[U-Boot] [PATCH v4 00/18] usb: xhci: Fix USB xHCI support on Intel platform
Currently U-Boot xHCI driver does not work on Intel BayTrail SoC based boards that have USB 3.0 ports. Trying to do a 'usb start' simply hangs the board. This series fixes a bunch of xHCI driver issues to make it work on Intel's platform.
Issues identified in the U-Boot xHCI driver are really spec violations, but apparently other xHCI IPs found on ARM SoCs (mainly Synopsis IP?) are quite tolerant with these spec violations, or IOW those IPs don't respect the xHCI spec. While it comes to Intel platform, it just breaks.
Note xHCI interrupt transfer is still not supported in this series, as it has been there since the original commit of xHCI support for years.
Tested on Intel MinnowMax board with the following USB devices: - Dell USB 1.1 keyboard - Dell USB 1.1 mouse - Netac USB 2.0 flash disk - JetFlash USB 3.0 flash disk - GenesysLogic 4-port USB 3.0 hub, with an integrated Realtek USB ethernet chipset connected to one of its downstream port
Testing were performed on both ports (2.0 port and 3.0 port), and both ports are connected to xHCI (configure MinnowMax to enable xHCI).
Testing results: - DELL USB 1.1 keyboard and mouse can be enumerated on both ports - USB 2.0 and 3.0 flash disks work fine (enumerated, read/write) on both ports - GenesysLogic USB 3.0 hub can be enumerated on 2.0 port as a 2.0 hub, and the integrated Realtek USB ethernet chipset enumerated as well. USB 2.0 and 3.0 flash disks connected via the hub can be enumerated, but DELL USB 1.1 keyboard and mouse cannot. - GenesysLogic USB 3.0 hub can be enumerated on 3.0 port as a 3.0 hub, but the integrated Realtek USB ethernet chipset cannot be enumerated. None of devices connected via the hub can be enumerated. U-Boot xHCI driver just throws BUG_ON() on the event TRB handling.
This indicates that USB 3.0 hub support in U-Boot is seriously broken. So far this series tries to fix some of the issues identified, but the USB 3.0 hub is still not working. This will be left as future work.
The USB 3.0 hub work includes: port status translation, USB 3.0 newly added "Set Hub Depth" request support, xHCI codes update to fill in hub description fields in the input slot context when issuing commands to xHC, etc.
This series is available at u-boot-x86/xhci-working for testing.
Changes in v4: - remove CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS in poplar.h - Rebase on u-boot-usb/master
Changes in v3: - Rebase on u-boot/master
Changes in v2: - Change to use uint and also 'normal' variable name packet_size. - Update description to use "PCI-based" - Remove CONFIG_USB_XHCI_PCI from config_whitelist.txt - Drop two x86 patches that were already applied to u-boot-x86
Bin Meng (18): usb: xhci: Remove incorrect comments for struct xhci_container_ctx usb: xhci: Correct command TRB 4th dword initialization usb: xhci: Initialize scratchpad buffer array and scratchpad buffers usb: xhci: Add input slot context in xhci_set_configuration() usb: hub: Update handling connect status/change in usb_scan_port() usb: hub: Send correct wValue to get hub descriptor of a USB 3.0 hub usb: hub: Revise wLength for 'get port status' request usb: hub: Change USB hub descriptor to match USB 3.0 hubs usb: hub: Add 3.0 hub port status mask of 2.0 hub usb: xhci: Change MAX_HC_PORTS to 255 usb: xhci: Get rid of CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS configs: Remove CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS in all boards usb: ehci: Get rid of CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS configs: Remove CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS in all boards usb: cmd: Print actual packet size for super speed devices usb: xhci: Convert CONFIG_USB_XHCI_PCI to Kconfig x86: minnowmax: Add a environment variable for USB power-on delay x86: minnowmax: Enable USB xHCI support
arch/arm/include/asm/ehci-omap.h | 4 -- arch/x86/dts/minnowmax.dts | 3 ++ cmd/usb.c | 7 ++- common/usb_hub.c | 41 +++++++++++------ configs/minnowmax_defconfig | 1 + drivers/usb/emul/sandbox_hub.c | 7 ++- drivers/usb/host/Kconfig | 6 +++ drivers/usb/host/ehci-hcd.c | 14 +++--- drivers/usb/host/ehci.h | 7 ++- drivers/usb/host/xhci-mem.c | 87 ++++++++++++++++++++++++++++++++++++ drivers/usb/host/xhci-ring.c | 11 ++++- drivers/usb/host/xhci.c | 17 ++++--- drivers/usb/host/xhci.h | 23 +++++----- include/configs/MPC8572DS.h | 1 - include/configs/am43xx_evm.h | 1 - include/configs/am57xx_evm.h | 1 - include/configs/cl-som-am57x.h | 1 - include/configs/cm_t43.h | 1 - include/configs/cm_t54.h | 1 - include/configs/corvus.h | 3 -- include/configs/dra7xx_evm.h | 1 - include/configs/ds414.h | 1 - include/configs/duovero.h | 2 - include/configs/exynos5-common.h | 3 -- include/configs/ls1012afrdm.h | 1 - include/configs/ls1012aqds.h | 1 - include/configs/ls1012ardb.h | 1 - include/configs/ls1021aiot.h | 1 - include/configs/ls1021aqds.h | 1 - include/configs/ls1021atwr.h | 1 - include/configs/ls1043aqds.h | 1 - include/configs/ls1043ardb.h | 1 - include/configs/ls1046aqds.h | 1 - include/configs/ls1046ardb.h | 1 - include/configs/ls2080aqds.h | 1 - include/configs/ls2080ardb.h | 1 - include/configs/ma5d4evk.h | 1 - include/configs/mcx.h | 1 - include/configs/minnowmax.h | 3 +- include/configs/mvebu_armada-37xx.h | 9 +--- include/configs/mvebu_armada-8k.h | 9 +--- include/configs/mx35pdk.h | 1 - include/configs/odroid.h | 1 - include/configs/omap3_beagle.h | 1 - include/configs/omap3_overo.h | 1 - include/configs/omap4_panda.h | 2 - include/configs/omap5_uevm.h | 1 - include/configs/picosam9g45.h | 3 -- include/configs/poplar.h | 1 - include/configs/rk3328_common.h | 2 - include/configs/rk3399_common.h | 3 -- include/configs/sama5d2_ptc.h | 4 -- include/configs/snapper9g45.h | 3 -- include/configs/sunxi-common.h | 1 - include/configs/tam3517-common.h | 1 - include/configs/tao3530.h | 1 - include/configs/tegra114-common.h | 1 - include/configs/tegra124-common.h | 1 - include/configs/tegra20-common.h | 1 - include/configs/tegra210-common.h | 1 - include/configs/tegra30-common.h | 1 - include/configs/ti_armv7_keystone2.h | 1 - include/configs/uniphier.h | 3 -- include/configs/vinco.h | 6 --- include/configs/x86-common.h | 1 - include/configs/xilinx_zynqmp.h | 2 - include/usb.h | 18 ++++++-- include/usb_defs.h | 8 +++- scripts/config_whitelist.txt | 3 -- 69 files changed, 205 insertions(+), 147 deletions(-)
There is no member called 'dma' in struct xhci_container_ctx. Remove the comments that mentions it.
