[U-Boot] [PATCH v3 07/10] usb: dwc2: force to host mode if HNP/SRP not support
In current code, after running the command of "usb start", the controller will keep in otg mode and can't switch to host mode if not support SNP/SRP capability. So add the property of "hnp-srp-disable" in the DTS to config the contrller work in force mode of host.
Signed-off-by: Meng Dongyang daniel.meng@rock-chips.com ---
Changes in v3: - revert change of macro definition in dwc2 driver - support host mode without HNP/SRP capability through DTS
Changes in v2: - Splited from patch [07/08] of v1
drivers/usb/host/dwc2.c | 13 ++++++++++++- 1 file changed, 12 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/host/dwc2.c b/drivers/usb/host/dwc2.c index 0e5df15..73a0290 100644 --- a/drivers/usb/host/dwc2.c +++ b/drivers/usb/host/dwc2.c @@ -43,6 +43,7 @@ struct dwc2_priv { struct dwc2_core_regs *regs; int root_hub_devnum; bool ext_vbus; + bool hnp_srp_disable; bool oc_disable; };
@@ -394,6 +395,9 @@ static void dwc_otg_core_init(struct dwc2_priv *priv) usbcfg |= DWC2_GUSBCFG_ULPI_CLK_SUS_M; } #endif + if (priv->hnp_srp_disable) + usbcfg |= DWC2_GUSBCFG_FORCEHOSTMODE; + writel(usbcfg, ®s->gusbcfg);
/* Program the GAHBCFG Register. */ @@ -423,7 +427,9 @@ static void dwc_otg_core_init(struct dwc2_priv *priv) writel(ahbcfg, ®s->gahbcfg);
/* Program the GUSBCFG register for HNP/SRP. */ - setbits_le32(®s->gusbcfg, DWC2_GUSBCFG_HNPCAP | DWC2_GUSBCFG_SRPCAP); + if (!priv->hnp_srp_disable) + setbits_le32(®s->gusbcfg, + DWC2_GUSBCFG_HNPCAP | DWC2_GUSBCFG_SRPCAP);
#ifdef CONFIG_DWC2_IC_USB_CAP setbits_le32(®s->gusbcfg, DWC2_GUSBCFG_IC_USB_CAP); @@ -1244,6 +1250,11 @@ static int dwc2_usb_ofdata_to_platdata(struct udevice *dev) if (prop) priv->oc_disable = true;
+ prop = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), + "hnp-srp-disable", NULL); + if (prop) + priv->hnp_srp_disable = true; + return 0; }
Changes in v3:
Changes in v2:
- bool hnp_srp_disable; bool oc_disable;
- if (!priv->hnp_srp_disable)
I guess you can prepare the mask and then do setbits...() once ? Looks good otherwise.
- prop = fdt_getprop(gd->fdt_blob, dev_of_offset(dev),
- if (prop)
Changes in v3:
Changes in v2:
- bool hnp_srp_disable; bool oc_disable; };
I have attempted to move this config to the last writel of usbcfg and checked on our platform. Do you think it is better? Prepare a mask maybe looks a little strange since it only use with writel() and the other setbits..() in this function use macro definition directly.
- if (prop)
- return 0; }
Changes in v3:
Changes in v2:
- bool hnp_srp_disable; bool oc_disable; }; @@ -394,6 +395,9 @@ static void dwc_otg_core_init(struct dwc2_priv
- if (priv->hnp_srp_disable)
writel(usbcfg, ®s->gusbcfg); /* Program the GAHBCFG Register. */
@@ -423,7 +427,9 @@ static void dwc_otg_core_init(struct dwc2_priv *priv) writel(ahbcfg, ®s->gahbcfg); /* Program the GUSBCFG register for HNP/SRP. */
There is no last writel() call in this function, so no. There're only setbits() call and this can be reduced to a single setbits() call at the end. Note that setbits...() is a RMW call.
Not sure I understand this concern. You need to set conditional bits in the mask.
ie. u32 mask = FOO;
if (bar) mask |= BAZ;
mask |= QUUX; setbits...(reg, mask);
- if (prop)
}return 0;
Meng Dongyang
