Please pull u-boot-watchdog/master
Hi Tom,
please pull the following cyclic related change to fix the CI build issue here:
---------------------------------------------------------------- - cyclic: Rise default CYCLIC_MAX_CPU_TIME_US to 5000 (Jiaxun) ----------------------------------------------------------------
Here the Azure build, without any issues:
https://dev.azure.com/sr0718/u-boot/_build/results?buildId=371&view=resu...
Thanks, Stefan
The following changes since commit 16324b43db3f2b4fbbc3b701893fcfc4104f33fb:
Merge tag 'u-boot-nand-20240617' of https://source.denx.de/u-boot/custodians/u-boot-nand-flash (2024-06-17 09:27:28 -0600)
git@source.denx.de:u-boot/custodians/u-boot-watchdog.git
for you to fetch changes up to 1fd754cebd38d7456caa82bef15225cbe77960ec:
cyclic: Rise default CYCLIC_MAX_CPU_TIME_US to 5000 (2024-06-18 12:34:37 +0200)
---------------------------------------------------------------- Jiaxun Yang (1): cyclic: Rise default CYCLIC_MAX_CPU_TIME_US to 5000
common/Kconfig | 2 +- configs/octeon_nic23_defconfig | 1 - 2 files changed, 1 insertion(+), 2 deletions(-)
Stefan Roese
