[U-Boot] [PATCH v4 00/16] spi: zynq qspi support
These are the previous version patches- https://patchwork.ozlabs.org/patch/302945/ https://patchwork.ozlabs.org/patch/264440/
This series adds zynq qspi controller driver in driver model and enabled support on relevent zynq boards and tested the same.
Branch to verify: $ git clone git://git.denx.de/u-boot-spi.git $ cd u-boot-spi $ git checkout -b master-next origin/master-next
Changes for v4: - Rebase to master
Changes for v3: - Added driver-model to zynq-qspi driver - devicetree support on zynq-qspi - Enabled qspi nodes on relevent board dts files - Enabled qspi driver on relevent board config files
Changes for v3: - Fixes with macro's addition
Jagan Teki (16): spi: Add zynq qspi controller driver dts: zynq: Add zynq qspi controller nodes doc: device-tree-bindings: spi: Add zynq qspi info dts: microzed: Enable zynq qspi controller node dts: zc702: Enable zynq qspi controller node dts: zc706: Enable zynq qspi controller node dts: zc770-xm010: Enable zynq qspi controller node dts: zed: Enable zynq qspi controller node configs: Enable legacy SPI flash interface support zynq-common: Enable zynq qspi controller support zynq-common: Enable Bank/Extended address register support configs: zynq: Enable zynq qspi controller spi: Kconfig: Add Zynq QSPI controller entry spi: zynq_spi: Add config reg shift named macros spi: zynq_spi: Rename baudrate divisor mask name spi: zynq_spi: Store cs value into private data
arch/arm/dts/zynq-7000.dtsi | 12 + arch/arm/dts/zynq-microzed.dts | 5 + arch/arm/dts/zynq-zc702.dts | 5 + arch/arm/dts/zynq-zc706.dts | 5 + arch/arm/dts/zynq-zc770-xm010.dts | 5 + arch/arm/dts/zynq-zed.dts | 5 + configs/zynq_microzed_defconfig | 2 + configs/zynq_zc702_defconfig | 2 + configs/zynq_zc706_defconfig | 2 + configs/zynq_zc70x_defconfig | 2 + configs/zynq_zc770_xm010_defconfig | 1 + configs/zynq_zed_defconfig | 2 + doc/device-tree-bindings/spi/spi-zynq-qspi.txt | 26 ++ drivers/spi/Kconfig | 9 + drivers/spi/Makefile | 1 + drivers/spi/zynq_qspi.c | 622 +++++++++++++++++++++++++ drivers/spi/zynq_spi.c | 20 +- include/configs/zynq-common.h | 10 + 18 files changed, 729 insertions(+), 7 deletions(-) create mode 100644 doc/device-tree-bindings/spi/spi-zynq-qspi.txt create mode 100644 drivers/spi/zynq_qspi.c
Added zynq qspi controller driver for Xilinx Zynq APSOC, this driver is driver-model driven with devicetree support.
=> sf probe SF: Detected S25FL128S_64K with page size 256 Bytes, erase size 64 KiB, total 16 MiB => mw.b 0x100 0xCC 0x1000000 => sf update 0x100 0x0 0x1000000 device 0 whole chip 16777216 bytes written, 0 bytes skipped in 59.842s, speed 289262 B/s => sf read 0x3000000 0x0 0x1000000 device 0 whole chip SF: 16777216 bytes @ 0x0 Read: OK => cmp.b 0x3000000 0x100 0x1000000 Total of 16777216 byte(s) were the same
Signed-off-by: Jagan Teki jteki@openedev.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Tested-by: Jagan Teki jteki@openedev.com --- drivers/spi/Makefile | 1 + drivers/spi/zynq_qspi.c | 622 ++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 623 insertions(+) create mode 100644 drivers/spi/zynq_qspi.c
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index ee88aa1..f59312b 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -48,3 +48,4 @@ obj-$(CONFIG_TEGRA20_SLINK) += tegra20_slink.o obj-$(CONFIG_TI_QSPI) += ti_qspi.o obj-$(CONFIG_XILINX_SPI) += xilinx_spi.o obj-$(CONFIG_ZYNQ_SPI) += zynq_spi.o +obj-$(CONFIG_ZYNQ_QSPI) += zynq_qspi.o diff --git a/drivers/spi/zynq_qspi.c b/drivers/spi/zynq_qspi.c new file mode 100644 index 0000000..0ce6127 --- /dev/null +++ b/drivers/spi/zynq_qspi.c @@ -0,0 +1,622 @@ +/* + * (C) Copyright 2013 Xilinx, Inc. + * (C) Copyright 2015 Jagan Teki jteki@openedev.com + * + * Xilinx Zynq Quad-SPI(QSPI) controller driver (master mode only) + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <malloc.h> +#include <spi.h> +#include <asm/io.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* zynq qspi register bit masks ZYNQ_QSPI_<REG>_<BIT>_MASK */ +#define ZYNQ_QSPI_CR_IFMODE_MASK (1 << 31) /* Flash intrface mode*/ +#define ZYNQ_QSPI_CR_MSA_MASK (1 << 15) /* Manual start enb */ +#define ZYNQ_QSPI_CR_MCS_MASK (1 << 14) /* Manual chip select */ +#define ZYNQ_QSPI_CR_PCS_MASK (1 << 10) /* Peri chip select */ +#define ZYNQ_QSPI_CR_FW_MASK (0x3 << 6) /* FIFO width */ +#define ZYNQ_QSPI_CR_SS_MASK (0xF << 10) /* Slave Select */ +#define ZYNQ_QSPI_CR_BAUD_MASK (0x7 << 3) /* Baud rate div */ +#define ZYNQ_QSPI_CR_CPHA_MASK (1 << 2) /* Clock phase */ +#define ZYNQ_QSPI_CR_CPOL_MASK (1 << 1) /* Clock polarity */ +#define ZYNQ_QSPI_CR_MSTREN_MASK (1 << 0) /* Mode select */ +#define ZYNQ_QSPI_IXR_RXNEMPTY_MASK (1 << 4) /* RX_FIFO_not_empty */ +#define ZYNQ_QSPI_IXR_TXOW_MASK (1 << 2) /* TX_FIFO_not_full */ +#define ZYNQ_QSPI_IXR_ALL_MASK 0x7F /* All IXR bits */ +#define ZYNQ_QSPI_ENR_SPI_EN_MASK (1 << 0) /* SPI Enable */ + +/* zynq qspi Transmit Data Register */ +#define ZYNQ_QSPI_TXD_00_00_OFFSET 0x1C /* Transmit 4-byte inst */ +#define ZYNQ_QSPI_TXD_00_01_OFFSET 0x80 /* Transmit 1-byte inst */ +#define ZYNQ_QSPI_TXD_00_10_OFFSET 0x84 /* Transmit 2-byte inst */ +#define ZYNQ_QSPI_TXD_00_11_OFFSET 0x88 /* Transmit 3-byte inst */ + +#define ZYNQ_QSPI_TXFIFO_THRESHOLD 1 /* Tx FIFO threshold level*/ +#define ZYNQ_QSPI_RXFIFO_THRESHOLD 32 /* Rx FIFO threshold level */ + +#define ZYNQ_QSPI_CR_BAUD_MAX 8 /* Baud rate divisor max val */ +#define ZYNQ_QSPI_CR_BAUD_SHIFT 3 /* Baud rate divisor shift */ +#define ZYNQ_QSPI_CR_SS_SHIFT 10 /* Slave select shift */ + +#define ZYNQ_QSPI_FIFO_DEPTH 63 +#ifndef CONFIG_SYS_ZYNQ_QSPI_WAIT +#define CONFIG_SYS_ZYNQ_QSPI_WAIT CONFIG_SYS_HZ/100 /* 10 ms */ +#endif + +/* zynq qspi register set */ +struct zynq_qspi_regs { + u32 cr; /* 0x00 */ + u32 isr; /* 0x04 */ + u32 ier; /* 0x08 */ + u32 idr; /* 0x0C */ + u32 imr; /* 0x10 */ + u32 enr; /* 0x14 */ + u32 dr; /* 0x18 */ + u32 txd0r; /* 0x1C */ + u32 drxr; /* 0x20 */ + u32 sicr; /* 0x24 */ + u32 txftr; /* 0x28 */ + u32 rxftr; /* 0x2C */ + u32 gpior; /* 0x30 */ + u32 reserved0[19]; + u32 txd1r; /* 0x80 */ + u32 txd2r; /* 0x84 */ + u32 txd3r; /* 0x88 */ +}; + +/* zynq qspi platform data */ +struct zynq_qspi_platdata { + struct zynq_qspi_regs *regs; + u32 frequency; /* input frequency */ + u32 speed_hz; +}; + +/* zynq qspi priv */ +struct zynq_qspi_priv { + struct zynq_qspi_regs *regs; + u8 cs; + u8 mode; + u8 fifo_depth; + u32 freq; /* required frequency */ + const void *tx_buf; + void *rx_buf; + unsigned len; + int bytes_to_transfer; + int bytes_to_receive; + unsigned int is_inst; + unsigned cs_change:1; +}; + +static int zynq_qspi_ofdata_to_platdata(struct udevice *bus) +{ + struct zynq_qspi_platdata *plat = bus->platdata; + const void *blob = gd->fdt_blob; + int node = bus->of_offset; + + plat->regs = (struct zynq_qspi_regs *)fdtdec_get_addr(blob, + node, "reg"); + + /* FIXME: Use 166MHz as a suitable default */ + plat->frequency = fdtdec_get_int(blob, node, "spi-max-frequency", + 166666666); + plat->speed_hz = plat->frequency / 2; + + debug("%s: regs=%p max-frequency=%d\n", __func__, + plat->regs, plat->frequency); + + return 0; +} + +static void zynq_qspi_init_hw(struct zynq_qspi_priv *priv) +{ + struct zynq_qspi_regs *regs = priv->regs; + u32 confr; + + /* Disable QSPI */ + writel(~ZYNQ_QSPI_ENR_SPI_EN_MASK, ®s->enr); + + /* Disable Interrupts */ + writel(ZYNQ_QSPI_IXR_ALL_MASK, ®s->idr); + + /* Clear the TX and RX threshold reg */ + writel(ZYNQ_QSPI_TXFIFO_THRESHOLD, ®s->txftr); + writel(ZYNQ_QSPI_RXFIFO_THRESHOLD, ®s->rxftr); + + /* Clear the RX FIFO */ + while (readl(®s->isr) & ZYNQ_QSPI_IXR_RXNEMPTY_MASK) + readl(®s->drxr); + + /* Clear Interrupts */ + writel(ZYNQ_QSPI_IXR_ALL_MASK, ®s->isr); + + /* Manual slave select and Auto start */ + confr = readl(®s->cr); + confr &= ~ZYNQ_QSPI_CR_MSA_MASK; + confr |= ZYNQ_QSPI_CR_IFMODE_MASK | ZYNQ_QSPI_CR_MCS_MASK | + ZYNQ_QSPI_CR_PCS_MASK | ZYNQ_QSPI_CR_FW_MASK | + ZYNQ_QSPI_CR_MSTREN_MASK; + writel(confr, ®s->cr); + + /* Enable SPI */ + writel(ZYNQ_QSPI_ENR_SPI_EN_MASK, ®s->enr); +} + +static int zynq_qspi_probe(struct udevice *bus) +{ + struct zynq_qspi_platdata *plat = dev_get_platdata(bus); + struct zynq_qspi_priv *priv = dev_get_priv(bus); + + priv->regs = plat->regs; + priv->fifo_depth = ZYNQ_QSPI_FIFO_DEPTH; + + /* init the zynq spi hw */ + zynq_qspi_init_hw(priv); + + return 0; +} + +/* + * zynq_qspi_read_data - Copy data to RX buffer + * @zqspi: Pointer to the zynq_qspi structure + * @data: The 32 bit variable where data is stored + * @size: Number of bytes to be copied from data to RX buffer + */ +static void zynq_qspi_read_data(struct zynq_qspi_priv *priv, u32 data, u8 size) +{ + u8 byte3; + + debug("%s: data 0x%04x rx_buf addr: 0x%08x size %d\n", __func__ , + data, (unsigned)(priv->rx_buf), size); + + if (priv->rx_buf) { + switch (size) { + case 1: + *((u8 *)priv->rx_buf) = data; + priv->rx_buf += 1; + break; + case 2: + *((u16 *)priv->rx_buf) = data; + priv->rx_buf += 2; + break; + case 3: + *((u16 *)priv->rx_buf) = data; + priv->rx_buf += 2; + byte3 = (u8)(data >> 16); + *((u8 *)priv->rx_buf) = byte3; + priv->rx_buf += 1; + break; + case 4: + /* Can not assume word aligned buffer */ + memcpy(priv->rx_buf, &data, size); + priv->rx_buf += 4; + break; + default: + /* This will never execute */ + break; + } + } + priv->bytes_to_receive -= size; + if (priv->bytes_to_receive < 0) + priv->bytes_to_receive = 0; +} + +/* + * zynq_qspi_write_data - Copy data from TX buffer + * @zqspi: Pointer to the zynq_qspi structure + * @data: Pointer to the 32 bit variable where data is to be copied + * @size: Number of bytes to be copied from TX buffer to data + */ +static void zynq_qspi_write_data(struct zynq_qspi_priv *priv, + u32 *data, u8 size) +{ + if (priv->tx_buf) { + switch (size) { + case 1: + *data = *((u8 *)priv->tx_buf); + priv->tx_buf += 1; + *data |= 0xFFFFFF00; + break; + case 2: + *data = *((u16 *)priv->tx_buf); + priv->tx_buf += 2; + *data |= 0xFFFF0000; + break; + case 3: + *data = *((u16 *)priv->tx_buf); + priv->tx_buf += 2; + *data |= (*((u8 *)priv->tx_buf) << 16); + priv->tx_buf += 1; + *data |= 0xFF000000; + break; + case 4: + /* Can not assume word aligned buffer */ + memcpy(data, priv->tx_buf, size); + priv->tx_buf += 4; + break; + default: + /* This will never execute */ + break; + } + } else { + *data = 0; + } + + debug("%s: data 0x%08x tx_buf addr: 0x%08x size %d\n", __func__, + *data, (u32)priv->tx_buf, size); + + priv->bytes_to_transfer -= size; + if (priv->bytes_to_transfer < 0) + priv->bytes_to_transfer = 0; +} + +static void zynq_qspi_chipselect(struct zynq_qspi_priv *priv, int is_on) +{ + u32 confr; + struct zynq_qspi_regs *regs = priv->regs; + + confr = readl(®s->cr); + + if (is_on) { + /* Select the slave */ + confr &= ~ZYNQ_QSPI_CR_SS_MASK; + confr |= (~(1 << priv->cs) << ZYNQ_QSPI_CR_SS_SHIFT) & + ZYNQ_QSPI_CR_SS_MASK; + } else + /* Deselect the slave */ + confr |= ZYNQ_QSPI_CR_SS_MASK; + + writel(confr, ®s->cr); +} + +/* + * zynq_qspi_fill_tx_fifo - Fills the TX FIFO with as many bytes as possible + * @zqspi: Pointer to the zynq_qspi structure + */ +static void zynq_qspi_fill_tx_fifo(struct zynq_qspi_priv *priv, u32 size) +{ + u32 data = 0; + u32 fifocount = 0; + unsigned len, offset; + struct zynq_qspi_regs *regs = priv->regs; + static const unsigned offsets[4] = { + ZYNQ_QSPI_TXD_00_00_OFFSET, ZYNQ_QSPI_TXD_00_01_OFFSET, + ZYNQ_QSPI_TXD_00_10_OFFSET, ZYNQ_QSPI_TXD_00_11_OFFSET }; + + while ((fifocount < size) && + (priv->bytes_to_transfer > 0)) { + if (priv->bytes_to_transfer >= 4) { + if (priv->tx_buf) { + memcpy(&data, priv->tx_buf, 4); + priv->tx_buf += 4; + } else { + data = 0; + } + writel(data, ®s->txd0r); + priv->bytes_to_transfer -= 4; + fifocount++; + } else { + /* Write TXD1, TXD2, TXD3 only if TxFIFO is empty. */ + if (!(readl(®s->isr) + & ZYNQ_QSPI_IXR_TXOW_MASK) && + !priv->rx_buf) + return; + len = priv->bytes_to_transfer; + zynq_qspi_write_data(priv, &data, len); + offset = (priv->rx_buf) ? offsets[0] : offsets[len]; + writel(data, ®s->cr + (offset / 4)); + } + } +} + +/* + * zynq_qspi_irq_poll - Interrupt service routine of the QSPI controller + * @zqspi: Pointer to the zynq_qspi structure + * + * This function handles TX empty and Mode Fault interrupts only. + * On TX empty interrupt this function reads the received data from RX FIFO and + * fills the TX FIFO if there is any data remaining to be transferred. + * On Mode Fault interrupt this function indicates that transfer is completed, + * the SPI subsystem will identify the error as the remaining bytes to be + * transferred is non-zero. + * + * returns: 0 for poll timeout + * 1 transfer operation complete + */ +static int zynq_qspi_irq_poll(struct zynq_qspi_priv *priv) +{ + struct zynq_qspi_regs *regs = priv->regs; + u32 rxindex = 0; + u32 rxcount; + u32 status, timeout; + + /* Poll until any of the interrupt status bits are set */ + timeout = get_timer(0); + do { + status = readl(®s->isr); + } while ((status == 0) && + (get_timer(timeout) < CONFIG_SYS_ZYNQ_QSPI_WAIT)); + + if (status == 0) { + printf("zynq_qspi_irq_poll: Timeout!