Signed-off-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Stefan Roese sr@denx.de Tested-by: Stefan Roese sr@denx.de ---
Changes in v4: None Changes in v3: None Changes in v2: None
drivers/usb/host/xhci.h | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/usb/host/xhci.h b/drivers/usb/host/xhci.h index 2afa386..431afd8 100644 --- a/drivers/usb/host/xhci.h +++ b/drivers/usb/host/xhci.h @@ -482,10 +482,9 @@ struct xhci_protocol_caps { * @type: Type of context. Used to calculated offsets to contained contexts. * @size: Size of the context data * @bytes: The raw context data given to HW - * @dma: dma address of the bytes * * Represents either a Device or Input context. Holds a pointer to the raw - * memory used for the context (bytes) and dma address of it (dma). + * memory used for the context (bytes). */ struct xhci_container_ctx { unsigned type;
In xhci_queue_command(), when the command is not 'reset endpoint', 'stop endpoint' or 'set TR dequeue pointer', endpoint ID should not be encoded in the TRB.
drivers/usb/host/xhci-ring.c | 11 +++++++++-- 1 file changed, 9 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/host/xhci-ring.c b/drivers/usb/host/xhci-ring.c index 2675a8f..579e670 100644 --- a/drivers/usb/host/xhci-ring.c +++ b/drivers/usb/host/xhci-ring.c @@ -280,8 +280,15 @@ void xhci_queue_command(struct xhci_ctrl *ctrl, u8 *ptr, u32 slot_id, fields[0] = lower_32_bits(val_64); fields[1] = upper_32_bits(val_64); fields[2] = 0; - fields[3] = TRB_TYPE(cmd) | EP_ID_FOR_TRB(ep_index) | - SLOT_ID_FOR_TRB(slot_id) | ctrl->cmd_ring->cycle_state; + fields[3] = TRB_TYPE(cmd) | SLOT_ID_FOR_TRB(slot_id) | + ctrl->cmd_ring->cycle_state; + + /* + * Only 'reset endpoint', 'stop endpoint' and 'set TR dequeue pointer' + * commands need endpoint id encoded. + */ + if (cmd >= TRB_RESET_EP && cmd <= TRB_SET_DEQ) + fields[3] |= EP_ID_FOR_TRB(ep_index);
queue_trb(ctrl, ctrl->cmd_ring, false, fields);
The scratchpad buffer array is used to define the locations of statically allocated memory pages that are available for the private use of the xHC. The xHCI spec explicitly mentions that system software shall allocate the scratchpad buffers before placing the xHC in to Run mode (Run/Stop (R/S) = ‘1’), however U-Boot is missing this part.
This causes xHC on Intel platform does not respond the very first 'enable slot' command that is given to xHC and the 'enable slot' command completion event TRB is never generated and xHC seems to hang forever.
drivers/usb/host/xhci-mem.c | 87 +++++++++++++++++++++++++++++++++++++++++++++ drivers/usb/host/xhci.h | 10 ++++-- 2 files changed, 95 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/host/xhci-mem.c b/drivers/usb/host/xhci-mem.c index 62db51d..12e277a 100644 --- a/drivers/usb/host/xhci-mem.c +++ b/drivers/usb/host/xhci-mem.c @@ -96,6 +96,25 @@ static void xhci_ring_free(struct xhci_ring *ring) }
/** + * Free the scratchpad buffer array and scratchpad buffers + * + * @ctrl host controller data structure + * @return none + */ +static void xhci_scratchpad_free(struct xhci_ctrl *ctrl) +{ + if (!ctrl->scratchpad) + return; + + ctrl->dcbaa->dev_context_ptrs[0] = 0; + + free((void *)(uintptr_t)ctrl->scratchpad->sp_array[0]); + free(ctrl->scratchpad->sp_array); + free(ctrl->scratchpad); + ctrl->scratchpad = NULL; +} + +/** * frees the "xhci_container_ctx" pointer passed * * @param ptr pointer to "xhci_container_ctx" to be freed @@ -155,6 +174,7 @@ void xhci_cleanup(struct xhci_ctrl *ctrl) { xhci_ring_free(ctrl->event_ring); xhci_ring_free(ctrl->cmd_ring); + xhci_scratchpad_free(ctrl); xhci_free_virt_devices(ctrl); free(ctrl->erst.entries); free(ctrl->dcbaa); @@ -320,6 +340,70 @@ struct xhci_ring *xhci_ring_alloc(unsigned int num_segs, bool link_trbs) }
/** + * Set up the scratchpad buffer array and scratchpad buffers + * + * @ctrl host controller data structure + * @return -ENOMEM if buffer allocation fails, 0 on success + */ +static int xhci_scratchpad_alloc(struct xhci_ctrl *ctrl) +{ + struct xhci_hccr *hccr = ctrl->hccr; + struct xhci_hcor *hcor = ctrl->hcor; + struct xhci_scratchpad *scratchpad; + int num_sp; + uint32_t page_size; + void *buf; + int i; + + num_sp = HCS_MAX_SCRATCHPAD(xhci_readl(&hccr->cr_hcsparams2)); + if (!num_sp) + return 0; + + scratchpad = malloc(sizeof(*scratchpad)); + if (!scratchpad) + goto fail_sp; + ctrl->scratchpad = scratchpad; + + scratchpad->sp_array = xhci_malloc(num_sp * sizeof(u64)); + if (!scratchpad->sp_array) + goto fail_sp2; + ctrl->dcbaa->dev_context_ptrs[0] = + cpu_to_le64((uintptr_t)scratchpad->sp_array); + + page_size = xhci_readl(&hcor->or_pagesize) & 0xffff; + for (i = 0; i < 16; i++) { + if ((0x1 & page_size) != 0) + break; + page_size = page_size >> 1; + } + BUG_ON(i == 16); + + page_size = 1 << (i + 12); + buf = memalign(page_size, num_sp * page_size); + if (!buf) + goto fail_sp3; + memset(buf, '\0', num_sp * page_size); + xhci_flush_cache((uintptr_t)buf, num_sp * page_size); + + for (i = 0; i < num_sp; i++) { + uintptr_t ptr = (uintptr_t)buf + i * page_size; + scratchpad->sp_array[i] = cpu_to_le64(ptr); + } + + return 0; + +fail_sp3: + free(scratchpad->sp_array); + +fail_sp2: + free(scratchpad); + ctrl->scratchpad = NULL; + +fail_sp: + return -ENOMEM; +} + +/** * Allocates the Container context * * @param ctrl Host controller data structure @@ -499,6 +583,9 @@ int xhci_mem_init(struct xhci_ctrl *ctrl, struct xhci_hccr *hccr,
xhci_writeq(&ctrl->ir_set->erst_base, val_64);
+ /* set up the scratchpad buffer array and scratchpad buffers */ + xhci_scratchpad_alloc(ctrl); + /* initializing the virtual devices to NULL */ for (i = 0; i < MAX_HC_SLOTS; ++i) ctrl->devs[i] = NULL; diff --git a/drivers/usb/host/xhci.h b/drivers/usb/host/xhci.h index 431afd8..32dd611 100644 --- a/drivers/usb/host/xhci.h +++ b/drivers/usb/host/xhci.h @@ -111,9 +111,10 @@ struct xhci_hccr { #define HCS_IST(p) (((p) >> 0) & 0xf) /* bits 4:7, max number of Event Ring segments */ #define HCS_ERST_MAX(p) (((p) >> 4) & 0xf) +/* bits 21:25 Hi 5 bits of Scratchpad buffers SW must allocate for the HW */ /* bit 26 Scratchpad restore - for save/restore HW state - not used yet */ -/* bits 27:31 number of Scratchpad buffers SW must allocate for the HW */ -#define HCS_MAX_SCRATCHPAD(p) (((p) >> 27) & 0x1f) +/* bits 27:31 Lo 5 bits of Scratchpad buffers SW must allocate for the HW */ +#define HCS_MAX_SCRATCHPAD(p) ((((p) >> 16) & 0x3e0) | (((p) >> 27) & 0x1f))
/* HCSPARAMS3 - hcs_params3 - bitmasks */ /* bits 0:7, Max U1 to U0 latency for the roothub ports */ @@ -1037,6 +1038,10 @@ struct xhci_erst { unsigned int erst_size; };
+struct xhci_scratchpad { + u64 *sp_array; +}; + /* * Each segment table entry is 4*32bits long. 1K seems like an ok size: * (1K bytes * 8bytes/bit) / (4*32 bits) = 64 segment entries in the table, @@ -1224,6 +1229,7 @@ struct xhci_ctrl { struct xhci_intr_reg *ir_set; struct xhci_erst erst; struct xhci_erst_entry entry[ERST_NUM_SEGS]; + struct xhci_scratchpad *scratchpad; struct xhci_virt_device *devs[MAX_HC_SLOTS]; int rootdev; };
A valid input slot context for a 'configure endpoint' command requires the 'Context Entries' field to be initialized to the index of the last valid endpoint context that is defined by the target configuration. We set up the 'Context Entries' field, but we forget to include the input slot context in the input control context 'Add Context flags' bitmap. So xHC will simply ignore input slot context and continue using its own which contains old information of the device.
drivers/usb/host/xhci.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/host/xhci.c b/drivers/usb/host/xhci.c index bd8f4c4..95a0fba 100644 --- a/drivers/usb/host/xhci.c +++ b/drivers/usb/host/xhci.c @@ -332,8 +332,8 @@ static int xhci_set_configuration(struct usb_device *udev) ifdesc = &udev->config.if_desc[0];
ctrl_ctx = xhci_get_input_control_ctx(in_ctx); - /* Zero the input context control */ - ctrl_ctx->add_flags = 0; + /* Initialize the input context control */ + ctrl_ctx->add_flags = cpu_to_le32(SLOT_FLAG); ctrl_ctx->drop_flags = 0;
/* EP_FLAG gives values 1 & 4 for EP1OUT and EP2IN */
It was observed that on Intel MinnowMax board, when xHCI is enabled in the BayTrail SoC, with a USB 3.0 device connected to the bottom USB 3.0 port (mapped to xHCI root port #7), its PORTSC register is always 0x201203 (CCS = 1, CSC = 0). The root cause of such behavior is unknown yet. Connect status change bit is set on the same port with a USB 2.0 device (mapped to xHCI port #1, which is a different port on the root hub).
