[U-Boot] [PATCH] usb:composite:fix Provide function data when addressing device with only one interface
This commit fixes problems with some non-standard requests send with device address instead of interface address (bmRequestType.Receipent field).
This happens with dfu-util (debian version: 0.5), which address non standard requests (like w_value=0x21 and bRequest=GET_DESCRIPTOR) to device. Without this fix, the above request is STALLED, and hence causes dfu-util to assume some standard configuration (packet size = 1024B instead of 4096B) In turn it displays following errors: Error obtaining DFU functional descriptor Warning: Assuming DFU version 1.0 Warning: Transfer size can not be detected ... Warning: Trying default transfer size 1024
This fix allows passing non-standard request to function setup code, where it shall be handled.
Tested at: Trats (exynos4210) Tested with:DFU and UMS gadgets
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- This patch fixes problem pointed by Pantelis Antoniou. It is supposed to replace following commit added to u-boot-usb repository:
"dfu: Send correct DFU response from composite_setup" SHA1: fef31049fa06e516945114195eb14ac3549d0ad2 --- drivers/usb/gadget/composite.c | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/drivers/usb/gadget/composite.c b/drivers/usb/gadget/composite.c index ebb5131..2c5600e 100644 --- a/drivers/usb/gadget/composite.c +++ b/drivers/usb/gadget/composite.c @@ -859,6 +859,25 @@ unknown: if (&f->list == &cdev->config->functions) f = NULL; break; + /* + * dfu-util (version 0.5) sets bmRequestType.Receipent = Device + * for non-standard request (w_value = 0x21, + * bRequest = GET_DESCRIPTOR in this case). + * When only one interface is registered (as it is done now), + * then this request shall be handled as it was requested for + * interface. + * + * In the below code it is checked if only one interface is + * present and proper function for it is extracted. Due to that + * function's setup (f->setup) is called to handle this + * special non-standard request. + */ + case USB_RECIP_DEVICE: + debug("cdev->config->next_interface_id: %d intf: %d\n", + cdev->config->next_interface_id, intf); + if (cdev->config->next_interface_id == 1) + f = cdev->config->interface[intf]; + break; }
if (f && f->setup)
Dear Lukasz Majewski,
Can you please repost all the patches you want applied on u-boot-usb ? I'm completely lost in all this DFU stuff.
Best regards, Marek Vasut
Hi Marek,
This is only one patch to replace patch done by Pantelis:
Patch to replace (revert): dfu: Send correct DFU response from composite_setup SHA1: fef31049fa06e516945114195eb14ac3549d0ad2
And this shall be replaced with posted patch.
Another patches (with UMS gadget support - done by Piotr Wilczek), also shall be added to u-boot-usb tree:
http://patchwork.ozlabs.org/patch/219744/ http://patchwork.ozlabs.org/patch/219746/ http://patchwork.ozlabs.org/patch/219745/
Hi Marek,
Ok, please check the u-boot-usb ... if it's OK, I will send Tom a pullrq (finally). Tom, do you still accept those for .04 ?
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
Hi Marek,
As of earlier in the day it still had Pantelis' patch for sending files larger than memory which breaks all filesystem-based writes, so that needs to go. Lukasz and I are discussing how to deal with that.
- -- Tom
Dear Tom Rini,
Hi Marek,
IIRC I killed that patch.
On Wed, Mar 06, 2013 at 12:54:45AM +0100, Marek Vasut wrote:
Dear Tom Rini,
Hi Marek,
In u-boot-usb/master currently: commit a09f955db6ad7031bd715a615fb8b90d671a14d4 Author: Pantelis Antoniou panto@antoniou-consulting.com Date: Fri Nov 30 08:01:12 2012 +0000
dfu: Support larger than memory transfers.
Is one of the two that needed to go. The patch in this thread replaced the other one that you did drop.
Dear Tom Rini,
Dear Tom Rini,
Hi Marek,
> This commit fixes problems with some non-standard requests > send with device address instead of interface address > (bmRequestType.Receipent field). > > This happens with dfu-util (debian version: 0.5), which > address non standard requests (like w_value=0x21 and > bRequest=GET_DESCRIPTOR) to device. Without this fix, the > above request is STALLED, and hence causes dfu-util to assume > some standard configuration (packet size = 1024B instead of > 4096B) In turn it displays following errors: Error obtaining > DFU functional descriptor Warning: Assuming DFU version 1.0 > Warning: Transfer size can not be detected ... Warning: > Trying default transfer size 1024 > > This fix allows passing non-standard request to function > setup code, where it shall be handled. > > Tested at: Trats (exynos4210) Tested with:DFU and UMS > gadgets
True, we now have the proper one applied to my understanding.
On 03/05/2013 07:55 PM, Marek Vasut wrote:
Dear Tom Rini,
Dear Tom Rini,
Hi Marek,
> Dear Lukasz Majewski, > >> This commit fixes problems with some non-standard >> requests send with device address instead of >> interface address (bmRequestType.Receipent field). >> >> This happens with dfu-util (debian version: 0.5), >> which address non standard requests (like >> w_value=0x21 and bRequest=GET_DESCRIPTOR) to device. >> Without this fix, the above request is STALLED, and >> hence causes dfu-util to assume some standard >> configuration (packet size = 1024B instead of 4096B) >> In turn it displays following errors: Error >> obtaining DFU functional descriptor Warning: Assuming >> DFU version 1.0 Warning: Transfer size can not be >> detected ... Warning: Trying default transfer size >> 1024 >> >> This fix allows passing non-standard request to >> function setup code, where it shall be handled. >> >> Tested at: Trats (exynos4210) Tested with:DFU and >> UMS gadgets > > Can you please repost all the patches you want applied > on u-boot-usb ? I'm completely lost in all this DFU > stuff.