\n"); + return -ETIMEDOUT; + } + + writel(status, ®s->isr); + + /* Disable all interrupts */ + writel(ZYNQ_QSPI_IXR_ALL_MASK, ®s->idr); + if ((status & ZYNQ_QSPI_IXR_TXOW_MASK) || + (status & ZYNQ_QSPI_IXR_RXNEMPTY_MASK)) { + /* + * This bit is set when Tx FIFO has < THRESHOLD entries. We have + * the THRESHOLD value set to 1, so this bit indicates Tx FIFO + * is empty + */ + rxcount = priv->bytes_to_receive - priv->bytes_to_transfer; + rxcount = (rxcount % 4) ? ((rxcount/4)+1) : (rxcount/4); + while ((rxindex < rxcount) && + (rxindex < ZYNQ_QSPI_RXFIFO_THRESHOLD)) { + /* Read out the data from the RX FIFO */ + u32 data; + data = readl(®s->drxr); + + if (priv->bytes_to_receive >= 4) { + if (priv->rx_buf) { + memcpy(priv->rx_buf, &data, 4); + priv->rx_buf += 4; + } + priv->bytes_to_receive -= 4; + } else { + zynq_qspi_read_data(priv, data, + priv->bytes_to_receive); + } + rxindex++; + } + + if (priv->bytes_to_transfer) { + /* There is more data to send */ + zynq_qspi_fill_tx_fifo(priv, + ZYNQ_QSPI_RXFIFO_THRESHOLD); + + writel(ZYNQ_QSPI_IXR_ALL_MASK, ®s->ier); + } else { + /* + * If transfer and receive is completed then only send + * complete signal + */ + if (!priv->bytes_to_receive) { + /* return operation complete */ + writel(ZYNQ_QSPI_IXR_ALL_MASK, + ®s->idr); + return 1; + } + } + } + + return 0; +} + +/* + * zynq_qspi_start_transfer - Initiates the QSPI transfer + * @qspi: Pointer to the spi_device structure + * @transfer: Pointer to the spi_transfer structure which provide information + * about next transfer parameters + * + * This function fills the TX FIFO, starts the QSPI transfer, and waits for the + * transfer to be completed. + * + * returns: Number of bytes transferred in the last transfer + */ +static int zynq_qspi_start_transfer(struct zynq_qspi_priv *priv) +{ + u32 data = 0; + struct zynq_qspi_regs *regs = priv->regs; + + debug("%s: qspi: 0x%08x transfer: 0x%08x len: %d\n", __func__, + (u32)priv, (u32)priv, priv->len); + + priv->bytes_to_transfer = priv->len; + priv->bytes_to_receive = priv->len; + + if (priv->len < 4) + zynq_qspi_fill_tx_fifo(priv, priv->len); + else + zynq_qspi_fill_tx_fifo(priv, priv->fifo_depth); + + writel(ZYNQ_QSPI_IXR_ALL_MASK, ®s->ier); + /* Start the transfer by enabling manual start bit */ + + /* wait for completion */ + do { + data = zynq_qspi_irq_poll(priv); + } while (data == 0); + + return (priv->len) - (priv->bytes_to_transfer); +} + +static int zynq_qspi_transfer(struct zynq_qspi_priv *priv) +{ + unsigned cs_change = 1; + int status = 0; + + while (1) { + /* Select the chip if required */ + if (cs_change) + zynq_qspi_chipselect(priv, 1); + + cs_change = priv->cs_change; + + if (!priv->tx_buf && !priv->rx_buf && priv->len) { + status = -1; + break; + } + + /* Request the transfer */ + if (priv->len) { + status = zynq_qspi_start_transfer(priv); + priv->is_inst = 0; + } + + if (status != priv->len) { + if (status > 0) + status = -EMSGSIZE; + debug("zynq_qspi_transfer:%d len:%d\n", + status, priv->len); + break; + } + status = 0; + + if (cs_change) + /* Deselect the chip */ + zynq_qspi_chipselect(priv, 0); + + break; + } + + return 0; +} + +static int zynq_qspi_claim_bus(struct udevice *dev) +{ + struct udevice *bus = dev->parent; + struct zynq_qspi_priv *priv = dev_get_priv(bus); + struct zynq_qspi_regs *regs = priv->regs; + + writel(ZYNQ_QSPI_ENR_SPI_EN_MASK, ®s->enr); + + return 0; +} + +static int zynq_qspi_release_bus(struct udevice *dev) +{ + struct udevice *bus = dev->parent; + struct zynq_qspi_priv *priv = dev_get_priv(bus); + struct zynq_qspi_regs *regs = priv->regs; + + writel(~ZYNQ_QSPI_ENR_SPI_EN_MASK, ®s->enr); + + return 0; +} + +static int zynq_qspi_xfer(struct udevice *dev, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct udevice *bus = dev->parent; + struct zynq_qspi_priv *priv = dev_get_priv(bus); + struct dm_spi_slave_platdata *slave_plat = dev_get_parent_platdata(dev); + + priv->cs = slave_plat->cs; + priv->tx_buf = dout; + priv->rx_buf = din; + priv->len = bitlen / 8; + + debug("spi_xfer: bus:%i cs:%i bitlen:%i len:%i flags:%lx\n", + bus->seq, slave_plat->cs, bitlen, priv->len, flags); + + /* + * Festering sore. + * Assume that the beginning of a transfer with bits to + * transmit must contain a device command. + */ + if (dout && flags & SPI_XFER_BEGIN) + priv->is_inst = 1; + else + priv->is_inst = 0; + + if (flags & SPI_XFER_END) + priv->cs_change = 1; + else + priv->cs_change = 0; + + zynq_qspi_transfer(priv); + + return 0; +} + +static int zynq_qspi_set_speed(struct udevice *bus, uint speed) +{ + struct zynq_qspi_platdata *plat = bus->platdata; + struct zynq_qspi_priv *priv = dev_get_priv(bus); + struct zynq_qspi_regs *regs = priv->regs; + uint32_t confr; + u8 baud_rate_val = 0; + + if (speed > plat->frequency) + speed = plat->frequency; + + /* Set the clock frequency */ + confr = readl(®s->cr); + if (speed == 0) { + /* Set baudrate x8, if the freq is 0 */ + baud_rate_val = 0x2; + } else if (plat->speed_hz != speed) { + while ((baud_rate_val < ZYNQ_QSPI_CR_BAUD_MAX) && + ((plat->frequency / + (2 << baud_rate_val)) > speed)) + baud_rate_val++; + + plat->speed_hz = speed / (2 << baud_rate_val); + } + confr &= ~ZYNQ_QSPI_CR_BAUD_MASK; + confr |= (baud_rate_val << ZYNQ_QSPI_CR_BAUD_SHIFT); + + writel(confr, ®s->cr); + priv->freq = speed; + + debug("zynq_spi_set_speed: regs=%p, mode=%d\n", priv->regs, priv->freq); + + return 0; +} + +static int zynq_qspi_set_mode(struct udevice *bus, uint mode) +{ + struct zynq_qspi_priv *priv = dev_get_priv(bus); + struct zynq_qspi_regs *regs = priv->regs; + uint32_t confr; + + /* Set the SPI Clock phase and polarities */ + confr = readl(®s->cr); + confr &= ~(ZYNQ_QSPI_CR_CPHA_MASK | ZYNQ_QSPI_CR_CPOL_MASK); + + if (priv->mode & SPI_CPHA) + confr |= ZYNQ_QSPI_CR_CPHA_MASK; + if (priv->mode & SPI_CPOL) + confr |= ZYNQ_QSPI_CR_CPOL_MASK; + + writel(confr, ®s->cr); + priv->mode = mode; + + debug("zynq_spi_set_mode: regs=%p, mode=%d\n", priv->regs, priv->mode); + + return 0; +} + +static const struct dm_spi_ops zynq_qspi_ops = { + .claim_bus = zynq_qspi_claim_bus, + .release_bus = zynq_qspi_release_bus, + .xfer = zynq_qspi_xfer, + .set_speed = zynq_qspi_set_speed, + .set_mode = zynq_qspi_set_mode, +}; + +static const struct udevice_id zynq_qspi_ids[] = { + { .compatible = "xlnx,zynq-qspi-1.0" }, + { } +}; + +U_BOOT_DRIVER(zynq_qspi) = { + .name = "zynq_qspi", + .id = UCLASS_SPI, + .of_match = zynq_qspi_ids, + .ops = &zynq_qspi_ops, + .ofdata_to_platdata = zynq_qspi_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct zynq_qspi_platdata), + .priv_auto_alloc_size = sizeof(struct zynq_qspi_priv), + .probe = zynq_qspi_probe, +};
-----Original Message----- From: Jagan Teki [mailto:jteki@openedev.com] Sent: Tuesday, September 01, 2015 11:42 AM To: u-boot@lists.denx.de Cc: Jagan Teki; Michal Simek; Siva Durga Prasad Paladugu Subject: [PATCH v4 01/16] spi: Add zynq qspi controller driver
Added zynq qspi controller driver for Xilinx Zynq APSOC, this driver is driver- model driven with devicetree support.
Acked-by: Siva Durga Prasad Paladugu sivadur@xilinx.com
Thanks, Siva
- (C) Copyright 2013 Xilinx, Inc.