With current logic in usb_scan_port(), the enumeration process will abort if it does not detect a connect status change on a hub port. However since a device connection status is correctly reported, the enumeration process can still continue.
With this change, USB device connected to the bottom blue port on MinnowMax board can be enumerated under either SS or HS mode.
Signed-off-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Stefan Roese sr@denx.de Tested-by: Stefan Roese sr@denx.de Tested-by: Dinh Nguyen dinguyen@kernel.org ---
common/usb_hub.c | 15 +++++++++------ 1 file changed, 9 insertions(+), 6 deletions(-)
diff --git a/common/usb_hub.c b/common/usb_hub.c index d135526..4fe0daa 100644 --- a/common/usb_hub.c +++ b/common/usb_hub.c @@ -405,8 +405,15 @@ static int usb_scan_port(struct usb_device_scan *usb_scan) portchange = le16_to_cpu(portsts->wPortChange); debug("Port %d Status %X Change %X\n", i + 1, portstatus, portchange);
- /* No connection change happened, wait a bit more. */ - if (!(portchange & USB_PORT_STAT_C_CONNECTION)) { + /* + * No connection change happened, wait a bit more. + * + * For some situation, the hub reports no connection change but a + * device is connected to the port (eg: CCS bit is set but CSC is not + * in the PORTSC register of a root hub), ignore such case. + */ + if (!(portchange & USB_PORT_STAT_C_CONNECTION) && + !(portstatus & USB_PORT_STAT_CONNECTION)) { if (get_timer(0) >= hub->connect_timeout) { debug("devnum=%d port=%d: timeout\n", dev->devnum, i + 1); @@ -418,10 +425,6 @@ static int usb_scan_port(struct usb_device_scan *usb_scan) return 0; }
- /* Test if the connection came up, and if not exit */ - if (!(portstatus & USB_PORT_STAT_CONNECTION)) - return 0; - /* A new USB device is ready at this point */ debug("devnum=%d port=%d: USB dev found\n", dev->devnum, i + 1);
Testing a USB 3.0 hub by connecting it to the xHCI port on Intel MinnowMax, when issuing 'get hub descriptor' to the hub, xHCI reports a transfer event TRB with a completion code 6 which means 'Stall Error'.
In fact super speed USB hub descriptor type is 0x2a, not 0x29. Sending correct SETUP packet to the hub makes it not stall anymore.
common/usb_hub.c | 12 +++++++++++- drivers/usb/host/xhci.c | 1 + include/usb_defs.h | 1 + 3 files changed, 13 insertions(+), 1 deletion(-)
diff --git a/common/usb_hub.c b/common/usb_hub.c index 4fe0daa..48831b5 100644 --- a/common/usb_hub.c +++ b/common/usb_hub.c @@ -65,11 +65,21 @@ __weak void usb_hub_reset_devices(int port) return; }
+static inline bool usb_hub_is_superspeed(struct usb_device *hdev) +{ + return hdev->descriptor.bDeviceProtocol == 3; +} + static int usb_get_hub_descriptor(struct usb_device *dev, void *data, int size) { + unsigned short dtype = USB_DT_HUB; + + if (usb_hub_is_superspeed(dev)) + dtype = USB_DT_SS_HUB; + return usb_control_msg(dev, usb_rcvctrlpipe(dev, 0), USB_REQ_GET_DESCRIPTOR, USB_DIR_IN | USB_RT_HUB, - USB_DT_HUB << 8, 0, data, size, USB_CNTL_TIMEOUT); + dtype << 8, 0, data, size, USB_CNTL_TIMEOUT); }
static int usb_clear_port_feature(struct usb_device *dev, int port, int feature) diff --git a/drivers/usb/host/xhci.c b/drivers/usb/host/xhci.c index 95a0fba..59ee476 100644 --- a/drivers/usb/host/xhci.c +++ b/drivers/usb/host/xhci.c @@ -727,6 +727,7 @@ static int xhci_submit_root(struct usb_device *udev, unsigned long pipe, case USB_REQ_GET_DESCRIPTOR | ((USB_DIR_IN | USB_RT_HUB) << 8): switch (le16_to_cpu(req->value) >> 8) { case USB_DT_HUB: + case USB_DT_SS_HUB: debug("USB_DT_HUB config\n"); srcptr = &descriptor.hub; srclen = 0x8; diff --git a/include/usb_defs.h b/include/usb_defs.h index 8214ba9..608a0ca 100644 --- a/include/usb_defs.h +++ b/include/usb_defs.h @@ -93,6 +93,7 @@ #define USB_DT_REPORT (USB_TYPE_CLASS | 0x02) #define USB_DT_PHYSICAL (USB_TYPE_CLASS | 0x03) #define USB_DT_HUB (USB_TYPE_CLASS | 0x09) +#define USB_DT_SS_HUB (USB_TYPE_CLASS | 0x0a)
/* Descriptor sizes per descriptor type */ #define USB_DT_DEVICE_SIZE 18
For accuracy, we should use 'sizeof(struct usb_port_status)' as the wLength for 'get port status' request, although it happens to be equal to 'sizeof(struct usb_hub_status)'.
common/usb_hub.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/usb_hub.c b/common/usb_hub.c index 48831b5..83c6767 100644 --- a/common/usb_hub.c +++ b/common/usb_hub.c @@ -107,7 +107,7 @@ int usb_get_port_status(struct usb_device *dev, int port, void *data) { return usb_control_msg(dev, usb_rcvctrlpipe(dev, 0), USB_REQ_GET_STATUS, USB_DIR_IN | USB_RT_PORT, 0, port, - data, sizeof(struct usb_hub_status), USB_CNTL_TIMEOUT); + data, sizeof(struct usb_port_status), USB_CNTL_TIMEOUT); }
USB 3.0 hubs have a slightly different hub descriptor than USB 2.0 hubs, with a fixed (rather than variable length) size. Change the host controller drivers that access those last two fields (DeviceRemovable and PortPowerCtrlMask) to use the union.
