[U-Boot] [WIP PATCH 0/2] arm: socfpga: Add Cadence QSPI support
Hi SoCFPGA-developers!
I'm currently using Marek's latest SoCFPGA port. This works really great so far. Thank you all for this effort.
What I need additionally is SPI NOR flash support. So I talked a bit with Marek and tried to port the Cadence QSPI driver to mainline U-Boot (on-top of Marek's patch set of course). This version in these patches now compiles clean. And detecting of the SPI flash also works good. Reading also seems to be okay. Only easing and writing have some problems.
Perhaps somebody from Altera with deeper Cadence SPI controller knowledge can take a quick look at this. Could be a pretty obvious mistake that I made while copying / porting the code. Or something else thats simply missing.
Any hints are really appretiated!
BTW: I'm currently testing this on the EBV SoCrates board.
Thanks, Stefan
Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@altera.com Cc: Vince Bridgers vbridger@altera.com Cc: Marek Vasut marex@denx.de Cc: Pavel Machek pavel@denx.de
This driver is copied directly from the Altera Rockerboard.org U-Boot repository. I used this git tag: ACDS14.0.1_REL_GSRD_RC2. With minimal changes to enable compilation in mainline U-Boot.
Signed-off-by: Stefan Roese sr@denx.de Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@altera.com Cc: Vince Bridgers vbridger@altera.com Cc: Marek Vasut marex@denx.de Cc: Pavel Machek pavel@denx.de --- drivers/spi/Makefile | 1 + drivers/spi/cadence_qspi.c | 355 ++++++++++++++++ drivers/spi/cadence_qspi.h | 73 ++++ drivers/spi/cadence_qspi_apb.c | 900 +++++++++++++++++++++++++++++++++++++++++ 4 files changed, 1329 insertions(+) create mode 100644 drivers/spi/cadence_qspi.c create mode 100644 drivers/spi/cadence_qspi.h create mode 100644 drivers/spi/cadence_qspi_apb.c
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index f02c35a..4b7b566 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -16,6 +16,7 @@ obj-$(CONFIG_ATMEL_DATAFLASH_SPI) += atmel_dataflash_spi.o obj-$(CONFIG_ATMEL_SPI) += atmel_spi.o obj-$(CONFIG_BFIN_SPI) += bfin_spi.o obj-$(CONFIG_BFIN_SPI6XX) += bfin_spi6xx.o +obj-$(CONFIG_CADENCE_QSPI) += cadence_qspi.o cadence_qspi_apb.o obj-$(CONFIG_CF_SPI) += cf_spi.o obj-$(CONFIG_CF_QSPI) += cf_qspi.o obj-$(CONFIG_DAVINCI_SPI) += davinci_spi.o diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c new file mode 100644 index 0000000..3228cbe --- /dev/null +++ b/drivers/spi/cadence_qspi.c @@ -0,0 +1,355 @@ +/* + * Copyright (C) 2012 + * Altera Corporation <www.altera.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <malloc.h> +#include <spi.h> +#include "cadence_qspi.h" + +#define CQSPI_STIG_READ 0 +#define CQSPI_STIG_WRITE 1 +#define CQSPI_INDIRECT_READ 2 +#define CQSPI_INDIRECT_WRITE 3 + +static int qspi_is_init; +static unsigned int qspi_calibrated_hz; +static unsigned int qspi_calibrated_cs; + +struct cadence_qspi_slave { + struct spi_slave slave; + unsigned int mode; + unsigned int max_hz; + void *regbase; + void *ahbbase; + size_t cmd_len; + u8 cmd_buf[32]; + size_t data_len; +}; + +#define to_cadence_qspi_slave(s) \ + container_of(s, struct cadence_qspi_slave, slave) + +void spi_set_speed(struct spi_slave *slave, uint hz) +{ + struct cadence_qspi_slave *cadence_qspi = to_cadence_qspi_slave(slave); + void *base = cadence_qspi->regbase; + + cadence_qspi_apb_config_baudrate_div(base, CONFIG_CQSPI_REF_CLK, hz); + + /* Reconfigure delay timing if speed is changed. */ + cadence_qspi_apb_delay(base, CONFIG_CQSPI_REF_CLK, hz, + CONFIG_CQSPI_TSHSL_NS, CONFIG_CQSPI_TSD2D_NS, + CONFIG_CQSPI_TCHSH_NS, CONFIG_CQSPI_TSLCH_NS); + return; +} + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct cadence_qspi_slave *cadence_qspi; + + debug("%s: bus %d cs %d max_hz %dMHz mode %d\n", __func__, + bus, cs, max_hz/1000000, mode); + + if (!spi_cs_is_valid(bus, cs)) + return NULL; + + cadence_qspi = calloc(sizeof(struct cadence_qspi_slave), 1); + if (!cadence_qspi) { + printf("QSPI: Can't allocate struct cadence_qspi_slave. " + "Bus %d cs %d\n", bus, cs); + return NULL; + } + + cadence_qspi->slave.bus = bus; + cadence_qspi->slave.cs = cs; + cadence_qspi->mode = mode; + cadence_qspi->max_hz = max_hz; + cadence_qspi->regbase = (void *)QSPI_BASE; + cadence_qspi->ahbbase = (void *)QSPI_AHB_BASE; + + if (!qspi_is_init) + spi_init(); + + return &cadence_qspi->slave; +} + +void spi_free_slave(struct spi_slave *slave) +{ + struct cadence_qspi_slave *cadence_qspi = to_cadence_qspi_slave(slave); + free(cadence_qspi); + return; +} + +void spi_init(void) +{ + cadence_qspi_apb_controller_init((void *)QSPI_BASE); + qspi_is_init = 1; + return; +} + +/* calibration sequence to determine the read data capture delay register */ +int spi_calibration(struct spi_slave *slave) +{ + struct cadence_qspi_slave *cadence_qspi = to_cadence_qspi_slave(slave); + void *base = cadence_qspi->regbase; + u8 opcode_rdid = 0x9F; + unsigned int idcode = 0, temp = 0; + int err = 0, i, range_lo = -1, range_hi = -1; + + /* start with slowest clock (1 MHz) */ + spi_set_speed(slave, 1000000); + + /* configure the read data capture delay register to 0 */ + cadence_qspi_apb_readdata_capture(base, 1, 0); + + /* Enable QSPI */ + cadence_qspi_apb_controller_enable(base); + + /* read the ID which will be our golden value */ + err = cadence_qspi_apb_command_read(base, 1, &opcode_rdid, + 3, (u8 *)&idcode); + if (err) { + puts("SF: Calibration failed (read)\n"); + return err; + } + + /* use back the intended clock and find low range */ + spi_set_speed(slave, cadence_qspi->max_hz); + for (i = 0; i < CQSPI_READ_CAPTURE_MAX_DELAY; i++) { + /* Disable QSPI */ + cadence_qspi_apb_controller_disable(base); + + /* reconfigure the read data capture delay register */ + cadence_qspi_apb_readdata_capture(base, 1, i); + + /* Enable back QSPI */ + cadence_qspi_apb_controller_enable(base); + + /* issue a RDID to get the ID value */ + err = cadence_qspi_apb_command_read(base, 1, &opcode_rdid, + 3, (u8 *)&temp); + if (err) { + puts("SF: Calibration failed (read)\n"); + return err; + } + + /* search for range lo */ + if (range_lo == -1 && temp == idcode) { + range_lo = i; + continue; + } + + /* search for range hi */ + if (range_lo != -1 && temp != idcode) { + range_hi = i - 1; + break; + } + range_hi = i; + } + + if (range_lo == -1) { + puts("SF: Calibration failed (low range)\n"); + return err; + } + + /* Disable QSPI for subsequent initialization */ + cadence_qspi_apb_controller_disable(base); + + /* configure the final value for read data capture delay register */ + cadence_qspi_apb_readdata_capture(base, 1, (range_hi + range_lo) / 2); + printf("SF: Read data capture delay calibrated to %i (%i - %i)\n", + (range_hi + range_lo) / 2, range_lo, range_hi); + + /* just to ensure we do once only when speed or chip select change */ + qspi_calibrated_hz = cadence_qspi->max_hz; + qspi_calibrated_cs = slave->cs; + return 0; +} + +int spi_claim_bus(struct spi_slave *slave) +{ + struct cadence_qspi_slave *cadence_qspi = to_cadence_qspi_slave(slave); + unsigned int clk_pol = (cadence_qspi->mode & SPI_CPOL) ? 1 : 0; + unsigned int clk_pha = (cadence_qspi->mode & SPI_CPHA) ? 1 : 0; + void *base = cadence_qspi->regbase; + int err = 0; + + debug("%s: bus:%i cs:%i\n", __func__, slave->bus, slave->cs); + + /* Disable QSPI */ + cadence_qspi_apb_controller_disable(base); + + /* Set Chip select */ + cadence_qspi_apb_chipselect(base, slave->cs, CONFIG_CQSPI_DECODER); + + /* Set SPI mode */ + cadence_qspi_apb_set_clk_mode(base, clk_pol, clk_pha); + + /* Set clock speed */ + spi_set_speed(slave, cadence_qspi->max_hz); + + /* calibration required for different SCLK speed or chip select */ + if (qspi_calibrated_hz != cadence_qspi->max_hz || + qspi_calibrated_cs != slave->cs) { + err = spi_calibration(slave); + if (err) + return err; + } + + /* Enable QSPI */ + cadence_qspi_apb_controller_enable(base); + + return 0; +} + +void spi_release_bus(struct spi_slave *slave) +{ + return; +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *data_out, + void *data_in, unsigned long flags) +{ + struct cadence_qspi_slave *cadence_qspi = to_cadence_qspi_slave(slave); + void *base = cadence_qspi->regbase; + void *ahbbase = cadence_qspi->ahbbase; + u8 *cmd_buf = cadence_qspi->cmd_buf; + size_t data_bytes; + int err = 0; + u32 mode = CQSPI_STIG_WRITE; + + if (flags & SPI_XFER_BEGIN) { + /* copy command to local buffer */ + cadence_qspi->cmd_len = bitlen / 8; + memcpy(cmd_buf, data_out, cadence_qspi->cmd_len); + } + + if (flags == (SPI_XFER_BEGIN | SPI_XFER_END)) { + /* if start and end bit are set, the data bytes is 0. */ + data_bytes = 0; + } else { + data_bytes = bitlen / 8; + } + + if ((flags & SPI_XFER_END) || (flags == 0)) { + + if (cadence_qspi->cmd_len == 0) { + printf("QSPI: Error, command is empty.\n"); + return -1; + } + + if (data_in && data_bytes) { + /* read */ + /* Use STIG if no address. */ + if (!CQSPI_IS_ADDR(cadence_qspi->cmd_len)) + mode = CQSPI_STIG_READ; + else + mode = CQSPI_INDIRECT_READ; + } else if (data_out && !(flags & SPI_XFER_BEGIN)) { + /* write */ + if (!CQSPI_IS_ADDR(cadence_qspi->cmd_len)) + mode = CQSPI_STIG_WRITE; + else + mode = CQSPI_INDIRECT_WRITE; + } + + switch (mode) { + case CQSPI_STIG_READ: + err = cadence_qspi_apb_command_read( + base, cadence_qspi->cmd_len, cmd_buf, + data_bytes, data_in); + + break; + case CQSPI_STIG_WRITE: + err = cadence_qspi_apb_command_write(base, + cadence_qspi->cmd_len, cmd_buf, + data_bytes, data_out); + break; + case CQSPI_INDIRECT_READ: + err = cadence_qspi_apb_indirect_read_setup( + base, QSPI_AHB_BASE, + cadence_qspi->cmd_len, cmd_buf); + if (!err) { + err = cadence_qspi_apb_indirect_read_execute + (base, ahbbase, data_bytes, data_in); + } + break; + case CQSPI_INDIRECT_WRITE: + err = cadence_qspi_apb_indirect_write_setup + (base, QSPI_AHB_BASE, + cadence_qspi->cmd_len, cmd_buf); + if (!err) { + err = cadence_qspi_apb_indirect_write_execute + (base, ahbbase, data_bytes, data_out); + } + break; + default: + err = -1; + break; + } + + if (flags & SPI_XFER_END) { + /* clear command buffer */ + memset(cmd_buf, 0, sizeof(cadence_qspi->cmd_buf)); + cadence_qspi->cmd_len = 0; + } + } + return err; +} + +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ +#if (CONFIG_CQSPI_DECODER == 1) + if (((cs >= 0) && (cs < CQSPI_DECODER_MAX_CS)) && ((bus >= 0) && + (bus < CQSPI_DECODER_MAX_CS))) { + return 1; + } +#else + if (((cs >= 