- (C) Copyright 2015 Jagan Teki jteki@openedev.com
- Xilinx Zynq Quad-SPI(QSPI) controller driver (master mode only)
- u32 cr; /* 0x00 */
- u32 isr; /* 0x04 */
- u32 ier; /* 0x08 */
- u32 idr; /* 0x0C */
- u32 imr; /* 0x10 */
- u32 enr; /* 0x14 */
- u32 dr; /* 0x18 */
- u32 txd0r; /* 0x1C */
- u32 drxr; /* 0x20 */
- u32 sicr; /* 0x24 */
- u32 txftr; /* 0x28 */
- u32 rxftr; /* 0x2C */
- u32 gpior; /* 0x30 */
- u32 reserved0[19];
- u32 txd1r; /* 0x80 */
- u32 txd2r; /* 0x84 */
- u32 txd3r; /* 0x88 */
- struct zynq_qspi_regs *regs;
- u32 frequency; /* input frequency */
- u32 speed_hz;
- u8 cs;
- u8 mode;
- u8 fifo_depth;
- u32 freq; /* required frequency */
- const void *tx_buf;
- void *rx_buf;
- unsigned len;
- int bytes_to_transfer;
- int bytes_to_receive;
- unsigned int is_inst;
- unsigned cs_change:1;
+static int zynq_qspi_ofdata_to_platdata(struct udevice *bus) {
- struct zynq_qspi_platdata *plat = bus->platdata;
- const void *blob = gd->fdt_blob;
- int node = bus->of_offset;
- plat->regs = (struct zynq_qspi_regs *)fdtdec_get_addr(blob,
node, "reg");
- /* FIXME: Use 166MHz as a suitable default */
- plat->frequency = fdtdec_get_int(blob, node, "spi-max-frequency",
166666666);
- plat->speed_hz = plat->frequency / 2;
- debug("%s: regs=%p max-frequency=%d\n", __func__,
+static void zynq_qspi_init_hw(struct zynq_qspi_priv *priv) {
- struct zynq_qspi_regs *regs = priv->regs;
- u32 confr;
- /* Disable QSPI */
- writel(~ZYNQ_QSPI_ENR_SPI_EN_MASK, ®s->enr);
- /* Disable Interrupts */
- writel(ZYNQ_QSPI_IXR_ALL_MASK, ®s->idr);
- /* Clear the TX and RX threshold reg */
- writel(ZYNQ_QSPI_TXFIFO_THRESHOLD, ®s->txftr);
- writel(ZYNQ_QSPI_RXFIFO_THRESHOLD, ®s->rxftr);
- /* Clear the RX FIFO */
- while (readl(®s->isr) & ZYNQ_QSPI_IXR_RXNEMPTY_MASK)
readl(®s->drxr);
- /* Clear Interrupts */
- writel(ZYNQ_QSPI_IXR_ALL_MASK, ®s->isr);
- /* Manual slave select and Auto start */
- confr = readl(®s->cr);
- confr &= ~ZYNQ_QSPI_CR_MSA_MASK;
- confr |= ZYNQ_QSPI_CR_IFMODE_MASK |
- writel(confr, ®s->cr);
- /* Enable SPI */
- writel(ZYNQ_QSPI_ENR_SPI_EN_MASK, ®s->enr); }
+static int zynq_qspi_probe(struct udevice *bus) {
- struct zynq_qspi_platdata *plat = dev_get_platdata(bus);
- struct zynq_qspi_priv *priv = dev_get_priv(bus);
- priv->regs = plat->regs;
- priv->fifo_depth = ZYNQ_QSPI_FIFO_DEPTH;
- /* init the zynq spi hw */
- zynq_qspi_init_hw(priv);
- zynq_qspi_read_data - Copy data to RX buffer
- @zqspi: Pointer to the zynq_qspi structure
- @data: The 32 bit variable where data is stored
- @size: Number of bytes to be copied from data to RX buffer
+static void zynq_qspi_read_data(struct zynq_qspi_priv *priv, u32 data, +u8 size) {
- u8 byte3;
- debug("%s: data 0x%04x rx_buf addr: 0x%08x size %d\n", __func__ ,
- if (priv->rx_buf) {
switch (size) {
case 1:
priv->rx_buf += 1;
break;
case 2:
priv->rx_buf += 2;
break;
case 3:
priv->rx_buf += 2;
priv->rx_buf += 1;
break;
case 4:
priv->rx_buf += 4;
break;
default:
break;
- priv->bytes_to_receive -= size;
- if (priv->bytes_to_receive < 0)
- zynq_qspi_write_data - Copy data from TX buffer
- @data: Pointer to the 32 bit variable where data is to be copied
- @size: Number of bytes to be copied from TX buffer to data
u32 *data, u8 size)
- if (priv->tx_buf) {
switch (size) {
case 1:
priv->tx_buf += 1;
break;
case 2:
priv->tx_buf += 2;
break;
case 3:
priv->tx_buf += 2;
priv->tx_buf += 1;
break;
case 4:
priv->tx_buf += 4;
break;
default:
break;
- } else {
*data = 0;
- debug("%s: data 0x%08x tx_buf addr: 0x%08x size %d\n", __func__,
- priv->bytes_to_transfer -= size;
- if (priv->bytes_to_transfer < 0)
+static void zynq_qspi_chipselect(struct zynq_qspi_priv *priv, int +is_on) {
- u32 confr;
- if (is_on) {
- } else
- zynq_qspi_fill_tx_fifo - Fills the TX FIFO with as many bytes as possible
+static void zynq_qspi_fill_tx_fifo(struct zynq_qspi_priv *priv, u32 +size) {
- u32 data = 0;
- u32 fifocount = 0;
- unsigned len, offset;
- static const unsigned offsets[4] = {
- while ((fifocount < size) &&
if (priv->tx_buf) {
priv->tx_buf += 4;
} else {
data = 0;
fifocount++;
} else {
!priv->rx_buf)
return;
- zynq_qspi_irq_poll - Interrupt service routine of the QSPI controller
- This function handles TX empty and Mode Fault interrupts only.
- On TX empty interrupt this function reads the received data from RX
+FIFO and
- fills the TX FIFO if there is any data remaining to be transferred.
- On Mode Fault interrupt this function indicates that transfer is
+completed,
- the SPI subsystem will identify the error as the remaining bytes to
+be
- transferred is non-zero.
- returns: 0 for poll timeout
+static int zynq_qspi_irq_poll(struct zynq_qspi_priv *priv) {
- u32 rxindex = 0;
- u32 rxcount;
- u32 status, timeout;
- /* Poll until any of the interrupt status bits are set */
- timeout = get_timer(0);
- do {
- } while ((status == 0) &&
- if (status == 0) {
return -ETIMEDOUT;
- writel(status, ®s->isr);
- /* Disable all interrupts */
- if ((status & ZYNQ_QSPI_IXR_TXOW_MASK) ||
have
* is empty
u32 data;
if (priv->rx_buf) {
priv->rx_buf += 4;
} else {
rxindex++;
} else {
* complete signal
®s->idr);
return 1;
- zynq_qspi_start_transfer - Initiates the QSPI transfer
- @qspi: Pointer to the spi_device structure
- @transfer: Pointer to the spi_transfer structure which provide
information
- This function fills the TX FIFO, starts the QSPI transfer, and waits
+for the
- transfer to be completed.
- returns: Number of bytes transferred in the last transfer
+static int zynq_qspi_start_transfer(struct zynq_qspi_priv *priv) {
- u32 data = 0;
- debug("%s: qspi: 0x%08x transfer: 0x%08x len: %d\n", __func__,
- priv->bytes_to_transfer = priv->len;
- priv->bytes_to_receive = priv->len;
- if (priv->len < 4)
- else
- writel(ZYNQ_QSPI_IXR_ALL_MASK, ®s->ier);
- /* Start the transfer by enabling manual start bit */
- /* wait for completion */
- do {
- } while (data == 0);
- return (priv->len) - (priv->bytes_to_transfer); }
+static int zynq_qspi_transfer(struct zynq_qspi_priv *priv) {
- unsigned cs_change = 1;
- int status = 0;
- while (1) {
if (cs_change)
status = -1;
break;
if (priv->len) {
priv->is_inst = 0;
if (status > 0)
status = -EMSGSIZE;
status, priv->len);
break;
status = 0;
if (cs_change)
break;
+static int zynq_qspi_claim_bus(struct udevice *dev) {
- struct udevice *bus = dev->parent;
+static int zynq_qspi_release_bus(struct udevice *dev) {
const void *dout, void *din, unsigned long flags) {
- struct dm_spi_slave_platdata *slave_plat =
+dev_get_parent_platdata(dev);
- priv->cs = slave_plat->cs;
- priv->tx_buf = dout;
- priv->rx_buf = din;
- priv->len = bitlen / 8;
- debug("spi_xfer: bus:%i cs:%i bitlen:%i len:%i flags:%lx\n",
* Festering sore.
- if (dout && flags & SPI_XFER_BEGIN)
priv->is_inst = 1;
- else
priv->is_inst = 0;
- if (flags & SPI_XFER_END)
- else
- zynq_qspi_transfer(priv);
+static int zynq_qspi_set_speed(struct udevice *bus, uint speed) {
- uint32_t confr;
- u8 baud_rate_val = 0;
- if (speed > plat->frequency)
- /* Set the clock frequency */
- if (speed == 0) {
- } else if (plat->speed_hz != speed) {
((plat->frequency /
baud_rate_val++;
- confr &= ~ZYNQ_QSPI_CR_BAUD_MASK;
- confr |= (baud_rate_val << ZYNQ_QSPI_CR_BAUD_SHIFT);
- priv->freq = speed;
- debug("zynq_spi_set_speed: regs=%p, mode=%d\n", priv->regs,
+priv->freq);
+static int zynq_qspi_set_mode(struct udevice *bus, uint mode) {
- uint32_t confr;
- /* Set the SPI Clock phase and polarities */
- confr &= ~(ZYNQ_QSPI_CR_CPHA_MASK |
- if (priv->mode & SPI_CPHA)
- if (priv->mode & SPI_CPOL)
- priv->mode = mode;
- debug("zynq_spi_set_mode: regs=%p, mode=%d\n", priv->regs,
+priv->mode);
- .claim_bus = zynq_qspi_claim_bus,
- .release_bus = zynq_qspi_release_bus,
- .xfer = zynq_qspi_xfer,
- .set_speed = zynq_qspi_set_speed,
- .set_mode = zynq_qspi_set_mode,
- { .compatible = "xlnx,zynq-qspi-1.0" },
- .name = "zynq_qspi",
- .id = UCLASS_SPI,
- .of_match = zynq_qspi_ids,
- .ops = &zynq_qspi_ops,
- .ofdata_to_platdata = zynq_qspi_ofdata_to_platdata,
- .platdata_auto_alloc_size = sizeof(struct zynq_qspi_platdata),
- .priv_auto_alloc_size = sizeof(struct zynq_qspi_priv),
- .probe = zynq_qspi_probe,
1.9.1
Hi Siva,
On 3 September 2015 at 12:56, Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com wrote:
Can you please test this on zc70x boards.