common/usb_hub.c | 12 +++++++----- drivers/usb/emul/sandbox_hub.c | 7 ++++++- drivers/usb/host/ehci-hcd.c | 4 ++-- drivers/usb/host/xhci.c | 4 ++-- include/usb.h | 18 ++++++++++++++---- 5 files changed, 31 insertions(+), 14 deletions(-)
diff --git a/common/usb_hub.c b/common/usb_hub.c index 83c6767..a46d26a 100644 --- a/common/usb_hub.c +++ b/common/usb_hub.c @@ -583,17 +583,19 @@ static int usb_hub_configure(struct usb_device *dev) &descriptor->wHubCharacteristics)), &hub->desc.wHubCharacteristics); /* set the bitmap */ - bitmap = (unsigned char *)&hub->desc.DeviceRemovable[0]; + bitmap = (unsigned char *)&hub->desc.u.hs.DeviceRemovable[0]; /* devices not removable by default */ memset(bitmap, 0xff, (USB_MAXCHILDREN+1+7)/8); - bitmap = (unsigned char *)&hub->desc.PortPowerCtrlMask[0]; + bitmap = (unsigned char *)&hub->desc.u.hs.PortPowerCtrlMask[0]; memset(bitmap, 0xff, (USB_MAXCHILDREN+1+7)/8); /* PowerMask = 1B */
for (i = 0; i < ((hub->desc.bNbrPorts + 1 + 7)/8); i++) - hub->desc.DeviceRemovable[i] = descriptor->DeviceRemovable[i]; + hub->desc.u.hs.DeviceRemovable[i] = + descriptor->u.hs.DeviceRemovable[i];
for (i = 0; i < ((hub->desc.bNbrPorts + 1 + 7)/8); i++) - hub->desc.PortPowerCtrlMask[i] = descriptor->PortPowerCtrlMask[i]; + hub->desc.u.hs.PortPowerCtrlMask[i] = + descriptor->u.hs.PortPowerCtrlMask[i];
dev->maxchild = descriptor->bNbrPorts; debug("%d ports detected\n", dev->maxchild); @@ -637,7 +639,7 @@ static int usb_hub_configure(struct usb_device *dev)
for (i = 0; i < dev->maxchild; i++) debug("port %d is%s removable\n", i + 1, - hub->desc.DeviceRemovable[(i + 1) / 8] & \ + hub->desc.u.hs.DeviceRemovable[(i + 1) / 8] & \ (1 << ((i + 1) % 8)) ? " not" : "");
if (sizeof(struct usb_hub_status) > USB_BUFSIZ) { diff --git a/drivers/usb/emul/sandbox_hub.c b/drivers/usb/emul/sandbox_hub.c index 9ffda9c..1432858 100644 --- a/drivers/usb/emul/sandbox_hub.c +++ b/drivers/usb/emul/sandbox_hub.c @@ -96,7 +96,12 @@ static struct usb_hub_descriptor hub_desc = { 1 << 7), .bPwrOn2PwrGood = 2, .bHubContrCurrent = 5, - .DeviceRemovable = {0, 0xff}, /* all ports removeable */ + { + { + /* all ports removeable */ + .DeviceRemovable = {0, 0xff} + } + } #if SANDBOX_NUM_PORTS > 8 #error "This code sets up an incorrect mask" #endif diff --git a/drivers/usb/host/ehci-hcd.c b/drivers/usb/host/ehci-hcd.c index f08709d..40ac3a6 100644 --- a/drivers/usb/host/ehci-hcd.c +++ b/drivers/usb/host/ehci-hcd.c @@ -52,8 +52,8 @@ static struct descriptor { 0, /* wHubCharacteristics */ 10, /* bPwrOn2PwrGood */ 0, /* bHubCntrCurrent */ - {}, /* Device removable */ - {} /* at most 7 ports! XXX */ + { /* Device removable */ + } /* at most 7 ports! XXX */ }, { 0x12, /* bLength */ diff --git a/drivers/usb/host/xhci.c b/drivers/usb/host/xhci.c index 59ee476..d5a1b34 100644 --- a/drivers/usb/host/xhci.c +++ b/drivers/usb/host/xhci.c @@ -50,8 +50,8 @@ static struct descriptor { cpu_to_le16(0x8), /* wHubCharacteristics */ 10, /* bPwrOn2PwrGood */ 0, /* bHubCntrCurrent */ - {}, /* Device removable */ - {} /* at most 7 ports! XXX */ + { /* Device removable */ + } /* at most 7 ports! XXX */ }, { 0x12, /* bLength */ diff --git a/include/usb.h b/include/usb.h index 62f051f..eb82cc2 100644 --- a/include/usb.h +++ b/include/usb.h @@ -546,10 +546,20 @@ struct usb_hub_descriptor { unsigned short wHubCharacteristics; unsigned char bPwrOn2PwrGood; unsigned char bHubContrCurrent; - unsigned char DeviceRemovable[(USB_MAXCHILDREN+1+7)/8]; - unsigned char PortPowerCtrlMask[(USB_MAXCHILDREN+1+7)/8]; - /* DeviceRemovable and PortPwrCtrlMask want to be variable-length - bitmaps that hold max 255 entries. (bit0 is ignored) */ + /* 2.0 and 3.0 hubs differ here */ + union { + struct { + /* add 1 bit for hub status change; round to bytes */ + __u8 DeviceRemovable[(USB_MAXCHILDREN + 1 + 7) / 8]; + __u8 PortPowerCtrlMask[(USB_MAXCHILDREN + 1 + 7) / 8]; + } __attribute__ ((packed)) hs; + + struct { + __u8 bHubHdrDecLat; + __le16 wHubDelay; + __le16 DeviceRemovable; + } __attribute__ ((packed)) ss; + } u; } __attribute__ ((packed));
USB 3.0 hub port status has different bit position regarding to port power, port speed, etc. But others are the same as 2.0 hubs.
include/usb_defs.h | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/include/usb_defs.h b/include/usb_defs.h index 608a0ca..6b4385a 100644 --- a/include/usb_defs.h +++ b/include/usb_defs.h @@ -262,12 +262,17 @@
/* * Changes to wPortStatus bit field in USB 3.0 - * See USB 3.0 spec Table 10-11 + * See USB 3.0 spec Table 10-10 */ #define USB_SS_PORT_STAT_LINK_STATE 0x01e0 #define USB_SS_PORT_STAT_POWER 0x0200 #define USB_SS_PORT_STAT_SPEED 0x1c00 #define USB_SS_PORT_STAT_SPEED_5GBPS 0x0000 +/* Bits that are the same from USB 2.0 */ +#define USB_SS_PORT_STAT_MASK (USB_PORT_STAT_CONNECTION | \ + USB_PORT_STAT_ENABLE | \ + USB_PORT_STAT_OVERCURRENT | \ + USB_PORT_STAT_RESET)
/* wPortChange bits */ #define USB_PORT_STAT_C_CONNECTION 0x0001
HCSPARAMS1:MaxPorts field specifies the maximum port number value, and its valid values are in the range of 1 to 255.
drivers/usb/host/xhci.h | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/usb/host/xhci.h b/drivers/usb/host/xhci.h index 32dd611..3cf08e4 100644 --- a/drivers/usb/host/xhci.h +++ b/drivers/usb/host/xhci.h @@ -30,7 +30,7 @@ /* Max number of USB devices for any host controller - limit in section 6.1 */ #define MAX_HC_SLOTS 256 /* Section 5.3.3 - MaxPorts */ -#define MAX_HC_PORTS 127 +#define MAX_HC_PORTS 255
/* Up to 16 ms to halt an HC */ #define XHCI_MAX_HALT_USEC (16*1000) @@ -102,8 +102,8 @@ struct xhci_hccr { #define HCS_MAX_INTRS(p) (((p) >> 8) & 0x7ff) /* bits 24:31, Max Ports - max value is 0x7F = 127 ports */ #define HCS_MAX_PORTS_SHIFT 24 -#define HCS_MAX_PORTS_MASK (0x7f << HCS_MAX_PORTS_SHIFT) -#define HCS_MAX_PORTS(p) (((p) >> 24) & 0x7f) +#define HCS_MAX_PORTS_MASK (0xff << HCS_MAX_PORTS_SHIFT) +#define HCS_MAX_PORTS(p) (((p) >> 24) & 0xff)
/* HCSPARAMS2 - hcs_params2 - bitmasks */ /* bits 0:3, frames or uframes that SW needs to queue transactions
xHC reports supported maximum number of ports in the HCSPARAMS1 register, so it's unnecessary to use a hardcoded config option CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS.
drivers/usb/host/xhci.c | 8 +++++--- drivers/usb/host/xhci.h | 4 +--- 2 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/usb/host/xhci.c b/drivers/usb/host/xhci.c index d5a1b34..62ab62b 100644 --- a/drivers/usb/host/xhci.c +++ b/drivers/usb/host/xhci.c @@ -668,12 +668,14 @@ static int xhci_submit_root(struct usb_device *udev, unsigned long pipe, uint32_t reg; volatile uint32_t *status_reg; struct xhci_ctrl *ctrl = xhci_get_ctrl(udev); + struct xhci_hccr *hccr = ctrl->hccr; struct xhci_hcor *hcor = ctrl->hcor; + int max_ports = HCS_MAX_PORTS(xhci_readl(&hccr->cr_hcsparams1));
if ((req->requesttype & USB_RT_PORT) && - le16_to_cpu(req->index) > CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS) { - printf("The request port(%d) is not configured\n", - le16_to_cpu(req->index) - 1); + le16_to_cpu(req->index) > max_ports) { + printf("The request port(%d) exceeds maximum port number\n", + le16_to_cpu(req->index) - 1); return -EINVAL; }
diff --git a/drivers/usb/host/xhci.h b/drivers/usb/host/xhci.h index 3cf08e4..b9602ba 100644 --- a/drivers/usb/host/xhci.h +++ b/drivers/usb/host/xhci.h @@ -172,9 +172,7 @@ struct xhci_hcor { volatile uint64_t or_dcbaap; volatile uint32_t or_config; volatile uint32_t reserved_2[241]; - struct xhci_hcor_port_regs portregs[CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS]; - - uint32_t reserved_4[CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS * 254]; + struct xhci_hcor_port_regs portregs[MAX_HC_PORTS]; };
/* USBCMD - USB command - command bitmasks */
Now that xHCD does not use CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS, remove it in all boards' config files.