0) && (cs < CQSPI_NO_DECODER_MAX_CS)) && + ((bus >= 0) && (bus < CQSPI_NO_DECODER_MAX_CS))) { + return 1; + } +#endif + printf("QSPI: Invalid bus or cs. Bus %d cs %d\n", bus, cs); + return 0; +} + +void spi_cs_activate(struct spi_slave *slave) +{ + return; +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + return; +} + +void spi_enter_xip(struct spi_slave *slave, char xip_dummy) +{ + struct cadence_qspi_slave *cadence_qspi = to_cadence_qspi_slave(slave); + void *base = cadence_qspi->regbase; + /* Enter XiP */ + cadence_qspi_apb_enter_xip(base, xip_dummy); + return; +} diff --git a/drivers/spi/cadence_qspi.h b/drivers/spi/cadence_qspi.h new file mode 100644 index 0000000..95254f4 --- /dev/null +++ b/drivers/spi/cadence_qspi.h @@ -0,0 +1,73 @@ +/* + * Copyright (C) 2012 + * Altera Corporation <www.altera.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CADENCE_QSPI_H__ +#define __CADENCE_QSPI_H__ + +#define CQSPI_WRITEL writel +#define CQSPI_READL readl + +#define QSPI_BASE (CONFIG_CQSPI_BASE) +#define QSPI_AHB_BASE (CONFIG_CQSPI_AHB_BASE) +#define CQSPI_IS_ADDR(cmd_len) (cmd_len > 1 ? 1 : 0) + +#define CQSPI_NO_DECODER_MAX_CS (4) +#define CQSPI_DECODER_MAX_CS (16) +#define CQSPI_READ_CAPTURE_MAX_DELAY (16) + +/* Functions call declaration */ +void cadence_qspi_apb_controller_init(void *reg_base_addr); +void cadence_qspi_apb_controller_enable(void *reg_base_addr); +void cadence_qspi_apb_controller_disable(void *reg_base_addr); + +int cadence_qspi_apb_command_read(void *reg_base_addr, + unsigned int cmdlen, const u8 *cmdbuf, unsigned int rxlen, u8* rxbuf); +int cadence_qspi_apb_command_write(void *reg_base_addr, + unsigned int cmdlen, const u8 *cmdbuf, + unsigned int txlen, const u8 *txbuf); + +int cadence_qspi_apb_indirect_read_setup(void *reg_base, + unsigned int ahb_phy_addr, unsigned int cmdlen, const u8 *cmdbuf); +int cadence_qspi_apb_indirect_read_execute(void *reg_base_addr, + void *ahb_base_addr, unsigned int rxlen, u8 *rxbuf); + +int cadence_qspi_apb_indirect_write_setup(void *reg_base, + unsigned int ahb_phy_addr, unsigned int cmdlen, const u8 *cmdbuf); +int cadence_qspi_apb_indirect_write_execute(void *reg_base_addr, + void *ahb_base_addr, unsigned int txlen, const u8 *txbuf); + +void cadence_qspi_apb_chipselect(void *reg_base, + unsigned int chip_select, unsigned int decoder_enable); +void cadence_qspi_apb_set_clk_mode(void *reg_base_addr, + unsigned int clk_pol, unsigned int clk_pha); +void cadence_qspi_apb_config_baudrate_div(void *reg_base, + unsigned int ref_clk_hz, unsigned int sclk_hz); +void cadence_qspi_apb_delay(void *reg_base, + unsigned int ref_clk, unsigned int sclk_hz, + unsigned int tshsl_ns, unsigned int tsd2d_ns, + unsigned int tchsh_ns, unsigned int tslch_ns); +void cadence_qspi_apb_enter_xip(void *reg_base, char xip_dummy); +void cadence_qspi_apb_readdata_capture(void *reg_base, + unsigned int bypass, unsigned int delay); + +#endif /* __CADENCE_QSPI_H__ */ diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c new file mode 100644 index 0000000..33b662c --- /dev/null +++ b/drivers/spi/cadence_qspi_apb.c @@ -0,0 +1,900 @@ +/* + * Copyright (C) 2012 Altera Corporation <www.altera.com> + * All rights reserved. + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions are met: + * - Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * - Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in the + * documentation and/or other materials provided with the distribution. + * - Neither the name of the Altera Corporation nor the + * names of its contributors may be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE + * ARE DISCLAIMED. IN NO EVENT SHALL ALTERA CORPORATION BE LIABLE FOR ANY + * DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES + * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; + * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND + * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF + * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/errno.h> +#include "cadence_qspi.h" + +#define CQSPI_REG_POLL_US (1) /* 1us */ +#define CQSPI_REG_RETRY (10000) +#define CQSPI_POLL_IDLE_RETRY (3) + +#define CQSPI_FIFO_WIDTH (4) + +/* Controller sram size in word */ +#define CQSPI_REG_SRAM_SIZE_WORD (128) +#define CQSPI_REG_SRAM_RESV_WORDS (2) +#define CQSPI_REG_SRAM_PARTITION_WR (1) +#define CQSPI_REG_SRAM_PARTITION_RD \ + (CQSPI_REG_SRAM_SIZE_WORD - CQSPI_REG_SRAM_RESV_WORDS) +#define CQSPI_REG_SRAM_THRESHOLD_WORDS (50) + +/* Transfer mode */ +#define CQSPI_INST_TYPE_SINGLE (0) +#define CQSPI_INST_TYPE_DUAL (1) +#define CQSPI_INST_TYPE_QUAD (2) + +#define CQSPI_STIG_DATA_LEN_MAX (8) +#define CQSPI_INDIRECTTRIGGER_ADDR_MASK (0xFFFFF) + +#define CQSPI_DUMMY_CLKS_PER_BYTE (8) +#define CQSPI_DUMMY_BYTES_MAX (4) + + +#define CQSPI_REG_SRAM_FILL_THRESHOLD \ + ((CQSPI_REG_SRAM_SIZE_WORD / 2) * CQSPI_FIFO_WIDTH) +/**************************************************************************** + * Controller's configuration and status register (offset from QSPI_BASE) + ****************************************************************************/ +#define CQSPI_REG_CONFIG 0x00 +#define CQSPI_REG_CONFIG_CLK_POL_LSB 1 +#define CQSPI_REG_CONFIG_CLK_PHA_LSB 2 +#define