[PATCH 1/2] arm: dts: rockchip: rk3588, rk3588s: sync with Linux
Sync the devicetree with linux-next tag: next-20230831
Signed-off-by: FUKAUMI Naoki naoki@radxa.com --- arch/arm/dts/rk3588.dtsi | 215 +++++++++++++++++++ arch/arm/dts/rk3588s.dtsi | 367 +++++++++++++++++++++++++++++++++ include/dt-bindings/ata/ahci.h | 20 ++ 3 files changed, 602 insertions(+) create mode 100644 include/dt-bindings/ata/ahci.h
diff --git a/arch/arm/dts/rk3588.dtsi b/arch/arm/dts/rk3588.dtsi index 8be75556af..5519c1430c 100644 --- a/arch/arm/dts/rk3588.dtsi +++ b/arch/arm/dts/rk3588.dtsi @@ -7,6 +7,16 @@ #include "rk3588-pinctrl.dtsi"
/ { + pcie30_phy_grf: syscon@fd5b8000 { + compatible = "rockchip,rk3588-pcie3-phy-grf", "syscon"; + reg = <0x0 0xfd5b8000 0x0 0x10000>; + }; + + pipe_phy1_grf: syscon@fd5c0000 { + compatible = "rockchip,rk3588-pipe-phy-grf", "syscon"; + reg = <0x0 0xfd5c0000 0x0 0x100>; + }; + i2s8_8ch: i2s@fddc8000 { compatible = "rockchip,rk3588-i2s-tdm"; reg = <0x0 0xfddc8000 0x0 0x1000>; @@ -75,6 +85,159 @@ status = "disabled"; };
+ pcie3x4: pcie@fe150000 { + compatible = "rockchip,rk3588-pcie", "rockchip,rk3568-pcie"; + #address-cells = <3>; + #size-cells = <2>; + bus-range = <0x00 0x0f>; + clocks = <&cru ACLK_PCIE_4L_MSTR>, <&cru ACLK_PCIE_4L_SLV>, + <&cru ACLK_PCIE_4L_DBI>, <&cru PCLK_PCIE_4L>, + <&cru CLK_PCIE_AUX0>, <&cru CLK_PCIE4L_PIPE>; + clock-names = "aclk_mst", "aclk_slv", + "aclk_dbi", "pclk", + "aux", "pipe"; + device_type = "pci"; + interrupts = <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 261 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 260 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 259 IRQ_TYPE_LEVEL_HIGH 0>; + interrupt-names = "sys", "pmc", "msg", "legacy", "err"; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 7>; + interrupt-map = <0 0 0 1 &pcie3x4_intc 0>, + <0 0 0 2 &pcie3x4_intc 1>, + <0 0 0 3 &pcie3x4_intc 2>, + <0 0 0 4 &pcie3x4_intc 3>; + linux,pci-domain = <0>; + max-link-speed = <3>; + msi-map = <0x0000 &its1 0x0000 0x1000>; + num-lanes = <4>; + phys = <&pcie30phy>; + phy-names = "pcie-phy"; + power-domains = <&power RK3588_PD_PCIE>; + ranges = <0x01000000 0x0 0xf0100000 0x0 0xf0100000 0x0 0x00100000>, + <0x02000000 0x0 0xf0200000 0x0 0xf0200000 0x0 0x00e00000>, + <0x03000000 0x0 0x40000000 0x9 0x00000000 0x0 0x40000000>; + reg = <0xa 0x40000000 0x0 0x00400000>, + <0x0 0xfe150000 0x0 0x00010000>, + <0x0 0xf0000000 0x0 0x00100000>; + reg-names = "dbi", "apb", "config"; + resets = <&cru SRST_PCIE0_POWER_UP>, <&cru SRST_P_PCIE0>; + reset-names = "pwr", "pipe"; + status = "disabled"; + + pcie3x4_intc: legacy-interrupt-controller { + interrupt-controller; + #address-cells = <0>; + #interrupt-cells = <1>; + interrupt-parent = <&gic>; + interrupts = <GIC_SPI 260 IRQ_TYPE_EDGE_RISING 0>; + }; + }; + + pcie3x2: pcie@fe160000 { + compatible = "rockchip,rk3588-pcie", "rockchip,rk3568-pcie"; + #address-cells = <3>; + #size-cells = <2>; + bus-range = <0x10 0x1f>; + clocks = <&cru ACLK_PCIE_2L_MSTR>, <&cru ACLK_PCIE_2L_SLV>, + <&cru ACLK_PCIE_2L_DBI>, <&cru PCLK_PCIE_2L>, + <&cru CLK_PCIE_AUX1>, <&cru CLK_PCIE2L_PIPE>; + clock-names = "aclk_mst", "aclk_slv", + "aclk_dbi", "pclk", + "aux", "pipe"; + device_type = "pci"; + interrupts = <GIC_SPI 258 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 257 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 255 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 254 IRQ_TYPE_LEVEL_HIGH 0>; + interrupt-names = "sys", "pmc", "msg", "legacy", "err"; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 7>; + interrupt-map = <0 0 0 1 &pcie3x2_intc 0>, + <0 0 0 2 &pcie3x2_intc 1>, + <0 0 0 3 &pcie3x2_intc 2>, + <0 0 0 4 &pcie3x2_intc 3>; + linux,pci-domain = <1>; + max-link-speed = <3>; + msi-map = <0x1000 &its1 0x1000 0x1000>; + num-lanes = <2>; + phys = <&pcie30phy>; + phy-names = "pcie-phy"; + power-domains = <&power RK3588_PD_PCIE>; + ranges = <0x01000000 0x0 0xf1100000 0x0 0xf1100000 0x0 0x00100000>, + <0x02000000 0x0 0xf1200000 0x0 0xf1200000 0x0 0x00e00000>, + <0x03000000 0x0 0x40000000 0x9 0x40000000 0x0 0x40000000>; + reg = <0xa 0x40400000 0x0 0x00400000>, + <0x0 0xfe160000 0x0 0x00010000>, + <0x0 0xf1000000 0x0 0x00100000>; + reg-names = "dbi", "apb", "config"; + resets = <&cru SRST_PCIE1_POWER_UP>, <&cru SRST_P_PCIE1>; + reset-names = "pwr", "pipe"; + status = "disabled"; + + pcie3x2_intc: legacy-interrupt-controller { + interrupt-controller; + #address-cells = <0>; + #interrupt-cells = <1>; + interrupt-parent = <&gic>; + interrupts = <GIC_SPI 255 IRQ_TYPE_EDGE_RISING 0>; + }; + }; + + pcie2x1l0: pcie@fe170000 { + compatible = "rockchip,rk3588-pcie", "rockchip,rk3568-pcie"; + bus-range = <0x20 0x2f>; + clocks = <&cru ACLK_PCIE_1L0_MSTR>, <&cru ACLK_PCIE_1L0_SLV>, + <&cru ACLK_PCIE_1L0_DBI>, <&cru PCLK_PCIE_1L0>, + <&cru CLK_PCIE_AUX2>, <&cru CLK_PCIE1L0_PIPE>; + clock-names = "aclk_mst", "aclk_slv", + "aclk_dbi", "pclk", + "aux", "pipe"; + device_type = "pci"; + interrupts = <GIC_SPI 243 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 242 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 241 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 240 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 239 IRQ_TYPE_LEVEL_HIGH 0>; + interrupt-names = "sys", "pmc", "msg", "legacy", "err"; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 7>; + interrupt-map = <0 0 0 1 &pcie2x1l0_intc 0>, + <0 0 0 2 &pcie2x1l0_intc 1>, + <0 0 0 3 &pcie2x1l0_intc 2>, + <0 0 0 4 &pcie2x1l0_intc 3>; + linux,pci-domain = <2>; + max-link-speed = <2>; + msi-map = <0x2000 &its0 0x2000 0x1000>; + num-lanes = <1>; + phys = <&combphy1_ps PHY_TYPE_PCIE>; + phy-names = "pcie-phy"; + power-domains = <&power RK3588_PD_PCIE>; + ranges = <0x01000000 0x0 0xf2100000 0x0 0xf2100000 0x0 0x00100000>, + <0x02000000 0x0 0xf2200000 0x0 0xf2200000 0x0 0x00e00000>, + <0x03000000 0x0 0x40000000 0x9 0x80000000 0x0 0x40000000>; + reg = <0xa 0x40800000 0x0 0x00400000>, + <0x0 0xfe170000 0x0 0x00010000>, + <0x0 0xf2000000 0x0 0x00100000>; + reg-names = "dbi", "apb", "config"; + resets = <&cru SRST_PCIE2_POWER_UP>, <&cru SRST_P_PCIE2>; + reset-names = "pwr", "pipe"; + #address-cells = <3>; + #size-cells = <2>; + status = "disabled"; + + pcie2x1l0_intc: legacy-interrupt-controller { + interrupt-controller; + #address-cells = <0>; + #interrupt-cells = <1>; + interrupt-parent = <&gic>; + interrupts = <GIC_SPI 240 IRQ_TYPE_EDGE_RISING 0>; + }; + }; + gmac0: ethernet@fe1b0000 { compatible = "rockchip,rk3588-gmac", "snps,dwmac-4.20a"; reg = <0x0 0xfe1b0000 0x0 0x10000>; @@ -123,4 +286,56 @@ queue1 {}; }; }; + + sata1: sata@fe220000 { + compatible = "rockchip,rk3588-dwc-ahci", "snps,dwc-ahci"; + reg = <0 0xfe220000 0 0x1000>; + interrupts = <GIC_SPI 274 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru ACLK_SATA1>, <&cru CLK_PMALIVE1>, + <&cru CLK_RXOOB1>, <&cru CLK_PIPEPHY1_REF>, + <&cru CLK_PIPEPHY1_PIPE_ASIC_G>; + clock-names = "sata", "pmalive", "rxoob", "ref", "asic"; + ports-implemented = <0x1>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + + sata-port@0 { + reg = <0>; + hba-port-cap = <HBA_PORT_FBSCP>; + phys = <&combphy1_ps PHY_TYPE_SATA>; + phy-names = "sata-phy"; + snps,rx-ts-max = <32>; + snps,tx-ts-max = <32>; + }; + }; + + combphy1_ps: phy@fee10000 { + compatible = "rockchip,rk3588-naneng-combphy"; + reg = <0x0 0xfee10000 0x0 0x100>; + clocks = <&cru CLK_REF_PIPE_PHY1>, <&cru PCLK_PCIE_COMBO_PIPE_PHY1>, + <&cru PCLK_PHP_ROOT>; + clock-names = "ref", "apb", "pipe"; + assigned-clocks = <&cru CLK_REF_PIPE_PHY1>; + assigned-clock-rates = <100000000>; + #phy-cells = <1>; + resets = <&cru SRST_REF_PIPE_PHY1>, <&cru SRST_P_PCIE2_PHY1>; + reset-names = "phy", "apb"; + rockchip,pipe-grf = <&php_grf>; + rockchip,pipe-phy-grf = <&pipe_phy1_grf>; + status = "disabled"; + }; + + pcie30phy: phy@fee80000 { + compatible = "rockchip,rk3588-pcie3-phy"; + reg = <0x0 0xfee80000 0x0 0x20000>; + #phy-cells = <0>; + clocks = <&cru PCLK_PCIE_COMBO_PIPE_PHY>; + clock-names = "pclk"; + resets = <&cru SRST_PCIE30_PHY>; + reset-names = "phy"; + rockchip,pipe-grf = <&php_grf>; + rockchip,phy-grf = <&pcie30_phy_grf>; + status = "disabled"; + }; }; diff --git a/arch/arm/dts/rk3588s.dtsi b/arch/arm/dts/rk3588s.dtsi index 7dbac9ae2e..5544f66c6f 100644 --- a/arch/arm/dts/rk3588s.dtsi +++ b/arch/arm/dts/rk3588s.dtsi @@ -8,6 +8,8 @@ #include <dt-bindings/interrupt-controller/irq.h> #include <dt-bindings/power/rk3588-power.h> #include <dt-bindings/reset/rockchip,rk3588-cru.h> +#include <dt-bindings/phy/phy.h> +#include <dt-bindings/ata/ahci.h>
/ { compatible = "rockchip,rk3588"; @@ -397,6 +399,50 @@ }; };
+ usb_host0_ehci: usb@fc800000 { + compatible = "rockchip,rk3588-ehci", "generic-ehci"; + reg = <0x0 0xfc800000 0x0 0x40000>; + interrupts = <GIC_SPI 215 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST_ARB0>, <&cru ACLK_USB>, <&u2phy2>; + phys = <&u2phy2_host>; + phy-names = "usb"; + power-domains = <&power RK3588_PD_USB>; + status = "disabled"; + }; + + usb_host0_ohci: usb@fc840000 { + compatible = "rockchip,rk3588-ohci", "generic-ohci"; + reg = <0x0 0xfc840000 0x0 0x40000>; + interrupts = <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST_ARB0>, <&cru ACLK_USB>, <&u2phy2>; + phys = <&u2phy2_host>; + phy-names = "usb"; + power-domains = <&power RK3588_PD_USB>; + status = "disabled"; + }; + + usb_host1_ehci: usb@fc880000 { + compatible = "rockchip,rk3588-ehci", "generic-ehci"; + reg = <0x0 0xfc880000 0x0 0x40000>; + interrupts = <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru HCLK_HOST1>, <&cru HCLK_HOST_ARB1>, <&cru ACLK_USB>, <&u2phy3>; + phys = <&u2phy3_host>; + phy-names = "usb"; + power-domains = <&power RK3588_PD_USB>; + status = "disabled"; + }; + + usb_host1_ohci: usb@fc8c0000 { + compatible = "rockchip,rk3588-ohci", "generic-ohci"; + reg = <0x0 0xfc8c0000 0x0 0x40000>; + interrupts = <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru HCLK_HOST1>, <&cru HCLK_HOST_ARB1>, <&cru ACLK_USB>, <&u2phy3>; + phys = <&u2phy3_host>; + phy-names = "usb"; + power-domains = <&power RK3588_PD_USB>; + status = "disabled"; + }; + sys_grf: syscon@fd58c000 { compatible = "rockchip,rk3588-sys-grf", "syscon"; reg = <0x0 0xfd58c000 0x0 0x1000>; @@ -407,6 +453,66 @@ reg = <0x0 0xfd5b0000 0x0 0x1000>; };
+ pipe_phy0_grf: syscon@fd5bc000 { + compatible = "rockchip,rk3588-pipe-phy-grf", "syscon"; + reg = <0x0 0xfd5bc000 0x0 0x100>; + }; + + pipe_phy2_grf: syscon@fd5c4000 { + compatible = "rockchip,rk3588-pipe-phy-grf", "syscon"; + reg = <0x0 0xfd5c4000 0x0 0x100>; + }; + + usb2phy2_grf: syscon@fd5d8000 { + compatible = "rockchip,rk3588-usb2phy-grf", "syscon", "simple-mfd"; + reg = <0x0 0xfd5d8000 0x0 0x4000>; + #address-cells = <1>; + #size-cells = <1>; + + u2phy2: usb2-phy@8000 { + compatible = "rockchip,rk3588-usb2phy"; + reg = <0x8000 0x10>; + interrupts = <GIC_SPI 391 IRQ_TYPE_LEVEL_HIGH 0>; + resets = <&cru SRST_OTGPHY_U2_0>, <&cru SRST_P_USB2PHY_U2_0_GRF0>; + reset-names = "phy", "apb"; + clocks = <&cru CLK_USB2PHY_HDPTXRXPHY_REF>; + clock-names = "phyclk"; + clock-output-names = "usb480m_phy2"; + #clock-cells = <0>; + status = "disabled"; + + u2phy2_host: host-port { + #phy-cells = <0>; + status = "disabled"; + }; + }; + }; + + usb2phy3_grf: syscon@fd5dc000 { + compatible = "rockchip,rk3588-usb2phy-grf", "syscon", "simple-mfd"; + reg = <0x0 0xfd5dc000 0x0 0x4000>; + #address-cells = <1>; + #size-cells = <1>; + + u2phy3: usb2-phy@c000 { + compatible = "rockchip,rk3588-usb2phy"; + reg = <0xc000 0x10>; + interrupts = <GIC_SPI 392 IRQ_TYPE_LEVEL_HIGH 0>; + resets = <&cru SRST_OTGPHY_U2_1>, <&cru SRST_P_USB2PHY_U2_1_GRF0>; + reset-names = "phy", "apb"; + clocks = <&cru CLK_USB2PHY_HDPTXRXPHY_REF>; + clock-names = "phyclk"; + clock-output-names = "usb480m_phy3"; + #clock-cells = <0>; + status = "disabled"; + + u2phy3_host: host-port { + #phy-cells = <0>; + status = "disabled"; + }; + }; + }; + ioc: syscon@fd5f0000 { compatible = "rockchip,rk3588-ioc", "syscon"; reg = <0x0 0xfd5f0000 0x0 0x10000>; @@ -830,6 +936,57 @@ }; };
+ i2s4_8ch: i2s@fddc0000 { + compatible = "rockchip,rk3588-i2s-tdm"; + reg = <0x0 0xfddc0000 0x0 0x1000>; + interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru MCLK_I2S4_8CH_TX>, <&cru MCLK_I2S4_8CH_TX>, <&cru HCLK_I2S4_8CH>; + clock-names = "mclk_tx", "mclk_rx", "hclk"; + assigned-clocks = <&cru CLK_I2S4_8CH_TX_SRC>; + assigned-clock-parents = <&cru PLL_AUPLL>; + dmas = <&dmac2 0>; + dma-names = "tx"; + power-domains = <&power RK3588_PD_VO0>; + resets = <&cru SRST_M_I2S4_8CH_TX>; + reset-names = "tx-m"; + #sound-dai-cells = <0>; + status = "disabled"; + }; + + i2s5_8ch: i2s@fddf0000 { + compatible = "rockchip,rk3588-i2s-tdm"; + reg = <0x0 0xfddf0000 0x0 0x1000>; + interrupts = <GIC_SPI 185 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru MCLK_I2S5_8CH_TX>, <&cru MCLK_I2S5_8CH_TX>, <&cru HCLK_I2S5_8CH>; + clock-names = "mclk_tx", "mclk_rx", "hclk"; + assigned-clocks = <&cru CLK_I2S5_8CH_TX_SRC>; + assigned-clock-parents = <&cru PLL_AUPLL>; + dmas = <&dmac2 2>; + dma-names = "tx"; + power-domains = <&power RK3588_PD_VO1>; + resets = <&cru SRST_M_I2S5_8CH_TX>; + reset-names = "tx-m"; + #sound-dai-cells = <0>; + status = "disabled"; + }; + + i2s9_8ch: i2s@fddfc000 { + compatible = "rockchip,rk3588-i2s-tdm"; + reg = <0x0 0xfddfc000 0x0 0x1000>; + interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru MCLK_I2S9_8CH_RX>, <&cru MCLK_I2S9_8CH_RX>, <&cru HCLK_I2S9_8CH>; + clock-names = "mclk_tx", "mclk_rx", "hclk"; + assigned-clocks = <&cru CLK_I2S9_8CH_RX_SRC>; + assigned-clock-parents = <&cru PLL_AUPLL>; + dmas = <&dmac2 23>; + dma-names = "rx"; + power-domains = <&power RK3588_PD_VO1>; + resets = <&cru SRST_M_I2S9_8CH_RX>; + reset-names = "rx-m"; + #sound-dai-cells = <0>; + status = "disabled"; + }; + qos_gpu_m0: qos@fdf35000 { compatible = "rockchip,rk3588-qos", "syscon"; reg = <0x0 0xfdf35000 0x0 0x20>; @@ -1070,6 +1227,108 @@ reg = <0x0 0xfdf82200 0x0 0x20>; };
+ pcie2x1l1: pcie@fe180000 { + compatible = "rockchip,rk3588-pcie", "rockchip,rk3568-pcie"; + bus-range = <0x30 0x3f>; + clocks = <&cru ACLK_PCIE_1L1_MSTR>, <&cru ACLK_PCIE_1L1_SLV>, + <&cru ACLK_PCIE_1L1_DBI>, <&cru PCLK_PCIE_1L1>, + <&cru CLK_PCIE_AUX3>, <&cru CLK_PCIE1L1_PIPE>; + clock-names = "aclk_mst", "aclk_slv", + "aclk_dbi", "pclk", + "aux", "pipe"; + device_type = "pci"; + interrupts = <GIC_SPI 248 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 247 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 245 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 244 IRQ_TYPE_LEVEL_HIGH 0>; + interrupt-names = "sys", "pmc", "msg", "legacy", "err"; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 7>; + interrupt-map = <0 0 0 1 &pcie2x1l1_intc 0>, + <0 0 0 2 &pcie2x1l1_intc 1>, + <0 0 0 3 &pcie2x1l1_intc 2>, + <0 0 0 4 &pcie2x1l1_intc 3>; + linux,pci-domain = <3>; + max-link-speed = <2>; + msi-map = <0x3000 &its0 0x3000 0x1000>; + num-lanes = <1>; + phys = <&combphy2_psu PHY_TYPE_PCIE>; + phy-names = "pcie-phy"; + power-domains = <&power RK3588_PD_PCIE>; + ranges = <0x01000000 0x0 0xf3100000 0x0 0xf3100000 0x0 0x00100000>, + <0x02000000 0x0 0xf3200000 0x0 0xf3200000 0x0 0x00e00000>, + <0x03000000 0x0 0x40000000 0x9 0xc0000000 0x0 0x40000000>; + reg = <0xa 0x40c00000 0x0 0x00400000>, + <0x0 0xfe180000 0x0 0x00010000>, + <0x0 0xf3000000 0x0 0x00100000>; + reg-names = "dbi", "apb", "config"; + resets = <&cru SRST_PCIE3_POWER_UP>, <&cru SRST_P_PCIE3>; + reset-names = "pwr", "pipe"; + #address-cells = <3>; + #size-cells = <2>; + status = "disabled"; + + pcie2x1l1_intc: legacy-interrupt-controller { + interrupt-controller; + #address-cells = <0>; + #interrupt-cells = <1>; + interrupt-parent = <&gic>; + interrupts = <GIC_SPI 245 IRQ_TYPE_EDGE_RISING 0>; + }; + }; + + pcie2x1l2: pcie@fe190000 { + compatible = "rockchip,rk3588-pcie", "rockchip,rk3568-pcie"; + bus-range = <0x40 0x4f>; + clocks = <&cru ACLK_PCIE_1L2_MSTR>, <&cru ACLK_PCIE_1L2_SLV>, + <&cru ACLK_PCIE_1L2_DBI>, <&cru PCLK_PCIE_1L2>, + <&cru CLK_PCIE_AUX4>, <&cru CLK_PCIE1L2_PIPE>; + clock-names = "aclk_mst", "aclk_slv", + "aclk_dbi", "pclk", + "aux", "pipe"; + device_type = "pci"; + interrupts = <GIC_SPI 253 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 252 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 251 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 250 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 249 IRQ_TYPE_LEVEL_HIGH 0>; + interrupt-names = "sys", "pmc", "msg", "legacy", "err"; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 7>; + interrupt-map = <0 0 0 1 &pcie2x1l2_intc 0>, + <0 0 0 2 &pcie2x1l2_intc 1>, + <0 0 0 3 &pcie2x1l2_intc 2>, + <0 0 0 4 &pcie2x1l2_intc 3>; + linux,pci-domain = <4>; + max-link-speed = <2>; + msi-map = <0x4000 &its0 0x4000 0x1000>; + num-lanes = <1>; + phys = <&combphy0_ps PHY_TYPE_PCIE>; + phy-names = "pcie-phy"; + power-domains = <&power RK3588_PD_PCIE>; + ranges = <0x01000000 0x0 0xf4100000 0x0 0xf4100000 0x0 0x00100000>, + <0x02000000 0x0 0xf4200000 0x0 0xf4200000 0x0 0x00e00000>, + <0x03000000 0x0 0x40000000 0xa 0x00000000 0x0 0x40000000>; + reg = <0xa 0x41000000 0x0 0x00400000>, + <0x0 0xfe190000 0x0 0x00010000>, + <0x0 0xf4000000 0x0 0x00100000>; + reg-names = "dbi", "apb", "config"; + resets = <&cru SRST_PCIE4_POWER_UP>, <&cru SRST_P_PCIE4>; + reset-names = "pwr", "pipe"; + #address-cells = <3>; + #size-cells = <2>; + status = "disabled"; + + pcie2x1l2_intc: legacy-interrupt-controller { + interrupt-controller; + #address-cells = <0>; + #interrupt-cells = <1>; + interrupt-parent = <&gic>; + interrupts = <GIC_SPI 250 IRQ_TYPE_EDGE_RISING 0>; + }; + }; + gmac1: ethernet@fe1c0000 { compatible = "rockchip,rk3588-gmac", "snps,dwmac-4.20a"; reg = <0x0 0xfe1c0000 0x0 0x10000>; @@ -1119,6 +1378,52 @@ }; };
+ sata0: sata@fe210000 { + compatible = "rockchip,rk3588-dwc-ahci", "snps,dwc-ahci"; + reg = <0 0xfe210000 0 0x1000>; + interrupts = <GIC_SPI 273 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru ACLK_SATA0>, <&cru CLK_PMALIVE0>, + <&cru CLK_RXOOB0>, <&cru CLK_PIPEPHY0_REF>, + <&cru CLK_PIPEPHY0_PIPE_ASIC_G>; + clock-names = "sata", "pmalive", "rxoob", "ref", "asic"; + ports-implemented = <0x1>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + + sata-port@0 { + reg = <0>; + hba-port-cap = <HBA_PORT_FBSCP>; + phys = <&combphy0_ps PHY_TYPE_SATA>; + phy-names = "sata-phy"; + snps,rx-ts-max = <32>; + snps,tx-ts-max = <32>; + }; + }; + + sata2: sata@fe230000 { + compatible = "rockchip,rk3588-dwc-ahci", "snps,dwc-ahci"; + reg = <0 0xfe230000 0 0x1000>; + interrupts = <GIC_SPI 275 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru ACLK_SATA2>, <&cru CLK_PMALIVE2>, + <&cru CLK_RXOOB2>, <&cru CLK_PIPEPHY2_REF>, + <&cru CLK_PIPEPHY2_PIPE_ASIC_G>; + clock-names = "sata", "pmalive", "rxoob", "ref", "asic"; + ports-implemented = <0x1>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + + sata-port@0 { + reg = <0>; + hba-port-cap = <HBA_PORT_FBSCP>; + phys = <&combphy2_psu PHY_TYPE_SATA>; + phy-names = "sata-phy"; + snps,rx-ts-max = <32>; + snps,tx-ts-max = <32>; + }; + }; + sdmmc: mmc@fe2c0000 { compatible = "rockchip,rk3588-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x0 0xfe2c0000 0x0 0x4000>; @@ -1134,6 +1439,21 @@ status = "disabled"; };