include/configs/am43xx_evm.h | 1 - include/configs/am57xx_evm.h | 1 - include/configs/cl-som-am57x.h | 1 - include/configs/cm_t43.h | 1 - include/configs/dra7xx_evm.h | 1 - include/configs/ds414.h | 1 - include/configs/exynos5-common.h | 1 - include/configs/ls1012afrdm.h | 1 - include/configs/ls1012aqds.h | 1 - include/configs/ls1012ardb.h | 1 - include/configs/ls1021aiot.h | 1 - include/configs/ls1021aqds.h | 1 - include/configs/ls1021atwr.h | 1 - include/configs/ls1043aqds.h | 1 - include/configs/ls1043ardb.h | 1 - include/configs/ls1046aqds.h | 1 - include/configs/ls1046ardb.h | 1 - include/configs/ls2080aqds.h | 1 - include/configs/ls2080ardb.h | 1 - include/configs/mvebu_armada-37xx.h | 4 +--- include/configs/mvebu_armada-8k.h | 4 +--- include/configs/rk3328_common.h | 2 -- include/configs/rk3399_common.h | 3 --- include/configs/ti_armv7_keystone2.h | 1 - include/configs/uniphier.h | 3 --- include/configs/xilinx_zynqmp.h | 2 -- scripts/config_whitelist.txt | 1 - 27 files changed, 2 insertions(+), 37 deletions(-)
diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 1d8e39c..4278878 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -83,7 +83,6 @@ #if defined(CONFIG_SPL_USB_HOST_SUPPORT) || !defined(CONFIG_SPL_BUILD) #define CONFIG_SYS_USB_FAT_BOOT_PARTITION 1 #define CONFIG_USB_XHCI_OMAP -#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2
#define CONFIG_OMAP_USB_PHY #define CONFIG_AM437X_USB2PHY2_HOST diff --git a/include/configs/am57xx_evm.h b/include/configs/am57xx_evm.h index 98ce6c5..2f59111 100644 --- a/include/configs/am57xx_evm.h +++ b/include/configs/am57xx_evm.h @@ -93,7 +93,6 @@
/* USB xHCI HOST */ #define CONFIG_USB_XHCI_OMAP -#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2
#define CONFIG_OMAP_USB_PHY #define CONFIG_OMAP_USB3PHY1_HOST diff --git a/include/configs/cl-som-am57x.h b/include/configs/cl-som-am57x.h index a04f4cd..02adac5 100644 --- a/include/configs/cl-som-am57x.h +++ b/include/configs/cl-som-am57x.h @@ -84,7 +84,6 @@
#define CONFIG_OMAP_USB_PHY #define CONFIG_OMAP_USB3PHY1_HOST diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index 7b5ca0d..ad6f6ce 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -60,7 +60,6 @@
/* USB support */ #define CONFIG_USB_XHCI_OMAP -#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 #define CONFIG_OMAP_USB_PHY #define CONFIG_AM437X_USB2PHY2_HOST
diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index d2f7c7c..102c986 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -156,7 +156,6 @@
#define CONFIG_OMAP_USB_PHY #define CONFIG_OMAP_USB2PHY2_HOST diff --git a/include/configs/ds414.h b/include/configs/ds414.h index aaba5d8..b0846ef 100644 --- a/include/configs/ds414.h +++ b/include/configs/ds414.h @@ -69,7 +69,6 @@ #if 0 #undef CONFIG_DM_USB #define CONFIG_USB_XHCI_PCI -#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 #endif
#if !defined(CONFIG_USB_XHCI_HCD) diff --git a/include/configs/exynos5-common.h b/include/configs/exynos5-common.h index 378219d..7cb3278 100644 --- a/include/configs/exynos5-common.h +++ b/include/configs/exynos5-common.h @@ -135,7 +135,6 @@
/* USB */ #define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 -#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2
#define CONFIG_USB_HOST_ETHER #define CONFIG_USB_ETHER_ASIX diff --git a/include/configs/ls1012afrdm.h b/include/configs/ls1012afrdm.h index f6f88e8..6b1ba57 100644 --- a/include/configs/ls1012afrdm.h +++ b/include/configs/ls1012afrdm.h @@ -39,7 +39,6 @@ #ifdef CONFIG_HAS_FSL_XHCI_USB #define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 -#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 #endif
#define CONFIG_CMD_MEMINFO diff --git a/include/configs/ls1012aqds.h b/include/configs/ls1012aqds.h index 9e6c7a7..bebb0df 100644 --- a/include/configs/ls1012aqds.h +++ b/include/configs/ls1012aqds.h @@ -124,7 +124,6 @@ #ifdef CONFIG_HAS_FSL_XHCI_USB #define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 -#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 #endif
/* MMC */ diff --git a/include/configs/ls1012ardb.h b/include/configs/ls1012ardb.h index 0705bc5..32c8cec 100644 --- a/include/configs/ls1012ardb.h +++ b/include/configs/ls1012ardb.h @@ -27,7 +27,6 @@ #ifdef CONFIG_HAS_FSL_XHCI_USB #define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 -#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 #endif
/* diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index c1ec2d4..26fbb09 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -26,7 +26,6 @@ #define CONFIG_USB_XHCI_FSL #define CONFIG_USB_XHCI_DWC3 #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 -#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 #endif
#if defined(CONFIG_HAS_FSL_DR_USB) || defined(CONFIG_HAS_FSL_XHCI_USB) diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 1529541..101e2e5 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -413,7 +413,6 @@ unsigned long get_board_ddr_clk(void); #ifdef CONFIG_HAS_FSL_XHCI_USB #define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 -#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 #endif
/* diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 067ef4d..fd3b979 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -50,7 +50,6 @@ #ifdef CONFIG_HAS_FSL_XHCI_USB #define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 -#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 #endif
#define CONFIG_SYS_CLK_FREQ 100000000 diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 87ca36a..437439c 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -377,7 +377,6 @@ unsigned long get_board_ddr_clk(void); #ifdef CONFIG_HAS_FSL_XHCI_USB #define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 3 -#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 #endif
/* diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index deae787..f87fce6 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -291,7 +291,6 @@ #ifdef CONFIG_HAS_FSL_XHCI_USB #define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 3 -#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 #endif #endif
diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 77619ab..5779e45 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -144,7 +144,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_USB_XHCI_FSL #define CONFIG_USB_XHCI_DWC3 #define CONFIG_USB_MAX_CONTROLLER_COUNT 3 -#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 #define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #endif diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h index 8a6b4e6..fe74c1f 100644 --- a/include/configs/ls1046ardb.h +++ b/include/configs/ls1046ardb.h @@ -222,7 +222,6 @@ #define CONFIG_USB_XHCI_FSL #define CONFIG_USB_XHCI_DWC3 #define CONFIG_USB_MAX_CONTROLLER_COUNT 3 -#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 #define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #endif diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 5e1867d..a32e80e 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -449,7 +449,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_HAS_FSL_XHCI_USB #define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 -#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2
#include <asm/fsl_secure_boot.h>
diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index e8aacd3..2db682f 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -348,7 +348,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_HAS_FSL_XHCI_USB #define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 -#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2
#undef CONFIG_CMDLINE_EDITING #include <config_distro_defaults.h> diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h index eb80ac5..11323f8 100644 --- a/include/configs/mvebu_armada-37xx.h +++ b/include/configs/mvebu_armada-37xx.h @@ -98,10 +98,8 @@ #define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3
/* USB 3.0 */ -#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 3 - #define CONFIG_USB_MAX_CONTROLLER_COUNT (CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS + \ - CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS) + 3)
/* USB ethernet */ #define CONFIG_USB_HOST_ETHER diff --git a/include/configs/mvebu_armada-8k.h b/include/configs/mvebu_armada-8k.h index ac116ed..3e4680f 100644 --- a/include/configs/mvebu_armada-8k.h +++ b/include/configs/mvebu_armada-8k.h @@ -104,10 +104,8 @@ #define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3
/* USB ethernet */ #define CONFIG_USB_HOST_ETHER diff --git a/include/configs/rk3328_common.h b/include/configs/rk3328_common.h index 7f9f0c5..906c821 100644 --- a/include/configs/rk3328_common.h +++ b/include/configs/rk3328_common.h @@ -63,6 +63,4 @@ #define CONFIG_USB_OHCI_NEW #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 1
-/* xhci host */ -#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 #endif diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h index 54ea97b..14fe12f 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -82,7 +82,4 @@ #define CONFIG_USB_ETHER_SMSC95XX #define CONFIG_USB_ETHER_RTL8152
-/* rockchip xhci host driver */ -#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 - #endif diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index ac8dabd..ea93b05 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -195,7 +195,6 @@
/* USB Configuration */ #define CONFIG_USB_XHCI_KEYSTONE -#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 #define CONFIG_USB_SS_BASE KS2_USB_SS_BASE #define CONFIG_USB_HOST_XHCI_BASE KS2_USB_HOST_XHCI_BASE #define CONFIG_DEV_USB_PHY_BASE KS2_DEV_USB_PHY_BASE diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index e45b506..aa6900e 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -114,9 +114,6 @@ #define CONFIG_SYS_NAND_USE_FLASH_BBT #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0
-/* USB */ -#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 4 - /* SD/MMC */ #define CONFIG_SUPPORT_EMMC_BOOT
diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index c7fcd86..ef9d94f 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -91,8 +91,6 @@ #define CONFIG_SYS_LOAD_ADDR 0x8000000
#if defined(CONFIG_ZYNQMP_USB) -#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 - #define CONFIG_SYS_DFU_DATA_BUF_SIZE 0x1800000 #define DFU_DEFAULT_POLL_TIMEOUT 300 #define CONFIG_USB_CABLE_CHECK diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index e261d02..7c306ec 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -4887,7 +4887,6 @@ CONFIG_SYS_USB_OHCI_CPU_INIT CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS CONFIG_SYS_USB_OHCI_REGS_BASE CONFIG_SYS_USB_OHCI_SLOT_NAME -CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS CONFIG_SYS_USER_SWITCHES_BASE CONFIG_SYS_USE_BOOT_NORFLASH CONFIG_SYS_USE_DATAFLASH
EHC reports supported maximum number of ports in the HCSPARAMS register, so it's unnecessary to use a hardcoded config option CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS.