CQSPI_REG_CONFIG_ENABLE_MASK (1 << 0) +#define CQSPI_REG_CONFIG_DIRECT_MASK (1 << 7) +#define CQSPI_REG_CONFIG_DECODE_MASK (1 << 9) +#define CQSPI_REG_CONFIG_XIP_IMM_MASK (1 << 18) +#define CQSPI_REG_CONFIG_CHIPSELECT_LSB 10 +#define CQSPI_REG_CONFIG_BAUD_LSB 19 +#define CQSPI_REG_CONFIG_IDLE_LSB 31 +#define CQSPI_REG_CONFIG_CHIPSELECT_MASK 0xF +#define CQSPI_REG_CONFIG_BAUD_MASK 0xF + +#define CQSPI_REG_RD_INSTR 0x04 +#define CQSPI_REG_RD_INSTR_OPCODE_LSB 0 +#define CQSPI_REG_RD_INSTR_TYPE_INSTR_LSB 8 +#define CQSPI_REG_RD_INSTR_TYPE_ADDR_LSB 12 +#define CQSPI_REG_RD_INSTR_TYPE_DATA_LSB 16 +#define CQSPI_REG_RD_INSTR_MODE_EN_LSB 20 +#define CQSPI_REG_RD_INSTR_DUMMY_LSB 24 +#define CQSPI_REG_RD_INSTR_TYPE_INSTR_MASK 0x3 +#define CQSPI_REG_RD_INSTR_TYPE_ADDR_MASK 0x3 +#define CQSPI_REG_RD_INSTR_TYPE_DATA_MASK 0x3 +#define CQSPI_REG_RD_INSTR_DUMMY_MASK 0x1F + +#define CQSPI_REG_WR_INSTR 0x08 +#define CQSPI_REG_WR_INSTR_OPCODE_LSB 0 + +#define CQSPI_REG_DELAY 0x0C +#define CQSPI_REG_DELAY_TSLCH_LSB 0 +#define CQSPI_REG_DELAY_TCHSH_LSB 8 +#define CQSPI_REG_DELAY_TSD2D_LSB 16 +#define CQSPI_REG_DELAY_TSHSL_LSB 24 +#define CQSPI_REG_DELAY_TSLCH_MASK 0xFF +#define CQSPI_REG_DELAY_TCHSH_MASK 0xFF +#define CQSPI_REG_DELAY_TSD2D_MASK 0xFF +#define CQSPI_REG_DELAY_TSHSL_MASK 0xFF + +#define CQSPI_READLCAPTURE 0x10 +#define CQSPI_READLCAPTURE_BYPASS_LSB 0 +#define CQSPI_READLCAPTURE_DELAY_LSB 1 +#define CQSPI_READLCAPTURE_DELAY_MASK 0xF + +#define CQSPI_REG_SIZE 0x14 +#define CQSPI_REG_SIZE_ADDRESS_LSB 0 +#define CQSPI_REG_SIZE_PAGE_LSB 4 +#define CQSPI_REG_SIZE_BLOCK_LSB 16 +#define CQSPI_REG_SIZE_ADDRESS_MASK 0xF +#define CQSPI_REG_SIZE_PAGE_MASK 0xFFF +#define CQSPI_REG_SIZE_BLOCK_MASK 0x3F + +#define CQSPI_REG_SRAMPARTITION 0x18 +#define CQSPI_REG_INDIRECTTRIGGER 0x1C + +#define CQSPI_REG_REMAP 0x24 +#define CQSPI_REG_MODE_BIT 0x28 + +#define CQSPI_REG_SDRAMLEVEL 0x2C +#define CQSPI_REG_SDRAMLEVEL_RD_LSB 0 +#define CQSPI_REG_SDRAMLEVEL_WR_LSB 16 +#define CQSPI_REG_SDRAMLEVEL_RD_MASK 0xFFFF +#define CQSPI_REG_SDRAMLEVEL_WR_MASK 0xFFFF + +#define CQSPI_REG_IRQSTATUS 0x40 +#define CQSPI_REG_IRQMASK 0x44 + +#define CQSPI_REG_INDIRECTRD 0x60 +#define CQSPI_REG_INDIRECTRD_START_MASK (1 << 0) +#define CQSPI_REG_INDIRECTRD_CANCEL_MASK (1 << 1) +#define CQSPI_REG_INDIRECTRD_INPROGRESS_MASK (1 << 2) +#define CQSPI_REG_INDIRECTRD_DONE_MASK (1 << 5) + +#define CQSPI_REG_INDIRECTRDWATERMARK 0x64 +#define CQSPI_REG_INDIRECTRDSTARTADDR 0x68 +#define CQSPI_REG_INDIRECTRDBYTES 0x6C + +#define CQSPI_REG_CMDCTRL 0x90 +#define CQSPI_REG_CMDCTRL_EXECUTE_MASK (1 << 0) +#define CQSPI_REG_CMDCTRL_INPROGRESS_MASK (1 << 1) +#define CQSPI_REG_CMDCTRL_DUMMY_LSB 7 +#define CQSPI_REG_CMDCTRL_WR_BYTES_LSB 12 +#define CQSPI_REG_CMDCTRL_WR_EN_LSB 15 +#define CQSPI_REG_CMDCTRL_ADD_BYTES_LSB 16 +#define CQSPI_REG_CMDCTRL_ADDR_EN_LSB 19 +#define CQSPI_REG_CMDCTRL_RD_BYTES_LSB 20 +#define CQSPI_REG_CMDCTRL_RD_EN_LSB 23 +#define CQSPI_REG_CMDCTRL_OPCODE_LSB 24 +#define CQSPI_REG_CMDCTRL_DUMMY_MASK 0x1F +#define CQSPI_REG_CMDCTRL_WR_BYTES_MASK 0x7 +#define CQSPI_REG_CMDCTRL_ADD_BYTES_MASK 0x3 +#define CQSPI_REG_CMDCTRL_RD_BYTES_MASK 0x7 +#define CQSPI_REG_CMDCTRL_OPCODE_MASK 0xFF + +#define CQSPI_REG_INDIRECTWR 0x70 +#define CQSPI_REG_INDIRECTWR_START_MASK (1 << 0) +#define CQSPI_REG_INDIRECTWR_CANCEL_MASK (1 << 1) +#define CQSPI_REG_INDIRECTWR_INPROGRESS_MASK (1 << 2) +#define CQSPI_REG_INDIRECTWR_DONE_MASK (1 << 5) + +#define CQSPI_REG_INDIRECTWRWATERMARK 0x74 +#define CQSPI_REG_INDIRECTWRSTARTADDR 0x78 +#define CQSPI_REG_INDIRECTWRBYTES 0x7C + +#define CQSPI_REG_CMDADDRESS 0x94 +#define CQSPI_REG_CMDREADDATALOWER 0xA0 +#define CQSPI_REG_CMDREADDATAUPPER 0xA4 +#define CQSPI_REG_CMDWRITEDATALOWER 0xA8 +#define CQSPI_REG_CMDWRITEDATAUPPER 0xAC + +#define CQSPI_REG_IS_IDLE(base) \ + ((CQSPI_READL(base + CQSPI_REG_CONFIG) >> \ + CQSPI_REG_CONFIG_IDLE_LSB) & 0x1) + +#define CQSPI_CAL_DELAY(tdelay_ns, tref_ns, tsclk_ns) \ + ((((tdelay_ns) - (tsclk_ns)) / (tref_ns))) + +#define CQSPI_GET_RD_SRAM_LEVEL(reg_basse) \ + (((CQSPI_READL(reg_base + CQSPI_REG_SDRAMLEVEL)) >> \ + CQSPI_REG_SDRAMLEVEL_RD_LSB) & CQSPI_REG_SDRAMLEVEL_RD_MASK) + +#define CQSPI_GET_WR_SRAM_LEVEL(reg_basse) \ + (((CQSPI_READL(reg_base + CQSPI_REG_SDRAMLEVEL)) >> \ + CQSPI_REG_SDRAMLEVEL_WR_LSB) & CQSPI_REG_SDRAMLEVEL_WR_MASK) + +static unsigned int cadence_qspi_apb_cmd2addr(const unsigned char *addr_buf, + unsigned int addr_width) +{ + unsigned int addr; + + addr = (addr_buf[0] << 16) | (addr_buf[1] << 8) | addr_buf[2]; + + if (addr_width == 4) + addr = (addr << 8) | addr_buf[3]; + + return addr; +} + +static void cadence_qspi_apb_read_fifo_data(void *dest, + const void *src_ahb_addr, unsigned int bytes) +{ + unsigned int temp; + int remaining = bytes; + unsigned int *dest_ptr = (unsigned int *)dest; + unsigned int *src_ptr = (unsigned int *)src_ahb_addr; + + while (remaining > 0) { + if (remaining >= CQSPI_FIFO_WIDTH) { + *dest_ptr = CQSPI_READL(src_ptr); + remaining -= CQSPI_FIFO_WIDTH; + } else { + /* dangling bytes */ + temp = CQSPI_READL(src_ptr); + memcpy(dest_ptr, &temp, remaining); + break; + } + dest_ptr++; + } + + return; +} + +static void cadence_qspi_apb_write_fifo_data(const void *dest_ahb_addr, + const void *src, unsigned int bytes) +{ + unsigned int temp; + int remaining = bytes; + unsigned int *dest_ptr = (unsigned int *)dest_ahb_addr; + unsigned int *src_ptr = (unsigned int *)src; + + while (remaining > 0) { + if (remaining >= CQSPI_FIFO_WIDTH) { + CQSPI_WRITEL(*src_ptr, dest_ptr); + remaining -= sizeof(unsigned int); + } else { + /* dangling bytes */ + memcpy(&temp, src_ptr, remaining); + CQSPI_WRITEL(temp, dest_ptr); + break; + } + src_ptr++; + } + + return; +} + +/* Read from SRAM FIFO with polling SRAM fill level. */ +static int qspi_read_sram_fifo_poll(const void *reg_base, void *dest_addr, + const void *src_addr, unsigned int num_bytes) +{ + unsigned int remaining = num_bytes; + unsigned int retry; + unsigned int sram_level = 0; + unsigned char *dest = (unsigned char *)dest_addr; + + while (remaining > 0) { + retry = CQSPI_REG_RETRY; + while (retry--) { + sram_level = CQSPI_GET_RD_SRAM_LEVEL(reg_base); + if (sram_level) + break; + udelay(1); + } + + if (!retry) { + printf("QSPI: No receive data after polling for %d " + "times\n", CQSPI_REG_RETRY); + return -1; + } + + sram_level *= CQSPI_FIFO_WIDTH; + sram_level = sram_level > remaining ? remaining : sram_level; + + /* Read data from FIFO. */ + cadence_qspi_apb_read_fifo_data(dest, src_addr, sram_level); + dest += sram_level; + remaining -= sram_level; + udelay(1); + } + return 0; +} + + +/* Write to SRAM FIFO with polling SRAM fill level. */ +static int qpsi_write_sram_fifo_push(const void *reg_base, void *dest_addr, + const void *src_addr, unsigned int num_bytes) +{ + unsigned int retry = CQSPI_REG_RETRY; + unsigned int sram_level; + unsigned int wr_bytes; + unsigned char* src = (unsigned char *)src_addr; + int remaining = num_bytes; + unsigned int page_size = CONFIG_CQSPI_PAGE_SIZE; + unsigned int sram_threshold_words = CQSPI_REG_SRAM_THRESHOLD_WORDS; + + while (remaining > 0) { + retry = CQSPI_REG_RETRY; + while (retry--) { + sram_level = CQSPI_GET_WR_SRAM_LEVEL(reg_base); + if (sram_level <= sram_threshold_words) + break; + } + if (!retry) { + printf("QSPI: SRAM fill level (0x%08x) " + "not hit lower expected level (0x%08x)", + sram_level, sram_threshold_words); + return -1; + } + /* Write a page or remaining bytes. */ + wr_bytes = (remaining > page_size) ? + page_size : remaining; + + cadence_qspi_apb_write_fifo_data(dest_addr, src, wr_bytes); + src += wr_bytes; + remaining -= wr_bytes; + } + + return 0; +} + +void cadence_qspi_apb_controller_enable(void *reg_base) +{ + unsigned int reg; + reg = CQSPI_READL(reg_base + CQSPI_REG_CONFIG); + reg |= CQSPI_REG_CONFIG_ENABLE_MASK; + CQSPI_WRITEL(reg, reg_base + CQSPI_REG_CONFIG); + return; +} + +void cadence_qspi_apb_controller_disable(void *reg_base) +{ + unsigned int reg; + reg = CQSPI_READL(reg_base + CQSPI_REG_CONFIG); + reg &= ~CQSPI_REG_CONFIG_ENABLE_MASK; + CQSPI_WRITEL(reg, reg_base + CQSPI_REG_CONFIG); + return; +} + +/* Return 1 if idle, otherwise return 0 (busy). */ +static unsigned int cadence_qspi_wait_idle(void *reg_base) +{ + unsigned int start, count = 0; + /* timeout in unit of ms */ + unsigned int timeout = 5000; + + start = get_timer(0); + for ( ; get_timer(start) < timeout ; ) { + if (CQSPI_REG_IS_IDLE(reg_base)) + count++; + else + count = 0; + /* + * Ensure the QSPI controller is in true idle state after + * reading back the same idle status consecutively + */ + if (count >= CQSPI_POLL_IDLE_RETRY) + return 1; + } + + /* Timeout, still in busy mode. */ + printf("QSPI: QSPI is still busy after poll for %d times.\n", + CQSPI_REG_RETRY); + return 0; +} + +void cadence_qspi_apb_readdata_capture(void *reg_base, + unsigned int bypass, unsigned int delay) +{ + unsigned int reg; + cadence_qspi_apb_controller_disable(reg_base); + + reg = CQSPI_READL(reg_base + CQSPI_READLCAPTURE); + + if (bypass) + reg |= (1 << CQSPI_READLCAPTURE_BYPASS_LSB); + else + reg &= ~(1 << CQSPI_READLCAPTURE_BYPASS_LSB); + + reg &= ~(CQSPI_READLCAPTURE_DELAY_MASK + << CQSPI_READLCAPTURE_DELAY_LSB); + + reg |= ((delay & CQSPI_READLCAPTURE_DELAY_MASK) + << CQSPI_READLCAPTURE_DELAY_LSB); + + CQSPI_WRITEL(reg, reg_base + CQSPI_READLCAPTURE); + + cadence_qspi_apb_controller_enable(reg_base); + return; +} + +void cadence_qspi_apb_config_baudrate_div(void *reg_base, + unsigned int ref_clk_hz, unsigned int sclk_hz) +{ + unsigned int reg; + unsigned int div; + + cadence_qspi_apb_controller_disable(reg_base); + reg = CQSPI_READL(reg_base + CQSPI_REG_CONFIG); + reg &= ~(CQSPI_REG_CONFIG_BAUD_MASK << CQSPI_REG_CONFIG_BAUD_LSB); + + div = ref_clk_hz / sclk_hz; + + if (div > 32) + div = 32; + + /* Check if even number. */ + if ((div & 1)) + div = (div / 2); + else { + if (ref_clk_hz % sclk_hz) + /* ensure generated SCLK doesn't exceed user + specified sclk_hz */ + div = (div / 2); + else + div = (div / 2) - 1; + } + + debug("%s: ref_clk %dHz sclk %dHz Div 0x%x\n", __func__, + ref_clk_hz, sclk_hz, div); + + div = (div & CQSPI_REG_CONFIG_BAUD_MASK) << CQSPI_REG_CONFIG_BAUD_LSB; + reg |= div; + CQSPI_WRITEL(reg, reg_base + CQSPI_REG_CONFIG); + + cadence_qspi_apb_controller_enable(reg_base); + return; +} + +void cadence_qspi_apb_set_clk_mode(void *reg_base, + unsigned int clk_pol, unsigned int clk_pha) +{ + unsigned int reg; + + cadence_qspi_apb_controller_disable(reg_base); + reg = CQSPI_READL(reg_base + CQSPI_REG_CONFIG); + reg &= ~(1 << + (CQSPI_REG_CONFIG_CLK_POL_LSB | CQSPI_REG_CONFIG_CLK_PHA_LSB)); + + reg |= ((clk_pol & 0x1) << CQSPI_REG_CONFIG_CLK_POL_LSB); + reg |= ((clk_pha & 0x1) << CQSPI_REG_CONFIG_CLK_PHA_LSB); + + CQSPI_WRITEL(reg, reg_base + CQSPI_REG_CONFIG); + + cadence_qspi_apb_controller_enable(reg_base); + return; +} + +void cadence_qspi_apb_chipselect(void *reg_base, + unsigned int chip_select, unsigned int decoder_enable) +{ + unsigned int reg; + + cadence_qspi_apb_controller_disable(reg_base); + + debug("%s : chipselect %d decode %d\n", __func__, chip_select, + decoder_enable); + + reg = CQSPI_READL(reg_base + CQSPI_REG_CONFIG); + /* docoder */ + if (decoder_enable) + reg |= CQSPI_REG_CONFIG_DECODE_MASK; + else { + reg &= ~CQSPI_REG_CONFIG_DECODE_MASK; + /* Convert CS if without decoder. + * CS0 to 4b'1110 + * CS1 to 4b'1101 + * CS2 to 4b'1011 + * CS3 to 4b'0111 + */ + chip_select = 0xF & ~(1 << chip_select); + } + + reg &= ~(CQSPI_REG_CONFIG_CHIPSELECT_MASK + << CQSPI_REG_CONFIG_CHIPSELECT_LSB); + reg |= (chip_select & CQSPI_REG_CONFIG_CHIPSELECT_MASK) + << CQSPI_REG_CONFIG_CHIPSELECT_LSB; + CQSPI_WRITEL(reg, reg_base + CQSPI_REG_CONFIG); + + cadence_qspi_apb_controller_enable(reg_base); + return; +} + +void cadence_qspi_apb_delay(void *reg_base, + unsigned int ref_clk, unsigned int sclk_hz, + unsigned int tshsl_ns, unsigned int tsd2d_ns, + unsigned int tchsh_ns, unsigned int tslch_ns) +{ + unsigned int ref_clk_ns; + unsigned int sclk_ns; + unsigned int tshsl, tchsh, tslch, tsd2d; + unsigned int reg; + + cadence_qspi_apb_controller_disable(reg_base); + + /* Convert to ns. */ + ref_clk_ns = (1000000000) / ref_clk; + + /* Convert to ns. */ + sclk_ns = (1000000000) / sclk_hz; + + /* Plus 1 to round up 1 clock cycle. */ + tshsl = CQSPI_CAL_DELAY(tshsl_ns, ref_clk_ns, sclk_ns) + 1; + tchsh = CQSPI_CAL_DELAY(tchsh_ns, ref_clk_ns, sclk_ns) + 1; + tslch = CQSPI_CAL_DELAY(tslch_ns, ref_clk_ns, sclk_ns) + 1; + tsd2d = CQSPI_CAL_DELAY(tsd2d_ns, ref_clk_ns, sclk_ns) + 1; + + reg = ((tshsl & CQSPI_REG_DELAY_TSHSL_MASK) + << CQSPI_REG_DELAY_TSHSL_LSB); + reg |= ((tchsh & CQSPI_REG_DELAY_TCHSH_MASK) + << CQSPI_REG_DELAY_TCHSH_LSB); + reg |= ((tslch & CQSPI_REG_DELAY_TSLCH_MASK) + << CQSPI_REG_DELAY_TSLCH_LSB); + reg |= ((tsd2d & CQSPI_REG_DELAY_TSD2D_MASK) + << CQSPI_REG_DELAY_TSD2D_LSB); + CQSPI_WRITEL(reg, reg_base + CQSPI_REG_DELAY); + + cadence_qspi_apb_controller_enable(reg_base); + return; +} + +void cadence_qspi_apb_controller_init(void *reg_base) +{ + unsigned reg; + + cadence_qspi_apb_controller_disable(reg_base); + + /* Configure the device size and address bytes */ + reg = CQSPI_READL(reg_base + CQSPI_REG_SIZE); + /* Clear the previous value */ + reg &= ~(CQSPI_REG_SIZE_PAGE_MASK << CQSPI_REG_SIZE_PAGE_LSB); + reg &= ~(CQSPI_REG_SIZE_BLOCK_MASK << CQSPI_REG_SIZE_BLOCK_LSB); + reg |= (CONFIG_CQSPI_PAGE_SIZE << CQSPI_REG_SIZE_PAGE_LSB); + reg |= (CONFIG_CQSPI_BLOCK_SIZE << CQSPI_REG_SIZE_BLOCK_LSB); + CQSPI_WRITEL(reg, reg_base + CQSPI_REG_SIZE); + + /* Configure the remap address register, no remap */ + CQSPI_WRITEL(0, reg_base + CQSPI_REG_REMAP); + + /* Disable all interrupts */ + CQSPI_WRITEL(0, reg_base + CQSPI_REG_IRQMASK); + + cadence_qspi_apb_controller_enable(reg_base); + return; +} + +static int cadence_qspi_apb_exec_flash_cmd(void *reg_base, + unsigned int reg) +{ + unsigned int retry = CQSPI_REG_RETRY; + + /* Write the CMDCTRL without start execution. */ + CQSPI_WRITEL(reg, reg_base + CQSPI_REG_CMDCTRL); + /* Start execute */ + reg |= CQSPI_REG_CMDCTRL_EXECUTE_MASK; + CQSPI_WRITEL(reg, reg_base + CQSPI_REG_CMDCTRL); + + while (retry--) { + reg = CQSPI_READL(reg_base + CQSPI_REG_CMDCTRL); + if ((reg & CQSPI_REG_CMDCTRL_INPROGRESS_MASK) == 0) + break; + udelay(1); + } + + if (!retry) { + printf("QSPI: flash command execution timeout\n"); + return -EIO; + } + + /* Polling QSPI idle status. */ + if (!cadence_qspi_wait_idle(reg_base)) + return -EIO; + + return 0; +} + +/* For command RDID, RDSR. */ +int cadence_qspi_apb_command_read(void *reg_base, + unsigned int cmdlen, const u8 *cmdbuf, unsigned int rxlen, + u8 *rxbuf) +{ + unsigned int reg; + unsigned int read_len; + int status; + + if (!cmdlen || rxlen > CQSPI_STIG_DATA_LEN_MAX || rxbuf == NULL) { + printf("QSPI: Invalid input arguments cmdlen %d " + "rxlen %d\n", cmdlen, rxlen); + return -EINVAL; + } + + reg = cmdbuf[0] << CQSPI_REG_CMDCTRL_OPCODE_LSB; + + reg |= (0x1 << CQSPI_REG_CMDCTRL_RD_EN_LSB); + + /* 0 means 1 byte. */ + reg |= (((rxlen - 1) & CQSPI_REG_CMDCTRL_RD_BYTES_MASK) + << CQSPI_REG_CMDCTRL_RD_BYTES_LSB); + status = cadence_qspi_apb_exec_flash_cmd(reg_base, reg); + if (status != 0) + return status; + + reg = CQSPI_READL(reg_base + CQSPI_REG_CMDREADDATALOWER); + + /* Put the read value into rx_buf */ + read_len = (rxlen > 4) ? 