[U-Boot] [PATCH v2] ARM: AM437x: Align HS device variant defconfig filename
Align the name of the defconfig file for high-security (HS) device variants from the AM43xx family of SoCs with the corresponding name used for the general purpose devices. This allows for easier cross-association of those files and also provides room to grow from an HS device part number perspective.
Furthermore, update and cleanup associated MAINTAINERS file.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com Cc: Lokesh Vutla lokeshvutla@ti.com Cc: Madan Srinivas madans@ti.com ---
Update since last patch: Added defconfig file to MAINTAINERS doc. Also took the liberty to swap two entries in said MAINTAINERS file so that the list of defconfig files is in alphabetical order (allows for easier comparison with the associated directory contents).
board/ti/am43xx/MAINTAINERS | 3 ++- configs/am437x_hs_evm_defconfig | 59 ----------------------------------------- configs/am43xx_hs_evm_defconfig | 59 +++++++++++++++++++++++++++++++++++++++++ 3 files changed, 61 insertions(+), 60 deletions(-) delete mode 100644 configs/am437x_hs_evm_defconfig create mode 100644 configs/am43xx_hs_evm_defconfig
diff --git a/board/ti/am43xx/MAINTAINERS b/board/ti/am43xx/MAINTAINERS index 3d40b17..83645ac 100644 --- a/board/ti/am43xx/MAINTAINERS +++ b/board/ti/am43xx/MAINTAINERS @@ -4,6 +4,7 @@ S: Maintained F: board/ti/am43xx/ F: include/configs/am43xx_evm.h F: configs/am43xx_evm_defconfig -F: configs/am43xx_evm_qspiboot_defconfig F: configs/am43xx_evm_ethboot_defconfig +F: configs/am43xx_evm_qspiboot_defconfig F: configs/am43xx_evm_usbhost_boot_defconfig +F: configs/am43xx_hs_evm_defconfig diff --git a/configs/am437x_hs_evm_defconfig b/configs/am437x_hs_evm_defconfig deleted file mode 100644 index 4856a19..0000000 --- a/configs/am437x_hs_evm_defconfig +++ /dev/null @@ -1,59 +0,0 @@ -CONFIG_ARM=y -CONFIG_AM43XX=y -CONFIG_TI_SECURE_DEVICE=y -CONFIG_TARGET_AM43XX_EVM=y -CONFIG_DM_SERIAL=y -CONFIG_DM_GPIO=y -CONFIG_SPL_STACK_R_ADDR=0x82000000 -# Device tree file can be same on HS evm -CONFIG_DEFAULT_DEVICE_TREE="am437x-gp-evm" -CONFIG_SPL=y -CONFIG_ISW_ENTRY_ADDR=0x40302ae0 -CONFIG_SPL_STACK_R=y -CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1, NAND" -CONFIG_SPL_LOAD_FIT=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_IMLS is not set -CONFIG_CMD_ASKENV=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_MMC=y -CONFIG_CMD_SF=y -CONFIG_CMD_SPI=y -CONFIG_CMD_I2C=y -CONFIG_CMD_USB=y -CONFIG_CMD_DFU=y -CONFIG_CMD_GPIO=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_OF_CONTROL=y -CONFIG_OF_LIST="am437x-gp-evm" -CONFIG_DM=y -CONFIG_DM_MMC=y -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_SYS_NS16550=y -CONFIG_TI_QSPI=y -CONFIG_TIMER=y -CONFIG_OMAP_TIMER=y -CONFIG_USB=y -CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_DWC3=y -CONFIG_USB_DWC3_GADGET=y -CONFIG_USB_DWC3_OMAP=y -CONFIG_USB_DWC3_PHY_OMAP=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0403 -CONFIG_G_DNL_PRODUCT_NUM=0xbd00 -CONFIG_SPL_OF_LIBFDT=y diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig new file mode 100644 index 0000000..4856a19 --- /dev/null +++ b/configs/am43xx_hs_evm_defconfig @@ -0,0 +1,59 @@ +CONFIG_ARM=y +CONFIG_AM43XX=y +CONFIG_TI_SECURE_DEVICE=y +CONFIG_TARGET_AM43XX_EVM=y +CONFIG_DM_SERIAL=y +CONFIG_DM_GPIO=y +CONFIG_SPL_STACK_R_ADDR=0x82000000 +# Device tree file can be same on HS evm +CONFIG_DEFAULT_DEVICE_TREE="am437x-gp-evm" +CONFIG_SPL=y +CONFIG_ISW_ENTRY_ADDR=0x40302ae0 +CONFIG_SPL_STACK_R=y +CONFIG_FIT=y +CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1, NAND" +CONFIG_SPL_LOAD_FIT=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_GPIO=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_CONTROL=y +CONFIG_OF_LIST="am437x-gp-evm" +CONFIG_DM=y +CONFIG_DM_MMC=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SYS_NS16550=y +CONFIG_TI_QSPI=y +CONFIG_TIMER=y +CONFIG_OMAP_TIMER=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GADGET=y +CONFIG_USB_DWC3_OMAP=y +CONFIG_USB_DWC3_PHY_OMAP=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_G_DNL_MANUFACTURER="Texas Instruments" +CONFIG_G_DNL_VENDOR_NUM=0x0403 +CONFIG_G_DNL_PRODUCT_NUM=0xbd00 +CONFIG_SPL_OF_LIBFDT=y
Andreas Dannenberg