drivers/usb/host/ehci-hcd.c | 10 +++++++--- drivers/usb/host/ehci.h | 7 +++---- 2 files changed, 10 insertions(+), 7 deletions(-)
diff --git a/drivers/usb/host/ehci-hcd.c b/drivers/usb/host/ehci-hcd.c index 40ac3a6..3243c1d 100644 --- a/drivers/usb/host/ehci-hcd.c +++ b/drivers/usb/host/ehci-hcd.c @@ -148,9 +148,12 @@ static void ehci_powerup_fixup(struct ehci_ctrl *ctrl, uint32_t *status_reg,
static uint32_t *ehci_get_portsc_register(struct ehci_ctrl *ctrl, int port) { - if (port < 0 || port >= CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS) { + int max_ports = HCS_N_PORTS(ehci_readl(&ctrl->hccr->cr_hcsparams)); + + if (port < 0 || port >= max_ports) { /* Printing the message would cause a scan failure! */ - debug("The request port(%u) is not configured\n", port); + debug("The request port(%u) exceeds maximum port number\n", + port); return NULL; }
@@ -205,6 +208,7 @@ static int ehci_shutdown(struct ehci_ctrl *ctrl) { int i, ret = 0; uint32_t cmd, reg; + int max_ports = HCS_N_PORTS(ehci_readl(&ctrl->hccr->cr_hcsparams));
if (!ctrl || !ctrl->hcor) return -EINVAL; @@ -219,7 +223,7 @@ static int ehci_shutdown(struct ehci_ctrl *ctrl) 100 * 1000);
if (!ret) { - for (i = 0; i < CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS; i++) { + for (i = 0; i < max_ports; i++) { reg = ehci_readl(&ctrl->hcor->or_portsc[i]); reg |= EHCI_PS_SUSP; ehci_writel(&ctrl->hcor->or_portsc[i], reg); diff --git a/drivers/usb/host/ehci.h b/drivers/usb/host/ehci.h index 2ab830d..7c39bec 100644 --- a/drivers/usb/host/ehci.h +++ b/drivers/usb/host/ehci.h @@ -11,9 +11,8 @@
#include <usb.h>
-#if !defined(CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS) -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 2 -#endif +/* Section 2.2.3 - N_PORTS */ +#define MAX_HC_PORTS 15
/* * Register Space. @@ -62,7 +61,7 @@ struct ehci_hcor { uint32_t _reserved_1_[6]; uint32_t or_configflag; #define FLAG_CF (1 << 0) /* true: we'll support "high speed" */ - uint32_t or_portsc[CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS]; + uint32_t or_portsc[MAX_HC_PORTS]; #define PORTSC_PSPD(x) (((x) >> 26) & 0x3) #define PORTSC_PSPD_FS 0x0 #define PORTSC_PSPD_LS 0x1
Now that EHCD does not use CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS, remove it in all boards' config files.
arch/arm/include/asm/ehci-omap.h | 4 ---- include/configs/MPC8572DS.h | 1 - include/configs/cm_t54.h | 1 - include/configs/corvus.h | 3 --- include/configs/duovero.h | 2 -- include/configs/exynos5-common.h | 2 -- include/configs/ma5d4evk.h | 1 - include/configs/mcx.h | 1 - include/configs/mvebu_armada-37xx.h | 7 +------ include/configs/mvebu_armada-8k.h | 7 +------ include/configs/mx35pdk.h | 1 - include/configs/odroid.h | 1 - include/configs/omap3_beagle.h | 1 - include/configs/omap3_overo.h | 1 - include/configs/omap4_panda.h | 2 -- include/configs/omap5_uevm.h | 1 - include/configs/picosam9g45.h | 3 --- include/configs/poplar.h | 1 - include/configs/sama5d2_ptc.h | 4 ---- include/configs/snapper9g45.h | 3 --- include/configs/sunxi-common.h | 1 - include/configs/tam3517-common.h | 1 - include/configs/tao3530.h | 1 - include/configs/tegra114-common.h | 1 - include/configs/tegra124-common.h | 1 - include/configs/tegra20-common.h | 1 - include/configs/tegra210-common.h | 1 - include/configs/tegra30-common.h | 1 - include/configs/vinco.h | 6 ------ include/configs/x86-common.h | 1 - scripts/config_whitelist.txt | 1 - 31 files changed, 2 insertions(+), 61 deletions(-)
diff --git a/arch/arm/include/asm/ehci-omap.h b/arch/arm/include/asm/ehci-omap.h index 5a53e40..9dbb2c4 100644 --- a/arch/arm/include/asm/ehci-omap.h +++ b/arch/arm/include/asm/ehci-omap.h @@ -19,11 +19,7 @@ enum usbhs_omap_port_mode { OMAP_EHCI_PORT_MODE_HSIC, };
-#ifdef CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS -#define OMAP_HS_USB_PORTS CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS -#else #define OMAP_HS_USB_PORTS 3 -#endif
#define is_ehci_phy_mode(x) ((x) == OMAP_EHCI_PORT_MODE_PHY) #define is_ehci_tll_mode(x) ((x) == OMAP_EHCI_PORT_MODE_TLL) diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index d8e0dfd..8eb40a6 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -561,7 +561,6 @@ #define CONFIG_USB_EHCI_PCI #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_PCI_EHCI_DEVICE 0 -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 2 #endif
#undef CONFIG_WATCHDOG /* watchdog disabled */ diff --git a/include/configs/cm_t54.h b/include/configs/cm_t54.h index 3647573..6a4ba39 100644 --- a/include/configs/cm_t54.h +++ b/include/configs/cm_t54.h @@ -57,7 +57,6 @@ #define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ CONFIG_SYS_SCSI_MAX_LUN) /* USB UHH support options */ -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 #define CONFIG_EHCI_HCD_INIT_AFTER_RESET
#define CONFIG_OMAP_EHCI_PHY2_RESET_GPIO 76 /* HSIC2 HUB #RESET */ diff --git a/include/configs/corvus.h b/include/configs/corvus.h index 8b8b122..d4bb9ef 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -94,9 +94,6 @@ #define CONFIG_NET_RETRY_COUNT 20 #define CONFIG_AT91_WANTS_COMMON_PHY
-/* USB */ -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 2 - /* USB DFU support */ #define CONFIG_CMD_MTDPARTS #define CONFIG_MTD_DEVICE diff --git a/include/configs/duovero.h b/include/configs/duovero.h index f142231..49875ff 100644 --- a/include/configs/duovero.h +++ b/include/configs/duovero.h @@ -25,8 +25,6 @@ #define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS
/* USB UHH support options */ -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 - #define CONFIG_OMAP_EHCI_PHY1_RESET_GPIO 1 #define CONFIG_OMAP_EHCI_PHY2_RESET_GPIO 62
diff --git a/include/configs/exynos5-common.h b/include/configs/exynos5-common.h index 7cb3278..3b73bbc 100644 --- a/include/configs/exynos5-common.h +++ b/include/configs/exynos5-common.h @@ -134,8 +134,6 @@ /* Enable Time Command */
/* USB */ -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 - #define CONFIG_USB_HOST_ETHER #define CONFIG_USB_ETHER_ASIX #define CONFIG_USB_ETHER_SMSC95XX diff --git a/include/configs/ma5d4evk.h b/include/configs/ma5d4evk.h index 82aee15..95b2573 100644 --- a/include/configs/ma5d4evk.h +++ b/include/configs/ma5d4evk.h @@ -97,7 +97,6 @@ * USB */ #ifdef CONFIG_CMD_USB -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3
/* USB device */ #define CONFIG_USB_ETHER diff --git a/include/configs/mcx.h b/include/configs/mcx.h index 0c237a5..0c5becd 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -74,7 +74,6 @@