u32 cr; /* 0x00 */
u32 isr; /* 0x04 */
u32 ier; /* 0x08 */
u32 idr; /* 0x0C */
u32 imr; /* 0x10 */
u32 enr; /* 0x14 */
u32 dr; /* 0x18 */
u32 reserved0[19];
u32 speed_hz;
u8 cs;
u8 mode;
u8 fifo_depth;
const void *tx_buf;
void *rx_buf;
unsigned len;
node, "reg");
166666666);
u32 confr;
/* Disable QSPI */
readl(®s->drxr);
/* Enable SPI */
u8 byte3;
if (priv->rx_buf) {
switch (size) {
case 1:
priv->rx_buf += 1;
break;
case 2:
priv->rx_buf += 2;
break;
case 3:
priv->rx_buf += 2;
priv->rx_buf += 1;
break;
case 4:
priv->rx_buf += 4;
break;
default:
break;
u32 *data, u8 size)
if (priv->tx_buf) {
switch (size) {
case 1:
priv->tx_buf += 1;
break;
case 2:
priv->tx_buf += 2;
break;
case 3:
priv->tx_buf += 2;
priv->tx_buf += 1;
break;
case 4:
priv->tx_buf += 4;
break;
default:
break;
} else {
*data = 0;
u32 confr;
if (is_on) {
} else
u32 data = 0;
u32 fifocount = 0;
if (priv->tx_buf) {
priv->tx_buf += 4;
} else {
data = 0;
fifocount++;
} else {
!priv->rx_buf)
return;
+FIFO and
+completed,
+be
u32 rxindex = 0;
u32 rxcount;
do {
if (status == 0) {
return -ETIMEDOUT;
have
* is empty
u32 data;
if (priv->rx_buf) {
priv->rx_buf += 4;
} else {
rxindex++;
} else {
* complete signal
®s->idr);
return 1;
information
+for the
u32 data = 0;
if (priv->len < 4)
else
do {
int status = 0;
while (1) {
if (cs_change)
status = -1;
break;
if (priv->len) {
priv->is_inst = 0;
if (status > 0)
status = -EMSGSIZE;
status, priv->len);
break;
status = 0;
if (cs_change)
break;
priv->rx_buf = din;
* Festering sore.
priv->is_inst = 1;
else
priv->is_inst = 0;
else
uint32_t confr;
if (speed == 0) {
((plat->frequency /
baud_rate_val++;
priv->freq = speed;
+priv->freq);
uint32_t confr;
priv->mode = mode;
+priv->mode);
.id = UCLASS_SPI,
1.9.1
Hi Jagan,
-----Original Message----- From: Jagan Teki [mailto:jteki@openedev.com] Sent: Thursday, September 03, 2015 1:38 PM To: Siva Durga Prasad Paladugu Cc: u-boot@lists.denx.de; Michal Simek Subject: Re: [PATCH v4 01/16] spi: Add zynq qspi controller driver
Hi Siva,
How about this log. Looks like you have already tested. Is it just message or you copied the log?
Thanks, Siva
- SPDX-License-Identifier: GPL-2.0+ */
u32 cr; /* 0x00 */
u32 isr; /* 0x04 */
u32 ier; /* 0x08 */
u32 idr; /* 0x0C */
u32 imr; /* 0x10 */
u32 enr; /* 0x14 */
u32 dr; /* 0x18 */
u32 reserved0[19];
u32 speed_hz;
u8 cs;
u8 mode;
u8 fifo_depth;
const void *tx_buf;
void *rx_buf;
unsigned len;
node,
- "reg");
166666666);
u32 confr;
/* Disable QSPI */
readl(®s->drxr);
/* Enable SPI */
+static void zynq_qspi_read_data(struct zynq_qspi_priv *priv, u32 +data, +u8 size) {
u8 byte3;
if (priv->rx_buf) {
switch (size) {
case 1:
priv->rx_buf += 1;
break;
case 2:
priv->rx_buf += 2;
break;
case 3:
priv->rx_buf += 2;
priv->rx_buf += 1;
break;
case 4:
priv->rx_buf += 4;
break;
default:
break;
priv->bytes_to_receive = 0; }
u32 *data, u8 size)
if (priv->tx_buf) {
switch (size) {
case 1:
priv->tx_buf += 1;
break;
case 2:
priv->tx_buf += 2;
break;
case 3:
priv->tx_buf += 2;
priv->tx_buf += 1;
break;
case 4:
priv->tx_buf += 4;
break;
default:
break;
} else {
*data = 0;
priv->bytes_to_transfer = 0; }
u32 confr;
if (is_on) {
} else
u32 data = 0;
u32 fifocount = 0;
if (priv->tx_buf) {
priv->tx_buf += 4;
} else {
data = 0;
fifocount++;
} else {
!priv->rx_buf)
return;
+RX FIFO and
+completed,
+to be
u32 rxindex = 0;
u32 rxcount;
do {
if (status == 0) {
return -ETIMEDOUT;
- entries. We
have
* is empty
u32 data;
if (priv->rx_buf) {
priv->rx_buf += 4;
} else {
rxindex++;
} else {
* complete signal
®s->idr);
return 1;
information
+waits for the
- returns: Number of bytes transferred in the last transfer */
u32 data = 0;
if (priv->len < 4)
else
do {
int status = 0;
while (1) {
if (cs_change)
status = -1;
break;
if (priv->len) {
priv->is_inst = 0;
if (status > 0)
status = -EMSGSIZE;
status, priv->len);
break;
status = 0;
if (cs_change)
break;
priv->rx_buf = din;
* Festering sore.
priv->is_inst = 1;
else
priv->is_inst = 0;
else
uint32_t confr;
if (speed == 0) {
((plat->frequency /
baud_rate_val++;
priv->freq = speed;
+priv->freq);
uint32_t confr;
priv->mode = mode;
+priv->mode);
.id = UCLASS_SPI,
1.9.1
-- Jagan | openedev.
On 3 September 2015 at 14:08, Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com wrote:
Hi Jagan,
Hi Siva,
I have verified it on microzed, just wanted to verify from your side on zc70x if possible?
thanks! -- Jagan.
Hi Jagan,
Hi Siva,
Tested-by: Siva Durga Prasad Paladugu sivadur@xilinx.com
Here is the log of my testing on 702 board => sf probe 0 0 0 SF: Detected N25Q128A with page size 256 Bytes, erase size 64 KiB, total 16 MiB => sf update 100000 0 1000000 device 0 whole chip 16777216 bytes written, 0 bytes skipped in 235.961s, speed 72944 B/s => sf read 2000000 0 1000000 device 0 whole chip SF: 16777216 bytes @ 0x0 Read: OK => cmp.b 100000 2000000 1000000 Total of 16777216 byte(s) were the same
Thanks, Siva
u32 cr; /* 0x00 */
u32 isr; /* 0x04 */
u32 ier; /* 0x08 */
u32 idr; /* 0x0C */
u32 imr; /* 0x10 */
u32 enr; /* 0x14 */
u32 dr; /* 0x18 */
u32 reserved0[19];
u32 speed_hz;
u8 cs;
u8 mode;
u8 fifo_depth;
const void *tx_buf;
void *rx_buf;
unsigned len;
node,
- "reg");
166666666);
u32 confr;
/* Disable QSPI */
readl(®s->drxr);
/* Enable SPI */
u8 byte3;
if (priv->rx_buf) {
switch (size) {
case 1:
priv->rx_buf += 1;
break;
case 2:
priv->rx_buf += 2;
break;
case 3:
priv->rx_buf += 2;
priv->rx_buf += 1;
break;
case 4:
priv->rx_buf += 4;
break;
default:
break;
u32 *data, u8 size)
if (priv->tx_buf) {
switch (size) {
case 1:
priv->tx_buf += 1;
break;
case 2:
priv->tx_buf += 2;
break;
case 3:
priv->tx_buf += 2;
priv->tx_buf += 1;
break;
case 4:
priv->tx_buf += 4;
break;
default:
break;
} else {
*data = 0;
u32 confr;
if (is_on) {
} else
u32 data = 0;
u32 fifocount = 0;
if (priv->tx_buf) {
priv->tx_buf += 4;
} else {
data = 0;
fifocount++;
} else {
!priv->rx_buf)
return;
+RX FIFO and
+completed,
+to be
u32 rxindex = 0;
u32 rxcount;
do {
if (status == 0) {
return -ETIMEDOUT;
- entries. We
have
* is empty
u32 data;
if (priv->rx_buf) {
priv->rx_buf += 4;
} else {
rxindex++;
} else {
* complete signal
®s->idr);
return 1;
information
+waits for the
u32 data = 0;
if (priv->len < 4)
else
do {
int status = 0;
while (1) {
if (cs_change)
status = -1;
break;
if (priv->len) {
priv->is_inst = 0;
if (status > 0)
status = -EMSGSIZE;
status, priv->len);
break;
status = 0;
if (cs_change)
break;
priv->rx_buf = din;
* Festering sore.
priv->is_inst = 1;
else
priv->is_inst = 0;
else
uint32_t confr;
if (speed == 0) {
((plat->frequency /
baud_rate_val++;
priv->freq = speed;
+priv->freq);
uint32_t confr;
priv->mode = mode;
+priv->mode);
.id = UCLASS_SPI,
1.9.1
Hi there,
i am currently debugging on my zynq zc702 board and therefore i have to study the qspi-driver :-)
i've some questions about the implementation details.
