[U-Boot-Users] Modifying U-Boot
Hi, when modifying u-boot for a custom design board, is schematic of the board is required? i have datasheet of the board that explain memory map, bridge and cpu type, ex. is this datasheet sufficient to modify u-boot? if schematic is required, what are names of u-boot source files that must be modifyed according to schematic?
Best regards, Mustafa
This depends on the quality and level of datail of the other documen- tation you have. I prefer to be able to verify this form the schematics (which usually is more up-to-date than all text docs, too).
Maybe, maybe not. I don't know your board. Does your documentation explain the use of all port pins, clock routing, how to reset the PHY etc.?
It depends...
Mustafa Çayır