4 : rxlen; + memcpy(rxbuf, ®, read_len); + rxbuf += read_len; + + if (rxlen > 4) { + reg = CQSPI_READL(reg_base + CQSPI_REG_CMDREADDATAUPPER); + + read_len = rxlen - read_len; + memcpy(rxbuf, ®, read_len); + } + return 0; +} + +/* For commands: WRSR, WREN, WRDI, CHIP_ERASE, BE, etc. */ +int cadence_qspi_apb_command_write(void *reg_base, unsigned int cmdlen, + const u8 *cmdbuf, unsigned int txlen, const u8 *txbuf) +{ + unsigned int reg = 0; + unsigned int addr_value; + unsigned int wr_data; + unsigned int wr_len; + + if (!cmdlen || cmdlen > 5 || txlen > 8 || cmdbuf == NULL) { + printf("QSPI: Invalid input arguments cmdlen %d txlen %d\n", + cmdlen, txlen); + return -EINVAL; + } + + reg |= cmdbuf[0] << CQSPI_REG_CMDCTRL_OPCODE_LSB; + + if (cmdlen == 4 || cmdlen == 5) { + /* Command with address */ + reg |= (0x1 << CQSPI_REG_CMDCTRL_ADDR_EN_LSB); + /* Number of bytes to write. */ + reg |= ((cmdlen - 2) & CQSPI_REG_CMDCTRL_ADD_BYTES_MASK) + << CQSPI_REG_CMDCTRL_ADD_BYTES_LSB; + /* Get address */ + addr_value = cadence_qspi_apb_cmd2addr(&cmdbuf[1], + cmdlen >= 5 ? 4 : 3); + + CQSPI_WRITEL(addr_value, reg_base + CQSPI_REG_CMDADDRESS); + } + + if (txlen) { + /* writing data = yes */ + reg |= (0x1 << CQSPI_REG_CMDCTRL_WR_EN_LSB); + reg |= ((txlen - 1) & CQSPI_REG_CMDCTRL_WR_BYTES_MASK) + << CQSPI_REG_CMDCTRL_WR_BYTES_LSB; + + wr_len = txlen > 4 ? 4 : txlen; + memcpy(&wr_data, txbuf, wr_len); + CQSPI_WRITEL(wr_data, reg_base + + CQSPI_REG_CMDWRITEDATALOWER); + + if (txlen > 4) { + txbuf += wr_len; + wr_len = txlen - wr_len; + memcpy(&wr_data, txbuf, wr_len); + CQSPI_WRITEL(wr_data, reg_base + + CQSPI_REG_CMDWRITEDATAUPPER); + } + } + + /* Execute the command */ + return cadence_qspi_apb_exec_flash_cmd(reg_base, reg); +} + +/* Opcode + Address (3/4 bytes) + dummy bytes (0-4 bytes) */ +int cadence_qspi_apb_indirect_read_setup(void *reg_base, + unsigned int ahb_phy_addr, unsigned int cmdlen, const u8 *cmdbuf) +{ + unsigned int reg; + unsigned int rd_reg; + unsigned int addr_value; + unsigned int dummy_clk; + unsigned int dummy_bytes; + unsigned int addr_bytes; + + /* + * Identify addr_byte. All NOR flash device drivers are using fast read + * which always expecting 1 dummy byte, 1 cmd byte and 3/4 addr byte. + * With that, the length is in value of 5 or 6. Only FRAM chip from + * ramtron using normal read (which won't need dummy byte). + * Unlikely NOR flash using normal read due to performance issue. + */ + if (cmdlen >= 5) + /* to cater fast read where cmd + addr + dummy */ + addr_bytes = cmdlen - 2; + else + /* for normal read (only ramtron as of now) */ + addr_bytes = cmdlen - 1; + + /* Setup the indirect trigger address */ + CQSPI_WRITEL((ahb_phy_addr & CQSPI_INDIRECTTRIGGER_ADDR_MASK), + reg_base + CQSPI_REG_INDIRECTTRIGGER); + + /* Configure SRAM partition for read. */ + CQSPI_WRITEL(CQSPI_REG_SRAM_PARTITION_RD, reg_base + + CQSPI_REG_SRAMPARTITION); + + /* Configure the opcode */ + rd_reg = cmdbuf[0] << CQSPI_REG_RD_INSTR_OPCODE_LSB; + +#if (CONFIG_SPI_FLASH_QUAD == 1) + /* Instruction and address at DQ0, data at DQ0-3. */ + rd_reg |= CQSPI_INST_TYPE_QUAD << CQSPI_REG_RD_INSTR_TYPE_DATA_LSB; +#endif + + /* Get address */ + addr_value = cadence_qspi_apb_cmd2addr(&cmdbuf[1], addr_bytes); + CQSPI_WRITEL(addr_value, reg_base + CQSPI_REG_INDIRECTRDSTARTADDR); + + /* The remaining lenght is dummy bytes. */ + dummy_bytes = cmdlen - addr_bytes - 1; + if (dummy_bytes) { + + if (dummy_bytes > CQSPI_DUMMY_BYTES_MAX) + dummy_bytes = CQSPI_DUMMY_BYTES_MAX; + + rd_reg |= (1 << CQSPI_REG_RD_INSTR_MODE_EN_LSB); +#if defined(CONFIG_SPL_SPI_XIP) && defined(CONFIG_SPL_BUILD) + CQSPI_WRITEL(0x0, reg_base + CQSPI_REG_MODE_BIT); +#else + CQSPI_WRITEL(0xFF, reg_base + CQSPI_REG_MODE_BIT); +#endif + + /* Convert to clock cycles. */ + dummy_clk = dummy_bytes * CQSPI_DUMMY_CLKS_PER_BYTE; + /* Need to minus the mode byte (8 clocks). */ + dummy_clk -= CQSPI_DUMMY_CLKS_PER_BYTE; + + if (dummy_clk) + rd_reg |= (dummy_clk & CQSPI_REG_RD_INSTR_DUMMY_MASK) + << CQSPI_REG_RD_INSTR_DUMMY_LSB; + } + + CQSPI_WRITEL(rd_reg, reg_base + CQSPI_REG_RD_INSTR); + + /* set device size */ + reg = CQSPI_READL(reg_base + CQSPI_REG_SIZE); + reg &= ~CQSPI_REG_SIZE_ADDRESS_MASK; + reg |= (addr_bytes - 1); + CQSPI_WRITEL(reg, reg_base + CQSPI_REG_SIZE); + return 0; +} + +int cadence_qspi_apb_indirect_read_execute(void *reg_base, + void *ahb_base_addr, unsigned int rxlen, u8 *rxbuf) +{ + unsigned int reg; + + CQSPI_WRITEL(rxlen, reg_base + CQSPI_REG_INDIRECTRDBYTES); + + /* Start the indirect read transfer */ + CQSPI_WRITEL(CQSPI_REG_INDIRECTRD_START_MASK, + reg_base + CQSPI_REG_INDIRECTRD); + + if (qspi_read_sram_fifo_poll(reg_base, (void *)rxbuf, + (const void *)ahb_base_addr, rxlen)) { + goto failrd; + } + + /* Check flash indirect controller */ + reg = CQSPI_READL(reg_base + CQSPI_REG_INDIRECTRD); + if (!(reg & CQSPI_REG_INDIRECTRD_DONE_MASK)) { + reg = CQSPI_READL(reg_base + CQSPI_REG_INDIRECTRD); + printf("QSPI: indirect completion status " + "error with reg 0x%08x\n", reg); + goto failrd; + } + + /* Clear indirect completion status */ + CQSPI_WRITEL(CQSPI_REG_INDIRECTRD_DONE_MASK, + reg_base + CQSPI_REG_INDIRECTRD); + return 0; + +failrd: + /* Cancel the indirect read */ + CQSPI_WRITEL(CQSPI_REG_INDIRECTRD_CANCEL_MASK, + reg_base + CQSPI_REG_INDIRECTRD); + return -1; +} + +/* Opcode + Address (3/4 bytes) */ +int cadence_qspi_apb_indirect_write_setup(void *reg_base, + unsigned int ahb_phy_addr, unsigned int cmdlen, const u8 *cmdbuf) +{ + unsigned int reg; + unsigned int addr_bytes = cmdlen > 4 ? 