No, the concept needs re-working as non-filesystem can work in chunks but files must be done all at once.
- -- Tom
Dear All,
Hi Marek,
Marek, thanks for pulling those patches.
The patch about which Tom is speaking is: "dfu: Support larger than memory transfers." SHA1: a09f955db6ad7031bd715a615fb8b90d671a14d4
This patch is causing regression (not only on Trats).
I think, that it shall be dropped and replaced by new patch on which Tom (with my little help) is working now.
This patch is not connected to the one, which you have already removed from u-boot-usb tree. You have removed patch about composite.c DFU fix (which was fixed by: "usb:composite:fix Provide function data when addressing device with only one interface").
Tom -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.11 (GNU/Linux) Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQIcBAEBAgAGBQJRNoNSAAoJENk4IS6UOR1WnDkP+QE7ihcrFz0u5v2wAhkjwtaZ etpl6oL/rB7jA6jK9zDYkyoc/Bf9A9/ffxsfGruP8kzjK2BTwHizs/Hz4I8Z90k6 6g4S7DUY4kx9t20Iyyswwuo8Bs0MXuEyDSS1a3kWXsB1110eUXd6xBsQoOKv5BeK 1UO29ZFMRJAnIpKBSrrGNE0e8xG8fnF1y8/Wos8OAk240DKoMPTF1lZEB5TEkbtN 7xePk4XLGClePj8CH8iIBj2YDo5kjRPUCZ2zSd6niayVrp5On5as+Fn9XTvWiQYG UjLDbeAhNinzRJx9q8sB2dxXq2sSh+8ehtKZgnQCwOuj0bV0Ok4um0FP7DKN1Z+K COvJdKC629rZ9cyc/kLfXtJzEYBJwK+OsLjLHOf7YuuhQpcPcugZWmdc8LZt6QMA aL61JGTCfF80PVO8jAjWkJjniTHTSQRL+Adt91wej9D8e246/SbzFMqjjpTWQvVB RcR6fUwKdcMwT+RKAJybYH8z3tqwiRQXleBPs6NqcRYV7E8AHzpeMUh5v7m2Gz/P 8y+ea4v8Nglq79UnYmeqCHmvMO0ZqUpb8/+hB35xfkyuIHstx3J784NHOaQ7IZqj iJZ/Stf3De+ASddDFeAldoyc3EdT2k98gYUKpitExTOB5EbWKrK781JOEC0q+iSb +xUyux8npF6Rhhf55Rm7 =DAuM -----END PGP SIGNATURE-----
Hi Lukasz,
On Mar 6, 2013, at 9:42 AM, Lukasz Majewski wrote:
Dear All,
Hi Marek,
Sorry about missing this thread. I've been busy with other stuff.
What kind of regressions are we talking about?
I'm trying to get around to looking into all of this, but this shouldn't be causing all that trouble.
Regards
-- Pantelis
-- Best regards,
Lukasz Majewski
Samsung R&D Poland (SRPOL) | Linux Platform Group
On 03/06/2013 02:45 AM, Pantelis Antoniou wrote:
[snip]
There's two problems. The first big problem is that file writes become impossible as we don't support appending to files at an offset today. The second problem is that Lukasz is seeing a regression with regards to raw block operations (I think akin to how we have to account for bad blocks, on eMMC we have to deal with lba block sizes).
- -- Tom
Tested-by: Tom Rini trini@ti.com on am335x_evm with this patch replacing Pantelis' patch, in the stack of things required for DFU on this board.
Lukasz Majewski writes:
Dear u-boot developers,
The above comment seems to imply that dfu-util is sending non-standard requests. For the record, that would be wrong. dfu-util is sending a standard "get descriptor" request. These always go to the device, not to an interface. The descriptor it is asking for is, although not mandatory per the core USB standard, a class-specific descriptor which is part of the DFU 1.0 standard. So this is all standard.
While on this topic, I would recommend that you include this descriptor in the configuration descriptor set, that is, in the complete configuration descriptor that the host OS usually requests during enumeration. Also this class-specific descriptor belongs here. In that case, the OS and libusb will keep a copy of this descriptor, and dfu-util will not have to send an explicit request (through libusb_get_descriptor()) to retrieve it.
Note that this number is the "Maximum number of bytes that the device can accept per control-write transaction."
The DFU transactions should work fine if a smaller packet size is used - as long as it is larger or equal to the bMaxPacketSize0. Of course, smaller packets will cause more overhead and be less efficient, but you must make sure that your device can handle this. I am not sure from these comments whether the smaller packet size caused errors in your implementation, or if the problem was just reduced performance.
Best regards, Tormod Volden
On Thu, 27 Jun 2013 21:36:09 +0000 (UTC), Tormod Volden wrote:
Hi Tormod,
Thanks for explanation. The commit about which we are discussing was a (reasonable) fix for the problem.
I need to look into this and came up with proper solution.
I need to check this, but AFAIR there was a problem with dfu-util (and probably libusb under the hood) version 0.1 (shipped with "ancient" old stable debian) and 0.5 which is currently in use.
The change was driven by the need to improve performance, when downloading large files (with roofts) and to silent warning on the dfu-util side.
participants (5)
Lukasz Majewski
Pantelis Antoniou
Tormod Volden
