tmp = ($c == 0) ? 0 : int(log($c)/log(2)); + $tmp = int($tmp / 7); + + for (; $tmp > 0; $tmp--) { + push @octets, (($c >> $tmp * 7) & 0x7f) | 0x80; + } + push @octets, $c & 0x7f; + } + + push @encoded_oids, @octets; +} + +# +# Create a hash value for each OID +# +my @hash_values = (); +for (my $i = 0; $i <= $#names; $i++) { + my @octets = @{$encoded_oids[$i]}; + + my $hash = $#octets; + foreach (@octets) { + $hash += $_ * 33; + } + + $hash = ($hash >> 24) ^ ($hash >> 16) ^ ($hash >> 8) ^ ($hash); + + push @hash_values, $hash & 0xff; +} + +# +# Emit the OID data +# +print C_FILE "\n"; +print C_FILE "static const unsigned char oid_data[", $total_length, "] = {\n"; +for (my $i = 0; $i <= $#names; $i++) { + my @octets = @{$encoded_oids[$i]}; + print C_FILE "\t"; + print C_FILE $_, ", " foreach (@octets); + print C_FILE "\t// ", $names[$i]; + print C_FILE "\n"; +} +print C_FILE "};\n"; + +# +# Build the search index table (ordered by length then hash then content) +# +my @index_table = ( 0 .. $#names ); + +@index_table = sort { + my @octets_a = @{$encoded_oids[$a]}; + my @octets_b = @{$encoded_oids[$b]}; + + return $hash_values[$a] <=> $hash_values[$b] + if ($hash_values[$a] != $hash_values[$b]); + return $#octets_a <=> $#octets_b + if ($#octets_a != $#octets_b); + for (my $i = $#octets_a; $i >= 0; $i--) { + return $octets_a[$i] <=> $octets_b[$i] + if ($octets_a[$i] != $octets_b[$i]); + } + return 0; + +} @index_table; + +# +# Emit the search index and hash value table +# +print C_FILE "\n"; +print C_FILE "static const struct {\n"; +print C_FILE "\tunsigned char hash;\n"; +if ($#names <= 255) { + print C_FILE "\tenum OID oid : 8;\n"; +} else { + print C_FILE "\tenum OID oid : 16;\n"; +} +print C_FILE "} oid_search_table[OID__NR] = {\n"; +for (my $i = 0; $i <= $#names; $i++) { + my @octets = @{$encoded_oids[$index_table[$i]]}; + printf(C_FILE "\t[%3u] = { %3u, OID_%-35s }, // ", + $i, + $hash_values[$index_table[$i]], + $names[$index_table[$i]]); + printf C_FILE "%02x", $_ foreach (@octets); + print C_FILE "\n"; +} +print C_FILE "};\n"; + +# +# Emit the OID debugging name table +# +#print C_FILE "\n"; +#print C_FILE "const char *const oid_name_table[OID__NR + 1] = {\n"; +# +#for (my $i = 0; $i <= $#names; $i++) { +# print C_FILE "\t"", $names[$i], "",\n" +#} +#print C_FILE "\t"Unknown-OID"\n"; +#print C_FILE "};\n"; + +# +# Polish off +# +close C_FILE or die;
Imported from linux kernel v5.3: asymmetric-type.h with changes marked as __UBOOT__ asymmetric_type.c with changes marked as __UBOOT__ public_key.h with changes marked as __UBOOT__ public_key.c with changes marked as __UBOOT__
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- include/crypto/public_key.h | 90 +++++ include/keys/asymmetric-type.h | 88 +++++ lib/crypto/Kconfig | 19 + lib/crypto/Makefile | 10 + lib/crypto/asymmetric_type.c | 668 +++++++++++++++++++++++++++++++++ lib/crypto/public_key.c | 376 +++++++++++++++++++ 6 files changed, 1251 insertions(+) create mode 100644 include/crypto/public_key.h create mode 100644 include/keys/asymmetric-type.h create mode 100644 lib/crypto/Kconfig create mode 100644 lib/crypto/Makefile create mode 100644 lib/crypto/asymmetric_type.c create mode 100644 lib/crypto/public_key.c
diff --git a/include/crypto/public_key.h b/include/crypto/public_key.h new file mode 100644 index 000000000000..436a1ee1ee64 --- /dev/null +++ b/include/crypto/public_key.h @@ -0,0 +1,90 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* Asymmetric public-key algorithm definitions + * + * See Documentation/crypto/asymmetric-keys.txt + * + * Copyright (C) 2012 Red Hat, Inc. All Rights Reserved. + * Written by David Howells (dhowells@redhat.com) + */ + +#ifndef _LINUX_PUBLIC_KEY_H +#define _LINUX_PUBLIC_KEY_H + +#ifdef __UBOOT__ +#include <linux/types.h> +#else +#include <linux/keyctl.h> +#endif +#include <linux/oid_registry.h> + +/* + * Cryptographic data for the public-key subtype of the asymmetric key type. + * + * Note that this may include private part of the key as well as the public + * part. + */ +struct public_key { + void *key; + u32 keylen; + enum OID algo; + void *params; + u32 paramlen; + bool key_is_private; + const char *id_type; + const char *pkey_algo; +}; + +extern void public_key_free(struct public_key *key); + +/* + * Public key cryptography signature data + */ +struct public_key_signature { + struct asymmetric_key_id *auth_ids[2]; + u8 *s; /* Signature */ + u32 s_size; /* Number of bytes in signature */ + u8 *digest; + u8 digest_size; /* Number of bytes in digest */ + const char *pkey_algo; + const char *hash_algo; + const char *encoding; +}; + +extern void public_key_signature_free(struct public_key_signature *sig); + +#ifndef __UBOOT__ +extern struct asymmetric_key_subtype public_key_subtype; + +struct key; +struct key_type; +union key_payload; + +extern int restrict_link_by_signature(struct key *dest_keyring, + const struct key_type *type, + const union key_payload *payload, + struct key *trust_keyring); + +extern int restrict_link_by_key_or_keyring(struct key *dest_keyring, + const struct key_type *type, + const union key_payload *payload, + struct key *trusted); + +extern int restrict_link_by_key_or_keyring_chain(struct key *trust_keyring, + const struct key_type *type, + const union key_payload *payload, + struct key *trusted); + +extern int query_asymmetric_key(const struct kernel_pkey_params *, + struct kernel_pkey_query *); + +extern int encrypt_blob(struct kernel_pkey_params *, const void *, void *); +extern int decrypt_blob(struct kernel_pkey_params *, const void *, void *); +extern int create_signature(struct kernel_pkey_params *, const void *, void *); +extern int verify_signature(const struct key *, + const struct public_key_signature *); + +int public_key_verify_signature(const struct public_key *pkey, + const struct public_key_signature *sig); +#endif /* !__UBOOT__ */ + +#endif /* _LINUX_PUBLIC_KEY_H */ diff --git a/include/keys/asymmetric-type.h b/include/keys/asymmetric-type.h new file mode 100644 index 000000000000..47d83917df2f --- /dev/null +++ b/include/keys/asymmetric-type.h @@ -0,0 +1,88 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* Asymmetric Public-key cryptography key type interface + * + * See Documentation/crypto/asymmetric-keys.txt + * + * Copyright (C) 2012 Red Hat, Inc. All Rights Reserved. + * Written by David Howells (dhowells@redhat.com) + */ + +#ifndef _KEYS_ASYMMETRIC_TYPE_H +#define _KEYS_ASYMMETRIC_TYPE_H + +#ifndef __UBOOT__ +#include <linux/key-type.h> +#include <linux/verification.h> + +extern struct key_type key_type_asymmetric; + +/* + * The key payload is four words. The asymmetric-type key uses them as + * follows: + */ +enum asymmetric_payload_bits { + asym_crypto, /* The data representing the key */ + asym_subtype, /* Pointer to an asymmetric_key_subtype struct */ + asym_key_ids, /* Pointer to an asymmetric_key_ids struct */ + asym_auth /* The key's authorisation (signature, parent key ID) */ +}; +#endif /* !__UBOOT__ */ + +/* + * Identifiers for an asymmetric key ID. We have three ways of looking up a + * key derived from an X.509 certificate: + * + * (1) Serial Number & Issuer. Non-optional. This is the only valid way to + * map a PKCS#7 signature to an X.509 certificate. + * + * (2) Issuer & Subject Unique IDs. Optional. These were the original way to + * match X.509 certificates, but have fallen into disuse in favour of (3). + * + * (3) Auth & Subject Key Identifiers. Optional. SKIDs are only provided on + * CA keys that are intended to sign other keys, so don't appear in end + * user certificates unless forced. + * + * We could also support an PGP key identifier, which is just a SHA1 sum of the + * public key and certain parameters, but since we don't support PGP keys at + * the moment, we shall ignore those. + * + * What we actually do is provide a place where binary identifiers can be + * stashed and then compare against them when checking for an id match. + */ +struct asymmetric_key_id { + unsigned short len; + unsigned char data[]; +}; + +struct asymmetric_key_ids { + void *id[2]; +}; + +extern bool asymmetric_key_id_same(const struct asymmetric_key_id *kid1, + const struct asymmetric_key_id *kid2); + +extern bool asymmetric_key_id_partial(const struct asymmetric_key_id *kid1, + const struct asymmetric_key_id *kid2); + +extern struct asymmetric_key_id *asymmetric_key_generate_id(const void *val_1, + size_t len_1, + const void *val_2, + size_t len_2); +#ifndef __UBOOT__ +static inline +const struct asymmetric_key_ids *asymmetric_key_ids(const struct key *key) +{ + return key->payload.data[asym_key_ids]; +} + +extern struct key *find_asymmetric_key(struct key *keyring, + const struct asymmetric_key_id *id_0, + const struct asymmetric_key_id *id_1, + bool partial); +#endif + +/* + * The payload is at the discretion of the subtype. + */ + +#endif /* _KEYS_ASYMMETRIC_TYPE_H */ diff --git a/lib/crypto/Kconfig b/lib/crypto/Kconfig new file mode 100644 index 000000000000..b8e8288d2f80 --- /dev/null +++ b/lib/crypto/Kconfig @@ -0,0 +1,19 @@ +menuconfig ASYMMETRIC_KEY_TYPE + bool "Asymmetric (public-key cryptographic) key Support" + help + This option provides support for a key type that holds the data for + the asymmetric keys used for public key cryptographic operations such + as encryption, decryption, signature generation and signature + verification. + +if ASYMMETRIC_KEY_TYPE + +config ASYMMETRIC_PUBLIC_KEY_SUBTYPE + bool "Asymmetric public-key crypto algorithm subtype" + help + This option provides support for asymmetric public key type handling. + If signature generation and/or verification are to be used, + appropriate hash algorithms (such as SHA-1) must be available. + ENOPKG will be reported if the requisite algorithm is unavailable. + +endif # ASYMMETRIC_KEY_TYPE diff --git a/lib/crypto/Makefile b/lib/crypto/Makefile new file mode 100644 index 000000000000..a284de9e0411 --- /dev/null +++ b/lib/crypto/Makefile @@ -0,0 +1,10 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Makefile for asymmetric cryptographic keys +# + +obj-$(CONFIG_ASYMMETRIC_KEY_TYPE) += asymmetric_keys.o + +asymmetric_keys-y := asymmetric_type.o + +obj-$(CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE) += public_key.o diff --git a/lib/crypto/asymmetric_type.c b/lib/crypto/asymmetric_type.c new file mode 100644 index 000000000000..e04666c0801d --- /dev/null +++ b/lib/crypto/asymmetric_type.c @@ -0,0 +1,668 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* Asymmetric public-key cryptography key type + * + * See Documentation/crypto/asymmetric-keys.txt + * + * Copyright (C) 2012 Red Hat, Inc. All Rights Reserved. + * Written by David Howells (dhowells@redhat.com) + */ +#ifndef __UBOOT__ +#include <keys/asymmetric-subtype.h> +#include <keys/asymmetric-parser.h> +#endif +#include <crypto/public_key.h> +#ifdef __UBOOT__ +#include <linux/compat.h> +#include <linux/ctype.h> +#include <linux/string.h> +#else +#include <linux/seq_file.h> +#include <linux/module.h> +#include <linux/slab.h> +#include <linux/ctype.h> +#endif +#ifdef __UBOOT__ +#include <keys/asymmetric-type.h> +#else +#include <keys/system_keyring.h> +#include <keys/user-type.h> +#include "asymmetric_keys.h" +#endif + +MODULE_LICENSE("GPL"); + +#ifndef __UBOOT__ +const char *const key_being_used_for[NR__KEY_BEING_USED_FOR] = { + [VERIFYING_MODULE_SIGNATURE] = "mod sig", + [VERIFYING_FIRMWARE_SIGNATURE] = "firmware sig", + [VERIFYING_KEXEC_PE_SIGNATURE] = "kexec PE sig", + [VERIFYING_KEY_SIGNATURE] = "key sig", + [VERIFYING_KEY_SELF_SIGNATURE] = "key self sig", + [VERIFYING_UNSPECIFIED_SIGNATURE] = "unspec sig", +}; +EXPORT_SYMBOL_GPL(key_being_used_for); + +static LIST_HEAD(asymmetric_key_parsers); +static DECLARE_RWSEM(asymmetric_key_parsers_sem); + +/** + * find_asymmetric_key - Find a key by ID. + * @keyring: The keys to search. + * @id_0: The first ID to look for or NULL. + * @id_1: The second ID to look for or NULL. + * @partial: Use partial match if true, exact if false. + * + * Find a key in the given keyring by identifier. The preferred identifier is + * the id_0 and the fallback identifier is the id_1. If both are given, the + * lookup is by the former, but the latter must also match. + */ +struct key *find_asymmetric_key(struct key *keyring, + const struct asymmetric_key_id *id_0, + const struct asymmetric_key_id *id_1, + bool partial) +{ + struct key *key; + key_ref_t ref; + const char *lookup; + char *req, *p; + int len; + + BUG_ON(!id_0 && !id_1); + + if (id_0) { + lookup = id_0->data; + len = id_0->len; + } else { + lookup = id_1->data; + len = id_1->len; + } + + /* Construct an identifier "id:<keyid>". */ + p = req = kmalloc(2 + 1 + len * 2 + 1, GFP_KERNEL); + if (!req) + return ERR_PTR(-ENOMEM); + + if (partial) { + *p++ = 'i'; + *p++ = 'd'; + } else { + *p++ = 'e'; + *p++ = 'x'; + } + *p++ = ':'; + p = bin2hex(p, lookup, len); + *p = 0; + + pr_debug("Look up: "%s"\n", req); + + ref = keyring_search(make_key_ref(keyring, 1), + &key_type_asymmetric, req, true); + if (IS_ERR(ref)) + pr_debug("Request for key '%s' err %ld\n", req, PTR_ERR(ref)); + kfree(req); + + if (IS_ERR(ref)) { + switch (PTR_ERR(ref)) { + /* Hide some search errors */ + case -EACCES: + case -ENOTDIR: + case -EAGAIN: + return ERR_PTR(-ENOKEY); + default: + return ERR_CAST(ref); + } + } + + key = key_ref_to_ptr(ref); + if (id_0 && id_1) { + const struct asymmetric_key_ids *kids = asymmetric_key_ids(key); + + if (!kids->id[1]) { + pr_debug("First ID matches, but second is missing\n"); + goto reject; + } + if (!asymmetric_key_id_same(id_1, kids->id[1])) { + pr_debug("First ID matches, but second does not\n"); + goto reject; + } + } + + pr_devel("<==%s() = 0 [%x]\n", __func__, key_serial(key)); + return key; + +reject: + key_put(key); + return ERR_PTR(-EKEYREJECTED); +} +EXPORT_SYMBOL_GPL(find_asymmetric_key); +#endif /* !__UBOOT__ */ + +/** + * asymmetric_key_generate_id: Construct an asymmetric key ID + * @val_1: First binary blob + * @len_1: Length of first binary blob + * @val_2: Second binary blob + * @len_2: Length of second binary blob + * + * Construct an asymmetric key ID from a pair of binary blobs. + */ +struct asymmetric_key_id *asymmetric_key_generate_id(const void *val_1, + size_t len_1, + const void *val_2, + size_t len_2) +{ + struct asymmetric_key_id *kid; + + kid = kmalloc(sizeof(struct asymmetric_key_id) + len_1 + len_2, + GFP_KERNEL); + if (!kid) + return ERR_PTR(-ENOMEM); + kid->len = len_1 + len_2; + memcpy(kid->data, val_1, len_1); + memcpy(kid->data + len_1, val_2, len_2); + return kid; +} +EXPORT_SYMBOL_GPL(asymmetric_key_generate_id); + +/** + * asymmetric_key_id_same - Return true if two asymmetric keys IDs are the same. + * @kid_1, @kid_2: The key IDs to compare + */ +bool asymmetric_key_id_same(const struct asymmetric_key_id *kid1, + const struct asymmetric_key_id *kid2) +{ + if (!kid1 || !kid2) + return false; + if (kid1->len != kid2->len) + return false; + return memcmp(kid1->data, kid2->data, kid1->len) == 0; +} +EXPORT_SYMBOL_GPL(asymmetric_key_id_same); + +/** + * asymmetric_key_id_partial - Return true if two asymmetric keys IDs + * partially match + * @kid_1, @kid_2: The key IDs to compare + */ +bool asymmetric_key_id_partial(const struct asymmetric_key_id *kid1, + const struct asymmetric_key_id *kid2) +{ + if (!kid1 || !kid2) + return false; + if (kid1->len < kid2->len) + return false; + return memcmp(kid1->data + (kid1->len - kid2->len), + kid2->data, kid2->len) == 0; +} +EXPORT_SYMBOL_GPL(asymmetric_key_id_partial); + +#ifndef __UBOOT__ +/** + * asymmetric_match_key_ids - Search asymmetric key IDs + * @kids: The list of key IDs to check + * @match_id: The key ID we're looking for + * @match: The match function to use + */ +static bool asymmetric_match_key_ids( + const struct asymmetric_key_ids *kids, + const struct asymmetric_key_id *match_id, + bool (*match)(const struct asymmetric_key_id *kid1, + const struct asymmetric_key_id *kid2)) +{ + int i; + + if (!kids || !match_id) + return false; + for (i = 0; i < ARRAY_SIZE(kids->id); i++) + if (match(kids->id[i], match_id)) + return true; + return false; +} + +/* helper function can be called directly with pre-allocated memory */ +inline int __asymmetric_key_hex_to_key_id(const char *id, + struct asymmetric_key_id *match_id, + size_t hexlen) +{ + match_id->len = hexlen; + return hex2bin(match_id->data, id, hexlen); +} + +/** + * asymmetric_key_hex_to_key_id - Convert a hex string into a key ID. + * @id: The ID as a hex string. + */ +struct asymmetric_key_id *asymmetric_key_hex_to_key_id(const char *id) +{ + struct asymmetric_key_id *match_id; + size_t asciihexlen; + int ret; + + if (!*id) + return ERR_PTR(-EINVAL); + asciihexlen = strlen(id); + if (asciihexlen & 1) + return ERR_PTR(-EINVAL); + + match_id = kmalloc(sizeof(struct asymmetric_key_id) + asciihexlen / 2, + GFP_KERNEL); + if (!match_id) + return ERR_PTR(-ENOMEM); + ret = __asymmetric_key_hex_to_key_id(id, match_id, asciihexlen / 2); + if (ret < 0) { + kfree(match_id); + return ERR_PTR(-EINVAL); + } + return match_id; +} + +/* + * Match asymmetric keys by an exact match on an ID. + */ +static bool asymmetric_key_cmp(const struct key *key, + const struct key_match_data *match_data) +{ + const struct asymmetric_key_ids *kids = asymmetric_key_ids(key); + const struct asymmetric_key_id *match_id = match_data->preparsed; + + return asymmetric_match_key_ids(kids, match_id, + asymmetric_key_id_same); +} + +/* + * Match asymmetric keys by a partial match on an IDs. + */ +static bool asymmetric_key_cmp_partial(const struct key *key, + const struct key_match_data *match_data) +{ + const struct asymmetric_key_ids *kids = asymmetric_key_ids(key); + const struct asymmetric_key_id *match_id = match_data->preparsed; + + return asymmetric_match_key_ids(kids, match_id, + asymmetric_key_id_partial); +} + +/* + * Preparse the match criterion. If we don't set lookup_type and cmp, + * the default will be an exact match on the key description. + * + * There are some specifiers for matching key IDs rather than by the key + * description: + * + * "id:<id>" - find a key by partial match on any available ID + * "ex:<id>" - find a key by exact match on any available ID + * + * These have to be searched by iteration rather than by direct lookup because + * the key is hashed according to its description. + */ +static int asymmetric_key_match_preparse(struct key_match_data *match_data) +{ + struct asymmetric_key_id *match_id; + const char *spec = match_data->raw_data; + const char *id; + bool (*cmp)(const struct key *, const struct key_match_data *) = + asymmetric_key_cmp; + + if (!spec || !