[U-Boot] [PATCH 10/25] x86: ich6-gpio: Add Intel Tunnel Creek GPIO support
Intel Tunnel Creek GPIO register block is compatible with current ich6-gpio driver, except the offset and content of GPIO block base address register in the LPC PCI configuration space are different.
Use u16 instead of u32 to store the 16-bit I/O address of the GPIO registers so that it could support both Ivybridge and Tunnel Creek.
Signed-off-by: Bin Meng bmeng.cn@gmail.com --- arch/x86/include/asm/arch-queensbay/gpio.h | 13 +++++++++++++ arch/x86/include/asm/gpio.h | 2 +- board/google/chromebook_link/link.c | 2 +- drivers/gpio/intel_ich6_gpio.c | 17 ++++++++--------- 4 files changed, 23 insertions(+), 11 deletions(-) create mode 100644 arch/x86/include/asm/arch-queensbay/gpio.h
diff --git a/arch/x86/include/asm/arch-queensbay/gpio.h b/arch/x86/include/asm/arch-queensbay/gpio.h new file mode 100644 index 0000000..ab4e059 --- /dev/null +++ b/arch/x86/include/asm/arch-queensbay/gpio.h @@ -0,0 +1,13 @@ +/* + * Copyright (C) 2014, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _X86_ARCH_GPIO_H_ +#define _X86_ARCH_GPIO_H_ + +/* Where in config space is the register that points to the GPIO registers? */ +#define PCI_CFG_GPIOBASE 0x44 + +#endif /* _X86_ARCH_GPIO_H_ */ diff --git a/arch/x86/include/asm/gpio.h b/arch/x86/include/asm/gpio.h index 5540d42..83878a7 100644 --- a/arch/x86/include/asm/gpio.h +++ b/arch/x86/include/asm/gpio.h @@ -11,7 +11,7 @@ #include <asm-generic/gpio.h>
struct ich6_bank_platdata { - uint32_t base_addr; + uint16_t base_addr; const char *bank_name; };
diff --git a/board/google/chromebook_link/link.c b/board/google/chromebook_link/link.c index 4d95c1c..9978e92 100644 --- a/board/google/chromebook_link/link.c +++ b/board/google/chromebook_link/link.c @@ -125,7 +125,7 @@ int board_early_init_f(void) return 0; }
-void setup_pch_gpios(u32 gpiobase, const struct pch_gpio_map *gpio) +void setup_pch_gpios(u16 gpiobase, const struct pch_gpio_map *gpio) { /* GPIO Set 1 */ if (gpio->set1.level) diff --git a/drivers/gpio/intel_ich6_gpio.c b/drivers/gpio/intel_ich6_gpio.c index 3a2e1b0..3b2962a 100644 --- a/drivers/gpio/intel_ich6_gpio.c +++ b/drivers/gpio/intel_ich6_gpio.c @@ -39,12 +39,12 @@
struct ich6_bank_priv { /* These are I/O addresses */ - uint32_t use_sel; - uint32_t io_sel; - uint32_t lvl; + uint16_t use_sel; + uint16_t io_sel; + uint16_t lvl; };
-__weak void setup_pch_gpios(u32 gpiobase, const struct pch_gpio_map *gpio) +__weak void setup_pch_gpios(u16 gpiobase, const struct pch_gpio_map *gpio) { return; } @@ -62,7 +62,7 @@ static int gpio_ich6_ofdata_to_platdata(struct udevice *dev) u8 tmpbyte; u16 tmpword; u32 tmplong; - u32 gpiobase; + u16 gpiobase; int offset;
/* Where should it be? */ @@ -121,11 +121,10 @@ static int gpio_ich6_ofdata_to_platdata(struct udevice *dev) /* * GPIOBASE moved to its current offset with ICH6, but prior to * that it was unused (or undocumented). Check that it looks - * okay: not all ones or zeros, and mapped to I/O space (bit 0). + * okay: not all ones or zeros. */ tmplong = pci_read_config32(pci_dev, PCI_CFG_GPIOBASE); - if (tmplong == 0x00000000 || tmplong == 0xffffffff || - !(tmplong & 0x00000001)) { + if (tmplong == 0x00000000 || tmplong == 0xffffffff) { debug("%s: unexpected GPIOBASE value\n", __func__); return -ENODEV; } @@ -136,7 +135,7 @@ static int gpio_ich6_ofdata_to_platdata(struct udevice *dev) * at the offset that we just read. Bit 0 indicates that it's * an I/O address, not a memory address, so mask that off. */ - gpiobase = tmplong & 0xfffffffe; + gpiobase = tmplong & 0xfffe; offset = fdtdec_get_int(gd->fdt_blob, dev->of_offset, "reg", -1); if (offset == -1) { debug("%s: Invalid register offset %d\n", __func__, offset);
Hi Bin,
How does that help?
- Copyright (C) 2014, Bin Meng bmeng.cn@gmail.com
uint32_t base_addr;
uint32_t use_sel;
uint32_t io_sel;
uint32_t lvl;
uint16_t use_sel;
uint16_t io_sel;
uint16_t lvl;
u32 gpiobase;
u16 gpiobase; int offset; /* Where should it be? */
Why take out this check?
-- 1.8.2.1
Hi Simon,
On Fri, Dec 5, 2014 at 6:43 AM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
How does that help?
The Tunnel Creek GPIO base address register bit31 is bit to control the I/O decode of the GPIO block (1 means decode enable), while on the Ivybridge bit31-bit16 is reserved (read returns 0).
uint32_t base_addr;
uint32_t use_sel;
uint32_t io_sel;
uint32_t lvl;
uint16_t use_sel;
uint16_t io_sel;
uint16_t lvl;
u32 gpiobase;
Again the Tunnel Creek GPIO base address register bit0 is reserved (read returns 0), while on the Ivybridge the bit0 is used to indicate it is an I/O space.
[snip]
Regards, Bin
Hi Bin,
On 5 December 2014 at 01:35, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Hi Bin,
How does that help?
uint32_t base_addr;
uint32_t use_sel;
uint32_t io_sel;
uint32_t lvl;
uint16_t use_sel;
uint16_t io_sel;
uint16_t lvl;
u32 gpiobase;
OK can you add a comment here about that?
Hi Simon,
On Fri, Dec 5, 2014 at 11:08 PM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
Hi Simon,
Hi Bin,
How does that help?
uint32_t base_addr;
uint32_t use_sel;
uint32_t io_sel;
uint32_t lvl;
uint16_t use_sel;
uint16_t io_sel;
uint16_t lvl;
u32 gpiobase;
Will do in v2.
Regards, Bin
Bin Meng
