[U-Boot] [PATCH] Merge and reformat boards.cfg and MAINTAINERS
Merge information from MAINTAINERS into boards.cfg, remove MAINTAINERS and reformat boards.cfg.
From now on, any modifications to boards.cfg must strictly
adhere to the formatting and ordering described in the file header.
The reformatting script tools/reformat.py is provided to facilitate keeping boards.cfg formatted and ordered.
Signed-off-by: Albert ARIBAUD albert.u.boot@aribaud.net --- This patch is a squash of the RFC v2 patch previously posted, plus removal of the tools/merge.py and MAINTAINERS files which were overlooked so far.
MAINTAINERS | 1391 ---------------------------- MAKEALL | 20 +- Makefile | 2 +- boards.cfg | 2312 +++++++++++++++++++++++------------------------ mkconfig | 31 +- tools/buildman/board.py | 2 +- tools/reformat.py | 132 +++ 7 files changed, 1316 insertions(+), 2574 deletions(-) delete mode 100644 MAINTAINERS create mode 100755 tools/reformat.py
diff --git a/MAINTAINERS b/MAINTAINERS deleted file mode 100644 index 081cf96..0000000 --- a/MAINTAINERS +++ /dev/null @@ -1,1391 +0,0 @@ -######################################################################### -# # -# Regular Maintainers for U-Boot board support: # -# # -# For any board without permanent maintainer, please contact # -# Wolfgang Denk wd@denx.de # -# and Cc: the u-boot@lists.denx.de mailing list. # -# # -# Note: lists sorted by Maintainer Name # -# Note: These are the maintainers for specific *boards*. The # -# custodians for general architectures and subsystems can # -# be found here -- http://www.denx.de/wiki/U-Boot/Custodians # -# # -######################################################################### - - -######################################################################### -# PowerPC Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Poonam Aggrwal poonam.aggrwal@freescale.com - - P2020RDB P2020 - - BSC9131RDB BSC9131 - -Naveen Burmi NaveenBurmi@freescale.com - - BSC9132QDS BSC9132 - -Greg Allen gallen@arlut.utexas.edu - - UTX8245 MPC8245 - -Pantelis Antoniou panto@intracom.gr - - NETVIA MPC8xx - -Reinhard Arlt reinhard.arlt@esd-electronics.com - - cpci5200 MPC5200 - mecp5123 MPC5121 - mecp5200 MPC5200 - pf5200 MPC5200 - - caddy2 MPC8349 - vme8349 MPC8349 - - CPCI750 PPC750FX/GX - -Peter Barada peter.barada@logicpd.com - - omap3_logic ARM ARMV7 (Logic OMAP35xx/DM37xx) - -Yuli Barcohen yuli@arabellasw.com - - Adder MPC87x/MPC852T - ep8248 MPC8248 - ISPAN MPC8260 - MPC8260ADS MPC826x/MPC827x/MPC8280 - Rattler MPC8248 - ZPC1900 MPC8265 - -Michael Barkowski michael.barkowski@freescale.com - - MPC8323ERDB MPC8323 - -Jerry Van Baren gerald.vanbaren@smiths-aerospace.com - - sacsng MPC8260 - -Oliver Brown obrown@adventnetworks.com - - gw8260 MPC8260 - -Holger Brunck holger.brunck@keymile.com - - kmeter1 MPC8360 - kmcoge5ne MPC8360 - mgcoge MPC8247 - mgcoge3ne MPC8247 - suvd3 MPC8321 - tuge1 MPC8321 - tuxx1 MPC8321 - -Conn Clark clark@esteem.com - - ESTEEM192E MPC8xx - -Jason Cooper u-boot@lakedaemon.net - - dreamplug ARM926EJS (Kirkwood SoC) - -Joe D'Abbraccio ljd015@freescale.com - - MPC837xERDB MPC837x - -Kári Davíðsson kd@flaga.is - - FLAGADM MPC823 - -Torsten Demke torsten.demke@fci.com - - eXalion MPC824x - -Wolfgang Denk wd@denx.de - - IceCube_5200 MPC5200 - - ARIA MPC5121e - - FPS850L MPC850 - FPS860L MPC860 - ICU862 MPC862 - IP860 MPC860 - IVML24 MPC860 - IVML24_128 MPC860 - IVML24_256 MPC860 - IVMS8 MPC860 - IVMS8_128 MPC860 - IVMS8_256 MPC860 - LWMON MPC823 - R360MPI MPC823 - RRvision MPC823 - SM850 MPC850 - SPD823TS MPC823 - TQM823L MPC823 - TQM823L_LCD MPC823 - TQM850L MPC850 - TQM855L MPC855 - TQM860L MPC860 - TQM860L_FEC MPC860 - hermes MPC860 - lwmon MPC823 - - CU824 MPC8240 - Sandpoint8240 MPC8240 - - ATC MPC8250 - PM825 MPC8250 - - TQM8255 MPC8255 - - CPU86 MPC8260 - PM826 MPC8260 - TQM8260 MPC8260 - - P3G4 MPC7410 - -Phil Edworthy phil.edworthy@renesas.com - - rsk7264 SH7264 - -egnite GmbH info@egnite.de - - ethernut5 ARM926EJS (AT91SAM9XE SoC) - -Dirk Eibach eibach@gdsys.de - - controlcenterd P1022 - devconcenter PPC460EX - dlvision PPC405EP - dlvision-10g PPC405EP - gdppc440etx PPC440EP/GR - intip PPC460EX - io PPC405EP - io64 PPC405EX - iocon PPC405EP - neo PPC405EP - -Dave Ellis DGE@sixnetio.com - - SXNI855T MPC8xx - -Thomas Frieden ThomasF@hyperion-entertainment.com - - AmigaOneG3SE MPC7xx - -Matthias Fuchs matthias.fuchs@esd-electronics.com - - APC405 PPC405GP - AR405 PPC405GP - ASH405 PPC405EP - CANBT PPC405CR - CPCI2DP PPC405GP - CPCI405 PPC405GP - CPCI4052 PPC405GP - CPCI405AB PPC405GP - CPCI405DT PPC405GP - CPCIISER4 PPC405GP - DP405 PPC405EP - DU405 PPC405GP - DU440 PPC440EPx - G2000 PPC405EP - HH405 PPC405EP - HUB405 PPC405EP - OCRTC PPC405GP - ORSG PPC405GP - PCI405 PPC405GP - PLU405 PPC405EP - PMC405 PPC405GP - PMC405DE PPC405EP - PMC440 PPC440EPx - VOH405 PPC405EP - VOM405 PPC405EP - WUH405 PPC405EP - CMS700 PPC405EP - -Siddarth Gore gores@marvell.com - - guruplug ARM926EJS (Kirkwood SoC) - -Paul Gortmaker paul.gortmaker@windriver.com - - sbc8349 MPC8349 - sbc8548 MPC8548 - sbc8641d MPC8641D - -Frank Gottschling fgottschling@eltec.de - - MHPC MPC8xx - -Wolfgang Grandegger wg@denx.de - - ipek01 MPC5200 - - PN62 MPC8240 - IPHASE4539 MPC8260 - -Anatolij Gustschin agust@denx.de - - ac14xx MPC5121e - O2D MPC5200 - O2D300 MPC5200 - O2DNT2 MPC5200 - O2I MPC5200 - O2MNT MPC5200 - O3DNT MPC5200 - -Rob Herring rob.herring@calxeda.com - - highbank highbank - -Klaus Heydeck heydeck@kieback-peter.de - - KUP4K MPC855 - KUP4X MPC859 - -Gabriel Huau contact@huau-gabriel.fr - - mini2440 s3c2440 - -Gary Jennejohn garyj@denx.de - - quad100hd PPC405EP - -Murray Jensen Murray.Jensen@csiro.au - - cogent_mpc8xx MPC8xx - - cogent_mpc8260 MPC8260 - hymod MPC8260 - -Larry Johnson lrj@acm.org - - korat PPC440EPx - -Feng Kan fkan@amcc.com - - redwood PPC4xx - -Brad Kemp Brad.Kemp@seranoa.com - - ppmc8260 MPC8260 - -Sangmoon Kim dogoil@etinsys.com - - debris MPC8245 - KVME080 MPC8245 - -The LEOX team team@leox.org - - ELPT860 MPC860T - -Guennadi Liakhovetski g.liakhovetski@gmx.de - - linkstation MPC8241 - -Dave Liu daveliu@freescale.com - - MPC8315ERDB MPC8315 - MPC832XEMDS MPC832x - MPC8360EMDS MPC8360 - MPC837XEMDS MPC837x - -Nye Liu nyet@zumanetworks.com - - ZUMA MPC7xx_74xx - -Kumar Gala kumar.gala@freescale.com - - MPC8540ADS MPC8540 - MPC8560ADS MPC8560 - MPC8541CDS MPC8541 - MPC8555CDS MPC8555 - - MPC8641HPCN MPC8641D - -Ron Madrid info@sheldoninst.com - - SIMPC8313 MPC8313 - -Dan Malek dan@embeddedalley.com - - stxgp3 MPC85xx - stxssa MPC85xx - stxxtc MPC8xx - -Ryan Mallon ryan@bluewatersys.com - - snapper9260 ARM926EJS (AT91SAM9260 SoC) - snapper9g20 ARM926EJS (AT91SAM9G20 SoC) - -Andrea "llandre" Marson andrea.marson@dave-tech.it - - PPChameleonEVB PPC405EP - -Tirumala Marri tmarri@apm.com - - bluestone APM821XX - -Reinhard Meyer reinhard.meyer@emk-elektronik.de - - TOP860 MPC860T - TOP5200 MPC5200 - TOP9000 ARM926EJS (AT91SAM9xxx SoC) - -Kyle Moffett Kyle.D.Moffett@boeing.com - - HWW1U1A P2020 - -Tolunay Orkun torkun@nextio.com - - csb272 PPC405GP - csb472 PPC405GP - -John Otken jotken@softadvances.com - - luan PPC440SP - taihu PPC405EP - -Keith Outwater Keith_Outwater@mvis.com - - GEN860T MPC860T - GEN860T_SC MPC860T - -Frank Panno fpanno@delphintech.com - - ep8260 MPC8260 - -Chan-Taek Park c-park@ti.com - - tnetv107x_evm tnetv107x - -Denis Peter d.peter@mpl.ch - - MIP405 PPC4xx - PIP405 PPC4xx - -Werner Pfister Pfister_Werner@intercontrol.de - digsy_mtc mpc5200 - digsy_mtc_rev5 mpc5200 - -Kim Phillips kim.phillips@freescale.com - - MPC8349EMDS MPC8349 - -Sergei Poselenov sposelenov@emcraft.com - - a4m072 MPC5200 - -Sudhakar Rajashekhara sudhakar.raj@ti.com - - da850evm ARM926EJS (DA850/OMAP-L138) - -Ricardo Ribalda ricardo.ribalda@uam.es - - ml507 PPC440x5 - v5fx30teval PPC440x5 - xilinx-ppc405-generic PPC405 - xilinx-ppc440-generic PPC440x5 - -Stefan Roese sr@denx.de - - a3m071 MPC5200 - a4m2k MPC5200 - - P3M7448 MPC7448 - - uc100 MPC857 - - acadia PPC405EZ - alpr PPC440GX - bamboo PPC440EP - bunbinga PPC405EP - canyonlands PPC460EX - ebony PPC440GP - glacier PPC460GT - haleakala PPC405EXr - icon PPC440SPe - katmai PPC440SPe - kilauea PPC405EX - lwmon5 PPC440EPx - makalu PPC405EX - ocotea PPC440GX - p3p440 PPC440GP - pcs440ep PPC440EP - rainier PPC440GRx - sequoia PPC440EPx - sycamore PPC405GPr - t3corp PPC460GT - taishan PPC440GX - walnut PPC405GP - yellowstone PPC440GR - yosemite PPC440EP - zeus PPC405EP - - P3M750 PPC750FX/GX/GL - -Yusdi Santoso yusdi_santoso@adaptec.com - - HIDDEN_DRAGON MPC8241/MPC8245 - -Travis Sawyer (travis.sawyer@sandburst.com> - - KAREF PPC440GX - METROBOX PPC440GX - -Georg Schardt schardt@team-ctech.de - - fx12mm PPC405 - -Heiko Schocher hs@denx.de - - cam_enc_4xx davinci/ARM926EJS - charon MPC5200 - ids8247 MPC8247 - jupiter MPC5200 - kmsupx5 MPC8321 - mucmc52 MPC5200 - muas3001 MPC8270 - municse MPC5200 - sc3 PPC405GP - uc101 MPC5200 - ve8313 MPC8313 - -Andre Schwarz andre.schwarz@matrix-vision.de - - mergerbox MPC8377 - mvbc_p MPC5200 - mvblm7 MPC8343 - mvsmr MPC5200 - -Jon Smirl jonsmirl@gmail.com - - pcm030 MPC5200 - -Ira W. Snyder iws@ovro.caltech.edu - - P2020COME P2020 - -Timur Tabi timur@freescale.com - - MPC8349E-mITX MPC8349 - MPC8349E-mITX-GP MPC8349 - P1022DS P1022 - -Erik Theisen etheisen@mindspring.com - - W7OLMC PPC4xx - W7OLMG PPC4xx - -Jim Thompson jim@musenki.com - - MUSENKI MPC8245/8241 - Sandpoint8245 MPC8245 - -Rune Torgersen runet@innovsys.com - - MPC8266ADS MPC8266 - -Peter Tyser ptyser@xes-inc.com - - xpedite1000 PPC440GX - xpedite5170 MPC8640 - xpedite5200 MPC8548 - xpedite5370 MPC8572 - xpedite5500 P2020 - -David Updegraff dave@cray.com - - CRAYL1 PPC4xx - -Anton Vorontsov avorontsov@ru.mvista.com - - MPC8360ERDK MPC8360 - -Josef Wagner Wagner@Microsys.de - - CPC45 MPC8245 - PM520 MPC5200 - -Michael Weiss michael.weiss@ifm.com - - PDM360NG MPC5121e - -Stephen Williams steve@icarus.com - - JSE PPC405GPr - -Ilya Yanok yanok@emcraft.com - - mpc8308_p1m MPC8308 - MPC8308RDB MPC8308 - -Roy Zang tie-fei.zang@freescale.com - - mpc7448hpc2 MPC7448 - P1023RDS P1023 - -John Zhan zhanz@sinovee.com - - svm_sc8xx MPC8xx - -Detlev Zundel dzu@denx.de - - inka4x0 MPC5200 - -------------------------------------------------------------------------- - -Unknown / orphaned boards: - - ADS860 MPC8xx - FADS823 MPC8xx - FADS850SAR MPC8xx - FADS860T MPC8xx - GENIETV MPC8xx - MBX MPC8xx - MBX860T MPC8xx - NX823 MPC8xx - RPXClassic MPC8xx - RPXlite MPC8xx - - MOUSSE MPC824x - - RPXsuper MPC8260 - rsdproto MPC8260 - - EVB64260 MPC7xx_74xx - EVB64260_750CX MPC750CX [Eran Man eran@nbase.co.il] - - versatile ARM926EJ-S - -######################################################################### -# ARM Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Albert ARIBAUD albert.u.boot@aribaud.net - - edminiv2 ARM926EJS (Orion5x SoC) - -Raphael Assenat raph@8d.com - - eco5pk ARM ARMV7 (AM35x SoC) - -Stefano Babic sbabic@denx.de - - ea20 davinci - flea3 i.MX35 - mt_ventoux omap3 - mx35pdk i.MX35 - mx51evk i.MX51 - polaris xscale/pxa - trizepsiv xscale/pxa - twister omap3 - vision2 i.MX51 - woodburn i.MX35 - -Lukasz Dalek luk0104@gmail.com - - h2200 xscale/pxa - -Jason Liu r64343@freescale.com - - mx53evk i.MX53 - mx53loco i.MX53 - mx6qarm2 i.MX6Q - mx6qsabrelite i.MX6Q - -Enric Balletbo i Serra eballetbo@iseebcn.com - - igep0020 ARM ARMV7 (OMAP3xx SoC) - igep0030 ARM ARMV7 (OMAP3xx SoC) - igep0032 ARM ARMV7 (OMAP3xx SoC) - igep0033 ARM ARMV7 (AM33xx Soc) - -Eric Benard eric@eukrea.com - - cpuat91 ARM920T - cpu9260 ARM926EJS (AT91SAM9260 SoC) - cpu9G20 ARM926EJS (AT91SAM9G20 SoC) - -Ajay Bhargav ajay.bhargav@einfochips.com - - gplugd ARM926EJS (ARMADA100 88AP168 SoC) - -Rishi Bhattacharya rishi@ti.com - - omap5912osk ARM926EJS - -Andreas Bießmann andreas.devel@gmail.com - - at91rm9200ek at91rm9200 - -Cliff Brake cliff.brake@gmail.com - - pxa255_idp xscale/pxa - -Rick Bronson rick@efn.org - - AT91RM9200DK at91rm9200 - -Luca Ceresoli luca.ceresoli@comelit.it - - dig297 ARM ARMV7 (OMAP3530 SoC) - -Po-Yu Chuang ratbert@faraday-tech.com - - a320evb FA526 (ARM920T-like) (a320 SoC) - -Eric Cooper ecc@cmu.edu - - dockstar ARM926EJS (Kirkwood SoC) - -Wolfgang Denk wd@denx.de - imx27lite i.MX27 - qong i.MX31 - -Mike Dunn mikedunn@newsguy.com - palmtreo680 pxa270 - -Kristoffer Ericson kristoffer.ericson@gmail.com - - jornada SA1110 - -Fabio Estevam fabio.estevam@freescale.com - - mx25pdk i.MX25 - mx28evk i.MX28 - mx31pdk i.MX31 - mx53ard i.MX53 - mx53smd i.MX53 - mx6sabresd i.MX6Q/DL - mx6qsabreauto i.MX6Q - wandboard i.MX6DL/S/Q - mx6slevk i.MX6SL - -Daniel Gorsulowski daniel.gorsulowski@esd.eu - - meesc ARM926EJS (AT91SAM9263 SoC) - otc570 ARM926EJS (AT91SAM9263 SoC) - -Bo Shenvoice.shen@atmel.com - at91sam9g10ek ARM926EJS (AT91SAM9G10 SoC) - at91sam9m10g45ek ARM926EJS (AT91SAM9G45 SoC) - -Simon Guinot simon.guinot@sequanux.org - - inetspace_v2 ARM926EJS (Kirkwood SoC) - netspace_v2 ARM926EJS (Kirkwood SoC) - netspace_max_v2 ARM926EJS (Kirkwood SoC) - net2big_v2 ARM926EJS (Kirkwood SoC) - -Igor Grinberg grinberg@compulab.co.il - - cm_t35 ARM ARMV7 (OMAP3xx Soc) - -Stefan Herbrechtsmeier stefan@code.herbrechtsmeier.net - - dns325 ARM926EJS (Kirkwood SoC) - -Lauri Hintsala lauri.hintsala@bluegiga.com - - apx4devkit i.MX28 - -Vaibhav Hiremath hvaibhav@ti.com - - am3517_evm ARM ARMV7 (AM35x SoC) - -Markus Hubig mhubig@imko.de - - STAMP9G20 ARM926EJS - -Grazvydas Ignotas notasas@gmail.com - - omap3_pandora ARM ARMV7 (OMAP3xx SoC) - -Ilko Iliev iliev@ronetix.at - - PM9261 AT91SAM9261 - PM9263 AT91SAM9263 - PM9G45 ARM926EJS (AT91SAM9G45 SoC) - -Michael Jones michael.jones@matrix-vision.de - - omap3_mvblx ARM ARMV7 (OMAP3xx SoC) - -Matthias Kaehlcke matthias@kaehlcke.net - edb9301 ARM920T (EP9301) - edb9302 ARM920T (EP9302) - edb9302a ARM920T (EP9302) - edb9307 ARM920T (EP9307) - edb9307a ARM920T (EP9307) - edb9312 ARM920T (EP9312) - edb9315 ARM920T (EP9315) - edb9315a ARM920T (EP9315) - -Nishant Kamat nskamat@ti.com - - omap1610h2 ARM926EJS - -Minkyu Kang mk7.kang@samsung.com - - SMDKC100 ARM ARMV7 (S5PC100 SoC) - s5p_goni ARM ARMV7 (S5PC110 SoC) - s5pc210_universal ARM ARMV7 (EXYNOS4210 SoC) - -Chander Kashyap k.chander@samsung.com - - origen ARM ARMV7 (EXYNOS4210 SoC) - SMDKV310 ARM ARMV7 (EXYNOS4210 SoC) - SMDK5250 ARM ARMV7 (EXYNOS5250 SoC) - -Lukasz Majewski l.majewski@samsung.com - - trats ARM ARMV7 (EXYNOS4210 SoC) - -Torsten Koschorrek koschorrek@synertronixx.de - scb9328 ARM920T (i.MXL) - -Sergey Kubushyn ksi@koi8.net - - DV-EVM ARM926EJS - SONATA ARM926EJS - SCHMOOGIE ARM926EJS - -Vipin Kumar vipin.kumar@st.com - - spear300 ARM926EJS (spear300 Soc) - spear310 ARM926EJS (spear310 Soc) - spear320 ARM926EJS (spear320 Soc) - spear600 ARM926EJS (spear600 Soc) - -Sergey Lapin slapin@ossfans.org - - afeb9260 ARM926EJS (AT91SAM9260 SoC) - -Valentin Longchamp valentin.longchamp@keymile.com - - km_kirkwood ARM926EJS (Kirkwood SoC) - kmnusa ARM926EJS (Kirkwood SoC) - mgcoge3un ARM926EJS (Kirkwood SoC) - kmcoge5un ARM926EJS (Kirkwood SoC) - portl2 ARM926EJS (Kirkwood SoC) - -Nishanth Menon nm@ti.com - - omap3_sdp3430 ARM ARMV7 (OMAP3xx SoC) - omap3_zoom1 ARM ARMV7 (OMAP3xx SoC) - -David Müller d.mueller@elsoft.ch - - smdk2410 ARM920T - VCMA9 ARM920T - -Eric Millbrandt emillbrandt@dekaresearch.com - - galaxy5200 mpc5200 - -Nagendra T S nagendra@mistralsolutions.com - - am3517_crane ARM ARMV7 (AM35x SoC) - -Dinh Nguyen dinguyen@altera.com -Chin Liang See clsee@altera.com - - socfpga socfpga_cyclone5 - -Sandeep Paulraj s-paulraj@ti.com - - davinci_dm355evm ARM926EJS - davinci_dm355leopard ARM926EJS - davinci_dm365evm ARM926EJS - davinci_dm6467evm ARM926EJS - -Helmut Raiger helmut.raiger@hale.at - - tt01 i.MX31 - -Linus Walleij linus.walleij@linaro.org - integratorap various - integratorcp various - -Luka Perkov luka@openwrt.org - - ib62x0 ARM926EJS - iconnect ARM926EJS - -Dave Peverley dpeverley@mpc-data.co.uk - - omap730p2 ARM926EJS - -Lars Poeschel poeschel@lemonage.de - pcm051 ARM ARMV7 (AM33xx Soc) - -Mathieu Poirier mathieu.poirier@linaro.org - - snowball ARM ARMV7 (u8500 SoC) - -Stelian Pop stelian@popies.net - - at91sam9260ek ARM926EJS (AT91SAM9260 SoC) - at91sam9261ek ARM926EJS (AT91SAM9261 SoC) - at91sam9263ek ARM926EJS (AT91SAM9263 SoC) - at91sam9rlek ARM926EJS (AT91SAM9RL SoC) - -Matt Porter mporter@ti.com - - ti814x_evm ARM ARMV7 (TI814x Soc) - -Dave Purdy david.c.purdy@gmail.com - - pogo_e02 ARM926EJS (Kirkwood SoC) - -Sricharan R r.sricharan@ti.com - - omap4_panda ARM ARMV7 (OMAP4xx SoC) - omap4_sdp4430 ARM ARMV7 (OMAP4xx SoC) - omap5_evm ARM ARMV7 (OMAP5xx Soc) - -Suriyan Ramasami suriyan.r@gmail.com - - goflexhome ARM926EJS (Kirkwood SoC) - -Thierry Reding thierry.reding@avionic-design.de - - plutux Tegra20 (ARM7 & A9 Dual Core) - medcom-wide Tegra20 (ARM7 & A9 Dual Core) - tec Tegra20 (ARM7 & A9 Dual Core) - -Christian Riesch christian.riesch@omicron.at -Manfred Rudigier manfred.rudigier@omicron.at - - calimain ARM926EJS (AM1808 SoC) - -Tom Rini trini@ti.com - - am335x_evm ARM ARMV7 (AM33xx Soc) - omap3_beagle ARM ARMV7 (OMAP3xx SoC) - omap3_evm ARM ARMV7 (OMAP3xx SoC) - -Tom Rix Tom.Rix@windriver.com - - omap3_zoom2 ARM ARMV7 (OMAP3xx SoC) - -John Rigby jcrigby@gmail.com - - tx25 i.MX25 - -Stefan Roese sr@denx.de - - x600 ARM926EJS (spear600 Soc) - - titanium i.MX6Q - - pdnb3 xscale/ixp - scpu xscale/ixp - -Alessandro Rubini rubini@unipv.it -Nomadik Linux Team STN_WMM_nomadik_linux@list.st.com - - nhk8815 ARM926EJS (Nomadik 8815 Soc) - -Steve Sakoman sakoman@gmail.com - - omap3_overo ARM ARMV7 (OMAP3xx SoC) - -Leo Sartre lsartre@adeneo-embedded.com - - cgtqmx6qeval i.MX6Q - -Jens Scharsig esw@bus-elektronik.de - - eb_cpux9k2 ARM920T (AT91RM9200 SoC) - vl_ma2sc ARM926EJS (AT91SAM9263 SoC) - -Heiko Schocher hs@denx.de - - enbw_cmc ARM926EJS (AM1808 SoC) - magnesium i.MX27 - -Michael Schwingen michael@schwingen.org - - actux1 xscale/ixp - actux2 xscale/ixp - actux3 xscale/ixp - actux4 xscale/ixp - dvlhost xscale/ixp - -Matt Sealey matt@genesi-usa.com - - efikamx i.MX51 - efikasb i.MX51 - -Bo Shen voice.shen@atmel.com - at91sam9x5ek ARM926EJS (AT91SAM9G15,G25,G35,X25,X35 SoC) - sama5d3xek ARMV7 (SAMA5D31, D33, D34, D35 SoC) - -Rajeshwari Shinde rajeshwari.s@samsung.com - - snow ARM ARMV7 (EXYNOS5250 SoC) - -Michal Simek monstr@monstr.eu - - zynq ARM ARMV7 (Zynq SoC) - -Lucas Stach dev@lynxeye.de - - colibri_t20_iris Tegra20 (ARM7 & A9 Dual Core) - -Nick Thompson nick.thompson@gefanuc.com - - da830evm ARM926EJS (DA830/OMAP-L137) - -Albin Tonnerre albin.tonnerre@free-electrons.com - - sbc35_a9g20 ARM926EJS (AT91SAM9G20 SoC) - tny_a9260 ARM926EJS (AT91SAM9260 SoC) - tny_a9g20 ARM926EJS (AT91SAM9G20 SoC) - -Greg Ungerer greg.ungerer@opengear.com - - cm4008 ks8695p - cm4116 ks8695p - cm4148 ks8695p - -Marek Vasut marek.vasut@gmail.com - - balloon3 xscale/pxa - colibri_pxa270 xscale/pxa - palmld xscale/pxa - palmtc xscale/pxa - vpac270 xscale/pxa - zipitz2 xscale/pxa - mx23_olinuxino i.MX23 - m28evk i.MX28 - sc_sps_1 i.MX28 - m53evk i.MX53 - -Hugo Villeneuve hugo.villeneuve@lyrtech.com - - SFFSDR ARM926EJS - -Lokesh Vutla lokeshvutla@ti.com - - dra7xx_evm ARM ARMV7 (DRA7xx Soc) - -Matt Waddel matt.waddel@linaro.org - - vexpress_ca9x4 ARM ARMV7 (Quad Core) - vexpress_ca5x2 ARM ARMV7 (Dual Core) - -Otavio Salvador otavio@ossystems.com.br - - mx23evk i.MX23 - -Prafulla Wadaskar prafulla@marvell.com - - aspenite ARM926EJS (ARMADA100 88AP168 SoC) - mv88f6281gtw_ge ARM926EJS (Kirkwood SoC) - openrd_base ARM926EJS (Kirkwood SoC) - rd6281a ARM926EJS (Kirkwood SoC) - sheevaplug ARM926EJS (Kirkwood SoC) - -Michael Walle michael@walle.cc - - lschlv2 ARM926EJS (Kirkwood SoC) - lsxhl ARM926EJS (Kirkwood SoC) - -Tom Warren twarren@nvidia.com - - harmony Tegra20 (ARM7 & A9 Dual Core) - seaboard Tegra20 (ARM7 & A9 Dual Core) - cardhu Tegra30 (ARM7 & A9 Quad Core) - dalmore Tegra114 (ARM7 & A15 Quad Core) - -Tom Warren twarren@nvidia.com -Stephen Warren swarren@nvidia.com - - ventana Tegra20 (ARM7 & A9 Dual Core) - paz00 Tegra20 (ARM7 & A9 Dual Core) - trimslice Tegra20 (ARM7 & A9 Dual Core) - whistler Tegra20 (ARM7 & A9 Dual Core) - beaver Tegra30 (ARM7 & A9 Quad Core) - -Stephen Warren swarren@wwwdotorg.org - - rpi_b BCM2835 (ARM1176) - -Thomas Weber weber@corscience.de - - devkit8000 ARM ARMV7 (OMAP3530 SoC) - tricorder ARM ARMV7 (OMAP3503 SoC) - -Lei Wen leiwen@marvell.com - - dkb ARM926EJS (PANTHEON 88AP920 SOC) - -Matthias Weisser weisserm@arcor.de - - jadecpu ARM926EJS (MB86R01 SoC) - zmx25 ARM926EJS (imx25 SoC) - -Josh Wu josh.wu@atmel.com - at91sam9n12ek ARM926EJS (AT91SAM9N12 SoC) - -Ilya Yanok yanok@emcraft.com - - mcx ARM ARMV7 (AM35x SoC) - -Syed Mohammed Khasim sm.khasim@gmail.com -Sughosh Ganu urwithsughosh@gmail.com - - hawkboard ARM926EJS (OMAP-L138) - -Vladimir Zapolskiy vz@mleia.com - - devkit3250 lpc32xx - -Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com -Tetsuyuki Kobayashi koba@kmckk.co.jp - - kzm9g SH73A0 (RMOBILE SoC) - -Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com - - armadillo-800eva R8A7740 (RMOBILE SoC) - -Pali Rohár pali.rohar@gmail.com - - nokia_rx51 ARM ARMV7 (OMAP34xx SoC) - -Eric Nelson eric.nelson@boundarydevices.com - nitrogen6dl i.MX6DL 1GB - nitrogen6dl2g i.MX6DL 2GB - nitrogen6q i.MX6Q/6D 1GB - nitrogen6q2g i.MX6Q/6D 2GB - nitrogen6s i.MX6S 512MB - nitrogen6s1g i.MX6S 1GB - -Alison Wang b18965@freescale.com - - vf610twr VF610 - -Sergey Yanovich ynvich@gmail.com - - lp8x4x xscale/pxa - -------------------------------------------------------------------------- - -Unknown / orphaned boards: - Board CPU Last known maintainer / Comment -......................................................................... - - omap1510inn ARM925T Kshitij Gupta kshitij@ti.com - - lubbock xscale/pxa Kyle Harris kharris@nexus-tech.net / dead address - - imx31_phycore_eet i.MX31 Guennadi Liakhovetski g.liakhovetski@gmx.de / resigned - mx31ads i.MX31 Guennadi Liakhovetski g.liakhovetski@gmx.de / resigned - -######################################################################### -# x86 Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Simon Glass sjg@chromium.org - - chromebook-x86 Coreboot runs first, then U-Boot - Supports Intel Sandy Bridge / Ivy Bridge so far - - Chromebooks for x86, including: - Samsung Series 5 Chromebook - Acer AC700 Chromebook - Acer C7 Chromebook - Samsung Chromebook 550 - HP Pavillion Chromebook - Acer C710 Chromebook - Chromebook Pixel - -######################################################################### -# MIPS Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Wolfgang Denk wd@denx.de - - incaip MIPS32 4Kc - -Vlad Lungu vlad.lungu@windriver.com - qemu_mips MIPS32 - -Stefan Roese sr@denx.de - - vct_xxx MIPS32 4Kc - -------------------------------------------------------------------------- - -Unknown / orphaned boards: - Board CPU Last known maintainer / Comment -......................................................................... - - dbau1x00 MIPS32 Au1000 Thomas Lange thomas@corelatus.se - -######################################################################### -# Nios-II Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Scott McNutt smcnutt@psyent.com - - PCI5441 Nios-II - PK1C20 Nios-II - nios2-generic Nios-II - -######################################################################### -# MicroBlaze Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Michal Simek monstr@monstr.eu - - microblaze-generic MicroBlaze - -######################################################################### -# Coldfire Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Hayden Fraser Hayden.Fraser@freescale.com - - M5253EVBE mcf52x2 - -Matthias Fuchs matthias.fuchs@esd-electronics.com - - TASREG MCF5249 - -Jens Scharsig esw@bus-elektronik.de - - eb_cpu5282 mfc5282 - -TsiChung Liew Tsi-Chung.Liew@freescale.com - - M52277EVB mcf5227x - M5235EVB mcf52x2 - M5253DEMO mcf52x2 - M53017EVB mcf532x - M5329EVB mcf532x - M5373EVB mcf532x - M54455EVB mcf5445x - M5475EVB mcf547x_8x - M5485EVB mcf547x_8x - -Wolfgang Wegner w.wegner@astro-kom.de - - astro_mcf5373l MCF5373L - -######################################################################### -# AVR32 Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Andreas Bießmann andreas.devel@googlemail.com - grasshopper AT32AP7000 - atngw100mkii AT32AP7000 - -Hans-Christian Egtvedt hans-christian.egtvedt@atmel.com - - FAVR-32-EZKIT AT32AP7000 - -Mark Jackson mpfj@mimc.co.uk - - MIMC200 AT32AP7000 - -Alex Raimondi alex.raimondi@miromico.ch -Julien May julien.may@miromico.ch - - HAMMERHEAD AT32AP7000 - -Haavard Skinnemoen haavard.skinnemoen@atmel.com - - ATSTK1000 AT32AP7xxx - ATSTK1002 AT32AP7000 - ATSTK1003 AT32AP7001 - ATSTK1004 AT32AP7002 - ATSTK1006 AT32AP7000 - ATNGW100 AT32AP7000 - -######################################################################### -# SuperH Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Yusuke Goda goda.yusuke@renesas.com - - MIGO-R SH7722 - -Nobuhiro Iwamatsu iwamatsu@nigauri.org - iwamatsu.nobuhiro@renesas.com - - MS7750SE SH7750 - MS7722SE SH7722 - R7780MP SH7780 - R2DPlus SH7751R - SH7763RDP SH7763 - RSK7203 SH7203 - AP325RXA SH7723 - SHMIN SH7706 - ECOVEC SH7724 - R0P7734 SH7734 - AP_SH4A_4A SH7734 - -Mark Jonas mark.jonas@de.bosch.com - - mpr2 SH7720 - -Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com - - MS7720SE SH7720 - R0P77520000RZ SH7752 - R0P77570030RL SH7757 - R0P77850011RL SH7785 - -######################################################################### -# Blackfin Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Sonic Zhang sonic.adi@gmail.com -Blackfin Team u-boot-devel@blackfin.uclinux.org - - BF506F-EZKIT BF506 - BF518F-EZBRD BF518 - BF526-EZBRD BF526 - BF527-AD7160-EVAL BF527 - BF527-EZKIT BF527 - BF527-EZKIT-V2 BF527 - BF527-SDP BF527 - BF533-EZKIT BF533 - BF533-STAMP BF533 - BF537-PNAV BF537 - BF537-STAMP BF537 - BF538F-EZKIT BF538 - BF548-EZKIT BF548 - BF561-EZKIT BF561 - BF609-EZKIT BF609 - -M.Hasewinkel (MHA) info@ssv-embedded.de - - dnp5370 BF537 - -Brent Kandetzki brentk@teleco.com - - IP04 BF532 - -Peter Meerwald devel@bct-electronic.com - - bct-brettl2 BF536 - -I-SYST Micromodule support@i-syst.com - - IBF-DSP561 BF561 - -Wojtek Skulski skulski@pas.rochester.edu -Wojtek Skulski info@skutek.com -Benjamin Matthews mben12@gmail.com - - BlackStamp BF533 - BlackVME BF561 - -Martin Strubel strubel@section5.ch - - BF537-minotaur BF537 - BF537-srv1 BF537 - -Bluetechnix Tinyboards bluetechnix@blackfin.uclinux.org - - CM-BF527 BF527 - CM-BF533 BF533 - CM-BF537E BF537 - CM-BF537U BF537 - CM-BF548 BF548 - CM-BF561 BF561 - TCM-BF518 BF518 - TCM-BF537 BF537 - -Valentin Yakovenkov yakovenkov@niistt.ru -Anton Shurpin shurpin.aa@niistt.ru - - BF561-ACVILON BF561 - -Haitao Zhang hzhang@ucrobotics.com -Chong Huang chuang@ucrobotics.com - - bf525-ucr2 BF525 - -Dimitar Penev dpn@switchfin.org - - BR4 Appliance BF537 - PR1 Appliance BF537 - -######################################################################### -# NDS32 Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Macpaul Lin macpaul@andestech.com - - ADP-AG101 N1213 (AG101 SoC) - ADP-AG101P N1213 (AG101P XC5 FPGA) - ADP-AG102 N1213f (AG102 SoC with FPU) - -######################################################################### -# OpenRISC Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Stefan Kristiansson stefan.kristiansson@saunalahti.fi - - openrisc-generic OpenRISC - -######################################################################### -# Sandbox: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Simon Glass sjg@chromium.org - - sandbox sandbox - -######################################################################### -# End of MAINTAINERS list # -######################################################################### diff --git a/MAKEALL b/MAKEALL index bed99de..3e895f6 100755 --- a/MAKEALL +++ b/MAKEALL @@ -160,7 +160,7 @@ FILTER="$1 !~ /^#/" [ "$opt_v" ] && FILTER="${FILTER} && $opt_v"
if [ "$SELECTED" ] ; then - SELECTED=$(awk '('"$FILTER"') { print $1 }' boards.cfg) + SELECTED=$(awk '('"$FILTER"') { print $7 }' boards.cfg)
# Make sure some boards from boards.cfg are actually found if [ -z "$SELECTED" ] ; then @@ -237,7 +237,7 @@ boards_by_field() } boards_by_arch() { boards_by_field 2 "$@" ; } boards_by_cpu() { boards_by_field 3 "$@" "[: \t]+" ; } -boards_by_soc() { boards_by_field 6 "$@" ; } +boards_by_soc() { boards_by_field 4 "$@" ; }
######################################################################### ## MPC5xx Systems @@ -519,7 +519,7 @@ get_target_location() { local vendor=""
# Automatic mode - local line=`egrep -i "^[[:space:]]*${target}[[:space:]]" boards.cfg` + local line=`egrep -i "[[:space:]]*${target}[[:space:]]" boards.cfg`
if [ -z "${line}" ] ; then echo "" ; return ; fi
@@ -532,15 +532,17 @@ get_target_location() {
[ "${BOARD_NAME}" ] || BOARD_NAME="${1%_config}"
- if [ "$4" = "-" ] ; then - board=${BOARD_NAME} - else - board="$4" + if [ $# -gt 5 ]; then + if [ "$6" = "-" ] ; then + board=${BOARD_NAME} + else + board="$4" + fi fi
[ $# -gt 4 ] && [ "$5" != "-" ] && vendor="$5" - [ $# -gt 6 ] && [ "$7" != "-" ] && { - tmp="${7%:*}" + [ $# -gt 6 ] && [ "$8" != "-" ] && { + tmp="${8%:*}" if [ "$tmp" ] ; then CONFIG_NAME="$tmp" fi diff --git a/Makefile b/Makefile index 7206aba..4d24cfa 100644 --- a/Makefile +++ b/Makefile @@ -784,7 +784,7 @@ unconfig:
sinclude $(obj).boards.depend $(obj).boards.depend: boards.cfg - @awk '(NF && $$1 !~ /^#/) { print $$1 ": " $$1 "_config; $$(MAKE)" }' $< > $@ + @awk '(NF && $$1 !~ /^#/) { print $$7 ": " $$7 "_config; $$(MAKE) -d" }' $< > $@
# # Functions to generate common board directory names diff --git a/boards.cfg b/boards.cfg index 211ed58..6ce6b7b 100644 --- a/boards.cfg +++ b/boards.cfg @@ -26,1164 +26,1162 @@ # #define CONFIG_HAS_BAR 1 # #define CONFIG_BAZ 64 # -# The list should be ordered according to the following fields, -# from most to least significant: -# -# ARCH, CPU, SoC, Vendor, Target -# -# To keep the list sorted, use something like -# :.,$! sort -bdf -k2,2 -k3,3 -k6,6 -k5,5 -k1,1 +# The maintainers field lists the e-mail addresses of the board's +# maintainers, separated by colons. NOTE: there are spaces in this field! +# For any board without permanent maintainer, please contact +# Wolfgang Denk wd@denx.de +# And Cc: the u-boot@lists.denx.de mailing list. + +# The list should be ordered according to the C locale. # -# To reformat the list, use something like -# :.,$! column -t +# To keep the list formatted and sorted, script tools/reformat.py is available. +# It can be used from a shell: +# tools/reformat.py -i -d '-' -s 8 <boards.cfg >boards0.cfg && mv boards0.cfg boards.cfg +# It can directly be invoked from vim: +# :%tools/reformat.py -i -d '-' -s 8 # -# Target ARCH CPU Board name Vendor SoC Options +# Status, Arch, CPU:SPLCPU, SoC, Vendor, Board name, Target, Options, Maintainers ###########################################################################################################
-integratorcp_cm1136 arm arm1136 integrator armltd - integratorcp:CM1136 -imx31_phycore arm arm1136 - - mx31 -imx31_phycore_eet arm arm1136 imx31_phycore - mx31 imx31_phycore:IMX31_PHYCORE_EET -qong arm arm1136 - davedenx mx31 -mx31ads arm arm1136 - freescale mx31 -mx31pdk arm arm1136 - freescale mx31 -tt01 arm arm1136 - hale mx31 -imx31_litekit arm arm1136 - logicpd mx31 -flea3 arm arm1136 - CarMediaLab mx35 -mx35pdk arm arm1136 - freescale mx35 -woodburn arm arm1136 - - mx35 -woodburn_sd arm arm1136 woodburn - mx35 woodburn_sd:IMX_CONFIG=board/woodburn/imximage.cfg -tnetv107x_evm arm arm1176 tnetv107xevm ti tnetv107x -rpi_b arm arm1176 rpi_b raspberrypi bcm2835 -integratorap_cm720t arm arm720t integrator armltd - integratorap:CM720T -integratorap_cm920t arm arm920t integrator armltd - integratorap:CM920T -integratorcp_cm920t arm arm920t integrator armltd - integratorcp:CM920T -a320evb arm arm920t - faraday a320 -at91rm9200ek arm arm920t at91rm9200ek atmel at91 at91rm9200ek -at91rm9200ek_ram arm arm920t at91rm9200ek atmel at91 at91rm9200ek:RAMBOOT -eb_cpux9k2 arm arm920t eb_cpux9k2 BuS at91 eb_cpux9k2 -eb_cpux9k2_ram arm arm920t eb_cpux9k2 BuS at91 eb_cpux9k2:RAMBOOT -cpuat91 arm arm920t cpuat91 eukrea at91 cpuat91 -cpuat91_ram arm arm920t cpuat91 eukrea at91 cpuat91:RAMBOOT -mx1ads arm arm920t - - imx -scb9328 arm arm920t - - imx -cm4008 arm arm920t - - ks8695 -cm41xx arm arm920t - - ks8695 -mini2440 arm arm920t mini2440 friendlyarm s3c24x0 -VCMA9 arm arm920t vcma9 mpl s3c24x0 -smdk2410 arm arm920t - samsung s3c24x0 -omap1510inn arm arm925t - ti -integratorap_cm926ejs arm arm926ejs integrator armltd - integratorap:CM926EJ_S -integratorcp_cm926ejs arm arm926ejs integrator armltd - integratorcp:CM924EJ_S -aspenite arm arm926ejs - Marvell armada100 -gplugd arm arm926ejs - Marvell armada100 -afeb9260 arm arm926ejs - - at91 -at91sam9260ek_dataflash_cs0 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9260,SYS_USE_DATAFLASH_CS0 -at91sam9260ek_dataflash_cs1 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9260,SYS_USE_DATAFLASH_CS1 -at91sam9260ek_nandflash arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9260,SYS_USE_NANDFLASH -at91sam9261ek_dataflash_cs0 arm arm926ejs at91sam9261ek atmel at91 at91sam9261ek:AT91SAM9261,SYS_USE_DATAFLASH_CS0 -at91sam9261ek_dataflash_cs3 arm arm926ejs at91sam9261ek atmel at91 at91sam9261ek:AT91SAM9261,SYS_USE_DATAFLASH_CS3 -at91sam9261ek_nandflash arm arm926ejs at91sam9261ek atmel at91 at91sam9261ek:AT91SAM9261,SYS_USE_NANDFLASH -at91sam9263ek_dataflash arm arm926ejs at91sam9263ek atmel at91 at91sam9263ek:AT91SAM9263,SYS_USE_DATAFLASH -at91sam9263ek_dataflash_cs0 arm arm926ejs at91sam9263ek atmel at91 at91sam9263ek:AT91SAM9263,SYS_USE_DATAFLASH -at91sam9263ek_nandflash arm arm926ejs at91sam9263ek atmel at91 at91sam9263ek:AT91SAM9263,SYS_USE_NANDFLASH -at91sam9263ek_norflash arm arm926ejs at91sam9263ek atmel at91 at91sam9263ek:AT91SAM9263,SYS_USE_NORFLASH -at91sam9263ek_norflash_boot arm arm926ejs at91sam9263ek atmel at91 at91sam9263ek:AT91SAM9263,SYS_USE_BOOT_NORFLASH -at91sam9g10ek_dataflash_cs0 arm arm926ejs at91sam9261ek atmel at91 at91sam9261ek:AT91SAM9G10,SYS_USE_DATAFLASH_CS0 -at91sam9g10ek_dataflash_cs3 arm arm926ejs at91sam9261ek atmel at91 at91sam9261ek:AT91SAM9G10,SYS_USE_DATAFLASH_CS3 -at91sam9g10ek_nandflash arm arm926ejs at91sam9261ek atmel at91 at91sam9261ek:AT91SAM9G10,SYS_USE_NANDFLASH -at91sam9g20ek_dataflash_cs0 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9G20,SYS_USE_DATAFLASH_CS0 -at91sam9g20ek_dataflash_cs1 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9G20,SYS_USE_DATAFLASH_CS1 -at91sam9g20ek_mmc arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9G20,SYS_USE_MMC -at91sam9g20ek_nandflash arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9G20,SYS_USE_NANDFLASH -at91sam9g20ek_2mmc_nandflash arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9G20,AT91SAM9G20EK_2MMC,SYS_USE_NANDFLASH -at91sam9m10g45ek_nandflash arm arm926ejs at91sam9m10g45ek atmel at91 at91sam9m10g45ek:AT91SAM9M10G45,SYS_USE_NANDFLASH -at91sam9rlek_dataflash arm arm926ejs at91sam9rlek atmel at91 at91sam9rlek:AT91SAM9RL,SYS_USE_DATAFLASH -at91sam9rlek_nandflash arm arm926ejs at91sam9rlek atmel at91 at91sam9rlek:AT91SAM9RL,SYS_USE_NANDFLASH -at91sam9x5ek_nandflash arm arm926ejs at91sam9x5ek atmel at91 at91sam9x5ek:AT91SAM9X5,SYS_USE_NANDFLASH -at91sam9x5ek_dataflash arm arm926ejs at91sam9x5ek atmel at91 at91sam9x5ek:AT91SAM9X5,SYS_USE_DATAFLASH -at91sam9x5ek_spiflash arm arm926ejs at91sam9x5ek atmel at91 at91sam9x5ek:AT91SAM9X5,SYS_USE_SPIFLASH -at91sam9x5ek_mmc arm arm926ejs at91sam9x5ek atmel at91 at91sam9x5ek:AT91SAM9X5,SYS_USE_MMC -at91sam9xeek_dataflash_cs0 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9XE,SYS_USE_DATAFLASH_CS0 -at91sam9xeek_dataflash_cs1 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9XE,SYS_USE_DATAFLASH_CS1 -at91sam9xeek_nandflash arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9XE,SYS_USE_NANDFLASH -at91sam9n12ek_nandflash arm arm926ejs at91sam9n12ek atmel at91 at91sam9n12ek:AT91SAM9N12,SYS_USE_NANDFLASH -at91sam9n12ek_spiflash arm arm926ejs at91sam9n12ek atmel at91 at91sam9n12ek:AT91SAM9N12,SYS_USE_SPIFLASH -at91sam9n12ek_mmc arm arm926ejs at91sam9n12ek atmel at91 at91sam9n12ek:AT91SAM9N12,SYS_USE_MMC -snapper9260 arm arm926ejs - bluewater at91 snapper9260:AT91SAM9260 -snapper9g20 arm arm926ejs snapper9260 bluewater at91 snapper9260:AT91SAM9G20 -vl_ma2sc arm arm926ejs vl_ma2sc BuS at91 -vl_ma2sc_ram arm arm926ejs vl_ma2sc BuS at91 vl_ma2sc:RAMLOAD -sbc35_a9g20_eeprom arm arm926ejs sbc35_a9g20 calao at91 sbc35_a9g20:AT91SAM9G20,SYS_USE_EEPROM -sbc35_a9g20_nandflash arm arm926ejs sbc35_a9g20 calao at91 sbc35_a9g20:AT91SAM9G20,SYS_USE_NANDFLASH -tny_a9260_eeprom arm arm926ejs tny_a9260 calao at91 tny_a9260:AT91SAM9260,SYS_USE_EEPROM -tny_a9260_nandflash arm arm926ejs tny_a9260 calao at91 tny_a9260:AT91SAM9260,SYS_USE_NANDFLASH -tny_a9g20_eeprom arm arm926ejs tny_a9260 calao at91 tny_a9260:AT91SAM9G20,SYS_USE_EEPROM -tny_a9g20_nandflash arm arm926ejs tny_a9260 calao at91 tny_a9260:AT91SAM9G20,SYS_USE_NANDFLASH -ethernut5 arm arm926ejs ethernut5 egnite at91 ethernut5:AT91SAM9XE -top9000eval_xe arm arm926ejs top9000 emk at91 top9000:EVAL9000 -top9000su_xe arm arm926ejs top9000 emk at91 top9000:SU9000 -meesc arm arm926ejs meesc esd at91 meesc:AT91SAM9263,SYS_USE_NANDFLASH -meesc_dataflash arm arm926ejs meesc esd at91 meesc:AT91SAM9263,SYS_USE_DATAFLASH -otc570 arm arm926ejs otc570 esd at91 otc570:AT91SAM9263,SYS_USE_NANDFLASH -otc570_dataflash arm arm926ejs otc570 esd at91 otc570:AT91SAM9263,SYS_USE_DATAFLASH -cpu9260 arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9260 -cpu9260_128M arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9260,CPU9260_128M -cpu9260_nand arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9260,NANDBOOT -cpu9260_nand_128M arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9260,CPU9260_128M,NANDBOOT -cpu9G20 arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9G20 -cpu9G20_128M arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9G20,CPU9G20_128M -cpu9G20_nand arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9G20,NANDBOOT -cpu9G20_nand_128M arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9G20,CPU9G20_128M,NANDBOOT -pm9261 arm arm926ejs pm9261 ronetix at91 pm9261:AT91SAM9261 -pm9263 arm arm926ejs pm9263 ronetix at91 pm9263:AT91SAM9263 -pm9g45 arm arm926ejs pm9g45 ronetix at91 pm9g45:AT91SAM9G45 -portuxg20 arm arm926ejs stamp9g20 taskit at91 stamp9g20:AT91SAM9G20,PORTUXG20 -stamp9g20 arm arm926ejs stamp9g20 taskit at91 stamp9g20:AT91SAM9G20 -cam_enc_4xx arm arm926ejs cam_enc_4xx ait davinci cam_enc_4xx -da830evm arm arm926ejs da8xxevm davinci davinci -da850_am18xxevm arm arm926ejs da8xxevm davinci davinci da850evm:DA850_AM18X_EVM,MAC_ADDR_IN_EEPROM,SYS_I2C_EEPROM_ADDR_LEN=2,SYS_I2C_EEPROM_ADDR=0x50 -da850evm arm arm926ejs da8xxevm davinci davinci da850evm:MAC_ADDR_IN_SPIFLASH -da850evm_direct_nor arm arm926ejs da8xxevm davinci davinci da850evm:MAC_ADDR_IN_SPIFLASH,USE_NOR,DIRECT_NOR_BOOT -davinci_dm355evm arm arm926ejs dm355evm davinci davinci -davinci_dm355leopard arm arm926ejs dm355leopard davinci davinci -davinci_dm365evm arm arm926ejs dm365evm davinci davinci -davinci_dm6467evm arm arm926ejs dm6467evm davinci davinci davinci_dm6467evm:REFCLK_FREQ=27000000 -davinci_dm6467Tevm arm arm926ejs dm6467evm davinci davinci davinci_dm6467evm:DAVINCI_DM6467TEVM,REFCLK_FREQ=33000000 -davinci_dvevm arm arm926ejs dvevm davinci davinci -davinci_schmoogie arm arm926ejs schmoogie davinci davinci -davinci_sffsdr arm arm926ejs sffsdr davinci davinci -davinci_sonata arm arm926ejs sonata davinci davinci -ea20 arm arm926ejs ea20 davinci davinci -hawkboard arm arm926ejs da8xxevm davinci davinci -hawkboard_uart arm arm926ejs da8xxevm davinci davinci hawkboard:UART_U_BOOT -enbw_cmc arm arm926ejs enbw_cmc enbw davinci -calimain arm arm926ejs calimain omicron davinci -pogo_e02 arm arm926ejs - cloudengines kirkwood -dns325 arm arm926ejs - d-link kirkwood -iconnect arm arm926ejs - iomega kirkwood -lschlv2 arm arm926ejs lsxl buffalo kirkwood lsxl:LSCHLV2 -lsxhl arm arm926ejs lsxl buffalo kirkwood lsxl:LSXHL -km_kirkwood arm arm926ejs km_arm keymile kirkwood km_kirkwood:KM_KIRKWOOD -km_kirkwood_pci arm arm926ejs km_arm keymile kirkwood km_kirkwood:KM_KIRKWOOD_PCI -kmnusa arm arm926ejs km_arm keymile kirkwood km_kirkwood:KM_NUSA -kmsuv31 arm arm926ejs km_arm keymile kirkwood km_kirkwood:KM_SUV31 -mgcoge3un arm arm926ejs km_arm keymile kirkwood km_kirkwood:KM_MGCOGE3UN -kmcoge5un arm arm926ejs km_arm keymile kirkwood km_kirkwood:KM_COGE5UN -portl2 arm arm926ejs km_arm keymile kirkwood km_kirkwood:KM_PORTL2 -d2net_v2 arm arm926ejs net2big_v2 LaCie kirkwood lacie_kw:D2NET_V2 -inetspace_v2 arm arm926ejs netspace_v2 LaCie kirkwood lacie_kw:INETSPACE_V2 -net2big_v2 arm arm926ejs net2big_v2 LaCie kirkwood lacie_kw:NET2BIG_V2 -netspace_lite_v2 arm arm926ejs netspace_v2 LaCie kirkwood lacie_kw:NETSPACE_LITE_V2 -netspace_max_v2 arm arm926ejs netspace_v2 LaCie kirkwood lacie_kw:NETSPACE_MAX_V2 -netspace_mini_v2 arm arm926ejs netspace_v2 LaCie kirkwood lacie_kw:NETSPACE_MINI_V2 -netspace_v2 arm arm926ejs netspace_v2 LaCie kirkwood lacie_kw:NETSPACE_V2 -wireless_space arm arm926ejs wireless_space LaCie kirkwood -dreamplug arm arm926ejs - Marvell kirkwood -guruplug arm arm926ejs - Marvell kirkwood -mv88f6281gtw_ge arm arm926ejs - Marvell kirkwood -openrd_base arm arm926ejs openrd Marvell kirkwood openrd:BOARD_IS_OPENRD_BASE -openrd_client arm arm926ejs openrd Marvell kirkwood openrd:BOARD_IS_OPENRD_CLIENT -openrd_ultimate arm arm926ejs openrd Marvell kirkwood openrd:BOARD_IS_OPENRD_ULTIMATE -rd6281a arm arm926ejs - Marvell kirkwood -sheevaplug arm arm926ejs - Marvell kirkwood -ib62x0 arm arm926ejs ib62x0 raidsonic kirkwood -dockstar arm arm926ejs - Seagate kirkwood -goflexhome arm arm926ejs - Seagate kirkwood -tk71 arm arm926ejs tk71 karo kirkwood -devkit3250 arm arm926ejs devkit3250 timll lpc32xx -jadecpu arm arm926ejs jadecpu syteco mb86r0x -mx25pdk arm arm926ejs mx25pdk freescale mx25 mx25pdk:IMX_CONFIG=board/freescale/mx25pdk/imximage.cfg -tx25 arm arm926ejs tx25 karo mx25 -zmx25 arm arm926ejs zmx25 syteco mx25 -imx27lite arm arm926ejs imx27lite logicpd mx27 -magnesium arm arm926ejs imx27lite logicpd mx27 -mx23_olinuxino arm arm926ejs mx23_olinuxino olimex mxs mx23_olinuxino -apx4devkit arm arm926ejs apx4devkit bluegiga mxs apx4devkit -mx23evk arm arm926ejs mx23evk freescale mxs mx23evk -m28evk arm arm926ejs m28evk denx mxs m28evk -mx28evk arm arm926ejs mx28evk freescale mxs mx28evk:ENV_IS_IN_MMC -mx28evk_nand arm arm926ejs mx28evk freescale mxs mx28evk:ENV_IS_IN_NAND -sc_sps_1 arm arm926ejs sc_sps_1 schulercontrol mxs -nhk8815 arm arm926ejs nhk8815 st nomadik -nhk8815_onenand arm arm926ejs nhk8815 st nomadik nhk8815:BOOT_ONENAND -omap5912osk arm arm926ejs - ti omap -omap730p2 arm arm926ejs omap730p2 ti omap omap730p2:CS3_BOOT -omap730p2_cs0boot arm arm926ejs omap730p2 ti omap omap730p2:CS0_BOOT -omap730p2_cs3boot arm arm926ejs omap730p2 ti omap omap730p2:CS3_BOOT -edminiv2 arm arm926ejs - LaCie orion5x -dkb arm arm926ejs - Marvell pantheon -spear300 arm arm926ejs spear300 spear spear spear3xx_evb:spear300 -spear300_nand arm arm926ejs spear300 spear spear spear3xx_evb:spear300,nand -spear300_usbtty arm arm926ejs spear300 spear spear spear3xx_evb:spear300,usbtty -spear300_usbtty_nand arm arm926ejs spear300 spear spear spear3xx_evb:spear300,usbtty,nand -spear310 arm arm926ejs spear310 spear spear spear3xx_evb:spear310 -spear310_pnor arm arm926ejs spear310 spear spear spear3xx_evb:spear310,FLASH_PNOR -spear310_nand arm arm926ejs spear310 spear spear spear3xx_evb:spear310,nand -spear310_usbtty arm arm926ejs spear310 spear spear spear3xx_evb:spear310,usbtty -spear310_usbtty_pnor arm arm926ejs spear310 spear spear spear3xx_evb:spear310,usbtty,FLASH_PNOR -spear310_usbtty_nand arm arm926ejs spear310 spear spear spear3xx_evb:spear310,usbtty,nand -spear320 arm arm926ejs spear320 spear spear spear3xx_evb:spear320 -spear320_pnor arm arm926ejs spear320 spear spear spear3xx_evb:spear320,FLASH_PNOR -spear320_nand arm arm926ejs spear320 spear spear spear3xx_evb:spear320,nand -spear320_usbtty arm arm926ejs spear320 spear spear spear3xx_evb:spear320,usbtty -spear320_usbtty_pnor arm arm926ejs spear320 spear spear spear3xx_evb:spear320,usbtty,FLASH_PNOR -spear320_usbtty_nand arm arm926ejs spear320 spear spear spear3xx_evb:spear320,usbtty,nand -spear600 arm arm926ejs spear600 spear spear spear6xx_evb:spear600 -spear600_nand arm arm926ejs spear600 spear spear spear6xx_evb:spear600,nand -spear600_usbtty arm arm926ejs spear600 spear spear spear6xx_evb:spear600,usbtty -spear600_usbtty_nand arm arm926ejs spear600 spear spear spear6xx_evb:spear600,usbtty,nand -x600 arm arm926ejs - spear spear x600 -versatileab arm arm926ejs versatile armltd versatile versatile:ARCH_VERSATILE_AB -versatilepb arm arm926ejs versatile armltd versatile versatile:ARCH_VERSATILE_PB -versatileqemu arm arm926ejs versatile armltd versatile versatile:ARCH_VERSATILE_QEMU,ARCH_VERSATILE_PB -integratorap_cm946es arm arm946es integrator armltd - integratorap:CM946ES -integratorcp_cm946es arm arm946es integrator armltd - integratorcp:CM946ES -vexpress_ca15_tc2 arm armv7 vexpress armltd -vexpress_ca5x2 arm armv7 vexpress armltd -vexpress_ca9x4 arm armv7 vexpress armltd -am335x_evm arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,NAND -am335x_evm_nor arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,NAND,NOR -am335x_evm_norboot arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,NOR,NOR_BOOT -am335x_evm_spiboot arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,SPI_BOOT -am335x_evm_uart1 arm armv7 am335x ti am33xx am335x_evm:SERIAL2,CONS_INDEX=1,NAND -am335x_evm_uart2 arm armv7 am335x ti am33xx am335x_evm:SERIAL3,CONS_INDEX=1,NAND -am335x_evm_uart3 arm armv7 am335x ti am33xx am335x_evm:SERIAL4,CONS_INDEX=1,NAND -am335x_evm_uart4 arm armv7 am335x ti am33xx am335x_evm:SERIAL5,CONS_INDEX=1,NAND -am335x_evm_uart5 arm armv7 am335x ti am33xx am335x_evm:SERIAL6,CONS_INDEX=1,NAND -am335x_evm_usbspl arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,NAND,SPL_USBETH_SUPPORT -am335x_boneblack arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,EMMC_BOOT -ti814x_evm arm armv7 ti814x ti am33xx -pcm051 arm armv7 pcm051 phytec am33xx pcm051 -sama5d3xek_mmc arm armv7 sama5d3xek atmel at91 sama5d3xek:SAMA5D3,SYS_USE_MMC -sama5d3xek_nandflash arm armv7 sama5d3xek atmel at91 sama5d3xek:SAMA5D3,SYS_USE_NANDFLASH -sama5d3xek_spiflash arm armv7 sama5d3xek atmel at91 sama5d3xek:SAMA5D3,SYS_USE_SERIALFLASH -highbank arm armv7 highbank - highbank -m53evk arm armv7 m53evk denx mx5 m53evk:IMX_CONFIG=board/denx/m53evk/imximage.cfg -mx51_efikamx arm armv7 mx51_efikamx genesi mx5 mx51_efikamx:MACH_TYPE=MACH_TYPE_MX51_EFIKAMX,IMX_CONFIG=board/genesi/mx51_efikamx/imximage_mx.cfg -mx51_efikasb arm armv7 mx51_efikamx genesi mx5 mx51_efikamx:MACH_TYPE=MACH_TYPE_MX51_EFIKASB,IMX_CONFIG=board/genesi/mx51_efikamx/imximage_sb.cfg -mx51evk arm armv7 mx51evk freescale mx5 mx51evk:IMX_CONFIG=board/freescale/mx51evk/imximage.cfg -mx53ard arm armv7 mx53ard freescale mx5 mx53ard:IMX_CONFIG=board/freescale/mx53ard/imximage_dd3.cfg -mx53evk arm armv7 mx53evk freescale mx5 mx53evk:IMX_CONFIG=board/freescale/mx53evk/imximage.cfg -mx53loco arm armv7 mx53loco freescale mx5 mx53loco:IMX_CONFIG=board/freescale/mx53loco/imximage.cfg -mx53smd arm armv7 mx53smd freescale mx5 mx53smd:IMX_CONFIG=board/freescale/mx53smd/imximage.cfg -ima3-mx53 arm armv7 ima3-mx53 esg mx5 ima3-mx53:IMX_CONFIG=board/esg/ima3-mx53/imximage.cfg -vision2 arm armv7 vision2 ttcontrol mx5 vision2:IMX_CONFIG=board/ttcontrol/vision2/imximage_hynix.cfg -cgtqmx6qeval arm armv7 cgtqmx6eval congatec mx6 cgtqmx6eval:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg,MX6Q -mx6qarm2 arm armv7 mx6qarm2 freescale mx6 mx6qarm2:IMX_CONFIG=board/freescale/mx6qarm2/imximage.cfg -mx6qsabreauto arm armv7 mx6qsabreauto freescale mx6 mx6qsabreauto:IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg,MX6Q -mx6qsabrelite arm armv7 mx6qsabrelite freescale mx6 mx6qsabrelite:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg -mx6dlsabresd arm armv7 mx6sabresd freescale mx6 mx6sabresd:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL -mx6qsabresd arm armv7 mx6sabresd freescale mx6 mx6sabresd:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg,MX6Q -mx6slevk arm armv7 mx6slevk freescale mx6 mx6slevk:IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL -titanium arm armv7 titanium freescale mx6 titanium:IMX_CONFIG=board/freescale/titanium/imximage.cfg -vf610twr arm armv7 vf610twr freescale vf610 vf610twr:IMX_CONFIG=board/freescale/vf610twr/imximage.cfg -eco5pk arm armv7 eco5pk 8dtech omap3 -nitrogen6dl arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024 -nitrogen6dl2g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg,MX6DL,DDR_MB=2048 -nitrogen6q arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024 -nitrogen6q2g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048 -nitrogen6s arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512 -nitrogen6s1g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024 -wandboard_dl arm armv7 wandboard - mx6 wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024 -wandboard_quad arm armv7 wandboard - mx6 wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048 -wandboard_solo arm armv7 wandboard - mx6 wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512 -omap3_overo arm armv7 overo - omap3 -omap3_pandora arm armv7 pandora - omap3 -dig297 arm armv7 dig297 comelit omap3 -cm_t35 arm armv7 cm_t35 compulab omap3 -igep0020 arm armv7 igep00x0 isee omap3 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0020,BOOT_ONENAND -igep0020_nand arm armv7 igep00x0 isee omap3 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0020,BOOT_NAND -igep0030 arm armv7 igep00x0 isee omap3 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_ONENAND -igep0030_nand arm armv7 igep00x0 isee omap3 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_NAND -igep0032 arm armv7 igep00x0 isee omap3 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0032,BOOT_ONENAND -igep0033 arm armv7 igep0033 isee am33xx -am3517_evm arm armv7 am3517evm logicpd omap3 -mt_ventoux arm armv7 mt_ventoux teejet omap3 -omap3_zoom1 arm armv7 zoom1 logicpd omap3 -omap3_zoom2 arm armv7 zoom2 logicpd omap3 -omap3_logic arm armv7 omap3som logicpd omap3 -omap3_mvblx arm armv7 mvblx matrix_vision omap3 -am3517_crane arm armv7 am3517crane ti omap3 -omap3_beagle arm armv7 beagle ti omap3 -omap3_evm arm armv7 evm ti omap3 -omap3_evm_quick_mmc arm armv7 evm ti omap3 -omap3_evm_quick_nand arm armv7 evm ti omap3 -omap3_sdp3430 arm armv7 sdp3430 ti omap3 -devkit8000 arm armv7 devkit8000 timll omap3 -mcx arm armv7 mcx htkw omap3 -tricorder arm armv7 tricorder corscience omap3 -twister arm armv7 twister technexion omap3 -nokia_rx51 arm armv7 rx51 nokia omap3 -omap4_panda arm armv7 panda ti omap4 -omap4_sdp4430 arm armv7 sdp4430 ti omap4 -omap5_uevm arm armv7 omap5_uevm ti omap5 -dra7xx_evm arm armv7 dra7xx ti omap5 -s5p_goni arm armv7 goni samsung s5pc1xx -smdkc100 arm armv7 smdkc100 samsung s5pc1xx -origen arm armv7 origen samsung exynos -s5pc210_universal arm armv7 universal_c210 samsung exynos -snow arm armv7 smdk5250 samsung exynos -smdk5250 arm armv7 smdk5250 samsung exynos -smdkv310 arm armv7 smdkv310 samsung exynos -trats arm armv7 trats samsung exynos -harmony arm armv7:arm720t harmony nvidia tegra20 -seaboard arm armv7:arm720t seaboard nvidia tegra20 -ventana arm armv7:arm720t ventana nvidia tegra20 -whistler arm armv7:arm720t whistler nvidia tegra20 -cardhu arm armv7:arm720t cardhu nvidia tegra30 -beaver arm armv7:arm720t beaver nvidia tegra30 -dalmore arm armv7:arm720t dalmore nvidia tegra114 -colibri_t20_iris arm armv7:arm720t colibri_t20_iris toradex tegra20 -u8500_href arm armv7 u8500 st-ericsson u8500 -snowball arm armv7 snowball st-ericsson u8500 -kzm9g arm armv7 kzm9g kmc rmobile -armadillo-800eva arm armv7 armadillo-800eva atmark-techno rmobile -zynq arm armv7 zynq xilinx zynq -zynq_dcc arm armv7 zynq xilinx zynq zynq:ZYNQ_DCC -socfpga_cyclone5 arm armv7 socfpga altera socfpga -actux1_4_16 arm ixp actux1 - - actux1:FLASH2X2 -actux1_4_32 arm ixp actux1 - - actux1:FLASH2X2,RAM_32MB -actux1_8_16 arm ixp actux1 - - actux1:FLASH1X8 -actux1_8_32 arm ixp actux1 - - actux1:FLASH1X8,RAM_32MB -actux2 arm ixp -actux3 arm ixp -actux4 arm ixp -dvlhost arm ixp -pdnb3 arm ixp pdnb3 prodrive -scpu arm ixp pdnb3 prodrive - pdnb3:SCPU -balloon3 arm pxa -h2200 arm pxa -lp8x4x arm pxa lp8x4x icpdas -lubbock arm pxa -palmld arm pxa -palmtc arm pxa -palmtreo680 arm pxa -polaris arm pxa trizepsiv - - trizepsiv:POLARIS -pxa255_idp arm pxa -trizepsiv arm pxa -vpac270_nor_128 arm pxa vpac270 - - vpac270:NOR,RAM_128M -vpac270_nor_256 arm pxa vpac270 - - vpac270:NOR,RAM_256M -vpac270_ond_256 arm pxa vpac270 - - vpac270:ONENAND,RAM_256M -xaeniax arm pxa -zipitz2 arm pxa -colibri_pxa270 arm pxa - toradex -jornada arm sa1100 -plutux arm armv7:arm720t plutux avionic-design tegra20 -medcom-wide arm armv7:arm720t medcom-wide avionic-design tegra20 -tec arm armv7:arm720t tec avionic-design tegra20 -paz00 arm armv7:arm720t paz00 compal tegra20 -trimslice arm armv7:arm720t trimslice compulab tegra20 -atngw100 avr32 at32ap - atmel at32ap700x -atngw100mkii avr32 at32ap - atmel at32ap700x -atstk1002 avr32 at32ap atstk1000 atmel at32ap700x -atstk1003 avr32 at32ap atstk1000 atmel at32ap700x -atstk1004 avr32 at32ap atstk1000 atmel at32ap700x -atstk1006 avr32 at32ap atstk1000 atmel at32ap700x -favr-32-ezkit avr32 at32ap - earthlcd at32ap700x -grasshopper avr32 at32ap - in-circuit at32ap700x -mimc200 avr32 at32ap - mimc at32ap700x -hammerhead avr32 at32ap - miromico at32ap700x -bct-brettl2 blackfin blackfin -bf506f-ezkit blackfin blackfin -bf518f-ezbrd blackfin blackfin -bf525-ucr2 blackfin blackfin -bf526-ezbrd blackfin blackfin -bf527-ad7160-eval blackfin blackfin -bf527-ezkit blackfin blackfin -bf527-ezkit-v2 blackfin blackfin bf527-ezkit - - bf527-ezkit:BF527_EZKIT_REV_2_1 -bf527-sdp blackfin blackfin -bf533-ezkit blackfin blackfin -bf533-stamp blackfin blackfin -bf537-minotaur blackfin blackfin -bf537-pnav blackfin blackfin -bf537-srv1 blackfin blackfin -bf537-stamp blackfin blackfin -bf538f-ezkit blackfin blackfin -bf548-ezkit blackfin blackfin -bf561-acvilon blackfin blackfin -bf561-ezkit blackfin blackfin -bf609-ezkit blackfin blackfin -blackstamp blackfin blackfin -blackvme blackfin blackfin -br4 blackfin blackfin -cm-bf527 blackfin blackfin -cm-bf533 blackfin blackfin -cm-bf537e blackfin blackfin -cm-bf537u blackfin blackfin -cm-bf548 blackfin blackfin -cm-bf561 blackfin blackfin -dnp5370 blackfin blackfin -ibf-dsp561 blackfin blackfin -ip04 blackfin blackfin -pr1 blackfin blackfin -tcm-bf518 blackfin blackfin -tcm-bf537 blackfin blackfin -M52277EVB m68k mcf5227x m52277evb freescale - M52277EVB:SYS_SPANSION_BOOT,SYS_TEXT_BASE=0x00000000 -M52277EVB_stmicro m68k mcf5227x m52277evb freescale - M52277EVB:CF_SBF,SYS_STMICRO_BOOT,SYS_TEXT_BASE=0x43E00000 -M5235EVB m68k mcf523x m5235evb freescale - M5235EVB:SYS_TEXT_BASE=0xFFE00000 -M5235EVB_Flash32 m68k mcf523x m5235evb freescale - M5235EVB:NORFLASH_PS32BIT,SYS_TEXT_BASE=0xFFC00000 -cobra5272 m68k mcf52x2 cobra5272 - -idmr m68k mcf52x2 -eb_cpu5282 m68k mcf52x2 eb_cpu5282 BuS - eb_cpu5282:SYS_TEXT_BASE=0xFF000000,SYS_MONITOR_BASE=0xFF000400 -eb_cpu5282_internal m68k mcf52x2 eb_cpu5282 BuS - eb_cpu5282:SYS_TEXT_BASE=0xF0000000,SYS_MONITOR_BASE=0xF0000418 -TASREG m68k mcf52x2 tasreg esd -M5208EVBE m68k mcf52x2 m5208evbe freescale -M5249EVB m68k mcf52x2 m5249evb freescale -M5253DEMO m68k mcf52x2 m5253demo freescale -M5253EVBE m68k mcf52x2 m5253evbe freescale -M5271EVB m68k mcf52x2 m5271evb freescale -M5272C3 m68k mcf52x2 m5272c3 freescale -M5275EVB m68k mcf52x2 m5275evb freescale -M5282EVB m68k mcf52x2 m5282evb freescale -astro_mcf5373l m68k mcf532x mcf5373l astro -M53017EVB m68k mcf532x m53017evb freescale -M5329AFEE m68k mcf532x m5329evb freescale - M5329EVB:NANDFLASH_SIZE=0 -M5329BFEE m68k mcf532x m5329evb freescale - M5329EVB:NANDFLASH_SIZE=16 -M5373EVB m68k mcf532x m5373evb freescale - M5373EVB:NANDFLASH_SIZE=16 -M54418TWR m68k mcf5445x m54418twr freescale - M54418TWR:CF_SBF,SYS_SERIAL_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=50000000 -M54418TWR_nand_mii m68k mcf5445x m54418twr freescale - M54418TWR:SYS_NAND_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=25000000 -M54418TWR_nand_rmii m68k mcf5445x m54418twr freescale - M54418TWR:SYS_NAND_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=50000000 -M54418TWR_nand_rmii_lowfreq m68k mcf5445x m54418twr freescale - M54418TWR:SYS_NAND_BOOT,LOW_MCFCLK,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=50000000 -M54418TWR_serial_mii m68k mcf5445x m54418twr freescale - M54418TWR:CF_SBF,SYS_SERIAL_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=25000000 -M54418TWR_serial_rmii m68k mcf5445x m54418twr freescale - M54418TWR:CF_SBF,SYS_SERIAL_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=50000000 -M54451EVB m68k mcf5445x m54451evb freescale - M54451EVB:SYS_TEXT_BASE=0x00000000,SYS_INPUT_CLKSRC=24000000 -M54451EVB_stmicro m68k mcf5445x m54451evb freescale - M54451EVB:CF_SBF,SYS_STMICRO_BOOT,SYS_TEXT_BASE=0x47e00000,SYS_INPUT_CLKSRC=24000000 -M54455EVB m68k mcf5445x m54455evb freescale - M54455EVB:SYS_ATMEL_BOOT,SYS_TEXT_BASE=0x04000000,SYS_INPUT_CLKSRC=33333333 -M54455EVB_a66 m68k mcf5445x m54455evb freescale - M54455EVB:SYS_ATMEL_BOOT,SYS_TEXT_BASE=0x04000000,SYS_INPUT_CLKSRC=66666666 -M54455EVB_i66 m68k mcf5445x m54455evb freescale - M54455EVB:SYS_INTEL_BOOT,SYS_TEXT_BASE=0x00000000,SYS_INPUT_CLKSRC=66666666 -M54455EVB_intel m68k mcf5445x m54455evb freescale - M54455EVB:SYS_INTEL_BOOT,SYS_TEXT_BASE=0x00000000,SYS_INPUT_CLKSRC=33333333 -M54455EVB_stm33 m68k mcf5445x m54455evb freescale - M54455EVB:SYS_STMICRO_BOOT,CF_SBF,SYS_TEXT_BASE=0x4FE00000,SYS_INPUT_CLKSRC=33333333 -M5475AFE m68k mcf547x_8x m547xevb freescale - M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64 -M5475BFE m68k mcf547x_8x m547xevb freescale - M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16 -M5475CFE m68k mcf547x_8x m547xevb freescale - M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16,SYS_VIDEO,SYS_USBCTRL -M5475DFE m68k mcf547x_8x m547xevb freescale - M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_USBCTRL -M5475EFE m68k mcf547x_8x m547xevb freescale - M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_VIDEO,SYS_USBCTRL -M5475FFE m68k mcf547x_8x m547xevb freescale - M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=32,SYS_VIDEO,SYS_USBCTRL,SYS_DRAMSZ1=64 -M5475GFE m68k mcf547x_8x m547xevb freescale - M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=4,SYS_DRAMSZ=64 -M5485AFE m68k mcf547x_8x m548xevb freescale - M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64 -M5485BFE m68k mcf547x_8x m548xevb freescale - M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16 -M5485CFE m68k mcf547x_8x m548xevb freescale - M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16,SYS_VIDEO,SYS_USBCTRL -M5485DFE m68k mcf547x_8x m548xevb freescale - M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_USBCTRL -M5485EFE m68k mcf547x_8x m548xevb freescale - M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_VIDEO,SYS_USBCTRL -M5485FFE m68k mcf547x_8x m548xevb freescale - M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=32,SYS_VIDEO,SYS_USBCTRL,SYS_DRAMSZ1=64 -M5485GFE m68k mcf547x_8x m548xevb freescale - M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=4,SYS_DRAMSZ=64 -M5485HFE m68k mcf547x_8x m548xevb freescale - M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16,SYS_VIDEO -microblaze-generic microblaze microblaze microblaze-generic xilinx -qemu_mips mips mips32 qemu-mips - - qemu-mips:SYS_BIG_ENDIAN -qemu_mipsel mips mips32 qemu-mips - - qemu-mips:SYS_LITTLE_ENDIAN -qemu_mips64 mips mips64 qemu-mips - - qemu-mips64:SYS_BIG_ENDIAN -qemu_mips64el mips mips64 qemu-mips - - qemu-mips64:SYS_LITTLE_ENDIAN -qemu_malta mips mips32 qemu-malta - - qemu-malta:MIPS32,SYS_BIG_ENDIAN -qemu_maltael mips mips32 qemu-malta - - qemu-malta:MIPS32,SYS_LITTLE_ENDIAN -vct_platinum mips mips32 vct micronas - vct:VCT_PLATINUM -vct_platinumavc mips mips32 vct micronas - vct:VCT_PLATINUMAVC -vct_platinumavc_onenand mips mips32 vct micronas - vct:VCT_PLATINUMAVC,VCT_ONENAND -vct_platinumavc_onenand_small mips mips32 vct micronas - vct:VCT_PLATINUMAVC,VCT_ONENAND,VCT_SMALL_IMAGE -vct_platinumavc_small mips mips32 vct micronas - vct:VCT_PLATINUMAVC,VCT_SMALL_IMAGE -vct_platinum_onenand mips mips32 vct micronas - vct:VCT_PLATINUM,VCT_ONENAND -vct_platinum_onenand_small mips mips32 vct micronas - vct:VCT_PLATINUM,VCT_ONENAND,VCT_SMALL_IMAGE -vct_platinum_small mips mips32 vct micronas - vct:VCT_PLATINUM,VCT_SMALL_IMAGE -vct_premium mips mips32 vct micronas - vct:VCT_PREMIUM -vct_premium_onenand mips mips32 vct micronas - vct:VCT_PREMIUM,VCT_ONENAND -vct_premium_onenand_small mips mips32 vct micronas - vct:VCT_PREMIUM,VCT_ONENAND,VCT_SMALL_IMAGE -vct_premium_small mips mips32 vct micronas - vct:VCT_PREMIUM,VCT_SMALL_IMAGE -dbau1000 mips mips32 dbau1x00 - au1x00 dbau1x00:DBAU1000 -dbau1100 mips mips32 dbau1x00 - au1x00 dbau1x00:DBAU1100 -dbau1500 mips mips32 dbau1x00 - au1x00 dbau1x00:DBAU1500 -dbau1550 mips mips32 dbau1x00 - au1x00 dbau1x00:DBAU1550 -dbau1550_el mips mips32 dbau1x00 - au1x00 dbau1x00:DBAU1550,SYS_LITTLE_ENDIAN -pb1000 mips mips32 pb1x00 - au1x00 pb1x00:PB1000 -incaip mips mips32 incaip - incaip -incaip_100MHz mips mips32 incaip - incaip incaip:CPU_CLOCK_RATE=100000000 -incaip_133MHz mips mips32 incaip - incaip incaip:CPU_CLOCK_RATE=133000000 -incaip_150MHz mips mips32 incaip - incaip incaip:CPU_CLOCK_RATE=150000000 -adp-ag101 nds32 n1213 adp-ag101 AndesTech ag101 -adp-ag101p nds32 n1213 adp-ag101p AndesTech ag101 -adp-ag102 nds32 n1213 adp-ag102 AndesTech ag102 -nios2-generic nios2 nios2 nios2-generic altera -PCI5441 nios2 nios2 pci5441 psyent -PK1C20 nios2 nios2 pk1c20 psyent -openrisc-generic openrisc or1200 openrisc-generic openrisc - -EVB64260 powerpc 74xx_7xx evb64260 - - EVB64260 -EVB64260_750CX powerpc 74xx_7xx evb64260 - - EVB64260 -P3G4 powerpc 74xx_7xx evb64260 -ppmc7xx powerpc 74xx_7xx -ZUMA powerpc 74xx_7xx evb64260 -ELPPC powerpc 74xx_7xx elppc eltec -CPCI750 powerpc 74xx_7xx cpci750 esd -mpc7448hpc2 powerpc 74xx_7xx mpc7448hpc2 freescale -DB64360 powerpc 74xx_7xx db64360 Marvell -DB64460 powerpc 74xx_7xx db64460 Marvell -p3m7448 powerpc 74xx_7xx p3mx prodrive - p3mx:P3M7448 -p3m750 powerpc 74xx_7xx p3mx prodrive - p3mx:P3M750 -pdm360ng powerpc mpc512x -aria powerpc mpc512x - davedenx -mecp5123 powerpc mpc512x - esd -mpc5121ads powerpc mpc512x mpc5121ads freescale -mpc5121ads_rev2 powerpc mpc512x mpc5121ads freescale - mpc5121ads:MPC5121ADS_REV2 -ac14xx powerpc mpc512x ac14xx ifm -cmi_mpc5xx powerpc mpc5xx cmi -PATI powerpc mpc5xx pati mpl -a3m071 powerpc mpc5xxx a3m071 -a4m072 powerpc mpc5xxx a4m072 -a4m2k powerpc mpc5xxx a3m071 - - a3m071:A4M2K -BC3450 powerpc mpc5xxx bc3450 -canmb powerpc mpc5xxx -cm5200 powerpc mpc5xxx -galaxy5200 powerpc mpc5xxx galaxy5200 - - galaxy5200:galaxy5200 -galaxy5200_LOWBOOT powerpc mpc5xxx galaxy5200 - - galaxy5200:galaxy5200_LOWBOOT -icecube_5200 powerpc mpc5xxx icecube - - IceCube -icecube_5200_DDR powerpc mpc5xxx icecube - - IceCube:MPC5200_DDR -icecube_5200_DDR_LOWBOOT powerpc mpc5xxx icecube - - IceCube:SYS_TEXT_BASE=0xFF800000,MPC5200_DDR -icecube_5200_DDR_LOWBOOT08 powerpc mpc5xxx icecube - - IceCube:SYS_TEXT_BASE=0xFF800000,MPC5200_DDR -icecube_5200_LOWBOOT powerpc mpc5xxx icecube - - IceCube:SYS_TEXT_BASE=0xFF000000 -icecube_5200_LOWBOOT08 powerpc mpc5xxx icecube - - IceCube:SYS_TEXT_BASE=0xFF800000 -inka4x0 powerpc mpc5xxx -ipek01 powerpc mpc5xxx -jupiter powerpc mpc5xxx -Lite5200 powerpc mpc5xxx icecube - - IceCube -lite5200b powerpc mpc5xxx icecube - - IceCube:MPC5200_DDR,LITE5200B -lite5200b_LOWBOOT powerpc mpc5xxx icecube - - IceCube:MPC5200_DDR,LITE5200B,SYS_TEXT_BASE=0xFF000000 -lite5200b_PM powerpc mpc5xxx icecube - - IceCube:MPC5200_DDR,LITE5200B,LITE5200B_PM -Lite5200_LOWBOOT powerpc mpc5xxx icecube - - IceCube:SYS_TEXT_BASE=0xFF000000 -Lite5200_LOWBOOT08 powerpc mpc5xxx icecube - - IceCube:SYS_TEXT_BASE=0xFF800000 -mcc200 powerpc mpc5xxx mcc200 - - mcc200 -mcc200_COM12 powerpc mpc5xxx mcc200 - - mcc200:CONSOLE_COM12 -mcc200_COM12_highboot powerpc mpc5xxx mcc200 - - mcc200:CONSOLE_COM12,SYS_TEXT_BASE=0xFFF00000 -mcc200_COM12_highboot_SDRAM powerpc mpc5xxx mcc200 - - mcc200:CONSOLE_COM12,SYS_TEXT_BASE=0xFFF00000,MCC200_SDRAM -mcc200_COM12_SDRAM powerpc mpc5xxx mcc200 - - mcc200:CONSOLE_COM12,MCC200_SDRAM -mcc200_highboot powerpc mpc5xxx mcc200 - - mcc200:SYS_TEXT_BASE=0xFFF00000 -mcc200_highboot_SDRAM powerpc mpc5xxx mcc200 - - mcc200:SYS_TEXT_BASE=0xFFF00000,MCC200_SDRAM -mcc200_SDRAM powerpc mpc5xxx mcc200 - - mcc200:MCC200_SDRAM -motionpro powerpc mpc5xxx -munices powerpc mpc5xxx -PM520 powerpc mpc5xxx pm520 -PM520_DDR powerpc mpc5xxx pm520 - - PM520:MPC5200_DDR -PM520_ROMBOOT powerpc mpc5xxx pm520 - - PM520:BOOT_ROM -PM520_ROMBOOT_DDR powerpc mpc5xxx pm520 - - PM520:MPC5200_DDR,BOOT_ROM -prs200 powerpc mpc5xxx mcc200 - - mcc200:PRS200,MCC200_SDRAM -prs200_DDR powerpc mpc5xxx mcc200 - - mcc200:PRS200 -prs200_highboot powerpc mpc5xxx mcc200 - - mcc200:PRS200,SYS_TEXT_BASE=0xFFF00000,MCC200_SDRAM -prs200_highboot_DDR powerpc mpc5xxx mcc200 - - mcc200:PRS200,SYS_TEXT_BASE=0xFFF00000 -Total5200 powerpc mpc5xxx total5200 - - Total5200:TOTAL5200_REV=1 -Total5200_lowboot powerpc mpc5xxx total5200 - - Total5200:TOTAL5200_REV=1,SYS_TEXT_BASE=0xFE000000 -Total5200_Rev2 powerpc mpc5xxx total5200 - - Total5200:TOTAL5200_REV=2 -Total5200_Rev2_lowboot powerpc mpc5xxx total5200 - - Total5200:TOTAL5200_REV=2,SYS_TEXT_BASE=0xFE000000 -v38b powerpc mpc5xxx -EVAL5200 powerpc mpc5xxx top5200 emk - TOP5200:EVAL5200 -MINI5200 powerpc mpc5xxx top5200 emk - TOP5200:MINI5200 -TOP5200 powerpc mpc5xxx top5200 emk - TOP5200:TOP5200 -cpci5200 powerpc mpc5xxx - esd -mecp5200 powerpc mpc5xxx - esd -pf5200 powerpc mpc5xxx - esd -O2D powerpc mpc5xxx o2dnt2 ifm - o2d -O2D300 powerpc mpc5xxx o2dnt2 ifm - o2d300 -O2DNT2 powerpc mpc5xxx o2dnt2 ifm - o2dnt2 -O2DNT2_RAMBOOT powerpc mpc5xxx o2dnt2 ifm - o2dnt2:SYS_TEXT_BASE=0x00100000 -O2I powerpc mpc5xxx o2dnt2 ifm - o2i -O2MNT powerpc mpc5xxx o2dnt2 ifm - o2mnt -O2MNT_O2M110 powerpc mpc5xxx o2dnt2 ifm - o2mnt:IFM_SENSOR_TYPE="O2M110" -O2MNT_O2M112 powerpc mpc5xxx o2dnt2 ifm - o2mnt:IFM_SENSOR_TYPE="O2M112" -O2MNT_O2M113 powerpc mpc5xxx o2dnt2 ifm - o2mnt:IFM_SENSOR_TYPE="O2M113" -O3DNT powerpc mpc5xxx o2dnt2 ifm - o3dnt -digsy_mtc powerpc mpc5xxx digsy_mtc intercontrol -digsy_mtc_RAMBOOT powerpc mpc5xxx digsy_mtc intercontrol - digsy_mtc:SYS_TEXT_BASE=0x00100000 -digsy_mtc_rev5 powerpc mpc5xxx digsy_mtc intercontrol - digsy_mtc:DIGSY_REV5 -digsy_mtc_rev5_RAMBOOT powerpc mpc5xxx digsy_mtc intercontrol - digsy_mtc:SYS_TEXT_BASE=0x00100000,DIGSY_REV5 -hmi1001 powerpc mpc5xxx - manroland -mucmc52 powerpc mpc5xxx - manroland -uc101 powerpc mpc5xxx - manroland -MVBC_P powerpc mpc5xxx mvbc_p matrix_vision - MVBC_P:MVBC_P -MVSMR powerpc mpc5xxx mvsmr matrix_vision -pcm030 powerpc mpc5xxx pcm030 phytec - pcm030 -pcm030_LOWBOOT powerpc mpc5xxx pcm030 phytec - pcm030:SYS_TEXT_BASE=0xFF000000 -aev powerpc mpc5xxx tqm5200 tqc -cam5200 powerpc mpc5xxx tqm5200 tqc - TQM5200:CAM5200,TQM5200S,TQM5200_B -cam5200_niosflash powerpc mpc5xxx tqm5200 tqc - TQM5200:CAM5200,TQM5200S,TQM5200_B,CAM5200_NIOSFLASH -charon powerpc mpc5xxx tqm5200 tqc - charon -fo300 powerpc mpc5xxx tqm5200 tqc - TQM5200:FO300 -MiniFAP powerpc mpc5xxx tqm5200 tqc - TQM5200:MINIFAP -TB5200 powerpc mpc5xxx tqm5200 tqc -TB5200_B powerpc mpc5xxx tqm5200 tqc - TB5200:TQM5200_B -TQM5200 powerpc mpc5xxx tqm5200 tqc - TQM5200: -TQM5200_B powerpc mpc5xxx tqm5200 tqc - TQM5200:TQM5200_B -TQM5200_B_HIGHBOOT powerpc mpc5xxx tqm5200 tqc - TQM5200:TQM5200_B,SYS_TEXT_BASE=0xFFF00000 -TQM5200S powerpc mpc5xxx tqm5200 tqc - TQM5200:TQM5200_B,TQM5200S -TQM5200S_HIGHBOOT powerpc mpc5xxx tqm5200 tqc - TQM5200:TQM5200_B,TQM5200S,SYS_TEXT_BASE=0xFFF00000 -TQM5200_STK100 powerpc mpc5xxx tqm5200 tqc - TQM5200:STK52XX_REV100 -A3000 powerpc mpc824x a3000 -CPC45 powerpc mpc824x cpc45 - - CPC45 -CPC45_ROMBOOT powerpc mpc824x cpc45 - - CPC45:BOOT_ROM -CU824 powerpc mpc824x cu824 -eXalion powerpc mpc824x eXalion -HIDDEN_DRAGON powerpc mpc824x hidden_dragon -linkstation_HGLAN powerpc mpc824x linkstation - - linkstation:HGLAN=1 -MOUSSE powerpc mpc824x mousse -MUSENKI powerpc mpc824x musenki -MVBLUE powerpc mpc824x mvblue -PN62 powerpc mpc824x pn62 -Sandpoint8240 powerpc mpc824x sandpoint -Sandpoint8245 powerpc mpc824x sandpoint -utx8245 powerpc mpc824x -debris powerpc mpc824x - etin -kvme080 powerpc mpc824x - etin -atc powerpc mpc8260 -cogent_mpc8260 powerpc mpc8260 cogent -CPU86 powerpc mpc8260 cpu86 - - CPU86 -CPU86_ROMBOOT powerpc mpc8260 cpu86 - - CPU86:BOOT_ROM -CPU87 powerpc mpc8260 cpu87 - - CPU87 -CPU87_ROMBOOT powerpc mpc8260 cpu87 - - CPU87:BOOT_ROM -ep8248 powerpc mpc8260 ep8248 -ep8248E powerpc mpc8260 ep8248 - - ep8248 -ep8260 powerpc mpc8260 -ep82xxm powerpc mpc8260 -gw8260 powerpc mpc8260 -hymod powerpc mpc8260 -IDS8247 powerpc mpc8260 ids8247 -IPHASE4539 powerpc mpc8260 iphase4539 -ISPAN powerpc mpc8260 ispan -ISPAN_REVB powerpc mpc8260 ispan - - ISPAN:SYS_REV_B -muas3001 powerpc mpc8260 muas3001 -muas3001_dev powerpc mpc8260 muas3001 - - muas3001:MUAS_DEV_BOARD -PM825 powerpc mpc8260 pm826 - - PM826:PCI,SYS_TEXT_BASE=0xFF000000 -PM825_BIGFLASH powerpc mpc8260 pm826 - - PM826:PCI,FLASH_32MB,SYS_TEXT_BASE=0x40000000 -PM825_ROMBOOT powerpc mpc8260 pm826 - - PM826:PCI,BOOT_ROM,SYS_TEXT_BASE=0xFF800000 -PM825_ROMBOOT_BIGFLASH powerpc mpc8260 pm826 - - PM826:PCI,BOOT_ROM,FLASH_32MB,SYS_TEXT_BASE=0xFF800000 -PM826 powerpc mpc8260 pm826 - - PM826:SYS_TEXT_BASE=0xFF000000 -PM826_BIGFLASH powerpc mpc8260 pm826 - - PM826:FLASH_32MB,SYS_TEXT_BASE=0x40000000 -PM826_ROMBOOT powerpc mpc8260 pm826 - - PM826:BOOT_ROM,SYS_TEXT_BASE=0xFF800000 -PM826_ROMBOOT_BIGFLASH powerpc mpc8260 pm826 - - PM826:BOOT_ROM,FLASH_32MB,SYS_TEXT_BASE=0xFF800000 -PM828 powerpc mpc8260 pm828 - - PM828 -PM828_PCI powerpc mpc8260 pm828 - - PM828:PCI -PM828_ROMBOOT powerpc mpc8260 pm828 - - PM828:BOOT_ROM,SYS_TEXT_BASE=0xFF800000 -PM828_ROMBOOT_PCI powerpc mpc8260 pm828 - - PM828:PCI,BOOT_ROM,SYS_TEXT_BASE=0xFF800000 -ppmc8260 powerpc mpc8260 -Rattler powerpc mpc8260 rattler - - Rattler -Rattler8248 powerpc mpc8260 rattler - - Rattler:MPC8248 -RPXsuper powerpc mpc8260 rpxsuper -rsdproto powerpc mpc8260 -sacsng powerpc mpc8260 -ZPC1900 powerpc mpc8260 zpc1900 -MPC8260ADS powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS -MPC8260ADS_33MHz powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS,8260_CLKIN=33000000 -MPC8260ADS_33MHz_lowboot powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS,8260_CLKIN=33000000,SYS_TEXT_BASE=0xFF800000 -MPC8260ADS_40MHz powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS,8260_CLKIN=40000000 -MPC8260ADS_40MHz_lowboot powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS,8260_CLKIN=40000000,SYS_TEXT_BASE=0xFF800000 -MPC8260ADS_lowboot powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS,SYS_TEXT_BASE=0xFF800000 -MPC8266ADS powerpc mpc8260 mpc8266ads freescale -MPC8272ADS powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_8272ADS -MPC8272ADS_lowboot powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_8272ADS,SYS_TEXT_BASE=0xFF800000 -PQ2FADS powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS -PQ2FADS_lowboot powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,SYS_TEXT_BASE=0xFF800000 -PQ2FADS-VR powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,8260_CLKIN=66000000 -PQ2FADS-VR_lowboot powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,8260_CLKIN=66000000,SYS_TEXT_BASE=0xFF800000 -PQ2FADS-ZU powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS -PQ2FADS-ZU_66MHz powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,8260_CLKIN=66000000 -PQ2FADS-ZU_66MHz_lowboot powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,8260_CLKIN=66000000,SYS_TEXT_BASE=0xFF800000 -PQ2FADS-ZU_lowboot powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,SYS_TEXT_BASE=0xFF800000 -VoVPN-GW_66MHz powerpc mpc8260 vovpn-gw funkwerk - VoVPN-GW:CLKIN_66MHz -mgcoge powerpc mpc8260 km82xx keymile - km82xx:MGCOGE -mgcoge3ne powerpc mpc8260 km82xx keymile - km82xx:MGCOGE3NE -TQM8255_AA powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8255,300MHz -TQM8260_AA powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8260,200MHz -TQM8260_AB powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8260,200MHz,L2_CACHE,BUSMODE_60x -TQM8260_AC powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8260,200MHz,L2_CACHE,BUSMODE_60x -TQM8260_AD powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8260,300MHz,BUSMODE_60x -TQM8260_AE powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8260,266MHz -TQM8260_AF powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8260,300MHz,BUSMODE_60x -TQM8260_AG powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8260,300MHz -TQM8260_AH powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8260,300MHz,L2_CACHE,BUSMODE_60x -TQM8260_AI powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8260,300MHz,BUSMODE_60x -TQM8265_AA powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8265,300MHz,BUSMODE_60x -TQM8272 powerpc mpc8260 tqm8272 tqc -mpc8308_p1m powerpc mpc83xx -sbc8349 powerpc mpc83xx sbc8349 - - sbc8349 -sbc8349_PCI_33 powerpc mpc83xx sbc8349 - - sbc8349:PCI,PCI_33M -sbc8349_PCI_66 powerpc mpc83xx sbc8349 - - sbc8349:PCI,PCI_66M -ve8313 powerpc mpc83xx ve8313 -caddy2 powerpc mpc83xx vme8349 esd - vme8349:CADDY2 -vme8349 powerpc mpc83xx vme8349 esd - vme8349 -MPC8308RDB powerpc mpc83xx mpc8308rdb freescale -MPC8313ERDB_33 powerpc mpc83xx mpc8313erdb freescale - MPC8313ERDB:SYS_33MHZ -MPC8313ERDB_66 powerpc mpc83xx mpc8313erdb freescale - MPC8313ERDB:SYS_66MHZ -MPC8313ERDB_NAND_33 powerpc mpc83xx mpc8313erdb freescale - MPC8313ERDB:SYS_33MHZ,NAND -MPC8313ERDB_NAND_66 powerpc mpc83xx mpc8313erdb freescale - MPC8313ERDB:SYS_66MHZ,NAND -MPC8315ERDB powerpc mpc83xx mpc8315erdb freescale - MPC8315ERDB -MPC8315ERDB_NAND powerpc mpc83xx mpc8315erdb freescale - MPC8315ERDB:NAND_U_BOOT -MPC8323ERDB powerpc mpc83xx mpc8323erdb freescale -MPC832XEMDS powerpc mpc83xx mpc832xemds freescale - MPC832XEMDS: -MPC832XEMDS_ATM powerpc mpc83xx mpc832xemds freescale - MPC832XEMDS:PQ_MDS_PIB=1,PQ_MDS_PIB_ATM=1 -MPC832XEMDS_HOST_33 powerpc mpc83xx mpc832xemds freescale - MPC832XEMDS:PCI,PCI_33M,PQ_MDS_PIB=1 -MPC832XEMDS_HOST_66 powerpc mpc83xx mpc832xemds freescale - MPC832XEMDS:PCI,PCI_66M,PQ_MDS_PIB=1 -MPC832XEMDS_SLAVE powerpc mpc83xx mpc832xemds freescale - MPC832XEMDS:PCI,PCISLAVE -MPC8349EMDS powerpc mpc83xx mpc8349emds freescale -MPC8349ITX powerpc mpc83xx mpc8349itx freescale - MPC8349ITX:MPC8349ITX -MPC8349ITXGP powerpc mpc83xx mpc8349itx freescale - MPC8349ITX:MPC8349ITXGP,SYS_TEXT_BASE=0xFE000000 -MPC8349ITX_LOWBOOT powerpc mpc83xx mpc8349itx freescale - MPC8349ITX:MPC8349ITX,SYS_TEXT_BASE=0xFE000000 -MPC8360EMDS_33 powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_33MHZ -MPC8360EMDS_33_ATM powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_33MHZ,PQ_MDS_PIB=1,PQ_MDS_PIB_ATM=1 -MPC8360EMDS_33_HOST_33 powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_33MHZ,PCI,PCI_33M,PQ_MDS_PIB=1 -MPC8360EMDS_33_HOST_66 powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_33MHZ,PCI,PCI_66M,PQ_MDS_PIB=1 -MPC8360EMDS_33_SLAVE powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_33MHZ,PCI,PCISLAVE -MPC8360EMDS_66 powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_66MHZ -MPC8360EMDS_66_ATM powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_66MHZ,PQ_MDS_PIB=1,PQ_MDS_PIB_ATM=1 -MPC8360EMDS_66_HOST_33 powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_66MHZ,PCI,PCI_33M,PQ_MDS_PIB=1 -MPC8360EMDS_66_HOST_66 powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_66MHZ,PCI,PCI_66M,PQ_MDS_PIB=1 -MPC8360EMDS_66_SLAVE powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_66MHZ,PCI,PCISLAVE -MPC8360ERDK powerpc mpc83xx mpc8360erdk freescale - MPC8360ERDK -MPC8360ERDK_33 powerpc mpc83xx mpc8360erdk freescale - MPC8360ERDK:CLKIN_33MHZ -MPC8360ERDK_66 powerpc mpc83xx mpc8360erdk freescale - MPC8360ERDK -MPC837XEMDS powerpc mpc83xx mpc837xemds freescale - MPC837XEMDS -MPC837XEMDS_HOST powerpc mpc83xx mpc837xemds freescale - MPC837XEMDS:PCI -MPC837XERDB powerpc mpc83xx mpc837xerdb freescale -kmcoge5ne powerpc mpc83xx km83xx keymile - km8360:KMCOGE5NE -kmeter1 powerpc mpc83xx km83xx keymile - km8360:KMETER1 -MERGERBOX powerpc mpc83xx mergerbox matrix_vision -MVBLM7 powerpc mpc83xx mvblm7 matrix_vision -SIMPC8313_LP powerpc mpc83xx simpc8313 sheldon - SIMPC8313:NAND_LP -SIMPC8313_SP powerpc mpc83xx simpc8313 sheldon - SIMPC8313:NAND_SP -TQM834x powerpc mpc83xx tqm834x tqc -suvd3 powerpc mpc83xx km83xx keymile - suvd3:SUVD3 -kmvect1 powerpc mpc83xx km83xx keymile - suvd3:KMVECT1 -tuge1 powerpc mpc83xx km83xx keymile - tuxx1:TUGE1 -tuxx1 powerpc mpc83xx km83xx keymile - tuxx1:TUXX1 -kmopti2 powerpc mpc83xx km83xx keymile - tuxx1:KMOPTI2 -kmsupx5 powerpc mpc83xx km83xx keymile - tuxx1:KMSUPX5 -sbc8548 powerpc mpc85xx sbc8548 - - sbc8548 -sbc8548_PCI_33 powerpc mpc85xx sbc8548 - - sbc8548:PCI,33 -sbc8548_PCI_33_PCIE powerpc mpc85xx sbc8548 - - sbc8548:PCI,33,PCIE -sbc8548_PCI_66 powerpc mpc85xx sbc8548 - - sbc8548:PCI,66 -sbc8548_PCI_66_PCIE powerpc mpc85xx sbc8548 - - sbc8548:PCI,66,PCIE -socrates powerpc mpc85xx socrates -HWW1U1A powerpc mpc85xx hww1u1a exmeritus -MPC8536DS powerpc mpc85xx mpc8536ds freescale - MPC8536DS -MPC8536DS_36BIT powerpc mpc85xx mpc8536ds freescale - MPC8536DS:36BIT -MPC8536DS_NAND powerpc mpc85xx mpc8536ds freescale - MPC8536DS:NAND -MPC8536DS_SDCARD powerpc mpc85xx mpc8536ds freescale - MPC8536DS:SDCARD -MPC8536DS_SPIFLASH powerpc mpc85xx mpc8536ds freescale - MPC8536DS:SPIFLASH -MPC8540ADS powerpc mpc85xx mpc8540ads freescale -MPC8541CDS powerpc mpc85xx mpc8541cds freescale - MPC8541CDS -MPC8541CDS_legacy powerpc mpc85xx mpc8541cds freescale - MPC8541CDS:LEGACY -MPC8544DS powerpc mpc85xx mpc8544ds freescale -MPC8548CDS powerpc mpc85xx mpc8548cds freescale - MPC8548CDS -MPC8548CDS_36BIT powerpc mpc85xx mpc8548cds freescale - MPC8548CDS:36BIT -MPC8548CDS_legacy powerpc mpc85xx mpc8548cds freescale - MPC8548CDS:LEGACY -MPC8555CDS powerpc mpc85xx mpc8555cds freescale - MPC8555CDS -MPC8555CDS_legacy powerpc mpc85xx mpc8555cds freescale - MPC8555CDS:LEGACY -MPC8560ADS powerpc mpc85xx mpc8560ads freescale -MPC8568MDS powerpc mpc85xx mpc8568mds freescale -MPC8569MDS powerpc mpc85xx mpc8569mds freescale - MPC8569MDS -MPC8569MDS_ATM powerpc mpc85xx mpc8569mds freescale - MPC8569MDS:ATM -MPC8569MDS_NAND powerpc mpc85xx mpc8569mds freescale - MPC8569MDS:NAND -MPC8572DS powerpc mpc85xx mpc8572ds freescale - MPC8572DS -MPC8572DS_36BIT powerpc mpc85xx mpc8572ds freescale - MPC8572DS:36BIT -MPC8572DS_NAND powerpc mpc85xx mpc8572ds freescale - MPC8572DS:NAND -P1010RDB_36BIT_NAND powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT,NAND -P1010RDB_36BIT_NAND_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT,NAND_SECBOOT,SECURE_BOOT -P1010RDB_36BIT_NOR powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT -P1010RDB_36BIT_NOR_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT,SECURE_BOOT -P1010RDB_36BIT_SDCARD powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT,SDCARD -P1010RDB_36BIT_SPIFLASH powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT,SPIFLASH -P1010RDB_36BIT_SPIFLASH_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT,SPIFLASH,SECURE_BOOT -P1010RDB_NAND powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,NAND -P1010RDB_NAND_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,NAND_SECBOOT,SECURE_BOOT -P1010RDB_NOR powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB -P1010RDB_NOR_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,SECURE_BOOT -P1010RDB_SDCARD powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,SDCARD -P1010RDB_SPIFLASH powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,SPIFLASH -P1010RDB_SPIFLASH_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,SPIFLASH,SECURE_BOOT -P1011RDB powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1011RDB -P1011RDB_36BIT powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1011RDB,36BIT -P1011RDB_36BIT_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1011RDB,36BIT,SDCARD -P1011RDB_36BIT_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1011RDB,36BIT,SPIFLASH -P1011RDB_NAND powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1011RDB,NAND -P1011RDB_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1011RDB,SDCARD -P1011RDB_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1011RDB,SPIFLASH -P1020MBG-PC powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020MBG -P1020MBG-PC_36BIT powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020MBG,36BIT -P1020MBG-PC_36BIT_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020MBG,SDCARD,36BIT -P1020MBG-PC_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020MBG,SDCARD -P1020RDB powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1020RDB -P1020RDB_36BIT powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1020RDB,36BIT -P1020RDB_36BIT_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1020RDB,36BIT,SDCARD -P1020RDB_36BIT_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1020RDB,36BIT,SPIFLASH -P1020RDB_NAND powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1020RDB,NAND -P1020RDB-PC powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB -P1020RDB-PC_36BIT powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB,36BIT -P1020RDB-PC_36BIT_NAND powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB,36BIT,NAND -P1020RDB-PC_36BIT_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB,36BIT,SDCARD -P1020RDB-PC_36BIT_SPIFLASH powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB,36BIT,SPIFLASH -P1020RDB-PC_NAND powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB,NAND -P1020RDB-PC_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB,SDCARD -P1020RDB-PC_SPIFLASH powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB,SPIFLASH -P1020RDB_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1020RDB,SDCARD -P1020RDB_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1020RDB,SPIFLASH -P1020UTM-PC powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020UTM -P1020UTM-PC_36BIT powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020UTM,36BIT -P1020UTM-PC_36BIT_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020UTM,36BIT,SDCARD -P1020UTM-PC_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020UTM,SDCARD -P1021RDB-PC powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1021RDB -P1021RDB-PC_36BIT powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1021RDB,36BIT -P1021RDB-PC_36BIT_NAND powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1021RDB,36BIT,NAND -P1021RDB-PC_36BIT_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1021RDB,36BIT,SDCARD -P1021RDB-PC_36BIT_SPIFLASH powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1021RDB,36BIT,SPIFLASH -P1021RDB-PC_NAND powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1021RDB,NAND -P1021RDB-PC_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1021RDB,SDCARD -P1021RDB-PC_SPIFLASH powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1021RDB,SPIFLASH -P1022DS powerpc mpc85xx p1022ds freescale -P1022DS_NAND powerpc mpc85xx p1022ds freescale - P1022DS:NAND -P1022DS_36BIT_NAND powerpc mpc85xx p1022ds freescale - P1022DS:36BIT,NAND -P1022DS_SPIFLASH powerpc mpc85xx p1022ds freescale - P1022DS:SPIFLASH -P1022DS_36BIT_SPIFLASH powerpc mpc85xx p1022ds freescale - P1022DS:36BIT,SPIFLASH -P1022DS_SDCARD powerpc mpc85xx p1022ds freescale - P1022DS:SDCARD -P1022DS_36BIT_SDCARD powerpc mpc85xx p1022ds freescale - P1022DS:36BIT,SDCARD -P1022DS_36BIT powerpc mpc85xx p1022ds freescale - P1022DS:36BIT -P1023RDB powerpc mpc85xx p1023rdb freescale - P1023RDB -P1023RDS powerpc mpc85xx p1023rds freescale - P1023RDS -P1023RDS_NAND powerpc mpc85xx p1023rds freescale - P1023RDS:NAND -P1024RDB powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1024RDB -P1024RDB_36BIT powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1024RDB,36BIT -P1024RDB_NAND powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1024RDB,NAND -P1024RDB_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1024RDB,SDCARD -P1024RDB_SPIFLASH powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1024RDB,SPIFLASH -P1025RDB powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1025RDB -P1025RDB_36BIT powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1025RDB,36BIT -P1025RDB_NAND powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1025RDB,NAND -P1025RDB_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1025RDB,SDCARD -P1025RDB_SPIFLASH powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1025RDB,SPIFLASH -P2010RDB powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2010RDB -P2010RDB_36BIT powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2010RDB,36BIT -P2010RDB_36BIT_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2010RDB,36BIT,SDCARD -P2010RDB_36BIT_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2010RDB,36BIT,SPIFLASH -P2010RDB_NAND powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2010RDB,NAND -P2010RDB_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2010RDB,SDCARD -P2010RDB_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2010RDB,SPIFLASH -P2020COME_SDCARD powerpc mpc85xx p2020come freescale - P2020COME:SDCARD -P2020COME_SPIFLASH powerpc mpc85xx p2020come freescale - P2020COME:SPIFLASH -P2020DS powerpc mpc85xx p2020ds freescale -P2020DS_36BIT powerpc mpc85xx p2020ds freescale - P2020DS:36BIT -P2020DS_DDR2 powerpc mpc85xx p2020ds freescale - P2020DS:DDR2 -P2020DS_SDCARD powerpc mpc85xx p2020ds freescale - P2020DS:SDCARD -P2020DS_SPIFLASH powerpc mpc85xx p2020ds freescale - P2020DS:SPIFLASH -P2020RDB powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020RDB -P2020RDB_36BIT powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020RDB,36BIT -P2020RDB_36BIT_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020RDB,36BIT,SDCARD -P2020RDB_36BIT_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020RDB,36BIT,SPIFLASH -P2020RDB_NAND powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020RDB,NAND -P2020RDB-PC powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P2020RDB -P2020RDB-PC_36BIT powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P2020RDB,36BIT -P2020RDB-PC_36BIT_NAND powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P2020RDB,36BIT,NAND -P2020RDB-PC_36BIT_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P2020RDB,36BIT,SDCARD -P2020RDB-PC_36BIT_SPIFLASH powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P2020RDB,36BIT,SPIFLASH -P2020RDB-PC_NAND powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P2020RDB,NAND -P2020RDB-PC_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P2020RDB,SDCARD -P2020RDB-PC_SPIFLASH powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P2020RDB,SPIFLASH -P2020RDB_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020RDB,SDCARD -P2020RDB_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020RDB,SPIFLASH -P2041RDB powerpc mpc85xx p2041rdb freescale -P2041RDB_NAND powerpc mpc85xx p2041rdb freescale - P2041RDB:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 -P2041RDB_SDCARD powerpc mpc85xx p2041rdb freescale - P2041RDB:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 -P2041RDB_SECURE_BOOT powerpc mpc85xx p2041rdb freescale - P2041RDB:SECURE_BOOT -P2041RDB_SPIFLASH powerpc mpc85xx p2041rdb freescale - P2041RDB:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -P2041RDB_SRIO_PCIE_BOOT powerpc mpc85xx p2041rdb freescale - P2041RDB:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 -P3041DS powerpc mpc85xx corenet_ds freescale -P3041DS_NAND powerpc mpc85xx corenet_ds freescale - P3041DS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 -P3041DS_SDCARD powerpc mpc85xx corenet_ds freescale - P3041DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 -P3041DS_SECURE_BOOT powerpc mpc85xx corenet_ds freescale - P3041DS:SECURE_BOOT -P3041DS_SPIFLASH powerpc mpc85xx corenet_ds freescale - P3041DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -P3041DS_SRIO_PCIE_BOOT powerpc mpc85xx corenet_ds freescale - P3041DS:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 -P4080DS powerpc mpc85xx corenet_ds freescale -P4080DS_SDCARD powerpc mpc85xx corenet_ds freescale - P4080DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 -P4080DS_SECURE_BOOT powerpc mpc85xx corenet_ds freescale - P4080DS:SECURE_BOOT -P4080DS_SPIFLASH powerpc mpc85xx corenet_ds freescale - P4080DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -P4080DS_SRIO_PCIE_BOOT powerpc mpc85xx corenet_ds freescale - P4080DS:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 -P5020DS powerpc mpc85xx corenet_ds freescale -P5020DS_NAND powerpc mpc85xx corenet_ds freescale - P5020DS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 -P5020DS_SDCARD powerpc mpc85xx corenet_ds freescale - P5020DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 -P5020DS_SECURE_BOOT powerpc mpc85xx corenet_ds freescale - P5020DS:SECURE_BOOT -P5020DS_SPIFLASH powerpc mpc85xx corenet_ds freescale - P5020DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -P5020DS_SRIO_PCIE_BOOT powerpc mpc85xx corenet_ds freescale - P5020DS:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 -P5040DS powerpc mpc85xx corenet_ds freescale -P5040DS_NAND powerpc mpc85xx corenet_ds freescale - P5040DS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 -P5040DS_SDCARD powerpc mpc85xx corenet_ds freescale - P5040DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 -P5040DS_SPIFLASH powerpc mpc85xx corenet_ds freescale - P5040DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -BSC9131RDB_SPIFLASH powerpc mpc85xx bsc9131rdb freescale - BSC9131RDB:BSC9131RDB,SPIFLASH -BSC9131RDB_SPIFLASH_SYSCLK100 powerpc mpc85xx bsc9131rdb freescale - BSC9131RDB:BSC9131RDB,SPIFLASH,SYS_CLK_100 -BSC9131RDB_NAND powerpc mpc85xx bsc9131rdb freescale - BSC9131RDB:BSC9131RDB,NAND -BSC9131RDB_NAND_SYSCLK100 powerpc mpc85xx bsc9131rdb freescale - BSC9131RDB:BSC9131RDB,NAND,SYS_CLK_100 -BSC9132QDS_NOR_DDRCLK100 powerpc mpc85xx bsc9132qds freescale - BSC9132QDS:BSC9132QDS,SYS_CLK_100_DDR_100 -BSC9132QDS_NOR_DDRCLK133 powerpc mpc85xx bsc9132qds freescale - BSC9132QDS:BSC9132QDS,SYS_CLK_100_DDR_133 -BSC9132QDS_NAND_DDRCLK100 powerpc mpc85xx bsc9132qds freescale - BSC9132QDS:BSC9132QDS,NAND,SYS_CLK_100_DDR_100 -BSC9132QDS_NAND_DDRCLK133 powerpc mpc85xx bsc9132qds freescale - BSC9132QDS:BSC9132QDS,NAND,SYS_CLK_100_DDR_133 -BSC9132QDS_SDCARD_DDRCLK100 powerpc mpc85xx bsc9132qds freescale - BSC9132QDS:BSC9132QDS,SDCARD,SYS_CLK_100_DDR_100 -BSC9132QDS_SDCARD_DDRCLK133 powerpc mpc85xx bsc9132qds freescale - BSC9132QDS:BSC9132QDS,SDCARD,SYS_CLK_100_DDR_133 -BSC9132QDS_SPIFLASH_DDRCLK100 powerpc mpc85xx bsc9132qds freescale - BSC9132QDS:BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_100 -BSC9132QDS_SPIFLASH_DDRCLK133 powerpc mpc85xx bsc9132qds freescale - BSC9132QDS:BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_133 -controlcenterd_36BIT_SDCARD powerpc mpc85xx p1022 gdsys - controlcenterd:36BIT,SDCARD -controlcenterd_36BIT_SDCARD_DEVELOP powerpc mpc85xx p1022 gdsys - controlcenterd:36BIT,SDCARD,DEVELOP -controlcenterd_TRAILBLAZER powerpc mpc85xx p1022 gdsys - controlcenterd:TRAILBLAZER,SPIFLASH -controlcenterd_TRAILBLAZER_DEVELOP powerpc mpc85xx p1022 gdsys - controlcenterd:TRAILBLAZER,SPIFLASH,DEVELOP -stxgp3 powerpc mpc85xx stxgp3 stx -stxssa powerpc mpc85xx stxssa stx - stxssa -stxssa_4M powerpc mpc85xx stxssa stx - stxssa:STXSSA_4M -T4240QDS powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4240 -T4240QDS_SDCARD powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4240,RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 -T4240QDS_SPIFLASH powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4240,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -T4240QDS_SRIO_PCIE_BOOT powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4240,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 -T4160QDS powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4160 -T4160QDS_SDCARD powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4160,RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 -T4160QDS_SPIFLASH powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4160,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -B4860QDS powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4860 -B4860QDS_NAND powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4860,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 -B4860QDS_SPIFLASH powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4860,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -B4860QDS_SRIO_PCIE_BOOT powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4860,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 -B4420QDS powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4420 -B4420QDS_NAND powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4420,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 -B4420QDS_SPIFLASH powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4420,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -xpedite520x powerpc mpc85xx - xes -xpedite537x powerpc mpc85xx - xes -xpedite550x powerpc mpc85xx - xes -sbc8641d powerpc mpc86xx -MPC8610HPCD powerpc mpc86xx mpc8610hpcd freescale -MPC8641HPCN powerpc mpc86xx mpc8641hpcn freescale - MPC8641HPCN -MPC8641HPCN_36BIT powerpc mpc86xx mpc8641hpcn freescale - MPC8641HPCN:PHYS_64BIT -xpedite517x powerpc mpc86xx - xes -Adder powerpc mpc8xx adder -Adder87x powerpc mpc8xx adder - - Adder -AdderII powerpc mpc8xx adder - - Adder:MPC852T -AdderUSB powerpc mpc8xx adder - - Adder -ADS860 powerpc mpc8xx fads -cogent_mpc8xx powerpc mpc8xx cogent -ESTEEM192E powerpc mpc8xx esteem192e -FADS823 powerpc mpc8xx fads -FADS850SAR powerpc mpc8xx fads -FADS860T powerpc mpc8xx fads -FLAGADM powerpc mpc8xx flagadm -GEN860T powerpc mpc8xx gen860t -GEN860T_SC powerpc mpc8xx gen860t - - GEN860T:SC -GENIETV powerpc mpc8xx genietv -hermes powerpc mpc8xx -ICU862 powerpc mpc8xx icu862 -ICU862_100MHz powerpc mpc8xx icu862 - - ICU862:100MHz -IP860 powerpc mpc8xx ip860 -IVML24 powerpc mpc8xx ivm - - IVML24:IVML24_16M -IVML24_128 powerpc mpc8xx ivm - - IVML24:IVML24_32M -IVML24_256 powerpc mpc8xx ivm - - IVML24:IVML24_64M -IVMS8 powerpc mpc8xx ivm - - IVMS8:IVMS8_16M -IVMS8_128 powerpc mpc8xx ivm - - IVMS8:IVMS8_32M -IVMS8_256 powerpc mpc8xx ivm - - IVMS8:IVMS8_64M -lwmon powerpc mpc8xx -MBX powerpc mpc8xx mbx8xx -MBX860T powerpc mpc8xx mbx8xx -MPC86xADS powerpc mpc8xx fads -MPC885ADS powerpc mpc8xx fads -NETPHONE powerpc mpc8xx netphone - - NETPHONE:NETPHONE_VERSION=1 -NETPHONE_V2 powerpc mpc8xx netphone - - NETPHONE:NETPHONE_VERSION=2 -NETTA powerpc mpc8xx netta - - NETTA -NETTA2 powerpc mpc8xx netta2 - - NETTA2:NETTA2_VERSION=1 -NETTA2_V2 powerpc mpc8xx netta2 - - NETTA2:NETTA2_VERSION=2 -NETTA_6412 powerpc mpc8xx netta - - NETTA:NETTA_6412=1 -NETTA_6412_SWAPHOOK powerpc mpc8xx netta - - NETTA:NETTA_6412=1,NETTA_SWAPHOOK=1 -NETTA_ISDN powerpc mpc8xx netta - - NETTA:NETTA_ISDN=1 -NETTA_ISDN_6412 powerpc mpc8xx netta - - NETTA:NETTA_ISDN=1,NETTA_6412=1 -NETTA_ISDN_6412_SWAPHOOK powerpc mpc8xx netta - - NETTA:NETTA_ISDN=1,NETTA_6412=1,NETTA_SWAPHOOK=1 -NETTA_ISDN_SWAPHOOK powerpc mpc8xx netta - - NETTA:NETTA_ISDN=1,NETTA_SWAPHOOK=1 -NETTA_SWAPHOOK powerpc mpc8xx netta - - NETTA:NETTA_SWAPHOOK=1 -NETVIA powerpc mpc8xx netvia - - NETVIA:NETVIA_VERSION=1 -NETVIA_V2 powerpc mpc8xx netvia - - NETVIA:NETVIA_VERSION=2 -NX823 powerpc mpc8xx nx823 -quantum powerpc mpc8xx -R360MPI powerpc mpc8xx r360mpi -RBC823 powerpc mpc8xx rbc823 -RPXClassic powerpc mpc8xx -RPXlite powerpc mpc8xx -RPXlite_DW powerpc mpc8xx RPXlite_dw - - RPXlite_DW -RPXlite_DW_64 powerpc mpc8xx RPXlite_dw - - RPXlite_DW:RPXlite_64MHz -RPXlite_DW_64_LCD powerpc mpc8xx RPXlite_dw - - RPXlite_DW:RPXlite_64MHz,LCD,NEC_NL6448BC20 -RPXlite_DW_LCD powerpc mpc8xx RPXlite_dw - - RPXlite_DW:LCD,NEC_NL6448BC20 -RPXlite_DW_NVRAM powerpc mpc8xx RPXlite_dw - - RPXlite_DW:ENV_IS_IN_NVRAM -RPXlite_DW_NVRAM_64 powerpc mpc8xx RPXlite_dw - - RPXlite_DW:RPXlite_64MHz,ENV_IS_IN_NVRAM -RPXlite_DW_NVRAM_64_LCD powerpc mpc8xx RPXlite_dw - - RPXlite_DW:RPXlite_64MHz,LCD,NEC_NL6448BC20,ENV_IS_IN_NVRAM -RPXlite_DW_NVRAM_LCD powerpc mpc8xx RPXlite_dw - - RPXlite_DW:LCD,NEC_NL6448BC20,ENV_IS_IN_NVRAM -RRvision powerpc mpc8xx -RRvision_LCD powerpc mpc8xx RRvision - - RRvision:LCD,SHARP_LQ104V7DS01 -spc1920 powerpc mpc8xx -SPD823TS powerpc mpc8xx spd8xx -svm_sc8xx powerpc mpc8xx -SXNI855T powerpc mpc8xx sixnet -v37 powerpc mpc8xx -MHPC powerpc mpc8xx mhpc eltec -TOP860 powerpc mpc8xx top860 emk -KUP4K powerpc mpc8xx kup4k kup -KUP4X powerpc mpc8xx kup4x kup -ELPT860 powerpc mpc8xx elpt860 LEOX -uc100 powerpc mpc8xx - manroland -QS823 powerpc mpc8xx qs850 snmc -QS850 powerpc mpc8xx qs850 snmc -QS860T powerpc mpc8xx qs860t snmc -stxxtc powerpc mpc8xx stxxtc stx -FPS850L powerpc mpc8xx tqm8xx tqc -FPS860L powerpc mpc8xx tqm8xx tqc -NSCU powerpc mpc8xx tqm8xx tqc -SM850 powerpc mpc8xx tqm8xx tqc -TK885D powerpc mpc8xx tqm8xx tqc -TQM823L powerpc mpc8xx tqm8xx tqc -TQM823L_LCD powerpc mpc8xx tqm8xx tqc - TQM823L:LCD,NEC_NL6448BC20 -TQM823M powerpc mpc8xx tqm8xx tqc -TQM850L powerpc mpc8xx tqm8xx tqc -TQM850M powerpc mpc8xx tqm8xx tqc -TQM855L powerpc mpc8xx tqm8xx tqc -TQM855M powerpc mpc8xx tqm8xx tqc -TQM860L powerpc mpc8xx tqm8xx tqc -TQM860M powerpc mpc8xx tqm8xx tqc -TQM862L powerpc mpc8xx tqm8xx tqc -TQM862M powerpc mpc8xx tqm8xx tqc -TQM866M powerpc mpc8xx tqm8xx tqc -TQM885D powerpc mpc8xx tqm8xx tqc -TTTech powerpc mpc8xx tqm8xx tqc - TQM823L:LCD,SHARP_LQ104V7DS01 -virtlab2 powerpc mpc8xx tqm8xx tqc -wtk powerpc mpc8xx tqm8xx tqc - TQM823L:LCD,SHARP_LQ065T9DR51U -csb272 powerpc ppc4xx -csb472 powerpc ppc4xx -G2000 powerpc ppc4xx g2000 -JSE powerpc ppc4xx jse -korat powerpc ppc4xx -korat_perm powerpc ppc4xx korat - - korat:KORAT_PERMANENT -lwmon5 powerpc ppc4xx -lcd4_lwmon5 powerpc ppc4xx lwmon5 - - lwmon5:LCD4_LWMON5 -pcs440ep powerpc ppc4xx -quad100hd powerpc ppc4xx -sbc405 powerpc ppc4xx -sc3 powerpc ppc4xx -t3corp powerpc ppc4xx -W7OLMC powerpc ppc4xx w7o -W7OLMG powerpc ppc4xx w7o -zeus powerpc ppc4xx -acadia powerpc ppc4xx - amcc -acadia_nand powerpc ppc4xx acadia amcc - acadia:NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 -arches powerpc ppc4xx canyonlands amcc - canyonlands:ARCHES -bamboo powerpc ppc4xx - amcc -bamboo_nand powerpc ppc4xx bamboo amcc - bamboo:NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 -bluestone powerpc ppc4xx - amcc -bubinga powerpc ppc4xx - amcc -canyonlands powerpc ppc4xx canyonlands amcc - canyonlands:CANYONLANDS -canyonlands_nand powerpc ppc4xx canyonlands amcc - canyonlands:CANYONLANDS,NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 -ebony powerpc ppc4xx - amcc -glacier powerpc ppc4xx canyonlands amcc - canyonlands:GLACIER -glacier_nand powerpc ppc4xx canyonlands amcc - canyonlands:GLACIER,NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 -haleakala powerpc ppc4xx kilauea amcc - kilauea:HALEAKALA -haleakala_nand powerpc ppc4xx kilauea amcc - kilauea:NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 -katmai powerpc ppc4xx - amcc -kilauea powerpc ppc4xx kilauea amcc - kilauea:KILAUEA -kilauea_nand powerpc ppc4xx kilauea amcc - kilauea:NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 -luan powerpc ppc4xx - amcc -makalu powerpc ppc4xx - amcc -ocotea powerpc ppc4xx - amcc -rainier powerpc ppc4xx sequoia amcc - sequoia:RAINIER -rainier_nand powerpc ppc4xx sequoia amcc - sequoia:RAINIER,NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 -rainier_ramboot powerpc ppc4xx sequoia amcc - sequoia:RAINIER,SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/sequoia/u-boot-ram.lds -redwood powerpc ppc4xx - amcc -sequoia powerpc ppc4xx sequoia amcc - sequoia:SEQUOIA -sequoia_nand powerpc ppc4xx sequoia amcc - sequoia:SEQUOIA,NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 -sequoia_ramboot powerpc ppc4xx sequoia amcc - sequoia:SEQUOIA,SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/sequoia/u-boot-ram.lds -sycamore powerpc ppc4xx walnut amcc - walnut -taihu powerpc ppc4xx - amcc -taishan powerpc ppc4xx - amcc -walnut powerpc ppc4xx walnut amcc -yellowstone powerpc ppc4xx yosemite amcc - yosemite:YELLOWSTONE -yosemite powerpc ppc4xx yosemite amcc - yosemite:YOSEMITE -yucca powerpc ppc4xx - amcc -fx12mm powerpc ppc4xx fx12mm avnet - fx12mm:SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,INIT_TLB=board/xilinx/ppc405-generic/init.o -fx12mm_flash powerpc ppc4xx fx12mm avnet - fx12mm:SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC,INIT_TLB=board/xilinx/ppc405-generic/init.o -v5fx30teval powerpc ppc4xx v5fx30teval avnet - v5fx30teval:SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,BOOT_FROM_XMD=1,INIT_TLB=board/xilinx/ppc440-generic/init.o -v5fx30teval_flash powerpc ppc4xx v5fx30teval avnet - v5fx30teval:SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC,INIT_TLB=board/xilinx/ppc440-generic/init.o -CRAYL1 powerpc ppc4xx L1 cray -CATcenter powerpc ppc4xx PPChameleonEVB dave - CATcenter:PPCHAMELEON_MODULE_MODEL=1 -CATcenter_25 powerpc ppc4xx PPChameleonEVB dave - CATcenter:PPCHAMELEON_MODULE_MODEL=1,PPCHAMELEON_CLK_25 -CATcenter_33 powerpc ppc4xx PPChameleonEVB dave - CATcenter:PPCHAMELEON_MODULE_MODEL=1,PPCHAMELEON_CLK_33 -PPChameleonEVB powerpc ppc4xx PPChameleonEVB dave -PPChameleonEVB_BA_25 powerpc ppc4xx PPChameleonEVB dave - PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=0,PPCHAMELEON_CLK_25 -PPChameleonEVB_BA_33 powerpc ppc4xx PPChameleonEVB dave - PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=0,PPCHAMELEON_CLK_33 -PPChameleonEVB_HI_25 powerpc ppc4xx PPChameleonEVB dave - PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=2,PPCHAMELEON_CLK_25 -PPChameleonEVB_HI_33 powerpc ppc4xx PPChameleonEVB dave - PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=2,PPCHAMELEON_CLK_33 -PPChameleonEVB_ME_25 powerpc ppc4xx PPChameleonEVB dave - PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=1,PPCHAMELEON_CLK_25 -PPChameleonEVB_ME_33 powerpc ppc4xx PPChameleonEVB dave - PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=1,PPCHAMELEON_CLK_33 -APC405 powerpc ppc4xx apc405 esd -AR405 powerpc ppc4xx ar405 esd -ASH405 powerpc ppc4xx ash405 esd -CANBT powerpc ppc4xx canbt esd -CMS700 powerpc ppc4xx cms700 esd -CPCI2DP powerpc ppc4xx cpci2dp esd -CPCI405 powerpc ppc4xx cpci405 esd -CPCI4052 powerpc ppc4xx cpci405 esd -CPCI405AB powerpc ppc4xx cpci405 esd -CPCI405DT powerpc ppc4xx cpci405 esd -CPCIISER4 powerpc ppc4xx cpciiser4 esd -DP405 powerpc ppc4xx dp405 esd -DU405 powerpc ppc4xx du405 esd -DU440 powerpc ppc4xx du440 esd -HH405 powerpc ppc4xx hh405 esd -HUB405 powerpc ppc4xx hub405 esd -OCRTC powerpc ppc4xx ocrtc esd -PCI405 powerpc ppc4xx pci405 esd -PLU405 powerpc ppc4xx plu405 esd -PMC405 powerpc ppc4xx pmc405 esd -PMC405DE powerpc ppc4xx pmc405de esd -PMC440 powerpc ppc4xx pmc440 esd -VOH405 powerpc ppc4xx voh405 esd -VOM405 powerpc ppc4xx vom405 esd -WUH405 powerpc ppc4xx wuh405 esd -devconcenter powerpc ppc4xx intip gdsys - intip:DEVCONCENTER -dlvision powerpc ppc4xx - gdsys -dlvision-10g powerpc ppc4xx 405ep gdsys -gdppc440etx powerpc ppc4xx - gdsys -intip powerpc ppc4xx intip gdsys - intip:INTIB -io powerpc ppc4xx 405ep gdsys -io64 powerpc ppc4xx 405ex gdsys -iocon powerpc ppc4xx 405ep gdsys -neo powerpc ppc4xx 405ep gdsys -icon powerpc ppc4xx - mosaixtech -MIP405 powerpc ppc4xx mip405 mpl -MIP405T powerpc ppc4xx mip405 mpl - MIP405:MIP405T -PIP405 powerpc ppc4xx pip405 mpl -alpr powerpc ppc4xx - prodrive -p3p440 powerpc ppc4xx - prodrive -KAREF powerpc ppc4xx karef sandburst -METROBOX powerpc ppc4xx metrobox sandburst -xpedite1000 powerpc ppc4xx - xes -ml507 powerpc ppc4xx ml507 xilinx - ml507:SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,BOOT_FROM_XMD=1,INIT_TLB=board/xilinx/ppc440-generic/init.o -ml507_flash powerpc ppc4xx ml507 xilinx - ml507:SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC,INIT_TLB=board/xilinx/ppc440-generic/init.o -xilinx-ppc405-generic powerpc ppc4xx ppc405-generic xilinx - xilinx-ppc405-generic:SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000 -xilinx-ppc405-generic_flash powerpc ppc4xx ppc405-generic xilinx - xilinx-ppc405-generic:SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC -xilinx-ppc440-generic powerpc ppc4xx ppc440-generic xilinx - xilinx-ppc440-generic:SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,BOOT_FROM_XMD=1 -xilinx-ppc440-generic_flash powerpc ppc4xx ppc440-generic xilinx - xilinx-ppc440-generic:SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC -sandbox sandbox sandbox sandbox sandbox - -rsk7203 sh sh2 rsk7203 renesas - -rsk7264 sh sh2 rsk7264 renesas - -rsk7269 sh sh2 rsk7269 renesas - -mpr2 sh sh3 mpr2 - - -ms7720se sh sh3 ms7720se - - -shmin sh sh3 shmin - - -espt sh sh4 espt - - -ms7722se sh sh4 ms7722se - - -ms7750se sh sh4 ms7750se - - -ap325rxa sh sh4 ap325rxa renesas - -ecovec sh sh4 ecovec renesas - -MigoR sh sh4 MigoR renesas - -r2dplus sh sh4 r2dplus renesas - -r7780mp sh sh4 r7780mp renesas - -sh7752evb sh sh4 sh7752evb renesas - -sh7757lcr sh sh4 sh7757lcr renesas - -sh7763rdp sh sh4 sh7763rdp renesas - -sh7785lcr sh sh4 sh7785lcr renesas - -sh7785lcr_32bit sh sh4 sh7785lcr renesas - sh7785lcr:SH_32BIT=1 -r0p7734 sh sh4 r0p7734 renesas - -ap_sh4a_4a sh sh4 ap_sh4a_4a alphaproject - -grsim_leon2 sparc leon2 - gaisler -gr_cpci_ax2000 sparc leon3 - gaisler -gr_ep2s60 sparc leon3 - gaisler -grsim sparc leon3 - gaisler -gr_xc3s_1500 sparc leon3 - gaisler -coreboot-x86 x86 x86 coreboot chromebook-x86 coreboot coreboot:SYS_TEXT_BASE=0x01110000 -# Target ARCH CPU Board name Vendor SoC Options -######################################################################################################################## +Active arm arm1136 - armltd integrator integratorcp_cm1136 integratorcp:CM1136 Linus Walleij linus.walleij@linaro.org +Active arm arm1136 mx31 - - imx31_phycore - - +Active arm arm1136 mx31 davedenx - qong - Wolfgang Denk wd@denx.de +Active arm arm1136 mx31 freescale - mx31pdk - Fabio Estevam fabio.estevam@freescale.com +Active arm arm1136 mx31 hale - tt01 - Helmut Raiger helmut.raiger@hale.at +Active arm arm1136 mx31 logicpd - imx31_litekit - - +Active arm arm1136 mx35 - - woodburn - Stefano Babic sbabic@denx.de +Active arm arm1136 mx35 - woodburn woodburn_sd woodburn_sd:IMX_CONFIG=board/woodburn/imximage.cfg Stefano Babic sbabic@denx.de +Active arm arm1136 mx35 CarMediaLab - flea3 - Stefano Babic sbabic@denx.de +Active arm arm1136 mx35 freescale - mx35pdk - Stefano Babic sbabic@denx.de +Active arm arm1176 bcm2835 raspberrypi rpi_b rpi_b - Stephen Warren swarren@wwwdotorg.org +Active arm arm1176 tnetv107x ti tnetv107xevm tnetv107x_evm - Chan-Taek Park c-park@ti.com +Active arm arm720t - armltd integrator integratorap_cm720t integratorap:CM720T Linus Walleij linus.walleij@linaro.org +Active arm arm920t - armltd integrator integratorap_cm920t integratorap:CM920T Linus Walleij linus.walleij@linaro.org +Active arm arm920t - armltd integrator integratorcp_cm920t integratorcp:CM920T Linus Walleij linus.walleij@linaro.org +Active arm arm920t a320 faraday - a320evb - Po-Yu Chuang ratbert@faraday-tech.com +Active arm arm920t at91 atmel at91rm9200ek at91rm9200ek at91rm9200ek Andreas Bießmann andreas.devel@gmail.com +Active arm arm920t at91 atmel at91rm9200ek at91rm9200ek_ram at91rm9200ek:RAMBOOT Andreas Bießmann andreas.devel@gmail.com +Active arm arm920t at91 BuS eb_cpux9k2 eb_cpux9k2 eb_cpux9k2 Jens Scharsig esw@bus-elektronik.de +Active arm arm920t at91 BuS eb_cpux9k2 eb_cpux9k2_ram eb_cpux9k2:RAMBOOT Jens Scharsig esw@bus-elektronik.de +Active arm arm920t at91 eukrea cpuat91 cpuat91 cpuat91 Eric Benard eric@eukrea.com +Active arm arm920t at91 eukrea cpuat91 cpuat91_ram cpuat91:RAMBOOT Eric Benard eric@eukrea.com +Active arm arm920t imx - - mx1ads - - +Active arm arm920t imx - - scb9328 - Torsten Koschorrek koschorrek@synertronixx.de +Active arm arm920t ks8695 - - cm4008 - Greg Ungerer greg.ungerer@opengear.com +Active arm arm920t ks8695 - - cm41xx - - +Active arm arm920t s3c24x0 friendlyarm mini2440 mini2440 - Gabriel Huau contact@huau-gabriel.fr +Active arm arm920t s3c24x0 mpl vcma9 VCMA9 - David Müller d.mueller@elsoft.ch +Active arm arm920t s3c24x0 samsung - smdk2410 - David Müller d.mueller@elsoft.ch +Active arm arm926ejs - armltd integrator integratorap_cm926ejs integratorap:CM926EJ_S Linus Walleij linus.walleij@linaro.org +Active arm arm926ejs - armltd integrator integratorcp_cm926ejs integratorcp:CM924EJ_S Linus Walleij linus.walleij@linaro.org +Active arm arm926ejs armada100 Marvell - aspenite - Prafulla Wadaskar prafulla@marvell.com +Active arm arm926ejs armada100 Marvell - gplugd - Ajay Bhargav ajay.bhargav@einfochips.com +Active arm arm926ejs at91 - - afeb9260 - Sergey Lapin slapin@ossfans.org +Active arm arm926ejs at91 atmel at91sam9260ek at91sam9260ek_dataflash_cs0 at91sam9260ek:AT91SAM9260,SYS_USE_DATAFLASH_CS0 Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9260ek at91sam9260ek_dataflash_cs1 at91sam9260ek:AT91SAM9260,SYS_USE_DATAFLASH_CS1 Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9260ek at91sam9260ek_nandflash at91sam9260ek:AT91SAM9260,SYS_USE_NANDFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9260ek at91sam9g20ek_2mmc_nandflash at91sam9260ek:AT91SAM9G20,AT91SAM9G20EK_2MMC,SYS_USE_NANDFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9260ek at91sam9g20ek_dataflash_cs0 at91sam9260ek:AT91SAM9G20,SYS_USE_DATAFLASH_CS0 Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9260ek at91sam9g20ek_dataflash_cs1 at91sam9260ek:AT91SAM9G20,SYS_USE_DATAFLASH_CS1 Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9260ek at91sam9g20ek_mmc at91sam9260ek:AT91SAM9G20,SYS_USE_MMC Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9260ek at91sam9g20ek_nandflash at91sam9260ek:AT91SAM9G20,SYS_USE_NANDFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9260ek at91sam9xeek_dataflash_cs0 at91sam9260ek:AT91SAM9XE,SYS_USE_DATAFLASH_CS0 Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9260ek at91sam9xeek_dataflash_cs1 at91sam9260ek:AT91SAM9XE,SYS_USE_DATAFLASH_CS1 Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9260ek at91sam9xeek_nandflash at91sam9260ek:AT91SAM9XE,SYS_USE_NANDFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9261ek at91sam9261ek_dataflash_cs0 at91sam9261ek:AT91SAM9261,SYS_USE_DATAFLASH_CS0 Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9261ek at91sam9261ek_dataflash_cs3 at91sam9261ek:AT91SAM9261,SYS_USE_DATAFLASH_CS3 Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9261ek at91sam9261ek_nandflash at91sam9261ek:AT91SAM9261,SYS_USE_NANDFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9261ek at91sam9g10ek_dataflash_cs0 at91sam9261ek:AT91SAM9G10,SYS_USE_DATAFLASH_CS0 Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9261ek at91sam9g10ek_dataflash_cs3 at91sam9261ek:AT91SAM9G10,SYS_USE_DATAFLASH_CS3 Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9261ek at91sam9g10ek_nandflash at91sam9261ek:AT91SAM9G10,SYS_USE_NANDFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9263ek at91sam9263ek_dataflash at91sam9263ek:AT91SAM9263,SYS_USE_DATAFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9263ek at91sam9263ek_dataflash_cs0 