*spec) + return -EINVAL; + if (spec[0] == 'i' && + spec[1] == 'd' && + spec[2] == ':') { + id = spec + 3; + cmp = asymmetric_key_cmp_partial; + } else if (spec[0] == 'e' && + spec[1] == 'x' && + spec[2] == ':') { + id = spec + 3; + } else { + goto default_match; + } + + match_id = asymmetric_key_hex_to_key_id(id); + if (IS_ERR(match_id)) + return PTR_ERR(match_id); + + match_data->preparsed = match_id; + match_data->cmp = cmp; + match_data->lookup_type = KEYRING_SEARCH_LOOKUP_ITERATE; + return 0; + +default_match: + return 0; +} + +/* + * Free the preparsed the match criterion. + */ +static void asymmetric_key_match_free(struct key_match_data *match_data) +{ + kfree(match_data->preparsed); +} + +/* + * Describe the asymmetric key + */ +static void asymmetric_key_describe(const struct key *key, struct seq_file *m) +{ + const struct asymmetric_key_subtype *subtype = asymmetric_key_subtype(key); + const struct asymmetric_key_ids *kids = asymmetric_key_ids(key); + const struct asymmetric_key_id *kid; + const unsigned char *p; + int n; + + seq_puts(m, key->description); + + if (subtype) { + seq_puts(m, ": "); + subtype->describe(key, m); + + if (kids && kids->id[1]) { + kid = kids->id[1]; + seq_putc(m, ' '); + n = kid->len; + p = kid->data; + if (n > 4) { + p += n - 4; + n = 4; + } + seq_printf(m, "%*phN", n, p); + } + + seq_puts(m, " ["); + /* put something here to indicate the key's capabilities */ + seq_putc(m, ']'); + } +} + +/* + * Preparse a asymmetric payload to get format the contents appropriately for the + * internal payload to cut down on the number of scans of the data performed. + * + * We also generate a proposed description from the contents of the key that + * can be used to name the key if the user doesn't want to provide one. + */ +static int asymmetric_key_preparse(struct key_preparsed_payload *prep) +{ + struct asymmetric_key_parser *parser; + int ret; + + pr_devel("==>%s()\n", __func__); + + if (prep->datalen == 0) + return -EINVAL; + + down_read(&asymmetric_key_parsers_sem); + + ret = -EBADMSG; + list_for_each_entry(parser, &asymmetric_key_parsers, link) { + pr_debug("Trying parser '%s'\n", parser->name); + + ret = parser->parse(prep); + if (ret != -EBADMSG) { + pr_debug("Parser recognised the format (ret %d)\n", + ret); + break; + } + } + + up_read(&asymmetric_key_parsers_sem); + pr_devel("<==%s() = %d\n", __func__, ret); + return ret; +} + +/* + * Clean up the key ID list + */ +static void asymmetric_key_free_kids(struct asymmetric_key_ids *kids) +{ + int i; + + if (kids) { + for (i = 0; i < ARRAY_SIZE(kids->id); i++) + kfree(kids->id[i]); + kfree(kids); + } +} + +/* + * Clean up the preparse data + */ +static void asymmetric_key_free_preparse(struct key_preparsed_payload *prep) +{ + struct asymmetric_key_subtype *subtype = prep->payload.data[asym_subtype]; + struct asymmetric_key_ids *kids = prep->payload.data[asym_key_ids]; + + pr_devel("==>%s()\n", __func__); + + if (subtype) { + subtype->destroy(prep->payload.data[asym_crypto], + prep->payload.data[asym_auth]); + module_put(subtype->owner); + } + asymmetric_key_free_kids(kids); + kfree(prep->description); +} + +/* + * dispose of the data dangling from the corpse of a asymmetric key + */ +static void asymmetric_key_destroy(struct key *key) +{ + struct asymmetric_key_subtype *subtype = asymmetric_key_subtype(key); + struct asymmetric_key_ids *kids = key->payload.data[asym_key_ids]; + void *data = key->payload.data[asym_crypto]; + void *auth = key->payload.data[asym_auth]; + + key->payload.data[asym_crypto] = NULL; + key->payload.data[asym_subtype] = NULL; + key->payload.data[asym_key_ids] = NULL; + key->payload.data[asym_auth] = NULL; + + if (subtype) { + subtype->destroy(data, auth); + module_put(subtype->owner); + } + + asymmetric_key_free_kids(kids); +} + +static struct key_restriction *asymmetric_restriction_alloc( + key_restrict_link_func_t check, + struct key *key) +{ + struct key_restriction *keyres = + kzalloc(sizeof(struct key_restriction), GFP_KERNEL); + + if (!keyres) + return ERR_PTR(-ENOMEM); + + keyres->check = check; + keyres->key = key; + keyres->keytype = &key_type_asymmetric; + + return keyres; +} + +/* + * look up keyring restrict functions for asymmetric keys + */ +static struct key_restriction *asymmetric_lookup_restriction( + const char *restriction) +{ + char *restrict_method; + char *parse_buf; + char *next; + struct key_restriction *ret = ERR_PTR(-EINVAL); + + if (strcmp("builtin_trusted", restriction) == 0) + return asymmetric_restriction_alloc( + restrict_link_by_builtin_trusted, NULL); + + if (strcmp("builtin_and_secondary_trusted", restriction) == 0) + return asymmetric_restriction_alloc( + restrict_link_by_builtin_and_secondary_trusted, NULL); + + parse_buf = kstrndup(restriction, PAGE_SIZE, GFP_KERNEL); + if (!parse_buf) + return ERR_PTR(-ENOMEM); + + next = parse_buf; + restrict_method = strsep(&next, ":"); + + if ((strcmp(restrict_method, "key_or_keyring") == 0) && next) { + char *key_text; + key_serial_t serial; + struct key *key; + key_restrict_link_func_t link_fn = + restrict_link_by_key_or_keyring; + bool allow_null_key = false; + + key_text = strsep(&next, ":"); + + if (next) { + if (strcmp(next, "chain") != 0) + goto out; + + link_fn = restrict_link_by_key_or_keyring_chain; + allow_null_key = true; + } + + if (kstrtos32(key_text, 0, &serial) < 0) + goto out; + + if ((serial == 0) && allow_null_key) { + key = NULL; + } else { + key = key_lookup(serial); + if (IS_ERR(key)) { + ret = ERR_CAST(key); + goto out; + } + } + + ret = asymmetric_restriction_alloc(link_fn, key); + if (IS_ERR(ret)) + key_put(key); + } + +out: + kfree(parse_buf); + return ret; +} + +int asymmetric_key_eds_op(struct kernel_pkey_params *params, + const void *in, void *out) +{ + const struct asymmetric_key_subtype *subtype; + struct key *key = params->key; + int ret; + + pr_devel("==>%s()\n", __func__); + + if (key->type != &key_type_asymmetric) + return -EINVAL; + subtype = asymmetric_key_subtype(key); + if (!subtype || + !key->payload.data[0]) + return -EINVAL; + if (!subtype->eds_op) + return -ENOTSUPP; + + ret = subtype->eds_op(params, in, out); + + pr_devel("<==%s() = %d\n", __func__, ret); + return ret; +} + +static int asymmetric_key_verify_signature(struct kernel_pkey_params *params, + const void *in, const void *in2) +{ + struct public_key_signature sig = { + .s_size = params->in2_len, + .digest_size = params->in_len, + .encoding = params->encoding, + .hash_algo = params->hash_algo, + .digest = (void *)in, + .s = (void *)in2, + }; + + return verify_signature(params->key, &sig); +} + +struct key_type key_type_asymmetric = { + .name = "asymmetric", + .preparse = asymmetric_key_preparse, + .free_preparse = asymmetric_key_free_preparse, + .instantiate = generic_key_instantiate, + .match_preparse = asymmetric_key_match_preparse, + .match_free = asymmetric_key_match_free, + .destroy = asymmetric_key_destroy, + .describe = asymmetric_key_describe, + .lookup_restriction = asymmetric_lookup_restriction, + .asym_query = query_asymmetric_key, + .asym_eds_op = asymmetric_key_eds_op, + .asym_verify_signature = asymmetric_key_verify_signature, +}; +EXPORT_SYMBOL_GPL(key_type_asymmetric); + +/** + * register_asymmetric_key_parser - Register a asymmetric key blob parser + * @parser: The parser to register + */ +int register_asymmetric_key_parser(struct asymmetric_key_parser *parser) +{ + struct asymmetric_key_parser *cursor; + int ret; + + down_write(&asymmetric_key_parsers_sem); + + list_for_each_entry(cursor, &asymmetric_key_parsers, link) { + if (strcmp(cursor->name, parser->name) == 0) { + pr_err("Asymmetric key parser '%s' already registered\n", + parser->name); + ret = -EEXIST; + goto out; + } + } + + list_add_tail(&parser->link, &asymmetric_key_parsers); + + pr_notice("Asymmetric key parser '%s' registered\n", parser->name); + ret = 0; + +out: + up_write(&asymmetric_key_parsers_sem); + return ret; +} +EXPORT_SYMBOL_GPL(register_asymmetric_key_parser); + +/** + * unregister_asymmetric_key_parser - Unregister a asymmetric key blob parser + * @parser: The parser to unregister + */ +void unregister_asymmetric_key_parser(struct asymmetric_key_parser *parser) +{ + down_write(&asymmetric_key_parsers_sem); + list_del(&parser->link); + up_write(&asymmetric_key_parsers_sem); + + pr_notice("Asymmetric key parser '%s' unregistered\n", parser->name); +} +EXPORT_SYMBOL_GPL(unregister_asymmetric_key_parser); + +/* + * Module stuff + */ +static int __init asymmetric_key_init(void) +{ + return register_key_type(&key_type_asymmetric); +} + +static void __exit asymmetric_key_cleanup(void) +{ + unregister_key_type(&key_type_asymmetric); +} + +module_init(asymmetric_key_init); +module_exit(asymmetric_key_cleanup); +#endif /* !__UBOOT__ */ diff --git a/lib/crypto/public_key.c b/lib/crypto/public_key.c new file mode 100644 index 000000000000..634377472f40 --- /dev/null +++ b/lib/crypto/public_key.c @@ -0,0 +1,376 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* In-software asymmetric public-key crypto subtype + * + * See Documentation/crypto/asymmetric-keys.txt + * + * Copyright (C) 2012 Red Hat, Inc. All Rights Reserved. + * Written by David Howells (dhowells@redhat.com) + */ + +#define pr_fmt(fmt) "PKEY: "fmt +#ifdef __UBOOT__ +#include <linux/compat.h> +#else +#include <linux/module.h> +#include <linux/export.h> +#endif +#include <linux/kernel.h> +#ifndef __UBOOT__ +#include <linux/slab.h> +#include <linux/seq_file.h> +#include <linux/scatterlist.h> +#include <keys/asymmetric-subtype.h> +#endif +#include <crypto/public_key.h> +#ifndef __UBOOT__ +#include <crypto/akcipher.h> +#endif + +MODULE_DESCRIPTION("In-software asymmetric public-key subtype"); +MODULE_AUTHOR("Red Hat, Inc."); +MODULE_LICENSE("GPL"); + +#ifndef __UBOOT__ +/* + * Provide a part of a description of the key for /proc/keys. + */ +static void public_key_describe(const struct key *asymmetric_key, + struct seq_file *m) +{ + struct public_key *key = asymmetric_key->payload.data[asym_crypto]; + + if (key) + seq_printf(m, "%s.%s", key->id_type, key->pkey_algo); +} +#endif + +/* + * Destroy a public key algorithm key. + */ +void public_key_free(struct public_key *key) +{ + if (key) { + kfree(key->key); + kfree(key->params); + kfree(key); + } +} +EXPORT_SYMBOL_GPL(public_key_free); + +#ifdef __UBOOT__ +/* + * from <linux>/crypto/asymmetric_keys/signature.c + * + * Destroy a public key signature. + */ +void public_key_signature_free(struct public_key_signature *sig) +{ + int i; + + if (sig) { + for (i = 0; i < ARRAY_SIZE(sig->auth_ids); i++) + free(sig->auth_ids[i]); + free(sig->s); + free(sig->digest); + free(sig); + } +} +EXPORT_SYMBOL_GPL(public_key_signature_free); + +#else +/* + * Destroy a public key algorithm key. + */ +static void public_key_destroy(void *payload0, void *payload3) +{ + public_key_free(payload0); + public_key_signature_free(payload3); +} + +/* + * Determine the crypto algorithm name. + */ +static +int software_key_determine_akcipher(const char *encoding, + const char *hash_algo, + const struct public_key *pkey, + char alg_name[CRYPTO_MAX_ALG_NAME]) +{ + int n; + + if (strcmp(encoding, "pkcs1") == 0) { + /* The data wangled by the RSA algorithm is typically padded + * and encoded in some manner, such as EMSA-PKCS1-1_5 [RFC3447 + * sec 8.2]. + */ + if (!hash_algo) + n = snprintf(alg_name, CRYPTO_MAX_ALG_NAME, + "pkcs1pad(%s)", + pkey->pkey_algo); + else + n = snprintf(alg_name, CRYPTO_MAX_ALG_NAME, + "pkcs1pad(%s,%s)", + pkey->pkey_algo, hash_algo); + return n >= CRYPTO_MAX_ALG_NAME ? -EINVAL : 0; + } + + if (strcmp(encoding, "raw") == 0) { + strcpy(alg_name, pkey->pkey_algo); + return 0; + } + + return -ENOPKG; +} + +static u8 *pkey_pack_u32(u8 *dst, u32 val) +{ + memcpy(dst, &val, sizeof(val)); + return dst + sizeof(val); +} + +/* + * Query information about a key. + */ +static int software_key_query(const struct kernel_pkey_params *params, + struct kernel_pkey_query *info) +{ + struct crypto_akcipher *tfm; + struct public_key *pkey = params->key->payload.data[asym_crypto]; + char alg_name[CRYPTO_MAX_ALG_NAME]; + u8 *key, *ptr; + int ret, len; + + ret = software_key_determine_akcipher(params->encoding, + params->hash_algo, + pkey, alg_name); + if (ret < 0) + return ret; + + tfm = crypto_alloc_akcipher(alg_name, 0, 0); + if (IS_ERR(tfm)) + return PTR_ERR(tfm); + + key = kmalloc(pkey->keylen + sizeof(u32) * 2 + pkey->paramlen, + GFP_KERNEL); + if (!key) + goto error_free_tfm; + memcpy(key, pkey->key, pkey->keylen); + ptr = key + pkey->keylen; + ptr = pkey_pack_u32(ptr, pkey->algo); + ptr = pkey_pack_u32(ptr, pkey->paramlen); + memcpy(ptr, pkey->params, pkey->paramlen); + + if (pkey->key_is_private) + ret = crypto_akcipher_set_priv_key(tfm, key, pkey->keylen); + else + ret = crypto_akcipher_set_pub_key(tfm, key, pkey->keylen); + if (ret < 0) + goto error_free_key; + + len = crypto_akcipher_maxsize(tfm); + info->key_size = len * 8; + info->max_data_size = len; + info->max_sig_size = len; + info->max_enc_size = len; + info->max_dec_size = len; + info->supported_ops = (KEYCTL_SUPPORTS_ENCRYPT | + KEYCTL_SUPPORTS_VERIFY); + if (pkey->key_is_private) + info->supported_ops |= (KEYCTL_SUPPORTS_DECRYPT | + KEYCTL_SUPPORTS_SIGN); + ret = 0; + +error_free_key: + kfree(key); +error_free_tfm: + crypto_free_akcipher(tfm); + pr_devel("<==%s() = %d\n", __func__, ret); + return ret; +} + +/* + * Do encryption, decryption and signing ops. + */ +static int software_key_eds_op(struct kernel_pkey_params *params, + const void *in, void *out) +{ + const struct public_key *pkey = params->key->payload.data[asym_crypto]; + struct akcipher_request *req; + struct crypto_akcipher *tfm; + struct crypto_wait cwait; + struct scatterlist in_sg, out_sg; + char alg_name[CRYPTO_MAX_ALG_NAME]; + char *key, *ptr; + int ret; + + pr_devel("==>%s()\n", __func__); + + ret = software_key_determine_akcipher(params->encoding, + params->hash_algo, + pkey, alg_name); + if (ret < 0) + return ret; + + tfm = crypto_alloc_akcipher(alg_name, 0, 0); + if (IS_ERR(tfm)) + return PTR_ERR(tfm); + + req = akcipher_request_alloc(tfm, GFP_KERNEL); + if (!req) + goto error_free_tfm; + + key = kmalloc(pkey->keylen + sizeof(u32) * 2 + pkey->paramlen, + GFP_KERNEL); + if (!key) + goto error_free_req; + + memcpy(key, pkey->key, pkey->keylen); + ptr = key + pkey->keylen; + ptr = pkey_pack_u32(ptr, pkey->algo); + ptr = pkey_pack_u32(ptr, pkey->paramlen); + memcpy(ptr, pkey->params, pkey->paramlen); + + if (pkey->key_is_private) + ret = crypto_akcipher_set_priv_key(tfm, key, pkey->keylen); + else + ret = crypto_akcipher_set_pub_key(tfm, key, pkey->keylen); + if (ret) + goto error_free_key; + + sg_init_one(&in_sg, in, params->in_len); + sg_init_one(&out_sg, out, params->out_len); + akcipher_request_set_crypt(req, &in_sg, &out_sg, params->in_len, + params->out_len); + crypto_init_wait(&cwait); + akcipher_request_set_callback(req, CRYPTO_TFM_REQ_MAY_BACKLOG | + CRYPTO_TFM_REQ_MAY_SLEEP, + crypto_req_done, &cwait); + + /* Perform the encryption calculation. */ + switch (params->op) { + case kernel_pkey_encrypt: + ret = crypto_akcipher_encrypt(req); + break; + case kernel_pkey_decrypt: + ret = crypto_akcipher_decrypt(req); + break; + case kernel_pkey_sign: + ret = crypto_akcipher_sign(req); + break; + default: + BUG(); + } + + ret = crypto_wait_req(ret, &cwait); + if (ret == 0) + ret = req->dst_len; + +error_free_key: + kfree(key); +error_free_req: + akcipher_request_free(req); +error_free_tfm: + crypto_free_akcipher(tfm); + pr_devel("<==%s() = %d\n", __func__, ret); + return ret; +} + +/* + * Verify a signature using a public key. + */ +int public_key_verify_signature(const struct public_key *pkey, + const struct public_key_signature *sig) +{ + struct crypto_wait cwait; + struct crypto_akcipher *tfm; + struct akcipher_request *req; + struct scatterlist src_sg[2]; + char alg_name[CRYPTO_MAX_ALG_NAME]; + char *key, *ptr; + int ret; + + pr_devel("==>%s()\n", __func__); + + BUG_ON(!pkey); + BUG_ON(!sig); + BUG_ON(!sig->s); + + ret = software_key_determine_akcipher(sig->encoding, + sig->hash_algo, + pkey, alg_name); + if (ret < 0) + return ret; + + tfm = crypto_alloc_akcipher(alg_name, 0, 0); + if (IS_ERR(tfm)) + return PTR_ERR(tfm); + + ret = -ENOMEM; + req = akcipher_request_alloc(tfm, GFP_KERNEL); + if (!req) + goto error_free_tfm; + + key = kmalloc(pkey->keylen + sizeof(u32) * 2 + pkey->paramlen, + GFP_KERNEL); + if (!key) + goto error_free_req; + + memcpy(key, pkey->key, pkey->keylen); + ptr = key + pkey->keylen; + ptr = pkey_pack_u32(ptr, pkey->algo); + ptr = pkey_pack_u32(ptr, pkey->paramlen); + memcpy(ptr, pkey->params, pkey->paramlen); + + if (pkey->key_is_private) + ret = crypto_akcipher_set_priv_key(tfm, key, pkey->keylen); + else + ret = crypto_akcipher_set_pub_key(tfm, key, pkey->keylen); + if (ret) + goto error_free_key; + + sg_init_table(src_sg, 2); + sg_set_buf(&src_sg[0], sig->s, sig->s_size); + sg_set_buf(&src_sg[1], sig->digest, sig->digest_size); + akcipher_request_set_crypt(req, src_sg, NULL, sig->s_size, + sig->digest_size); + crypto_init_wait(&cwait); + akcipher_request_set_callback(req, CRYPTO_TFM_REQ_MAY_BACKLOG | + CRYPTO_TFM_REQ_MAY_SLEEP, + crypto_req_done, &cwait); + ret = crypto_wait_req(crypto_akcipher_verify(req), &cwait); + +error_free_key: + kfree(key); +error_free_req: + akcipher_request_free(req); +error_free_tfm: + crypto_free_akcipher(tfm); + pr_devel("<==%s() = %d\n", __func__, ret); + if (WARN_ON_ONCE(ret > 0)) + ret = -EINVAL; + return ret; +} +EXPORT_SYMBOL_GPL(public_key_verify_signature); + +static int public_key_verify_signature_2(const struct key *key, + const struct public_key_signature *sig) +{ + const struct public_key *pk = key->payload.data[asym_crypto]; + return public_key_verify_signature(pk, sig); +} + +/* + * Public key algorithm asymmetric key subtype + */ +struct asymmetric_key_subtype public_key_subtype = { + .owner = THIS_MODULE, + .name = "public_key", + .name_len = sizeof("public_key") - 1, + .describe = public_key_describe, + .destroy = public_key_destroy, + .query = software_key_query, + .eds_op = software_key_eds_op, + .verify_signature = public_key_verify_signature_2, +}; +EXPORT_SYMBOL_GPL(public_key_subtype); +#endif /* !__UBOOT__ */
Imported from linux kernel v5.3: rsapubkey.asn1 without changes rsa.h without changes rsa_helper.c with changes marked as __UBOOT__
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- include/crypto/internal/rsa.h | 57 ++++++++++ lib/crypto/Kconfig | 11 ++ lib/crypto/Makefile | 11 ++ lib/crypto/rsa_helper.c | 198 ++++++++++++++++++++++++++++++++++ lib/crypto/rsapubkey.asn1 | 4 + 5 files changed, 281 insertions(+) create mode 100644 include/crypto/internal/rsa.h create mode 100644 lib/crypto/rsa_helper.c create mode 100644 lib/crypto/rsapubkey.asn1
diff --git a/include/crypto/internal/rsa.h b/include/crypto/internal/rsa.h new file mode 100644 index 000000000000..e870133f4b77 --- /dev/null +++ b/include/crypto/internal/rsa.h @@ -0,0 +1,57 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* + * RSA internal helpers + * + * Copyright (c) 2015, Intel Corporation + * Authors: Tadeusz Struk tadeusz.struk@intel.com + */ +#ifndef _RSA_HELPER_ +#define _RSA_HELPER_ +#include <linux/types.h> + +/** + * rsa_key - RSA key structure + * @n : RSA modulus raw byte stream + * @e : RSA public exponent raw byte stream + * @d : RSA private exponent raw byte stream + * @p : RSA prime factor p of n raw byte stream + * @q : RSA prime factor q of n raw byte stream + * @dp : RSA exponent d mod (p - 1) raw byte stream + * @dq : RSA exponent d mod (q - 1) raw byte stream + * @qinv : RSA CRT coefficient q^(-1) mod p raw byte stream + * @n_sz : length in bytes of RSA modulus n + * @e_sz : length in bytes of RSA public exponent + * @d_sz : length in bytes of RSA private exponent + * @p_sz : length in bytes of p field + * @q_sz : length in bytes of q field + * @dp_sz : length in bytes of dp field + * @dq_sz : length in bytes of dq field + * @qinv_sz : length in bytes of qinv field + */ +struct rsa_key { + const u8 *n; + const u8 *e; + const u8 *d; + const u8 *p; + const u8 *q; + const u8 *dp; + const u8 *dq; + const u8 *qinv; + size_t n_sz; + size_t e_sz; + size_t d_sz; + size_t p_sz; + size_t q_sz; + size_t dp_sz; + size_t dq_sz; + size_t qinv_sz; +}; + +int rsa_parse_pub_key(struct rsa_key *rsa_key, const void *key, + unsigned int key_len); + +int rsa_parse_priv_key(struct rsa_key *rsa_key, const void *key, + unsigned int key_len); + +extern struct crypto_template rsa_pkcs1pad_tmpl; +#endif diff --git a/lib/crypto/Kconfig b/lib/crypto/Kconfig index b8e8288d2f80..9572ea8c87f3 100644 --- a/lib/crypto/Kconfig +++ b/lib/crypto/Kconfig @@ -16,4 +16,15 @@ config ASYMMETRIC_PUBLIC_KEY_SUBTYPE appropriate hash algorithms (such as SHA-1) must be available. ENOPKG will be reported if the requisite algorithm is unavailable.