/* EHCI */ #define CONFIG_OMAP_EHCI_PHY1_RESET_GPIO 57 -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 #define CONFIG_USB_HOST_ETHER #define CONFIG_USB_ETHER_ASIX #define CONFIG_USB_ETHER_MCS7830 diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h index 11323f8..3edb64b 100644 --- a/include/configs/mvebu_armada-37xx.h +++ b/include/configs/mvebu_armada-37xx.h @@ -94,12 +94,7 @@ #define CONFIG_NET_RETRY_COUNT 50 #define CONFIG_PHY_MARVELL
-/* USB 2.0 */ -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 - -/* USB 3.0 */ -#define CONFIG_USB_MAX_CONTROLLER_COUNT (CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS + \ - 3) +#define CONFIG_USB_MAX_CONTROLLER_COUNT (3 + 3)
/* USB ethernet */ #define CONFIG_USB_HOST_ETHER diff --git a/include/configs/mvebu_armada-8k.h b/include/configs/mvebu_armada-8k.h index 3e4680f..ed90e24 100644 --- a/include/configs/mvebu_armada-8k.h +++ b/include/configs/mvebu_armada-8k.h @@ -100,12 +100,7 @@ #define CONFIG_ARP_TIMEOUT 200 #define CONFIG_NET_RETRY_COUNT 50
/* USB ethernet */ #define CONFIG_USB_HOST_ETHER diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index e60b96f..615080c 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -199,7 +199,6 @@ #define CONFIG_SYS_NAND_LARGEPAGE
/* EHCI driver */ -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 1 #define CONFIG_EHCI_IS_TDI #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_USB_EHCI_MXC diff --git a/include/configs/odroid.h b/include/configs/odroid.h index 609a3d1..af47554 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -185,7 +185,6 @@ /* USB */ #define CONFIG_USB_EHCI_EXYNOS
-#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 #define CONFIG_USB_HOST_ETHER #define CONFIG_USB_ETHER_SMSC95XX
diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 0d48d4e..019c1b0 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -58,7 +58,6 @@
#define CONFIG_OMAP_EHCI_PHY1_RESET_GPIO 147
-#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 #define CONFIG_USB_HOST_ETHER #define CONFIG_USB_ETHER_ASIX #define CONFIG_USB_ETHER_MCS7830 diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index 111aec5..2bd8f55 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -41,7 +41,6 @@
/* USB EHCI */ #define CONFIG_OMAP_EHCI_PHY1_RESET_GPIO 183 -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3
/* commands to include */
diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h index e1263b6..32c1e67 100644 --- a/include/configs/omap4_panda.h +++ b/include/configs/omap4_panda.h @@ -17,8 +17,6 @@ */
diff --git a/include/configs/omap5_uevm.h b/include/configs/omap5_uevm.h index 15d06bb..9d0a513 100644 --- a/include/configs/omap5_uevm.h +++ b/include/configs/omap5_uevm.h @@ -52,7 +52,6 @@ #define CONFIG_SYS_I2C_TCA642X_ADDR 0x22
#define CONFIG_OMAP_EHCI_PHY2_RESET_GPIO 80 diff --git a/include/configs/picosam9g45.h b/include/configs/picosam9g45.h index c83e559..a687e40 100644 --- a/include/configs/picosam9g45.h +++ b/include/configs/picosam9g45.h @@ -97,9 +97,6 @@ #define CONFIG_RESET_PHY_R #define CONFIG_AT91_WANTS_COMMON_PHY
-/* USB */ -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 2 - #define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */
#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE diff --git a/include/configs/poplar.h b/include/configs/poplar.h index 55e05d6..65bc8cb 100644 --- a/include/configs/poplar.h +++ b/include/configs/poplar.h @@ -30,7 +30,6 @@ #define CONFIG_PL01X_SERIAL
/* USB configuration */ -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_USB_EVENT_POLL #define CONFIG_USB_HOST_ETHER diff --git a/include/configs/sama5d2_ptc.h b/include/configs/sama5d2_ptc.h index 7607f94..203c3bc 100644 --- a/include/configs/sama5d2_ptc.h +++ b/include/configs/sama5d2_ptc.h @@ -65,10 +65,6 @@ /* USB */ #define CONFIG_CMD_USB
-#ifdef CONFIG_CMD_USB -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 -#endif - /* USB device */ #define CONFIG_USB_GADGET #define CONFIG_USB_GADGET_DUALSPEED diff --git a/include/configs/snapper9g45.h b/include/configs/snapper9g45.h index 4e0b9b1..8cbd44e 100644 --- a/include/configs/snapper9g45.h +++ b/include/configs/snapper9g45.h @@ -60,9 +60,6 @@ #define CONFIG_TFTP_PORT #define CONFIG_TFTP_TSIZE
-/* USB */ -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 2 - /* MMC */ #define CONFIG_GENERIC_ATMEL_MCI
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index fefd58f..681c91c 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -310,7 +310,6 @@ extern int soft_i2c_gpio_scl; #define CONFIG_USB_OHCI_NEW #define CONFIG_USB_OHCI_SUNXI #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 1 -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 1 #endif
#ifdef CONFIG_USB_MUSB_SUNXI diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index 0b87c9c..9d23754 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -67,7 +67,6 @@ 115200} /* EHCI */ #define CONFIG_OMAP_EHCI_PHY1_RESET_GPIO 25 -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3
/* commands to include */ #define CONFIG_CMD_NAND /* NAND support */ diff --git a/include/configs/tao3530.h b/include/configs/tao3530.h index f994d2d..a60cddd 100644 --- a/include/configs/tao3530.h +++ b/include/configs/tao3530.h @@ -230,7 +230,6 @@ /* USB EHCI */ #define CONFIG_OMAP_EHCI_PHY1_RESET_GPIO 162
diff --git a/include/configs/tegra114-common.h b/include/configs/tegra114-common.h index 107a0f8..75d2065 100644 --- a/include/configs/tegra114-common.h +++ b/include/configs/tegra114-common.h @@ -63,6 +63,5 @@ /* For USB EHCI controller */ #define CONFIG_EHCI_IS_TDI #define CONFIG_USB_EHCI_TXFIFO_THRESH 0x10 -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 1
#endif /* _TEGRA114_COMMON_H_ */ diff --git a/include/configs/tegra124-common.h b/include/configs/tegra124-common.h index 8cf9bac..0d61753 100644 --- a/include/configs/tegra124-common.h +++ b/include/configs/tegra124-common.h @@ -65,7 +65,6 @@ /* For USB EHCI controller */ #define CONFIG_EHCI_IS_TDI #define CONFIG_USB_EHCI_TXFIFO_THRESH 0x10 -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 1
/* GPU needs setup */ #define CONFIG_TEGRA_GPU diff --git a/include/configs/tegra20-common.h b/include/configs/tegra20-common.h index db1cc24..342ffbe 100644 --- a/include/configs/tegra20-common.h +++ b/include/configs/tegra20-common.h @@ -82,7 +82,6 @@ */ #define CONFIG_USB_EHCI_TXFIFO_THRESH 10 #define CONFIG_EHCI_IS_TDI -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 1