at91sam9263ek:AT91SAM9263,SYS_USE_DATAFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9263ek at91sam9263ek_nandflash at91sam9263ek:AT91SAM9263,SYS_USE_NANDFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9263ek at91sam9263ek_norflash at91sam9263ek:AT91SAM9263,SYS_USE_NORFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9263ek at91sam9263ek_norflash_boot at91sam9263ek:AT91SAM9263,SYS_USE_BOOT_NORFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9m10g45ek at91sam9m10g45ek_nandflash at91sam9m10g45ek:AT91SAM9M10G45,SYS_USE_NANDFLASH Bo Shenvoice.shen@atmel.com +Active arm arm926ejs at91 atmel at91sam9n12ek at91sam9n12ek_mmc at91sam9n12ek:AT91SAM9N12,SYS_USE_MMC Josh Wu josh.wu@atmel.com +Active arm arm926ejs at91 atmel at91sam9n12ek at91sam9n12ek_nandflash at91sam9n12ek:AT91SAM9N12,SYS_USE_NANDFLASH Josh Wu josh.wu@atmel.com +Active arm arm926ejs at91 atmel at91sam9n12ek at91sam9n12ek_spiflash at91sam9n12ek:AT91SAM9N12,SYS_USE_SPIFLASH Josh Wu josh.wu@atmel.com +Active arm arm926ejs at91 atmel at91sam9rlek at91sam9rlek_dataflash at91sam9rlek:AT91SAM9RL,SYS_USE_DATAFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9rlek at91sam9rlek_nandflash at91sam9rlek:AT91SAM9RL,SYS_USE_NANDFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9x5ek at91sam9x5ek_dataflash at91sam9x5ek:AT91SAM9X5,SYS_USE_DATAFLASH Bo Shen voice.shen@atmel.com +Active arm arm926ejs at91 atmel at91sam9x5ek at91sam9x5ek_mmc at91sam9x5ek:AT91SAM9X5,SYS_USE_MMC Bo Shen voice.shen@atmel.com +Active arm arm926ejs at91 atmel at91sam9x5ek at91sam9x5ek_nandflash at91sam9x5ek:AT91SAM9X5,SYS_USE_NANDFLASH Bo Shen voice.shen@atmel.com +Active arm arm926ejs at91 atmel at91sam9x5ek at91sam9x5ek_spiflash at91sam9x5ek:AT91SAM9X5,SYS_USE_SPIFLASH Bo Shen voice.shen@atmel.com +Active arm arm926ejs at91 bluewater - snapper9260 snapper9260:AT91SAM9260 Ryan Mallon ryan@bluewatersys.com +Active arm arm926ejs at91 bluewater snapper9260 snapper9g20 snapper9260:AT91SAM9G20 Ryan Mallon ryan@bluewatersys.com +Active arm arm926ejs at91 BuS vl_ma2sc vl_ma2sc - Jens Scharsig esw@bus-elektronik.de +Active arm arm926ejs at91 BuS vl_ma2sc vl_ma2sc_ram vl_ma2sc:RAMLOAD Jens Scharsig esw@bus-elektronik.de +Active arm arm926ejs at91 calao sbc35_a9g20 sbc35_a9g20_eeprom sbc35_a9g20:AT91SAM9G20,SYS_USE_EEPROM Albin Tonnerre albin.tonnerre@free-electrons.com +Active arm arm926ejs at91 calao sbc35_a9g20 sbc35_a9g20_nandflash sbc35_a9g20:AT91SAM9G20,SYS_USE_NANDFLASH Albin Tonnerre albin.tonnerre@free-electrons.com +Active arm arm926ejs at91 calao tny_a9260 tny_a9260_eeprom tny_a9260:AT91SAM9260,SYS_USE_EEPROM Albin Tonnerre albin.tonnerre@free-electrons.com +Active arm arm926ejs at91 calao tny_a9260 tny_a9260_nandflash tny_a9260:AT91SAM9260,SYS_USE_NANDFLASH Albin Tonnerre albin.tonnerre@free-electrons.com +Active arm arm926ejs at91 calao tny_a9260 tny_a9g20_eeprom tny_a9260:AT91SAM9G20,SYS_USE_EEPROM Albin Tonnerre albin.tonnerre@free-electrons.com +Active arm arm926ejs at91 calao tny_a9260 tny_a9g20_nandflash tny_a9260:AT91SAM9G20,SYS_USE_NANDFLASH Albin Tonnerre albin.tonnerre@free-electrons.com +Active arm arm926ejs at91 egnite ethernut5 ethernut5 ethernut5:AT91SAM9XE egnite GmbH info@egnite.de +Active arm arm926ejs at91 emk top9000 top9000eval_xe top9000:EVAL9000 Reinhard Meyer reinhard.meyer@emk-elektronik.de +Active arm arm926ejs at91 emk top9000 top9000su_xe top9000:SU9000 Reinhard Meyer reinhard.meyer@emk-elektronik.de +Active arm arm926ejs at91 esd meesc meesc meesc:AT91SAM9263,SYS_USE_NANDFLASH Daniel Gorsulowski daniel.gorsulowski@esd.eu +Active arm arm926ejs at91 esd meesc meesc_dataflash meesc:AT91SAM9263,SYS_USE_DATAFLASH Daniel Gorsulowski daniel.gorsulowski@esd.eu +Active arm arm926ejs at91 esd otc570 otc570 otc570:AT91SAM9263,SYS_USE_NANDFLASH Daniel Gorsulowski daniel.gorsulowski@esd.eu +Active arm arm926ejs at91 esd otc570 otc570_dataflash otc570:AT91SAM9263,SYS_USE_DATAFLASH Daniel Gorsulowski daniel.gorsulowski@esd.eu +Active arm arm926ejs at91 eukrea cpu9260 cpu9260 cpu9260:CPU9260 Eric Benard eric@eukrea.com +Active arm arm926ejs at91 eukrea cpu9260 cpu9260_128M cpu9260:CPU9260,CPU9260_128M Eric Benard eric@eukrea.com +Active arm arm926ejs at91 eukrea cpu9260 cpu9260_nand cpu9260:CPU9260,NANDBOOT Eric Benard eric@eukrea.com +Active arm arm926ejs at91 eukrea cpu9260 cpu9260_nand_128M cpu9260:CPU9260,CPU9260_128M,NANDBOOT Eric Benard eric@eukrea.com +Active arm arm926ejs at91 eukrea cpu9260 cpu9G20 cpu9260:CPU9G20 Eric Benard eric@eukrea.com +Active arm arm926ejs at91 eukrea cpu9260 cpu9G20_128M cpu9260:CPU9G20,CPU9G20_128M Eric Benard eric@eukrea.com +Active arm arm926ejs at91 eukrea cpu9260 cpu9G20_nand cpu9260:CPU9G20,NANDBOOT Eric Benard eric@eukrea.com +Active arm arm926ejs at91 eukrea cpu9260 cpu9G20_nand_128M cpu9260:CPU9G20,CPU9G20_128M,NANDBOOT Eric Benard eric@eukrea.com +Active arm arm926ejs at91 ronetix pm9261 pm9261 pm9261:AT91SAM9261 Ilko Iliev iliev@ronetix.at +Active arm arm926ejs at91 ronetix pm9263 pm9263 pm9263:AT91SAM9263 Ilko Iliev iliev@ronetix.at +Active arm arm926ejs at91 ronetix pm9g45 pm9g45 pm9g45:AT91SAM9G45 Ilko Iliev iliev@ronetix.at +Active arm arm926ejs at91 taskit stamp9g20 portuxg20 stamp9g20:AT91SAM9G20,PORTUXG20 Markus Hubig mhubig@imko.de +Active arm arm926ejs at91 taskit stamp9g20 stamp9g20 stamp9g20:AT91SAM9G20 Markus Hubig mhubig@imko.de +Active arm arm926ejs davinci ait cam_enc_4xx cam_enc_4xx cam_enc_4xx Heiko Schocher hs@denx.de +Active arm arm926ejs davinci davinci da8xxevm da830evm - Nick Thompson nick.thompson@gefanuc.com +Active arm arm926ejs davinci davinci da8xxevm da850_am18xxevm da850evm:DA850_AM18X_EVM,MAC_ADDR_IN_EEPROM,SYS_I2C_EEPROM_ADDR_LEN=2,SYS_I2C_EEPROM_ADDR=0x50 Sudhakar Rajashekhara sudhakar.raj@ti.com +Active arm arm926ejs davinci davinci da8xxevm da850evm da850evm:MAC_ADDR_IN_SPIFLASH Sudhakar Rajashekhara sudhakar.raj@ti.com +Active arm arm926ejs davinci davinci da8xxevm da850evm_direct_nor da850evm:MAC_ADDR_IN_SPIFLASH,USE_NOR,DIRECT_NOR_BOOT Sudhakar Rajashekhara sudhakar.raj@ti.com +Active arm arm926ejs davinci davinci da8xxevm hawkboard - Syed Mohammed Khasim sm.khasim@gmail.com:Sughosh Ganu urwithsughosh@gmail.com +Active arm arm926ejs davinci davinci da8xxevm hawkboard_uart hawkboard:UART_U_BOOT Syed Mohammed Khasim sm.khasim@gmail.com:Sughosh Ganu urwithsughosh@gmail.com +Active arm arm926ejs davinci davinci dm355evm davinci_dm355evm - Sandeep Paulraj s-paulraj@ti.com +Active arm arm926ejs davinci davinci dm355leopard davinci_dm355leopard - Sandeep Paulraj s-paulraj@ti.com +Active arm arm926ejs davinci davinci dm365evm davinci_dm365evm - Sandeep Paulraj s-paulraj@ti.com +Active arm arm926ejs davinci davinci dm6467evm davinci_dm6467evm davinci_dm6467evm:REFCLK_FREQ=27000000 Sandeep Paulraj s-paulraj@ti.com +Active arm arm926ejs davinci davinci dm6467evm davinci_dm6467Tevm davinci_dm6467evm:DAVINCI_DM6467TEVM,REFCLK_FREQ=33000000 Sandeep Paulraj s-paulraj@ti.com +Active arm arm926ejs davinci davinci dvevm davinci_dvevm - - +Active arm arm926ejs davinci davinci ea20 ea20 - Stefano Babic sbabic@denx.de +Active arm arm926ejs davinci davinci schmoogie davinci_schmoogie - Sergey Kubushyn ksi@koi8.net +Active arm arm926ejs davinci davinci sffsdr davinci_sffsdr - Hugo Villeneuve hugo.villeneuve@lyrtech.com +Active arm arm926ejs davinci davinci sonata davinci_sonata - Sergey Kubushyn ksi@koi8.net +Active arm arm926ejs davinci enbw enbw_cmc enbw_cmc - Heiko Schocher hs@denx.de +Active arm arm926ejs davinci omicron calimain calimain - Manfred Rudigier manfred.rudigier@omicron.at:Christian Riesch christian.riesch@omicron.at +Active arm arm926ejs kirkwood buffalo lsxl lschlv2 lsxl:LSCHLV2 Michael Walle michael@walle.cc +Active arm arm926ejs kirkwood buffalo lsxl lsxhl lsxl:LSXHL Michael Walle michael@walle.cc +Active arm arm926ejs kirkwood cloudengines - pogo_e02 - Dave Purdy david.c.purdy@gmail.com +Active arm arm926ejs kirkwood d-link - dns325 - Stefan Herbrechtsmeier stefan@code.herbrechtsmeier.net +Active arm arm926ejs kirkwood iomega - iconnect - Luka Perkov luka@openwrt.org +Active arm arm926ejs kirkwood karo tk71 tk71 - - +Active arm arm926ejs kirkwood keymile km_arm km_kirkwood km_kirkwood:KM_KIRKWOOD Valentin Longchamp valentin.longchamp@keymile.com +Active arm arm926ejs kirkwood keymile km_arm km_kirkwood_pci km_kirkwood:KM_KIRKWOOD_PCI Valentin Longchamp valentin.longchamp@keymile.com +Active arm arm926ejs kirkwood keymile km_arm kmcoge5un km_kirkwood:KM_COGE5UN Valentin Longchamp valentin.longchamp@keymile.com +Active arm arm926ejs kirkwood keymile km_arm kmnusa km_kirkwood:KM_NUSA Valentin Longchamp valentin.longchamp@keymile.com +Active arm arm926ejs kirkwood keymile km_arm kmsuv31 km_kirkwood:KM_SUV31 Valentin Longchamp valentin.longchamp@keymile.com +Active arm arm926ejs kirkwood keymile km_arm mgcoge3un km_kirkwood:KM_MGCOGE3UN Valentin Longchamp valentin.longchamp@keymile.com +Active arm arm926ejs kirkwood keymile km_arm portl2 km_kirkwood:KM_PORTL2 Valentin Longchamp valentin.longchamp@keymile.com +Active arm arm926ejs kirkwood LaCie net2big_v2 d2net_v2 lacie_kw:D2NET_V2 Simon Guinot simon.guinot@sequanux.org +Active arm arm926ejs kirkwood LaCie net2big_v2 net2big_v2 lacie_kw:NET2BIG_V2 Simon Guinot simon.guinot@sequanux.org +Active arm arm926ejs kirkwood LaCie netspace_v2 inetspace_v2 lacie_kw:INETSPACE_V2 Simon Guinot simon.guinot@sequanux.org +Active arm arm926ejs kirkwood LaCie netspace_v2 netspace_lite_v2 lacie_kw:NETSPACE_LITE_V2 Simon Guinot simon.guinot@sequanux.org +Active arm arm926ejs kirkwood LaCie netspace_v2 netspace_max_v2 lacie_kw:NETSPACE_MAX_V2 Simon Guinot simon.guinot@sequanux.org +Active arm arm926ejs kirkwood LaCie netspace_v2 netspace_mini_v2 lacie_kw:NETSPACE_MINI_V2 Simon Guinot simon.guinot@sequanux.org +Active arm arm926ejs kirkwood LaCie netspace_v2 netspace_v2 lacie_kw:NETSPACE_V2 Simon Guinot simon.guinot@sequanux.org +Active arm arm926ejs kirkwood LaCie wireless_space wireless_space - - +Active arm arm926ejs kirkwood Marvell - dreamplug - Jason Cooper u-boot@lakedaemon.net +Active arm arm926ejs kirkwood Marvell - guruplug - Siddarth Gore gores@marvell.com +Active arm arm926ejs kirkwood Marvell - mv88f6281gtw_ge - Prafulla Wadaskar prafulla@marvell.com +Active arm arm926ejs kirkwood Marvell - rd6281a - Prafulla Wadaskar prafulla@marvell.com +Active arm arm926ejs kirkwood Marvell - sheevaplug - Prafulla Wadaskar prafulla@marvell.com +Active arm arm926ejs kirkwood Marvell openrd openrd_base openrd:BOARD_IS_OPENRD_BASE Prafulla Wadaskar prafulla@marvell.com +Active arm arm926ejs kirkwood Marvell openrd openrd_client openrd:BOARD_IS_OPENRD_CLIENT - +Active arm arm926ejs kirkwood Marvell openrd openrd_ultimate openrd:BOARD_IS_OPENRD_ULTIMATE - +Active arm arm926ejs kirkwood raidsonic ib62x0 ib62x0 - Luka Perkov luka@openwrt.org +Active arm arm926ejs kirkwood Seagate - dockstar - Eric Cooper ecc@cmu.edu +Active arm arm926ejs kirkwood Seagate - goflexhome - Suriyan Ramasami suriyan.r@gmail.com +Active arm arm926ejs lpc32xx timll devkit3250 devkit3250 - Vladimir Zapolskiy vz@mleia.com +Active arm arm926ejs mb86r0x syteco jadecpu jadecpu - Matthias Weisser weisserm@arcor.de +Active arm arm926ejs mx25 freescale mx25pdk mx25pdk mx25pdk:IMX_CONFIG=board/freescale/mx25pdk/imximage.cfg Fabio Estevam fabio.estevam@freescale.com +Active arm arm926ejs mx25 karo tx25 tx25 - John Rigby jcrigby@gmail.com +Active arm arm926ejs mx25 syteco zmx25 zmx25 - Matthias Weisser weisserm@arcor.de +Active arm arm926ejs mx27 logicpd imx27lite imx27lite - Wolfgang Denk wd@denx.de +Active arm arm926ejs mx27 logicpd imx27lite magnesium - Wolfgang Denk wd@denx.de:Heiko Schocher hs@denx.de +Active arm arm926ejs mxs bluegiga apx4devkit apx4devkit apx4devkit Lauri Hintsala lauri.hintsala@bluegiga.com +Active arm arm926ejs mxs denx m28evk m28evk m28evk Marek Vasut marek.vasut@gmail.com +Active arm arm926ejs mxs freescale mx23evk mx23evk mx23evk Otavio Salvador otavio@ossystems.com.br +Active arm arm926ejs mxs freescale mx28evk mx28evk mx28evk:ENV_IS_IN_MMC Fabio Estevam fabio.estevam@freescale.com +Active arm arm926ejs mxs freescale mx28evk mx28evk_nand mx28evk:ENV_IS_IN_NAND Fabio Estevam fabio.estevam@freescale.com +Active arm arm926ejs mxs olimex mx23_olinuxino mx23_olinuxino mx23_olinuxino Marek Vasut marek.vasut@gmail.com +Active arm arm926ejs mxs schulercontrol sc_sps_1 sc_sps_1 - Marek Vasut marek.vasut@gmail.com +Active arm arm926ejs nomadik st nhk8815 nhk8815 - Nomadik Linux Team STN_WMM_nomadik_linux@list.st.com:Alessandro Rubini rubini@unipv.it +Active arm arm926ejs nomadik st nhk8815 nhk8815_onenand nhk8815:BOOT_ONENAND Nomadik Linux Team STN_WMM_nomadik_linux@list.st.com:Alessandro Rubini rubini@unipv.it +Active arm arm926ejs omap ti - omap5912osk - Rishi Bhattacharya rishi@ti.com +Active arm arm926ejs omap ti omap730p2 omap730p2 omap730p2:CS3_BOOT Dave Peverley dpeverley@mpc-data.co.uk +Active arm arm926ejs omap ti omap730p2 omap730p2_cs0boot omap730p2:CS0_BOOT Dave Peverley dpeverley@mpc-data.co.uk +Active arm arm926ejs omap ti omap730p2 omap730p2_cs3boot omap730p2:CS3_BOOT Dave Peverley dpeverley@mpc-data.co.uk +Active arm arm926ejs orion5x LaCie - edminiv2 - Albert ARIBAUD albert.u.boot@aribaud.net +Active arm arm926ejs pantheon Marvell - dkb - Lei Wen leiwen@marvell.com +Active arm arm926ejs spear spear - x600 x600 Stefan Roese sr@denx.de +Active arm arm926ejs spear spear spear300 spear300 spear3xx_evb:spear300 Vipin Kumar vipin.kumar@st.com +Active arm arm926ejs spear spear spear300 spear300_nand spear3xx_evb:spear300,nand Vipin Kumar vipin.kumar@st.com +Active arm arm926ejs spear spear spear300 spear300_usbtty spear3xx_evb:spear300,usbtty Vipin Kumar vipin.kumar@st.com +Active arm arm926ejs spear spear spear300 spear300_usbtty_nand spear3xx_evb:spear300,usbtty,nand Vipin Kumar vipin.kumar@st.com +Active arm arm926ejs spear spear spear310 spear310 spear3xx_evb:spear310 Vipin Kumar vipin.kumar@st.com +Active arm arm926ejs spear spear spear310 spear310_nand spear3xx_evb:spear310,nand Vipin Kumar vipin.kumar@st.com +Active arm arm926ejs spear spear spear310 spear310_pnor spear3xx_evb:spear310,FLASH_PNOR Vipin Kumar vipin.kumar@st.com +Active arm arm926ejs spear spear spear310 spear310_usbtty spear3xx_evb:spear310,usbtty Vipin Kumar vipin.kumar@st.com +Active arm arm926ejs spear spear spear310 spear310_usbtty_nand spear3xx_evb:spear310,usbtty,nand Vipin Kumar vipin.kumar@st.com +Active arm arm926ejs spear spear spear310 spear310_usbtty_pnor spear3xx_evb:spear310,usbtty,FLASH_PNOR Vipin Kumar vipin.kumar@st.com +Active arm arm926ejs spear spear spear320 spear320 spear3xx_evb:spear320 Vipin Kumar vipin.kumar@st.com +Active arm arm926ejs spear spear spear320 spear320_nand spear3xx_evb:spear320,nand Vipin Kumar vipin.kumar@st.com +Active arm arm926ejs spear spear spear320 spear320_pnor spear3xx_evb:spear320,FLASH_PNOR Vipin Kumar vipin.kumar@st.com +Active arm arm926ejs spear spear spear320 spear320_usbtty spear3xx_evb:spear320,usbtty Vipin Kumar vipin.kumar@st.com +Active arm arm926ejs spear spear spear320 spear320_usbtty_nand spear3xx_evb:spear320,usbtty,nand Vipin Kumar vipin.kumar@st.com +Active arm arm926ejs spear spear spear320 spear320_usbtty_pnor spear3xx_evb:spear320,usbtty,FLASH_PNOR Vipin Kumar vipin.kumar@st.com +Active arm arm926ejs spear spear spear600 spear600 spear6xx_evb:spear600 Vipin Kumar vipin.kumar@st.com +Active arm arm926ejs spear spear spear600 spear600_nand spear6xx_evb:spear600,nand Vipin Kumar vipin.kumar@st.com +Active arm arm926ejs spear spear spear600 spear600_usbtty spear6xx_evb:spear600,usbtty Vipin Kumar vipin.kumar@st.com +Active arm arm926ejs spear spear spear600 spear600_usbtty_nand spear6xx_evb:spear600,usbtty,nand Vipin Kumar vipin.kumar@st.com +Active arm arm946es - armltd integrator integratorap_cm946es integratorap:CM946ES Linus Walleij linus.walleij@linaro.org +Active arm arm946es - armltd integrator integratorcp_cm946es integratorcp:CM946ES Linus Walleij linus.walleij@linaro.org +Active arm armv7 - armltd vexpress vexpress_ca15_tc2 - - +Active arm armv7 - armltd vexpress vexpress_ca5x2 - Matt Waddel matt.waddel@linaro.org +Active arm armv7 - armltd vexpress vexpress_ca9x4 - Matt Waddel matt.waddel@linaro.org +Active arm armv7 am33xx isee igep0033 igep0033 - Enric Balletbo i Serra eballetbo@iseebcn.com +Active arm armv7 am33xx phytec pcm051 pcm051 pcm051 Lars Poeschel poeschel@lemonage.de +Active arm armv7 am33xx ti am335x am335x_evm am335x_evm:SERIAL1,CONS_INDEX=1 Tom Rini trini@ti.com +Active arm armv7 am33xx ti am335x am335x_evm_spiboot am335x_evm:SERIAL1,CONS_INDEX=1,SPI_BOOT Tom Rini trini@ti.com +Active arm armv7 am33xx ti am335x am335x_evm_uart1 am335x_evm:SERIAL2,CONS_INDEX=2 Tom Rini trini@ti.com +Active arm armv7 am33xx ti am335x am335x_evm_uart2 am335x_evm:SERIAL3,CONS_INDEX=3 Tom Rini trini@ti.com +Active arm armv7 am33xx ti am335x am335x_evm_uart3 am335x_evm:SERIAL4,CONS_INDEX=4 Tom Rini trini@ti.com +Active arm armv7 am33xx ti am335x am335x_evm_uart4 am335x_evm:SERIAL5,CONS_INDEX=5 Tom Rini trini@ti.com +Active arm armv7 am33xx ti am335x am335x_evm_uart5 am335x_evm:SERIAL6,CONS_INDEX=6 Tom Rini trini@ti.com +Active arm armv7 am33xx ti am335x am335x_evm_usbspl am335x_evm:SERIAL1,CONS_INDEX=1,SPL_USBETH_SUPPORT Tom Rini trini@ti.com +Active arm armv7 am33xx ti ti814x ti814x_evm - Matt Porter mporter@ti.com +Active arm armv7 at91 atmel sama5d3xek sama5d3xek_mmc sama5d3xek:SAMA5D3,SYS_USE_MMC Bo Shen voice.shen@atmel.com +Active arm armv7 at91 atmel sama5d3xek sama5d3xek_nandflash sama5d3xek:SAMA5D3,SYS_USE_NANDFLASH Bo Shen voice.shen@atmel.com +Active arm armv7 at91 atmel sama5d3xek sama5d3xek_spiflash sama5d3xek:SAMA5D3,SYS_USE_SERIALFLASH Bo Shen voice.shen@atmel.com +Active arm armv7 exynos samsung origen origen - Chander Kashyap k.chander@samsung.com +Active arm armv7 exynos samsung smdk5250 smdk5250 - Chander Kashyap k.chander@samsung.com +Active arm armv7 exynos samsung smdk5250 snow - Rajeshwari Shinde rajeshwari.s@samsung.com:Chander Kashyap k.chander@samsung.com +Active arm armv7 exynos samsung smdkv310 smdkv310 - Chander Kashyap k.chander@samsung.com +Active arm armv7 exynos samsung trats trats - Lukasz Majewski l.majewski@samsung.com +Active arm armv7 exynos samsung universal_c210 s5pc210_universal - Minkyu Kang mk7.kang@samsung.com +Active arm armv7 highbank - highbank highbank - Rob Herring rob.herring@calxeda.com +Active arm armv7 mx5 denx m53evk m53evk m53evk:IMX_CONFIG=board/denx/m53evk/imximage.cfg Marek Vasut marek.vasut@gmail.com +Active arm armv7 mx5 esg ima3-mx53 ima3-mx53 ima3-mx53:IMX_CONFIG=board/esg/ima3-mx53/imximage.cfg - +Active arm armv7 mx5 freescale mx51evk mx51evk mx51evk:IMX_CONFIG=board/freescale/mx51evk/imximage.cfg Stefano Babic sbabic@denx.de +Active arm armv7 mx5 freescale mx53ard mx53ard mx53ard:IMX_CONFIG=board/freescale/mx53ard/imximage_dd3.cfg Fabio Estevam fabio.estevam@freescale.com +Active arm armv7 mx5 freescale mx53evk mx53evk mx53evk:IMX_CONFIG=board/freescale/mx53evk/imximage.cfg Jason Liu r64343@freescale.com +Active arm armv7 mx5 freescale mx53loco mx53loco mx53loco:IMX_CONFIG=board/freescale/mx53loco/imximage.cfg Jason Liu r64343@freescale.com +Active arm armv7 mx5 freescale mx53smd mx53smd mx53smd:IMX_CONFIG=board/freescale/mx53smd/imximage.cfg Fabio Estevam fabio.estevam@freescale.com +Active arm armv7 mx5 genesi mx51_efikamx mx51_efikamx mx51_efikamx:MACH_TYPE=MACH_TYPE_MX51_EFIKAMX,IMX_CONFIG=board/genesi/mx51_efikamx/imximage_mx.cfg - +Active arm armv7 mx5 genesi mx51_efikamx mx51_efikasb mx51_efikamx:MACH_TYPE=MACH_TYPE_MX51_EFIKASB,IMX_CONFIG=board/genesi/mx51_efikamx/imximage_sb.cfg - +Active arm armv7 mx5 ttcontrol vision2 vision2 vision2:IMX_CONFIG=board/ttcontrol/vision2/imximage_hynix.cfg Stefano Babic sbabic@denx.de +Active arm armv7 mx6 - wandboard wandboard_dl wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024 Fabio Estevam fabio.estevam@freescale.com +Active arm armv7 mx6 - wandboard wandboard_quad wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048 Fabio Estevam fabio.estevam@freescale.com +Active arm armv7 mx6 - wandboard wandboard_solo wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512 Fabio Estevam fabio.estevam@freescale.com +Active arm armv7 mx6 boundary nitrogen6x nitrogen6dl nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024 Eric Nelson eric.nelson@boundarydevices.com +Active arm armv7 mx6 boundary nitrogen6x nitrogen6dl2g nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg,MX6DL,DDR_MB=2048 Eric Nelson eric.nelson@boundarydevices.com +Active arm armv7 mx6 boundary nitrogen6x nitrogen6q nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024 Eric Nelson eric.nelson@boundarydevices.com +Active arm armv7 mx6 boundary nitrogen6x nitrogen6q2g nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048 Eric Nelson eric.nelson@boundarydevices.com +Active arm armv7 mx6 boundary nitrogen6x nitrogen6s nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512 Eric Nelson eric.nelson@boundarydevices.com +Active arm armv7 mx6 boundary nitrogen6x nitrogen6s1g nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024 Eric Nelson eric.nelson@boundarydevices.com +Active arm armv7 mx6 congatec cgtqmx6eval cgtqmx6qeval cgtqmx6eval:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg,MX6Q Leo Sartre lsartre@adeneo-embedded.com +Active arm armv7 mx6 freescale mx6qarm2 mx6qarm2 mx6qarm2:IMX_CONFIG=board/freescale/mx6qarm2/imximage.cfg Jason Liu r64343@freescale.com +Active arm armv7 mx6 freescale mx6qsabreauto mx6qsabreauto mx6qsabreauto:IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg,MX6Q Fabio Estevam fabio.estevam@freescale.com +Active arm armv7 mx6 freescale mx6qsabrelite mx6qsabrelite mx6qsabrelite:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg Jason Liu r64343@freescale.com +Active arm armv7 mx6 freescale mx6sabresd mx6dlsabresd mx6sabresd:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL Fabio Estevam fabio.estevam@freescale.com +Active arm armv7 mx6 freescale mx6sabresd mx6qsabresd mx6sabresd:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg,MX6Q Fabio Estevam fabio.estevam@freescale.com +Active arm armv7 mx6 freescale mx6slevk mx6slevk mx6slevk:IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL Fabio Estevam fabio.estevam@freescale.com +Active arm armv7 mx6 freescale titanium titanium titanium:IMX_CONFIG=board/freescale/titanium/imximage.cfg Stefan Roese sr@denx.de +Active arm armv7 omap3 - overo omap3_overo - Steve Sakoman sakoman@gmail.com +Active arm armv7 omap3 - pandora omap3_pandora - Grazvydas Ignotas notasas@gmail.com +Active arm armv7 omap3 8dtech eco5pk eco5pk - Raphael Assenat raph@8d.com +Active arm armv7 omap3 comelit dig297 dig297 - Luca Ceresoli luca.ceresoli@comelit.it +Active arm armv7 omap3 compulab cm_t35 cm_t35 - Igor Grinberg grinberg@compulab.co.il +Active arm armv7 omap3 corscience tricorder tricorder - Thomas Weber weber@corscience.de +Active arm armv7 omap3 htkw mcx mcx - Ilya Yanok yanok@emcraft.com +Active arm armv7 omap3 isee igep00x0 igep0020 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0020,BOOT_ONENAND Enric Balletbo i Serra eballetbo@iseebcn.com +Active arm armv7 omap3 isee igep00x0 igep0020_nand igep00x0:MACH_TYPE=MACH_TYPE_IGEP0020,BOOT_NAND - +Active arm armv7 omap3 isee igep00x0 igep0030 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_ONENAND Enric Balletbo i Serra eballetbo@iseebcn.com +Active arm armv7 omap3 isee igep00x0 igep0030_nand igep00x0:MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_NAND - +Active arm armv7 omap3 isee igep00x0 igep0032 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0032,BOOT_ONENAND Enric Balletbo i Serra eballetbo@iseebcn.com +Active arm armv7 omap3 logicpd am3517evm am3517_evm - Vaibhav Hiremath hvaibhav@ti.com +Active arm armv7 omap3 logicpd omap3som omap3_logic - Peter Barada peter.barada@logicpd.com +Active arm armv7 omap3 logicpd zoom1 omap3_zoom1 - Nishanth Menon nm@ti.com +Active arm armv7 omap3 logicpd zoom2 omap3_zoom2 - Tom Rix Tom.Rix@windriver.com +Active arm armv7 omap3 matrix_vision mvblx omap3_mvblx - Michael Jones michael.jones@matrix-vision.de +Active arm armv7 omap3 nokia rx51 nokia_rx51 - Pali Rohár pali.rohar@gmail.com +Active arm armv7 omap3 technexion twister twister - Stefano Babic sbabic@denx.de +Active arm armv7 omap3 teejet mt_ventoux mt_ventoux - Stefano Babic sbabic@denx.de +Active arm armv7 omap3 ti am3517crane am3517_crane - Nagendra T S nagendra@mistralsolutions.com +Active arm armv7 omap3 ti beagle omap3_beagle - Tom Rini trini@ti.com +Active arm armv7 omap3 ti evm omap3_evm - Tom Rini trini@ti.com +Active arm armv7 omap3 ti evm omap3_evm_quick_mmc - - +Active arm armv7 omap3 ti evm omap3_evm_quick_nand - - +Active arm armv7 omap3 ti sdp3430 omap3_sdp3430 - Nishanth Menon nm@ti.com +Active arm armv7 omap3 timll devkit8000 devkit8000 - Thomas Weber weber@corscience.de +Active arm armv7 omap4 ti panda omap4_panda - Sricharan R r.sricharan@ti.com +Active arm armv7 omap4 ti sdp4430 omap4_sdp4430 - Sricharan R r.sricharan@ti.com +Active arm armv7 omap5 ti dra7xx dra7xx_evm - Lokesh Vutla lokeshvutla@ti.com +Active arm armv7 omap5 ti omap5_uevm omap5_uevm - - +Active arm armv7 rmobile atmark-techno armadillo-800eva armadillo-800eva - Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com +Active arm armv7 rmobile kmc kzm9g kzm9g - Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com:Tetsuyuki Kobayashi koba@kmckk.co.jp +Active arm armv7 s5pc1xx samsung goni s5p_goni - Minkyu Kang mk7.kang@samsung.com +Active arm armv7 s5pc1xx samsung smdkc100 smdkc100 - Minkyu Kang mk7.kang@samsung.com +Active arm armv7 socfpga altera socfpga socfpga_cyclone5 - Chin Liang See clsee@altera.com:Dinh Nguyen dinguyen@altera.com +Active arm armv7 u8500 st-ericsson snowball snowball - Mathieu Poirier mathieu.poirier@linaro.org +Active arm armv7 u8500 st-ericsson u8500 u8500_href - - +Active arm armv7 vf610 freescale vf610twr vf610twr vf610twr:IMX_CONFIG=board/freescale/vf610twr/imximage.cfg Alison Wang b18965@freescale.com +Active arm armv7 zynq xilinx zynq zynq - Michal Simek monstr@monstr.eu +Active arm armv7 zynq xilinx zynq zynq_dcc zynq:ZYNQ_DCC Michal Simek monstr@monstr.eu +Active arm armv7:arm720t tegra114 nvidia dalmore dalmore - Tom Warren twarren@nvidia.com +Active arm armv7:arm720t tegra20 avionic-design medcom-wide medcom-wide - Thierry Reding thierry.reding@avionic-design.de +Active arm armv7:arm720t tegra20 avionic-design plutux plutux - Thierry Reding thierry.reding@avionic-design.de +Active arm armv7:arm720t tegra20 avionic-design tec tec - Thierry Reding thierry.reding@avionic-design.de +Active arm armv7:arm720t tegra20 compal paz00 paz00 - Tom Warren twarren@nvidia.com:Stephen Warren swarren@nvidia.com +Active arm armv7:arm720t tegra20 compulab trimslice trimslice - Tom Warren twarren@nvidia.com:Stephen Warren swarren@nvidia.com +Active arm armv7:arm720t tegra20 nvidia harmony harmony - Tom Warren twarren@nvidia.com +Active arm armv7:arm720t tegra20 nvidia seaboard seaboard - Tom Warren twarren@nvidia.com +Active arm armv7:arm720t tegra20 nvidia ventana ventana - Tom Warren twarren@nvidia.com:Stephen Warren swarren@nvidia.com +Active arm armv7:arm720t tegra20 nvidia whistler whistler - Tom Warren twarren@nvidia.com:Stephen Warren swarren@nvidia.com +Active arm armv7:arm720t tegra20 toradex colibri_t20_iris colibri_t20_iris - Lucas Stach dev@lynxeye.de +Active arm armv7:arm720t tegra30 nvidia beaver beaver - Tom Warren twarren@nvidia.com:Stephen Warren swarren@nvidia.com +Active arm armv7:arm720t tegra30 nvidia cardhu cardhu - Tom Warren twarren@nvidia.com +Active arm ixp - - - actux2 - Michael Schwingen michael@schwingen.org +Active arm ixp - - - actux3 - Michael Schwingen michael@schwingen.org +Active arm ixp - - - actux4 - Michael Schwingen michael@schwingen.org +Active arm ixp - - - dvlhost - Michael Schwingen michael@schwingen.org +Active arm ixp - - actux1 actux1_4_16 actux1:FLASH2X2 Michael Schwingen michael@schwingen.org +Active arm ixp - - actux1 actux1_4_32 actux1:FLASH2X2,RAM_32MB Michael Schwingen michael@schwingen.org +Active arm ixp - - actux1 actux1_8_16 actux1:FLASH1X8 Michael Schwingen michael@schwingen.org +Active arm ixp - - actux1 actux1_8_32 actux1:FLASH1X8,RAM_32MB Michael Schwingen michael@schwingen.org +Active arm ixp - prodrive pdnb3 pdnb3 - Stefan Roese sr@denx.de +Active arm ixp - prodrive pdnb3 scpu pdnb3:SCPU Stefan Roese sr@denx.de +Active arm pxa - - - balloon3 - Marek Vasut marek.vasut@gmail.com +Active arm pxa - - - h2200 - Lukasz Dalek luk0104@gmail.com +Active arm pxa - - - palmld - Marek Vasut marek.vasut@gmail.com +Active arm pxa - - - palmtc - Marek Vasut marek.vasut@gmail.com +Active arm pxa - - - palmtreo680 - Mike Dunn mikedunn@newsguy.com +Active arm pxa - - - pxa255_idp - Cliff Brake cliff.brake@gmail.com +Active arm pxa - - - trizepsiv - Stefano Babic sbabic@denx.de +Active arm pxa - - - xaeniax - - +Active arm pxa - - - zipitz2 - Marek Vasut marek.vasut@gmail.com +Active arm pxa - - trizepsiv polaris trizepsiv:POLARIS Stefano Babic sbabic@denx.de +Active arm pxa - - vpac270 vpac270_nor_128 vpac270:NOR,RAM_128M Marek Vasut marek.vasut@gmail.com +Active arm pxa - - vpac270 vpac270_nor_256 vpac270:NOR,RAM_256M Marek Vasut marek.vasut@gmail.com +Active arm pxa - - vpac270 vpac270_ond_256 vpac270:ONENAND,RAM_256M Marek Vasut marek.vasut@gmail.com +Active arm pxa - icpdas lp8x4x lp8x4x - Sergey Yanovich ynvich@gmail.com +Active arm pxa - toradex - colibri_pxa270 - Marek Vasut marek.vasut@gmail.com +Active arm sa1100 - - - jornada - Kristoffer Ericson kristoffer.ericson@gmail.com +Active avr32 at32ap at32ap700x atmel - atngw100 - Haavard Skinnemoen haavard.skinnemoen@atmel.com +Active avr32 at32ap at32ap700x atmel - atngw100mkii - Andreas Bießmann andreas.devel@googlemail.com +Active avr32 at32ap at32ap700x atmel atstk1000 atstk1002 - Haavard Skinnemoen haavard.skinnemoen@atmel.com +Active avr32 at32ap at32ap700x atmel atstk1000 atstk1003 - Haavard Skinnemoen haavard.skinnemoen@atmel.com +Active avr32 at32ap at32ap700x atmel atstk1000 atstk1004 - Haavard Skinnemoen haavard.skinnemoen@atmel.com +Active avr32 at32ap at32ap700x atmel atstk1000 atstk1006 - Haavard Skinnemoen haavard.skinnemoen@atmel.com +Active avr32 at32ap at32ap700x earthlcd - favr-32-ezkit - Hans-Christian Egtvedt hans-christian.egtvedt@atmel.com +Active avr32 at32ap at32ap700x in-circuit - grasshopper - Andreas Bießmann andreas.devel@googlemail.com +Active avr32 at32ap at32ap700x mimc - mimc200 - Mark Jackson mpfj@mimc.co.uk +Active avr32 at32ap at32ap700x miromico - hammerhead - Julien May julien.may@miromico.ch:Alex Raimondi alex.raimondi@miromico.ch +Active blackfin blackfin - - - bct-brettl2 - Peter Meerwald devel@bct-electronic.com +Active blackfin blackfin - - - bf506f-ezkit - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf518f-ezbrd - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf525-ucr2 - Haitao Zhang hzhang@ucrobotics.com:Chong Huang chuang@ucrobotics.com +Active blackfin blackfin - - - bf526-ezbrd - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf527-ad7160-eval - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf527-ezkit - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf527-sdp - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf533-ezkit - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf533-stamp - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf537-minotaur - Martin Strubel strubel@section5.ch +Active blackfin blackfin - - - bf537-pnav - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf537-srv1 - Martin Strubel strubel@section5.ch +Active blackfin blackfin - - - bf537-stamp - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf538f-ezkit - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf548-ezkit - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf561-acvilon - Anton Shurpin shurpin.aa@niistt.ru:Valentin Yakovenkov yakovenkov@niistt.ru +Active blackfin blackfin - - - bf561-ezkit - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf609-ezkit - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - blackstamp - Wojtek Skulski skulski@pas.rochester.edu:Wojtek Skulski info@skutek.com:Benjamin Matthews mben12@gmail.com +Active blackfin blackfin - - - blackvme - Wojtek Skulski skulski@pas.rochester.edu:Wojtek Skulski info@skutek.com:Benjamin Matthews mben12@gmail.com +Active blackfin blackfin - - - br4 - Dimitar Penev dpn@switchfin.org +Active blackfin blackfin - - - cm-bf527 - Bluetechnix Tinyboards bluetechnix@blackfin.uclinux.org +Active blackfin blackfin - - - cm-bf533 - Bluetechnix Tinyboards bluetechnix@blackfin.uclinux.org +Active blackfin blackfin - - - cm-bf537e - Bluetechnix Tinyboards bluetechnix@blackfin.uclinux.org +Active blackfin blackfin - - - cm-bf537u - Bluetechnix Tinyboards bluetechnix@blackfin.uclinux.org +Active blackfin blackfin - - - cm-bf548 - Bluetechnix Tinyboards bluetechnix@blackfin.uclinux.org +Active blackfin blackfin - - - cm-bf561 - Bluetechnix Tinyboards bluetechnix@blackfin.uclinux.org +Active blackfin blackfin - - - dnp5370 - M.Hasewinkel info@ssv-embedded.de +Active blackfin blackfin - - - ibf-dsp561 - I-SYST Micromodule support@i-syst.com +Active blackfin blackfin - - - ip04 - Brent Kandetzki brentk@teleco.com +Active blackfin blackfin - - - pr1 - Dimitar Penev dpn@switchfin.org +Active blackfin blackfin - - - tcm-bf518 - Bluetechnix Tinyboards bluetechnix@blackfin.uclinux.org +Active blackfin blackfin - - - tcm-bf537 - Bluetechnix Tinyboards bluetechnix@blackfin.uclinux.org +Active blackfin blackfin - - bf527-ezkit bf527-ezkit-v2 bf527-ezkit:BF527_EZKIT_REV_2_1 Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active m68k mcf5227x - freescale m52277evb M52277EVB M52277EVB:SYS_SPANSION_BOOT,SYS_TEXT_BASE=0x00000000 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf5227x - freescale m52277evb M52277EVB_stmicro M52277EVB:CF_SBF,SYS_STMICRO_BOOT,SYS_TEXT_BASE=0x43E00000 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf523x - freescale m5235evb M5235EVB M5235EVB:SYS_TEXT_BASE=0xFFE00000 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf523x - freescale m5235evb M5235EVB_Flash32 M5235EVB:NORFLASH_PS32BIT,SYS_TEXT_BASE=0xFFC00000 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf52x2 - - - idmr - - +Active m68k mcf52x2 - - cobra5272 cobra5272 - - +Active m68k mcf52x2 - BuS eb_cpu5282 eb_cpu5282 eb_cpu5282:SYS_TEXT_BASE=0xFF000000,SYS_MONITOR_BASE=0xFF000400 Jens Scharsig esw@bus-elektronik.de +Active m68k mcf52x2 - BuS eb_cpu5282 eb_cpu5282_internal eb_cpu5282:SYS_TEXT_BASE=0xF0000000,SYS_MONITOR_BASE=0xF0000418 Jens Scharsig esw@bus-elektronik.de +Active m68k mcf52x2 - esd tasreg TASREG - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active m68k mcf52x2 - freescale m5208evbe M5208EVBE - - +Active m68k mcf52x2 - freescale m5249evb M5249EVB - - +Active m68k mcf52x2 - freescale m5253demo M5253DEMO - TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf52x2 - freescale m5253evbe M5253EVBE - Hayden Fraser Hayden.Fraser@freescale.com +Active m68k mcf52x2 - freescale m5271evb M5271EVB - - +Active m68k mcf52x2 - freescale m5272c3 M5272C3 - - +Active m68k mcf52x2 - freescale m5275evb M5275EVB - - +Active m68k mcf52x2 - freescale m5282evb M5282EVB - - +Active m68k mcf532x - astro mcf5373l astro_mcf5373l - Wolfgang Wegner w.wegner@astro-kom.de +Active m68k mcf532x - freescale m53017evb M53017EVB - TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf532x - freescale m5329evb M5329AFEE M5329EVB:NANDFLASH_SIZE=0 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf532x - freescale m5329evb M5329BFEE M5329EVB:NANDFLASH_SIZE=16 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf532x - freescale m5373evb M5373EVB M5373EVB:NANDFLASH_SIZE=16 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf5445x - freescale m54418twr M54418TWR M54418TWR:CF_SBF,SYS_SERIAL_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=50000000 - +Active m68k mcf5445x - freescale m54418twr M54418TWR_nand_mii M54418TWR:SYS_NAND_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=25000000 - +Active m68k mcf5445x - freescale m54418twr M54418TWR_nand_rmii M54418TWR:SYS_NAND_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=50000000 - +Active m68k mcf5445x - freescale m54418twr M54418TWR_nand_rmii_lowfreq M54418TWR:SYS_NAND_BOOT,LOW_MCFCLK,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=50000000 - +Active m68k mcf5445x - freescale m54418twr M54418TWR_serial_mii M54418TWR:CF_SBF,SYS_SERIAL_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=25000000 - +Active m68k mcf5445x - freescale m54418twr M54418TWR_serial_rmii M54418TWR:CF_SBF,SYS_SERIAL_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=50000000 - +Active m68k mcf5445x - freescale m54451evb M54451EVB M54451EVB:SYS_TEXT_BASE=0x00000000,SYS_INPUT_CLKSRC=24000000 - +Active m68k mcf5445x - freescale m54451evb M54451EVB_stmicro M54451EVB:CF_SBF,SYS_STMICRO_BOOT,SYS_TEXT_BASE=0x47e00000,SYS_INPUT_CLKSRC=24000000 - +Active m68k mcf5445x - freescale m54455evb M54455EVB M54455EVB:SYS_ATMEL_BOOT,SYS_TEXT_BASE=0x04000000,SYS_INPUT_CLKSRC=33333333 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf5445x - freescale m54455evb M54455EVB_a66 M54455EVB:SYS_ATMEL_BOOT,SYS_TEXT_BASE=0x04000000,SYS_INPUT_CLKSRC=66666666 