+config RSA_PUBLIC_KEY_PARSER + bool "RSA public key parser" + depends on ASYMMETRIC_PUBLIC_KEY_SUBTYPE + select ASN1_DECODER + select ASN1_COMPILER + select OID_REGISTRY + help + This option provides support for parsing a blob containing RSA + public key data and provides the ability to instantiate a public + key. + endif # ASYMMETRIC_KEY_TYPE diff --git a/lib/crypto/Makefile b/lib/crypto/Makefile index a284de9e0411..69330a9ebd27 100644 --- a/lib/crypto/Makefile +++ b/lib/crypto/Makefile @@ -8,3 +8,14 @@ obj-$(CONFIG_ASYMMETRIC_KEY_TYPE) += asymmetric_keys.o asymmetric_keys-y := asymmetric_type.o
obj-$(CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE) += public_key.o + +# +# RSA public key parser +# +obj-$(CONFIG_RSA_PUBLIC_KEY_PARSER) += rsa_public_key.o +rsa_public_key-y := \ + rsapubkey.asn1.o \ + rsa_helper.o + +$(obj)/rsapubkey.asn1.o: $(obj)/rsapubkey.asn1.c $(obj)/rsapubkey.asn1.h +$(obj)/rsa_helper.o: $(obj)/rsapubkey.asn1.h diff --git a/lib/crypto/rsa_helper.c b/lib/crypto/rsa_helper.c new file mode 100644 index 000000000000..aca627a4a619 --- /dev/null +++ b/lib/crypto/rsa_helper.c @@ -0,0 +1,198 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * RSA key extract helper + * + * Copyright (c) 2015, Intel Corporation + * Authors: Tadeusz Struk tadeusz.struk@intel.com + */ +#ifndef __UBOOT__ +#include <linux/kernel.h> +#include <linux/export.h> +#endif +#include <linux/err.h> +#ifndef __UBOOT__ +#include <linux/fips.h> +#endif +#include <crypto/internal/rsa.h> +#include "rsapubkey.asn1.h" +#ifndef __UBOOT__ +#include "rsaprivkey.asn1.h" +#endif + +int rsa_get_n(void *context, size_t hdrlen, unsigned char tag, + const void *value, size_t vlen) +{ + struct rsa_key *key = context; +#ifndef __UBOOT__ + const u8 *ptr = value; + size_t n_sz = vlen; +#endif + + /* invalid key provided */ + if (!value || !vlen) + return -EINVAL; + +#ifndef __UBOOT__ + if (fips_enabled) { + while (n_sz && !*ptr) { + ptr++; + n_sz--; + } + + /* In FIPS mode only allow key size 2K and higher */ + if (n_sz < 256) { + pr_err("RSA: key size not allowed in FIPS mode\n"); + return -EINVAL; + } + } +#endif + + key->n = value; + key->n_sz = vlen; + + return 0; +} + +int rsa_get_e(void *context, size_t hdrlen, unsigned char tag, + const void *value, size_t vlen) +{ + struct rsa_key *key = context; + + /* invalid key provided */ + if (!value || !key->n_sz || !vlen || vlen > key->n_sz) + return -EINVAL; + + key->e = value; + key->e_sz = vlen; + + return 0; +} + +int rsa_get_d(void *context, size_t hdrlen, unsigned char tag, + const void *value, size_t vlen) +{ + struct rsa_key *key = context; + + /* invalid key provided */ + if (!value || !key->n_sz || !vlen || vlen > key->n_sz) + return -EINVAL; + + key->d = value; + key->d_sz = vlen; + + return 0; +} + +int rsa_get_p(void *context, size_t hdrlen, unsigned char tag, + const void *value, size_t vlen) +{ + struct rsa_key *key = context; + + /* invalid key provided */ + if (!value || !vlen || vlen > key->n_sz) + return -EINVAL; + + key->p = value; + key->p_sz = vlen; + + return 0; +} + +int rsa_get_q(void *context, size_t hdrlen, unsigned char tag, + const void *value, size_t vlen) +{ + struct rsa_key *key = context; + + /* invalid key provided */ + if (!value || !vlen || vlen > key->n_sz) + return -EINVAL; + + key->q = value; + key->q_sz = vlen; + + return 0; +} + +int rsa_get_dp(void *context, size_t hdrlen, unsigned char tag, + const void *value, size_t vlen) +{ + struct rsa_key *key = context; + + /* invalid key provided */ + if (!value || !vlen || vlen > key->n_sz) + return -EINVAL; + + key->dp = value; + key->dp_sz = vlen; + + return 0; +} + +int rsa_get_dq(void *context, size_t hdrlen, unsigned char tag, + const void *value, size_t vlen) +{ + struct rsa_key *key = context; + + /* invalid key provided */ + if (!value || !vlen || vlen > key->n_sz) + return -EINVAL; + + key->dq = value; + key->dq_sz = vlen; + + return 0; +} + +int rsa_get_qinv(void *context, size_t hdrlen, unsigned char tag, + const void *value, size_t vlen) +{ + struct rsa_key *key = context; + + /* invalid key provided */ + if (!value || !vlen || vlen > key->n_sz) + return -EINVAL; + + key->qinv = value; + key->qinv_sz = vlen; + + return 0; +} + +/** + * rsa_parse_pub_key() - decodes the BER encoded buffer and stores in the + * provided struct rsa_key, pointers to the raw key as is, + * so that the caller can copy it or MPI parse it, etc. + * + * @rsa_key: struct rsa_key key representation + * @key: key in BER format + * @key_len: length of key + * + * Return: 0 on success or error code in case of error + */ +int rsa_parse_pub_key(struct rsa_key *rsa_key, const void *key, + unsigned int key_len) +{ + return asn1_ber_decoder(&rsapubkey_decoder, rsa_key, key, key_len); +} +EXPORT_SYMBOL_GPL(rsa_parse_pub_key); + +#ifndef __UBOOT__ +/** + * rsa_parse_priv_key() - decodes the BER encoded buffer and stores in the + * provided struct rsa_key, pointers to the raw key + * as is, so that the caller can copy it or MPI parse it, + * etc. + * + * @rsa_key: struct rsa_key key representation + * @key: key in BER format + * @key_len: length of key + * + * Return: 0 on success or error code in case of error + */ +int rsa_parse_priv_key(struct rsa_key *rsa_key, const void *key, + unsigned int key_len) +{ + return asn1_ber_decoder(&rsaprivkey_decoder, rsa_key, key, key_len); +} +EXPORT_SYMBOL_GPL(rsa_parse_priv_key); +#endif diff --git a/lib/crypto/rsapubkey.asn1 b/lib/crypto/rsapubkey.asn1 new file mode 100644 index 000000000000..725498e461d2 --- /dev/null +++ b/lib/crypto/rsapubkey.asn1 @@ -0,0 +1,4 @@ +RsaPubKey ::= SEQUENCE { + n INTEGER ({ rsa_get_n }), + e INTEGER ({ rsa_get_e }) +}
Imported from linux kernel v5.3: x509.asn1 without changes x509_akid.asn1 without changes x509_parser.h without changes x509_cert_parser.c with changes marked as __UBOOT__ x509_public_key.c with changes marked as __UBOOT__
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- lib/Kconfig | 1 + lib/Makefile | 1 + lib/crypto/Kconfig | 12 + lib/crypto/Makefile | 17 + lib/crypto/x509.asn1 | 60 +++ lib/crypto/x509_akid.asn1 | 35 ++ lib/crypto/x509_cert_parser.c | 697 ++++++++++++++++++++++++++++++++++ lib/crypto/x509_parser.h | 57 +++ lib/crypto/x509_public_key.c | 292 ++++++++++++++ 9 files changed, 1172 insertions(+) create mode 100644 lib/crypto/x509.asn1 create mode 100644 lib/crypto/x509_akid.asn1 create mode 100644 lib/crypto/x509_cert_parser.c create mode 100644 lib/crypto/x509_parser.h create mode 100644 lib/crypto/x509_public_key.c
diff --git a/lib/Kconfig b/lib/Kconfig index 0431cfbd21f8..051ffce23b42 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -265,6 +265,7 @@ config AES present.
source lib/rsa/Kconfig +source lib/crypto/Kconfig
config TPM bool "Trusted Platform Module (TPM) Support" diff --git a/lib/Makefile b/lib/Makefile index 9b8305e3190f..0fb1710f5aca 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -18,6 +18,7 @@ obj-$(CONFIG_CMD_DHRYSTONE) += dhry/ obj-$(CONFIG_ARCH_AT91) += at91/ obj-$(CONFIG_OPTEE) += optee/ obj-$(CONFIG_ASN1_DECODER) += asn1_decoder.o +obj-y += crypto/
obj-$(CONFIG_AES) += aes.o
diff --git a/lib/crypto/Kconfig b/lib/crypto/Kconfig index 9572ea8c87f3..aeb599c593ac 100644 --- a/lib/crypto/Kconfig +++ b/lib/crypto/Kconfig @@ -27,4 +27,16 @@ config RSA_PUBLIC_KEY_PARSER public key data and provides the ability to instantiate a public key.
+config X509_CERTIFICATE_PARSER + bool "X.509 certificate parser" + depends on ASYMMETRIC_PUBLIC_KEY_SUBTYPE + select ASN1_DECODER + select ASN1_COMPILER + select OID_REGISTRY + select LIB_DATE + help + This option provides support for parsing X.509 format blobs for key + data and provides the ability to instantiate a crypto key from a + public key packet found inside the certificate. + endif # ASYMMETRIC_KEY_TYPE diff --git a/lib/crypto/Makefile b/lib/crypto/Makefile index 69330a9ebd27..d7e27be568a1 100644 --- a/lib/crypto/Makefile +++ b/lib/crypto/Makefile @@ -19,3 +19,20 @@ rsa_public_key-y := \
$(obj)/rsapubkey.asn1.o: $(obj)/rsapubkey.asn1.c $(obj)/rsapubkey.asn1.h $(obj)/rsa_helper.o: $(obj)/rsapubkey.asn1.h + +# +# X.509 Certificate handling +# +obj-$(CONFIG_X509_CERTIFICATE_PARSER) += x509_key_parser.o +x509_key_parser-y := \ + x509.asn1.o \ + x509_akid.asn1.o \ + x509_cert_parser.o \ + x509_public_key.o + +$(obj)/x509_cert_parser.o: \ + $(obj)/x509.asn1.h \ + $(obj)/x509_akid.asn1.h + +$(obj)/x509.asn1.o: $(obj)/x509.asn1.c $(obj)/x509.asn1.h +$(obj)/x509_akid.asn1.o: $(obj)/x509_akid.asn1.c $(obj)/x509_akid.asn1.h diff --git a/lib/crypto/x509.asn1 b/lib/crypto/x509.asn1 new file mode 100644 index 000000000000..5c9f4e4a5231 --- /dev/null +++ b/lib/crypto/x509.asn1 @@ -0,0 +1,60 @@ +Certificate ::= SEQUENCE { + tbsCertificate TBSCertificate ({ x509_note_tbs_certificate }), + signatureAlgorithm AlgorithmIdentifier, + signature BIT STRING ({ x509_note_signature }) + } + +TBSCertificate ::= SEQUENCE { + version [ 0 ] Version DEFAULT, + serialNumber CertificateSerialNumber ({ x509_note_serial }), + signature AlgorithmIdentifier ({ x509_note_pkey_algo }), + issuer Name ({ x509_note_issuer }), + validity Validity, + subject Name ({ x509_note_subject }), + subjectPublicKeyInfo SubjectPublicKeyInfo, + issuerUniqueID [ 1 ] IMPLICIT UniqueIdentifier OPTIONAL, + subjectUniqueID [ 2 ] IMPLICIT UniqueIdentifier OPTIONAL, + extensions [ 3 ] Extensions OPTIONAL + } + +Version ::= INTEGER +CertificateSerialNumber ::= INTEGER + +AlgorithmIdentifier ::= SEQUENCE { + algorithm OBJECT IDENTIFIER ({ x509_note_OID }), + parameters ANY OPTIONAL ({ x509_note_params }) +} + +Name ::= SEQUENCE OF RelativeDistinguishedName + +RelativeDistinguishedName ::= SET OF AttributeValueAssertion + +AttributeValueAssertion ::= SEQUENCE { + attributeType OBJECT IDENTIFIER ({ x509_note_OID }), + attributeValue ANY ({ x509_extract_name_segment }) + } + +Validity ::= SEQUENCE { + notBefore Time ({ x509_note_not_before }), + notAfter Time ({ x509_note_not_after }) + } + +Time ::= CHOICE { + utcTime UTCTime, + generalTime GeneralizedTime + } + +SubjectPublicKeyInfo ::= SEQUENCE { + algorithm AlgorithmIdentifier, + subjectPublicKey BIT STRING ({ x509_extract_key_data }) + } + +UniqueIdentifier ::= BIT STRING + +Extensions ::= SEQUENCE OF Extension + +Extension ::= SEQUENCE { + extnid OBJECT IDENTIFIER ({ x509_note_OID }), + critical BOOLEAN DEFAULT, + extnValue OCTET STRING ({ x509_process_extension }) + } diff --git a/lib/crypto/x509_akid.asn1 b/lib/crypto/x509_akid.asn1 new file mode 100644 index 000000000000..1a33231a75a8 --- /dev/null +++ b/lib/crypto/x509_akid.asn1 @@ -0,0 +1,35 @@ +-- X.509 AuthorityKeyIdentifier +-- rfc5280 section 4.2.1.1 + +AuthorityKeyIdentifier ::= SEQUENCE { + keyIdentifier [0] IMPLICIT KeyIdentifier OPTIONAL, + authorityCertIssuer [1] IMPLICIT GeneralNames OPTIONAL, + authorityCertSerialNumber [2] IMPLICIT CertificateSerialNumber OPTIONAL + } + +KeyIdentifier ::= OCTET STRING ({ x509_akid_note_kid }) + +CertificateSerialNumber ::= INTEGER ({ x509_akid_note_serial }) + +GeneralNames ::= SEQUENCE OF GeneralName + +GeneralName ::= CHOICE { + otherName [0] ANY, + rfc822Name [1] IA5String, + dNSName [2] IA5String, + x400Address [3] ANY, + directoryName [4] Name ({ x509_akid_note_name }), + ediPartyName [5] ANY, + uniformResourceIdentifier [6] IA5String, + iPAddress [7] OCTET STRING, + registeredID [8] OBJECT IDENTIFIER + } + +Name ::= SEQUENCE OF RelativeDistinguishedName + +RelativeDistinguishedName ::= SET OF AttributeValueAssertion + +AttributeValueAssertion ::= SEQUENCE { + attributeType OBJECT IDENTIFIER ({ x509_note_OID }), + attributeValue ANY ({ x509_extract_name_segment }) + } diff --git a/lib/crypto/x509_cert_parser.c b/lib/crypto/x509_cert_parser.c new file mode 100644 index 000000000000..e6d2a426a0bc --- /dev/null +++ b/lib/crypto/x509_cert_parser.c @@ -0,0 +1,697 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* X.509 certificate parser + * + * Copyright (C) 2012 Red Hat, Inc. All Rights Reserved. + * Written by David Howells (dhowells@redhat.com) + */ + +#define pr_fmt(fmt) "X.509: "fmt +#include <linux/kernel.h> +#ifndef __UBOOT__ +#include <linux/export.h> +#include <linux/slab.h> +#endif +#include <linux/err.h> +#include <linux/oid_registry.h> +#ifdef __UBOOT__ +#include <linux/string.h> +#endif +#include <crypto/public_key.h> +#include "x509_parser.h" +#include "x509.asn1.h" +#include "x509_akid.asn1.h" + +struct x509_parse_context { + struct x509_certificate *cert; /* Certificate being constructed */ + unsigned long data; /* Start of data */ + const void *cert_start; /* Start of cert content */ + const void *key; /* Key data */ + size_t key_size; /* Size of key data */ + const void *params; /* Key parameters */ + size_t params_size; /* Size of key parameters */ + enum OID key_algo; /* Public key algorithm */ + enum OID last_oid; /* Last OID encountered */ + enum OID algo_oid; /* Algorithm OID */ + unsigned char nr_mpi; /* Number of MPIs stored */ + u8 o_size; /* Size of organizationName (O) */ + u8 cn_size; /* Size of commonName (CN) */ + u8 email_size; /* Size of emailAddress */ + u16 o_offset; /* Offset of organizationName (O) */ + u16 cn_offset; /* Offset of commonName (CN) */ + u16 email_offset; /* Offset of emailAddress */ + unsigned raw_akid_size; + const void *raw_akid; /* Raw authorityKeyId in ASN.1 */ + const void *akid_raw_issuer; /* Raw directoryName in authorityKeyId */ + unsigned akid_raw_issuer_size; +}; + +/* + * Free an X.509 certificate + */ +void x509_free_certificate(struct x509_certificate *cert) +{ + if (cert) { + public_key_free(cert->pub); + public_key_signature_free(cert->sig); + kfree(cert->issuer); + kfree(cert->subject); + kfree(cert->id); + kfree(cert->skid); + kfree(cert); + } +} +EXPORT_SYMBOL_GPL(x509_free_certificate); + +/* + * Parse an X.509 certificate + */ +struct x509_certificate *x509_cert_parse(const void *data, size_t datalen) +{ + struct x509_certificate *cert; + struct x509_parse_context *ctx; + struct asymmetric_key_id *kid; + long ret; + + ret = -ENOMEM; + cert = kzalloc(sizeof(struct x509_certificate), GFP_KERNEL); + if (!cert) + goto error_no_cert; + cert->pub = kzalloc(sizeof(struct public_key), GFP_KERNEL); + if (!cert->pub) + goto error_no_ctx; + cert->sig = kzalloc(sizeof(struct public_key_signature), GFP_KERNEL); + if (!cert->sig) + goto error_no_ctx; + ctx = kzalloc(sizeof(struct x509_parse_context), GFP_KERNEL); + if (!ctx) + goto error_no_ctx; + + ctx->cert = cert; + ctx->data = (unsigned long)data; + + /* Attempt to decode the certificate */ + ret = asn1_ber_decoder(&x509_decoder, ctx, data, datalen); + if (ret < 0) + goto error_decode; + + /* Decode the AuthorityKeyIdentifier */ + if (ctx->raw_akid) { + pr_devel("AKID: %u %*phN\n", + ctx->raw_akid_size, ctx->raw_akid_size, ctx->raw_akid); + ret = asn1_ber_decoder(&x509_akid_decoder, ctx, + ctx->raw_akid, ctx->raw_akid_size); + if (ret < 0) { + pr_warn("Couldn't decode AuthKeyIdentifier\n"); + goto error_decode; + } + } + + ret = -ENOMEM; + cert->pub->key = kmemdup(ctx->key, ctx->key_size, GFP_KERNEL); + if (!cert->pub->key) + goto error_decode; + + cert->pub->keylen = ctx->key_size; + + cert->pub->params = kmemdup(ctx->params, ctx->params_size, GFP_KERNEL); + if (!cert->pub->params) + goto error_decode; + + cert->pub->paramlen = ctx->params_size; + cert->pub->algo = ctx->key_algo; + + /* Grab the signature bits */ + ret = x509_get_sig_params(cert); + if (ret < 0) + goto error_decode; + + /* Generate cert issuer + serial number key ID */ + kid = asymmetric_key_generate_id(cert->raw_serial, + cert->raw_serial_size, + cert->raw_issuer, + cert->raw_issuer_size); + if (IS_ERR(kid)) { + ret = PTR_ERR(kid); + goto error_decode; + } + cert->id = kid; + +#ifndef __UBOOT__ + /* Detect self-signed certificates */ + ret = x509_check_for_self_signed(cert); + if (ret < 0) + goto error_decode; +#endif + + kfree(ctx); + return cert; + +error_decode: + kfree(ctx); +error_no_ctx: + x509_free_certificate(cert); +error_no_cert: + return ERR_PTR(ret); +} +EXPORT_SYMBOL_GPL(x509_cert_parse); + +/* + * Note an OID when we find one for later processing when we know how + * to interpret it. + */ +int x509_note_OID(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct x509_parse_context *ctx = context; + + ctx->last_oid = look_up_OID(value, vlen); + if (ctx->last_oid == OID__NR) { + char buffer[50]; + sprint_oid(value, vlen, buffer, sizeof(buffer)); + pr_debug("Unknown OID: [%lu] %s\n", + (unsigned long)value - ctx->data, buffer); + } + return 0; +} + +/* + * Save the position of the TBS data so that we can check the signature over it + * later. + */ +int x509_note_tbs_certificate(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct x509_parse_context *ctx = context; + + pr_debug("x509_note_tbs_certificate(,%zu,%02x,%ld,%zu)!