- u32 data = 0;
if (priv->tx_buf) {
priv->tx_buf += 4;
} else {
data = 0;
fifocount++;
} else {
!priv->rx_buf)
return;
I do not understand "offset / 4", if priv->rx_buf == NULL we have an offset of 0x1C / 4 --> 7, this end in a write to an unaligned register address. What is the purpose of this ?
best regards, Hannes
Hi Jagan,
during bringing up QSPI within SPL on my ZYNQ ZC702 board i made some review of your code. Have a look.
- u8 cs;
- u8 mode;
- u8 fifo_depth;
- void *rx_buf;
- unsigned len;
why not use "u32" for len ?
- u32 confr;
During bring up this driver within SPL i've figured out, that it is very important to do a clear reset to the QSPI unit. Initially the ROM codes fetches our SPL-binary from the flash into the OCM and executes. We don't know at this point how ROM-code has left the QSPI unit, and have to reset the Unit using responsible Bits in sclr area. Otherwise we can see strange behaviours like hang on reading RxFIFO sometimes and sometimes not.
readl(®s->drxr);
- confr |= ZYNQ_QSPI_CR_IFMODE_MASK | ZYNQ_QSPI_CR_MCS_MASK |
- /* Enable SPI */
- u8 byte3;
use 0x%p instead 0x%08x to display pointer addresses, with the advantage that no cast is necessary.
switch (size) {
case 1:
priv->rx_buf += 1;
break;
case 2:
priv->rx_buf += 2;
break;
case 3:
priv->rx_buf += 2;
priv->rx_buf += 1;
break;
case 4:
priv->rx_buf += 4;
break;
default:
break;
wouldn't it be good enough using always "memcpy" ? maybe we can drop this function completely ?
u32 *data, u8 size)
switch (size) {
case 1:
priv->tx_buf += 1;
break;
case 2:
priv->tx_buf += 2;
break;
case 3:
priv->tx_buf += 2;
priv->tx_buf += 1;
break;
case 4:
priv->tx_buf += 4;
break;
default:
break;
- } else {
*data = 0;
maybe same thing here as above during "zynq_qspi_read_data".
- u32 confr;
- if (is_on) {
in TRM (UG585, V1.1) pg. 1525, these bits 13..11 are described as reserved, only bit 10 (if priv->cs == 0) is allowed to write. For my reading we actually have only one CS.
So:
+ if (is_on) { + /* Select the slave */ + confr &= ~(1 << ZYNQ_QSPI_CR_SS_SHIFT); + } would be enough.
Or do we use here some undocumented feature ?
- } else
- u32 data = 0;
why not using u32 instead unsigned ?
if (priv->tx_buf) {
priv->tx_buf += 4;
} else {
data = 0;
fifocount++;
} else {
!priv->rx_buf)
return;
would suggest "continue" instead "return", otherwise we may loose data in case of busy TX-FIFO.
during review i understood my question from yesterday :-) sorry for noise.
- On TX empty interrupt this function reads the received data from RX FIFO and
- On Mode Fault interrupt this function indicates that transfer is completed,
- the SPI subsystem will identify the error as the remaining bytes to be
- u32 rxindex = 0;
- u32 rxcount;
- do {
return -ETIMEDOUT;
* is empty
u32 data;
if (priv->rx_buf) {
priv->rx_buf += 4;
} else {
rxindex++;
} else {
* complete signal
®s->idr);
return 1;
- @transfer: Pointer to the spi_transfer structure which provide information
- This function fills the TX FIFO, starts the QSPI transfer, and waits for the
- u32 data = 0;
use 0x%p for displaying pointer addresses.
- else
i think we can call the function always with "priv->fifo_depth", because the decision if the "size" parameter is used or not is there made based on priv->bytes_to_transfer.
this comment is confusing since we are in auto-mode with manually forced chipselect.
- do {
Hi Jagan,
did you take notice about that? Maybe i've not seen your answer.
regards, Hannes
On 15.10.2015 10:39, Hannes Schmelzer wrote:
Hi Jagan,
- u8 cs;
- u8 mode;
- u8 fifo_depth;
- void *rx_buf;
- unsigned len;
- u32 confr;
readl(®s->drxr);
- /* Enable SPI */
- u8 byte3;
switch (size) {
case 1:
priv->rx_buf += 1;
break;
case 2:
priv->rx_buf += 2;
break;
case 3:
priv->rx_buf += 2;
priv->rx_buf += 1;
break;
case 4:
priv->rx_buf += 4;
break;
default:
break;
u32 *data, u8 size)
switch (size) {
case 1:
priv->tx_buf += 1;
break;
case 2:
priv->tx_buf += 2;
break;
case 3:
priv->tx_buf += 2;
priv->tx_buf += 1;
break;
case 4:
priv->tx_buf += 4;
break;
default:
break;
- } else {
*data = 0;
- u32 confr;
- if (is_on) {
So:
- if (is_on) {
would be enough.
- } else
possible
- u32 data = 0;
if (priv->tx_buf) {
priv->tx_buf += 4;
} else {
data = 0;
fifocount++;
} else {
!priv->rx_buf)
return;
controller
RX FIFO and
completed,
to be
- u32 rxindex = 0;
- u32 rxcount;
- do {
return -ETIMEDOUT;
have
* is empty
u32 data;
if (priv->rx_buf) {
priv->rx_buf += 4;
} else {
rxindex++;
} else {
* complete signal
®s->idr);
return 1;
information
waits for the
- u32 data = 0;
- else
- do {
On 5 November 2015 at 13:03, Hannes Schmelzer hannes@schmelzer.or.at wrote:
Hi Jagan,
I will get my hardware next week, sure we can discuss this.
Hi Jagan,
- u8 cs;
- u8 mode;
- u8 fifo_depth;
- void *rx_buf;
- unsigned len;
- u32 confr;
readl(®s->drxr);
- /* Enable SPI */
- u8 byte3;
switch (size) {
case 1:
priv->rx_buf += 1;
break;
case 2:
priv->rx_buf += 2;
break;
case 3:
priv->rx_buf += 2;
priv->rx_buf += 1;
break;
case 4:
priv->rx_buf += 4;
break;
default:
break;
u32 *data, u8 size)
switch (size) {
case 1:
priv->tx_buf += 1;
break;
case 2:
priv->tx_buf += 2;
break;
case 3:
priv->tx_buf += 2;
priv->tx_buf += 1;
break;
case 4:
priv->tx_buf += 4;
break;
default:
break;
- } else {
*data = 0;
- u32 confr;
- if (is_on) {
So:
- if (is_on) {
would be enough.
- } else
possible
- u32 data = 0;
if (priv->tx_buf) {
priv->tx_buf += 4;
} else {
data = 0;
fifocount++;
} else {
!priv->rx_buf)
return;
FIFO and
completed,
be
- u32 rxindex = 0;
- u32 rxcount;
- do {
return -ETIMEDOUT;
* is empty
u32 data;
if (priv->rx_buf) {
priv->rx_buf += 4;
} else {
rxindex++;
} else {
* complete signal
®s->idr);
return 1;
information
for the
- u32 data = 0;
- else
- do {
This patch adds zynq qspi controller nodes in zynq-7000.dtsi.
Signed-off-by: Jagan Teki jteki@openedev.com Cc: Simon Glass sjg@chromium.org Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Tested-by: Jagan Teki jteki@openedev.com --- arch/arm/dts/zynq-7000.dtsi | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/arch/arm/dts/zynq-7000.dtsi b/arch/arm/dts/zynq-7000.dtsi index 0b62cb0..84c15b5 100644 --- a/arch/arm/dts/zynq-7000.dtsi +++ b/arch/arm/dts/zynq-7000.dtsi @@ -191,6 +191,18 @@ #size-cells = <0>; };
+ qspi: spi@e000d000 { + clock-names = "ref_clk", "pclk"; + clocks = <&clkc 10>, <&clkc 43>; + compatible = "xlnx,zynq-qspi-1.0"; + status = "disabled"; + interrupt-parent = <&intc>; + interrupts = <0 19 4>; + reg = <0xe000d000 0x1000>; + #address-cells = <1>; + #size-cells = <0>; + }; + gem0: ethernet@e000b000 { compatible = "cdns,zynq-gem", "cdns,gem"; reg = <0xe000b000 0x1000>;
Added device-tree-binding information for zynq qspi controller driver.
Signed-off-by: Jagan Teki jteki@openedev.com Cc: Simon Glass sjg@chromium.org Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Tested-by: Jagan Teki jteki@openedev.com --- doc/device-tree-bindings/spi/spi-zynq-qspi.txt | 26 ++++++++++++++++++++++++++ 1 file changed, 26 insertions(+) create mode 100644 doc/device-tree-bindings/spi/spi-zynq-qspi.txt
diff --git a/doc/device-tree-bindings/spi/spi-zynq-qspi.txt b/doc/device-tree-bindings/spi/spi-zynq-qspi.txt new file mode 100644 index 0000000..47472fd --- /dev/null +++ b/doc/device-tree-bindings/spi/spi-zynq-qspi.txt @@ -0,0 +1,26 @@ +Xilinx Zynq QSPI controller Device Tree Bindings +------------------------------------------------- + +Required properties: +- compatible : Should be "xlnx,zynq-qspi-1.0". +- reg : Physical base address and size of QSPI registers map. +- interrupts : Property with a value describing the interrupt + number. +- interrupt-parent : Must be core interrupt controller +- clock-names : List of input clock names - "ref_clk", "pclk" + (See clock bindings for details). +- clocks : Clock phandles (see clock bindings for details). + +Optional properties: +- num-cs : Number of chip selects used. + +Example: + qspi@e000d000 { + compatible = "xlnx,zynq-qspi-1.0"; + clock-names = "ref_clk", "pclk"; + clocks = <&clkc 10>, <&clkc 43>; + interrupt-parent = <&intc>; + interrupts = <0 19 4>; + num-cs = <1>; + reg = <0xe000d000 0x1000>; + } ;
Enabled zynq qspi controller node for microzed board, verified the same on spansion spi-nor flash.