#define CONFIG_SYS_NAND_SELF_INIT #define CONFIG_SYS_NAND_ONFI_DETECTION diff --git a/include/configs/tegra210-common.h b/include/configs/tegra210-common.h index 874fe34d..4c05576 100644 --- a/include/configs/tegra210-common.h +++ b/include/configs/tegra210-common.h @@ -68,7 +68,6 @@ /* For USB EHCI controller */ #define CONFIG_EHCI_IS_TDI #define CONFIG_USB_EHCI_TXFIFO_THRESH 0x10 -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 1
/* GPU needs setup */ #define CONFIG_TEGRA_GPU diff --git a/include/configs/tegra30-common.h b/include/configs/tegra30-common.h index 6083847..c2096fb 100644 --- a/include/configs/tegra30-common.h +++ b/include/configs/tegra30-common.h @@ -64,6 +64,5 @@ /* For USB EHCI controller */ #define CONFIG_EHCI_IS_TDI #define CONFIG_USB_EHCI_TXFIFO_THRESH 0x10 -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 1
#endif /* _TEGRA30_COMMON_H_ */ diff --git a/include/configs/vinco.h b/include/configs/vinco.h index dc35b28..adff1b6 100644 --- a/include/configs/vinco.h +++ b/include/configs/vinco.h @@ -63,12 +63,6 @@
#endif
-/* USB */ - -#ifdef CONFIG_CMD_USB -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 -#endif - /* USB device */ #define CONFIG_USB_ETHER #define CONFIG_USB_ETH_RNDIS diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index d104449..53aa417 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -130,7 +130,6 @@ * USB configuration */ #define CONFIG_USB_EHCI_PCI -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 12 #define CONFIG_SYS_USB_EVENT_POLL
#define CONFIG_USB_HOST_ETHER diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 7c306ec..72b7a6c 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -4878,7 +4878,6 @@ CONFIG_SYS_UNSPEC_STRID CONFIG_SYS_USBCTRL CONFIG_SYS_USBD_BASE CONFIG_SYS_USB_EHCI_CPU_INIT -CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS CONFIG_SYS_USB_EHCI_REGS_BASE CONFIG_SYS_USB_FAT_BOOT_PARTITION CONFIG_SYS_USB_HOST
USB 3.0 defines bMaxPacketSize0 field in the device descriptor as the exponent of 2, so let's print the calculated actual size.
Changes in v4: None Changes in v3: None Changes in v2: - Change to use uint and also 'normal' variable name packet_size.
cmd/usb.c | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/cmd/usb.c b/cmd/usb.c index 4fa456e..992d414 100644 --- a/cmd/usb.c +++ b/cmd/usb.c @@ -150,6 +150,8 @@ static void usb_display_string(struct usb_device *dev, int index)
static void usb_display_desc(struct usb_device *dev) { + uint packet_size = dev->descriptor.bMaxPacketSize0; + if (dev->descriptor.bDescriptorType == USB_DT_DEVICE) { printf("%d: %s, USB Revision %x.%x\n", dev->devnum, usb_get_class_desc(dev->config.if_desc[0].desc.bInterfaceClass), @@ -171,9 +173,10 @@ static void usb_display_desc(struct usb_device *dev) usb_get_class_desc( dev->config.if_desc[0].desc.bInterfaceClass)); } + if (dev->descriptor.bcdUSB >= cpu_to_le16(0x0300)) + packet_size = 1 << packet_size; printf(" - PacketSize: %d Configurations: %d\n", - dev->descriptor.bMaxPacketSize0, - dev->descriptor.bNumConfigurations); + packet_size, dev->descriptor.bNumConfigurations); printf(" - Vendor: 0x%04x Product 0x%04x Version %d.%d\n", dev->descriptor.idVendor, dev->descriptor.idProduct, (dev->descriptor.bcdDevice>>8) & 0xff,
Add CONFIG_USB_XHCI_PCI as a Kconfig option.
Changes in v4: None Changes in v3: None Changes in v2: - Update description to use "PCI-based" - Remove CONFIG_USB_XHCI_PCI from config_whitelist.txt
drivers/usb/host/Kconfig | 6 ++++++ scripts/config_whitelist.txt | 1 - 2 files changed, 6 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index bc2c1f1..9edc589 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -31,6 +31,12 @@ config USB_XHCI_MVEBU SoCs, which includes Armada8K, Armada3700 and other Armada family SoCs.
+config USB_XHCI_PCI + bool "Support for PCI-based xHCI USB controller" + default y if X86 + help + Enables support for the PCI-based xHCI controller. + config USB_XHCI_ROCKCHIP bool "Support for Rockchip on-chip xHCI USB controller" depends on ARCH_ROCKCHIP diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 72b7a6c..d7d3add 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -5204,7 +5204,6 @@ CONFIG_USB_XHCI_EXYNOS CONFIG_USB_XHCI_FSL CONFIG_USB_XHCI_KEYSTONE CONFIG_USB_XHCI_OMAP -CONFIG_USB_XHCI_PCI CONFIG_USER_LOWLEVEL_INIT CONFIG_USE_FDT CONFIG_USE_INTERRUPT
Occasionally it was observed that on Intel MinnowMax board, with a USB 2.0 device connected to the bottom port, when doing 'usb start' on the xHCI controller:
scanning bus 0 for devices... cannot reset port 3!?
But neither of the two USB ports is routed to xHCI root port 3. Adding some debug information shows that xHCI port 3 PORTSC register mysteriously reports both CCS = 1 and CSC = 1.
This is not seen every time. After increasing the timeout to wait for power to become stable, the issue is gone. So this indicates current default USB power-on delay (20ms) might be at a critical region where power is stable/unstable. U-Boot provides a mechanism to have a environment variable to override the default one. Add one for MinnowMax.
include/configs/minnowmax.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/include/configs/minnowmax.h b/include/configs/minnowmax.h index ae95485..6ea607d 100644 --- a/include/configs/minnowmax.h +++ b/include/configs/minnowmax.h @@ -20,7 +20,8 @@
#define CONFIG_STD_DEVICES_SETTINGS "stdin=usbkbd,serial\0" \ "stdout=vidconsole,serial\0" \ - "stderr=vidconsole,serial\0" + "stderr=vidconsole,serial\0" \ + "usb_pgood_delay=40\0"
#define CONFIG_SCSI_DEV_LIST \ {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_VALLEYVIEW_SATA}, \
BayTrail SoC supports both EHCI and xHCI controllers. However only one host controller (either EHCI or xHCI) can be used. To enable HSIC and SS ports, xHCI must be used. This turns on xHCI support on Intel MinnowMax board.
Changes in v4: - Rebase on u-boot-usb/master
Changes in v2: - Drop two x86 patches that were already applied to u-boot-x86
arch/x86/dts/minnowmax.dts | 3 +++ configs/minnowmax_defconfig | 1 + 2 files changed, 4 insertions(+)
diff --git a/arch/x86/dts/minnowmax.dts b/arch/x86/dts/minnowmax.dts index 4c0a8fe..a0ad03c 100644 --- a/arch/x86/dts/minnowmax.dts +++ b/arch/x86/dts/minnowmax.dts @@ -272,6 +272,9 @@ fsp,enable-spi; fsp,enable-sata; fsp,sata-mode = <SATA_MODE_AHCI>; +#ifdef CONFIG_USB_XHCI_HCD + fsp,enable-xhci; +#endif fsp,lpe-mode = <LPE_MODE_PCI>; fsp,lpss-sio-mode = <LPSS_SIO_MODE_PCI>; fsp,enable-dma0; diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index a64a0a3..72dea82 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -69,6 +69,7 @@ CONFIG_ICH_SPI=y CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_DM_VIDEO=y
Testing results:
Applied to u-boot-usb/master, thanks
Bin Meng