\n", + hdrlen, tag, (unsigned long)value - ctx->data, vlen); + + ctx->cert->tbs = value - hdrlen; + ctx->cert->tbs_size = vlen + hdrlen; + return 0; +} + +/* + * Record the public key algorithm + */ +int x509_note_pkey_algo(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct x509_parse_context *ctx = context; + + pr_debug("PubKey Algo: %u\n", ctx->last_oid); + + switch (ctx->last_oid) { + case OID_md2WithRSAEncryption: + case OID_md3WithRSAEncryption: + default: + return -ENOPKG; /* Unsupported combination */ + + case OID_md4WithRSAEncryption: + ctx->cert->sig->hash_algo = "md4"; + goto rsa_pkcs1; + + case OID_sha1WithRSAEncryption: + ctx->cert->sig->hash_algo = "sha1"; + goto rsa_pkcs1; + + case OID_sha256WithRSAEncryption: + ctx->cert->sig->hash_algo = "sha256"; + goto rsa_pkcs1; + + case OID_sha384WithRSAEncryption: + ctx->cert->sig->hash_algo = "sha384"; + goto rsa_pkcs1; + + case OID_sha512WithRSAEncryption: + ctx->cert->sig->hash_algo = "sha512"; + goto rsa_pkcs1; + + case OID_sha224WithRSAEncryption: + ctx->cert->sig->hash_algo = "sha224"; + goto rsa_pkcs1; + + case OID_gost2012Signature256: + ctx->cert->sig->hash_algo = "streebog256"; + goto ecrdsa; + + case OID_gost2012Signature512: + ctx->cert->sig->hash_algo = "streebog512"; + goto ecrdsa; + } + +rsa_pkcs1: + ctx->cert->sig->pkey_algo = "rsa"; + ctx->cert->sig->encoding = "pkcs1"; + ctx->algo_oid = ctx->last_oid; + return 0; +ecrdsa: + ctx->cert->sig->pkey_algo = "ecrdsa"; + ctx->cert->sig->encoding = "raw"; + ctx->algo_oid = ctx->last_oid; + return 0; +} + +/* + * Note the whereabouts and type of the signature. + */ +int x509_note_signature(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct x509_parse_context *ctx = context; + + pr_debug("Signature type: %u size %zu\n", ctx->last_oid, vlen); + + if (ctx->last_oid != ctx->algo_oid) { + pr_warn("Got cert with pkey (%u) and sig (%u) algorithm OIDs\n", + ctx->algo_oid, ctx->last_oid); + return -EINVAL; + } + + if (strcmp(ctx->cert->sig->pkey_algo, "rsa") == 0 || + strcmp(ctx->cert->sig->pkey_algo, "ecrdsa") == 0) { + /* Discard the BIT STRING metadata */ + if (vlen < 1 || *(const u8 *)value != 0) + return -EBADMSG; + + value++; + vlen--; + } + + ctx->cert->raw_sig = value; + ctx->cert->raw_sig_size = vlen; + return 0; +} + +/* + * Note the certificate serial number + */ +int x509_note_serial(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct x509_parse_context *ctx = context; + ctx->cert->raw_serial = value; + ctx->cert->raw_serial_size = vlen; + return 0; +} + +/* + * Note some of the name segments from which we'll fabricate a name. + */ +int x509_extract_name_segment(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct x509_parse_context *ctx = context; + + switch (ctx->last_oid) { + case OID_commonName: + ctx->cn_size = vlen; + ctx->cn_offset = (unsigned long)value - ctx->data; + break; + case OID_organizationName: + ctx->o_size = vlen; + ctx->o_offset = (unsigned long)value - ctx->data; + break; + case OID_email_address: + ctx->email_size = vlen; + ctx->email_offset = (unsigned long)value - ctx->data; + break; + default: + break; + } + + return 0; +} + +/* + * Fabricate and save the issuer and subject names + */ +static int x509_fabricate_name(struct x509_parse_context *ctx, size_t hdrlen, + unsigned char tag, + char **_name, size_t vlen) +{ + const void *name, *data = (const void *)ctx->data; + size_t namesize; + char *buffer; + + if (*_name) + return -EINVAL; + + /* Empty name string if no material */ + if (!ctx->cn_size && !ctx->o_size && !ctx->email_size) { + buffer = kmalloc(1, GFP_KERNEL); + if (!buffer) + return -ENOMEM; + buffer[0] = 0; + goto done; + } + + if (ctx->cn_size && ctx->o_size) { + /* Consider combining O and CN, but use only the CN if it is + * prefixed by the O, or a significant portion thereof. + */ + namesize = ctx->cn_size; + name = data + ctx->cn_offset; + if (ctx->cn_size >= ctx->o_size && + memcmp(data + ctx->cn_offset, data + ctx->o_offset, + ctx->o_size) == 0) + goto single_component; + if (ctx->cn_size >= 7 && + ctx->o_size >= 7 && + memcmp(data + ctx->cn_offset, data + ctx->o_offset, 7) == 0) + goto single_component; + + buffer = kmalloc(ctx->o_size + 2 + ctx->cn_size + 1, + GFP_KERNEL); + if (!buffer) + return -ENOMEM; + + memcpy(buffer, + data + ctx->o_offset, ctx->o_size); + buffer[ctx->o_size + 0] = ':'; + buffer[ctx->o_size + 1] = ' '; + memcpy(buffer + ctx->o_size + 2, + data + ctx->cn_offset, ctx->cn_size); + buffer[ctx->o_size + 2 + ctx->cn_size] = 0; + goto done; + + } else if (ctx->cn_size) { + namesize = ctx->cn_size; + name = data + ctx->cn_offset; + } else if (ctx->o_size) { + namesize = ctx->o_size; + name = data + ctx->o_offset; + } else { + namesize = ctx->email_size; + name = data + ctx->email_offset; + } + +single_component: + buffer = kmalloc(namesize + 1, GFP_KERNEL); + if (!buffer) + return -ENOMEM; + memcpy(buffer, name, namesize); + buffer[namesize] = 0; + +done: + *_name = buffer; + ctx->cn_size = 0; + ctx->o_size = 0; + ctx->email_size = 0; + return 0; +} + +int x509_note_issuer(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct x509_parse_context *ctx = context; + ctx->cert->raw_issuer = value; + ctx->cert->raw_issuer_size = vlen; + return x509_fabricate_name(ctx, hdrlen, tag, &ctx->cert->issuer, vlen); +} + +int x509_note_subject(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct x509_parse_context *ctx = context; + ctx->cert->raw_subject = value; + ctx->cert->raw_subject_size = vlen; + return x509_fabricate_name(ctx, hdrlen, tag, &ctx->cert->subject, vlen); +} + +/* + * Extract the parameters for the public key + */ +int x509_note_params(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct x509_parse_context *ctx = context; + + /* + * AlgorithmIdentifier is used three times in the x509, we should skip + * first and ignore third, using second one which is after subject and + * before subjectPublicKey. + */ + if (!ctx->cert->raw_subject || ctx->key) + return 0; + ctx->params = value - hdrlen; + ctx->params_size = vlen + hdrlen; + return 0; +} + +/* + * Extract the data for the public key algorithm + */ +int x509_extract_key_data(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct x509_parse_context *ctx = context; + + ctx->key_algo = ctx->last_oid; + if (ctx->last_oid == OID_rsaEncryption) + ctx->cert->pub->pkey_algo = "rsa"; + else if (ctx->last_oid == OID_gost2012PKey256 || + ctx->last_oid == OID_gost2012PKey512) + ctx->cert->pub->pkey_algo = "ecrdsa"; + else + return -ENOPKG; + + /* Discard the BIT STRING metadata */ + if (vlen < 1 || *(const u8 *)value != 0) + return -EBADMSG; + ctx->key = value + 1; + ctx->key_size = vlen - 1; + return 0; +} + +/* The keyIdentifier in AuthorityKeyIdentifier SEQUENCE is tag(CONT,PRIM,0) */ +#define SEQ_TAG_KEYID (ASN1_CONT << 6) + +/* + * Process certificate extensions that are used to qualify the certificate. + */ +int x509_process_extension(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct x509_parse_context *ctx = context; + struct asymmetric_key_id *kid; + const unsigned char *v = value; + + pr_debug("Extension: %u\n", ctx->last_oid); + + if (ctx->last_oid == OID_subjectKeyIdentifier) { + /* Get hold of the key fingerprint */ + if (ctx->cert->skid || vlen < 3) + return -EBADMSG; + if (v[0] != ASN1_OTS || v[1] != vlen - 2) + return -EBADMSG; + v += 2; + vlen -= 2; + + ctx->cert->raw_skid_size = vlen; + ctx->cert->raw_skid = v; + kid = asymmetric_key_generate_id(v, vlen, "", 0); + if (IS_ERR(kid)) + return PTR_ERR(kid); + ctx->cert->skid = kid; + pr_debug("subjkeyid %*phN\n", kid->len, kid->data); + return 0; + } + + if (ctx->last_oid == OID_authorityKeyIdentifier) { + /* Get hold of the CA key fingerprint */ + ctx->raw_akid = v; + ctx->raw_akid_size = vlen; + return 0; + } + + return 0; +} + +/** + * x509_decode_time - Decode an X.509 time ASN.1 object + * @_t: The time to fill in + * @hdrlen: The length of the object header + * @tag: The object tag + * @value: The object value + * @vlen: The size of the object value + * + * Decode an ASN.1 universal time or generalised time field into a struct the + * kernel can handle and check it for validity. The time is decoded thus: + * + * [RFC5280 §4.1.2.5] + * CAs conforming to this profile MUST always encode certificate validity + * dates through the year 2049 as UTCTime; certificate validity dates in + * 2050 or later MUST be encoded as GeneralizedTime. Conforming + * applications MUST be able to process validity dates that are encoded in + * either UTCTime or GeneralizedTime. + */ +int x509_decode_time(time64_t *_t, size_t hdrlen, + unsigned char tag, + const unsigned char *value, size_t vlen) +{ + static const unsigned char month_lengths[] = { 31, 28, 31, 30, 31, 30, + 31, 31, 30, 31, 30, 31 }; + const unsigned char *p = value; + unsigned year, mon, day, hour, min, sec, mon_len; + +#define dec2bin(X) ({ unsigned char x = (X) - '0'; if (x > 9) goto invalid_time; x; }) +#define DD2bin(P) ({ unsigned x = dec2bin(P[0]) * 10 + dec2bin(P[1]); P += 2; x; }) + + if (tag == ASN1_UNITIM) { + /* UTCTime: YYMMDDHHMMSSZ */ + if (vlen != 13) + goto unsupported_time; + year = DD2bin(p); + if (year >= 50) + year += 1900; + else + year += 2000; + } else if (tag == ASN1_GENTIM) { + /* GenTime: YYYYMMDDHHMMSSZ */ + if (vlen != 15) + goto unsupported_time; + year = DD2bin(p) * 100 + DD2bin(p); + if (year >= 1950 && year <= 2049) + goto invalid_time; + } else { + goto unsupported_time; + } + + mon = DD2bin(p); + day = DD2bin(p); + hour = DD2bin(p); + min = DD2bin(p); + sec = DD2bin(p); + + if (*p != 'Z') + goto unsupported_time; + + if (year < 1970 || + mon < 1 || mon > 12) + goto invalid_time; + + mon_len = month_lengths[mon - 1]; + if (mon == 2) { + if (year % 4 == 0) { + mon_len = 29; + if (year % 100 == 0) { + mon_len = 28; + if (year % 400 == 0) + mon_len = 29; + } + } + } + + if (day < 1 || day > mon_len || + hour > 24 || /* ISO 8601 permits 24:00:00 as midnight tomorrow */ + min > 59 || + sec > 60) /* ISO 8601 permits leap seconds [X.680 46.3] */ + goto invalid_time; + + *_t = mktime64(year, mon, day, hour, min, sec); + return 0; + +unsupported_time: + pr_debug("Got unsupported time [tag %02x]: '%*phN'\n", + tag, (int)vlen, value); + return -EBADMSG; +invalid_time: + pr_debug("Got invalid time [tag %02x]: '%*phN'\n", + tag, (int)vlen, value); + return -EBADMSG; +} +EXPORT_SYMBOL_GPL(x509_decode_time); + +int x509_note_not_before(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct x509_parse_context *ctx = context; + return x509_decode_time(&ctx->cert->valid_from, hdrlen, tag, value, vlen); +} + +int x509_note_not_after(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct x509_parse_context *ctx = context; + return x509_decode_time(&ctx->cert->valid_to, hdrlen, tag, value, vlen); +} + +/* + * Note a key identifier-based AuthorityKeyIdentifier + */ +int x509_akid_note_kid(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct x509_parse_context *ctx = context; + struct asymmetric_key_id *kid; + + pr_debug("AKID: keyid: %*phN\n", (int)vlen, value); + + if (ctx->cert->sig->auth_ids[1]) + return 0; + + kid = asymmetric_key_generate_id(value, vlen, "", 0); + if (IS_ERR(kid)) + return PTR_ERR(kid); + pr_debug("authkeyid %*phN\n", kid->len, kid->data); + ctx->cert->sig->auth_ids[1] = kid; + return 0; +} + +/* + * Note a directoryName in an AuthorityKeyIdentifier + */ +int x509_akid_note_name(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct x509_parse_context *ctx = context; + + pr_debug("AKID: name: %*phN\n", (int)vlen, value); + + ctx->akid_raw_issuer = value; + ctx->akid_raw_issuer_size = vlen; + return 0; +} + +/* + * Note a serial number in an AuthorityKeyIdentifier + */ +int x509_akid_note_serial(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct x509_parse_context *ctx = context; + struct asymmetric_key_id *kid; + + pr_debug("AKID: serial: %*phN\n", (int)vlen, value); + + if (!ctx->akid_raw_issuer || ctx->cert->sig->auth_ids[0]) + return 0; + + kid = asymmetric_key_generate_id(value, + vlen, + ctx->akid_raw_issuer, + ctx->akid_raw_issuer_size); + if (IS_ERR(kid)) + return PTR_ERR(kid); + + pr_debug("authkeyid %*phN\n", kid->len, kid->data); + ctx->cert->sig->auth_ids[0] = kid; + return 0; +} diff --git a/lib/crypto/x509_parser.h b/lib/crypto/x509_parser.h new file mode 100644 index 000000000000..c233f136fb35 --- /dev/null +++ b/lib/crypto/x509_parser.h @@ -0,0 +1,57 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* X.509 certificate parser internal definitions + * + * Copyright (C) 2012 Red Hat, Inc. All Rights Reserved. + * Written by David Howells (dhowells@redhat.com) + */ + +#include <linux/time.h> +#include <crypto/public_key.h> +#include <keys/asymmetric-type.h> + +struct x509_certificate { + struct x509_certificate *next; + struct x509_certificate *signer; /* Certificate that signed this one */ + struct public_key *pub; /* Public key details */ + struct public_key_signature *sig; /* Signature parameters */ + char *issuer; /* Name of certificate issuer */ + char *subject; /* Name of certificate subject */ + struct asymmetric_key_id *id; /* Issuer + Serial number */ + struct asymmetric_key_id *skid; /* Subject + subjectKeyId (optional) */ + time64_t valid_from; + time64_t valid_to; + const void *tbs; /* Signed data */ + unsigned tbs_size; /* Size of signed data */ + unsigned raw_sig_size; /* Size of sigature */ + const void *raw_sig; /* Signature data */ + const void *raw_serial; /* Raw serial number in ASN.1 */ + unsigned raw_serial_size; + unsigned raw_issuer_size; + const void *raw_issuer; /* Raw issuer name in ASN.1 */ + const void *raw_subject; /* Raw subject name in ASN.1 */ + unsigned