[U-Boot] [PATCH 1/1] efi_loader: LoadImage: always allocate new pages
If we want to properly unload images in Exit() the memory should always be allocated in the same way. As we allocate memory when reading from file we should do the same when the original image is in memory.
Further patches will be needed: - use LoadImage() in bootefi and bootmgr - implement correct unloading of images in Exit()
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- include/efi_loader.h | 2 +- lib/efi_loader/efi_bootmgr.c | 2 +- lib/efi_loader/efi_boottime.c | 56 ++++++++++++++++++++++++----------- 3 files changed, 40 insertions(+), 20 deletions(-)
diff --git a/include/efi_loader.h b/include/efi_loader.h index d4412d30bf..3525b65f49 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -391,7 +391,7 @@ efi_status_t efi_setup_loaded_image(struct efi_device_path *device_path, struct efi_loaded_image_obj **handle_ptr, struct efi_loaded_image **info_ptr); efi_status_t efi_load_image_from_path(struct efi_device_path *file_path, - void **buffer); + void **buffer, efi_uintn_t *size); /* Print information about all loaded images */ void efi_print_image_infos(void *pc);
diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index a095df3f54..196116b547 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -150,7 +150,7 @@ static void *try_load_entry(uint16_t n, struct efi_device_path **device_path, debug("%s: trying to load "%ls" from %pD\n", __func__, lo.label, lo.file_path);
- ret = efi_load_image_from_path(lo.file_path, &image); + ret = efi_load_image_from_path(lo.file_path, &image, &size);
if (ret != EFI_SUCCESS) goto error; diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index de746a2d48..37f0f0e338 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -1578,17 +1578,19 @@ failure:
/** * efi_load_image_from_path() - load an image using a file path - * @file_path: the path of the image to load - * @buffer: buffer containing the loaded image + * @file_path: the path of the image to load + * @buffer: buffer containing the loaded image + * @size: size of the loaded image * * Return: status code */ efi_status_t efi_load_image_from_path(struct efi_device_path *file_path, - void **buffer) + void **buffer, efi_uintn_t *size) { struct efi_file_info *info = NULL; struct efi_file_handle *f; static efi_status_t ret; + u64 addr; efi_uintn_t bs;
f = efi_file_from_path(file_path); @@ -1606,22 +1608,21 @@ efi_status_t efi_load_image_from_path(struct efi_device_path *file_path, if (ret != EFI_SUCCESS) goto error;
- ret = efi_allocate_pool(EFI_LOADER_DATA, info->file_size, buffer); - if (ret) + ret = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, + EFI_RUNTIME_SERVICES_CODE, + efi_size_in_pages(), &addr); + if (ret != EFI_SUCCESS) { + ret = EFI_OUT_OF_RESOURCES; goto error; + }
+ *buffer = (void *)(uintptr_t)addr; bs = info->file_size; EFI_CALL(ret = f->read(f, &bs, *buffer));
error: - free(info); EFI_CALL(f->close(f));
- if (ret != EFI_SUCCESS) { - efi_free_pool(*buffer); - *buffer = NULL; - } - return ret; }
@@ -1648,6 +1649,7 @@ static efi_status_t EFIAPI efi_load_image(bool boot_policy, efi_uintn_t source_size, efi_handle_t *image_handle) { + struct efi_device_path *dp, *fp; struct efi_loaded_image *info = NULL; struct efi_loaded_image_obj **image_obj = (struct efi_loaded_image_obj **)image_handle; @@ -1667,9 +1669,10 @@ static efi_status_t EFIAPI efi_load_image(bool boot_policy, }
if (!source_buffer) { - struct efi_device_path *dp, *fp; - - ret = efi_load_image_from_path(file_path, &source_buffer); + ret = efi_load_image_from_path(file_path, &source_buffer, + &source_size); + if (ret == EFI_OUT_OF_RESOURCES) + goto error; if (ret != EFI_SUCCESS) goto failure; /* @@ -1677,26 +1680,43 @@ static efi_status_t EFIAPI efi_load_image(bool boot_policy, * file parts: */ efi_dp_split_file_path(file_path, &dp, &fp); - ret = efi_setup_loaded_image(dp, fp, image_obj, &info); - if (ret != EFI_SUCCESS) - goto failure; } else { /* In this case, file_path is the "device" path, i.e. * something like a HARDWARE_DEVICE:MEMORY_MAPPED */ - ret = efi_setup_loaded_image(file_path, NULL, image_obj, &info); + u64 addr; + void *dest_buffer; + + ret = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, + EFI_RUNTIME_SERVICES_CODE, + efi_size_in_pages(source_size), &addr); if (ret != EFI_SUCCESS) goto error; + dest_buffer = (void *)(uintptr_t)addr; + memcpy(dest_buffer, source_buffer, source_size); + source_buffer = dest_buffer; + + dp = file_path; + fp = NULL; } + ret = efi_setup_loaded_image(dp, fp, image_obj, &info); + if (ret != EFI_SUCCESS) + goto failure; (*image_obj)->entry = efi_load_pe(*image_obj, source_buffer, info); if (!(*image_obj)->entry) { ret = EFI_UNSUPPORTED; goto failure; } + /* Update the type of the allocated memory */ + efi_add_memory_map((uintptr_t)source_buffer, + efi_size_in_pages(source_size), + info->image_code_type, false); info->system_table = &systab; info->parent_handle = parent_image; return EFI_EXIT(EFI_SUCCESS); failure: + efi_free_pages((uintptr_t)source_buffer, + efi_size_in_pages(source_size)); efi_delete_handle(*image_handle); *image_handle = NULL; free(info);