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf5445x - freescale m54455evb M54455EVB_i66 M54455EVB:SYS_INTEL_BOOT,SYS_TEXT_BASE=0x00000000,SYS_INPUT_CLKSRC=66666666 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf5445x - freescale m54455evb M54455EVB_intel M54455EVB:SYS_INTEL_BOOT,SYS_TEXT_BASE=0x00000000,SYS_INPUT_CLKSRC=33333333 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf5445x - freescale m54455evb M54455EVB_stm33 M54455EVB:SYS_STMICRO_BOOT,CF_SBF,SYS_TEXT_BASE=0x4FE00000,SYS_INPUT_CLKSRC=33333333 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m547xevb M5475AFE M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m547xevb M5475BFE M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m547xevb M5475CFE M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16,SYS_VIDEO,SYS_USBCTRL TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m547xevb M5475DFE M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_USBCTRL TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m547xevb M5475EFE M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_VIDEO,SYS_USBCTRL TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m547xevb M5475FFE M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=32,SYS_VIDEO,SYS_USBCTRL,SYS_DRAMSZ1=64 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m547xevb M5475GFE M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=4,SYS_DRAMSZ=64 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m548xevb M5485AFE M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m548xevb M5485BFE M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m548xevb M5485CFE M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16,SYS_VIDEO,SYS_USBCTRL TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m548xevb M5485DFE M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_USBCTRL TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m548xevb M5485EFE M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_VIDEO,SYS_USBCTRL TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m548xevb M5485FFE M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=32,SYS_VIDEO,SYS_USBCTRL,SYS_DRAMSZ1=64 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m548xevb M5485GFE M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=4,SYS_DRAMSZ=64 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m548xevb M5485HFE M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16,SYS_VIDEO TsiChung Liew Tsi-Chung.Liew@freescale.com +Active microblaze microblaze - xilinx microblaze-generic microblaze-generic - Michal Simek monstr@monstr.eu +Active mips mips32 - - qemu-malta qemu_malta qemu-malta:MIPS32,SYS_BIG_ENDIAN - +Active mips mips32 - - qemu-malta qemu_maltael qemu-malta:MIPS32,SYS_LITTLE_ENDIAN - +Active mips mips32 - - qemu-mips qemu_mips qemu-mips:SYS_BIG_ENDIAN Vlad Lungu vlad.lungu@windriver.com +Active mips mips32 - - qemu-mips qemu_mipsel qemu-mips:SYS_LITTLE_ENDIAN - +Active mips mips32 - micronas vct vct_platinum vct:VCT_PLATINUM - +Active mips mips32 - micronas vct vct_platinum_onenand vct:VCT_PLATINUM,VCT_ONENAND - +Active mips mips32 - micronas vct vct_platinum_onenand_small vct:VCT_PLATINUM,VCT_ONENAND,VCT_SMALL_IMAGE - +Active mips mips32 - micronas vct vct_platinum_small vct:VCT_PLATINUM,VCT_SMALL_IMAGE - +Active mips mips32 - micronas vct vct_platinumavc vct:VCT_PLATINUMAVC - +Active mips mips32 - micronas vct vct_platinumavc_onenand vct:VCT_PLATINUMAVC,VCT_ONENAND - +Active mips mips32 - micronas vct vct_platinumavc_onenand_small vct:VCT_PLATINUMAVC,VCT_ONENAND,VCT_SMALL_IMAGE - +Active mips mips32 - micronas vct vct_platinumavc_small vct:VCT_PLATINUMAVC,VCT_SMALL_IMAGE - +Active mips mips32 - micronas vct vct_premium vct:VCT_PREMIUM - +Active mips mips32 - micronas vct vct_premium_onenand vct:VCT_PREMIUM,VCT_ONENAND - +Active mips mips32 - micronas vct vct_premium_onenand_small vct:VCT_PREMIUM,VCT_ONENAND,VCT_SMALL_IMAGE - +Active mips mips32 - micronas vct vct_premium_small vct:VCT_PREMIUM,VCT_SMALL_IMAGE - +Active mips mips32 au1x00 - pb1x00 pb1000 pb1x00:PB1000 - +Active mips mips32 incaip - incaip incaip - Wolfgang Denk wd@denx.de +Active mips mips32 incaip - incaip incaip_100MHz incaip:CPU_CLOCK_RATE=100000000 Wolfgang Denk wd@denx.de +Active mips mips32 incaip - incaip incaip_133MHz incaip:CPU_CLOCK_RATE=133000000 Wolfgang Denk wd@denx.de +Active mips mips32 incaip - incaip incaip_150MHz incaip:CPU_CLOCK_RATE=150000000 Wolfgang Denk wd@denx.de +Active mips mips64 - - qemu-mips qemu_mips64 qemu-mips64:SYS_BIG_ENDIAN - +Active mips mips64 - - qemu-mips qemu_mips64el qemu-mips64:SYS_LITTLE_ENDIAN - +Active nds32 n1213 ag101 AndesTech adp-ag101 adp-ag101 - Macpaul Lin macpaul@andestech.com +Active nds32 n1213 ag101 AndesTech adp-ag101p adp-ag101p - Macpaul Lin macpaul@andestech.com +Active nds32 n1213 ag102 AndesTech adp-ag102 adp-ag102 - Macpaul Lin macpaul@andestech.com +Active nios2 nios2 - altera nios2-generic nios2-generic - Scott McNutt smcnutt@psyent.com +Active nios2 nios2 - psyent pci5441 PCI5441 - Scott McNutt smcnutt@psyent.com +Active nios2 nios2 - psyent pk1c20 PK1C20 - Scott McNutt smcnutt@psyent.com +Active openrisc or1200 - openrisc openrisc-generic openrisc-generic - Stefan Kristiansson stefan.kristiansson@saunalahti.fi +Active powerpc 74xx_7xx - - - ppmc7xx - - +Active powerpc 74xx_7xx - - evb64260 P3G4 - Wolfgang Denk wd@denx.de:- +Active powerpc 74xx_7xx - - evb64260 ZUMA - Nye Liu nyet@zumanetworks.com:- +Active powerpc 74xx_7xx - eltec elppc ELPPC - - +Active powerpc 74xx_7xx - esd cpci750 CPCI750 - Reinhard Arlt reinhard.arlt@esd-electronics.com +Active powerpc 74xx_7xx - freescale mpc7448hpc2 mpc7448hpc2 - Roy Zang tie-fei.zang@freescale.com +Active powerpc 74xx_7xx - Marvell db64360 DB64360 - - +Active powerpc 74xx_7xx - Marvell db64460 DB64460 - - +Active powerpc 74xx_7xx - prodrive p3mx p3m7448 p3mx:P3M7448 Stefan Roese sr@denx.de +Active powerpc 74xx_7xx - prodrive p3mx p3m750 p3mx:P3M750 Stefan Roese sr@denx.de +Active powerpc mpc512x - - - pdm360ng - Michael Weiss michael.weiss@ifm.com +Active powerpc mpc512x - davedenx - aria - Wolfgang Denk wd@denx.de +Active powerpc mpc512x - esd - mecp5123 - Reinhard Arlt reinhard.arlt@esd-electronics.com +Active powerpc mpc512x - freescale mpc5121ads mpc5121ads - - +Active powerpc mpc512x - freescale mpc5121ads mpc5121ads_rev2 mpc5121ads:MPC5121ADS_REV2 - +Active powerpc mpc512x - ifm ac14xx ac14xx - Anatolij Gustschin agust@denx.de +Active powerpc mpc5xx - - cmi cmi_mpc5xx - - +Active powerpc mpc5xx - mpl pati PATI - - +Active powerpc mpc5xxx - - - canmb - - +Active powerpc mpc5xxx - - - cm5200 - - +Active powerpc mpc5xxx - - - inka4x0 - Detlev Zundel dzu@denx.de +Active powerpc mpc5xxx - - - ipek01 - Wolfgang Grandegger wg@denx.de +Active powerpc mpc5xxx - - - jupiter - Heiko Schocher hs@denx.de +Active powerpc mpc5xxx - - - motionpro - - +Active powerpc mpc5xxx - - - munices - - +Active powerpc mpc5xxx - - - v38b - - +Active powerpc mpc5xxx - - a3m071 a3m071 - Stefan Roese sr@denx.de +Active powerpc mpc5xxx - - a3m071 a4m2k a3m071:A4M2K Stefan Roese sr@denx.de +Active powerpc mpc5xxx - - a4m072 a4m072 - Sergei Poselenov sposelenov@emcraft.com +Active powerpc mpc5xxx - - bc3450 BC3450 - - +Active powerpc mpc5xxx - - galaxy5200 galaxy5200 galaxy5200:galaxy5200 Eric Millbrandt emillbrandt@dekaresearch.com +Active powerpc mpc5xxx - - galaxy5200 galaxy5200_LOWBOOT galaxy5200:galaxy5200_LOWBOOT Eric Millbrandt emillbrandt@dekaresearch.com +Active powerpc mpc5xxx - - icecube icecube_5200 IceCube Wolfgang Denk wd@denx.de +Active powerpc mpc5xxx - - icecube icecube_5200_DDR IceCube:MPC5200_DDR - +Active powerpc mpc5xxx - - icecube icecube_5200_DDR_LOWBOOT IceCube:SYS_TEXT_BASE=0xFF800000,MPC5200_DDR - +Active powerpc mpc5xxx - - icecube icecube_5200_DDR_LOWBOOT08 IceCube:SYS_TEXT_BASE=0xFF800000,MPC5200_DDR - +Active powerpc mpc5xxx - - icecube icecube_5200_LOWBOOT IceCube:SYS_TEXT_BASE=0xFF000000 - +Active powerpc mpc5xxx - - icecube icecube_5200_LOWBOOT08 IceCube:SYS_TEXT_BASE=0xFF800000 - +Active powerpc mpc5xxx - - icecube Lite5200 IceCube - +Active powerpc mpc5xxx - - icecube Lite5200_LOWBOOT IceCube:SYS_TEXT_BASE=0xFF000000 - +Active powerpc mpc5xxx - - icecube Lite5200_LOWBOOT08 IceCube:SYS_TEXT_BASE=0xFF800000 - +Active powerpc mpc5xxx - - icecube lite5200b IceCube:MPC5200_DDR,LITE5200B - +Active powerpc mpc5xxx - - icecube lite5200b_LOWBOOT IceCube:MPC5200_DDR,LITE5200B,SYS_TEXT_BASE=0xFF000000 - +Active powerpc mpc5xxx - - icecube lite5200b_PM IceCube:MPC5200_DDR,LITE5200B,LITE5200B_PM - +Active powerpc mpc5xxx - - mcc200 mcc200 mcc200 - +Active powerpc mpc5xxx - - mcc200 mcc200_COM12 mcc200:CONSOLE_COM12 - +Active powerpc mpc5xxx - - mcc200 mcc200_COM12_highboot mcc200:CONSOLE_COM12,SYS_TEXT_BASE=0xFFF00000 - +Active powerpc mpc5xxx - - mcc200 mcc200_COM12_highboot_SDRAM mcc200:CONSOLE_COM12,SYS_TEXT_BASE=0xFFF00000,MCC200_SDRAM - +Active powerpc mpc5xxx - - mcc200 mcc200_COM12_SDRAM mcc200:CONSOLE_COM12,MCC200_SDRAM - +Active powerpc mpc5xxx - - mcc200 mcc200_highboot mcc200:SYS_TEXT_BASE=0xFFF00000 - +Active powerpc mpc5xxx - - mcc200 mcc200_highboot_SDRAM mcc200:SYS_TEXT_BASE=0xFFF00000,MCC200_SDRAM - +Active powerpc mpc5xxx - - mcc200 mcc200_SDRAM mcc200:MCC200_SDRAM - +Active powerpc mpc5xxx - - mcc200 prs200 mcc200:PRS200,MCC200_SDRAM - +Active powerpc mpc5xxx - - mcc200 prs200_DDR mcc200:PRS200 - +Active powerpc mpc5xxx - - mcc200 prs200_highboot mcc200:PRS200,SYS_TEXT_BASE=0xFFF00000,MCC200_SDRAM - +Active powerpc mpc5xxx - - mcc200 prs200_highboot_DDR mcc200:PRS200,SYS_TEXT_BASE=0xFFF00000 - +Active powerpc mpc5xxx - - pm520 PM520 - Josef Wagner Wagner@Microsys.de +Active powerpc mpc5xxx - - pm520 PM520_DDR PM520:MPC5200_DDR Josef Wagner Wagner@Microsys.de +Active powerpc mpc5xxx - - pm520 PM520_ROMBOOT PM520:BOOT_ROM Josef Wagner Wagner@Microsys.de +Active powerpc mpc5xxx - - pm520 PM520_ROMBOOT_DDR PM520:MPC5200_DDR,BOOT_ROM Josef Wagner Wagner@Microsys.de +Active powerpc mpc5xxx - - total5200 Total5200 Total5200:TOTAL5200_REV=1 - +Active powerpc mpc5xxx - - total5200 Total5200_lowboot Total5200:TOTAL5200_REV=1,SYS_TEXT_BASE=0xFE000000 - +Active powerpc mpc5xxx - - total5200 Total5200_Rev2 Total5200:TOTAL5200_REV=2 - +Active powerpc mpc5xxx - - total5200 Total5200_Rev2_lowboot Total5200:TOTAL5200_REV=2,SYS_TEXT_BASE=0xFE000000 - +Active powerpc mpc5xxx - emk top5200 EVAL5200 TOP5200:EVAL5200 Reinhard Meyer reinhard.meyer@emk-elektronik.de +Active powerpc mpc5xxx - emk top5200 MINI5200 TOP5200:MINI5200 Reinhard Meyer reinhard.meyer@emk-elektronik.de +Active powerpc mpc5xxx - emk top5200 TOP5200 TOP5200:TOP5200 Reinhard Meyer reinhard.meyer@emk-elektronik.de +Active powerpc mpc5xxx - esd - cpci5200 - Reinhard Arlt reinhard.arlt@esd-electronics.com +Active powerpc mpc5xxx - esd - mecp5200 - Reinhard Arlt reinhard.arlt@esd-electronics.com +Active powerpc mpc5xxx - esd - pf5200 - Reinhard Arlt reinhard.arlt@esd-electronics.com +Active powerpc mpc5xxx - ifm o2dnt2 O2D o2d Anatolij Gustschin agust@denx.de +Active powerpc mpc5xxx - ifm o2dnt2 O2D300 o2d300 Anatolij Gustschin agust@denx.de +Active powerpc mpc5xxx - ifm o2dnt2 O2DNT2 o2dnt2 Anatolij Gustschin agust@denx.de +Active powerpc mpc5xxx - ifm o2dnt2 O2DNT2_RAMBOOT o2dnt2:SYS_TEXT_BASE=0x00100000 Anatolij Gustschin agust@denx.de +Active powerpc mpc5xxx - ifm o2dnt2 O2I o2i Anatolij Gustschin agust@denx.de +Active powerpc mpc5xxx - ifm o2dnt2 O2MNT o2mnt Anatolij Gustschin agust@denx.de +Active powerpc mpc5xxx - ifm o2dnt2 O2MNT_O2M110 o2mnt:IFM_SENSOR_TYPE="O2M110" Anatolij Gustschin agust@denx.de +Active powerpc mpc5xxx - ifm o2dnt2 O2MNT_O2M112 o2mnt:IFM_SENSOR_TYPE="O2M112" Anatolij Gustschin agust@denx.de +Active powerpc mpc5xxx - ifm o2dnt2 O2MNT_O2M113 o2mnt:IFM_SENSOR_TYPE="O2M113" Anatolij Gustschin agust@denx.de +Active powerpc mpc5xxx - ifm o2dnt2 O3DNT o3dnt Anatolij Gustschin agust@denx.de +Active powerpc mpc5xxx - intercontrol digsy_mtc digsy_mtc - Werner Pfister Pfister_Werner@intercontrol.de +Active powerpc mpc5xxx - intercontrol digsy_mtc digsy_mtc_RAMBOOT digsy_mtc:SYS_TEXT_BASE=0x00100000 Werner Pfister Pfister_Werner@intercontrol.de +Active powerpc mpc5xxx - intercontrol digsy_mtc digsy_mtc_rev5 digsy_mtc:DIGSY_REV5 Werner Pfister Pfister_Werner@intercontrol.de +Active powerpc mpc5xxx - intercontrol digsy_mtc digsy_mtc_rev5_RAMBOOT digsy_mtc:SYS_TEXT_BASE=0x00100000,DIGSY_REV5 Werner Pfister Pfister_Werner@intercontrol.de +Active powerpc mpc5xxx - manroland - hmi1001 - - +Active powerpc mpc5xxx - manroland - mucmc52 - Heiko Schocher hs@denx.de +Active powerpc mpc5xxx - manroland - uc101 - Heiko Schocher hs@denx.de +Active powerpc mpc5xxx - matrix_vision mvbc_p MVBC_P MVBC_P:MVBC_P Andre Schwarz andre.schwarz@matrix-vision.de +Active powerpc mpc5xxx - matrix_vision mvsmr MVSMR - Andre Schwarz andre.schwarz@matrix-vision.de +Active powerpc mpc5xxx - phytec pcm030 pcm030 pcm030 Jon Smirl jonsmirl@gmail.com +Active powerpc mpc5xxx - phytec pcm030 pcm030_LOWBOOT pcm030:SYS_TEXT_BASE=0xFF000000 Jon Smirl jonsmirl@gmail.com +Active powerpc mpc5xxx - tqc tqm5200 aev - - +Active powerpc mpc5xxx - tqc tqm5200 cam5200 TQM5200:CAM5200,TQM5200S,TQM5200_B - +Active powerpc mpc5xxx - tqc tqm5200 cam5200_niosflash TQM5200:CAM5200,TQM5200S,TQM5200_B,CAM5200_NIOSFLASH - +Active powerpc mpc5xxx - tqc tqm5200 charon charon Heiko Schocher hs@denx.de +Active powerpc mpc5xxx - tqc tqm5200 fo300 TQM5200:FO300 - +Active powerpc mpc5xxx - tqc tqm5200 MiniFAP TQM5200:MINIFAP - +Active powerpc mpc5xxx - tqc tqm5200 TB5200 - - +Active powerpc mpc5xxx - tqc tqm5200 TB5200_B TB5200:TQM5200_B - +Active powerpc mpc5xxx - tqc tqm5200 TQM5200 TQM5200: - +Active powerpc mpc5xxx - tqc tqm5200 TQM5200_B TQM5200:TQM5200_B - +Active powerpc mpc5xxx - tqc tqm5200 TQM5200_B_HIGHBOOT TQM5200:TQM5200_B,SYS_TEXT_BASE=0xFFF00000 - +Active powerpc mpc5xxx - tqc tqm5200 TQM5200_STK100 TQM5200:STK52XX_REV100 - +Active powerpc mpc5xxx - tqc tqm5200 TQM5200S TQM5200:TQM5200_B,TQM5200S - +Active powerpc mpc5xxx - tqc tqm5200 TQM5200S_HIGHBOOT TQM5200:TQM5200_B,TQM5200S,SYS_TEXT_BASE=0xFFF00000 - +Active powerpc mpc824x - - - utx8245 - Greg Allen gallen@arlut.utexas.edu +Active powerpc mpc824x - - a3000 A3000 - - +Active powerpc mpc824x - - cpc45 CPC45 CPC45 Josef Wagner Wagner@Microsys.de +Active powerpc mpc824x - - cpc45 CPC45_ROMBOOT CPC45:BOOT_ROM Josef Wagner Wagner@Microsys.de +Active powerpc mpc824x - - cu824 CU824 - Wolfgang Denk wd@denx.de +Active powerpc mpc824x - - eXalion eXalion - Torsten Demke torsten.demke@fci.com +Active powerpc mpc824x - - hidden_dragon HIDDEN_DRAGON - Yusdi Santoso yusdi_santoso@adaptec.com +Active powerpc mpc824x - - linkstation linkstation_HGLAN linkstation:HGLAN=1 Guennadi Liakhovetski g.liakhovetski@gmx.de +Active powerpc mpc824x - - musenki MUSENKI - Jim Thompson jim@musenki.com +Active powerpc mpc824x - - mvblue MVBLUE - - +Active powerpc mpc824x - - pn62 PN62 - Wolfgang Grandegger wg@denx.de +Active powerpc mpc824x - - sandpoint Sandpoint8240 - Wolfgang Denk wd@denx.de +Active powerpc mpc824x - - sandpoint Sandpoint8245 - Jim Thompson jim@musenki.com +Active powerpc mpc824x - etin - debris - Sangmoon Kim dogoil@etinsys.com +Active powerpc mpc824x - etin - kvme080 - Sangmoon Kim dogoil@etinsys.com +Active powerpc mpc8260 - - - atc - Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - - - ep8260 - Frank Panno fpanno@delphintech.com +Active powerpc mpc8260 - - - ep82xxm - - +Active powerpc mpc8260 - - - gw8260 - Oliver Brown obrown@adventnetworks.com +Active powerpc mpc8260 - - - hymod - Murray Jensen Murray.Jensen@csiro.au +Active powerpc mpc8260 - - - ppmc8260 - Brad Kemp Brad.Kemp@seranoa.com +Active powerpc mpc8260 - - - sacsng - Jerry Van Baren gerald.vanbaren@smiths-aerospace.com +Active powerpc mpc8260 - - cogent cogent_mpc8260 - Murray Jensen Murray.Jensen@csiro.au +Active powerpc mpc8260 - - cpu86 CPU86 CPU86 Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - - cpu86 CPU86_ROMBOOT CPU86:BOOT_ROM Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - - cpu87 CPU87 CPU87 - +Active powerpc mpc8260 - - cpu87 CPU87_ROMBOOT CPU87:BOOT_ROM - +Active powerpc mpc8260 - - ep8248 ep8248 - Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - - ep8248 ep8248E ep8248 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - - ids8247 IDS8247 - Heiko Schocher hs@denx.de +Active powerpc mpc8260 - - iphase4539 IPHASE4539 - Wolfgang Grandegger wg@denx.de +Active powerpc mpc8260 - - ispan ISPAN - Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - - ispan ISPAN_REVB ISPAN:SYS_REV_B Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - - muas3001 muas3001 - Heiko Schocher hs@denx.de +Active powerpc mpc8260 - - muas3001 muas3001_dev muas3001:MUAS_DEV_BOARD Heiko Schocher hs@denx.de +Active powerpc mpc8260 - - pm826 PM825 PM826:PCI,SYS_TEXT_BASE=0xFF000000 Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - - pm826 PM825_BIGFLASH PM826:PCI,FLASH_32MB,SYS_TEXT_BASE=0x40000000 Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - - pm826 PM825_ROMBOOT PM826:PCI,BOOT_ROM,SYS_TEXT_BASE=0xFF800000 Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - - pm826 PM825_ROMBOOT_BIGFLASH PM826:PCI,BOOT_ROM,FLASH_32MB,SYS_TEXT_BASE=0xFF800000 Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - - pm826 PM826 PM826:SYS_TEXT_BASE=0xFF000000 Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - - pm826 PM826_BIGFLASH PM826:FLASH_32MB,SYS_TEXT_BASE=0x40000000 Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - - pm826 PM826_ROMBOOT PM826:BOOT_ROM,SYS_TEXT_BASE=0xFF800000 Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - - pm826 PM826_ROMBOOT_BIGFLASH PM826:BOOT_ROM,FLASH_32MB,SYS_TEXT_BASE=0xFF800000 Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - - pm828 PM828 PM828 - +Active powerpc mpc8260 - - pm828 PM828_PCI PM828:PCI - +Active powerpc mpc8260 - - pm828 PM828_ROMBOOT PM828:BOOT_ROM,SYS_TEXT_BASE=0xFF800000 - +Active powerpc mpc8260 - - pm828 PM828_ROMBOOT_PCI PM828:PCI,BOOT_ROM,SYS_TEXT_BASE=0xFF800000 - +Active powerpc mpc8260 - - rattler Rattler Rattler Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - - rattler Rattler8248 Rattler:MPC8248 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - - zpc1900 ZPC1900 - Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads MPC8260ADS MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads MPC8260ADS_33MHz MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS,8260_CLKIN=33000000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads MPC8260ADS_33MHz_lowboot MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS,8260_CLKIN=33000000,SYS_TEXT_BASE=0xFF800000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads MPC8260ADS_40MHz MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS,8260_CLKIN=40000000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads MPC8260ADS_40MHz_lowboot MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS,8260_CLKIN=40000000,SYS_TEXT_BASE=0xFF800000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads MPC8260ADS_lowboot MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS,SYS_TEXT_BASE=0xFF800000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads MPC8272ADS MPC8260ADS:ADSTYPE=CONFIG_SYS_8272ADS Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads MPC8272ADS_lowboot MPC8260ADS:ADSTYPE=CONFIG_SYS_8272ADS,SYS_TEXT_BASE=0xFF800000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads PQ2FADS MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads PQ2FADS-VR MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,8260_CLKIN=66000000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads PQ2FADS-VR_lowboot MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,8260_CLKIN=66000000,SYS_TEXT_BASE=0xFF800000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads PQ2FADS-ZU MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads PQ2FADS-ZU_66MHz MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,8260_CLKIN=66000000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads PQ2FADS-ZU_66MHz_lowboot MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,8260_CLKIN=66000000,SYS_TEXT_BASE=0xFF800000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads PQ2FADS-ZU_lowboot MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,SYS_TEXT_BASE=0xFF800000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads PQ2FADS_lowboot MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,SYS_TEXT_BASE=0xFF800000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8266ads MPC8266ADS - Rune Torgersen runet@innovsys.com +Active powerpc mpc8260 - funkwerk vovpn-gw VoVPN-GW_66MHz VoVPN-GW:CLKIN_66MHz - +Active powerpc mpc8260 - keymile km82xx mgcoge km82xx:MGCOGE Holger Brunck holger.brunck@keymile.com +Active powerpc mpc8260 - keymile km82xx mgcoge3ne km82xx:MGCOGE3NE Holger Brunck holger.brunck@keymile.com +Active powerpc mpc8260 - tqc tqm8260 TQM8255_AA TQM8260:MPC8255,300MHz Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - tqc tqm8260 TQM8260_AA TQM8260:MPC8260,200MHz Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - tqc tqm8260 TQM8260_AB TQM8260:MPC8260,200MHz,L2_CACHE,BUSMODE_60x Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - tqc tqm8260 TQM8260_AC TQM8260:MPC8260,200MHz,L2_CACHE,BUSMODE_60x Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - tqc tqm8260 TQM8260_AD TQM8260:MPC8260,300MHz,BUSMODE_60x Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - tqc tqm8260 TQM8260_AE TQM8260:MPC8260,266MHz Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - tqc tqm8260 TQM8260_AF TQM8260:MPC8260,300MHz,BUSMODE_60x Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - tqc tqm8260 TQM8260_AG TQM8260:MPC8260,300MHz Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - tqc tqm8260 TQM8260_AH TQM8260:MPC8260,300MHz,L2_CACHE,BUSMODE_60x Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - tqc tqm8260 TQM8260_AI TQM8260:MPC8260,300MHz,BUSMODE_60x Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - tqc tqm8260 TQM8265_AA TQM8260:MPC8265,300MHz,BUSMODE_60x Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - tqc tqm8272 TQM8272 - - +Active powerpc mpc83xx - - - mpc8308_p1m - Ilya Yanok yanok@emcraft.com +Active powerpc mpc83xx - - sbc8349 sbc8349 sbc8349 Paul Gortmaker paul.gortmaker@windriver.com +Active powerpc mpc83xx - - sbc8349 sbc8349_PCI_33 sbc8349:PCI,PCI_33M Paul Gortmaker paul.gortmaker@windriver.com +Active powerpc mpc83xx - - sbc8349 sbc8349_PCI_66 sbc8349:PCI,PCI_66M Paul Gortmaker paul.gortmaker@windriver.com +Active powerpc mpc83xx - - ve8313 ve8313 - Heiko Schocher hs@denx.de +Active powerpc mpc83xx - esd vme8349 caddy2 vme8349:CADDY2 Reinhard Arlt reinhard.arlt@esd-electronics.com +Active powerpc mpc83xx - esd vme8349 vme8349 vme8349 Reinhard Arlt reinhard.arlt@esd-electronics.com +Active powerpc mpc83xx - freescale mpc8308rdb MPC8308RDB - Ilya Yanok yanok@emcraft.com +Active powerpc mpc83xx - freescale mpc8313erdb MPC8313ERDB_33 MPC8313ERDB:SYS_33MHZ - +Active powerpc mpc83xx - freescale mpc8313erdb MPC8313ERDB_66 MPC8313ERDB:SYS_66MHZ - +Active powerpc mpc83xx - freescale mpc8313erdb MPC8313ERDB_NAND_33 MPC8313ERDB:SYS_33MHZ,NAND - +Active powerpc mpc83xx - freescale mpc8313erdb MPC8313ERDB_NAND_66 MPC8313ERDB:SYS_66MHZ,NAND - +Active powerpc mpc83xx - freescale mpc8315erdb MPC8315ERDB MPC8315ERDB Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8315erdb MPC8315ERDB_NAND MPC8315ERDB:NAND_U_BOOT Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8323erdb MPC8323ERDB - Michael Barkowski michael.barkowski@freescale.com +Active powerpc mpc83xx - freescale mpc832xemds MPC832XEMDS MPC832XEMDS: Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc832xemds MPC832XEMDS_ATM MPC832XEMDS:PQ_MDS_PIB=1,PQ_MDS_PIB_ATM=1 Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc832xemds MPC832XEMDS_HOST_33 MPC832XEMDS:PCI,PCI_33M,PQ_MDS_PIB=1 Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc832xemds MPC832XEMDS_HOST_66 MPC832XEMDS:PCI,PCI_66M,PQ_MDS_PIB=1 Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc832xemds MPC832XEMDS_SLAVE MPC832XEMDS:PCI,PCISLAVE Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8349emds MPC8349EMDS - Kim Phillips kim.phillips@freescale.com +Active powerpc mpc83xx - freescale mpc8349itx MPC8349ITX MPC8349ITX:MPC8349ITX - +Active powerpc mpc83xx - freescale mpc8349itx MPC8349ITX_LOWBOOT MPC8349ITX:MPC8349ITX,SYS_TEXT_BASE=0xFE000000 - +Active powerpc mpc83xx - freescale mpc8349itx MPC8349ITXGP MPC8349ITX:MPC8349ITXGP,SYS_TEXT_BASE=0xFE000000 - +Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_33 MPC8360EMDS:CLKIN_33MHZ Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_33_ATM MPC8360EMDS:CLKIN_33MHZ,PQ_MDS_PIB=1,PQ_MDS_PIB_ATM=1 Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_33_HOST_33 MPC8360EMDS:CLKIN_33MHZ,PCI,PCI_33M,PQ_MDS_PIB=1 Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_33_HOST_66 MPC8360EMDS:CLKIN_33MHZ,PCI,PCI_66M,PQ_MDS_PIB=1 Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_33_SLAVE MPC8360EMDS:CLKIN_33MHZ,PCI,PCISLAVE Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_66 MPC8360EMDS:CLKIN_66MHZ Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_66_ATM MPC8360EMDS:CLKIN_66MHZ,PQ_MDS_PIB=1,PQ_MDS_PIB_ATM=1 Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_66_HOST_33 MPC8360EMDS:CLKIN_66MHZ,PCI,PCI_33M,PQ_MDS_PIB=1 Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_66_HOST_66 MPC8360EMDS:CLKIN_66MHZ,PCI,PCI_66M,PQ_MDS_PIB=1 Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_66_SLAVE MPC8360EMDS:CLKIN_66MHZ,PCI,PCISLAVE Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8360erdk MPC8360ERDK MPC8360ERDK Anton Vorontsov avorontsov@ru.mvista.com +Active powerpc mpc83xx - freescale mpc8360erdk MPC8360ERDK_33 MPC8360ERDK:CLKIN_33MHZ Anton Vorontsov avorontsov@ru.mvista.com +Active powerpc mpc83xx - freescale mpc8360erdk MPC8360ERDK_66 MPC8360ERDK Anton Vorontsov avorontsov@ru.mvista.com +Active powerpc mpc83xx - freescale mpc837xemds MPC837XEMDS MPC837XEMDS Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc837xemds MPC837XEMDS_HOST MPC837XEMDS:PCI Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc837xerdb MPC837XERDB - Joe D'Abbraccio ljd015@freescale.com +Active powerpc mpc83xx - keymile km83xx kmcoge5ne km8360:KMCOGE5NE Holger Brunck holger.brunck@keymile.com +Active powerpc mpc83xx - keymile km83xx kmeter1 km8360:KMETER1 Holger Brunck holger.brunck@keymile.com +Active powerpc mpc83xx - keymile km83xx kmopti2 tuxx1:KMOPTI2 Holger Brunck holger.brunck@keymile.com +Active powerpc mpc83xx - keymile km83xx kmsupx5 tuxx1:KMSUPX5 Holger Brunck holger.brunck@keymile.com:Heiko Schocher hs@denx.de +Active powerpc mpc83xx - keymile km83xx kmvect1 suvd3:KMVECT1 Holger Brunck holger.brunck@keymile.com +Active powerpc mpc83xx - keymile km83xx suvd3 suvd3:SUVD3 Holger Brunck holger.brunck@keymile.com +Active powerpc mpc83xx - keymile km83xx tuge1 tuxx1:TUGE1 Holger Brunck holger.brunck@keymile.com +Active powerpc mpc83xx - keymile km83xx tuxx1 tuxx1:TUXX1 Holger Brunck holger.brunck@keymile.com +Active powerpc mpc83xx - matrix_vision mergerbox MERGERBOX - Andre Schwarz andre.schwarz@matrix-vision.de +Active powerpc mpc83xx - matrix_vision mvblm7 MVBLM7 - Andre Schwarz andre.schwarz@matrix-vision.de +Active powerpc mpc83xx - sheldon simpc8313 SIMPC8313_LP SIMPC8313:NAND_LP Ron Madrid info@sheldoninst.com +Active powerpc mpc83xx - sheldon simpc8313 SIMPC8313_SP SIMPC8313:NAND_SP Ron Madrid info@sheldoninst.com +Active powerpc mpc83xx - tqc tqm834x TQM834x - - +Active powerpc mpc85xx - - sbc8548 sbc8548 sbc8548 Paul Gortmaker paul.gortmaker@windriver.com +Active powerpc mpc85xx - - sbc8548 sbc8548_PCI_33 sbc8548:PCI,33 Paul Gortmaker paul.gortmaker@windriver.com +Active powerpc mpc85xx - - sbc8548 sbc8548_PCI_33_PCIE sbc8548:PCI,33,PCIE Paul Gortmaker paul.gortmaker@windriver.com +Active powerpc mpc85xx - - sbc8548 sbc8548_PCI_66 sbc8548:PCI,66 Paul Gortmaker paul.gortmaker@windriver.com +Active powerpc mpc85xx - - sbc8548 sbc8548_PCI_66_PCIE sbc8548:PCI,66,PCIE Paul Gortmaker paul.gortmaker@windriver.com +Active powerpc mpc85xx - - socrates socrates - - +Active powerpc mpc85xx - exmeritus hww1u1a HWW1U1A - Kyle Moffett Kyle.D.Moffett@boeing.com +Active powerpc mpc85xx - freescale b4860qds B4420QDS B4860QDS:PPC_B4420 - +Active powerpc mpc85xx - freescale b4860qds B4420QDS_NAND B4860QDS:PPC_B4420,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale b4860qds B4420QDS_SPIFLASH B4860QDS:PPC_B4420,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale b4860qds B4860QDS B4860QDS:PPC_B4860 - +Active powerpc mpc85xx - freescale b4860qds B4860QDS_NAND B4860QDS:PPC_B4860,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale b4860qds B4860QDS_SPIFLASH B4860QDS:PPC_B4860,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale b4860qds B4860QDS_SRIO_PCIE_BOOT B4860QDS:PPC_B4860,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale bsc9131rdb BSC9131RDB_NAND BSC9131RDB:BSC9131RDB,NAND Poonam Aggrwal poonam.aggrwal@freescale.com +Active powerpc mpc85xx - freescale bsc9131rdb BSC9131RDB_NAND_SYSCLK100 BSC9131RDB:BSC9131RDB,NAND,SYS_CLK_100 Poonam Aggrwal poonam.aggrwal@freescale.com +Active powerpc mpc85xx - freescale bsc9131rdb BSC9131RDB_SPIFLASH BSC9131RDB:BSC9131RDB,SPIFLASH Poonam Aggrwal poonam.aggrwal@freescale.com +Active powerpc mpc85xx - freescale bsc9131rdb BSC9131RDB_SPIFLASH_SYSCLK100 BSC9131RDB:BSC9131RDB,SPIFLASH,SYS_CLK_100 Poonam Aggrwal poonam.aggrwal@freescale.com +Active powerpc mpc85xx - freescale bsc9132qds BSC9132QDS_NAND_DDRCLK100 BSC9132QDS:BSC9132QDS,NAND,SYS_CLK_100_DDR_100 Naveen Burmi NaveenBurmi@freescale.com +Active powerpc mpc85xx - freescale bsc9132qds BSC9132QDS_NAND_DDRCLK133 BSC9132QDS:BSC9132QDS,NAND,SYS_CLK_100_DDR_133 Naveen Burmi NaveenBurmi@freescale.com +Active powerpc mpc85xx - freescale bsc9132qds BSC9132QDS_NOR_DDRCLK100 BSC9132QDS:BSC9132QDS,SYS_CLK_100_DDR_100 Naveen Burmi NaveenBurmi@freescale.com +Active powerpc mpc85xx - freescale bsc9132qds BSC9132QDS_NOR_DDRCLK133 BSC9132QDS:BSC9132QDS,SYS_CLK_100_DDR_133 Naveen Burmi NaveenBurmi@freescale.com +Active powerpc mpc85xx - freescale bsc9132qds BSC9132QDS_SDCARD_DDRCLK100 BSC9132QDS:BSC9132QDS,SDCARD,SYS_CLK_100_DDR_100 Naveen Burmi NaveenBurmi@freescale.com +Active powerpc mpc85xx - freescale bsc9132qds BSC9132QDS_SDCARD_DDRCLK133 BSC9132QDS:BSC9132QDS,SDCARD,SYS_CLK_100_DDR_133 Naveen Burmi NaveenBurmi@freescale.com +Active powerpc mpc85xx - freescale bsc9132qds BSC9132QDS_SPIFLASH_DDRCLK100 BSC9132QDS:BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_100 Naveen Burmi NaveenBurmi@freescale.com +Active powerpc mpc85xx - freescale bsc9132qds BSC9132QDS_SPIFLASH_DDRCLK133 BSC9132QDS:BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_133 Naveen Burmi NaveenBurmi@freescale.com +Active powerpc mpc85xx - freescale corenet_ds P3041DS - - +Active powerpc mpc85xx - freescale corenet_ds P3041DS_NAND P3041DS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P3041DS_SDCARD P3041DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P3041DS_SECURE_BOOT P3041DS:SECURE_BOOT - +Active powerpc mpc85xx - freescale corenet_ds P3041DS_SPIFLASH P3041DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P3041DS_SRIO_PCIE_BOOT P3041DS:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P4080DS - - +Active powerpc mpc85xx - freescale corenet_ds P4080DS_SDCARD P4080DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P4080DS_SECURE_BOOT P4080DS:SECURE_BOOT - +Active powerpc mpc85xx - freescale corenet_ds P4080DS_SPIFLASH P4080DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P4080DS_SRIO_PCIE_BOOT P4080DS:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P5020DS - - +Active powerpc mpc85xx - freescale corenet_ds P5020DS_NAND P5020DS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P5020DS_SDCARD P5020DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P5020DS_SECURE_BOOT P5020DS:SECURE_BOOT - +Active powerpc mpc85xx - freescale corenet_ds P5020DS_SPIFLASH P5020DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P5020DS_SRIO_PCIE_BOOT P5020DS:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P5040DS - - +Active powerpc mpc85xx - freescale corenet_ds P5040DS_NAND P5040DS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P5040DS_SDCARD P5040DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P5040DS_SPIFLASH P5040DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale mpc8536ds MPC8536DS MPC8536DS - +Active powerpc mpc85xx - freescale mpc8536ds MPC8536DS_36BIT MPC8536DS:36BIT - +Active powerpc mpc85xx - freescale mpc8536ds MPC8536DS_NAND MPC8536DS:NAND - +Active powerpc mpc85xx - freescale mpc8536ds MPC8536DS_SDCARD MPC8536DS:SDCARD - +Active powerpc mpc85xx - freescale mpc8536ds MPC8536DS_SPIFLASH MPC8536DS:SPIFLASH - +Active powerpc mpc85xx - freescale mpc8540ads MPC8540ADS - Kumar Gala kumar.gala@freescale.com +Active powerpc mpc85xx - freescale mpc8541cds MPC8541CDS MPC8541CDS Kumar Gala kumar.gala@freescale.com +Active powerpc mpc85xx - freescale mpc8541cds MPC8541CDS_legacy MPC8541CDS:LEGACY Kumar Gala kumar.gala@freescale.com +Active powerpc mpc85xx - freescale mpc8544ds MPC8544DS - - +Active powerpc mpc85xx - freescale mpc8548cds MPC8548CDS MPC8548CDS - +Active powerpc mpc85xx - freescale mpc8548cds MPC8548CDS_36BIT MPC8548CDS:36BIT - +Active powerpc mpc85xx - freescale mpc8548cds MPC8548CDS_legacy MPC8548CDS:LEGACY - +Active powerpc mpc85xx - freescale mpc8555cds MPC8555CDS MPC8555CDS Kumar Gala kumar.gala@freescale.com +Active powerpc mpc85xx - freescale mpc8555cds MPC8555CDS_legacy MPC8555CDS:LEGACY Kumar Gala kumar.gala@freescale.com +Active powerpc mpc85xx - freescale mpc8560ads MPC8560ADS - Kumar Gala kumar.gala@freescale.com +Active powerpc mpc85xx - freescale mpc8568mds MPC8568MDS - - +Active powerpc mpc85xx - freescale mpc8569mds MPC8569MDS MPC8569MDS - +Active powerpc mpc85xx - freescale mpc8569mds MPC8569MDS_ATM MPC8569MDS:ATM - +Active powerpc mpc85xx - freescale mpc8569mds MPC8569MDS_NAND MPC8569MDS:NAND - +Active powerpc mpc85xx - freescale mpc8572ds MPC8572DS MPC8572DS - +Active powerpc mpc85xx - freescale mpc8572ds MPC8572DS_36BIT MPC8572DS:36BIT - +Active powerpc mpc85xx - freescale mpc8572ds MPC8572DS_NAND MPC8572DS:NAND - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_36BIT_NAND P1010RDB:P1010RDB,36BIT,NAND - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_36BIT_NAND_SECBOOT P1010RDB:P1010RDB,36BIT,NAND_SECBOOT,SECURE_BOOT - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_36BIT_NOR P1010RDB:P1010RDB,36BIT - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_36BIT_NOR_SECBOOT P1010RDB:P1010RDB,36BIT,SECURE_BOOT - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_36BIT_SDCARD P1010RDB:P1010RDB,36BIT,SDCARD - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_36BIT_SPIFLASH P1010RDB:P1010RDB,36BIT,SPIFLASH - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_36BIT_SPIFLASH_SECBOOT P1010RDB:P1010RDB,36BIT,SPIFLASH,SECURE_BOOT - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_NAND P1010RDB:P1010RDB,NAND - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_NAND_SECBOOT P1010RDB:P1010RDB,NAND_SECBOOT,SECURE_BOOT - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_NOR P1010RDB:P1010RDB - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_NOR_SECBOOT P1010RDB:P1010RDB,SECURE_BOOT - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_SDCARD P1010RDB:P1010RDB,SDCARD - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_SPIFLASH P1010RDB:P1010RDB,SPIFLASH - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_SPIFLASH_SECBOOT P1010RDB:P1010RDB,SPIFLASH,SECURE_BOOT - +Active powerpc mpc85xx - freescale p1022ds P1022DS - Timur Tabi timur@freescale.com +Active powerpc mpc85xx - freescale p1022ds P1022DS_36BIT P1022DS:36BIT Timur Tabi timur@freescale.com +Active powerpc mpc85xx - freescale p1022ds P1022DS_36BIT_NAND P1022DS:36BIT,NAND Timur Tabi timur@freescale.com +Active powerpc mpc85xx - freescale p1022ds P1022DS_36BIT_SDCARD P1022DS:36BIT,SDCARD Timur Tabi timur@freescale.com +Active powerpc mpc85xx - freescale p1022ds P1022DS_36BIT_SPIFLASH P1022DS:36BIT,SPIFLASH Timur Tabi timur@freescale.com +Active powerpc mpc85xx - freescale p1022ds P1022DS_NAND P1022DS:NAND Timur Tabi timur@freescale.com +Active powerpc mpc85xx - freescale p1022ds P1022DS_SDCARD P1022DS:SDCARD Timur Tabi timur@freescale.com +Active powerpc mpc85xx - freescale p1022ds P1022DS_SPIFLASH P1022DS:SPIFLASH Timur Tabi timur@freescale.com +Active powerpc mpc85xx - freescale p1023rdb P1023RDB P1023RDB - +Active powerpc mpc85xx - freescale p1023rds P1023RDS P1023RDS Roy Zang tie-fei.zang@freescale.com +Active powerpc mpc85xx - freescale p1023rds P1023RDS_NAND P1023RDS:NAND Roy Zang tie-fei.zang@freescale.com +Active powerpc mpc85xx - freescale p1_p2_rdb P1011RDB P1_P2_RDB:P1011RDB - +Active powerpc mpc85xx - freescale p1_p2_rdb P1011RDB_36BIT P1_P2_RDB:P1011RDB,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb P1011RDB_36BIT_SDCARD P1_P2_RDB:P1011RDB,36BIT,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb P1011RDB_36BIT_SPIFLASH P1_P2_RDB:P1011RDB,36BIT,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb P1011RDB_NAND P1_P2_RDB:P1011RDB,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb P1011RDB_SDCARD P1_P2_RDB:P1011RDB,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb P1011RDB_SPIFLASH P1_P2_RDB:P1011RDB,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb P1020RDB P1_P2_RDB:P1020RDB - +Active powerpc mpc85xx - freescale p1_p2_rdb P1020RDB_36BIT P1_P2_RDB:P1020RDB,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb P1020RDB_36BIT_SDCARD P1_P2_RDB:P1020RDB,36BIT,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb P1020RDB_36BIT_SPIFLASH P1_P2_RDB:P1020RDB,36BIT,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb P1020RDB_NAND P1_P2_RDB:P1020RDB,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb P1020RDB_SDCARD P1_P2_RDB:P1020RDB,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb P1020RDB_SPIFLASH P1_P2_RDB:P1020RDB,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb P2010RDB P1_P2_RDB:P2010RDB - +Active powerpc mpc85xx - freescale p1_p2_rdb P2010RDB_36BIT P1_P2_RDB:P2010RDB,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb P2010RDB_36BIT_SDCARD P1_P2_RDB:P2010RDB,36BIT,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb P2010RDB_36BIT_SPIFLASH P1_P2_RDB:P2010RDB,36BIT,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb P2010RDB_NAND P1_P2_RDB:P2010RDB,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb P2010RDB_SDCARD P1_P2_RDB:P2010RDB,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb P2010RDB_SPIFLASH P1_P2_RDB:P2010RDB,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb P2020RDB P1_P2_RDB:P2020RDB Poonam Aggrwal poonam.aggrwal@freescale.com +Active powerpc mpc85xx - freescale p1_p2_rdb P2020RDB_36BIT P1_P2_RDB:P2020RDB,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb P2020RDB_36BIT_SDCARD P1_P2_RDB:P2020RDB,36BIT,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb P2020RDB_36BIT_SPIFLASH P1_P2_RDB:P2020RDB,36BIT,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb P2020RDB_NAND P1_P2_RDB:P2020RDB,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb P2020RDB_SDCARD P1_P2_RDB:P2020RDB,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb P2020RDB_SPIFLASH P1_P2_RDB:P2020RDB,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020MBG-PC p1_p2_rdb_pc:P1020MBG - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020MBG-PC_36BIT p1_p2_rdb_pc:P1020MBG,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020MBG-PC_36BIT_SDCARD p1_p2_rdb_pc:P1020MBG,SDCARD,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020MBG-PC_SDCARD p1_p2_rdb_pc:P1020MBG,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020RDB-PC p1_p2_rdb_pc:P1020RDB - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020RDB-PC_36BIT p1_p2_rdb_pc:P1020RDB,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020RDB-PC_36BIT_NAND p1_p2_rdb_pc:P1020RDB,36BIT,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020RDB-PC_36BIT_SDCARD p1_p2_rdb_pc:P1020RDB,36BIT,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020RDB-PC_36BIT_SPIFLASH p1_p2_rdb_pc:P1020RDB,36BIT,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020RDB-PC_NAND p1_p2_rdb_pc:P1020RDB,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020RDB-PC_SDCARD p1_p2_rdb_pc:P1020RDB,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020RDB-PC_SPIFLASH p1_p2_rdb_pc:P1020RDB,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020UTM-PC p1_p2_rdb_pc:P1020UTM - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020UTM-PC_36BIT p1_p2_rdb_pc:P1020UTM,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020UTM-PC_36BIT_SDCARD p1_p2_rdb_pc:P1020UTM,36BIT,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020UTM-PC_SDCARD p1_p2_rdb_pc:P1020UTM,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1021RDB-PC p1_p2_rdb_pc:P1021RDB - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1021RDB-PC_36BIT p1_p2_rdb_pc:P1021RDB,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1021RDB-PC_36BIT_NAND p1_p2_rdb_pc:P1021RDB,36BIT,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1021RDB-PC_36BIT_SDCARD p1_p2_rdb_pc:P1021RDB,36BIT,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1021RDB-PC_36BIT_SPIFLASH p1_p2_rdb_pc:P1021RDB,36BIT,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1021RDB-PC_NAND p1_p2_rdb_pc:P1021RDB,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1021RDB-PC_SDCARD p1_p2_rdb_pc:P1021RDB,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1021RDB-PC_SPIFLASH p1_p2_rdb_pc:P1021RDB,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1024RDB p1_p2_rdb_pc:P1024RDB - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1024RDB_36BIT p1_p2_rdb_pc:P1024RDB,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1024RDB_NAND p1_p2_rdb_pc:P1024RDB,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1024RDB_SDCARD p1_p2_rdb_pc:P1024RDB,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1024RDB_SPIFLASH p1_p2_rdb_pc:P1024RDB,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1025RDB p1_p2_rdb_pc:P1025RDB - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1025RDB_36BIT p1_p2_rdb_pc:P1025RDB,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1025RDB_NAND p1_p2_rdb_pc:P1025RDB,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1025RDB_SDCARD p1_p2_rdb_pc:P1025RDB,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1025RDB_SPIFLASH p1_p2_rdb_pc:P1025RDB,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P2020RDB-PC p1_p2_rdb_pc:P2020RDB - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P2020RDB-PC_36BIT p1_p2_rdb_pc:P2020RDB,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P2020RDB-PC_36BIT_NAND p1_p2_rdb_pc:P2020RDB,36BIT,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P2020RDB-PC_36BIT_SDCARD p1_p2_rdb_pc:P2020RDB,36BIT,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P2020RDB-PC_36BIT_SPIFLASH p1_p2_rdb_pc:P2020RDB,36BIT,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P2020RDB-PC_NAND p1_p2_rdb_pc:P2020RDB,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P2020RDB-PC_SDCARD p1_p2_rdb_pc:P2020RDB,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P2020RDB-PC_SPIFLASH p1_p2_rdb_pc:P2020RDB,SPIFLASH - +Active powerpc mpc85xx - freescale p2020come P2020COME_SDCARD P2020COME:SDCARD Ira W. Snyder iws@ovro.caltech.edu +Active powerpc mpc85xx - freescale p2020come P2020COME_SPIFLASH P2020COME:SPIFLASH Ira W. Snyder iws@ovro.caltech.edu +Active powerpc mpc85xx - freescale p2020ds P2020DS - - +Active powerpc mpc85xx - freescale p2020ds P2020DS_36BIT P2020DS:36BIT - +Active powerpc mpc85xx - freescale p2020ds P2020DS_DDR2 P2020DS:DDR2 - +Active powerpc mpc85xx - freescale p2020ds P2020DS_SDCARD P2020DS:SDCARD - +Active powerpc mpc85xx - freescale p2020ds P2020DS_SPIFLASH P2020DS:SPIFLASH - +Active powerpc mpc85xx - freescale p2041rdb P2041RDB - - +Active powerpc mpc85xx - freescale p2041rdb P2041RDB_NAND P2041RDB:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale p2041rdb P2041RDB_SDCARD P2041RDB:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale p2041rdb P2041RDB_SECURE_BOOT P2041RDB:SECURE_BOOT - +Active powerpc mpc85xx - freescale p2041rdb P2041RDB_SPIFLASH P2041RDB:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale p2041rdb P2041RDB_SRIO_PCIE_BOOT P2041RDB:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale t4qds T4160QDS T4240QDS:PPC_T4160 - +Active powerpc mpc85xx - freescale t4qds T4160QDS_SDCARD T4240QDS:PPC_T4160,RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale t4qds T4160QDS_SPIFLASH T4240QDS:PPC_T4160,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale t4qds T4240QDS T4240QDS:PPC_T4240 - +Active powerpc mpc85xx - freescale t4qds T4240QDS_SDCARD T4240QDS:PPC_T4240,RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale t4qds T4240QDS_SPIFLASH T4240QDS:PPC_T4240,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale t4qds T4240QDS_SRIO_PCIE_BOOT T4240QDS:PPC_T4240,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - gdsys p1022 controlcenterd_36BIT_SDCARD controlcenterd:36BIT,SDCARD Dirk Eibach eibach@gdsys.de +Active powerpc mpc85xx - gdsys p1022 controlcenterd_36BIT_SDCARD_DEVELOP controlcenterd:36BIT,SDCARD,DEVELOP Dirk Eibach eibach@gdsys.de +Active powerpc mpc85xx - gdsys p1022 controlcenterd_TRAILBLAZER controlcenterd:TRAILBLAZER,SPIFLASH Dirk Eibach eibach@gdsys.de +Active powerpc mpc85xx - gdsys p1022 controlcenterd_TRAILBLAZER_DEVELOP controlcenterd:TRAILBLAZER,SPIFLASH,DEVELOP Dirk Eibach eibach@gdsys.de +Active powerpc mpc85xx - stx stxgp3 stxgp3 - Dan Malek dan@embeddedalley.com +Active powerpc mpc85xx - stx stxssa stxssa stxssa Dan Malek dan@embeddedalley.com +Active powerpc mpc85xx - stx stxssa stxssa_4M stxssa:STXSSA_4M Dan Malek dan@embeddedalley.com +Active powerpc mpc85xx - xes - xpedite520x - - +Active powerpc mpc85xx - xes - xpedite537x - - +Active powerpc mpc85xx - xes - xpedite550x - - +Active powerpc mpc86xx - - - sbc8641d - Paul Gortmaker paul.gortmaker@windriver.com +Active powerpc mpc86xx - freescale mpc8610hpcd MPC8610HPCD - - +Active powerpc mpc86xx - freescale mpc8641hpcn MPC8641HPCN MPC8641HPCN Kumar Gala kumar.gala@freescale.com +Active powerpc mpc86xx - freescale mpc8641hpcn MPC8641HPCN_36BIT MPC8641HPCN:PHYS_64BIT Kumar Gala kumar.gala@freescale.com +Active powerpc mpc86xx - xes - xpedite517x - - +Active powerpc mpc8xx - - - hermes - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - - lwmon - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - - quantum - - +Active powerpc mpc8xx - - - RRvision - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - - spc1920 - - +Active powerpc mpc8xx - - - svm_sc8xx - John Zhan zhanz@sinovee.com +Active powerpc mpc8xx - - - v37 - - +Active powerpc mpc8xx - - adder Adder - Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8xx - - adder Adder87x Adder Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8xx - - adder AdderII Adder:MPC852T Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8xx - - adder AdderUSB Adder Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8xx - - cogent cogent_mpc8xx - Murray Jensen Murray.Jensen@csiro.au +Active powerpc mpc8xx - - esteem192e ESTEEM192E - Conn Clark clark@esteem.com +Active powerpc mpc8xx - - fads MPC86xADS - - +Active powerpc mpc8xx - - fads MPC885ADS - - +Active powerpc mpc8xx - - flagadm FLAGADM - Kári Davíðsson kd@flaga.is +Active powerpc mpc8xx - - gen860t GEN860T - Keith Outwater Keith_Outwater@mvis.com +Active powerpc mpc8xx - - gen860t GEN860T_SC GEN860T:SC Keith Outwater Keith_Outwater@mvis.com +Active powerpc mpc8xx - - icu862 ICU862 - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - icu862 ICU862_100MHz ICU862:100MHz Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - ip860 IP860 - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - ivm IVML24 IVML24:IVML24_16M Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - ivm IVML24_128 IVML24:IVML24_32M Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - ivm IVML24_256 IVML24:IVML24_64M Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - ivm IVMS8 IVMS8:IVMS8_16M Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - ivm IVMS8_128 IVMS8:IVMS8_32M Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - ivm IVMS8_256 IVMS8:IVMS8_64M Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - netphone NETPHONE NETPHONE:NETPHONE_VERSION=1 - +Active powerpc mpc8xx - - netphone NETPHONE_V2 NETPHONE:NETPHONE_VERSION=2 - +Active powerpc mpc8xx - - netta NETTA NETTA - +Active powerpc mpc8xx - - netta NETTA_6412 NETTA:NETTA_6412=1 - +Active powerpc mpc8xx - - netta NETTA_6412_SWAPHOOK NETTA:NETTA_6412=1,NETTA_SWAPHOOK=1 - +Active powerpc mpc8xx - - netta NETTA_ISDN NETTA:NETTA_ISDN=1 - +Active powerpc mpc8xx - - netta NETTA_ISDN_6412 NETTA:NETTA_ISDN=1,NETTA_6412=1 - +Active powerpc mpc8xx - - netta NETTA_ISDN_6412_SWAPHOOK NETTA:NETTA_ISDN=1,NETTA_6412=1,NETTA_SWAPHOOK=1 - +Active powerpc mpc8xx - - netta NETTA_ISDN_SWAPHOOK NETTA:NETTA_ISDN=1,NETTA_SWAPHOOK=1 - +Active powerpc mpc8xx - - netta NETTA_SWAPHOOK NETTA:NETTA_SWAPHOOK=1 - +Active powerpc mpc8xx - - netta2 NETTA2 NETTA2:NETTA2_VERSION=1 - +Active powerpc mpc8xx - - netta2 NETTA2_V2 NETTA2:NETTA2_VERSION=2 - +Active powerpc mpc8xx - - netvia NETVIA NETVIA:NETVIA_VERSION=1 Pantelis Antoniou panto@intracom.gr +Active powerpc mpc8xx - - netvia NETVIA_V2 NETVIA:NETVIA_VERSION=2 Pantelis Antoniou panto@intracom.gr +Active powerpc mpc8xx - - r360mpi R360MPI - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - rbc823 RBC823 - - +Active powerpc mpc8xx - - RPXlite_dw RPXlite_DW RPXlite_DW - +Active powerpc mpc8xx - - RPXlite_dw RPXlite_DW_64 RPXlite_DW:RPXlite_64MHz - +Active powerpc mpc8xx - - RPXlite_dw RPXlite_DW_64_LCD RPXlite_DW:RPXlite_64MHz,LCD,NEC_NL6448BC20 - +Active powerpc mpc8xx - - RPXlite_dw RPXlite_DW_LCD RPXlite_DW:LCD,NEC_NL6448BC20 - +Active powerpc mpc8xx - - RPXlite_dw RPXlite_DW_NVRAM RPXlite_DW:ENV_IS_IN_NVRAM - +Active powerpc mpc8xx - - RPXlite_dw RPXlite_DW_NVRAM_64 RPXlite_DW:RPXlite_64MHz,ENV_IS_IN_NVRAM - +Active powerpc mpc8xx - - RPXlite_dw RPXlite_DW_NVRAM_64_LCD RPXlite_DW:RPXlite_64MHz,LCD,NEC_NL6448BC20,ENV_IS_IN_NVRAM - +Active powerpc mpc8xx - - RPXlite_dw RPXlite_DW_NVRAM_LCD RPXlite_DW:LCD,NEC_NL6448BC20,ENV_IS_IN_NVRAM - +Active powerpc mpc8xx - - RRvision RRvision_LCD RRvision:LCD,SHARP_LQ104V7DS01 Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - sixnet SXNI855T - Dave Ellis DGE@sixnetio.com +Active powerpc mpc8xx - - spd8xx SPD823TS - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - eltec mhpc MHPC - Frank Gottschling fgottschling@eltec.de +Active powerpc mpc8xx - emk top860 TOP860 - Reinhard Meyer reinhard.meyer@emk-elektronik.de +Active powerpc mpc8xx - kup kup4k KUP4K - Klaus Heydeck heydeck@kieback-peter.de +Active powerpc mpc8xx - kup kup4x KUP4X - Klaus Heydeck heydeck@kieback-peter.de +Active powerpc mpc8xx - LEOX elpt860 ELPT860 - The LEOX team team@leox.org +Active powerpc mpc8xx - manroland - uc100 - Stefan Roese sr@denx.de +Active powerpc mpc8xx - snmc qs850 QS823 - - +Active powerpc mpc8xx - snmc qs850 QS850 - - +Active powerpc mpc8xx - snmc qs860t QS860T - - +Active powerpc mpc8xx - stx stxxtc stxxtc - Dan Malek dan@embeddedalley.com +Active powerpc mpc8xx - tqc tqm8xx FPS850L - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - tqc tqm8xx FPS860L - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - tqc tqm8xx NSCU - - +Active powerpc mpc8xx - tqc tqm8xx SM850 - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - tqc tqm8xx TK885D - - +Active powerpc mpc8xx - tqc tqm8xx TQM823L - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - tqc tqm8xx TQM823L_LCD TQM823L:LCD,NEC_NL6448BC20 Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - tqc tqm8xx TQM823M - - +Active powerpc mpc8xx - tqc tqm8xx TQM850L - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - tqc tqm8xx TQM850M - - +Active powerpc mpc8xx - tqc tqm8xx TQM855L - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - tqc tqm8xx TQM855M - - +Active powerpc mpc8xx - tqc tqm8xx TQM860L - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - tqc tqm8xx TQM860M - - +Active powerpc mpc8xx - tqc tqm8xx TQM862L - - +Active powerpc mpc8xx - tqc tqm8xx TQM862M - - +Active powerpc mpc8xx - tqc tqm8xx TQM866M - - +Active powerpc mpc8xx - tqc tqm8xx TQM885D - - +Active powerpc mpc8xx - tqc tqm8xx TTTech TQM823L:LCD,SHARP_LQ104V7DS01 Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - tqc tqm8xx virtlab2 - - +Active powerpc mpc8xx - tqc tqm8xx wtk TQM823L:LCD,SHARP_LQ065T9DR51U Wolfgang Denk wd@denx.de +Active powerpc ppc4xx - - - csb272 - Tolunay Orkun torkun@nextio.com +Active powerpc ppc4xx - - - csb472 - Tolunay Orkun torkun@nextio.com +Active powerpc ppc4xx - - - korat - Larry Johnson lrj@acm.org +Active powerpc ppc4xx - - - lwmon5 - Stefan Roese sr@denx.de +Active powerpc ppc4xx - - - pcs440ep - Stefan Roese sr@denx.de +Active powerpc ppc4xx - - - quad100hd - Gary Jennejohn garyj@denx.de +Active powerpc ppc4xx - - - sbc405 - - +Active powerpc ppc4xx - - - sc3 - Heiko Schocher hs@denx.de +Active powerpc ppc4xx - - - t3corp - Stefan Roese sr@denx.de +Active powerpc ppc4xx - - - zeus - Stefan Roese sr@denx.de +Active powerpc ppc4xx - - g2000 G2000 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - - jse JSE - Stephen Williams steve@icarus.com +Active powerpc ppc4xx - - korat korat_perm korat:KORAT_PERMANENT Larry Johnson lrj@acm.org +Active powerpc ppc4xx - - lwmon5 lcd4_lwmon5 lwmon5:LCD4_LWMON5 Stefan Roese sr@denx.de +Active powerpc ppc4xx - - w7o W7OLMC - Erik Theisen etheisen@mindspring.com +Active powerpc ppc4xx - - w7o W7OLMG - Erik Theisen etheisen@mindspring.com +Active powerpc ppc4xx - amcc - acadia - Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc - bamboo - Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc - bluestone - Tirumala Marri tmarri@apm.com +Active powerpc ppc4xx - amcc - bubinga - - +Active powerpc ppc4xx - amcc - ebony - Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc - katmai - Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc - luan - John Otken jotken@softadvances.com +Active powerpc ppc4xx - amcc - makalu - Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc - ocotea - Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc - redwood - Feng Kan fkan@amcc.com +Active powerpc ppc4xx - amcc - taihu - John Otken jotken@softadvances.com +Active powerpc ppc4xx - amcc - taishan - Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc - yucca - - +Active powerpc ppc4xx - amcc acadia acadia_nand acadia:NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc bamboo bamboo_nand bamboo:NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc canyonlands arches canyonlands:ARCHES Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc canyonlands canyonlands canyonlands:CANYONLANDS Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc canyonlands canyonlands_nand canyonlands:CANYONLANDS,NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc canyonlands glacier canyonlands:GLACIER Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc canyonlands glacier_nand canyonlands:GLACIER,NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc kilauea haleakala kilauea:HALEAKALA Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc kilauea haleakala_nand kilauea:NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc kilauea kilauea kilauea:KILAUEA Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc kilauea kilauea_nand kilauea:NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc sequoia rainier sequoia:RAINIER Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc sequoia rainier_nand sequoia:RAINIER,NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc sequoia rainier_ramboot sequoia:RAINIER,SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/sequoia/u-boot-ram.lds Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc sequoia sequoia sequoia:SEQUOIA Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc sequoia sequoia_nand sequoia:SEQUOIA,NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc sequoia sequoia_ramboot sequoia:SEQUOIA,SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/sequoia/u-boot-ram.lds Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc walnut sycamore walnut Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc walnut walnut - Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc yosemite yellowstone yosemite:YELLOWSTONE Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc yosemite yosemite yosemite:YOSEMITE Stefan Roese sr@denx.de +Active powerpc ppc4xx - avnet fx12mm fx12mm fx12mm:SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,INIT_TLB=board/xilinx/ppc405-generic/init.o Georg Schardt schardt@team-ctech.de +Active powerpc ppc4xx - avnet fx12mm fx12mm_flash fx12mm:SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC,INIT_TLB=board/xilinx/ppc405-generic/init.o Georg Schardt schardt@team-ctech.de +Active powerpc ppc4xx - avnet v5fx30teval v5fx30teval v5fx30teval:SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,BOOT_FROM_XMD=1,INIT_TLB=board/xilinx/ppc440-generic/init.o Ricardo Ribalda ricardo.ribalda@uam.es +Active powerpc ppc4xx - avnet v5fx30teval v5fx30teval_flash v5fx30teval:SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC,INIT_TLB=board/xilinx/ppc440-generic/init.o Ricardo Ribalda ricardo.ribalda@uam.es +Active powerpc ppc4xx - cray L1 CRAYL1 - David Updegraff dave@cray.com +Active powerpc ppc4xx - dave PPChameleonEVB CATcenter CATcenter:PPCHAMELEON_MODULE_MODEL=1 Andrea "llandre" Marson andrea.marson@dave-tech.it +Active powerpc ppc4xx - dave PPChameleonEVB CATcenter_25 CATcenter:PPCHAMELEON_MODULE_MODEL=1,PPCHAMELEON_CLK_25 Andrea "llandre" Marson andrea.marson@dave-tech.it +Active powerpc ppc4xx - dave PPChameleonEVB CATcenter_33 CATcenter:PPCHAMELEON_MODULE_MODEL=1,PPCHAMELEON_CLK_33 Andrea "llandre" Marson andrea.marson@dave-tech.it +Active powerpc ppc4xx - dave PPChameleonEVB PPChameleonEVB - Andrea "llandre" Marson andrea.marson@dave-tech.it +Active powerpc ppc4xx - dave PPChameleonEVB PPChameleonEVB_BA_25 PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=0,PPCHAMELEON_CLK_25 Andrea "llandre" Marson andrea.marson@dave-tech.it +Active powerpc ppc4xx - dave PPChameleonEVB PPChameleonEVB_BA_33 PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=0,PPCHAMELEON_CLK_33 Andrea "llandre" Marson andrea.marson@dave-tech.it +Active powerpc ppc4xx - dave PPChameleonEVB PPChameleonEVB_HI_25 PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=2,PPCHAMELEON_CLK_25 Andrea "llandre" Marson andrea.marson@dave-tech.it +Active powerpc ppc4xx - dave PPChameleonEVB PPChameleonEVB_HI_33 PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=2,PPCHAMELEON_CLK_33 Andrea "llandre" Marson andrea.marson@dave-tech.it +Active powerpc ppc4xx - dave PPChameleonEVB PPChameleonEVB_ME_25 PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=1,PPCHAMELEON_CLK_25 Andrea "llandre" Marson andrea.marson@dave-tech.it +Active powerpc ppc4xx - dave PPChameleonEVB PPChameleonEVB_ME_33 PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=1,PPCHAMELEON_CLK_33 Andrea "llandre" Marson andrea.marson@dave-tech.it +Active powerpc ppc4xx - esd apc405 APC405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd ar405 AR405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd ash405 ASH405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd canbt CANBT - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd cms700 CMS700 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd cpci2dp CPCI2DP - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd cpci405 CPCI405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd cpci405 CPCI4052 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd cpci405 CPCI405AB - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd cpci405 CPCI405DT - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd cpciiser4 CPCIISER4 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd dp405 DP405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd du405 DU405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd du440 DU440 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd hh405 HH405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd hub405 HUB405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd ocrtc OCRTC - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd pci405 PCI405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd plu405 PLU405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd pmc405 PMC405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd pmc405de PMC405DE - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd pmc440 PMC440 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd voh405 VOH405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd vom405 VOM405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd wuh405 WUH405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - gdsys - dlvision - Dirk Eibach eibach@gdsys.de +Active powerpc ppc4xx - gdsys - gdppc440etx - Dirk Eibach eibach@gdsys.de +Active powerpc ppc4xx - gdsys 405ep dlvision-10g - Dirk Eibach eibach@gdsys.de +Active powerpc ppc4xx - gdsys 405ep io - Dirk Eibach eibach@gdsys.de +Active powerpc ppc4xx - gdsys 405ep iocon - Dirk Eibach eibach@gdsys.de +Active powerpc ppc4xx - gdsys 405ep neo - Dirk Eibach eibach@gdsys.de +Active powerpc ppc4xx - gdsys 405ex io64 - Dirk Eibach eibach@gdsys.de +Active powerpc ppc4xx - gdsys intip devconcenter intip:DEVCONCENTER Dirk Eibach eibach@gdsys.de +Active powerpc ppc4xx - gdsys intip intip intip:INTIB Dirk Eibach eibach@gdsys.de +Active powerpc ppc4xx - mosaixtech - icon - Stefan Roese sr@denx.de +Active powerpc ppc4xx - mpl mip405 MIP405 - Denis Peter d.peter@mpl.ch +Active powerpc ppc4xx - mpl mip405 MIP405T MIP405:MIP405T Denis Peter d.peter@mpl.ch +Active powerpc ppc4xx - mpl pip405 PIP405 - Denis Peter d.peter@mpl.ch +Active powerpc ppc4xx - prodrive - alpr - Stefan Roese sr@denx.de +Active powerpc ppc4xx - prodrive - p3p440 - Stefan Roese sr@denx.de +Active powerpc ppc4xx - sandburst karef KAREF - Travis Sawyer (travis.sawyer@sandburst.com> +Active powerpc ppc4xx - sandburst metrobox METROBOX - Travis Sawyer (travis.sawyer@sandburst.com> +Active powerpc ppc4xx - xes - xpedite1000 - Peter Tyser ptyser@xes-inc.com +Active powerpc ppc4xx - xilinx ml507 ml507 ml507:SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,BOOT_FROM_XMD=1,INIT_TLB=board/xilinx/ppc440-generic/init.o Ricardo Ribalda ricardo.ribalda@uam.es +Active powerpc ppc4xx - xilinx ml507 ml507_flash ml507:SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC,INIT_TLB=board/xilinx/ppc440-generic/init.o Ricardo Ribalda ricardo.ribalda@uam.es +Active powerpc ppc4xx - xilinx ppc405-generic xilinx-ppc405-generic xilinx-ppc405-generic:SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000 Ricardo Ribalda ricardo.ribalda@uam.es +Active powerpc ppc4xx - xilinx ppc405-generic xilinx-ppc405-generic_flash xilinx-ppc405-generic:SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC Ricardo Ribalda ricardo.ribalda@uam.es +Active powerpc ppc4xx - xilinx ppc440-generic xilinx-ppc440-generic xilinx-ppc440-generic:SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,BOOT_FROM_XMD=1 Ricardo Ribalda ricardo.ribalda@uam.es +Active powerpc ppc4xx - xilinx ppc440-generic xilinx-ppc440-generic_flash xilinx-ppc440-generic:SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC Ricardo Ribalda ricardo.ribalda@uam.es +Active sandbox sandbox - sandbox sandbox sandbox - Simon Glass sjg@chromium.org +Active sh sh2 - renesas rsk7203 rsk7203 - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org +Active sh sh2 - renesas rsk7264 rsk7264 - Phil Edworthy phil.edworthy@renesas.com +Active sh sh2 - renesas rsk7269 rsk7269 - - +Active sh sh3 - - mpr2 mpr2 - Mark Jonas mark.jonas@de.bosch.com +Active sh sh3 - - ms7720se ms7720se - Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com +Active sh sh3 - - shmin shmin - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org +Active sh sh4 - - espt espt - - +Active sh sh4 - - ms7722se ms7722se - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org +Active sh sh4 - - ms7750se ms7750se - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org +Active sh sh4 - alphaproject ap_sh4a_4a ap_sh4a_4a - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org +Active sh sh4 - renesas ap325rxa ap325rxa - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org +Active sh sh4 - renesas ecovec ecovec - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org +Active sh sh4 - renesas MigoR MigoR - - +Active sh sh4 - renesas r0p7734 r0p7734 - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org +Active sh sh4 - renesas r2dplus r2dplus - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org +Active sh sh4 - renesas r7780mp r7780mp - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org +Active sh sh4 - renesas sh7752evb sh7752evb - - +Active sh sh4 - renesas sh7757lcr sh7757lcr - - +Active sh sh4 - renesas sh7763rdp sh7763rdp - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org +Active sh sh4 - renesas sh7785lcr sh7785lcr - - +Active sh sh4 - renesas sh7785lcr sh7785lcr_32bit sh7785lcr:SH_32BIT=1 - +Active sparc leon2 - gaisler - grsim_leon2 - - +Active sparc leon3 - gaisler - gr_cpci_ax2000 - - +Active sparc leon3 - gaisler - gr_ep2s60 - - +Active sparc leon3 - gaisler - gr_xc3s_1500 - - +Active sparc leon3 - gaisler - grsim - - +Active x86 x86 coreboot chromebook-x86 coreboot coreboot-x86 coreboot:SYS_TEXT_BASE=0x01110000 - +Orphan arm arm1136 mx31 - imx31_phycore imx31_phycore_eet imx31_phycore:IMX31_PHYCORE_EET Kshitij Gupta kshitij@ti.com +Orphan arm arm1136 mx31 freescale - mx31ads - Kshitij Gupta kshitij@ti.com +Orphan arm arm925t - ti - omap1510inn - Kshitij Gupta kshitij@ti.com +Orphan arm arm926ejs versatile armltd versatile versatileab versatile:ARCH_VERSATILE_AB - +Orphan arm arm926ejs versatile armltd versatile versatilepb versatile:ARCH_VERSATILE_PB - +Orphan arm arm926ejs versatile armltd versatile versatileqemu versatile:ARCH_VERSATILE_QEMU,ARCH_VERSATILE_PB - +Orphan arm pxa - - - lubbock - Kshitij Gupta kshitij@ti.com +Orphan mips mips32 au1x00 - dbau1x00 dbau1000 dbau1x00:DBAU1000 Thomas Lange thomas@corelatus.se +Orphan mips mips32 au1x00 - dbau1x00 dbau1100 dbau1x00:DBAU1100 Thomas Lange thomas@corelatus.se +Orphan mips mips32 au1x00 - dbau1x00 dbau1500 dbau1x00:DBAU1500 Thomas Lange thomas@corelatus.se +Orphan mips mips32 au1x00 - dbau1x00 dbau1550 dbau1x00:DBAU1550 Thomas Lange thomas@corelatus.se +Orphan mips mips32 au1x00 - dbau1x00 dbau1550_el dbau1x00:DBAU1550,SYS_LITTLE_ENDIAN Thomas Lange thomas@corelatus.se +Orphan powerpc 74xx_7xx - - evb64260 EVB64260 EVB64260 - +Orphan powerpc 74xx_7xx - - evb64260 EVB64260_750CX EVB64260 Eran Man eran@nbase.co.il:- +Orphan powerpc mpc824x - - mousse MOUSSE - - +Orphan powerpc mpc8260 - - - rsdproto - - +Orphan powerpc mpc8260 - - rpxsuper RPXsuper - - +Orphan powerpc mpc8xx - - - RPXClassic - - +Orphan powerpc mpc8xx - - - RPXlite - - +Orphan powerpc mpc8xx - - fads ADS860 - - +Orphan powerpc mpc8xx - - fads FADS823 - - +Orphan powerpc mpc8xx - - fads FADS850SAR - - +Orphan powerpc mpc8xx - - fads FADS860T - - +Orphan powerpc mpc8xx - - genietv GENIETV - - +Orphan powerpc mpc8xx - - mbx8xx MBX - - +Orphan powerpc mpc8xx - - mbx8xx MBX860T - - +Orphan powerpc mpc8xx - - nx823 NX823 - - diff --git a/mkconfig b/mkconfig index 816ae3d..1d06c8e 100755 --- a/mkconfig +++ b/mkconfig @@ -23,10 +23,11 @@ options=""
if [ ( $# -eq 2 ) -a ( "$1" = "-A" ) ] ; then # Automatic mode - line=`egrep -i "^[[:space:]]*${2}[[:space:]]" boards.cfg` || { + line=`awk '($0 !~ /^#/ && $7 ~ /^'"$2"'$/) { print $1, $2, $3, $4, $5, $6, $7, $8 }' boards.cfg` + if [ -z "$line" ] ; then echo "make: *** No rule to make target `$2_config'. Stop." >&2 exit 1 - } + fi
set ${line} # add default board name if needed @@ -37,44 +38,44 @@ while [ $# -gt 0 ] ; do case "$1" in --) shift ; break ;; -a) shift ; APPEND=yes ;; - -n) shift ; BOARD_NAME="${1%_config}" ; shift ;; + -n) shift ; BOARD_NAME="${7%_config}" ; shift ;; -t) shift ; TARGETS="`echo $1 | sed 's:_: :g'` ${TARGETS}" ; shift ;; *) break ;; esac done
-[ $# -lt 4 ] && exit 1 -[ $# -gt 7 ] && exit 1 +[ $# -lt 7 ] && exit 1 +[ $# -gt 8 ] && exit 1
# Strip all options and/or _config suffixes -CONFIG_NAME="${1%_config}" +CONFIG_NAME="${7%_config}"
-[ "${BOARD_NAME}" ] || BOARD_NAME="${1%_config}" +[ "${BOARD_NAME}" ] || BOARD_NAME="${7%_config}"
arch="$2" cpu=`echo $3 | awk 'BEGIN {FS = ":"} ; {print $1}'` spl_cpu=`echo $3 | awk 'BEGIN {FS = ":"} ; {print $2}'` -if [ "$4" = "-" ] ; then +if [ "$6" = "-" ] ; then board=${BOARD_NAME} else - board="$4" + board="$6" fi -[ $# -gt 4 ] && [ "$5" != "-" ] && vendor="$5" -[ $# -gt 5 ] && [ "$6" != "-" ] && soc="$6" -[ $# -gt 6 ] && [ "$7" != "-" ] && { +[ "$5" != "-" ] && vendor="$5" +[ "$4" != "-" ] && soc="$4" +[ $# -gt 7 ] && [ "$8" != "-" ] && { # check if we have a board config name in the options field # the options field mave have a board config name and a list # of options, both separated by a colon (':'); the options are # separated by commas (','). # # Check for board name - tmp="${7%:*}" + tmp="${8%:*}" if [ "$tmp" ] ; then CONFIG_NAME="$tmp" fi # Check if we only have a colon... - if [ "${tmp}" != "$7" ] ; then - options=${7#*:} + if [ "${tmp}" != "$8" ] ; then + options=${8#*:} TARGETS="`echo ${options} | sed 's:,: :g'` ${TARGETS}" fi } diff --git a/tools/buildman/board.py b/tools/buildman/board.py index cc7b5d0..a388896 100644 --- a/tools/buildman/board.py +++ b/tools/buildman/board.py @@ -63,7 +63,7 @@ class Boards: for upto in range(len(fields)): if fields[upto] == '-': fields[upto] = '' - while len(fields) < 7: + while len(fields) < 9: fields.append('')
board = Board(*fields) diff --git a/tools/reformat.py b/tools/reformat.py new file mode 100755 index 0000000..ff6633f --- /dev/null +++ b/tools/reformat.py @@ -0,0 +1,132 @@ +#! /usr/bin/python +######################################################################## +# +# reorder and reformat a file in columns +# +# this utility takes lines from its standard input and reproduces them, +# partially reordered and reformatted, on its standard output. +# +# It has the same effect as a 'sort | column -t', with the exception +# that empty lines, as well as lines which start with a '#' sign, are +# not affected, i.e. they keep their position and formatting, and act +# as separators, i.e. the parts before and after them are each sorted +# separately (but overall field widths are computed across the whole +# input). +# +# Options: +# -i: +# --ignore-case: +# Do not consider case when sorting. +# -d: +# --default: +# What to chage empty fields to. +# -s <N>: +# --split=<N>: +# Treat only the first N whitespace sequences as separators. +# line content after the Nth separator will count as only one +# field even if it contains whitespace. +# Example : '-s 2' causes input 'a b c d e' to be split into +# three fields, 'a', 'b', and 'c d e'. +# +# boards.cfg requires -ids 6. +# +######################################################################## + +import sys, getopt, locale + +# ensure we sort using the C locale. + +locale.setlocale(locale.LC_ALL, 'C') + +# check options + +maxsplit = 0 +ignore_case = 0 +default_field ='' + +try: + opts, args = getopt.getopt(sys.argv[1:], "id:s:", + ["ignore-case","default","split="]) +except getopt.GetoptError as err: + print str(err) # will print something like "option -a not recognized" + sys.exit(2) + +for o, a in opts: + if o in ("-s", "--split"): + maxsplit = eval(a) + elif o in ("-i", "--ignore-case"): + ignore_case = 1 + elif o in ("-d", "--default"): + default_field = a + else: + assert False, "unhandled option" + +# collect all lines from standard input and, for the ones which must be +# reformatted and sorted, count their fields and compute each field's +# maximum size + +input_lines = [] +field_width = [] + +for line in sys.stdin: + # remove final end of line + input_line = line.strip('\n') + if (len(input_line)>0) and (input_line[0] != '#'): + # sortable line: split into fields + fields = input_line.split(None,maxsplit) + # if there are new fields, top up field_widths + for f in range(len(field_width), len(fields)): + field_width.append(0) + # compute the maximum witdh of each field + for f in range(len(fields)): + field_width[f] = max(field_width[f],len(fields[f])) + # collect the line for next stage + input_lines.append(input_line) + +# run through collected input lines, collect the ones which must be +# reformatted and sorted, and whenever a non-reformattable, non-sortable +# line is met, sort the collected lines before it and append them to the +# output lines, then add the non-sortable line too. + +output_lines = [] +sortable_lines = [] +for input_line in input_lines: + if (len(input_line)>0) and (input_line[0] != '#'): + # this line should be reformatted and sorted + input_fields = input_line.split(None,maxsplit) + output_fields = []; + # reformat each field to this field's column width + for f in range(len(input_fields)): + output_field = input_fields[f]; + output_fields.append(output_field.ljust(field_width[f])) + # any missing field is set to default if it exists + if default_field != '': + for f in range(len(input_fields),len(field_width)): + output_fields.append(default_field.ljust(field_width[f])) + # join fields using two spaces, like column -t would + output_line = ' '.join(output_fields); + # collect line for later + sortable_lines.append(output_line) + else: + # this line is non-sortable + # sort collected sortable lines + if ignore_case!=0: + sortable_lines.sort(key=lambda x: str.lower(locale.strxfrm(x))) + else: + sortable_lines.sort(key=lambda x: locale.strxfrm(x)) + # append sortable lines to the final output + output_lines.extend(sortable_lines) + sortable_lines = [] + # append non-sortable line to the final output + output_lines.append(input_line) +# maybe we had sortable lines pending, so append them to the final output +if ignore_case!=0: + sortable_lines.sort(key=lambda x: str.lower(locale.strxfrm(x))) +else: + sortable_lines.sort(key=lambda x: locale.strxfrm(x)) +output_lines.extend(sortable_lines) + +# run through output lines and print them, except rightmost whitespace + +for output_line in output_lines: + print output_line.rstrip()
Put all informations about targets, including state (active or orphan) and maintainers, in boards.cfg; remove MAINTAINERS; adjust the build system accordingly.