raw_subject_size; + unsigned raw_skid_size; + const void *raw_skid; /* Raw subjectKeyId in ASN.1 */ + unsigned index; + bool seen; /* Infinite recursion prevention */ + bool verified; + bool self_signed; /* T if self-signed (check unsupported_sig too) */ + bool unsupported_key; /* T if key uses unsupported crypto */ + bool unsupported_sig; /* T if signature uses unsupported crypto */ + bool blacklisted; +}; + +/* + * x509_cert_parser.c + */ +extern void x509_free_certificate(struct x509_certificate *cert); +extern struct x509_certificate *x509_cert_parse(const void *data, size_t datalen); +extern int x509_decode_time(time64_t *_t, size_t hdrlen, + unsigned char tag, + const unsigned char *value, size_t vlen); + +/* + * x509_public_key.c + */ +extern int x509_get_sig_params(struct x509_certificate *cert); +extern int x509_check_for_self_signed(struct x509_certificate *cert); diff --git a/lib/crypto/x509_public_key.c b/lib/crypto/x509_public_key.c new file mode 100644 index 000000000000..04bdb672b496 --- /dev/null +++ b/lib/crypto/x509_public_key.c @@ -0,0 +1,292 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* Instantiate a public key crypto key from an X.509 Certificate + * + * Copyright (C) 2012 Red Hat, Inc. All Rights Reserved. + * Written by David Howells (dhowells@redhat.com) + */ + +#define pr_fmt(fmt) "X.509: "fmt +#ifdef __UBOOT__ +#include <common.h> +#include <linux/compat.h> +#include <linux/errno.h> +#else +#include <linux/module.h> +#endif +#include <linux/kernel.h> +#ifndef __UBOOT__ +#include <linux/slab.h> +#include <keys/asymmetric-subtype.h> +#include <keys/asymmetric-parser.h> +#include <keys/system_keyring.h> +#include <crypto/hash.h> +#include "asymmetric_keys.h" +#endif +#include "x509_parser.h" + +/* + * Set up the signature parameters in an X.509 certificate. This involves + * digesting the signed data and extracting the signature. + */ +int x509_get_sig_params(struct x509_certificate *cert) +{ + struct public_key_signature *sig = cert->sig; +#ifndef __UBOOT__ + struct crypto_shash *tfm; + struct shash_desc *desc; + size_t desc_size; +#endif + int ret; + + pr_devel("==>%s()\n", __func__); + + if (!cert->pub->pkey_algo) + cert->unsupported_key = true; + + if (!sig->pkey_algo) + cert->unsupported_sig = true; + + /* We check the hash if we can - even if we can't then verify it */ + if (!sig->hash_algo) { + cert->unsupported_sig = true; + return 0; + } + + sig->s = kmemdup(cert->raw_sig, cert->raw_sig_size, GFP_KERNEL); + if (!sig->s) + return -ENOMEM; + + sig->s_size = cert->raw_sig_size; + +#ifdef __UBOOT__ + /* + * Note: + * This part (filling sig->digest) should be implemented if + * x509_check_for_self_signed() is enabled x509_cert_parse(). + * Currently, this check won't affect UEFI secure boot. + */ + ret = 0; +#else + /* Allocate the hashing algorithm we're going to need and find out how + * big the hash operational data will be. + */ + tfm = crypto_alloc_shash(sig->hash_algo, 0, 0); + if (IS_ERR(tfm)) { + if (PTR_ERR(tfm) == -ENOENT) { + cert->unsupported_sig = true; + return 0; + } + return PTR_ERR(tfm); + } + + desc_size = crypto_shash_descsize(tfm) + sizeof(*desc); + sig->digest_size = crypto_shash_digestsize(tfm); + + ret = -ENOMEM; + sig->digest = kmalloc(sig->digest_size, GFP_KERNEL); + if (!sig->digest) + goto error; + + desc = kzalloc(desc_size, GFP_KERNEL); + if (!desc) + goto error; + + desc->tfm = tfm; + + ret = crypto_shash_digest(desc, cert->tbs, cert->tbs_size, sig->digest); + if (ret < 0) + goto error_2; + + ret = is_hash_blacklisted(sig->digest, sig->digest_size, "tbs"); + if (ret == -EKEYREJECTED) { + pr_err("Cert %*phN is blacklisted\n", + sig->digest_size, sig->digest); + cert->blacklisted = true; + ret = 0; + } + +error_2: + kfree(desc); +error: + crypto_free_shash(tfm); +#endif /* __UBOOT__ */ + pr_devel("<==%s() = %d\n", __func__, ret); + return ret; +} + +#ifndef __UBOOT__ +/* + * Check for self-signedness in an X.509 cert and if found, check the signature + * immediately if we can. + */ +int x509_check_for_self_signed(struct x509_certificate *cert) +{ + int ret = 0; + + pr_devel("==>%s()\n", __func__); + + if (cert->raw_subject_size != cert->raw_issuer_size || + memcmp(cert->raw_subject, cert->raw_issuer, + cert->raw_issuer_size) != 0) + goto not_self_signed; + + if (cert->sig->auth_ids[0] || cert->sig->auth_ids[1]) { + /* If the AKID is present it may have one or two parts. If + * both are supplied, both must match. + */ + bool a = asymmetric_key_id_same(cert->skid, cert->sig->auth_ids[1]); + bool b = asymmetric_key_id_same(cert->id, cert->sig->auth_ids[0]); + + if (!a && !b) + goto not_self_signed; + + ret = -EKEYREJECTED; + if (((a && !b) || (b && !a)) && + cert->sig->auth_ids[0] && cert->sig->auth_ids[1]) + goto out; + } + + ret = -EKEYREJECTED; + if (strcmp(cert->pub->pkey_algo, cert->sig->pkey_algo) != 0) + goto out; + + ret = public_key_verify_signature(cert->pub, cert->sig); + if (ret < 0) { + if (ret == -ENOPKG) { + cert->unsupported_sig = true; + ret = 0; + } + goto out; + } + + pr_devel("Cert Self-signature verified"); + cert->self_signed = true; + +out: + pr_devel("<==%s() = %d\n", __func__, ret); + return ret; + +not_self_signed: + pr_devel("<==%s() = 0 [not]\n", __func__); + return 0; +} + +/* + * Attempt to parse a data blob for a key as an X509 certificate. + */ +static int x509_key_preparse(struct key_preparsed_payload *prep) +{ + struct asymmetric_key_ids *kids; + struct x509_certificate *cert; + const char *q; + size_t srlen, sulen; + char *desc = NULL, *p; + int ret; + + cert = x509_cert_parse(prep->data, prep->datalen); + if (IS_ERR(cert)) + return PTR_ERR(cert); + + pr_devel("Cert Issuer: %s\n", cert->issuer); + pr_devel("Cert Subject: %s\n", cert->subject); + + if (cert->unsupported_key) { + ret = -ENOPKG; + goto error_free_cert; + } + + pr_devel("Cert Key Algo: %s\n", cert->pub->pkey_algo); + pr_devel("Cert Valid period: %lld-%lld\n", cert->valid_from, cert->valid_to); + + cert->pub->id_type = "X509"; + + if (cert->unsupported_sig) { + public_key_signature_free(cert->sig); + cert->sig = NULL; + } else { + pr_devel("Cert Signature: %s + %s\n", + cert->sig->pkey_algo, cert->sig->hash_algo); + } + + /* Don't permit addition of blacklisted keys */ + ret = -EKEYREJECTED; + if (cert->blacklisted) + goto error_free_cert; + + /* Propose a description */ + sulen = strlen(cert->subject); + if (cert->raw_skid) { + srlen = cert->raw_skid_size; + q = cert->raw_skid; + } else { + srlen = cert->raw_serial_size; + q = cert->raw_serial; + } + + ret = -ENOMEM; + desc = kmalloc(sulen + 2 + srlen * 2 + 1, GFP_KERNEL); + if (!desc) + goto error_free_cert; + p = memcpy(desc, cert->subject, sulen); + p += sulen; + *p++ = ':'; + *p++ = ' '; + p = bin2hex(p, q, srlen); + *p = 0; + + kids = kmalloc(sizeof(struct asymmetric_key_ids), GFP_KERNEL); + if (!kids) + goto error_free_desc; + kids->id[0] = cert->id; + kids->id[1] = cert->skid; + + /* We're pinning the module by being linked against it */ + __module_get(public_key_subtype.owner); + prep->payload.data[asym_subtype] = &public_key_subtype; + prep->payload.data[asym_key_ids] = kids; + prep->payload.data[asym_crypto] = cert->pub; + prep->payload.data[asym_auth] = cert->sig; + prep->description = desc; + prep->quotalen = 100; + + /* We've finished with the certificate */ + cert->pub = NULL; + cert->id = NULL; + cert->skid = NULL; + cert->sig = NULL; + desc = NULL; + ret = 0; + +error_free_desc: + kfree(desc); +error_free_cert: + x509_free_certificate(cert); + return ret; +} + +static struct asymmetric_key_parser x509_key_parser = { + .owner = THIS_MODULE, + .name = "x509", + .parse = x509_key_preparse, +}; + +/* + * Module stuff + */ +static int __init x509_key_init(void) +{ + return register_asymmetric_key_parser(&x509_key_parser); +} + +static void __exit x509_key_exit(void) +{ + unregister_asymmetric_key_parser(&x509_key_parser); +} + +module_init(x509_key_init); +module_exit(x509_key_exit); +#endif /* !__UBOOT__ */ + +MODULE_DESCRIPTION("X.509 certificate parser"); +MODULE_AUTHOR("Red Hat, Inc."); +MODULE_LICENSE("GPL");
Hello Tom,
this patch causes a build error for rpi_0_w_defconfig with CONFIG_X509_CERTIFICATE_PARSER=y:
In file included from include/linux/time.h:4, from lib/crypto/x509_parser.h:8, from lib/crypto/x509_cert_parser.c:20: include/rtc.h:197:26: error: unknown type name ‘uchar’; did you mean ‘unchar’? void rtc_write8(int reg, uchar val); ^~~~~ unchar make[4]: *** [scripts/Makefile.build:279: lib/crypto/x509_cert_parser.o] Error 1
The error is caused by:
include/linux/types.h:88:typedef unsigned char unchar;
I have prepared a patch but will first run it through Gitlab:
https://gitlab.denx.de/u-boot/custodians/u-boot-efi/commit/f574992867cf40f48...
@Takahiro: I am wondering why this did not show up in your tests. Did Tom miss a patch?
Best regards
Heinrich
Hello Tom,
Only sandbox enables any of this out of the box, which is why I've taken it at this point in the window. It's otherwise neutral and as good as it was going to get prior to inclusion somewhere for wider testing. Which, thanks for doing.
Hello Tom,
Thank you for catching this, Heinrich.
Yeah, more strictly speaking, my x509 test is enabled by default due to "default y" if UNIT_TEST is also enabled. So if pytest is run on Travis CI, x509 test can also be exercised via pytest's ut driver, but pytest is run on limited number of architectures on Travis CI and UNIT_TEST is enabled only on sandbox for now.
Thanks, -Takahiro Akashi
-- Tom
Imported from linux kernel v5.3: pkcs7.asn1 without changes pkcs7.h with changes marked as __UBOOT__ pkcs7_parser.h without changes pkcs7_parser.c with changes marked as __UBOOT__
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- include/crypto/pkcs7.h | 47 +++ lib/crypto/Kconfig | 10 + lib/crypto/Makefile | 11 + lib/crypto/pkcs7.asn1 | 135 ++++++++ lib/crypto/pkcs7_parser.c | 693 ++++++++++++++++++++++++++++++++++++++ lib/crypto/pkcs7_parser.h | 65 ++++ scripts/Makefile.build | 4 +- 7 files changed, 962 insertions(+), 3 deletions(-) create mode 100644 include/crypto/pkcs7.h create mode 100644 lib/crypto/pkcs7.asn1 create mode 100644 lib/crypto/pkcs7_parser.c create mode 100644 lib/crypto/pkcs7_parser.h
diff --git a/include/crypto/pkcs7.h b/include/crypto/pkcs7.h new file mode 100644 index 000000000000..8f5c8a7ee3b9 --- /dev/null +++ b/include/crypto/pkcs7.h @@ -0,0 +1,47 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* PKCS#7 crypto data parser + * + * Copyright (C) 2012 Red Hat, Inc. All Rights Reserved. + * Written by David Howells (dhowells@redhat.com) + */ + +#ifndef _CRYPTO_PKCS7_H +#define _CRYPTO_PKCS7_H + +#ifndef __UBOOT__ +#include <linux/verification.h> +#include <crypto/public_key.h> +#endif + +struct key; +struct pkcs7_message; + +/* + * pkcs7_parser.c + */ +extern struct pkcs7_message *pkcs7_parse_message(const void *data, + size_t datalen); +extern void pkcs7_free_message(struct pkcs7_message *pkcs7); + +extern int pkcs7_get_content_data(const struct pkcs7_message *pkcs7, + const void **_data, size_t *_datalen, + size_t *_headerlen); + +#ifndef __UBOOT__ +/* + * pkcs7_trust.c + */ +extern int pkcs7_validate_trust(struct pkcs7_message *pkcs7, + struct key *trust_keyring); + +/* + * pkcs7_verify.c + */ +extern int pkcs7_verify(struct pkcs7_message *pkcs7, + enum key_being_used_for usage); + +extern int pkcs7_supply_detached_data(struct pkcs7_message *pkcs7, + const void *data, size_t datalen); +#endif + +#endif /* _CRYPTO_PKCS7_H */ diff --git a/lib/crypto/Kconfig b/lib/crypto/Kconfig index aeb599c593ac..2b221b915aa6 100644 --- a/lib/crypto/Kconfig +++ b/lib/crypto/Kconfig @@ -39,4 +39,14 @@ config X509_CERTIFICATE_PARSER data and provides the ability to instantiate a crypto key from a public key packet found inside the certificate.
+config PKCS7_MESSAGE_PARSER + bool "PKCS#7 message parser" + depends on X509_CERTIFICATE_PARSER + select ASN1_DECODER + select ASN1_COMPILER + select OID_REGISTRY + help + This option provides support for parsing PKCS#7 format messages for + signature data and provides the ability to verify the signature. + endif # ASYMMETRIC_KEY_TYPE diff --git a/lib/crypto/Makefile b/lib/crypto/Makefile index d7e27be568a1..8267fee0a7b8 100644 --- a/lib/crypto/Makefile +++ b/lib/crypto/Makefile @@ -36,3 +36,14 @@ $(obj)/x509_cert_parser.o: \
$(obj)/x509.asn1.o: $(obj)/x509.asn1.c $(obj)/x509.asn1.h $(obj)/x509_akid.asn1.o: $(obj)/x509_akid.asn1.c $(obj)/x509_akid.asn1.h + +# +# PKCS#7 message handling +# +obj-$(CONFIG_PKCS7_MESSAGE_PARSER) += pkcs7_message.o +pkcs7_message-y := \ + pkcs7.asn1.o \ + pkcs7_parser.o + +$(obj)/pkcs7_parser.o: $(obj)/pkcs7.asn1.h +$(obj)/pkcs7.asn1.o: $(obj)/pkcs7.asn1.c $(obj)/pkcs7.asn1.h diff --git a/lib/crypto/pkcs7.asn1 b/lib/crypto/pkcs7.asn1 new file mode 100644 index 000000000000..1eca740b816a --- /dev/null +++ b/lib/crypto/pkcs7.asn1 @@ -0,0 +1,135 @@ +PKCS7ContentInfo ::= SEQUENCE { + contentType ContentType ({ pkcs7_check_content_type }), + content [0] EXPLICIT SignedData OPTIONAL +} + +ContentType ::= OBJECT IDENTIFIER ({ pkcs7_note_OID }) + +SignedData ::= SEQUENCE { + version INTEGER ({ pkcs7_note_signeddata_version }), + digestAlgorithms DigestAlgorithmIdentifiers, + contentInfo ContentInfo ({ pkcs7_note_content }), + certificates CHOICE { + certSet [0] IMPLICIT ExtendedCertificatesAndCertificates, + certSequence [2] IMPLICIT Certificates + } OPTIONAL ({ pkcs7_note_certificate_list }), + crls CHOICE { + crlSet [1] IMPLICIT CertificateRevocationLists, + crlSequence [3] IMPLICIT CRLSequence + } OPTIONAL, + signerInfos SignerInfos +} + +ContentInfo ::= SEQUENCE { + contentType ContentType ({ pkcs7_note_OID }), + content [0] EXPLICIT Data OPTIONAL +} + +Data ::= ANY ({ pkcs7_note_data }) + +DigestAlgorithmIdentifiers ::= CHOICE { + daSet SET OF DigestAlgorithmIdentifier, + daSequence SEQUENCE OF DigestAlgorithmIdentifier +} + +DigestAlgorithmIdentifier ::= SEQUENCE { + algorithm OBJECT IDENTIFIER ({ pkcs7_note_OID }), + parameters ANY OPTIONAL +} + +-- +-- Certificates and certificate lists +-- +ExtendedCertificatesAndCertificates ::= SET OF ExtendedCertificateOrCertificate + +ExtendedCertificateOrCertificate ::= CHOICE { + certificate Certificate, -- X.509 + extendedCertificate [0] IMPLICIT ExtendedCertificate -- PKCS#6 +} + +ExtendedCertificate ::= Certificate -- cheating + +Certificates ::= SEQUENCE OF Certificate + +CertificateRevocationLists ::= SET OF CertificateList + +CertificateList ::= SEQUENCE OF Certificate -- This may be defined incorrectly + +CRLSequence ::= SEQUENCE OF CertificateList + +Certificate ::= ANY ({ pkcs7_extract_cert }) -- X.509 + +-- +-- Signer information +-- +SignerInfos ::= CHOICE { + siSet SET OF SignerInfo, + siSequence SEQUENCE OF SignerInfo +} + +SignerInfo ::= SEQUENCE { + version INTEGER ({ pkcs7_note_signerinfo_version }), + sid SignerIdentifier, -- CMS variant, not PKCS#7 + digestAlgorithm DigestAlgorithmIdentifier ({ pkcs7_sig_note_digest_algo }), + authenticatedAttributes CHOICE { + aaSet [0] IMPLICIT SetOfAuthenticatedAttribute + ({ pkcs7_sig_note_set_of_authattrs }), + aaSequence [2] EXPLICIT SEQUENCE OF AuthenticatedAttribute + -- Explicit because easier to compute digest on + -- sequence of