[PATCH] mmc: msm_sdhci: Use mmc_of_parse for setting host_caps
Since the introduction of 'get_cd' callback in sdhci core, dragonboard410c's MMC interface is broken. It turns out that 'get_cd' callback checks for the host_caps for validating the chip select. And since the msm_sdhci driver is not parsing the host_caps from DT, not all of the cababilities are parsed properly. This results in the MMC interfaces to be broken.
Hence, fix this by adding a call to 'mmc_of_parse' during driver probe.
Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org --- drivers/mmc/msm_sdhci.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/mmc/msm_sdhci.c b/drivers/mmc/msm_sdhci.c index da3ae2ec35..23e2e0fbc3 100644 --- a/drivers/mmc/msm_sdhci.c +++ b/drivers/mmc/msm_sdhci.c @@ -142,6 +142,10 @@ static int msm_sdc_probe(struct udevice *dev) writel(caps, host->ioaddr + SDHCI_VENDOR_SPEC_CAPABILITIES0); }
+ ret = mmc_of_parse(dev, &plat->cfg); + if (ret) + return ret; + host->mmc = &plat->mmc; host->mmc->dev = dev; ret = sdhci_setup_cfg(&plat->cfg, host, 0, 0);
I tested the patch using,
https://snapshots.linaro.org/96boards/dragonboard410c/linaro/uboot/28/
And now the mmc devices appears.
On Thu, 16 Jul 2020 at 04:07, Manivannan Sadhasivam < manivannan.sadhasivam@linaro.org> wrote:
Tested-by: Aníbal Limón anibal.limon@linaro.org
if (ret)
return ret;
-- 2.17.1
On Thu, 16 Jul 2020 at 04:07, Manivannan Sadhasivam manivannan.sadhasivam@linaro.org wrote:
if (ret)
return ret;
-- 2.17.1
Reviewed-By: Ramon Fried rfried.dev@gmail.com
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
- ret = mmc_of_parse(dev, &plat->cfg);
- if (ret)
return ret;
- host->mmc = &plat->mmc; host->mmc->dev = dev; ret = sdhci_setup_cfg(&plat->cfg, host, 0, 0);
Anibal Limon
Jaehoon Chung
Ramon Fried