4 : 3; + + if (cmdlen < 4 || cmdbuf == NULL) { + printf("QSPI: iInvalid input argument, len %d cmdbuf 0x%08x\n", + cmdlen, (unsigned int)cmdbuf); + return -EINVAL; + } + /* Setup the indirect trigger address */ + CQSPI_WRITEL((ahb_phy_addr & CQSPI_INDIRECTTRIGGER_ADDR_MASK), + reg_base + CQSPI_REG_INDIRECTTRIGGER); + + CQSPI_WRITEL(CQSPI_REG_SRAM_PARTITION_WR, + reg_base + CQSPI_REG_SRAMPARTITION); + + /* Configure the opcode */ + reg = cmdbuf[0] << CQSPI_REG_WR_INSTR_OPCODE_LSB; + CQSPI_WRITEL(reg, reg_base + CQSPI_REG_WR_INSTR); + + /* Setup write address. */ + reg = cadence_qspi_apb_cmd2addr(&cmdbuf[1], addr_bytes); + CQSPI_WRITEL(reg, reg_base + CQSPI_REG_INDIRECTWRSTARTADDR); + + reg = CQSPI_READL(reg_base + CQSPI_REG_SIZE); + reg &= ~CQSPI_REG_SIZE_ADDRESS_MASK; + reg |= (addr_bytes - 1); + CQSPI_WRITEL(reg, reg_base + CQSPI_REG_SIZE); + return 0; +} + +int cadence_qspi_apb_indirect_write_execute(void *reg_base, + void *ahb_base_addr, unsigned int txlen, const u8 *txbuf) +{ + unsigned int reg = 0; + unsigned int retry; + + /* Configure the indirect read transfer bytes */ + CQSPI_WRITEL(txlen, reg_base + CQSPI_REG_INDIRECTWRBYTES); + + /* Start the indirect write transfer */ + CQSPI_WRITEL(CQSPI_REG_INDIRECTWR_START_MASK, + reg_base + CQSPI_REG_INDIRECTWR); + + if (qpsi_write_sram_fifo_push(reg_base, ahb_base_addr, + (const void *)txbuf, txlen)) { + goto failwr; + } + + /* Wait until last write is completed (FIFO empty) */ + retry = CQSPI_REG_RETRY; + while (retry--) { + reg = CQSPI_GET_WR_SRAM_LEVEL(reg_base); + if (reg == 0) + break; + + udelay(1); + } + if (reg != 0) { + printf("QSPI: timeout for indirect write\n"); + goto failwr; + } + + /* Check flash indirect controller status */ + retry = CQSPI_REG_RETRY; + while (retry--) { + reg = CQSPI_READL(reg_base + CQSPI_REG_INDIRECTWR); + if (reg & CQSPI_REG_INDIRECTWR_DONE_MASK) + break; + udelay(1); + } + if (!(reg & CQSPI_REG_INDIRECTWR_DONE_MASK)) { + printf("QSPI: indirect completion " + "status error with reg 0x%08x\n", reg); + goto failwr; + } + + /* Clear indirect completion status */ + CQSPI_WRITEL(CQSPI_REG_INDIRECTWR_DONE_MASK, + reg_base + CQSPI_REG_INDIRECTWR); + return 0; + +failwr: + /* Cancel the indirect write */ + CQSPI_WRITEL(CQSPI_REG_INDIRECTWR_CANCEL_MASK, + reg_base + CQSPI_REG_INDIRECTWR); + return -1; +} + +void cadence_qspi_apb_enter_xip(void *reg_base, char xip_dummy) +{ + unsigned int reg; + + /* enter XiP mode immediately and enable direct mode */ + reg = CQSPI_READL(reg_base + CQSPI_REG_CONFIG); + reg |= CQSPI_REG_CONFIG_ENABLE_MASK; + reg |= CQSPI_REG_CONFIG_DIRECT_MASK; + reg |= CQSPI_REG_CONFIG_XIP_IMM_MASK; + CQSPI_WRITEL(reg, reg_base + CQSPI_REG_CONFIG); + + /* keep the XiP mode */ + CQSPI_WRITEL(xip_dummy, reg_base + CQSPI_REG_MODE_BIT); + + /* Enable mode bit at devrd */ + reg = CQSPI_READL(reg_base + CQSPI_REG_RD_INSTR); + reg |= (1 << CQSPI_REG_RD_INSTR_MODE_EN_LSB); + CQSPI_WRITEL(reg, reg_base + CQSPI_REG_RD_INSTR); +}
Signed-off-by: Stefan Roese sr@denx.de Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@altera.com Cc: Vince Bridgers vbridger@altera.com Cc: Marek Vasut marex@denx.de Cc: Pavel Machek pavel@denx.de --- include/configs/socfpga_cyclone5_common.h | 31 +++++++++++++++++++++++++++++++ 1 file changed, 31 insertions(+)
diff --git a/include/configs/socfpga_cyclone5_common.h b/include/configs/socfpga_cyclone5_common.h index 3f8f91f..d183510 100644 --- a/include/configs/socfpga_cyclone5_common.h +++ b/include/configs/socfpga_cyclone5_common.h @@ -142,6 +142,37 @@ #endif
/* + * QSPI support + */ +#ifdef CONFIG_CMD_SF +#define CONFIG_CADENCE_QSPI +#define CONFIG_CQSPI_BASE (SOCFPGA_QSPI_ADDRESS) +#define CONFIG_CQSPI_AHB_BASE (SOCFPGA_QSPIDATA_ADDRESS) +#define CONFIG_SPI_FLASH /* SPI flash subsystem */ +#define CONFIG_SPI_FLASH_STMICRO /* Micron/Numonyx flash */ +#define CONFIG_SPI_FLASH_SPANSION /* Spansion flash */ +#define CONFIG_SPI_FLASH_MTD +/* Flash device info */ +#define CONFIG_SF_DEFAULT_SPEED (50000000) +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_3 +#define CONFIG_SPI_FLASH_QUAD (1) +/* QSPI reference clock */ +#ifndef __ASSEMBLY__ +unsigned int cm_get_qspi_controller_clk_hz(void); +#define CONFIG_CQSPI_REF_CLK cm_get_qspi_controller_clk_hz() +#endif +/* QSPI page size and block size */ +#define CONFIG_CQSPI_PAGE_SIZE (256) +#define CONFIG_CQSPI_BLOCK_SIZE (16) +/* QSPI Delay timing */ +#define CONFIG_CQSPI_TSHSL_NS (200) +#define CONFIG_CQSPI_TSD2D_NS (255) +#define CONFIG_CQSPI_TCHSH_NS (20) +#define CONFIG_CQSPI_TSLCH_NS (20) +#define CONFIG_CQSPI_DECODER (0) +#endif /* CONFIG_CMD_SF */ + +/* * Serial Driver */ #define CONFIG_SYS_NS16550
Dear Stefan,
I can help to take a look as I was trying to upstream this code previously. But it was later on hold as the SPI driver / framework is under going some revamp. Hopefully I have some bandwidth tomorrow to start looking into Marek and your patches.
Chin Liang
Thanks, Stefan
Hi Chin Liang,
Dear Stefan,
Thanks! That would be great. I'll continue a bit this afternoon with this task as its a bit pressing right now. I'll let you know if I find the problem.
Thanks, Stefan
Chin Liang See
Stefan Roese