attributes and then reuse encoded + -- sequence in aaSequence. + } OPTIONAL, + digestEncryptionAlgorithm + DigestEncryptionAlgorithmIdentifier ({ pkcs7_sig_note_pkey_algo }), + encryptedDigest EncryptedDigest, + unauthenticatedAttributes CHOICE { + uaSet [1] IMPLICIT SET OF UnauthenticatedAttribute, + uaSequence [3] IMPLICIT SEQUENCE OF UnauthenticatedAttribute + } OPTIONAL +} ({ pkcs7_note_signed_info }) + +SignerIdentifier ::= CHOICE { + -- RFC5652 sec 5.3 + issuerAndSerialNumber IssuerAndSerialNumber, + subjectKeyIdentifier [0] IMPLICIT SubjectKeyIdentifier +} + +IssuerAndSerialNumber ::= SEQUENCE { + issuer Name ({ pkcs7_sig_note_issuer }), + serialNumber CertificateSerialNumber ({ pkcs7_sig_note_serial }) +} + +CertificateSerialNumber ::= INTEGER + +SubjectKeyIdentifier ::= OCTET STRING ({ pkcs7_sig_note_skid }) + +SetOfAuthenticatedAttribute ::= SET OF AuthenticatedAttribute + +AuthenticatedAttribute ::= SEQUENCE { + type OBJECT IDENTIFIER ({ pkcs7_note_OID }), + values SET OF ANY ({ pkcs7_sig_note_authenticated_attr }) +} + +UnauthenticatedAttribute ::= SEQUENCE { + type OBJECT IDENTIFIER, + values SET OF ANY +} + +DigestEncryptionAlgorithmIdentifier ::= SEQUENCE { + algorithm OBJECT IDENTIFIER ({ pkcs7_note_OID }), + parameters ANY OPTIONAL +} + +EncryptedDigest ::= OCTET STRING ({ pkcs7_sig_note_signature }) + +--- +--- X.500 Name +--- +Name ::= SEQUENCE OF RelativeDistinguishedName + +RelativeDistinguishedName ::= SET OF AttributeValueAssertion + +AttributeValueAssertion ::= SEQUENCE { + attributeType OBJECT IDENTIFIER ({ pkcs7_note_OID }), + attributeValue ANY +} diff --git a/lib/crypto/pkcs7_parser.c b/lib/crypto/pkcs7_parser.c new file mode 100644 index 000000000000..bf9e7e888f6b --- /dev/null +++ b/lib/crypto/pkcs7_parser.c @@ -0,0 +1,693 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* PKCS#7 parser + * + * Copyright (C) 2012 Red Hat, Inc. All Rights Reserved. + * Written by David Howells (dhowells@redhat.com) + */ + +#define pr_fmt(fmt) "PKCS7: "fmt +#ifdef __UBOOT__ +#include <linux/bitops.h> +#include <linux/compat.h> +#endif +#include <linux/kernel.h> +#ifndef __UBOOT__ +#include <linux/module.h> +#include <linux/export.h> +#include <linux/slab.h> +#endif +#include <linux/err.h> +#include <linux/oid_registry.h> +#include <crypto/public_key.h> +#include "pkcs7_parser.h" +#include "pkcs7.asn1.h" + +MODULE_DESCRIPTION("PKCS#7 parser"); +MODULE_AUTHOR("Red Hat, Inc."); +MODULE_LICENSE("GPL"); + +struct pkcs7_parse_context { + struct pkcs7_message *msg; /* Message being constructed */ + struct pkcs7_signed_info *sinfo; /* SignedInfo being constructed */ + struct pkcs7_signed_info **ppsinfo; + struct x509_certificate *certs; /* Certificate cache */ + struct x509_certificate **ppcerts; + unsigned long data; /* Start of data */ + enum OID last_oid; /* Last OID encountered */ + unsigned x509_index; + unsigned sinfo_index; + const void *raw_serial; + unsigned raw_serial_size; + unsigned raw_issuer_size; + const void *raw_issuer; + const void *raw_skid; + unsigned raw_skid_size; + bool expect_skid; +}; + +/* + * Free a signed information block. + */ +static void pkcs7_free_signed_info(struct pkcs7_signed_info *sinfo) +{ + if (sinfo) { + public_key_signature_free(sinfo->sig); + kfree(sinfo); + } +} + +/** + * pkcs7_free_message - Free a PKCS#7 message + * @pkcs7: The PKCS#7 message to free + */ +void pkcs7_free_message(struct pkcs7_message *pkcs7) +{ + struct x509_certificate *cert; + struct pkcs7_signed_info *sinfo; + + if (pkcs7) { + while (pkcs7->certs) { + cert = pkcs7->certs; + pkcs7->certs = cert->next; + x509_free_certificate(cert); + } + while (pkcs7->crl) { + cert = pkcs7->crl; + pkcs7->crl = cert->next; + x509_free_certificate(cert); + } + while (pkcs7->signed_infos) { + sinfo = pkcs7->signed_infos; + pkcs7->signed_infos = sinfo->next; + pkcs7_free_signed_info(sinfo); + } + kfree(pkcs7); + } +} +EXPORT_SYMBOL_GPL(pkcs7_free_message); + +/* + * Check authenticatedAttributes are provided or not provided consistently. + */ +static int pkcs7_check_authattrs(struct pkcs7_message *msg) +{ + struct pkcs7_signed_info *sinfo; + bool want = false; + + sinfo = msg->signed_infos; + if (!sinfo) + goto inconsistent; + + if (sinfo->authattrs) { + want = true; + msg->have_authattrs = true; + } + + for (sinfo = sinfo->next; sinfo; sinfo = sinfo->next) + if (!!sinfo->authattrs != want) + goto inconsistent; + return 0; + +inconsistent: + pr_warn("Inconsistently supplied authAttrs\n"); + return -EINVAL; +} + +/** + * pkcs7_parse_message - Parse a PKCS#7 message + * @data: The raw binary ASN.1 encoded message to be parsed + * @datalen: The size of the encoded message + */ +struct pkcs7_message *pkcs7_parse_message(const void *data, size_t datalen) +{ + struct pkcs7_parse_context *ctx; + struct pkcs7_message *msg = ERR_PTR(-ENOMEM); + int ret; + + ctx = kzalloc(sizeof(struct pkcs7_parse_context), GFP_KERNEL); + if (!ctx) + goto out_no_ctx; + ctx->msg = kzalloc(sizeof(struct pkcs7_message), GFP_KERNEL); + if (!ctx->msg) + goto out_no_msg; + ctx->sinfo = kzalloc(sizeof(struct pkcs7_signed_info), GFP_KERNEL); + if (!ctx->sinfo) + goto out_no_sinfo; + ctx->sinfo->sig = kzalloc(sizeof(struct public_key_signature), + GFP_KERNEL); + if (!ctx->sinfo->sig) + goto out_no_sig; + + ctx->data = (unsigned long)data; + ctx->ppcerts = &ctx->certs; + ctx->ppsinfo = &ctx->msg->signed_infos; + + /* Attempt to decode the signature */ + ret = asn1_ber_decoder(&pkcs7_decoder, ctx, data, datalen); + if (ret < 0) { + msg = ERR_PTR(ret); + goto out; + } + + ret = pkcs7_check_authattrs(ctx->msg); + if (ret < 0) { + msg = ERR_PTR(ret); + goto out; + } + + msg = ctx->msg; + ctx->msg = NULL; + +out: + while (ctx->certs) { + struct x509_certificate *cert = ctx->certs; + ctx->certs = cert->next; + x509_free_certificate(cert); + } +out_no_sig: + pkcs7_free_signed_info(ctx->sinfo); +out_no_sinfo: + pkcs7_free_message(ctx->msg); +out_no_msg: + kfree(ctx); +out_no_ctx: + return msg; +} +EXPORT_SYMBOL_GPL(pkcs7_parse_message); + +/** + * pkcs7_get_content_data - Get access to the PKCS#7 content + * @pkcs7: The preparsed PKCS#7 message to access + * @_data: Place to return a pointer to the data + * @_data_len: Place to return the data length + * @_headerlen: Size of ASN.1 header not included in _data + * + * Get access to the data content of the PKCS#7 message. The size of the + * header of the ASN.1 object that contains it is also provided and can be used + * to adjust *_data and *_data_len to get the entire object. + * + * Returns -ENODATA if the data object was missing from the message. + */ +int pkcs7_get_content_data(const struct pkcs7_message *pkcs7, + const void **_data, size_t *_data_len, + size_t *_headerlen) +{ + if (!pkcs7->data) + return -ENODATA; + + *_data = pkcs7->data; + *_data_len = pkcs7->data_len; + if (_headerlen) + *_headerlen = pkcs7->data_hdrlen; + return 0; +} +EXPORT_SYMBOL_GPL(pkcs7_get_content_data); + +/* + * Note an OID when we find one for later processing when we know how + * to interpret it. + */ +int pkcs7_note_OID(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct pkcs7_parse_context *ctx = context; + + ctx->last_oid = look_up_OID(value, vlen); + if (ctx->last_oid == OID__NR) { + char buffer[50]; + sprint_oid(value, vlen, buffer, sizeof(buffer)); + printk("PKCS7: Unknown OID: [%lu] %s\n", + (unsigned long)value - ctx->data, buffer); + } + return 0; +} + +/* + * Note the digest algorithm for the signature. + */ +int pkcs7_sig_note_digest_algo(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct pkcs7_parse_context *ctx = context; + + switch (ctx->last_oid) { + case OID_md4: + ctx->sinfo->sig->hash_algo = "md4"; + break; + case OID_md5: + ctx->sinfo->sig->hash_algo = "md5"; + break; + case OID_sha1: + ctx->sinfo->sig->hash_algo = "sha1"; + break; + case OID_sha256: + ctx->sinfo->sig->hash_algo = "sha256"; + break; + case OID_sha384: + ctx->sinfo->sig->hash_algo = "sha384"; + break; + case OID_sha512: + ctx->sinfo->sig->hash_algo = "sha512"; + break; + case OID_sha224: + ctx->sinfo->sig->hash_algo = "sha224"; + break; + default: + printk("Unsupported digest algo: %u\n", ctx->last_oid); + return -ENOPKG; + } + return 0; +} + +/* + * Note the public key algorithm for the signature. + */ +int pkcs7_sig_note_pkey_algo(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct pkcs7_parse_context *ctx = context; + + switch (ctx->last_oid) { + case OID_rsaEncryption: + ctx->sinfo->sig->pkey_algo = "rsa"; + ctx->sinfo->sig->encoding = "pkcs1"; + break; + default: + printk("Unsupported pkey algo: %u\n", ctx->last_oid); + return -ENOPKG; + } + return 0; +} + +/* + * We only support signed data [RFC2315 sec 9]. + */ +int pkcs7_check_content_type(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct pkcs7_parse_context *ctx = context; + + if (ctx->last_oid != OID_signed_data) { + pr_warn("Only support pkcs7_signedData type\n"); + return -EINVAL; + } + + return 0; +} + +/* + * Note the SignedData version + */ +int pkcs7_note_signeddata_version(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct pkcs7_parse_context *ctx = context; + unsigned version; + + if (vlen != 1) + goto unsupported; + + ctx->msg->version = version = *(const u8 *)value; + switch (version) { + case 1: + /* PKCS#7 SignedData [RFC2315 sec 9.1] + * CMS ver 1 SignedData [RFC5652 sec 5.1] + */ + break; + case 3: + /* CMS ver 3 SignedData [RFC2315 sec 5.1] */ + break; + default: + goto unsupported; + } + + return 0; + +unsupported: + pr_warn("Unsupported SignedData version\n"); + return -EINVAL; +} + +/* + * Note the SignerInfo version + */ +int pkcs7_note_signerinfo_version(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct pkcs7_parse_context *ctx = context; + unsigned version; + + if (vlen != 1) + goto unsupported; + + version = *(const u8 *)value; + switch (version) { + case 1: + /* PKCS#7 SignerInfo [RFC2315 sec 9.2] + * CMS ver 1 SignerInfo [RFC5652 sec 5.3] + */ + if (ctx->msg->version != 1) + goto version_mismatch; + ctx->expect_skid = false; + break; + case 3: + /* CMS ver 3 SignerInfo [RFC2315 sec 5.3] */ + if (ctx->msg->version == 1) + goto version_mismatch; + ctx->expect_skid = true; + break; + default: + goto unsupported; + } + + return 0; + +unsupported: + pr_warn("Unsupported SignerInfo version\n"); + return -EINVAL; +version_mismatch: + pr_warn("SignedData-SignerInfo version mismatch\n"); + return -EBADMSG; +} + +/* + * Extract a certificate and store it in the context. + */ +int pkcs7_extract_cert(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct pkcs7_parse_context *ctx = context; + struct x509_certificate *x509; + + if (tag != ((ASN1_UNIV << 6) | ASN1_CONS_BIT | ASN1_SEQ)) { + pr_debug("Cert began with tag %02x at %lu\n", + tag, (unsigned long)ctx - ctx->data); + return -EBADMSG; + } + + /* We have to correct for the header so that the X.509 parser can start + * from the beginning. Note that since X.509 stipulates DER, there + * probably shouldn't be an EOC trailer - but it is in PKCS#7 (which + * stipulates BER). + */ + value -= hdrlen; + vlen += hdrlen; + + if (((u8*)value)[1] == 0x80) + vlen += 2; /* Indefinite length - there should be an EOC */ + + x509 = x509_cert_parse(value, vlen); + if (IS_ERR(x509)) + return PTR_ERR(x509); + + x509->index = ++ctx->x509_index; + pr_debug("Got cert %u for %s\n", x509->index, x509->subject); + pr_debug("- fingerprint %*phN\n", x509->id->len, x509->id->data); + + *ctx->ppcerts = x509; + ctx->ppcerts = &x509->next; + return 0; +} + +/* + * Save the certificate list + */ +int pkcs7_note_certificate_list(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct pkcs7_parse_context *ctx = context; + + pr_devel("Got cert list (%02x)\n", tag); + + *ctx->ppcerts = ctx->msg->certs; + ctx->msg->certs = ctx->certs; + ctx->certs = NULL; + ctx->ppcerts = &ctx->certs; + return 0; +} + +/* + * Note the content type. + */ +int pkcs7_note_content(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct pkcs7_parse_context *ctx = context; + + if (ctx->last_oid != OID_data && + ctx->last_oid != OID_msIndirectData) { + pr_warn("Unsupported data type %d\n", ctx->last_oid); + return -EINVAL; + } + + ctx->msg->data_type = ctx->last_oid; + return 0; +} + +/* + * Extract the data from the message and store that and its content type OID in + * the context. + */ +int pkcs7_note_data(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct pkcs7_parse_context *ctx = context; + + pr_debug("Got data\n"); + + ctx->msg->data = value; + ctx->msg->data_len = vlen; + ctx->msg->data_hdrlen = hdrlen; + return 0; +} + +/* + * Parse authenticated attributes. + */ +int pkcs7_sig_note_authenticated_attr(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct pkcs7_parse_context *ctx = context; + struct pkcs7_signed_info *sinfo = ctx->sinfo; + enum OID content_type; + + pr_devel("AuthAttr: %02x %zu [%*ph]\n", tag, vlen, (unsigned)vlen, value); + + switch (ctx->last_oid) { + case OID_contentType: + if (__test_and_set_bit(sinfo_has_content_type, &sinfo->aa_set)) + goto repeated; + content_type = look_up_OID(value, vlen); + if (content_type != ctx->msg->data_type) { + pr_warn("Mismatch between global data type (%d) and sinfo %u (%d)\n", + ctx->msg->data_type, sinfo->index, + content_type); + return -EBADMSG; + } + return 0; + + case OID_signingTime: + if (__test_and_set_bit(sinfo_has_signing_time, &sinfo->aa_set)) + goto repeated; + /* Should we check that the signing time is consistent + * with the signer's X.509 cert? + */ + return x509_decode_time(&sinfo->signing_time, + hdrlen, tag, value, vlen); + + case OID_messageDigest: + if (__test_and_set_bit(sinfo_has_message_digest, &sinfo->aa_set)) + goto repeated; + if (tag != ASN1_OTS) + return -EBADMSG; + sinfo->msgdigest = value; + sinfo->msgdigest_len = vlen; + return 0; + + case OID_smimeCapabilites: + if (__test_and_set_bit(sinfo_has_smime_caps, &sinfo->aa_set)) + goto repeated; +#ifdef __UBOOT__ /* OID_data is needed for authenticated UEFI variables */ + if (ctx->msg->data_type != OID_msIndirectData && + ctx->msg->data_type != OID_data) { +#else + if (ctx->msg->data_type != OID_msIndirectData) { +#endif + pr_warn("S/MIME Caps only allowed with Authenticode\n"); + return -EKEYREJECTED; + } + return 0; + + /* Microsoft SpOpusInfo seems to be contain cont[0] 16-bit BE + * char URLs and cont[1] 8-bit char URLs. + * + * Microsoft StatementType seems to contain a list of OIDs that + * are also used as extendedKeyUsage types in X.509 certs. + */ + case OID_msSpOpusInfo: + if (__test_and_set_bit(sinfo_has_ms_opus_info, &sinfo->aa_set)) + goto repeated; + goto authenticode_check; + case OID_msStatementType: + if (__test_and_set_bit(sinfo_has_ms_statement_type, &sinfo->aa_set)) + goto repeated; + authenticode_check: + if (ctx->msg->data_type != OID_msIndirectData) { + pr_warn("Authenticode AuthAttrs only allowed with Authenticode\n"); + return -EKEYREJECTED; + } + /* I'm not sure how to validate these */ + return 0; + default: + return 0; + } + +repeated: + /* We permit max one item per AuthenticatedAttribute and no repeats */ + pr_warn("Repeated/multivalue AuthAttrs not permitted\n"); + return -EKEYREJECTED; +} + +/* + * Note the set of auth attributes for digestion purposes [RFC2315 sec 9.3] + */ +int