+ sdio: mmc@fe2d0000 { + compatible = "rockchip,rk3588-dw-mshc", "rockchip,rk3288-dw-mshc"; + reg = <0x00 0xfe2d0000 0x00 0x4000>; + interrupts = <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru HCLK_SDIO>, <&cru CCLK_SRC_SDIO>, + <&cru SCLK_SDIO_DRV>, <&cru SCLK_SDIO_SAMPLE>; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; + fifo-depth = <0x100>; + max-frequency = <200000000>; + pinctrl-names = "default"; + pinctrl-0 = <&sdiom1_pins>; + power-domains = <&power RK3588_PD_SDIO>; + status = "disabled"; + }; + sdhci: mmc@fe2e0000 { compatible = "rockchip,rk3588-dwcmshc"; reg = <0x0 0xfe2e0000 0x0 0x10000>; @@ -1145,6 +1465,9 @@ <&cru TMCLK_EMMC>; clock-names = "core", "bus", "axi", "block", "timer"; max-frequency = <200000000>; + pinctrl-0 = <&emmc_rstnout>, <&emmc_bus8>, <&emmc_clk>, + <&emmc_cmd>, <&emmc_data_strobe>; + pinctrl-names = "default"; resets = <&cru SRST_C_EMMC>, <&cru SRST_H_EMMC>, <&cru SRST_A_EMMC>, <&cru SRST_B_EMMC>, <&cru SRST_T_EMMC>; @@ -1742,6 +2065,18 @@ status = "disabled"; };
+ saradc: adc@fec10000 { + compatible = "rockchip,rk3588-saradc"; + reg = <0x0 0xfec10000 0x0 0x10000>; + interrupts = <GIC_SPI 398 IRQ_TYPE_LEVEL_HIGH 0>; + #io-channel-cells = <1>; + clocks = <&cru CLK_SARADC>, <&cru PCLK_SARADC>; + clock-names = "saradc", "apb_pclk"; + resets = <&cru SRST_P_SARADC>; + reset-names = "saradc-apb"; + status = "disabled"; + }; + i2c6: i2c@fec80000 { compatible = "rockchip,rk3588-i2c", "rockchip,rk3399-i2c"; reg = <0x0 0xfec80000 0x0 0x1000>; @@ -1862,6 +2197,38 @@ #dma-cells = <1>; };
+ combphy0_ps: phy@fee00000 { + compatible = "rockchip,rk3588-naneng-combphy"; + reg = <0x0 0xfee00000 0x0 0x100>; + clocks = <&cru CLK_REF_PIPE_PHY0>, <&cru PCLK_PCIE_COMBO_PIPE_PHY0>, + <&cru PCLK_PHP_ROOT>; + clock-names = "ref", "apb", "pipe"; + assigned-clocks = <&cru CLK_REF_PIPE_PHY0>; + assigned-clock-rates = <100000000>; + #phy-cells = <1>; + resets = <&cru SRST_REF_PIPE_PHY0>, <&cru SRST_P_PCIE2_PHY0>; + reset-names = "phy", "apb"; + rockchip,pipe-grf = <&php_grf>; + rockchip,pipe-phy-grf = <&pipe_phy0_grf>; + status = "disabled"; + }; + + combphy2_psu: phy@fee20000 { + compatible = "rockchip,rk3588-naneng-combphy"; + reg = <0x0 0xfee20000 0x0 0x100>; + clocks = <&cru CLK_REF_PIPE_PHY2>, <&cru PCLK_PCIE_COMBO_PIPE_PHY2>, + <&cru PCLK_PHP_ROOT>; + clock-names = "ref", "apb", "pipe"; + assigned-clocks = <&cru CLK_REF_PIPE_PHY2>; + assigned-clock-rates = <100000000>; + #phy-cells = <1>; + resets = <&cru SRST_REF_PIPE_PHY2>, <&cru SRST_P_PCIE2_PHY2>; + reset-names = "phy", "apb"; + rockchip,pipe-grf = <&php_grf>; + rockchip,pipe-phy-grf = <&pipe_phy2_grf>; + status = "disabled"; + }; + system_sram2: sram@ff001000 { compatible = "mmio-sram"; reg = <0x0 0xff001000 0x0 0xef000>; diff --git a/include/dt-bindings/ata/ahci.h b/include/dt-bindings/ata/ahci.h new file mode 100644 index 0000000000..b3f3b7cf9a --- /dev/null +++ b/include/dt-bindings/ata/ahci.h @@ -0,0 +1,20 @@ +/* SPDX-License-Identifier: GPL-2.0-only OR BSD-2-Clause */ +/* + * This header provides constants for most AHCI bindings. + */ + +#ifndef _DT_BINDINGS_ATA_AHCI_H +#define _DT_BINDINGS_ATA_AHCI_H + +/* Host Bus Adapter generic platform capabilities */ +#define HBA_SSS (1 << 27) +#define HBA_SMPS (1 << 28) + +/* Host Bus Adapter port-specific platform capabilities */ +#define HBA_PORT_HPCP (1 << 18) +#define HBA_PORT_MPSP (1 << 19) +#define HBA_PORT_CPD (1 << 20) +#define HBA_PORT_ESP (1 << 21) +#define HBA_PORT_FBSCP (1 << 22) + +#endif
this patch adds support for PCIe3 (M.2 M key) and enables NVMe.
=> pci BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ 00.00.00 0x1d87 0x3588 Bridge device 0x04 01.00.00 0x10ec 0x8125 Network controller 0x00 02.00.00 0x1d87 0x3588 Bridge device 0x04 03.00.00 0x1179 0x011a Mass storage controller 0x08 => nvme scan => nvme info Device 0: Vendor: 0x1179 Rev: AGHA4101 Prod: 79CA20WPKRYN Type: Hard Disk Capacity: 488386.3 MB = 476.9 GB (1000215216 x 512)
this patch depends: - "rockchip: rk3568: Fix use of PCIe bifurcation" [1] [1] https://patchwork.ozlabs.org/project/uboot/list/?series=366997 --- arch/arm/dts/rk3588-rock-5b-u-boot.dtsi | 33 +++++++++++++++++++++++++ configs/rock5b-rk3588_defconfig | 1 + 2 files changed, 34 insertions(+)
diff --git a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi index 1b2fcbb0bb..c790894170 100644 --- a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi +++ b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi @@ -27,6 +27,19 @@ regulator-max-microvolt = <12000000>; };
+ vcc3v3_pcie30: vcc3v3-pcie30-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_pcie30"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + enable-active-high; + gpios = <&gpio1 RK_PA4 GPIO_ACTIVE_HIGH>; + startup-delay-us = <5000>; + vin-supply = <&vcc5v0_sys>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie3_vcc3v3_en>; + }; + vcc5v0_usbdcin: vcc5v0-usbdcin { compatible = "regulator-fixed"; regulator-name = "vcc5v0_usbdcin"; @@ -87,6 +100,18 @@ status = "okay"; };
+&pcie30phy { + status = "okay"; +}; + +&pcie3x4 { + reset-gpios = <&gpio4 RK_PB6 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_pcie30>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie3_rst>; + status = "okay"; +}; + &pinctrl { pcie { pcie_reset_h: pcie-reset-h { @@ -97,6 +122,14 @@ rockchip,pins = <3 RK_PC7 4 &pcfg_pull_none>, <3 RK_PD0 4 &pcfg_pull_none>; }; + + pcie3_rst: pcie3-rst { + rockchip,pins = <4 RK_PB6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + pcie3_vcc3v3_en: pcie3-vcc3v3-en { + rockchip,pins = <1 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; + }; };
usb { diff --git a/configs/rock5b-rk3588_defconfig b/configs/rock5b-rk3588_defconfig index 3fa65cbf9b..50551c70f2 100644 --- a/configs/rock5b-rk3588_defconfig +++ b/configs/rock5b-rk3588_defconfig @@ -81,6 +81,7 @@ CONFIG_SPI_FLASH_XTX=y CONFIG_ETH_DESIGNWARE=y CONFIG_RTL8169=y CONFIG_GMAC_ROCKCHIP=y +CONFIG_NVME_PCI=y CONFIG_PCIE_DW_ROCKCHIP=y CONFIG_PHY_ROCKCHIP_INNO_USB2=y CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y
FUKAUMI Naoki