Signed-off-by: Jagan Teki jteki@openedev.com Cc: Simon Glass sjg@chromium.org Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Tested-by: Jagan Teki jteki@openedev.com --- arch/arm/dts/zynq-microzed.dts | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/dts/zynq-microzed.dts b/arch/arm/dts/zynq-microzed.dts index c373a2c..d5e0050 100644 --- a/arch/arm/dts/zynq-microzed.dts +++ b/arch/arm/dts/zynq-microzed.dts @@ -14,6 +14,7 @@
aliases { serial0 = &uart1; + spi0 = &qspi; };
memory { @@ -21,3 +22,7 @@ reg = <0 0x40000000>; }; }; + +&qspi { + status = "okay"; +};
Enabled zynq qspi controller node for zc702 board.
Signed-off-by: Jagan Teki jteki@openedev.com Cc: Simon Glass sjg@chromium.org Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com --- arch/arm/dts/zynq-zc702.dts | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/dts/zynq-zc702.dts b/arch/arm/dts/zynq-zc702.dts index 6691a8d..4d86960 100644 --- a/arch/arm/dts/zynq-zc702.dts +++ b/arch/arm/dts/zynq-zc702.dts @@ -17,6 +17,7 @@ ethernet0 = &gem0; i2c0 = &i2c0; serial0 = &uart1; + spi0 = &qspi; };
memory { @@ -380,6 +381,10 @@ pinctrl-0 = <&pinctrl_uart1_default>; };
+&qspi { + status = "okay"; +}; + &usb0 { status = "okay"; dr_mode = "host";
Enabled zynq qspi controller node for zc706 board.
Signed-off-by: Jagan Teki jteki@openedev.com Cc: Simon Glass sjg@chromium.org Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com --- arch/arm/dts/zynq-zc706.dts | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/dts/zynq-zc706.dts b/arch/arm/dts/zynq-zc706.dts index cf7bce4..fc336ea 100644 --- a/arch/arm/dts/zynq-zc706.dts +++ b/arch/arm/dts/zynq-zc706.dts @@ -17,6 +17,7 @@ ethernet0 = &gem0; i2c0 = &i2c0; serial0 = &uart1; + spi0 = &qspi; };
memory { @@ -301,6 +302,10 @@ pinctrl-0 = <&pinctrl_uart1_default>; };
Enabled zynq qspi controller node for zc770-xm010 board.
=> sf probe 0 -- bus0 for selecting spi controller => sf probe 1 -- bus1 for selecting qspi controller
Signed-off-by: Jagan Teki jteki@openedev.com Cc: Simon Glass sjg@chromium.org Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com --- arch/arm/dts/zynq-zc770-xm010.dts | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/dts/zynq-zc770-xm010.dts b/arch/arm/dts/zynq-zc770-xm010.dts index 680f24c..eec4c96 100644 --- a/arch/arm/dts/zynq-zc770-xm010.dts +++ b/arch/arm/dts/zynq-zc770-xm010.dts @@ -17,6 +17,7 @@ i2c0 = &i2c0; serial0 = &uart1; spi0 = &spi1; + spi1 = &qspi; };
chosen { @@ -53,6 +54,10 @@ }; };
+&qspi { + status = "okay"; +}; + &can0 { status = "okay"; };
spi1 = &qspi;
We have discussed this internally 2 weeks ago and I would prefer to have spi0 = &gspi; because then we can better handle internal commands where qspi is expected on bus 0.
Can you please switch it?
Thanks, Michal
spi1 = &qspi;
It is &qspi right not &gqspi
OK, I will make spi0 as qspi and spi1 as spi1 is that fine?
thanks!
spi1 = &qspi;
it is zynq that's why qspi.
Thanks, Michal
Enabled zynq qspi controller node for zed board.
Signed-off-by: Jagan Teki jteki@openedev.com Cc: Simon Glass sjg@chromium.org Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com --- arch/arm/dts/zynq-zed.dts | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/dts/zynq-zed.dts b/arch/arm/dts/zynq-zed.dts index 5762576..3630490 100644 --- a/arch/arm/dts/zynq-zed.dts +++ b/arch/arm/dts/zynq-zed.dts @@ -16,6 +16,7 @@ aliases { ethernet0 = &gem0; serial0 = &uart1; + spi0 = &qspi; };
memory { @@ -56,6 +57,10 @@ status = "okay"; };
Enable legacy spi-flash interface support for boards which supports qspi controller with connected spi-nor flash.
Signed-off-by: Jagan Teki jteki@openedev.com Cc: Simon Glass sjg@chromium.org Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Tested-by: Jagan Teki jteki@openedev.com --- configs/zynq_microzed_defconfig | 1 + configs/zynq_zc702_defconfig | 1 + configs/zynq_zc706_defconfig | 1 + configs/zynq_zc70x_defconfig | 1 + configs/zynq_zed_defconfig | 1 + 5 files changed, 5 insertions(+)
diff --git a/configs/zynq_microzed_defconfig b/configs/zynq_microzed_defconfig index 3e141a8..150cdbd 100644 --- a/configs/zynq_microzed_defconfig +++ b/configs/zynq_microzed_defconfig @@ -12,3 +12,4 @@ CONFIG_FIT_SIGNATURE=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPI_FLASH=y diff --git a/configs/zynq_zc702_defconfig b/configs/zynq_zc702_defconfig index f94bdde..be540b4 100644 --- a/configs/zynq_zc702_defconfig +++ b/configs/zynq_zc702_defconfig @@ -11,3 +11,4 @@ CONFIG_FIT_SIGNATURE=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPI_FLASH=y diff --git a/configs/zynq_zc706_defconfig b/configs/zynq_zc706_defconfig index 49efc6b..329e6d0 100644 --- a/configs/zynq_zc706_defconfig +++ b/configs/zynq_zc706_defconfig @@ -12,3 +12,4 @@ CONFIG_FIT_SIGNATURE=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPI_FLASH=y diff --git a/configs/zynq_zc70x_defconfig b/configs/zynq_zc70x_defconfig index 633c521..cc886dc 100644 --- a/configs/zynq_zc70x_defconfig +++ b/configs/zynq_zc70x_defconfig @@ -12,3 +12,4 @@ CONFIG_FIT_SIGNATURE=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPI_FLASH=y diff --git a/configs/zynq_zed_defconfig b/configs/zynq_zed_defconfig index ce414b7..a964411 100644 --- a/configs/zynq_zed_defconfig +++ b/configs/zynq_zed_defconfig @@ -12,3 +12,4 @@ CONFIG_FIT_SIGNATURE=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPI_FLASH=y
This patch adds support for zynq qspi controller driver on zynq-common.h
Signed-off-by: Jagan Teki jteki@openedev.com Cc: Simon Glass sjg@chromium.org Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Tested-by: Jagan Teki jteki@openedev.com --- include/configs/zynq-common.h | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index e7ab50a..514bdeb 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -72,6 +72,15 @@ # define CONFIG_CMD_SF #endif
+/* QSPI */ +#ifdef CONFIG_ZYNQ_QSPI +# define CONFIG_SF_DEFAULT_SPEED 30000000 +# define CONFIG_SPI_FLASH_SPANSION +# define CONFIG_SPI_FLASH_STMICRO +# define CONFIG_SPI_FLASH_WINBOND +# define CONFIG_CMD_SF +#endif + /* NOR */ #ifndef CONFIG_SYS_NO_FLASH # define CONFIG_SYS_FLASH_BASE 0xE2000000
Can you please also enable ISSI? # define CONFIG_SPI_FLASH_ISSI
Thanks, Michal
Enabled SPI flash Bank/Extended address register support.
Bank/Extended address registers are used to access the flash which has size > 16MiB in 3-byte addressing.
Signed-off-by: Jagan Teki jteki@openedev.com --- include/configs/zynq-common.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 514bdeb..f6dd03b 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -78,6 +78,7 @@ # define CONFIG_SPI_FLASH_SPANSION # define CONFIG_SPI_FLASH_STMICRO # define CONFIG_SPI_FLASH_WINBOND +# define CONFIG_SPI_FLASH_BAR # define CONFIG_CMD_SF #endif
Enable zynq qspi controller driver on respective zynq boards.