pkcs7_sig_note_set_of_authattrs(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct pkcs7_parse_context *ctx = context; + struct pkcs7_signed_info *sinfo = ctx->sinfo; + + if (!test_bit(sinfo_has_content_type, &sinfo->aa_set) || + !test_bit(sinfo_has_message_digest, &sinfo->aa_set)) { + pr_warn("Missing required AuthAttr\n"); + return -EBADMSG; + } + + if (ctx->msg->data_type != OID_msIndirectData && + test_bit(sinfo_has_ms_opus_info, &sinfo->aa_set)) { + pr_warn("Unexpected Authenticode AuthAttr\n"); + return -EBADMSG; + } + + /* We need to switch the 'CONT 0' to a 'SET OF' when we digest */ + sinfo->authattrs = value - (hdrlen - 1); + sinfo->authattrs_len = vlen + (hdrlen - 1); + return 0; +} + +/* + * Note the issuing certificate serial number + */ +int pkcs7_sig_note_serial(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct pkcs7_parse_context *ctx = context; + ctx->raw_serial = value; + ctx->raw_serial_size = vlen; + return 0; +} + +/* + * Note the issuer's name + */ +int pkcs7_sig_note_issuer(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct pkcs7_parse_context *ctx = context; + ctx->raw_issuer = value; + ctx->raw_issuer_size = vlen; + return 0; +} + +/* + * Note the issuing cert's subjectKeyIdentifier + */ +int pkcs7_sig_note_skid(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct pkcs7_parse_context *ctx = context; + + pr_devel("SKID: %02x %zu [%*ph]\n", tag, vlen, (unsigned)vlen, value); + + ctx->raw_skid = value; + ctx->raw_skid_size = vlen; + return 0; +} + +/* + * Note the signature data + */ +int pkcs7_sig_note_signature(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct pkcs7_parse_context *ctx = context; + + ctx->sinfo->sig->s = kmemdup(value, vlen, GFP_KERNEL); + if (!ctx->sinfo->sig->s) + return -ENOMEM; + + ctx->sinfo->sig->s_size = vlen; + return 0; +} + +/* + * Note a signature information block + */ +int pkcs7_note_signed_info(void *context, size_t hdrlen, + unsigned char tag, + const void *value, size_t vlen) +{ + struct pkcs7_parse_context *ctx = context; + struct pkcs7_signed_info *sinfo = ctx->sinfo; + struct asymmetric_key_id *kid; + + if (ctx->msg->data_type == OID_msIndirectData && !sinfo->authattrs) { + pr_warn("Authenticode requires AuthAttrs\n"); + return -EBADMSG; + } + + /* Generate cert issuer + serial number key ID */ + if (!ctx->expect_skid) { + kid = asymmetric_key_generate_id(ctx->raw_serial, + ctx->raw_serial_size, + ctx->raw_issuer, + ctx->raw_issuer_size); + } else { + kid = asymmetric_key_generate_id(ctx->raw_skid, + ctx->raw_skid_size, + "", 0); + } + if (IS_ERR(kid)) + return PTR_ERR(kid); + + pr_devel("SINFO KID: %u [%*phN]\n", kid->len, kid->len, kid->data); + + sinfo->sig->auth_ids[0] = kid; + sinfo->index = ++ctx->sinfo_index; + *ctx->ppsinfo = sinfo; + ctx->ppsinfo = &sinfo->next; + ctx->sinfo = kzalloc(sizeof(struct pkcs7_signed_info), GFP_KERNEL); + if (!ctx->sinfo) + return -ENOMEM; + ctx->sinfo->sig = kzalloc(sizeof(struct public_key_signature), + GFP_KERNEL); + if (!ctx->sinfo->sig) + return -ENOMEM; + return 0; +} diff --git a/lib/crypto/pkcs7_parser.h b/lib/crypto/pkcs7_parser.h new file mode 100644 index 000000000000..6565fdc2d4ca --- /dev/null +++ b/lib/crypto/pkcs7_parser.h @@ -0,0 +1,65 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* PKCS#7 crypto data parser internal definitions + * + * Copyright (C) 2012 Red Hat, Inc. All Rights Reserved. + * Written by David Howells (dhowells@redhat.com) + */ + +#include <linux/oid_registry.h> +#include <crypto/pkcs7.h> +#include "x509_parser.h" + +#define kenter(FMT, ...) \ + pr_devel("==> %s("FMT")\n", __func__, ##__VA_ARGS__) +#define kleave(FMT, ...) \ + pr_devel("<== %s()"FMT"\n", __func__, ##__VA_ARGS__) + +struct pkcs7_signed_info { + struct pkcs7_signed_info *next; + struct x509_certificate *signer; /* Signing certificate (in msg->certs) */ + unsigned index; + bool unsupported_crypto; /* T if not usable due to missing crypto */ + bool blacklisted; + + /* Message digest - the digest of the Content Data (or NULL) */ + const void *msgdigest; + unsigned msgdigest_len; + + /* Authenticated Attribute data (or NULL) */ + unsigned authattrs_len; + const void *authattrs; + unsigned long aa_set; +#define sinfo_has_content_type 0 +#define sinfo_has_signing_time 1 +#define sinfo_has_message_digest 2 +#define sinfo_has_smime_caps 3 +#define sinfo_has_ms_opus_info 4 +#define sinfo_has_ms_statement_type 5 + time64_t signing_time; + + /* Message signature. + * + * This contains the generated digest of _either_ the Content Data or + * the Authenticated Attributes [RFC2315 9.3]. If the latter, one of + * the attributes contains the digest of the the Content Data within + * it. + * + * THis also contains the issuing cert serial number and issuer's name + * [PKCS#7 or CMS ver 1] or issuing cert's SKID [CMS ver 3]. + */ + struct public_key_signature *sig; +}; + +struct pkcs7_message { + struct x509_certificate *certs; /* Certificate list */ + struct x509_certificate *crl; /* Revocation list */ + struct pkcs7_signed_info *signed_infos; + u8 version; /* Version of cert (1 -> PKCS#7 or CMS; 3 -> CMS) */ + bool have_authattrs; /* T if have authattrs */ + + /* Content Data (or NULL) */ + enum OID data_type; /* Type of Data */ + size_t data_len; /* Length of Data */ + size_t data_hdrlen; /* Length of Data ASN.1 header */ + const void *data; /* Content Data (or 0) */ +}; diff --git a/scripts/Makefile.build b/scripts/Makefile.build index 6d59ea91fac3..26eb701f8dea 100644 --- a/scripts/Makefile.build +++ b/scripts/Makefile.build @@ -419,11 +419,9 @@ targets += $(multi-used-y) $(multi-used-m) intermediate_targets = $(foreach sfx, $(2), \ $(patsubst %$(strip $(1)),%$(sfx), \ $(filter %$(strip $(1)), $(targets)))) -# %.asn1.o <- %.asn1.[ch] <- %.asn1 # %.lex.o <- %.lex.c <- %.l # %.tab.o <- %.tab.[ch] <- %.y -targets += $(call intermediate_targets, .asn1.o, .asn1.c .asn1.h) \ - $(call intermediate_targets, .lex.o, .lex.c) \ +targets += $(call intermediate_targets, .lex.o, .lex.c) \ $(call intermediate_targets, .tab.o, .tab.c .tab.h)
# Descending
This test will exercise asn1 compiler as well as asn1 decoder functions via various parsers.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- test/Kconfig | 18 ++- test/lib/Makefile | 1 + test/lib/asn1.c | 392 ++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 410 insertions(+), 1 deletion(-) create mode 100644 test/lib/asn1.c
diff --git a/test/Kconfig b/test/Kconfig index 48a0e501f88f..cb7954041eda 100644 --- a/test/Kconfig +++ b/test/Kconfig @@ -12,7 +12,23 @@ config UT_LIB default y help Enables the 'ut lib' command which tests library functions like - memcat(), memcyp(), memmove(). + memcat(), memcyp(), memmove() and ASN1 compiler/decoder. + +if UT_LIB + +config UT_LIB_ASN1 + bool "Unit test for asn1 compiler and decoder function" + default y + imply ASYMMETRIC_KEY_TYPE + imply ASYMMETRIC_PUBLIC_KEY_SUBTYPE + imply X509_CERTIFICATE_PARSER + imply PKCS7_MESSAGE_PARSER + imply RSA_PUBLIC_KEY_PARSER + help + Enables a test which exercises asn1 compiler and decoder function + via various parsers. + +endif
config UT_TIME bool "Unit tests for time functions" diff --git a/test/lib/Makefile b/test/lib/Makefile index b13aaca7ce54..72d2ec74b5f4 100644 --- a/test/lib/Makefile +++ b/test/lib/Makefile @@ -7,3 +7,4 @@ obj-y += hexdump.o obj-y += lmb.o obj-y += string.o obj-$(CONFIG_ERRNO_STR) += test_errno_str.o +obj-$(CONFIG_UT_LIB_ASN1) += asn1.o diff --git a/test/lib/asn1.c b/test/lib/asn1.c new file mode 100644 index 000000000000..d2b3f67e68da --- /dev/null +++ b/test/lib/asn1.c @@ -0,0 +1,392 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2019 Linaro Limited + * Author: AKASHI Takahiro + * + * Unit test for asn1 compiler and asn1 decoder function via various parsers + */ + +#include <common.h> +#include <command.h> +#include <test/lib.h> +#include <test/test.h> +#include <test/ut.h> + +#ifdef CONFIG_PKCS7_MESSAGE_PARSER +#include "../../lib/crypto/pkcs7_parser.h" +#else +#ifdef CONFIG_X509_CERTIFICATE_PARSER +#include "../../lib/crypto/x509_parser.h" +#endif +#endif + +#ifdef CONFIG_X509_CERTIFICATE_PARSER +static const unsigned char cert_data[] = { + 0x30, 0x82, 0x03, 0xc7, 0x30, 0x82, 0x02, 0xaf, 0xa0, 0x03, 0x02, 0x01, + 0x02, 0x02, 0x09, 0x00, 0xd7, 0x17, 0x0a, 0x76, 0xd5, 0xd3, 0x4d, 0xeb, + 0x30, 0x0d, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x01, + 0x0b, 0x05, 0x00, 0x30, 0x7a, 0x31, 0x0b, 0x30, 0x09, 0x06, 0x03, 0x55, + 0x04, 0x06, 0x13, 0x02, 0x4a, 0x50, 0x31, 0x0e, 0x30, 0x0c, 0x06, 0x03, + 0x55, 0x04, 0x08, 0x0c, 0x05, 0x54, 0x6f, 0x6b, 0x79, 0x6f, 0x31, 0x0e, + 0x30, 0x0c, 0x06, 0x03, 0x55, 0x04, 0x07, 0x0c, 0x05, 0x54, 0x6f, 0x6b, + 0x79, 0x6f, 0x31, 0x0f, 0x30, 0x0d, 0x06, 0x03, 0x55, 0x04, 0x0a, 0x0c, + 0x06, 0x4c, 0x69, 0x6e, 0x61, 0x72, 0x6f, 0x31, 0x0b, 0x30, 0x09, 0x06, + 0x03, 0x55, 0x04, 0x0b, 0x0c, 0x02, 0x53, 0x57, 0x31, 0x0f, 0x30, 0x0d, + 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x06, 0x54, 0x65, 0x73, 0x74, 0x65, + 0x72, 0x31, 0x1c, 0x30, 0x1a, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, + 0x0d, 0x01, 0x09, 0x01, 0x16, 0x0d, 0x74, 0x65, 0x73, 0x74, 0x40, 0x74, + 0x65, 0x73, 0x74, 0x2e, 0x6f, 0x72, 0x67, 0x30, 0x1e, 0x17, 0x0d, 0x31, + 0x39, 0x31, 0x30, 0x31, 0x38, 0x30, 0x33, 0x31, 0x33, 0x33, 0x31, 0x5a, + 0x17, 0x0d, 0x32, 0x30, 0x31, 0x30, 0x31, 0x37, 0x30, 0x33, 0x31, 0x33, + 0x33, 0x31, 0x5a, 0x30, 0x7a, 0x31, 0x0b, 0x30, 0x09, 0x06, 0x03, 0x55, + 0x04, 0x06, 0x13, 0x02, 0x4a, 0x50, 0x31, 0x0e, 0x30, 0x0c, 0x06, 0x03, + 0x55, 0x04, 0x08, 0x0c, 0x05, 0x54, 0x6f, 0x6b, 0x79, 0x6f, 0x31, 0x0e, + 0x30, 0x0c, 0x06, 0x03, 0x55, 0x04, 0x07, 0x0c, 0x05, 0x54, 0x6f, 0x6b, + 0x79, 0x6f, 0x31, 0x0f, 0x30, 0x0d, 0x06, 0x03, 0x55, 0x04, 0x0a, 0x0c, + 0x06, 0x4c, 0x69, 0x6e, 0x61, 0x72, 0x6f, 0x31, 0x0b, 0x30, 0x09, 0x06, + 0x03, 0x55, 0x04, 0x0b, 0x0c, 0x02, 0x53, 0x57, 0x31, 0x0f, 0x30, 0x0d, + 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x06, 0x54, 0x65, 0x73, 0x74, 0x65, + 0x72, 0x31, 0x1c, 0x30, 0x1a, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, + 0x0d, 0x01, 0x09, 0x01, 0x16, 0x0d, 0x74, 0x65, 0x73, 0x74, 0x40, 0x74, + 0x65, 0x73, 0x74, 0x2e, 0x6f, 0x72, 0x67, 0x30, 0x82, 0x01, 0x22, 0x30, + 0x0d, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x01, 0x01, + 0x05, 0x00, 0x03, 0x82, 0x01, 0x0f, 0x00, 0x30, 0x82, 0x01, 0x0a, 0x02, + 0x82, 0x01, 0x01, 0x00, 0x9f, 0x37, 0x4d, 0x95, 0x7e, 0x36, 0xb7, 0xaf, + 0xf4, 0xd6, 0xce, 0x39, 0x04, 0xee, 0xbf, 0x36, 0xb2, 0xcc, 0xa3, 0x8b, + 0x9e, 0xac, 0x62, 0x8a, 0xe9, 0xae, 0x18, 0xcf, 0xe8, 0x95, 0xfd, 0xcb, + 0xad, 0x34, 0x8a, 0x5f, 0x55, 0xe6, 0x0c, 0x5e, 0xf8, 0x76, 0xc1, 0xa2, + 0xc3, 0xd4, 0x73, 0x13, 0x8a, 0x71, 0x1b, 0xfd, 0x58, 0x27, 0xea, 0x4d, + 0x41, 0xff, 0x63, 0xbb, 0xad, 0x97, 0x62, 0xba, 0xe4, 0xe5, 0x97, 0x45, + 0xa3, 0x5b, 0xd5, 0x5b, 0x53, 0x55, 0x10, 0x19, 0xfa, 0xac, 0xbd, 0xdb, + 0x77, 0x62, 0x23, 0x50, 0x3f, 0x35, 0xdb, 0x8a, 0xf6, 0xee, 0x7a, 0x31, + 0xec, 0x92, 0xf5, 0x78, 0x35, 0x92, 0x76, 0x3c, 0x5f, 0xe7, 0xee, 0xc9, + 0xed, 0x01, 0x1c, 0x42, 0x55, 0xd6, 0x7e, 0xa6, 0xca, 0x7c, 0xd1, 0x15, + 0x16, 0x87, 0x7c, 0x99, 0x63, 0xc0, 0xa9, 0x25, 0x49, 0xbc, 0x4e, 0xdc, + 0x2d, 0x4b, 0xcb, 0x52, 0xd7, 0x67, 0xe9, 0x83, 0x6b, 0x5e, 0x5b, 0x48, + 0x80, 0x33, 0xe9, 0xcc, 0xe8, 0xfe, 0x19, 0xc8, 0xc2, 0x61, 0x74, 0x52, + 0x25, 0x92, 0x48, 0xea, 0xad, 0x15, 0x16, 0x64, 0x6e, 0x53, 0x30, 0x77, + 0xa2, 0xef, 0x61, 0x92, 0x1b, 0x5e, 0xbe, 0x07, 0xf2, 0x3c, 0xf8, 0x35, + 0x7d, 0x76, 0x4f, 0x78, 0xa9, 0x2a, 0xf1, 0x32, 0xff, 0xec, 0x89, 0xa9, + 0x22, 0x4c, 0x3d, 0xc8, 0x65, 0xca, 0xf4, 0xa2, 0x6d, 0x3f, 0xa4, 0x0a, + 0xfa, 0x9e, 0xe4, 0xf0, 0xdb, 0x39, 0xb1, 0xf9, 0xf0, 0xfb, 0x04, 0x81, + 0x44, 0xa7, 0xd7, 0x61, 0xdf, 0x2d, 0x13, 0x45, 0x2c, 0xae, 0xf0, 0x0e, + 0xc4, 0x07, 0x5d, 0x7d, 0x2b, 0xb2, 0x20, 0x75, 0x33, 0x6b, 0x5b, 0xf7, + 0xe7, 0x17, 0x51, 0xf1, 0xab, 0xc1, 0x9e, 0xc6, 0xf0, 0x30, 0xc6, 0x25, + 0x26, 0x3e, 0xd7, 0xd7, 0xa3, 0xcc, 0x15, 0x95, 0x02, 0x03, 0x01, 0x00, + 0x01, 0xa3, 0x50, 0x30, 0x4e, 0x30, 0x1d, 0x06, 0x03, 0x55, 0x1d, 0x0e, + 0x04, 0x16, 0x04, 0x14, 0x45, 0x8a, 0x76, 0xf7, 0x4f, 0xf4, 0x0e, 0xa0, + 0xf2, 0x02, 0xe1, 0xe7, 0xe9, 0xc7, 0x7d, 0x51, 0x55, 0x92, 0x33, 0xcd, + 0x30, 0x1f, 0x06, 0x03, 0x55, 0x1d, 0x23, 0x04, 0x18, 0x30, 0x16, 0x80, + 0x14, 0x45, 0x8a, 0x76, 0xf7, 0x4f, 0xf4, 0x0e, 0xa0, 0xf2, 0x02, 0xe1, + 0xe7, 0xe9, 0xc7, 0x7d, 0x51, 0x55, 0x92, 0x33, 0xcd, 0x30, 0x0c, 0x06, + 0x03, 0x55, 0x1d, 0x13, 0x04, 0x05, 0x30, 0x03, 0x01, 0x01, 0xff, 0x30, + 0x0d, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x01, 0x0b, + 0x05, 0x00, 0x03, 0x82, 0x01, 0x01, 0x00, 0x47, 0x93, 0x82, 0x0e, 0x8a, + 0x70, 0x9d, 0x6c, 0x7a, 0xdb, 0x04, 0xb4, 0xc9, 0xef, 0x98, 0x28, 0xc6, + 0xd9, 0x53, 0x90, 0xc8, 0x25, 0x83, 0x07, 0x23, 0xe7, 0x59, 0x38, 0xc1, + 0xc0, 0x50, 0x28, 0x99, 0x92, 0xfb, 0x21, 0x24, 0x72, 0xe5, 0xa6, 0x57, + 0x30, 0x31, 0xb3, 0xdf, 0xa0, 0x17, 0xa9, 0x73, 0x9c, 0x39, 0x83, 0xfb, + 0xe4, 0xfa, 0x20, 0x1d, 0xfa, 0x33, 0x20, 0x0c, 0x72, 0x2a, 0x50, 0x40, + 0xbd, 0x2d, 0x33, 0xa2, 0xfc, 0x06, 0xf9, 0xfe, 0x86, 0x4f, 0x50, 0x1d, + 0x65, 0x37, 0xe9, 0x30, 0x33, 0x82, 0xa1, 0x75, 0x8f, 0x5d, 0x33, 0x84, + 0x0d, 0xf2, 0x09, 0x04, 0xc0, 0x7a, 0x12, 0x79, 0xdb, 0x4f, 0x77, 0x04, + 0xe4, 0xd8, 0x0b, 0x87, 0x19, 0xba, 0xb7, 0x3c, 0xa6, 0x45, 0xaa, 0x91, + 0x62, 0x7f, 0x01, 0x7d, 0xc6, 0x20, 0x6d, 0x71, 0x15, 0x74, 0x5e, 0x87, + 0xb3, 0x60, 0x17, 0x9c, 0xc0, 0xed, 0x01, 0x4b, 0xb3, 0x23, 0x24, 0xc1, + 0xcb, 0x7a, 0x83, 0x03, 0x26, 0x2d, 0xde, 0x47, 0xc5, 0x11, 0x94, 0x28, + 0x27, 0x15, 0x92, 0x00, 0x8b, 0x2e, 0x51, 0x42, 0xca, 0x4b, 0x4a, 0x2c, + 0x51, 0x37, 0x56, 0xd0, 0xbc, 0x33, 0xd5, 0xd5, 0x3e, 0x79, 0x5c, 0x3f, + 0x9d, 0x6e, 0xb1, 0xe9, 0x71, 0xf1, 0x2c, 0xe9, 0xb4, 0x88, 0x2c, 0xd2, + 0x49, 0x97, 0xce, 0x29, 0x94, 0x16, 0xc9, 0xf9, 0x64, 0x0e, 0xd0, 0xd9, + 0x7a, 0x53, 0x10, 0x1a, 0xee, 0x83, 0x73, 0x93, 0x1b, 0xdf, 0x8a, 0x77, + 0xc0, 0x56, 0x63, 0xab, 0x5a, 0x65, 0xc5, 0xc5, 0x3b, 0xf3, 0x30, 0x80, + 0xfc, 0x38, 0x8b, 0xc9, 0xcd, 0xc3, 0x4f, 0x2e, 0x2d, 0x67, 0xcc, 0x17, + 0x18, 0x9b, 0x3e, 0xc6, 0x47, 0x03, 0xfc, 0x35, 0xa8, 0x35, 0x06, 0x5a, + 0x77, 0xe5, 0x97, 0x71, 0xbb, 0x27, 0x93, 0x0d, 0x1f, 0x0e, 0x8c +}; + +static unsigned int cert_data_len = 971; + +/** + * lib_asn1_x509() - unit test for asn1 decoder function + * with x509 certificate parser + * + * @uts: unit test state + * Return: 0 = success, 1 = failure + */ +static int lib_asn1_x509(struct unit_test_state *uts) +{ + struct x509_certificate *cert; + + cert = x509_cert_parse(cert_data, cert_data_len); + + ut_assertf(cert != NULL, "decoding failed\n"); + ut_assertf(!strcmp(cert->subject, "Linaro: Tester"), + "subject doesn't match\n"); + ut_assertf(!strcmp(cert->issuer, "Linaro: Tester"), + "issuer doesn't match\n"); + ut_assertf(cert->pub, "public key doesn't exist\n"); + ut_assertf(cert->pub->keylen == 0x10e, "key length doesn't match\n"); + ut_assertf(!strcmp(cert->pub->pkey_algo, "rsa"), "algo isn't rsa\n"); + ut_assertf(cert->valid_from == 0x5da92ddb, + "valid_from doesn't match\n"); + ut_assertf(cert->valid_to == 0x5f8a615b, "valid_to doesn't match\n"); + + x509_free_certificate(cert); + + return CMD_RET_SUCCESS; +} + +LIB_TEST(lib_asn1_x509, 0); +#endif /* CONFIG_X509_CERTIFICATE_PARSER */ + +#ifdef CONFIG_PKCS7_MESSAGE_PARSER +/* + * sbsign --key priv.pem --cert cert.pem --detach --out Image.pk Image + */ +static const unsigned char image_pk7[] = { + 0x30, 0x82, 0x07, 0x0f, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, + 0x01, 0x07, 0x02, 0xa0, 0x82, 0x07, 0x00, 0x30, 0x82, 0x06, 0xfc, 0x02, + 0x01, 0x01, 0x31, 0x0f, 0x30, 0x0d, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, + 0x65, 0x03, 0x04, 0x02, 0x01, 0x05, 0x00, 0x30, 0x78, 0x06, 0x0a, 0x2b, + 0x06, 0x01, 0x04, 0x01, 0x82, 0x37, 0x02, 0x01, 0x04, 0xa0, 0x6a, 0x30, + 0x68, 0x30, 0x33, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0x37, + 0x02, 0x01, 0x0f, 0x30, 0x25, 0x03, 0x01, 0x00, 0xa0, 0x20, 0xa2, 0x1e, + 0x80, 0x1c, 0x00, 0x3c, 0x00, 0x3c, 0x00, 0x3c, 0x00, 0x4f, 0x00, 0x62, + 0x00, 0x73, 0x00, 0x6f, 0x00, 0x6c, 0x00, 0x65, 0x00, 0x74, 0x00, 0x65, + 0x00, 0x3e, 0x00, 0x3e, 0x00, 0x3e, 0x30, 0x31, 0x30, 0x0d, 0x06, 0x09, + 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, 0x04, 0x02, 0x01, 0x05, 0x00, 0x04, + 0x20, 0x9e, 0x90, 0x99, 0x6d, 0xf2, 0xb5, 0x3d, 0x3f, 0xfc, 0x38, 0xb6, + 0xf2, 0x1f, 0xd2, 0x24, 0x88, 0x43, 0x77, 0x7d, 0xc1, 0x2c, 0x9e, 0x8a, + 0xf6, 0xf7, 0xdd, 0x9e, 0x9c, 0x5f, 0x18, 0x36, 0xc5, 0xa0, 0x82, 0x03, + 0xcb, 0x30, 0x82, 0x03, 0xc7, 0x30, 0x82, 0x02, 0xaf, 0xa0, 0x03, 0x02, + 0x01, 0x02, 0x02, 0x09, 0x00, 0xd7, 0x17, 0x0a, 0x76, 0xd5, 0xd3, 0x4d, + 0xeb, 0x30, 0x0d, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, + 0x01, 0x0b, 0x05, 0x00, 0x30, 0x7a, 0x31, 0x0b, 0x30, 0x09, 0x06, 0x03, + 0x55, 0x04, 0x06, 0x13, 0x02, 0x4a, 0x50, 0x31, 0x0e, 0x30, 0x0c, 0x06, + 0x03, 0x55, 0x04, 0x08, 0x0c, 0x05, 0x54, 0x6f, 0x6b, 0x79, 0x6f, 0x31, + 0x0e, 0x30, 0x0c, 0x06, 0x03, 0x55, 0x04, 0x07, 0x0c, 0x05, 0x54, 0x6f, + 0x6b, 0x79, 0x6f, 0x31, 0x0f, 0x30, 0x0d, 0x06, 0x03, 0x55, 0x04, 0x0a, + 0x0c, 0x06, 0x4c, 0x69, 0x6e, 0x61, 0x72, 0x6f, 0x31, 0x0b, 0x30, 0x09, + 0x06, 0x03, 0x55, 0x04, 0x0b, 0x0c, 0x02, 0x53, 0x57, 0x31, 0x0f, 0x30, + 0x0d, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x06, 0x54, 0x65, 0x73, 0x74, + 0x65, 0x72, 0x31, 0x1c, 0x30, 0x1a, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, + 0xf7, 0x0d, 0x01, 0x09, 0x01, 0x16, 0x0d, 0x74, 0x65, 0x73, 0x74, 0x40, + 0x74, 0x65, 0x73, 0x74, 0x2e, 0x6f, 0x72, 0x67, 0x30, 0x1e, 0x17, 0x0d, + 0x31, 0x39, 0x31, 0x30, 0x31, 0x38, 0x30, 0x33, 0x31, 0x33, 0x33, 0x31, + 0x5a, 0x17, 0x0d, 0x32, 0x30, 0x31, 0x30, 0x31, 0x37, 0x30, 0x33, 0x31, + 0x33, 0x33, 0x31, 0x5a, 0x30, 0x7a, 0x31, 0x0b, 0x30, 0x09, 0x06, 0x03, + 0x55, 0x04, 0x06, 0x13, 0x02, 0x4a, 0x50, 0x31, 0x0e, 0x30, 0x0c, 0x06, + 0x03, 0x55, 0x04, 0x08, 0x0c, 0x05, 0x54, 0x6f, 0x6b, 0x79, 0x6f, 0x31, + 0x0e, 0x30, 0x0c, 0x06, 0x03, 0x55, 0x04, 0x07, 0x0c, 0x05, 0x54, 0x6f, + 0x6b, 0x79, 0x6f, 0x31, 0x0f, 0x30, 0x0d, 0x06, 0x03, 0x55, 0x04, 0x0a, + 0x0c, 0x06, 0x4c, 0x69, 0x6e, 0x61, 0x72, 0x6f, 0x31, 0x0b, 0x30, 0x09, + 0x06, 0x03, 0x55, 0x04, 0x0b, 0x0c, 0x02, 0x53, 0x57, 0x31, 0x0f, 0x30, + 0x0d, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x06, 0x54, 0x65, 0x73, 0x74, + 0x65, 0x72, 0x31, 0x1c, 0x30, 0x1a, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, + 0xf7, 0x0d, 0x01, 0x09, 0x01, 0x16, 0x0d, 0x74, 0x65, 0x73, 0x74, 0x40, + 0x74, 0x65, 0x73, 0x74, 0x2e, 0x6f, 0x72, 0x67, 0x30, 0x82, 0x01, 0x22, + 0x30, 0x0d, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x01, + 0x01, 0x05, 0x00, 0x03, 0x82, 0x01, 0x0f, 0x00, 0x30, 0x82, 0x01, 0x0a, + 0x02, 0x82, 0x01, 0x01, 0x00, 0x9f, 0x37, 0x4d, 0x95, 0x7e, 0x36, 0xb7, + 0xaf, 0xf4, 0xd6, 0xce, 0x39, 0x04, 0xee, 0xbf, 0x36, 0xb2, 0xcc, 0xa3, + 0x8b, 0x9e, 0xac, 0x62, 0x8a, 0xe9, 0xae, 0x18, 0xcf, 0xe8, 0x95, 0xfd, + 0xcb, 0xad, 0x34, 0x8a, 0x5f, 0x55, 0xe6, 0x0c, 0x5e, 0xf8, 0x76, 0xc1, + 0xa2, 0xc3, 0xd4, 0x73, 0x13, 0x8a, 0x71, 0x1b, 0xfd, 0x58, 0x27, 0xea, + 0x4d, 0x41, 0xff, 0x63, 0xbb, 0xad, 0x97, 0x62, 0xba, 0xe4, 0xe5, 0x97, + 0x45, 0xa3, 0x5b, 0xd5, 0x5b, 0x53, 0x55, 0x10, 0x19, 0xfa, 0xac, 0xbd, + 0xdb, 0x77, 0x62, 0x23, 0x50, 0x3f, 0x35, 0xdb, 0x8a, 0xf6, 0xee, 0x7a, + 0x31, 0xec, 0x92, 0xf5, 0x78, 0x35, 0x92, 0x76, 0x3c, 0x5f, 0xe7, 0xee, + 0xc9, 0xed, 0x01, 0x1c, 0x42, 0x55, 0xd6, 0x7e, 0xa6, 0xca, 0x7c, 0xd1, + 0x15, 0x16, 0x87, 0x7c, 0x99, 0x63, 0xc0, 0xa9, 0x25, 0x49, 0xbc, 0x4e, + 0xdc, 0x2d, 0x4b, 0xcb, 0x52, 0xd7, 0x67, 0xe9, 0x83, 0x6b, 0x5e, 0x5b, + 0x48, 0x80, 0x33, 0xe9, 0xcc, 0xe8, 0xfe, 0x19, 0xc8, 0xc2, 0x61, 0x74, + 0x52, 0x25, 0x92, 0x48, 0xea, 0xad, 0x15, 0x16, 0x64, 0x6e, 0x53, 0x30, + 0x77, 0xa2, 0xef, 0x61, 0x92, 0x1b, 0x5e, 0xbe, 0x07, 0xf2, 0x3c, 0xf8, + 0x35, 0x7d, 0x76, 0x4f, 0x78, 0xa9, 0x2a, 0xf1, 0x32, 0xff, 0xec, 0x89, + 0xa9, 0x22, 0x4c, 0x3d, 0xc8, 0x65, 0xca, 0xf4, 0xa2, 0x6d, 0x3f, 0xa4, + 0x0a, 0xfa, 0x9e, 0xe4, 0xf0, 0xdb, 0x39, 0xb1, 0xf9, 0xf0, 0xfb, 0x04, + 0x81, 0x44, 0xa7, 0xd7, 0x61, 0xdf, 0x2d, 0x13, 0x45, 0x2c, 0xae, 0xf0, + 0x0e, 0xc4, 0x07, 0x5d, 0x7d, 0x2b, 0xb2, 0x20, 0x75, 0x33, 0x6b, 0x5b, + 0xf7, 0xe7, 0x17, 0x51, 0xf1, 0xab, 0xc1, 0x9e, 0xc6, 0xf0, 0x30, 0xc6, + 0x25, 0x26, 0x3e, 0xd7, 0xd7, 0xa3, 0xcc, 0x15, 0x95, 0x02, 0x03, 0x01, + 0x00, 0x01, 0xa3, 0x50, 0x30, 0x4e, 0x30, 0x1d, 0x06, 0x03, 0x55, 0x1d, + 0x0e, 0x04, 0x16, 0x04, 0x14, 0x45, 0x8a, 0x76, 0xf7, 0x4f, 0xf4, 0x0e, + 0xa0, 0xf2, 0x02, 0xe1, 0xe7, 0xe9, 0xc7, 0x7d, 0x51, 0x55, 0x92, 0x33, + 0xcd, 0x30, 0x1f, 0x06, 0x03, 0x55, 0x1d, 0x23, 0x04, 0x18, 0x30, 0x16, + 0x80, 0x14, 0x45, 0x8a, 0x76, 0xf7, 0x4f, 0xf4, 0x0e, 0xa0, 0xf2, 0x02, + 0xe1, 0xe7, 0xe9, 0xc7, 0x7d, 0x51, 0x55, 0x92, 0x33, 0xcd, 0x30, 0x0c, + 0x06, 0x03, 0x55, 0x1d, 0x13, 0x04, 0x05, 0x30, 0x03, 0x01, 0x01, 0xff, + 0x30, 0x0d, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x01, + 0x0b, 0x05, 0x00, 0x03, 0x82, 0x01, 0x01, 0x00, 0x47, 0x93, 0x82, 0x0e, + 0x8a, 0x70, 0x9d, 0x6c, 0x7a, 0xdb, 0x04, 0xb4, 0xc9, 0xef, 0x98, 0x28, + 0xc6, 0xd9, 0x53, 0x90, 0xc8, 0x25, 0x83, 0x07, 0x23, 0xe7, 0x59, 0x38, + 0xc1, 0xc0, 0x50, 0x28, 0x99, 0x92, 0xfb, 0x21, 0x24, 0x72, 0xe5, 0xa6, + 0x57, 0x30, 0x31, 0xb3, 0xdf, 0xa0, 0x17, 0xa9, 0x73, 0x9c, 0x39, 0x83, + 0xfb, 0xe4, 0xfa, 0x20, 0x1d, 0xfa, 0x33, 0x20, 0x0c, 0x72, 0x2a, 0x50, + 0x40, 0xbd, 0x2d, 0x33, 0xa2, 0xfc, 0x06, 0xf9, 0xfe, 0x86, 0x4f, 0x50, + 0x1d, 0x65, 0x37, 0xe9, 0x30, 0x33, 0x82, 0xa1, 0x75, 0x8f, 0x5d, 0x33, + 0x84, 0x0d, 0xf2, 0x09, 0x04, 0xc0, 0x7a, 0x12, 0x79, 0xdb, 0x4f, 0x77, + 0x04, 0xe4, 0xd8, 0x0b, 0x87, 0x19, 0xba, 0xb7, 0x3c, 0xa6, 0x45, 0xaa, + 0x91, 0x62, 0x7f, 0x01, 0x7d, 0xc6, 0x20, 0x6d, 0x71, 0x15, 0x74, 0x5e, + 0x87, 0xb3, 0x60, 0x17, 0x9c, 0xc0, 0xed, 0x01, 0x4b, 0xb3, 0x23, 0x24, + 0xc1, 0xcb, 0x7a, 0x83, 0x03, 0x26, 0x2d, 0xde, 0x47, 0xc5, 0x11, 0x94, + 0x28, 0x27, 0x15, 0x92, 0x00, 0x8b, 0x2e, 0x51, 0x42, 0xca, 0x4b, 0x4a, + 0x2c, 0x51, 0x37, 0x56, 0xd0, 0xbc, 0x33, 0xd5, 0xd5, 0x3e, 0x79, 0x5c, + 0x3f, 0x9d, 0x6e, 0xb1, 0xe9, 0x71, 0xf1, 0x2c, 0xe9, 0xb4, 0x88, 0x2c, + 0xd2, 0x49, 0x97, 0xce, 0x29, 0x94, 0x16, 0xc9, 0xf9, 0x64, 0x0e, 0xd0, + 0xd9, 0x7a, 0x53, 0x10, 0x1a, 0xee, 0x83, 0x73, 0x93, 0x1b, 0xdf, 0x8a, + 0x77, 0xc0, 0x56, 0x63, 0xab, 0x5a, 0x65, 0xc5, 0xc5, 0x3b, 0xf3, 0x30, + 0x80, 0xfc, 0x38, 0x8b, 0xc9, 0xcd, 0xc3, 0x4f, 0x2e, 0x2d, 0x67, 0xcc, + 0x17, 0x18, 0x9b, 0x3e, 0xc6, 0x47, 0x03, 0xfc, 0x35, 0xa8, 0x35, 0x06, + 0x5a, 0x77, 0xe5, 0x97, 0x71, 0xbb, 0x27, 0x93, 0x0d, 0x1f, 0x0e, 0x8c, + 0x31, 0x82, 0x02, 0x9b, 0x30, 0x82, 0x02, 0x97, 0x02, 0x01, 0x01, 0x30, + 0x81, 0x87, 0x30, 0x7a, 0x31, 0x0b, 0x30, 0x09, 0x06, 0x03, 0x55, 0x04, + 0x06, 0x13, 0x02, 0x4a, 0x50, 0x31, 0x0e, 0x30, 0x0c, 0x06, 0x03, 0x55, + 0x04, 0x08, 0x0c, 0x05, 0x54, 0x6f, 0x6b, 0x79, 0x6f, 0x31, 0x0e, 0x30, + 0x0c, 0x06, 0x03, 0x55, 0x04, 0x07, 0x0c, 0x05, 0x54, 0x6f, 0x6b, 0x79, + 0x6f, 0x31, 0x0f, 0x30, 0x0d, 0x06, 0x03, 0x55, 0x04, 0x0a, 0x0c, 0x06, + 0x4c, 0x69, 0x6e, 0x61, 0x72, 0x6f, 0x31, 0x0b, 0x30, 0x09, 0x06, 0x03, + 0x55, 0x04, 0x0b, 0x0c, 0x02, 0x53, 0x57, 0x31, 0x0f, 0x30, 0x0d, 0x06, + 0x03, 0x55, 0x04, 0x03, 0x0c, 0x06, 0x54, 0x65, 0x73, 0x74, 0x65, 0x72, + 0x31, 0x1c, 0x30, 0x1a, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, + 0x01, 0x09, 0x01, 0x16, 0x0d, 0x74, 0x65, 0x73, 0x74, 0x40, 0x74, 0x65, + 0x73, 0x74, 0x2e, 0x6f, 0x72, 0x67, 0x02, 0x09, 0x00, 0xd7, 0x17, 0x0a, + 0x76, 0xd5, 0xd3, 0x4d, 0xeb, 0x30, 0x0d, 0x06, 0x09, 0x60, 0x86, 0x48, + 0x01, 0x65, 0x03, 0x04, 0x02, 0x01, 0x05, 0x00, 0xa0, 0x81, 0xe5, 0x30, + 0x19, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x09, 0x03, + 0x31, 0x0c, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0x37, 0x02, + 0x01, 0x04, 0x30, 0x1c, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, + 0x01, 0x09, 0x05, 0x31, 0x0f, 0x17, 0x0d, 0x31, 0x39, 0x31, 0x30, 0x31, + 0x38, 0x30, 0x35, 0x35, 0x35, 0x32, 0x36, 0x5a, 0x30, 0x2f, 0x06, 0x09, + 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x09, 0x04, 0x31, 0x22, 0x04, + 0x20, 0x13, 0xe9, 0x2d, 0xcd, 0x35, 0x43, 0xe0, 0x13, 0x34, 0xc5, 0x67, + 0xde, 0xdd, 0x75, 0xdc, 0x62, 0x97, 0x76, 0x7d, 0x5b, 0xa0, 0xb4, 0x4d, + 0x4f, 0xef, 0xb8, 0xa7, 0x95, 0x50, 0xcb, 0x0f, 0xec, 0x30, 0x79, 0x06, + 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x09, 0x0f, 0x31, 0x6c, + 0x30, 0x6a, 0x30, 0x0b, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, + 0x04, 0x01, 0x2a, 0x30, 0x0b, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, + 0x03, 0x04, 0x01, 0x16, 0x30, 0x0b, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, + 0x65, 0x03, 0x04, 0x01, 0x02, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, + 0x86, 0xf7, 0x0d, 0x03, 0x07, 0x30, 0x0e, 0x06, 0x08, 0x2a, 0x86, 0x48, + 0x86, 0xf7, 0x0d, 0x03, 0x02, 0x02, 0x02, 0x00, 0x80, 0x30, 0x0d, 0x06, + 0x08, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x03, 0x02, 0x02, 0x01, 0x40, + 0x30, 0x07, 0x06, 0x05, 0x2b, 0x0e, 0x03, 0x02, 0x07, 0x30, 0x0d, 0x06, + 0x08, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x03, 0x02, 0x02, 0x01, 0x28, + 0x30, 0x0d, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x01, + 0x01, 0x05, 0x00, 0x04, 0x82, 0x01, 0x00, 0x38, 0x40, 0x09, 0xc7, 0xc4, + 0xf7, 0x78, 0x48, 0x75, 0x1e, 0xb2, 0x50, 0x95, 0x0a, 0x52, 0xee, 0x57, + 0x60, 0xc5, 0xf4, 0xdb, 0xca, 0x67, 0xb0, 0x19, 0xad, 0x68, 0xb1, 0xe1, + 0x1e, 0xb7, 0xf6, 0x53, 0x3d, 0x13, 0xb1, 0x11, 0x37, 0xa7, 0x6e, 0x9b, + 0x18, 0x1d, 0x0e, 0xbd, 0xc4, 0xb2, 0xd0, 0x36, 0x6c, 0x0c, 0x5a, 0x11, + 0x50, 0xcc, 0xdb, 0x1f, 0x6b, 0xcb, 0x28, 0x80, 0xd5, 0x3c, 0x4f, 0x93, + 0x0b, 0xd1, 0x45, 0x75, 0xa1, 0x89, 0x00, 0x71, 0x7d, 0x55, 0xcc, 0x1c, + 0x0a, 0xc9, 0xc4, 0xe6, 0x87, 0xf2, 0x87, 0x0d, 0x2e, 0x79, 0x71, 0x85, + 0x01, 0xd7, 0x32, 0x87, 0x9a, 0x11, 0xc6, 0x9a, 0xbb, 0x0a, 0x7b, 0xce, + 0xfe, 0xc8, 0xee, 0x10, 0x3c, 0xa6, 0x47, 0xdd, 0xbb, 0xa7, 0xf5, 0x19, + 0x50, 0xd5, 0x2a, 0x11, 0x44, 0x2f, 0x65, 0x09, 0x69, 0x50, 0xfa, 0xbd, + 0x02, 0xe4, 0x90, 0xdc, 0x2a, 0x7c, 0xdb, 0x82, 0x03, 0xa5, 0x28, 0x91, + 0x74, 0x7c, 0xd3, 0x83, 0xc8, 0x11, 0x1a, 0x14, 0x1b, 0xba, 0xb1, 0x82, + 0xbd, 0x53, 0xad, 0x9c, 0x34, 0x05, 0xfa, 0x2d, 0x14, 0x58, 0x5e, 0x50, + 0x64, 0x60, 0x5c, 0x21, 0x7c, 0xe6, 0xf0, 0x2b, 0xa2, 0xec, 0xe5, 0xeb, + 0xda, 0x88, 0xe2, 0x19, 0x36, 0x96, 0x65, 0xf7, 0x4c, 0x62, 0x9b, 0x75, + 0x24, 0xb4, 0xb1, 0x34, 0x83, 0xba, 0x05, 0x01, 0xd8, 0xe1, 0x33, 0xd3, + 0x1a, 0xd6, 0x09, 0x84, 0x31, 0xd0, 0x67, 0xf3, 0x3b, 0x0e, 0x19, 0x98, + 0x7e, 0x07, 0xdc, 0xe1, 0xd8, 0x45, 0x84, 0xa2, 0xdd, 0x8a, 0x04, 0x6a, + 0x43, 0xcf, 0xff, 0x7c, 0x9e, 0x83, 0xa8, 0x5d, 0xbc, 0x1f, 0x45, 0x86, + 0x5b, 0x2d, 0xcd, 0x9d, 0xa0, 0xba, 0x4d, 0xd2, 0xc6, 0xb9, 0xc5, 0x34, + 0x39, 0x29, 0x20, 0xee, 0x27, 0x60, 0x46, 0x9c, 0x62, 0xbe, 0xf2 +}; + +static unsigned int image_pk7_len = 1811; + +/** + * lib_asn1_pkcs7() - unit test for asn1 decoder function + * with pkcs7 message parser + * + * @uts: unit test state + * Return: 0 = success, 1 = failure + */ +static int lib_asn1_pkcs7(struct unit_test_state *uts) +{ + struct pkcs7_message *pkcs7; + + pkcs7 = pkcs7_parse_message(image_pk7, image_pk7_len); + + ut_assertf(pkcs7 != NULL, "decoding failed\n"); + ut_assertf(pkcs7->data_len == 104, "signature size doesn't match\n"); + ut_assertf(pkcs7->signed_infos != NULL, "sign-info doesn't exist\n"); + ut_assertf(pkcs7->signed_infos->msgdigest_len == 32, + "digest size doesn't match\n"); + ut_assertf(pkcs7->signed_infos->aa_set == 0xf, + "authenticated attributes doesn't match\n"); + + pkcs7_free_message(pkcs7); + + return CMD_RET_SUCCESS; +} + +LIB_TEST(lib_asn1_pkcs7, 0); +#endif /* CONFIG_PKCS7_MESSAGE_PARSER */ + +#ifdef CONFIG_RSA_PUBLIC_KEY_PARSER +#include <crypto/internal/rsa.h> + +/* + * openssl genrsa 2048 -out private.pem + * openssl rsa -in private.pem -pubout -outform der -out public.der + * dd if=public.der of=public.raw bs=24 skip=1 + */ +static const unsigned char public_key[] = { + 0x30, 0x82, 0x01, 0x0a, 0x02, 0x82, 0x01, 0x01, 0x00, 0xca, 0x25, 0x23, + 0xe0, 0x0a, 0x4d, 0x8f, 0x56, 0xfc, 0xc9, 0x06, 0x4c, 0xcc, 0x94, 0x43, + 0xe0, 0x56, 0x44, 0x6e, 0x37, 0x54, 0x87, 0x12, 0x84, 0xf9, 0x07, 0x4f, + 0xe4, 0x23, 0x40, 0xc3, 0x43, 0x84, 0x37, 0x86, 0xd3, 0x9d, 0x95, 0x1c, + 0xe4, 0x8a, 0x66, 0x02, 0x09, 0xe2, 0x3d, 0xce, 0x2c, 0xc6, 0x02, 0x6a, + 0xd4, 0x65, 0x61, 0xff, 0x85, 0x6f, 0x88, 0x63, 0xba, 0x31, 0x62, 0x1e, + 0xb7, 0x95, 0xe9, 0x08, 0x3c, 0xe9, 0x35, 0xde, 0xfd, 0x65, 0x92, 0xb8, + 0x9e, 0x71, 0xa4, 0xcd, 0x47, 0xfd, 0x04, 0x26, 0xb9, 0x78, 0xbf, 0x05, + 0x0d, 0xfc, 0x00, 0x84, 0x08, 0xfc, 0xc4, 0x4b, 0xea, 0xf5, 0x97, 0x68, + 0x0d, 0x97, 0xd7, 0xff, 0x4f, 0x92, 0x82, 0xd7, 0xbb, 0xef, 0xb7, 0x67, + 0x8e, 0x72, 0x54, 0xe8, 0xc5, 0x9e, 0xfd, 0xd8, 0x38, 0xe9, 0xbe, 0x19, + 0x37, 0x5b, 0x36, 0x8b, 0xbf, 0x49, 0xa1, 0x59, 0x3a, 0x9d, 0xad, 0x92, + 0x08, 0x0b, 0xe3, 0xa4, 0xa4, 0x7d, 0xd3, 0x70, 0xc0, 0xb8, 0xfb, 0xc7, + 0xda, 0xd3, 0x19, 0x86, 0x37, 0x9a, 0xcd, 0xab, 0x30, 0x96, 0xab, 0xa4, + 0xa2, 0x31, 0xa0, 0x38, 0xfb, 0xbf, 0x85, 0xd3, 0x24, 0x39, 0xed, 0xbf, + 0xe1, 0x31, 0xed, 0x6c, 0x39, 0xc1, 0xe5, 0x05, 0x2e, 0x12, 0x30, 0x36, + 0x73, 0x5d, 0x62, 0xf3, 0x82, 0xaf, 0x38, 0xc8, 0xca, 0xfa, 0xa1, 0x99, + 0x57, 0x3c, 0xe1, 0xc1, 0x7b, 0x05, 0x0b, 0xcc, 0x2e, 0xa9, 0x10, 0xc8, + 0x68, 0xbd, 0x27, 0xb6, 0x19, 0x9c, 0xd2, 0xad, 0xb3, 0x1f, 0xca, 0x35, + 0x6e, 0x84, 0x23, 0xa1, 0xe9, 0xa4, 0x4c, 0xab, 0x19, 0x09, 0x79, 0x6e, + 0x3c, 0x7b, 0x74, 0xfc, 0x33, 0x05, 0xcf, 0xa4, 0x2e, 0xeb, 0x55, 0x60, + 0x05, 0xc7, 0xcf, 0x3f, 0x92, 0xac, 0x2d, 0x69, 0x0b, 0x19, 0x16, 0x79, + 0x75, 0x02, 0x03, 0x01, 0x00, 0x01 +}; + +static unsigned int public_key_len = 270; + +/** + * lib_asn1_pkey() - unit test for asn1 decoder function + * with RSA public key parser + * + * @uts: unit test state + * Return: 0 = success, 1 = failure + */ +static int lib_asn1_pkey(struct unit_test_state *uts) +{ + struct rsa_key pkey; + int ret; + + ret = rsa_parse_pub_key(&pkey, public_key, public_key_len); + + ut_assertf(ret == 0, "decoding failed (%d)\n", ret); + ut_assertf(pkey.n_sz == 257, "public key modulus size doesn't match\n"); + ut_assertf(pkey.e_sz == 3, "public key exponent size doesn't match\n"); + ut_assertf(pkey.e[0] == 0x01 && pkey.e[1] == 0x00 && pkey.e[2] == 0x01, + "public key exponent doesn't match\n"); + + return CMD_RET_SUCCESS; +} + +LIB_TEST(lib_asn1_pkey, 0); +#endif /* CONFIG_RSA_PUBLIC_KEY_PARSER */
AKASHI Takahiro
