[PATCH] arm64: zynqmp: Rename clocks as per the Arasan NAND driver
From: Amit Kumar Mahapatra amit.kumar-mahapatra@xilinx.com
In zynqmp.dtsi file renamed "clk_sys" clock to "controller" and "clk_flash" clock to "bus" as per upstreamed Arasan NAND driver. This fixes NAND driver probe failure.
Signed-off-by: Amit Kumar Mahapatra amit.kumar-mahapatra@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/dts/zynqmp.dtsi | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/zynqmp.dtsi b/arch/arm/dts/zynqmp.dtsi index aa0ac95e122e..2917a956eb3d 100644 --- a/arch/arm/dts/zynqmp.dtsi +++ b/arch/arm/dts/zynqmp.dtsi @@ -505,7 +505,7 @@ compatible = "arasan,nfc-v3p10"; status = "disabled"; reg = <0x0 0xff100000 0x0 0x1000>; - clock-names = "clk_sys", "clk_flash"; + clock-names = "controller", "bus"; interrupt-parent = <&gic>; interrupts = <0 14 4>; #address-cells = <1>;
st 24. 2. 2021 v 10:11 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
-- 2.30.0
Applied. M
Michal Simek
Michal Simek