Signed-off-by: Jagan Teki jteki@openedev.com Cc: Simon Glass sjg@chromium.org Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Tested-by: Jagan Teki jteki@openedev.com --- configs/zynq_microzed_defconfig | 1 + configs/zynq_zc702_defconfig | 1 + configs/zynq_zc706_defconfig | 1 + configs/zynq_zc70x_defconfig | 1 + configs/zynq_zc770_xm010_defconfig | 1 + configs/zynq_zed_defconfig | 1 + 6 files changed, 6 insertions(+)
diff --git a/configs/zynq_microzed_defconfig b/configs/zynq_microzed_defconfig index 150cdbd..3984d77 100644 --- a/configs/zynq_microzed_defconfig +++ b/configs/zynq_microzed_defconfig @@ -13,3 +13,4 @@ CONFIG_FIT_SIGNATURE=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y +CONFIG_ZYNQ_QSPI=y diff --git a/configs/zynq_zc702_defconfig b/configs/zynq_zc702_defconfig index be540b4..250c4bd 100644 --- a/configs/zynq_zc702_defconfig +++ b/configs/zynq_zc702_defconfig @@ -12,3 +12,4 @@ CONFIG_FIT_SIGNATURE=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y +CONFIG_ZYNQ_QSPI=y diff --git a/configs/zynq_zc706_defconfig b/configs/zynq_zc706_defconfig index 329e6d0..5fb368e 100644 --- a/configs/zynq_zc706_defconfig +++ b/configs/zynq_zc706_defconfig @@ -13,3 +13,4 @@ CONFIG_FIT_SIGNATURE=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y +CONFIG_ZYNQ_QSPI=y diff --git a/configs/zynq_zc70x_defconfig b/configs/zynq_zc70x_defconfig index cc886dc..59d831b 100644 --- a/configs/zynq_zc70x_defconfig +++ b/configs/zynq_zc70x_defconfig @@ -13,3 +13,4 @@ CONFIG_FIT_SIGNATURE=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y +CONFIG_ZYNQ_QSPI=y diff --git a/configs/zynq_zc770_xm010_defconfig b/configs/zynq_zc770_xm010_defconfig index c608029..7dcf062 100644 --- a/configs/zynq_zc770_xm010_defconfig +++ b/configs/zynq_zc770_xm010_defconfig @@ -14,3 +14,4 @@ CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM010" CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y +CONFIG_ZYNQ_QSPI=y diff --git a/configs/zynq_zed_defconfig b/configs/zynq_zed_defconfig index a964411..8a6bea0 100644 --- a/configs/zynq_zed_defconfig +++ b/configs/zynq_zed_defconfig @@ -13,3 +13,4 @@ CONFIG_FIT_SIGNATURE=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y +CONFIG_ZYNQ_QSPI=y
Add Zynq QSPI controller Kconfig entry.
Signed-off-by: Jagan Teki jteki@openedev.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com --- drivers/spi/Kconfig | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index c84a7b7..facd94d 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -123,6 +123,15 @@ config ZYNQ_SPI access the SPI NOR flash on platforms embedding this Zynq SPI IP core.
+config ZYNQ_QSPI + bool "Zynq QSPI driver" + depends on ARCH_ZYNQ || TARGET_XILINX_ZYNQMP + help + Enable the Zynq Quad-SPI (QSPI) driver. This driver can be + used to access the SPI NOR flash on platforms embedding this + Zynq QSPI IP core. This IP is used to connect the flash in + 4-bit qspi, 8-bit dual stacked and shared 4-bit dual parallel. + endif # if DM_SPI
config FSL_ESPI
+config ZYNQ_QSPI
- bool "Zynq QSPI driver"
- depends on ARCH_ZYNQ || TARGET_XILINX_ZYNQMP
just ARCH_ZYNQ here.
Thanks, Michal
Update the numerical values for baudrate and chipselect with config reg shift named macro's
Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/spi/zynq_spi.c | 10 +++++++--- 1 file changed, 7 insertions(+), 3 deletions(-)
diff --git a/drivers/spi/zynq_spi.c b/drivers/spi/zynq_spi.c index b9cf335..817728c 100644 --- a/drivers/spi/zynq_spi.c +++ b/drivers/spi/zynq_spi.c @@ -28,6 +28,10 @@ DECLARE_GLOBAL_DATA_PTR; #define ZYNQ_SPI_IXR_ALL_MASK 0x7F /* All IXR bits */ #define ZYNQ_SPI_ENR_SPI_EN_MASK (1 << 0) /* SPI Enable */
+#define ZYNQ_SPI_CR_BAUD_MAX 8 /* Baud rate divisor max val */ +#define ZYNQ_SPI_CR_BAUD_SHIFT 3 /* Baud rate divisor shift */ +#define ZYNQ_SPI_CR_SS_SHIFT 10 /* Slave select shift */ + #define ZYNQ_SPI_FIFO_DEPTH 128 #ifndef CONFIG_SYS_ZYNQ_SPI_WAIT #define CONFIG_SYS_ZYNQ_SPI_WAIT (CONFIG_SYS_HZ/100) /* 10 ms */ @@ -139,7 +143,7 @@ static void spi_cs_activate(struct udevice *dev, uint cs) * xx01 - cs1 * x011 - cs2 */ - cr |= (~(0x1 << cs) << 10) & ZYNQ_SPI_CR_CS_MASK; + cr |= (~(0x1 << cs) << ZYNQ_SPI_CR_SS_SHIFT) & ZYNQ_SPI_CR_CS_MASK; writel(cr, ®s->cr); }
@@ -256,14 +260,14 @@ static int zynq_spi_set_speed(struct udevice *bus, uint speed) /* Set baudrate x8, if the freq is 0 */ baud_rate_val = 0x2; } else if (plat->speed_hz != speed) { - while ((baud_rate_val < 8) && + while ((baud_rate_val < ZYNQ_SPI_CR_BAUD_MAX) && ((plat->frequency / (2 << baud_rate_val)) > speed)) baud_rate_val++; plat->speed_hz = speed / (2 << baud_rate_val); } confr &= ~ZYNQ_SPI_CR_BRD_MASK; - confr |= (baud_rate_val << 3); + confr |= (baud_rate_val << ZYNQ_SPI_CR_BAUD_SHIFT);
writel(confr, ®s->cr); priv->freq = speed;
Rename ZYNQ_SPI_CR_BRD_MASK to ZYNQ_SPI_CR_BAUD_MASK for more readable.
Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/spi/zynq_spi.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/spi/zynq_spi.c b/drivers/spi/zynq_spi.c index 817728c..70d7716 100644 --- a/drivers/spi/zynq_spi.c +++ b/drivers/spi/zynq_spi.c @@ -19,7 +19,7 @@ DECLARE_GLOBAL_DATA_PTR; #define ZYNQ_SPI_CR_MSA_MASK (1 << 15) /* Manual start enb */ #define ZYNQ_SPI_CR_MCS_MASK (1 << 14) /* Manual chip select */ #define ZYNQ_SPI_CR_CS_MASK (0xF << 10) /* Chip select */ -#define ZYNQ_SPI_CR_BRD_MASK (0x7 << 3) /* Baud rate div */ +#define ZYNQ_SPI_CR_BAUD_MASK (0x7 << 3) /* Baud rate div */ #define ZYNQ_SPI_CR_CPHA_MASK (1 << 2) /* Clock phase */ #define ZYNQ_SPI_CR_CPOL_MASK (1 << 1) /* Clock polarity */ #define ZYNQ_SPI_CR_MSTREN_MASK (1 << 0) /* Mode select */ @@ -266,7 +266,7 @@ static int zynq_spi_set_speed(struct udevice *bus, uint speed) baud_rate_val++; plat->speed_hz = speed / (2 << baud_rate_val); } - confr &= ~ZYNQ_SPI_CR_BRD_MASK; + confr &= ~ZYNQ_SPI_CR_BAUD_MASK; confr |= (baud_rate_val << ZYNQ_SPI_CR_BAUD_SHIFT);
Store cs value into private data and use it while activating chipselect instead of passing through function.
Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/spi/zynq_spi.c | 8 +++++--- 1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/drivers/spi/zynq_spi.c b/drivers/spi/zynq_spi.c index 70d7716..70ddd7f 100644 --- a/drivers/spi/zynq_spi.c +++ b/drivers/spi/zynq_spi.c @@ -61,6 +61,7 @@ struct zynq_spi_platdata { /* zynq spi priv */ struct zynq_spi_priv { struct zynq_spi_regs *regs; + u8 cs; u8 mode; u8 fifo_depth; u32 freq; /* required frequency */ @@ -128,7 +129,7 @@ static int zynq_spi_probe(struct udevice *bus) return 0; }
-static void spi_cs_activate(struct udevice *dev, uint cs) +static void spi_cs_activate(struct udevice *dev) { struct udevice *bus = dev->parent; struct zynq_spi_priv *priv = dev_get_priv(bus); @@ -143,7 +144,7 @@ static void spi_cs_activate(struct udevice *dev, uint cs) * xx01 - cs1 * x011 - cs2 */ - cr |= (~(0x1 << cs) << ZYNQ_SPI_CR_SS_SHIFT) & ZYNQ_SPI_CR_CS_MASK; + cr |= (~(1 << priv->cs) << ZYNQ_SPI_CR_SS_SHIFT) & ZYNQ_SPI_CR_CS_MASK; writel(cr, ®s->cr); }
@@ -199,8 +200,9 @@ static int zynq_spi_xfer(struct udevice *dev, unsigned int bitlen, return -1; }
+ priv->cs = slave_plat->cs; if (flags & SPI_XFER_BEGIN) - spi_cs_activate(dev, slave_plat->cs); + spi_cs_activate(dev);
while (rx_len > 0) { /* Write the data into TX FIFO - tx threshold is fifo_depth */
Hi Michal/Siva,
Please let me know for any comments, and also test the same.
-- 1.9.1
thanks!
On 09/01/2015 08:14 AM, Jagan Teki wrote:
Hi Michal/Siva,
All these DTS patches are fine and here is my Acked-by: Michal Simek michal.simek@xilinx.com
The rest will be checked by Siva.
Thanks, Michal
Hi Michal/Siva,
Applied to u-boot-spi/master
thanks!
Hannes Schmelzer
Jagan Teki
Michal Simek