Signed-off-by: Albert ARIBAUD albert.u.boot@aribaud.net --- V2: - updated with latest boards.cfg/MAINTAINER info - fixed wrong maintainer(s) for orphan boards - fixed wrong maintainer(s) for base:options case - fixed lingering misuses of boards.cfg and MAINTAINERS V1: - initial submission from squashed RFC patch series
MAINTAINERS | 1412 ---------------------------- MAKEALL | 51 +- Makefile | 2 +- README | 6 +- boards.cfg | 2345 ++++++++++++++++++++++++----------------------- mkconfig | 31 +- tools/buildman/board.py | 2 +- tools/reformat.py | 132 +++ 8 files changed, 1350 insertions(+), 2631 deletions(-) delete mode 100644 MAINTAINERS create mode 100755 tools/reformat.py
diff --git a/MAINTAINERS b/MAINTAINERS deleted file mode 100644 index 86a5ce4..0000000 --- a/MAINTAINERS +++ /dev/null @@ -1,1412 +0,0 @@ -######################################################################### -# # -# Regular Maintainers for U-Boot board support: # -# # -# For any board without permanent maintainer, please contact # -# Wolfgang Denk wd@denx.de # -# and Cc: the u-boot@lists.denx.de mailing list. # -# # -# Note: lists sorted by Maintainer Name # -# Note: These are the maintainers for specific *boards*. The # -# custodians for general architectures and subsystems can # -# be found here -- http://www.denx.de/wiki/U-Boot/Custodians # -# # -######################################################################### - - -######################################################################### -# PowerPC Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Poonam Aggrwal poonam.aggrwal@freescale.com - - P2020RDB P2020 - - BSC9131RDB BSC9131 - -Naveen Burmi NaveenBurmi@freescale.com - - BSC9132QDS BSC9132 - -Greg Allen gallen@arlut.utexas.edu - - UTX8245 MPC8245 - -Pantelis Antoniou panto@intracom.gr - - NETVIA MPC8xx - -Reinhard Arlt reinhard.arlt@esd-electronics.com - - cpci5200 MPC5200 - mecp5123 MPC5121 - mecp5200 MPC5200 - pf5200 MPC5200 - - caddy2 MPC8349 - vme8349 MPC8349 - - CPCI750 PPC750FX/GX - -Peter Barada peter.barada@logicpd.com - - omap3_logic ARM ARMV7 (Logic OMAP35xx/DM37xx) - -Yuli Barcohen yuli@arabellasw.com - - Adder MPC87x/MPC852T - ep8248 MPC8248 - ISPAN MPC8260 - MPC8260ADS MPC826x/MPC827x/MPC8280 - Rattler MPC8248 - ZPC1900 MPC8265 - -Michael Barkowski michael.barkowski@freescale.com - - MPC8323ERDB MPC8323 - -Jerry Van Baren gerald.vanbaren@smiths-aerospace.com - - sacsng MPC8260 - -Oliver Brown obrown@adventnetworks.com - - gw8260 MPC8260 - -Holger Brunck holger.brunck@keymile.com - - kmeter1 MPC8360 - kmcoge5ne MPC8360 - mgcoge MPC8247 - mgcoge3ne MPC8247 - suvd3 MPC8321 - tuge1 MPC8321 - tuxx1 MPC8321 - -Conn Clark clark@esteem.com - - ESTEEM192E MPC8xx - -Jason Cooper u-boot@lakedaemon.net - - dreamplug ARM926EJS (Kirkwood SoC) - -Joe D'Abbraccio ljd015@freescale.com - - MPC837xERDB MPC837x - -Kári Davíðsson kd@flaga.is - - FLAGADM MPC823 - -Torsten Demke torsten.demke@fci.com - - eXalion MPC824x - -Wolfgang Denk wd@denx.de - - IceCube_5200 MPC5200 - - ARIA MPC5121e - - FPS850L MPC850 - FPS860L MPC860 - ICU862 MPC862 - IP860 MPC860 - IVML24 MPC860 - IVML24_128 MPC860 - IVML24_256 MPC860 - IVMS8 MPC860 - IVMS8_128 MPC860 - IVMS8_256 MPC860 - LWMON MPC823 - R360MPI MPC823 - RRvision MPC823 - SM850 MPC850 - SPD823TS MPC823 - TQM823L MPC823 - TQM823L_LCD MPC823 - TQM850L MPC850 - TQM855L MPC855 - TQM860L MPC860 - TQM860L_FEC MPC860 - hermes MPC860 - lwmon MPC823 - - CU824 MPC8240 - Sandpoint8240 MPC8240 - - ATC MPC8250 - PM825 MPC8250 - - TQM8255 MPC8255 - - CPU86 MPC8260 - PM826 MPC8260 - TQM8260 MPC8260 - - P3G4 MPC7410 - -Phil Edworthy phil.edworthy@renesas.com - - rsk7264 SH7264 - -egnite GmbH info@egnite.de - - ethernut5 ARM926EJS (AT91SAM9XE SoC) - -Dirk Eibach eibach@gdsys.de - - controlcenterd P1022 - devconcenter PPC460EX - dlvision PPC405EP - dlvision-10g PPC405EP - gdppc440etx PPC440EP/GR - intip PPC460EX - io PPC405EP - io64 PPC405EX - iocon PPC405EP - neo PPC405EP - -Dave Ellis DGE@sixnetio.com - - SXNI855T MPC8xx - -Thomas Frieden ThomasF@hyperion-entertainment.com - - AmigaOneG3SE MPC7xx - -Matthias Fuchs matthias.fuchs@esd-electronics.com - - APC405 PPC405GP - AR405 PPC405GP - ASH405 PPC405EP - CPCI2DP PPC405GP - CPCI405 PPC405GP - CPCI4052 PPC405GP - CPCI405AB PPC405GP - CPCI405DT PPC405GP - CPCIISER4 PPC405GP - DP405 PPC405EP - DU405 PPC405GP - DU440 PPC440EPx - G2000 PPC405EP - HH405 PPC405EP - HUB405 PPC405EP - OCRTC PPC405GP - ORSG PPC405GP - PCI405 PPC405GP - PLU405 PPC405EP - PMC405 PPC405GP - PMC405DE PPC405EP - PMC440 PPC440EPx - VOH405 PPC405EP - VOM405 PPC405EP - WUH405 PPC405EP - CMS700 PPC405EP - -Siddarth Gore gores@marvell.com - - guruplug ARM926EJS (Kirkwood SoC) - -Paul Gortmaker paul.gortmaker@windriver.com - - sbc8349 MPC8349 - sbc8548 MPC8548 - sbc8641d MPC8641D - -Frank Gottschling fgottschling@eltec.de - - MHPC MPC8xx - -Wolfgang Grandegger wg@denx.de - - ipek01 MPC5200 - - PN62 MPC8240 - IPHASE4539 MPC8260 - -Anatolij Gustschin agust@denx.de - - ac14xx MPC5121e - O2D MPC5200 - O2D300 MPC5200 - O2DNT2 MPC5200 - O2I MPC5200 - O2MNT MPC5200 - O3DNT MPC5200 - -Rob Herring rob.herring@calxeda.com - - highbank highbank - -Klaus Heydeck heydeck@kieback-peter.de - - KUP4K MPC855 - KUP4X MPC859 - -Gabriel Huau contact@huau-gabriel.fr - - mini2440 s3c2440 - -Gary Jennejohn garyj@denx.de - - quad100hd PPC405EP - -Murray Jensen Murray.Jensen@csiro.au - - cogent_mpc8xx MPC8xx - - cogent_mpc8260 MPC8260 - hymod MPC8260 - -Larry Johnson lrj@acm.org - - korat PPC440EPx - -Feng Kan fkan@amcc.com - - redwood PPC4xx - -Brad Kemp Brad.Kemp@seranoa.com - - ppmc8260 MPC8260 - -Sangmoon Kim dogoil@etinsys.com - - debris MPC8245 - KVME080 MPC8245 - -The LEOX team team@leox.org - - ELPT860 MPC860T - -Guennadi Liakhovetski g.liakhovetski@gmx.de - - linkstation MPC8241 - -Dave Liu daveliu@freescale.com - - MPC8315ERDB MPC8315 - MPC832XEMDS MPC832x - MPC8360EMDS MPC8360 - MPC837XEMDS MPC837x - -Nye Liu nyet@zumanetworks.com - - ZUMA MPC7xx_74xx - -Kumar Gala kumar.gala@freescale.com - - MPC8540ADS MPC8540 - MPC8560ADS MPC8560 - MPC8541CDS MPC8541 - MPC8555CDS MPC8555 - - MPC8641HPCN MPC8641D - -Ron Madrid info@sheldoninst.com - - SIMPC8313 MPC8313 - -Dan Malek dan@embeddedalley.com - - stxgp3 MPC85xx - stxssa MPC85xx - stxxtc MPC8xx - -Ryan Mallon ryan@bluewatersys.com - - snapper9260 ARM926EJS (AT91SAM9260 SoC) - snapper9g20 ARM926EJS (AT91SAM9G20 SoC) - -Andrea "llandre" Marson andrea.marson@dave-tech.it - - PPChameleonEVB PPC405EP - -Tirumala Marri tmarri@apm.com - - bluestone APM821XX - -Reinhard Meyer reinhard.meyer@emk-elektronik.de - - TOP860 MPC860T - TOP5200 MPC5200 - TOP9000 ARM926EJS (AT91SAM9xxx SoC) - -Kyle Moffett Kyle.D.Moffett@boeing.com - - HWW1U1A P2020 - -Tolunay Orkun torkun@nextio.com - - csb272 PPC405GP - csb472 PPC405GP - -John Otken jotken@softadvances.com - - luan PPC440SP - taihu PPC405EP - -Keith Outwater Keith_Outwater@mvis.com - - GEN860T MPC860T - GEN860T_SC MPC860T - -Frank Panno fpanno@delphintech.com - - ep8260 MPC8260 - -Chan-Taek Park c-park@ti.com - - tnetv107x_evm tnetv107x - -Denis Peter d.peter@mpl.ch - - MIP405 PPC4xx - PIP405 PPC4xx - -Werner Pfister Pfister_Werner@intercontrol.de - digsy_mtc mpc5200 - digsy_mtc_rev5 mpc5200 - -Kim Phillips kim.phillips@freescale.com - - MPC8349EMDS MPC8349 - -Sergei Poselenov sposelenov@emcraft.com - - a4m072 MPC5200 - -Sudhakar Rajashekhara sudhakar.raj@ti.com - - da850evm ARM926EJS (DA850/OMAP-L138) - -Ricardo Ribalda ricardo.ribalda@uam.es - - ml507 PPC440x5 - v5fx30teval PPC440x5 - xilinx-ppc405-generic PPC405 - xilinx-ppc440-generic PPC440x5 - -Stefan Roese sr@denx.de - - a3m071 MPC5200 - a4m2k MPC5200 - - P3M7448 MPC7448 - - uc100 MPC857 - - acadia PPC405EZ - alpr PPC440GX - bamboo PPC440EP - bunbinga PPC405EP - canyonlands PPC460EX - ebony PPC440GP - glacier PPC460GT - haleakala PPC405EXr - icon PPC440SPe - katmai PPC440SPe - kilauea PPC405EX - lwmon5 PPC440EPx - makalu PPC405EX - ocotea PPC440GX - p3p440 PPC440GP - pcs440ep PPC440EP - rainier PPC440GRx - sequoia PPC440EPx - sycamore PPC405GPr - t3corp PPC460GT - taishan PPC440GX - walnut PPC405GP - yellowstone PPC440GR - yosemite PPC440EP - zeus PPC405EP - - P3M750 PPC750FX/GX/GL - -Yusdi Santoso yusdi_santoso@adaptec.com - - HIDDEN_DRAGON MPC8241/MPC8245 - -Travis Sawyer (travis.sawyer@sandburst.com> - - KAREF PPC440GX - METROBOX PPC440GX - -Georg Schardt schardt@team-ctech.de - - fx12mm PPC405 - -Heiko Schocher hs@denx.de - - cam_enc_4xx davinci/ARM926EJS - charon MPC5200 - ids8247 MPC8247 - ipam390 davinci/ARM926EJS - jupiter MPC5200 - kmsupx5 MPC8321 - mucmc52 MPC5200 - muas3001 MPC8270 - municse MPC5200 - sc3 PPC405GP - uc101 MPC5200 - ve8313 MPC8313 - -Andre Schwarz andre.schwarz@matrix-vision.de - - mergerbox MPC8377 - mvbc_p MPC5200 - mvblm7 MPC8343 - mvsmr MPC5200 - -Inderpal Singh inderpal.singh@linaro.org - - Arndale ARM ARMV7 (EXYNOS5250 SoC) - -Jon Smirl jonsmirl@gmail.com - - pcm030 MPC5200 - -Ira W. Snyder iws@ovro.caltech.edu - - P2020COME P2020 - -York Sun yorksun@freescale.com - - T4240EMU T4240 - -Timur Tabi timur@freescale.com - - MPC8349E-mITX MPC8349 - MPC8349E-mITX-GP MPC8349 - P1022DS P1022 - -Erik Theisen etheisen@mindspring.com - - W7OLMC PPC4xx - W7OLMG PPC4xx - -Jim Thompson jim@musenki.com - - MUSENKI MPC8245/8241 - Sandpoint8245 MPC8245 - -Rune Torgersen runet@innovsys.com - - MPC8266ADS MPC8266 - -Peter Tyser ptyser@xes-inc.com - - xpedite1000 PPC440GX - xpedite5170 MPC8640 - xpedite5200 MPC8548 - xpedite5370 MPC8572 - xpedite5500 P2020 - -David Updegraff dave@cray.com - - CRAYL1 PPC4xx - -Anton Vorontsov avorontsov@ru.mvista.com - - MPC8360ERDK MPC8360 - -Josef Wagner Wagner@Microsys.de - - CPC45 MPC8245 - PM520 MPC5200 - -Michael Weiss michael.weiss@ifm.com - - PDM360NG MPC5121e - -Stephen Williams steve@icarus.com - - JSE PPC405GPr - -Ilya Yanok yanok@emcraft.com - - mpc8308_p1m MPC8308 - MPC8308RDB MPC8308 - -Roy Zang tie-fei.zang@freescale.com - - mpc7448hpc2 MPC7448 - P1023RDS P1023 - -John Zhan zhanz@sinovee.com - - svm_sc8xx MPC8xx - -Detlev Zundel dzu@denx.de - - inka4x0 MPC5200 - -Po Liu po.liu@freescale.com - - C29XPCIE C29X - -------------------------------------------------------------------------- - -Unknown / orphaned boards: - - ADS860 MPC8xx - FADS823 MPC8xx - FADS850SAR MPC8xx - FADS860T MPC8xx - GENIETV MPC8xx - MBX MPC8xx - MBX860T MPC8xx - NX823 MPC8xx - RPXClassic MPC8xx - RPXlite MPC8xx - - MOUSSE MPC824x - - RPXsuper MPC8260 - rsdproto MPC8260 - - EVB64260 MPC7xx_74xx - EVB64260_750CX MPC750CX [Eran Man eran@nbase.co.il] - - versatile ARM926EJ-S - -######################################################################### -# ARM Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Albert ARIBAUD albert.u.boot@aribaud.net - - edminiv2 ARM926EJS (Orion5x SoC) - -Raphael Assenat raph@8d.com - - eco5pk ARM ARMV7 (AM35x SoC) - -Stefano Babic sbabic@denx.de - - ea20 davinci - flea3 i.MX35 - mt_ventoux omap3 - mx35pdk i.MX35 - mx51evk i.MX51 - polaris xscale/pxa - trizepsiv xscale/pxa - twister omap3 - vision2 i.MX51 - woodburn i.MX35 - -Lukasz Dalek luk0104@gmail.com - - h2200 xscale/pxa - -Jason Liu r64343@freescale.com - - mx53evk i.MX53 - mx53loco i.MX53 - mx6qarm2 i.MX6Q - -Enric Balletbo i Serra eballetbo@iseebcn.com - - igep0020 ARM ARMV7 (OMAP3xx SoC) - igep0030 ARM ARMV7 (OMAP3xx SoC) - igep0032 ARM ARMV7 (OMAP3xx SoC) - igep0033 ARM ARMV7 (AM33xx Soc) - -Eric Benard eric@eukrea.com - - cpuat91 ARM920T - cpu9260 ARM926EJS (AT91SAM9260 SoC) - cpu9G20 ARM926EJS (AT91SAM9G20 SoC) - -Ajay Bhargav ajay.bhargav@einfochips.com - - gplugd ARM926EJS (ARMADA100 88AP168 SoC) - -Rishi Bhattacharya rishi@ti.com - - omap5912osk ARM926EJS - -Andreas Bießmann andreas.devel@gmail.com - - at91rm9200ek at91rm9200 - -Cliff Brake cliff.brake@gmail.com - - pxa255_idp xscale/pxa - -Rick Bronson rick@efn.org - - AT91RM9200DK at91rm9200 - -Luca Ceresoli luca.ceresoli@comelit.it - - dig297 ARM ARMV7 (OMAP3530 SoC) - -Po-Yu Chuang ratbert@faraday-tech.com - - a320evb FA526 (ARM920T-like) (a320 SoC) - -Eric Cooper ecc@cmu.edu - - dockstar ARM926EJS (Kirkwood SoC) - -Wolfgang Denk wd@denx.de - imx27lite i.MX27 - qong i.MX31 - -Mike Dunn mikedunn@newsguy.com - palmtreo680 pxa270 - -Kristoffer Ericson kristoffer.ericson@gmail.com - - jornada SA1110 - -Fabio Estevam fabio.estevam@freescale.com - - mx25pdk i.MX25 - mx28evk i.MX28 - mx31pdk i.MX31 - mx53ard i.MX53 - mx53smd i.MX53 - mx6sabresd i.MX6Q/DL - mx6qsabreauto i.MX6Q - wandboard i.MX6DL/S/Q - mx6slevk i.MX6SL - -Daniel Gorsulowski daniel.gorsulowski@esd.eu - - meesc ARM926EJS (AT91SAM9263 SoC) - otc570 ARM926EJS (AT91SAM9263 SoC) - -Bo Shenvoice.shen@atmel.com - at91sam9g10ek ARM926EJS (AT91SAM9G10 SoC) - at91sam9m10g45ek ARM926EJS (AT91SAM9G45 SoC) - -Simon Guinot simon.guinot@sequanux.org - - inetspace_v2 ARM926EJS (Kirkwood SoC) - netspace_v2 ARM926EJS (Kirkwood SoC) - netspace_max_v2 ARM926EJS (Kirkwood SoC) - net2big_v2 ARM926EJS (Kirkwood SoC) - -Igor Grinberg grinberg@compulab.co.il - - cm_t35 ARM ARMV7 (OMAP3xx Soc) - -Stefan Herbrechtsmeier stefan@code.herbrechtsmeier.net - - dns325 ARM926EJS (Kirkwood SoC) - -Lauri Hintsala lauri.hintsala@bluegiga.com - - apx4devkit i.MX28 - -Vaibhav Hiremath hvaibhav@ti.com - - am3517_evm ARM ARMV7 (AM35x SoC) - -Markus Hubig mhubig@imko.de - - STAMP9G20 ARM926EJS - -Grazvydas Ignotas notasas@gmail.com - - omap3_pandora ARM ARMV7 (OMAP3xx SoC) - -Ilko Iliev iliev@ronetix.at - - PM9261 AT91SAM9261 - PM9263 AT91SAM9263 - PM9G45 ARM926EJS (AT91SAM9G45 SoC) - -Michael Jones michael.jones@matrix-vision.de - - omap3_mvblx ARM ARMV7 (OMAP3xx SoC) - -Matthias Kaehlcke matthias@kaehlcke.net - edb9301 ARM920T (EP9301) - edb9302 ARM920T (EP9302) - edb9302a ARM920T (EP9302) - edb9307 ARM920T (EP9307) - edb9307a ARM920T (EP9307) - edb9312 ARM920T (EP9312) - edb9315 ARM920T (EP9315) - edb9315a ARM920T (EP9315) - -Nishant Kamat nskamat@ti.com - - omap1610h2 ARM926EJS - -Minkyu Kang mk7.kang@samsung.com - - SMDKC100 ARM ARMV7 (S5PC100 SoC) - s5p_goni ARM ARMV7 (S5PC110 SoC) - s5pc210_universal ARM ARMV7 (EXYNOS4210 SoC) - -Chander Kashyap k.chander@samsung.com - - origen ARM ARMV7 (EXYNOS4210 SoC) - SMDKV310 ARM ARMV7 (EXYNOS4210 SoC) - SMDK5250 ARM ARMV7 (EXYNOS5250 SoC) - -Lukasz Majewski l.majewski@samsung.com - - trats ARM ARMV7 (EXYNOS4210 SoC) - -Torsten Koschorrek koschorrek@synertronixx.de - scb9328 ARM920T (i.MXL) - -Sergey Kubushyn ksi@koi8.net - - DV-EVM ARM926EJS - SONATA ARM926EJS - SCHMOOGIE ARM926EJS - -Vipin Kumar vipin.kumar@st.com - - spear300 ARM926EJS (spear300 Soc) - spear310 ARM926EJS (spear310 Soc) - spear320 ARM926EJS (spear320 Soc) - spear600 ARM926EJS (spear600 Soc) - -Sergey Lapin slapin@ossfans.org - - afeb9260 ARM926EJS (AT91SAM9260 SoC) - -Valentin Longchamp valentin.longchamp@keymile.com - - km_kirkwood ARM926EJS (Kirkwood SoC) - kmnusa ARM926EJS (Kirkwood SoC) - mgcoge3un ARM926EJS (Kirkwood SoC) - kmcoge5un ARM926EJS (Kirkwood SoC) - portl2 ARM926EJS (Kirkwood SoC) - -Nishanth Menon nm@ti.com - - omap3_sdp3430 ARM ARMV7 (OMAP3xx SoC) - omap3_zoom1 ARM ARMV7 (OMAP3xx SoC) - -David Müller d.mueller@elsoft.ch - - smdk2410 ARM920T - VCMA9 ARM920T - -Eric Millbrandt emillbrandt@dekaresearch.com - - galaxy5200 mpc5200 - -Nagendra T S nagendra@mistralsolutions.com - - am3517_crane ARM ARMV7 (AM35x SoC) - -Dinh Nguyen dinguyen@altera.com -Chin Liang See clsee@altera.com - - socfpga socfpga_cyclone5 - -Sandeep Paulraj s-paulraj@ti.com - - davinci_dm355evm ARM926EJS - davinci_dm355leopard ARM926EJS - davinci_dm365evm ARM926EJS - davinci_dm6467evm ARM926EJS - -Helmut Raiger helmut.raiger@hale.at - - tt01 i.MX31 - -Linus Walleij linus.walleij@linaro.org - integratorap various - integratorcp various - -Luka Perkov luka@openwrt.org - - ib62x0 ARM926EJS - iconnect ARM926EJS - -Dave Peverley dpeverley@mpc-data.co.uk - - omap730p2 ARM926EJS - -Lars Poeschel poeschel@lemonage.de - pcm051 ARM ARMV7 (AM33xx Soc) - -Mathieu Poirier mathieu.poirier@linaro.org - - snowball ARM ARMV7 (u8500 SoC) - -Stelian Pop stelian@popies.net - - at91sam9260ek ARM926EJS (AT91SAM9260 SoC) - at91sam9261ek ARM926EJS (AT91SAM9261 SoC) - at91sam9263ek ARM926EJS (AT91SAM9263 SoC) - at91sam9rlek ARM926EJS (AT91SAM9RL SoC) - -Matt Porter mporter@ti.com - - ti814x_evm ARM ARMV7 (TI814x Soc) - -Dave Purdy david.c.purdy@gmail.com - - pogo_e02 ARM926EJS (Kirkwood SoC) - -Sricharan R r.sricharan@ti.com - - omap4_panda ARM ARMV7 (OMAP4xx SoC) - omap4_sdp4430 ARM ARMV7 (OMAP4xx SoC) - omap5_evm ARM ARMV7 (OMAP5xx Soc) - -Suriyan Ramasami suriyan.r@gmail.com - - goflexhome ARM926EJS (Kirkwood SoC) - -Thierry Reding thierry.reding@avionic-design.de - - plutux Tegra20 (ARM7 & A9 Dual Core) - medcom-wide Tegra20 (ARM7 & A9 Dual Core) - tec Tegra20 (ARM7 & A9 Dual Core) - -Christian Riesch christian.riesch@omicron.at -Manfred Rudigier manfred.rudigier@omicron.at - - calimain ARM926EJS (AM1808 SoC) - -Tom Rini trini@ti.com - - am335x_evm ARM ARMV7 (AM33xx Soc) - omap3_beagle ARM ARMV7 (OMAP3xx SoC) - omap3_evm ARM ARMV7 (OMAP3xx SoC) - -Tom Rix Tom.Rix@windriver.com - - omap3_zoom2 ARM ARMV7 (OMAP3xx SoC) - -John Rigby jcrigby@gmail.com - - tx25 i.MX25 - -Stefan Roese sr@denx.de - - x600 ARM926EJS (spear600 Soc) - - titanium i.MX6Q - - pdnb3 xscale/ixp - scpu xscale/ixp - -Alessandro Rubini rubini@unipv.it -Nomadik Linux Team STN_WMM_nomadik_linux@list.st.com - - nhk8815 ARM926EJS (Nomadik 8815 Soc) - -Steve Sakoman sakoman@gmail.com - - omap3_overo ARM ARMV7 (OMAP3xx SoC) - -Leo Sartre lsartre@adeneo-embedded.com - - cgtqmx6qeval i.MX6Q - -Jens Scharsig esw@bus-elektronik.de - - eb_cpux9k2 ARM920T (AT91RM9200 SoC) - vl_ma2sc ARM926EJS (AT91SAM9263 SoC) - -Heiko Schocher hs@denx.de - - enbw_cmc ARM926EJS (AM1808 SoC) - magnesium i.MX27 - -Michael Schwingen michael@schwingen.org - - actux1 xscale/ixp - actux2 xscale/ixp - actux3 xscale/ixp - actux4 xscale/ixp - dvlhost xscale/ixp - -Matt Sealey matt@genesi-usa.com - - efikamx i.MX51 - efikasb i.MX51 - -Bo Shen voice.shen@atmel.com - at91sam9x5ek ARM926EJS (AT91SAM9G15,G25,G35,X25,X35 SoC) - sama5d3xek ARMV7 (SAMA5D31, D33, D34, D35 SoC) - -Rajeshwari Shinde rajeshwari.s@samsung.com - - snow ARM ARMV7 (EXYNOS5250 SoC) - -Michal Simek monstr@monstr.eu - - zynq ARM ARMV7 (Zynq SoC) - -Lucas Stach dev@lynxeye.de - - colibri_t20_iris Tegra20 (ARM7 & A9 Dual Core) - -Antoine Tenart atenart@adeneo-embedded.com - - TI816X ARM ARMV7 (TI816x Soc) - -Nick Thompson nick.thompson@gefanuc.com - - da830evm ARM926EJS (DA830/OMAP-L137) - -Albin Tonnerre albin.tonnerre@free-electrons.com - - sbc35_a9g20 ARM926EJS (AT91SAM9G20 SoC) - tny_a9260 ARM926EJS (AT91SAM9260 SoC) - tny_a9g20 ARM926EJS (AT91SAM9G20 SoC) - -Greg Ungerer greg.ungerer@opengear.com - - cm4008 ks8695p - cm4116 ks8695p - cm4148 ks8695p - -Marek Vasut marek.vasut@gmail.com - - balloon3 xscale/pxa - colibri_pxa270 xscale/pxa - palmld xscale/pxa - palmtc xscale/pxa - vpac270 xscale/pxa - zipitz2 xscale/pxa - mx23_olinuxino i.MX23 - m28evk i.MX28 - sc_sps_1 i.MX28 - m53evk i.MX53 - -Hugo Villeneuve hugo.villeneuve@lyrtech.com - - SFFSDR ARM926EJS - -Lokesh Vutla lokeshvutla@ti.com - - dra7xx_evm ARM ARMV7 (DRA7xx Soc) - -Matt Waddel matt.waddel@linaro.org - - vexpress_ca9x4 ARM ARMV7 (Quad Core) - vexpress_ca5x2 ARM ARMV7 (Dual Core) - -Otavio Salvador otavio@ossystems.com.br - - mx23evk i.MX23 - -Prafulla Wadaskar prafulla@marvell.com - - aspenite ARM926EJS (ARMADA100 88AP168 SoC) - mv88f6281gtw_ge ARM926EJS (Kirkwood SoC) - openrd_base ARM926EJS (Kirkwood SoC) - rd6281a ARM926EJS (Kirkwood SoC) - sheevaplug ARM926EJS (Kirkwood SoC) - -Michael Walle michael@walle.cc - - lschlv2 ARM926EJS (Kirkwood SoC) - lsxhl ARM926EJS (Kirkwood SoC) - -Tom Warren twarren@nvidia.com - - harmony Tegra20 (ARM7 & A9 Dual Core) - seaboard Tegra20 (ARM7 & A9 Dual Core) - cardhu Tegra30 (ARM7 & A9 Quad Core) - dalmore Tegra114 (ARM7 & A15 Quad Core) - -Tom Warren twarren@nvidia.com -Stephen Warren swarren@nvidia.com - - ventana Tegra20 (ARM7 & A9 Dual Core) - paz00 Tegra20 (ARM7 & A9 Dual Core) - trimslice Tegra20 (ARM7 & A9 Dual Core) - whistler Tegra20 (ARM7 & A9 Dual Core) - beaver Tegra30 (ARM7 & A9 Quad Core) - -Stephen Warren swarren@wwwdotorg.org - - rpi_b BCM2835 (ARM1176) - -Thomas Weber weber@corscience.de - - devkit8000 ARM ARMV7 (OMAP3530 SoC) - tricorder ARM ARMV7 (OMAP3503 SoC) - -Lei Wen leiwen@marvell.com - - dkb ARM926EJS (PANTHEON 88AP920 SOC) - -Matthias Weisser weisserm@arcor.de - - jadecpu ARM926EJS (MB86R01 SoC) - zmx25 ARM926EJS (imx25 SoC) - -Josh Wu josh.wu@atmel.com - at91sam9n12ek ARM926EJS (AT91SAM9N12 SoC) - -Ilya Yanok yanok@emcraft.com - - mcx ARM ARMV7 (AM35x SoC) - -Syed Mohammed Khasim sm.khasim@gmail.com -Sughosh Ganu urwithsughosh@gmail.com - - hawkboard ARM926EJS (OMAP-L138) - -Vladimir Zapolskiy vz@mleia.com - - devkit3250 lpc32xx - -Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com -Tetsuyuki Kobayashi koba@kmckk.co.jp - - kzm9g SH73A0 (RMOBILE SoC) - -Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com - - armadillo-800eva R8A7740 (RMOBILE SoC) - -Pali Rohár pali.rohar@gmail.com - - nokia_rx51 ARM ARMV7 (OMAP34xx SoC) - -Eric Nelson eric.nelson@boundarydevices.com - mx6qsabrelite i.MX6Q 1GB - nitrogen6dl i.MX6DL 1GB - nitrogen6dl2g i.MX6DL 2GB - nitrogen6q i.MX6Q/6D 1GB - nitrogen6q2g i.MX6Q/6D 2GB - nitrogen6s i.MX6S 512MB - nitrogen6s1g i.MX6S 1GB - -Alison Wang b18965@freescale.com - - vf610twr VF610 - -Sergey Yanovich ynvich@gmail.com - - lp8x4x xscale/pxa - -Roger Meier r.meier@siemens.com - dxr2 ARM ARMV7 (AM335x SoC) - pxm2 ARM ARMV7 (AM335x SoC) - rut ARM ARMV7 (AM335x SoC) - -------------------------------------------------------------------------- - -Unknown / orphaned boards: - Board CPU Last known maintainer / Comment -......................................................................... - - omap1510inn ARM925T Kshitij Gupta kshitij@ti.com - - lubbock xscale/pxa Kyle Harris kharris@nexus-tech.net / dead address - - imx31_phycore_eet i.MX31 Guennadi Liakhovetski g.liakhovetski@gmx.de / resigned - mx31ads i.MX31 Guennadi Liakhovetski g.liakhovetski@gmx.de / resigned - -######################################################################### -# x86 Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Simon Glass sjg@chromium.org - - chromebook-x86 Coreboot runs first, then U-Boot - Supports Intel Sandy Bridge / Ivy Bridge so far - - Chromebooks for x86, including: - Samsung Series 5 Chromebook - Acer AC700 Chromebook - Acer C7 Chromebook - Samsung Chromebook 550 - HP Pavillion Chromebook - Acer C710 Chromebook - Chromebook Pixel - -######################################################################### -# MIPS Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Wolfgang Denk wd@denx.de - - incaip MIPS32 4Kc - -Vlad Lungu vlad.lungu@windriver.com - qemu_mips MIPS32 - -Stefan Roese sr@denx.de - - vct_xxx MIPS32 4Kc - -------------------------------------------------------------------------- - -Unknown / orphaned boards: - Board CPU Last known maintainer / Comment -......................................................................... - - dbau1x00 MIPS32 Au1000 Thomas Lange thomas@corelatus.se - -######################################################################### -# Nios-II Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Scott McNutt smcnutt@psyent.com - - PCI5441 Nios-II - PK1C20 Nios-II - nios2-generic Nios-II - -######################################################################### -# MicroBlaze Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Michal Simek monstr@monstr.eu - - microblaze-generic MicroBlaze - -######################################################################### -# Coldfire Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Hayden Fraser Hayden.Fraser@freescale.com - - M5253EVBE mcf52x2 - -Matthias Fuchs matthias.fuchs@esd-electronics.com - - TASREG MCF5249 - -Jens Scharsig esw@bus-elektronik.de - - eb_cpu5282 mfc5282 - -TsiChung Liew Tsi-Chung.Liew@freescale.com - - M52277EVB mcf5227x - M5235EVB mcf52x2 - M5253DEMO mcf52x2 - M53017EVB mcf532x - M5329EVB mcf532x - M5373EVB mcf532x - M54455EVB mcf5445x - M5475EVB mcf547x_8x - M5485EVB mcf547x_8x - -Wolfgang Wegner w.wegner@astro-kom.de - - astro_mcf5373l MCF5373L - -######################################################################### -# AVR32 Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Andreas Bießmann andreas.devel@googlemail.com - grasshopper AT32AP7000 - atngw100mkii AT32AP7000 - -Hans-Christian Egtvedt hans-christian.egtvedt@atmel.com - - FAVR-32-EZKIT AT32AP7000 - -Mark Jackson mpfj@mimc.co.uk - - MIMC200 AT32AP7000 - -Alex Raimondi alex.raimondi@miromico.ch -Julien May julien.may@miromico.ch - - HAMMERHEAD AT32AP7000 - -Haavard Skinnemoen haavard.skinnemoen@atmel.com - - ATSTK1000 AT32AP7xxx - ATSTK1002 AT32AP7000 - ATSTK1003 AT32AP7001 - ATSTK1004 AT32AP7002 - ATSTK1006 AT32AP7000 - ATNGW100 AT32AP7000 - -######################################################################### -# SuperH Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Yusuke Goda goda.yusuke@renesas.com - - MIGO-R SH7722 - -Nobuhiro Iwamatsu iwamatsu@nigauri.org - iwamatsu.nobuhiro@renesas.com - - MS7750SE SH7750 - MS7722SE SH7722 - R7780MP SH7780 - R2DPlus SH7751R - SH7763RDP SH7763 - RSK7203 SH7203 - AP325RXA SH7723 - SHMIN SH7706 - ECOVEC SH7724 - R0P7734 SH7734 - AP_SH4A_4A SH7734 - -Mark Jonas mark.jonas@de.bosch.com - - mpr2 SH7720 - -Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com - - MS7720SE SH7720 - R0P77520000RZ SH7752 - R0P77570030RL SH7757 - R0P77850011RL SH7785 - -######################################################################### -# Blackfin Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Sonic Zhang sonic.adi@gmail.com -Blackfin Team u-boot-devel@blackfin.uclinux.org - - BF506F-EZKIT BF506 - BF518F-EZBRD BF518 - BF526-EZBRD BF526 - BF527-AD7160-EVAL BF527 - BF527-EZKIT BF527 - BF527-EZKIT-V2 BF527 - BF527-SDP BF527 - BF533-EZKIT BF533 - BF533-STAMP BF533 - BF537-PNAV BF537 - BF537-STAMP BF537 - BF538F-EZKIT BF538 - BF548-EZKIT BF548 - BF561-EZKIT BF561 - BF609-EZKIT BF609 - -M.Hasewinkel (MHA) info@ssv-embedded.de - - dnp5370 BF537 - -Brent Kandetzki brentk@teleco.com - - IP04 BF532 - -Peter Meerwald devel@bct-electronic.com - - bct-brettl2 BF536 - -I-SYST Micromodule support@i-syst.com - - IBF-DSP561 BF561 - -Wojtek Skulski skulski@pas.rochester.edu -Wojtek Skulski info@skutek.com -Benjamin Matthews mben12@gmail.com - - BlackStamp BF533 - BlackVME BF561 - -Martin Strubel strubel@section5.ch - - BF537-minotaur BF537 - BF537-srv1 BF537 - -Bluetechnix Tinyboards bluetechnix@blackfin.uclinux.org - - CM-BF527 BF527 - CM-BF533 BF533 - CM-BF537E BF537 - CM-BF537U BF537 - CM-BF548 BF548 - CM-BF561 BF561 - TCM-BF518 BF518 - TCM-BF537 BF537 - -Valentin Yakovenkov yakovenkov@niistt.ru -Anton Shurpin shurpin.aa@niistt.ru - - BF561-ACVILON BF561 - -Haitao Zhang hzhang@ucrobotics.com -Chong Huang chuang@ucrobotics.com - - bf525-ucr2 BF525 - -Dimitar Penev dpn@switchfin.org - - BR4 Appliance BF537 - PR1 Appliance BF537 - -######################################################################### -# NDS32 Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Andes uboot@andestech.com - - ADP-AG101 N1213 (AG101 SoC) - ADP-AG101P N1213 (AG101P XC5 FPGA) - ADP-AG102 N1213f (AG102 SoC with FPU) - -######################################################################### -# OpenRISC Systems: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Stefan Kristiansson stefan.kristiansson@saunalahti.fi - - openrisc-generic OpenRISC - -######################################################################### -# Sandbox: # -# # -# Maintainer Name, Email Address # -# Board CPU # -######################################################################### - -Simon Glass sjg@chromium.org - - sandbox sandbox - -######################################################################### -# End of MAINTAINERS list # -######################################################################### diff --git a/MAKEALL b/MAKEALL index bed99de..c0d04fb 100755 --- a/MAKEALL +++ b/MAKEALL @@ -106,9 +106,9 @@ while true ; do -s|--soc) # echo "Option SoC: argument `$2'" if [ "$opt_s" ] ; then - opt_s="${opt_s%)} || $6 == "$2" || $6 ~ /$2/)" + opt_s="${opt_s%)} || $4 == "$2" || $4 ~ /$2/)" else - opt_s="($6 == "$2" || $6 ~ /$2/)" + opt_s="($4 == "$2" || $4 ~ /$2/)" fi SELECTED='y' shift 2 ;; @@ -160,7 +160,7 @@ FILTER="$1 !~ /^#/" [ "$opt_v" ] && FILTER="${FILTER} && $opt_v"
if [ "$SELECTED" ] ; then - SELECTED=$(awk '('"$FILTER"') { print $1 }' boards.cfg) + SELECTED=$(awk '('"$FILTER"') { print $7 }' boards.cfg)
# Make sure some boards from boards.cfg are actually found if [ -z "$SELECTED" ] ; then @@ -232,12 +232,12 @@ boards_by_field() -v field="$1" \ -v select="$2" \ -F "$FS" \ - '($1 !~ /^#/ && $field == select) { print $1 }' \ + '($1 !~ /^#/ && $field == select) { print $7 }' \ boards.cfg } boards_by_arch() { boards_by_field 2 "$@" ; } boards_by_cpu() { boards_by_field 3 "$@" "[: \t]+" ; } -boards_by_soc() { boards_by_field 6 "$@" ; } +boards_by_soc() { boards_by_field 4 "$@" ; }
######################################################################### ## MPC5xx Systems @@ -519,56 +519,53 @@ get_target_location() { local vendor=""
# Automatic mode - local line=`egrep -i "^[[:space:]]*${target}[[:space:]]" boards.cfg` - + local line=`awk -F '\ +' '$7 == "'"$target"'" { print $0 }' boards.cfg` if [ -z "${line}" ] ; then echo "" ; return ; fi
set ${line}
- # add default board name if needed - [ $# = 3 ] && set ${line} ${1} - - CONFIG_NAME="${1%_config}" + CONFIG_NAME="${7%_config}"
- [ "${BOARD_NAME}" ] || BOARD_NAME="${1%_config}" + [ "${BOARD_NAME}" ] || BOARD_NAME="${7%_config}"
- if [ "$4" = "-" ] ; then - board=${BOARD_NAME} - else - board="$4" + if [ $# -gt 5 ]; then + if [ "$6" = "-" ] ; then + board=${BOARD_NAME} + else + board="$6" + fi fi
[ $# -gt 4 ] && [ "$5" != "-" ] && vendor="$5" - [ $# -gt 6 ] && [ "$7" != "-" ] && { - tmp="${7%:*}" + [ $# -gt 6 ] && [ "$8" != "-" ] && { + tmp="${8%:*}" if [ "$tmp" ] ; then CONFIG_NAME="$tmp" fi }
# Assign board directory to BOARDIR variable - if [ -z "${vendor}" ] ; then + if [ "${vendor}" == "-" ] ; then BOARDDIR=${board} else BOARDDIR=${vendor}/${board} fi
- echo "${CONFIG_NAME}:${BOARDDIR}" + echo "${CONFIG_NAME}:${BOARDDIR}:${BOARD_NAME}" }
get_target_maintainers() { - local name=`echo $1 | cut -d : -f 1` + local name=`echo $1 | cut -d : -f 3`
- if ! grep -qsi "[[:blank:]]${name}[[:blank:]]" MAINTAINERS ; then + local line=`awk -F '\ +' '$7 == "'"$target"'" { print $0 }' boards.cfg` + if [ -z "${line}" ]; then echo "" return ; fi
- local line=`tac MAINTAINERS | grep -ni "[[:blank:]]${name}[[:blank:]]" | cut -d : -f 1` - local mail=`tac MAINTAINERS | tail -n +${line} | \ - sed -n ":start /.*@.*/ { b mail } ; n ; b start ; :mail /.*@.*/ { p ; n ; b mail } ; q" | \ - sed "s/^.*<//;s/>.*$//"` - echo "$mail" + local mails=`echo ${line} | cut -d ' ' -f 9- | sed -e 's/[^<]*<//' -e 's/>.*</ /' -e 's/>[^>]*$//'` + [ "$mails" == "-" ] && mails="" + echo "$mails" }
get_target_arch() { diff --git a/Makefile b/Makefile index 5de84b6..2a21aaa 100644 --- a/Makefile +++ b/Makefile @@ -837,7 +837,7 @@ unconfig:
sinclude $(obj).boards.depend $(obj).boards.depend: boards.cfg - @awk '(NF && $$1 !~ /^#/) { print $$1 ": " $$1 "_config; $$(MAKE)" }' $< > $@ + @awk '(NF && $$1 !~ /^#/) { print $$7 ": " $$7 "_config; $$(MAKE) -d" }' $< > $@
# # Functions to generate common board directory names diff --git a/README b/README index 677c3dc..3f0ca9f 100644 --- a/README +++ b/README @@ -35,7 +35,7 @@ Makefile have been tested to some extent and can be considered "working". In fact, many of them are used in production systems.
In case of problems see the CHANGELOG and CREDITS files to find out -who contributed the specific port. The MAINTAINERS file lists board +who contributed the specific port. The boards.cfg file lists board maintainers.
Note: There is no CHANGELOG file in the actual U-Boot source tree; @@ -5824,8 +5824,8 @@ it:
* For major contributions, your entry to the CREDITS file
-* When you add support for a new board, don't forget to add this - board to the MAINTAINERS file, too. +* When you add support for a new board, don't forget to add a + maintainer e-mail address to the boards.cfg file, too.
* If your patch adds new configuration options, don't forget to document these in the README file. diff --git a/boards.cfg b/boards.cfg index b4297e5..dbd8479 100644 --- a/boards.cfg +++ b/boards.cfg @@ -26,1179 +26,1180 @@ # #define CONFIG_HAS_BAR 1 # #define CONFIG_BAZ 64 # -# The list should be ordered according to the following fields, -# from most to least significant: -# -# ARCH, CPU, SoC, Vendor, Target -# -# To keep the list sorted, use something like -# :.,$! sort -bdf -k2,2 -k3,3 -k6,6 -k5,5 -k1,1 +# The maintainers field lists the e-mail addresses of the board's +# maintainers, separated by colons. NOTE: there are spaces in this field! +# For any board without permanent maintainer, please contact +# Wolfgang Denk wd@denx.de +# And Cc: the u-boot@lists.denx.de mailing list. + +# The list should be ordered according to the C locale. # -# To reformat the list, use something like -# :.,$! column -t +# To keep the list formatted and sorted, script tools/reformat.py is available. +# It can be used from a shell: +# tools/reformat.py -i -d '-' -s 8 <boards.cfg >boards0.cfg && mv boards0.cfg boards.cfg +# It can directly be invoked from vim: +# :%tools/reformat.py -i -d '-' -s 8 # -# Target ARCH CPU Board name Vendor SoC Options +# Status, Arch, CPU:SPLCPU, SoC, Vendor, Board name, Target, Options, Maintainers ###########################################################################################################
-integratorcp_cm1136 arm arm1136 integrator armltd - integratorcp:CM1136 -imx31_phycore arm arm1136 - - mx31 -imx31_phycore_eet arm arm1136 imx31_phycore - mx31 imx31_phycore:IMX31_PHYCORE_EET -qong arm arm1136 - davedenx mx31 -mx31ads arm arm1136 - freescale mx31 -mx31pdk arm arm1136 - freescale mx31 -tt01 arm arm1136 - hale mx31 -imx31_litekit arm arm1136 - logicpd mx31 -flea3 arm arm1136 - CarMediaLab mx35 -mx35pdk arm arm1136 - freescale mx35 -woodburn arm arm1136 - - mx35 -woodburn_sd arm arm1136 woodburn - mx35 woodburn_sd:IMX_CONFIG=board/woodburn/imximage.cfg -tnetv107x_evm arm arm1176 tnetv107xevm ti tnetv107x -rpi_b arm arm1176 rpi_b raspberrypi bcm2835 -integratorap_cm720t arm arm720t integrator armltd - integratorap:CM720T -integratorap_cm920t arm arm920t integrator armltd - integratorap:CM920T -integratorcp_cm920t arm arm920t integrator armltd - integratorcp:CM920T -a320evb arm arm920t - faraday a320 -at91rm9200ek arm arm920t at91rm9200ek atmel at91 at91rm9200ek -at91rm9200ek_ram arm arm920t at91rm9200ek atmel at91 at91rm9200ek:RAMBOOT -eb_cpux9k2 arm arm920t eb_cpux9k2 BuS at91 eb_cpux9k2 -eb_cpux9k2_ram arm arm920t eb_cpux9k2 BuS at91 eb_cpux9k2:RAMBOOT -cpuat91 arm arm920t cpuat91 eukrea at91 cpuat91 -cpuat91_ram arm arm920t cpuat91 eukrea at91 cpuat91:RAMBOOT -mx1ads arm arm920t - - imx -scb9328 arm arm920t - - imx -cm4008 arm arm920t - - ks8695 -cm41xx arm arm920t - - ks8695 -mini2440 arm arm920t mini2440 friendlyarm s3c24x0 -VCMA9 arm arm920t vcma9 mpl s3c24x0 -smdk2410 arm arm920t - samsung s3c24x0 -omap1510inn arm arm925t - ti -integratorap_cm926ejs arm arm926ejs integrator armltd - integratorap:CM926EJ_S -integratorcp_cm926ejs arm arm926ejs integrator armltd - integratorcp:CM924EJ_S -aspenite arm arm926ejs - Marvell armada100 -gplugd arm arm926ejs - Marvell armada100 -afeb9260 arm arm926ejs - - at91 -at91sam9260ek_dataflash_cs0 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9260,SYS_USE_DATAFLASH_CS0 -at91sam9260ek_dataflash_cs1 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9260,SYS_USE_DATAFLASH_CS1 -at91sam9260ek_nandflash arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9260,SYS_USE_NANDFLASH -at91sam9261ek_dataflash_cs0 arm arm926ejs at91sam9261ek atmel at91 at91sam9261ek:AT91SAM9261,SYS_USE_DATAFLASH_CS0 -at91sam9261ek_dataflash_cs3 arm arm926ejs at91sam9261ek atmel at91 at91sam9261ek:AT91SAM9261,SYS_USE_DATAFLASH_CS3 -at91sam9261ek_nandflash arm arm926ejs at91sam9261ek atmel at91 at91sam9261ek:AT91SAM9261,SYS_USE_NANDFLASH -at91sam9263ek_dataflash arm arm926ejs at91sam9263ek atmel at91 at91sam9263ek:AT91SAM9263,SYS_USE_DATAFLASH -at91sam9263ek_dataflash_cs0 arm arm926ejs at91sam9263ek atmel at91 at91sam9263ek:AT91SAM9263,SYS_USE_DATAFLASH -at91sam9263ek_nandflash arm arm926ejs at91sam9263ek atmel at91 at91sam9263ek:AT91SAM9263,SYS_USE_NANDFLASH -at91sam9263ek_norflash arm arm926ejs at91sam9263ek atmel at91 at91sam9263ek:AT91SAM9263,SYS_USE_NORFLASH -at91sam9263ek_norflash_boot arm arm926ejs at91sam9263ek atmel at91 at91sam9263ek:AT91SAM9263,SYS_USE_BOOT_NORFLASH -at91sam9g10ek_dataflash_cs0 arm arm926ejs at91sam9261ek atmel at91 at91sam9261ek:AT91SAM9G10,SYS_USE_DATAFLASH_CS0 -at91sam9g10ek_dataflash_cs3 arm arm926ejs at91sam9261ek atmel at91 at91sam9261ek:AT91SAM9G10,SYS_USE_DATAFLASH_CS3 -at91sam9g10ek_nandflash arm arm926ejs at91sam9261ek atmel at91 at91sam9261ek:AT91SAM9G10,SYS_USE_NANDFLASH -at91sam9g20ek_dataflash_cs0 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9G20,SYS_USE_DATAFLASH_CS0 -at91sam9g20ek_dataflash_cs1 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9G20,SYS_USE_DATAFLASH_CS1 -at91sam9g20ek_mmc arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9G20,SYS_USE_MMC -at91sam9g20ek_nandflash arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9G20,SYS_USE_NANDFLASH -at91sam9g20ek_2mmc_nandflash arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9G20,AT91SAM9G20EK_2MMC,SYS_USE_NANDFLASH -at91sam9m10g45ek_nandflash arm arm926ejs at91sam9m10g45ek atmel at91 at91sam9m10g45ek:AT91SAM9M10G45,SYS_USE_NANDFLASH -at91sam9rlek_dataflash arm arm926ejs at91sam9rlek atmel at91 at91sam9rlek:AT91SAM9RL,SYS_USE_DATAFLASH -at91sam9rlek_nandflash arm arm926ejs at91sam9rlek atmel at91 at91sam9rlek:AT91SAM9RL,SYS_USE_NANDFLASH -at91sam9x5ek_nandflash arm arm926ejs at91sam9x5ek atmel at91 at91sam9x5ek:AT91SAM9X5,SYS_USE_NANDFLASH -at91sam9x5ek_dataflash arm arm926ejs at91sam9x5ek atmel at91 at91sam9x5ek:AT91SAM9X5,SYS_USE_DATAFLASH -at91sam9x5ek_spiflash arm arm926ejs at91sam9x5ek atmel at91 at91sam9x5ek:AT91SAM9X5,SYS_USE_SPIFLASH -at91sam9x5ek_mmc arm arm926ejs at91sam9x5ek atmel at91 at91sam9x5ek:AT91SAM9X5,SYS_USE_MMC -at91sam9xeek_dataflash_cs0 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9XE,SYS_USE_DATAFLASH_CS0 -at91sam9xeek_dataflash_cs1 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9XE,SYS_USE_DATAFLASH_CS1 -at91sam9xeek_nandflash arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9XE,SYS_USE_NANDFLASH -at91sam9n12ek_nandflash arm arm926ejs at91sam9n12ek atmel at91 at91sam9n12ek:AT91SAM9N12,SYS_USE_NANDFLASH -at91sam9n12ek_spiflash arm arm926ejs at91sam9n12ek atmel at91 at91sam9n12ek:AT91SAM9N12,SYS_USE_SPIFLASH -at91sam9n12ek_mmc arm arm926ejs at91sam9n12ek atmel at91 at91sam9n12ek:AT91SAM9N12,SYS_USE_MMC -snapper9260 arm arm926ejs - bluewater at91 snapper9260:AT91SAM9260 -snapper9g20 arm arm926ejs snapper9260 bluewater at91 snapper9260:AT91SAM9G20 -vl_ma2sc arm arm926ejs vl_ma2sc BuS at91 -vl_ma2sc_ram arm arm926ejs vl_ma2sc BuS at91 vl_ma2sc:RAMLOAD -sbc35_a9g20_eeprom arm arm926ejs sbc35_a9g20 calao at91 sbc35_a9g20:AT91SAM9G20,SYS_USE_EEPROM -sbc35_a9g20_nandflash arm arm926ejs sbc35_a9g20 calao at91 sbc35_a9g20:AT91SAM9G20,SYS_USE_NANDFLASH -tny_a9260_eeprom arm arm926ejs tny_a9260 calao at91 tny_a9260:AT91SAM9260,SYS_USE_EEPROM -tny_a9260_nandflash arm arm926ejs tny_a9260 calao at91 tny_a9260:AT91SAM9260,SYS_USE_NANDFLASH -tny_a9g20_eeprom arm arm926ejs tny_a9260 calao at91 tny_a9260:AT91SAM9G20,SYS_USE_EEPROM -tny_a9g20_nandflash arm arm926ejs tny_a9260 calao at91 tny_a9260:AT91SAM9G20,SYS_USE_NANDFLASH -ethernut5 arm arm926ejs ethernut5 egnite at91 ethernut5:AT91SAM9XE -top9000eval_xe arm arm926ejs top9000 emk at91 top9000:EVAL9000 -top9000su_xe arm arm926ejs top9000 emk at91 top9000:SU9000 -meesc arm arm926ejs meesc esd at91 meesc:AT91SAM9263,SYS_USE_NANDFLASH -meesc_dataflash arm arm926ejs meesc esd at91 meesc:AT91SAM9263,SYS_USE_DATAFLASH -otc570 arm arm926ejs otc570 esd at91 otc570:AT91SAM9263,SYS_USE_NANDFLASH -otc570_dataflash arm arm926ejs otc570 esd at91 otc570:AT91SAM9263,SYS_USE_DATAFLASH -cpu9260 arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9260 -cpu9260_128M arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9260,CPU9260_128M -cpu9260_nand arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9260,NANDBOOT -cpu9260_nand_128M arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9260,CPU9260_128M,NANDBOOT -cpu9G20 arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9G20 -cpu9G20_128M arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9G20,CPU9G20_128M -cpu9G20_nand arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9G20,NANDBOOT -cpu9G20_nand_128M arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9G20,CPU9G20_128M,NANDBOOT -pm9261 arm arm926ejs pm9261 ronetix at91 pm9261:AT91SAM9261 -pm9263 arm arm926ejs pm9263 ronetix at91 pm9263:AT91SAM9263 -pm9g45 arm arm926ejs pm9g45 ronetix at91 pm9g45:AT91SAM9G45 -portuxg20 arm arm926ejs stamp9g20 taskit at91 stamp9g20:AT91SAM9G20,PORTUXG20 -stamp9g20 arm arm926ejs stamp9g20 taskit at91 stamp9g20:AT91SAM9G20 -cam_enc_4xx arm arm926ejs cam_enc_4xx ait davinci cam_enc_4xx -ipam390 arm arm926ejs ipam390 Barix davinci -da830evm arm arm926ejs da8xxevm davinci davinci -da850_am18xxevm arm arm926ejs da8xxevm davinci davinci da850evm:DA850_AM18X_EVM,MAC_ADDR_IN_EEPROM,SYS_I2C_EEPROM_ADDR_LEN=2,SYS_I2C_EEPROM_ADDR=0x50 -da850evm arm arm926ejs da8xxevm davinci davinci da850evm:MAC_ADDR_IN_SPIFLASH -da850evm_direct_nor arm arm926ejs da8xxevm davinci davinci da850evm:MAC_ADDR_IN_SPIFLASH,USE_NOR,DIRECT_NOR_BOOT -davinci_dm355evm arm arm926ejs dm355evm davinci davinci -davinci_dm355leopard arm arm926ejs dm355leopard davinci davinci -davinci_dm365evm arm arm926ejs dm365evm davinci davinci -davinci_dm6467evm arm arm926ejs dm6467evm davinci davinci davinci_dm6467evm:REFCLK_FREQ=27000000 -davinci_dm6467Tevm arm arm926ejs dm6467evm davinci davinci davinci_dm6467evm:DAVINCI_DM6467TEVM,REFCLK_FREQ=33000000 -davinci_dvevm arm arm926ejs dvevm davinci davinci -davinci_schmoogie arm arm926ejs schmoogie davinci davinci -davinci_sffsdr arm arm926ejs sffsdr davinci davinci -davinci_sonata arm arm926ejs sonata davinci davinci -ea20 arm arm926ejs ea20 davinci davinci -hawkboard arm arm926ejs da8xxevm davinci davinci -hawkboard_uart arm arm926ejs da8xxevm davinci davinci hawkboard:UART_U_BOOT -enbw_cmc arm arm926ejs enbw_cmc enbw davinci -calimain arm arm926ejs calimain omicron davinci -pogo_e02 arm arm926ejs - cloudengines kirkwood -dns325 arm arm926ejs - d-link kirkwood -iconnect arm arm926ejs - iomega kirkwood -lschlv2 arm arm926ejs lsxl buffalo kirkwood lsxl:LSCHLV2 -lsxhl arm arm926ejs lsxl buffalo kirkwood lsxl:LSXHL -km_kirkwood arm arm926ejs km_arm keymile kirkwood km_kirkwood:KM_KIRKWOOD -km_kirkwood_pci arm arm926ejs km_arm keymile kirkwood km_kirkwood:KM_KIRKWOOD_PCI -kmnusa arm arm926ejs km_arm keymile kirkwood km_kirkwood:KM_NUSA -kmsuv31 arm arm926ejs km_arm keymile kirkwood km_kirkwood:KM_SUV31 -mgcoge3un arm arm926ejs km_arm keymile kirkwood km_kirkwood:KM_MGCOGE3UN -kmcoge5un arm arm926ejs km_arm keymile kirkwood km_kirkwood:KM_COGE5UN -portl2 arm arm926ejs km_arm keymile kirkwood km_kirkwood:KM_PORTL2 -d2net_v2 arm arm926ejs net2big_v2 LaCie kirkwood lacie_kw:D2NET_V2 -inetspace_v2 arm arm926ejs netspace_v2 LaCie kirkwood lacie_kw:INETSPACE_V2 -net2big_v2 arm arm926ejs net2big_v2 LaCie kirkwood lacie_kw:NET2BIG_V2 -netspace_lite_v2 arm arm926ejs netspace_v2 LaCie kirkwood lacie_kw:NETSPACE_LITE_V2 -netspace_max_v2 arm arm926ejs netspace_v2 LaCie kirkwood lacie_kw:NETSPACE_MAX_V2 -netspace_mini_v2 arm arm926ejs netspace_v2 LaCie kirkwood lacie_kw:NETSPACE_MINI_V2 -netspace_v2 arm arm926ejs netspace_v2 LaCie kirkwood lacie_kw:NETSPACE_V2 -wireless_space arm arm926ejs wireless_space LaCie kirkwood -dreamplug arm arm926ejs - Marvell kirkwood -guruplug arm arm926ejs - Marvell kirkwood -mv88f6281gtw_ge arm arm926ejs - Marvell kirkwood -openrd_base arm arm926ejs openrd Marvell kirkwood openrd:BOARD_IS_OPENRD_BASE -openrd_client arm arm926ejs openrd Marvell kirkwood openrd:BOARD_IS_OPENRD_CLIENT -openrd_ultimate arm arm926ejs openrd Marvell kirkwood openrd:BOARD_IS_OPENRD_ULTIMATE -rd6281a arm arm926ejs - Marvell kirkwood -sheevaplug arm arm926ejs - Marvell kirkwood -ib62x0 arm arm926ejs ib62x0 raidsonic kirkwood -dockstar arm arm926ejs - Seagate kirkwood -goflexhome arm arm926ejs - Seagate kirkwood -tk71 arm arm926ejs tk71 karo kirkwood -devkit3250 arm arm926ejs devkit3250 timll lpc32xx -jadecpu arm arm926ejs jadecpu syteco mb86r0x -mx25pdk arm arm926ejs mx25pdk freescale mx25 mx25pdk:IMX_CONFIG=board/freescale/mx25pdk/imximage.cfg -tx25 arm arm926ejs tx25 karo mx25 -zmx25 arm arm926ejs zmx25 syteco mx25 -imx27lite arm arm926ejs imx27lite logicpd mx27 -magnesium arm arm926ejs imx27lite logicpd mx27 -mx23_olinuxino arm arm926ejs mx23_olinuxino olimex mxs mx23_olinuxino -apx4devkit arm arm926ejs apx4devkit bluegiga mxs apx4devkit -mx23evk arm arm926ejs mx23evk freescale mxs mx23evk -m28evk arm arm926ejs m28evk denx mxs m28evk -mx28evk arm arm926ejs mx28evk freescale mxs mx28evk:ENV_IS_IN_MMC -mx28evk_nand arm arm926ejs mx28evk freescale mxs mx28evk:ENV_IS_IN_NAND -mx28evk_auart_console arm arm926ejs mx28evk freescale mxs mx28evk:MXS_AUART,MXS_AUART_BASE=MXS_UARTAPP3_BASE,ENV_IS_IN_MMC -sc_sps_1 arm arm926ejs sc_sps_1 schulercontrol mxs -nhk8815 arm arm926ejs nhk8815 st nomadik -nhk8815_onenand arm arm926ejs nhk8815 st nomadik nhk8815:BOOT_ONENAND -omap5912osk arm arm926ejs - ti omap -omap730p2 arm arm926ejs omap730p2 ti omap omap730p2:CS3_BOOT -omap730p2_cs0boot arm arm926ejs omap730p2 ti omap omap730p2:CS0_BOOT -omap730p2_cs3boot arm arm926ejs omap730p2 ti omap omap730p2:CS3_BOOT -edminiv2 arm arm926ejs - LaCie orion5x -dkb arm arm926ejs - Marvell pantheon -spear300 arm arm926ejs spear300 spear spear spear3xx_evb:spear300 -spear300_nand arm arm926ejs spear300 spear spear spear3xx_evb:spear300,nand -spear300_usbtty arm arm926ejs spear300 spear spear spear3xx_evb:spear300,usbtty -spear300_usbtty_nand arm arm926ejs spear300 spear spear spear3xx_evb:spear300,usbtty,nand -spear310 arm arm926ejs spear310 spear spear spear3xx_evb:spear310 -spear310_pnor arm arm926ejs spear310 spear spear spear3xx_evb:spear310,FLASH_PNOR -spear310_nand arm arm926ejs spear310 spear spear spear3xx_evb:spear310,nand -spear310_usbtty arm arm926ejs spear310 spear spear spear3xx_evb:spear310,usbtty -spear310_usbtty_pnor arm arm926ejs spear310 spear spear spear3xx_evb:spear310,usbtty,FLASH_PNOR -spear310_usbtty_nand arm arm926ejs spear310 spear spear spear3xx_evb:spear310,usbtty,nand -spear320 arm arm926ejs spear320 spear spear spear3xx_evb:spear320 -spear320_pnor arm arm926ejs spear320 spear spear spear3xx_evb:spear320,FLASH_PNOR -spear320_nand arm arm926ejs spear320 spear spear spear3xx_evb:spear320,nand -spear320_usbtty arm arm926ejs spear320 spear spear spear3xx_evb:spear320,usbtty -spear320_usbtty_pnor arm arm926ejs spear320 spear spear spear3xx_evb:spear320,usbtty,FLASH_PNOR -spear320_usbtty_nand arm arm926ejs spear320 spear spear spear3xx_evb:spear320,usbtty,nand -spear600 arm arm926ejs spear600 spear spear spear6xx_evb:spear600 -spear600_nand arm arm926ejs spear600 spear spear spear6xx_evb:spear600,nand -spear600_usbtty arm arm926ejs spear600 spear spear spear6xx_evb:spear600,usbtty -spear600_usbtty_nand arm arm926ejs spear600 spear spear spear6xx_evb:spear600,usbtty,nand -x600 arm arm926ejs - spear spear x600 -versatileab arm arm926ejs versatile armltd versatile versatile:ARCH_VERSATILE_AB -versatilepb arm arm926ejs versatile armltd versatile versatile:ARCH_VERSATILE_PB -versatileqemu arm arm926ejs versatile armltd versatile versatile:ARCH_VERSATILE_QEMU,ARCH_VERSATILE_PB -integratorap_cm946es arm arm946es integrator armltd - integratorap:CM946ES -integratorcp_cm946es arm arm946es integrator armltd - integratorcp:CM946ES -vexpress_ca15_tc2 arm armv7 vexpress armltd -vexpress_ca5x2 arm armv7 vexpress armltd -vexpress_ca9x4 arm armv7 vexpress armltd -am335x_evm arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,NAND -am335x_evm_nor arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,NAND,NOR -am335x_evm_norboot arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,NOR,NOR_BOOT -am335x_evm_spiboot arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,SPI_BOOT -am335x_evm_uart1 arm armv7 am335x ti am33xx am335x_evm:SERIAL2,CONS_INDEX=1,NAND -am335x_evm_uart2 arm armv7 am335x ti am33xx am335x_evm:SERIAL3,CONS_INDEX=1,NAND -am335x_evm_uart3 arm armv7 am335x ti am33xx am335x_evm:SERIAL4,CONS_INDEX=1,NAND -am335x_evm_uart4 arm armv7 am335x ti am33xx am335x_evm:SERIAL5,CONS_INDEX=1,NAND -am335x_evm_uart5 arm armv7 am335x ti am33xx am335x_evm:SERIAL6,CONS_INDEX=1,NAND -am335x_evm_usbspl arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,NAND,SPL_USBETH_SUPPORT -am335x_boneblack arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,EMMC_BOOT -am43xx_evm arm armv7 am43xx ti am33xx am43xx_evm:SERIAL1,CONS_INDEX=1 -dxr2 arm armv7 dxr2 siemens am33xx -pxm2 arm armv7 pxm2 siemens am33xx -rut arm armv7 rut siemens am33xx -ti814x_evm arm armv7 ti814x ti am33xx -ti816x_evm arm armv7 ti816x ti am33xx -pcm051 arm armv7 pcm051 phytec am33xx pcm051 -sama5d3xek_mmc arm armv7 sama5d3xek atmel at91 sama5d3xek:SAMA5D3,SYS_USE_MMC -sama5d3xek_nandflash arm armv7 sama5d3xek atmel at91 sama5d3xek:SAMA5D3,SYS_USE_NANDFLASH -sama5d3xek_spiflash arm armv7 sama5d3xek atmel at91 sama5d3xek:SAMA5D3,SYS_USE_SERIALFLASH -highbank arm armv7 highbank - highbank -m53evk arm armv7 m53evk denx mx5 m53evk:IMX_CONFIG=board/denx/m53evk/imximage.cfg -mx51_efikamx arm armv7 mx51_efikamx genesi mx5 mx51_efikamx:MACH_TYPE=MACH_TYPE_MX51_EFIKAMX,IMX_CONFIG=board/genesi/mx51_efikamx/imximage_mx.cfg -mx51_efikasb arm armv7 mx51_efikamx genesi mx5 mx51_efikamx:MACH_TYPE=MACH_TYPE_MX51_EFIKASB,IMX_CONFIG=board/genesi/mx51_efikamx/imximage_sb.cfg -mx51evk arm armv7 mx51evk freescale mx5 mx51evk:IMX_CONFIG=board/freescale/mx51evk/imximage.cfg -mx53ard arm armv7 mx53ard freescale mx5 mx53ard:IMX_CONFIG=board/freescale/mx53ard/imximage_dd3.cfg -mx53evk arm armv7 mx53evk freescale mx5 mx53evk:IMX_CONFIG=board/freescale/mx53evk/imximage.cfg -mx53loco arm armv7 mx53loco freescale mx5 mx53loco:IMX_CONFIG=board/freescale/mx53loco/imximage.cfg -mx53smd arm armv7 mx53smd freescale mx5 mx53smd:IMX_CONFIG=board/freescale/mx53smd/imximage.cfg -ima3-mx53 arm armv7 ima3-mx53 esg mx5 ima3-mx53:IMX_CONFIG=board/esg/ima3-mx53/imximage.cfg -vision2 arm armv7 vision2 ttcontrol mx5 vision2:IMX_CONFIG=board/ttcontrol/vision2/imximage_hynix.cfg -cgtqmx6qeval arm armv7 cgtqmx6eval congatec mx6 cgtqmx6eval:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg,MX6Q -mx6qarm2 arm armv7 mx6qarm2 freescale mx6 mx6qarm2:IMX_CONFIG=board/freescale/mx6qarm2/imximage.cfg -mx6qsabreauto arm armv7 mx6qsabreauto freescale mx6 mx6qsabreauto:IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg,MX6Q -mx6qsabrelite arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,SABRELITE -mx6dlsabresd arm armv7 mx6sabresd freescale mx6 mx6sabresd:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL -mx6qsabresd arm armv7 mx6sabresd freescale mx6 mx6sabresd:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg,MX6Q -mx6slevk arm armv7 mx6slevk freescale mx6 mx6slevk:IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL -titanium arm armv7 titanium freescale mx6 titanium:IMX_CONFIG=board/freescale/titanium/imximage.cfg -vf610twr arm armv7 vf610twr freescale vf610 vf610twr:IMX_CONFIG=board/freescale/vf610twr/imximage.cfg -eco5pk arm armv7 eco5pk 8dtech omap3 -nitrogen6dl arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024 -nitrogen6dl2g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg,MX6DL,DDR_MB=2048 -nitrogen6q arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024 -nitrogen6q2g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048 -nitrogen6s arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512 -nitrogen6s1g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024 -wandboard_dl arm armv7 wandboard - mx6 wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024 -wandboard_quad arm armv7 wandboard - mx6 wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048 -wandboard_solo arm armv7 wandboard - mx6 wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512 -omap3_overo arm armv7 overo - omap3 -omap3_pandora arm armv7 pandora - omap3 -dig297 arm armv7 dig297 comelit omap3 -cm_t35 arm armv7 cm_t35 compulab omap3 -igep0020 arm armv7 igep00x0 isee omap3 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0020,BOOT_ONENAND -igep0020_nand arm armv7 igep00x0 isee omap3 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0020,BOOT_NAND -igep0030 arm armv7 igep00x0 isee omap3 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_ONENAND -igep0030_nand arm armv7 igep00x0 isee omap3 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_NAND -igep0032 arm armv7 igep00x0 isee omap3 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0032,BOOT_ONENAND -igep0033 arm armv7 igep0033 isee am33xx -am3517_evm arm armv7 am3517evm logicpd omap3 -mt_ventoux arm armv7 mt_ventoux teejet omap3 -omap3_zoom1 arm armv7 zoom1 logicpd omap3 -omap3_zoom2 arm armv7 zoom2 logicpd omap3 -omap3_logic arm armv7 omap3som logicpd omap3 -omap3_mvblx arm armv7 mvblx matrix_vision omap3 -am3517_crane arm armv7 am3517crane ti omap3 -omap3_beagle arm armv7 beagle ti omap3 -omap3_evm arm armv7 evm ti omap3 -omap3_evm_quick_mmc arm armv7 evm ti omap3 -omap3_evm_quick_nand arm armv7 evm ti omap3 -omap3_sdp3430 arm armv7 sdp3430 ti omap3 -devkit8000 arm armv7 devkit8000 timll omap3 -mcx arm armv7 mcx htkw omap3 -tricorder arm armv7 tricorder corscience omap3 -twister arm armv7 twister technexion omap3 -nokia_rx51 arm armv7 rx51 nokia omap3 -omap4_panda arm armv7 panda ti omap4 -omap4_sdp4430 arm armv7 sdp4430 ti omap4 -omap5_uevm arm armv7 omap5_uevm ti omap5 -dra7xx_evm arm armv7 dra7xx ti omap5 -s5p_goni arm armv7 goni samsung s5pc1xx -smdkc100 arm armv7 smdkc100 samsung s5pc1xx -arndale arm armv7 arndale samsung exynos -origen arm armv7 origen samsung exynos -s5pc210_universal arm armv7 universal_c210 samsung exynos -snow arm armv7 smdk5250 samsung exynos -smdk5250 arm armv7 smdk5250 samsung exynos -smdkv310 arm armv7 smdkv310 samsung exynos -trats arm armv7 trats samsung exynos -harmony arm armv7:arm720t harmony nvidia tegra20 -seaboard arm armv7:arm720t seaboard nvidia tegra20 -ventana arm armv7:arm720t ventana nvidia tegra20 -whistler arm armv7:arm720t whistler nvidia tegra20 -cardhu arm armv7:arm720t cardhu nvidia tegra30 -beaver arm armv7:arm720t beaver nvidia tegra30 -dalmore arm armv7:arm720t dalmore nvidia tegra114 -colibri_t20_iris arm armv7:arm720t colibri_t20_iris toradex tegra20 -u8500_href arm armv7 u8500 st-ericsson u8500 -snowball arm armv7 snowball st-ericsson u8500 -kzm9g arm armv7 kzm9g kmc rmobile -armadillo-800eva arm armv7 armadillo-800eva atmark-techno rmobile -zynq arm armv7 zynq xilinx zynq -zynq_dcc arm armv7 zynq xilinx zynq zynq:ZYNQ_DCC -socfpga_cyclone5 arm armv7 socfpga altera socfpga -actux1_4_16 arm ixp actux1 - - actux1:FLASH2X2 -actux1_4_32 arm ixp actux1 - - actux1:FLASH2X2,RAM_32MB -actux1_8_16 arm ixp actux1 - - actux1:FLASH1X8 -actux1_8_32 arm ixp actux1 - - actux1:FLASH1X8,RAM_32MB -actux2 arm ixp -actux3 arm ixp -actux4 arm ixp -dvlhost arm ixp -pdnb3 arm ixp pdnb3 prodrive -scpu arm ixp pdnb3 prodrive - pdnb3:SCPU -balloon3 arm pxa -h2200 arm pxa -lp8x4x arm pxa lp8x4x icpdas -lubbock arm pxa -palmld arm pxa -palmtc arm pxa -palmtreo680 arm pxa -polaris arm pxa trizepsiv - - trizepsiv:POLARIS -pxa255_idp arm pxa -trizepsiv arm pxa -vpac270_nor_128 arm pxa vpac270 - - vpac270:NOR,RAM_128M -vpac270_nor_256 arm pxa vpac270 - - vpac270:NOR,RAM_256M -vpac270_ond_256 arm pxa vpac270 - - vpac270:ONENAND,RAM_256M -xaeniax arm pxa -zipitz2 arm pxa -colibri_pxa270 arm pxa - toradex -jornada arm sa1100 -plutux arm armv7:arm720t plutux avionic-design tegra20 -medcom-wide arm armv7:arm720t medcom-wide avionic-design tegra20 -tec arm armv7:arm720t tec avionic-design tegra20 -paz00 arm armv7:arm720t paz00 compal tegra20 -trimslice arm armv7:arm720t trimslice compulab tegra20 -atngw100 avr32 at32ap - atmel at32ap700x -atngw100mkii avr32 at32ap - atmel at32ap700x -atstk1002 avr32 at32ap atstk1000 atmel at32ap700x -atstk1003 avr32 at32ap atstk1000 atmel at32ap700x -atstk1004 avr32 at32ap atstk1000 atmel at32ap700x -atstk1006 avr32 at32ap atstk1000 atmel at32ap700x -favr-32-ezkit avr32 at32ap - earthlcd at32ap700x -grasshopper avr32 at32ap - in-circuit at32ap700x -mimc200 avr32 at32ap - mimc at32ap700x -hammerhead avr32 at32ap - miromico at32ap700x -bct-brettl2 blackfin blackfin -bf506f-ezkit blackfin blackfin -bf518f-ezbrd blackfin blackfin -bf525-ucr2 blackfin blackfin -bf526-ezbrd blackfin blackfin -bf527-ad7160-eval blackfin blackfin -bf527-ezkit blackfin blackfin -bf527-ezkit-v2 blackfin blackfin bf527-ezkit - - bf527-ezkit:BF527_EZKIT_REV_2_1 -bf527-sdp blackfin blackfin -bf533-ezkit blackfin blackfin -bf533-stamp blackfin blackfin -bf537-minotaur blackfin blackfin -bf537-pnav blackfin blackfin -bf537-srv1 blackfin blackfin -bf537-stamp blackfin blackfin -bf538f-ezkit blackfin blackfin -bf548-ezkit blackfin blackfin -bf561-acvilon blackfin blackfin -bf561-ezkit blackfin blackfin -bf609-ezkit blackfin blackfin -blackstamp blackfin blackfin -blackvme blackfin blackfin -br4 blackfin blackfin -cm-bf527 blackfin blackfin -cm-bf533 blackfin blackfin -cm-bf537e blackfin blackfin -cm-bf537u blackfin blackfin -cm-bf548 blackfin blackfin -cm-bf561 blackfin blackfin -dnp5370 blackfin blackfin -ibf-dsp561 blackfin blackfin -ip04 blackfin blackfin -pr1 blackfin blackfin -tcm-bf518 blackfin blackfin -tcm-bf537 blackfin blackfin -M52277EVB m68k mcf5227x m52277evb freescale - M52277EVB:SYS_SPANSION_BOOT,SYS_TEXT_BASE=0x00000000 -M52277EVB_stmicro m68k mcf5227x m52277evb freescale - M52277EVB:CF_SBF,SYS_STMICRO_BOOT,SYS_TEXT_BASE=0x43E00000 -M5235EVB m68k mcf523x m5235evb freescale - M5235EVB:SYS_TEXT_BASE=0xFFE00000 -M5235EVB_Flash32 m68k mcf523x m5235evb freescale - M5235EVB:NORFLASH_PS32BIT,SYS_TEXT_BASE=0xFFC00000 -cobra5272 m68k mcf52x2 cobra5272 - -idmr m68k mcf52x2 -eb_cpu5282 m68k mcf52x2 eb_cpu5282 BuS - eb_cpu5282:SYS_TEXT_BASE=0xFF000000,SYS_MONITOR_BASE=0xFF000400 -eb_cpu5282_internal m68k mcf52x2 eb_cpu5282 BuS - eb_cpu5282:SYS_TEXT_BASE=0xF0000000,SYS_MONITOR_BASE=0xF0000418 -TASREG m68k mcf52x2 tasreg esd -M5208EVBE m68k mcf52x2 m5208evbe freescale -M5249EVB m68k mcf52x2 m5249evb freescale -M5253DEMO m68k mcf52x2 m5253demo freescale -M5253EVBE m68k mcf52x2 m5253evbe freescale -M5271EVB m68k mcf52x2 m5271evb freescale -M5272C3 m68k mcf52x2 m5272c3 freescale -M5275EVB m68k mcf52x2 m5275evb freescale -M5282EVB m68k mcf52x2 m5282evb freescale -astro_mcf5373l m68k mcf532x mcf5373l astro -M53017EVB m68k mcf532x m53017evb freescale -M5329AFEE m68k mcf532x m5329evb freescale - M5329EVB:NANDFLASH_SIZE=0 -M5329BFEE m68k mcf532x m5329evb freescale - M5329EVB:NANDFLASH_SIZE=16 -M5373EVB m68k mcf532x m5373evb freescale - M5373EVB:NANDFLASH_SIZE=16 -M54418TWR m68k mcf5445x m54418twr freescale - M54418TWR:CF_SBF,SYS_SERIAL_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=50000000 -M54418TWR_nand_mii m68k mcf5445x m54418twr freescale - M54418TWR:SYS_NAND_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=25000000 -M54418TWR_nand_rmii m68k mcf5445x m54418twr freescale - M54418TWR:SYS_NAND_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=50000000 -M54418TWR_nand_rmii_lowfreq m68k mcf5445x m54418twr freescale - M54418TWR:SYS_NAND_BOOT,LOW_MCFCLK,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=50000000 -M54418TWR_serial_mii m68k mcf5445x m54418twr freescale - M54418TWR:CF_SBF,SYS_SERIAL_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=25000000 -M54418TWR_serial_rmii m68k mcf5445x m54418twr freescale - M54418TWR:CF_SBF,SYS_SERIAL_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=50000000 -M54451EVB m68k mcf5445x m54451evb freescale - M54451EVB:SYS_TEXT_BASE=0x00000000,SYS_INPUT_CLKSRC=24000000 -M54451EVB_stmicro m68k mcf5445x m54451evb freescale - M54451EVB:CF_SBF,SYS_STMICRO_BOOT,SYS_TEXT_BASE=0x47e00000,SYS_INPUT_CLKSRC=24000000 -M54455EVB m68k mcf5445x m54455evb freescale - M54455EVB:SYS_ATMEL_BOOT,SYS_TEXT_BASE=0x04000000,SYS_INPUT_CLKSRC=33333333 -M54455EVB_a66 m68k mcf5445x m54455evb freescale - M54455EVB:SYS_ATMEL_BOOT,SYS_TEXT_BASE=0x04000000,SYS_INPUT_CLKSRC=66666666 -M54455EVB_i66 m68k mcf5445x m54455evb freescale - M54455EVB:SYS_INTEL_BOOT,SYS_TEXT_BASE=0x00000000,SYS_INPUT_CLKSRC=66666666 -M54455EVB_intel m68k mcf5445x m54455evb freescale - M54455EVB:SYS_INTEL_BOOT,SYS_TEXT_BASE=0x00000000,SYS_INPUT_CLKSRC=33333333 -M54455EVB_stm33 m68k mcf5445x m54455evb freescale - M54455EVB:SYS_STMICRO_BOOT,CF_SBF,SYS_TEXT_BASE=0x4FE00000,SYS_INPUT_CLKSRC=33333333 -M5475AFE m68k mcf547x_8x m547xevb freescale - M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64 -M5475BFE m68k mcf547x_8x m547xevb freescale - M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16 -M5475CFE m68k mcf547x_8x m547xevb freescale - M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16,SYS_VIDEO,SYS_USBCTRL -M5475DFE m68k mcf547x_8x m547xevb freescale - M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_USBCTRL -M5475EFE m68k mcf547x_8x m547xevb freescale - M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_VIDEO,SYS_USBCTRL -M5475FFE m68k mcf547x_8x m547xevb freescale - M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=32,SYS_VIDEO,SYS_USBCTRL,SYS_DRAMSZ1=64 -M5475GFE m68k mcf547x_8x m547xevb freescale - M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=4,SYS_DRAMSZ=64 -M5485AFE m68k mcf547x_8x m548xevb freescale - M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64 -M5485BFE m68k mcf547x_8x m548xevb freescale - M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16 -M5485CFE m68k mcf547x_8x m548xevb freescale - M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16,SYS_VIDEO,SYS_USBCTRL -M5485DFE m68k mcf547x_8x m548xevb freescale - M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_USBCTRL -M5485EFE m68k mcf547x_8x m548xevb freescale - M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_VIDEO,SYS_USBCTRL -M5485FFE m68k mcf547x_8x m548xevb freescale - M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=32,SYS_VIDEO,SYS_USBCTRL,SYS_DRAMSZ1=64 -M5485GFE m68k mcf547x_8x m548xevb freescale - M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=4,SYS_DRAMSZ=64 -M5485HFE m68k mcf547x_8x m548xevb freescale - M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16,SYS_VIDEO -microblaze-generic microblaze microblaze microblaze-generic xilinx -qemu_mips mips mips32 qemu-mips - - qemu-mips:SYS_BIG_ENDIAN -qemu_mipsel mips mips32 qemu-mips - - qemu-mips:SYS_LITTLE_ENDIAN -qemu_mips64 mips mips64 qemu-mips - - qemu-mips64:SYS_BIG_ENDIAN -qemu_mips64el mips mips64 qemu-mips - - qemu-mips64:SYS_LITTLE_ENDIAN -qemu_malta mips mips32 qemu-malta - - qemu-malta:MIPS32,SYS_BIG_ENDIAN -qemu_maltael mips mips32 qemu-malta - - qemu-malta:MIPS32,SYS_LITTLE_ENDIAN -vct_platinum mips mips32 vct micronas - vct:VCT_PLATINUM -vct_platinumavc mips mips32 vct micronas - vct:VCT_PLATINUMAVC -vct_platinumavc_onenand mips mips32 vct micronas - vct:VCT_PLATINUMAVC,VCT_ONENAND -vct_platinumavc_onenand_small mips mips32 vct micronas - vct:VCT_PLATINUMAVC,VCT_ONENAND,VCT_SMALL_IMAGE -vct_platinumavc_small mips mips32 vct micronas - vct:VCT_PLATINUMAVC,VCT_SMALL_IMAGE -vct_platinum_onenand mips mips32 vct micronas - vct:VCT_PLATINUM,VCT_ONENAND -vct_platinum_onenand_small mips mips32 vct micronas - vct:VCT_PLATINUM,VCT_ONENAND,VCT_SMALL_IMAGE -vct_platinum_small mips mips32 vct micronas - vct:VCT_PLATINUM,VCT_SMALL_IMAGE -vct_premium mips mips32 vct micronas - vct:VCT_PREMIUM -vct_premium_onenand mips mips32 vct micronas - vct:VCT_PREMIUM,VCT_ONENAND -vct_premium_onenand_small mips mips32 vct micronas - vct:VCT_PREMIUM,VCT_ONENAND,VCT_SMALL_IMAGE -vct_premium_small mips mips32 vct micronas - vct:VCT_PREMIUM,VCT_SMALL_IMAGE -dbau1000 mips mips32 dbau1x00 - au1x00 dbau1x00:DBAU1000 -dbau1100 mips mips32 dbau1x00 - au1x00 dbau1x00:DBAU1100 -dbau1500 mips mips32 dbau1x00 - au1x00 dbau1x00:DBAU1500 -dbau1550 mips mips32 dbau1x00 - au1x00 dbau1x00:DBAU1550 -dbau1550_el mips mips32 dbau1x00 - au1x00 dbau1x00:DBAU1550,SYS_LITTLE_ENDIAN -pb1000 mips mips32 pb1x00 - au1x00 pb1x00:PB1000 -incaip mips mips32 incaip - incaip -incaip_100MHz mips mips32 incaip - incaip incaip:CPU_CLOCK_RATE=100000000 -incaip_133MHz mips mips32 incaip - incaip incaip:CPU_CLOCK_RATE=133000000 -incaip_150MHz mips mips32 incaip - incaip incaip:CPU_CLOCK_RATE=150000000 -adp-ag101 nds32 n1213 adp-ag101 AndesTech ag101 -adp-ag101p nds32 n1213 adp-ag101p AndesTech ag101 -adp-ag102 nds32 n1213 adp-ag102 AndesTech ag102 -nios2-generic nios2 nios2 nios2-generic altera -PCI5441 nios2 nios2 pci5441 psyent -PK1C20 nios2 nios2 pk1c20 psyent -openrisc-generic openrisc or1200 openrisc-generic openrisc - -EVB64260 powerpc 74xx_7xx evb64260 - - EVB64260 -EVB64260_750CX powerpc 74xx_7xx evb64260 - - EVB64260 -P3G4 powerpc 74xx_7xx evb64260 -ppmc7xx powerpc 74xx_7xx -ZUMA powerpc 74xx_7xx evb64260 -ELPPC powerpc 74xx_7xx elppc eltec -CPCI750 powerpc 74xx_7xx cpci750 esd -mpc7448hpc2 powerpc 74xx_7xx mpc7448hpc2 freescale -DB64360 powerpc 74xx_7xx db64360 Marvell -DB64460 powerpc 74xx_7xx db64460 Marvell -p3m7448 powerpc 74xx_7xx p3mx prodrive - p3mx:P3M7448 -p3m750 powerpc 74xx_7xx p3mx prodrive - p3mx:P3M750 -pdm360ng powerpc mpc512x -aria powerpc mpc512x - davedenx -mecp5123 powerpc mpc512x - esd -mpc5121ads powerpc mpc512x mpc5121ads freescale -mpc5121ads_rev2 powerpc mpc512x mpc5121ads freescale - mpc5121ads:MPC5121ADS_REV2 -ac14xx powerpc mpc512x ac14xx ifm -cmi_mpc5xx powerpc mpc5xx cmi -PATI powerpc mpc5xx pati mpl -a3m071 powerpc mpc5xxx a3m071 -a4m072 powerpc mpc5xxx a4m072 -a4m2k powerpc mpc5xxx a3m071 - - a3m071:A4M2K -BC3450 powerpc mpc5xxx bc3450 -canmb powerpc mpc5xxx -cm5200 powerpc mpc5xxx -galaxy5200 powerpc mpc5xxx galaxy5200 - - galaxy5200:galaxy5200 -galaxy5200_LOWBOOT powerpc mpc5xxx galaxy5200 - - galaxy5200:galaxy5200_LOWBOOT -icecube_5200 powerpc mpc5xxx icecube - - IceCube -icecube_5200_DDR powerpc mpc5xxx icecube - - IceCube:MPC5200_DDR -icecube_5200_DDR_LOWBOOT powerpc mpc5xxx icecube - - IceCube:SYS_TEXT_BASE=0xFF800000,MPC5200_DDR -icecube_5200_DDR_LOWBOOT08 powerpc mpc5xxx icecube - - IceCube:SYS_TEXT_BASE=0xFF800000,MPC5200_DDR -icecube_5200_LOWBOOT powerpc mpc5xxx icecube - - IceCube:SYS_TEXT_BASE=0xFF000000 -icecube_5200_LOWBOOT08 powerpc mpc5xxx icecube - - IceCube:SYS_TEXT_BASE=0xFF800000 -inka4x0 powerpc mpc5xxx -ipek01 powerpc mpc5xxx -jupiter powerpc mpc5xxx -Lite5200 powerpc mpc5xxx icecube - - IceCube -lite5200b powerpc mpc5xxx icecube - - IceCube:MPC5200_DDR,LITE5200B -lite5200b_LOWBOOT powerpc mpc5xxx icecube - - IceCube:MPC5200_DDR,LITE5200B,SYS_TEXT_BASE=0xFF000000 -lite5200b_PM powerpc mpc5xxx icecube - - IceCube:MPC5200_DDR,LITE5200B,LITE5200B_PM -Lite5200_LOWBOOT powerpc mpc5xxx icecube - - IceCube:SYS_TEXT_BASE=0xFF000000 -Lite5200_LOWBOOT08 powerpc mpc5xxx icecube - - IceCube:SYS_TEXT_BASE=0xFF800000 -mcc200 powerpc mpc5xxx mcc200 - - mcc200 -mcc200_COM12 powerpc mpc5xxx mcc200 - - mcc200:CONSOLE_COM12 -mcc200_COM12_highboot powerpc mpc5xxx mcc200 - - mcc200:CONSOLE_COM12,SYS_TEXT_BASE=0xFFF00000 -mcc200_COM12_highboot_SDRAM powerpc mpc5xxx mcc200 - - mcc200:CONSOLE_COM12,SYS_TEXT_BASE=0xFFF00000,MCC200_SDRAM -mcc200_COM12_SDRAM powerpc mpc5xxx mcc200 - - mcc200:CONSOLE_COM12,MCC200_SDRAM -mcc200_highboot powerpc mpc5xxx mcc200 - - mcc200:SYS_TEXT_BASE=0xFFF00000 -mcc200_highboot_SDRAM powerpc mpc5xxx mcc200 - - mcc200:SYS_TEXT_BASE=0xFFF00000,MCC200_SDRAM -mcc200_SDRAM powerpc mpc5xxx mcc200 - - mcc200:MCC200_SDRAM -motionpro powerpc mpc5xxx -munices powerpc mpc5xxx -PM520 powerpc mpc5xxx pm520 -PM520_DDR powerpc mpc5xxx pm520 - - PM520:MPC5200_DDR -PM520_ROMBOOT powerpc mpc5xxx pm520 - - PM520:BOOT_ROM -PM520_ROMBOOT_DDR powerpc mpc5xxx pm520 - - PM520:MPC5200_DDR,BOOT_ROM -prs200 powerpc mpc5xxx mcc200 - - mcc200:PRS200,MCC200_SDRAM -prs200_DDR powerpc mpc5xxx mcc200 - - mcc200:PRS200 -prs200_highboot powerpc mpc5xxx mcc200 - - mcc200:PRS200,SYS_TEXT_BASE=0xFFF00000,MCC200_SDRAM -prs200_highboot_DDR powerpc mpc5xxx mcc200 - - mcc200:PRS200,SYS_TEXT_BASE=0xFFF00000 -Total5200 powerpc mpc5xxx total5200 - - Total5200:TOTAL5200_REV=1 -Total5200_lowboot powerpc mpc5xxx total5200 - - Total5200:TOTAL5200_REV=1,SYS_TEXT_BASE=0xFE000000 -Total5200_Rev2 powerpc mpc5xxx total5200 - - Total5200:TOTAL5200_REV=2 -Total5200_Rev2_lowboot powerpc mpc5xxx total5200 - - Total5200:TOTAL5200_REV=2,SYS_TEXT_BASE=0xFE000000 -v38b powerpc mpc5xxx -EVAL5200 powerpc mpc5xxx top5200 emk - TOP5200:EVAL5200 -MINI5200 powerpc mpc5xxx top5200 emk - TOP5200:MINI5200 -TOP5200 powerpc mpc5xxx top5200 emk - TOP5200:TOP5200 -cpci5200 powerpc mpc5xxx - esd -mecp5200 powerpc mpc5xxx - esd -pf5200 powerpc mpc5xxx - esd -O2D powerpc mpc5xxx o2dnt2 ifm - o2d -O2D300 powerpc mpc5xxx o2dnt2 ifm - o2d300 -O2DNT2 powerpc mpc5xxx o2dnt2 ifm - o2dnt2 -O2DNT2_RAMBOOT powerpc mpc5xxx o2dnt2 ifm - o2dnt2:SYS_TEXT_BASE=0x00100000 -O2I powerpc mpc5xxx o2dnt2 ifm - o2i -O2MNT powerpc mpc5xxx o2dnt2 ifm - o2mnt -O2MNT_O2M110 powerpc mpc5xxx o2dnt2 ifm - o2mnt:IFM_SENSOR_TYPE="O2M110" -O2MNT_O2M112 powerpc mpc5xxx o2dnt2 ifm - o2mnt:IFM_SENSOR_TYPE="O2M112" -O2MNT_O2M113 powerpc mpc5xxx o2dnt2 ifm - o2mnt:IFM_SENSOR_TYPE="O2M113" -O3DNT powerpc mpc5xxx o2dnt2 ifm - o3dnt -digsy_mtc powerpc mpc5xxx digsy_mtc intercontrol -digsy_mtc_RAMBOOT powerpc mpc5xxx digsy_mtc intercontrol - digsy_mtc:SYS_TEXT_BASE=0x00100000 -digsy_mtc_rev5 powerpc mpc5xxx digsy_mtc intercontrol - digsy_mtc:DIGSY_REV5 -digsy_mtc_rev5_RAMBOOT powerpc mpc5xxx digsy_mtc intercontrol - digsy_mtc:SYS_TEXT_BASE=0x00100000,DIGSY_REV5 -hmi1001 powerpc mpc5xxx - manroland -mucmc52 powerpc mpc5xxx - manroland -uc101 powerpc mpc5xxx - manroland -MVBC_P powerpc mpc5xxx mvbc_p matrix_vision - MVBC_P:MVBC_P -MVSMR powerpc mpc5xxx mvsmr matrix_vision -pcm030 powerpc mpc5xxx pcm030 phytec - pcm030 -pcm030_LOWBOOT powerpc mpc5xxx pcm030 phytec - pcm030:SYS_TEXT_BASE=0xFF000000 -aev powerpc mpc5xxx tqm5200 tqc -cam5200 powerpc mpc5xxx tqm5200 tqc - TQM5200:CAM5200,TQM5200S,TQM5200_B -cam5200_niosflash powerpc mpc5xxx tqm5200 tqc - TQM5200:CAM5200,TQM5200S,TQM5200_B,CAM5200_NIOSFLASH -charon powerpc mpc5xxx tqm5200 tqc - charon -fo300 powerpc mpc5xxx tqm5200 tqc - TQM5200:FO300 -MiniFAP powerpc mpc5xxx tqm5200 tqc - TQM5200:MINIFAP -TB5200 powerpc mpc5xxx tqm5200 tqc -TB5200_B powerpc mpc5xxx tqm5200 tqc - TB5200:TQM5200_B -TQM5200 powerpc mpc5xxx tqm5200 tqc - TQM5200: -TQM5200_B powerpc mpc5xxx tqm5200 tqc - TQM5200:TQM5200_B -TQM5200_B_HIGHBOOT powerpc mpc5xxx tqm5200 tqc - TQM5200:TQM5200_B,SYS_TEXT_BASE=0xFFF00000 -TQM5200S powerpc mpc5xxx tqm5200 tqc - TQM5200:TQM5200_B,TQM5200S -TQM5200S_HIGHBOOT powerpc mpc5xxx tqm5200 tqc - TQM5200:TQM5200_B,TQM5200S,SYS_TEXT_BASE=0xFFF00000 -TQM5200_STK100 powerpc mpc5xxx tqm5200 tqc - TQM5200:STK52XX_REV100 -A3000 powerpc mpc824x a3000 -CPC45 powerpc mpc824x cpc45 - - CPC45 -CPC45_ROMBOOT powerpc mpc824x cpc45 - - CPC45:BOOT_ROM -CU824 powerpc mpc824x cu824 -eXalion powerpc mpc824x eXalion -HIDDEN_DRAGON powerpc mpc824x hidden_dragon -linkstation_HGLAN powerpc mpc824x linkstation - - linkstation:HGLAN=1 -MOUSSE powerpc mpc824x mousse -MUSENKI powerpc mpc824x musenki -MVBLUE powerpc mpc824x mvblue -PN62 powerpc mpc824x pn62 -Sandpoint8240 powerpc mpc824x sandpoint -Sandpoint8245 powerpc mpc824x sandpoint -utx8245 powerpc mpc824x -debris powerpc mpc824x - etin -kvme080 powerpc mpc824x - etin -atc powerpc mpc8260 -cogent_mpc8260 powerpc mpc8260 cogent -CPU86 powerpc mpc8260 cpu86 - - CPU86 -CPU86_ROMBOOT powerpc mpc8260 cpu86 - - CPU86:BOOT_ROM -CPU87 powerpc mpc8260 cpu87 - - CPU87 -CPU87_ROMBOOT powerpc mpc8260 cpu87 - - CPU87:BOOT_ROM -ep8248 powerpc mpc8260 ep8248 -ep8248E powerpc mpc8260 ep8248 - - ep8248 -ep8260 powerpc mpc8260 -ep82xxm powerpc mpc8260 -gw8260 powerpc mpc8260 -hymod powerpc mpc8260 -IDS8247 powerpc mpc8260 ids8247 -IPHASE4539 powerpc mpc8260 iphase4539 -ISPAN powerpc mpc8260 ispan -ISPAN_REVB powerpc mpc8260 ispan - - ISPAN:SYS_REV_B -muas3001 powerpc mpc8260 muas3001 -muas3001_dev powerpc mpc8260 muas3001 - - muas3001:MUAS_DEV_BOARD -PM825 powerpc mpc8260 pm826 - - PM826:PCI,SYS_TEXT_BASE=0xFF000000 -PM825_BIGFLASH powerpc mpc8260 pm826 - - PM826:PCI,FLASH_32MB,SYS_TEXT_BASE=0x40000000 -PM825_ROMBOOT powerpc mpc8260 pm826 - - PM826:PCI,BOOT_ROM,SYS_TEXT_BASE=0xFF800000 -PM825_ROMBOOT_BIGFLASH powerpc mpc8260 pm826 - - PM826:PCI,BOOT_ROM,FLASH_32MB,SYS_TEXT_BASE=0xFF800000 -PM826 powerpc mpc8260 pm826 - - PM826:SYS_TEXT_BASE=0xFF000000 -PM826_BIGFLASH powerpc mpc8260 pm826 - - PM826:FLASH_32MB,SYS_TEXT_BASE=0x40000000 -PM826_ROMBOOT powerpc mpc8260 pm826 - - PM826:BOOT_ROM,SYS_TEXT_BASE=0xFF800000 -PM826_ROMBOOT_BIGFLASH powerpc mpc8260 pm826 - - PM826:BOOT_ROM,FLASH_32MB,SYS_TEXT_BASE=0xFF800000 -PM828 powerpc mpc8260 pm828 - - PM828 -PM828_PCI powerpc mpc8260 pm828 - - PM828:PCI -PM828_ROMBOOT powerpc mpc8260 pm828 - - PM828:BOOT_ROM,SYS_TEXT_BASE=0xFF800000 -PM828_ROMBOOT_PCI powerpc mpc8260 pm828 - - PM828:PCI,BOOT_ROM,SYS_TEXT_BASE=0xFF800000 -ppmc8260 powerpc mpc8260 -Rattler powerpc mpc8260 rattler - - Rattler -Rattler8248 powerpc mpc8260 rattler - - Rattler:MPC8248 -RPXsuper powerpc mpc8260 rpxsuper -rsdproto powerpc mpc8260 -sacsng powerpc mpc8260 -ZPC1900 powerpc mpc8260 zpc1900 -MPC8260ADS powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS -MPC8260ADS_33MHz powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS,8260_CLKIN=33000000 -MPC8260ADS_33MHz_lowboot powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS,8260_CLKIN=33000000,SYS_TEXT_BASE=0xFF800000 -MPC8260ADS_40MHz powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS,8260_CLKIN=40000000 -MPC8260ADS_40MHz_lowboot powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS,8260_CLKIN=40000000,SYS_TEXT_BASE=0xFF800000 -MPC8260ADS_lowboot powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS,SYS_TEXT_BASE=0xFF800000 -MPC8266ADS powerpc mpc8260 mpc8266ads freescale -MPC8272ADS powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_8272ADS -MPC8272ADS_lowboot powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_8272ADS,SYS_TEXT_BASE=0xFF800000 -PQ2FADS powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS -PQ2FADS_lowboot powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,SYS_TEXT_BASE=0xFF800000 -PQ2FADS-VR powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,8260_CLKIN=66000000 -PQ2FADS-VR_lowboot powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,8260_CLKIN=66000000,SYS_TEXT_BASE=0xFF800000 -PQ2FADS-ZU powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS -PQ2FADS-ZU_66MHz powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,8260_CLKIN=66000000 -PQ2FADS-ZU_66MHz_lowboot powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,8260_CLKIN=66000000,SYS_TEXT_BASE=0xFF800000 -PQ2FADS-ZU_lowboot powerpc mpc8260 mpc8260ads freescale - MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,SYS_TEXT_BASE=0xFF800000 -VoVPN-GW_66MHz powerpc mpc8260 vovpn-gw funkwerk - VoVPN-GW:CLKIN_66MHz -mgcoge powerpc mpc8260 km82xx keymile - km82xx:MGCOGE -mgcoge3ne powerpc mpc8260 km82xx keymile - km82xx:MGCOGE3NE -TQM8255_AA powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8255,300MHz -TQM8260_AA powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8260,200MHz -TQM8260_AB powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8260,200MHz,L2_CACHE,BUSMODE_60x -TQM8260_AC powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8260,200MHz,L2_CACHE,BUSMODE_60x -TQM8260_AD powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8260,300MHz,BUSMODE_60x -TQM8260_AE powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8260,266MHz -TQM8260_AF powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8260,300MHz,BUSMODE_60x -TQM8260_AG powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8260,300MHz -TQM8260_AH powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8260,300MHz,L2_CACHE,BUSMODE_60x -TQM8260_AI powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8260,300MHz,BUSMODE_60x -TQM8265_AA powerpc mpc8260 tqm8260 tqc - TQM8260:MPC8265,300MHz,BUSMODE_60x -TQM8272 powerpc mpc8260 tqm8272 tqc -mpc8308_p1m powerpc mpc83xx -sbc8349 powerpc mpc83xx sbc8349 - - sbc8349 -sbc8349_PCI_33 powerpc mpc83xx sbc8349 - - sbc8349:PCI,PCI_33M -sbc8349_PCI_66 powerpc mpc83xx sbc8349 - - sbc8349:PCI,PCI_66M -ve8313 powerpc mpc83xx ve8313 -caddy2 powerpc mpc83xx vme8349 esd - vme8349:CADDY2 -vme8349 powerpc mpc83xx vme8349 esd - vme8349 -MPC8308RDB powerpc mpc83xx mpc8308rdb freescale -MPC8313ERDB_33 powerpc mpc83xx mpc8313erdb freescale - MPC8313ERDB:SYS_33MHZ -MPC8313ERDB_66 powerpc mpc83xx mpc8313erdb freescale - MPC8313ERDB:SYS_66MHZ -MPC8313ERDB_NAND_33 powerpc mpc83xx mpc8313erdb freescale - MPC8313ERDB:SYS_33MHZ,NAND -MPC8313ERDB_NAND_66 powerpc mpc83xx mpc8313erdb freescale - MPC8313ERDB:SYS_66MHZ,NAND -MPC8315ERDB powerpc mpc83xx mpc8315erdb freescale - MPC8315ERDB -MPC8315ERDB_NAND powerpc mpc83xx mpc8315erdb freescale - MPC8315ERDB:NAND_U_BOOT -MPC8323ERDB powerpc mpc83xx mpc8323erdb freescale -MPC832XEMDS powerpc mpc83xx mpc832xemds freescale - MPC832XEMDS: -MPC832XEMDS_ATM powerpc mpc83xx mpc832xemds freescale - MPC832XEMDS:PQ_MDS_PIB=1,PQ_MDS_PIB_ATM=1 -MPC832XEMDS_HOST_33 powerpc mpc83xx mpc832xemds freescale - MPC832XEMDS:PCI,PCI_33M,PQ_MDS_PIB=1 -MPC832XEMDS_HOST_66 powerpc mpc83xx mpc832xemds freescale - MPC832XEMDS:PCI,PCI_66M,PQ_MDS_PIB=1 -MPC832XEMDS_SLAVE powerpc mpc83xx mpc832xemds freescale - MPC832XEMDS:PCI,PCISLAVE -MPC8349EMDS powerpc mpc83xx mpc8349emds freescale -MPC8349ITX powerpc mpc83xx mpc8349itx freescale - MPC8349ITX:MPC8349ITX -MPC8349ITXGP powerpc mpc83xx mpc8349itx freescale - MPC8349ITX:MPC8349ITXGP,SYS_TEXT_BASE=0xFE000000 -MPC8349ITX_LOWBOOT powerpc mpc83xx mpc8349itx freescale - MPC8349ITX:MPC8349ITX,SYS_TEXT_BASE=0xFE000000 -MPC8360EMDS_33 powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_33MHZ -MPC8360EMDS_33_ATM powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_33MHZ,PQ_MDS_PIB=1,PQ_MDS_PIB_ATM=1 -MPC8360EMDS_33_HOST_33 powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_33MHZ,PCI,PCI_33M,PQ_MDS_PIB=1 -MPC8360EMDS_33_HOST_66 powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_33MHZ,PCI,PCI_66M,PQ_MDS_PIB=1 -MPC8360EMDS_33_SLAVE powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_33MHZ,PCI,PCISLAVE -MPC8360EMDS_66 powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_66MHZ -MPC8360EMDS_66_ATM powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_66MHZ,PQ_MDS_PIB=1,PQ_MDS_PIB_ATM=1 -MPC8360EMDS_66_HOST_33 powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_66MHZ,PCI,PCI_33M,PQ_MDS_PIB=1 -MPC8360EMDS_66_HOST_66 powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_66MHZ,PCI,PCI_66M,PQ_MDS_PIB=1 -MPC8360EMDS_66_SLAVE powerpc mpc83xx mpc8360emds freescale - MPC8360EMDS:CLKIN_66MHZ,PCI,PCISLAVE -MPC8360ERDK powerpc mpc83xx mpc8360erdk freescale - MPC8360ERDK -MPC8360ERDK_33 powerpc mpc83xx mpc8360erdk freescale - MPC8360ERDK:CLKIN_33MHZ -MPC8360ERDK_66 powerpc mpc83xx mpc8360erdk freescale - MPC8360ERDK -MPC837XEMDS powerpc mpc83xx mpc837xemds freescale - MPC837XEMDS -MPC837XEMDS_HOST powerpc mpc83xx mpc837xemds freescale - MPC837XEMDS:PCI -MPC837XERDB powerpc mpc83xx mpc837xerdb freescale -kmcoge5ne powerpc mpc83xx km83xx keymile - km8360:KMCOGE5NE -kmeter1 powerpc mpc83xx km83xx keymile - km8360:KMETER1 -MERGERBOX powerpc mpc83xx mergerbox matrix_vision -MVBLM7 powerpc mpc83xx mvblm7 matrix_vision -SIMPC8313_LP powerpc mpc83xx simpc8313 sheldon - SIMPC8313:NAND_LP -SIMPC8313_SP powerpc mpc83xx simpc8313 sheldon - SIMPC8313:NAND_SP -TQM834x powerpc mpc83xx tqm834x tqc -suvd3 powerpc mpc83xx km83xx keymile - suvd3:SUVD3 -kmvect1 powerpc mpc83xx km83xx keymile - suvd3:KMVECT1 -tuge1 powerpc mpc83xx km83xx keymile - tuxx1:TUGE1 -tuxx1 powerpc mpc83xx km83xx keymile - tuxx1:TUXX1 -kmopti2 powerpc mpc83xx km83xx keymile - tuxx1:KMOPTI2 -kmsupx5 powerpc mpc83xx km83xx keymile - tuxx1:KMSUPX5 -sbc8548 powerpc mpc85xx sbc8548 - - sbc8548 -sbc8548_PCI_33 powerpc mpc85xx sbc8548 - - sbc8548:PCI,33 -sbc8548_PCI_33_PCIE powerpc mpc85xx sbc8548 - - sbc8548:PCI,33,PCIE -sbc8548_PCI_66 powerpc mpc85xx sbc8548 - - sbc8548:PCI,66 -sbc8548_PCI_66_PCIE powerpc mpc85xx sbc8548 - - sbc8548:PCI,66,PCIE -socrates powerpc mpc85xx socrates -HWW1U1A powerpc mpc85xx hww1u1a exmeritus -MPC8536DS powerpc mpc85xx mpc8536ds freescale - MPC8536DS -MPC8536DS_36BIT powerpc mpc85xx mpc8536ds freescale - MPC8536DS:36BIT -MPC8536DS_NAND powerpc mpc85xx mpc8536ds freescale - MPC8536DS:NAND -MPC8536DS_SDCARD powerpc mpc85xx mpc8536ds freescale - MPC8536DS:SDCARD -MPC8536DS_SPIFLASH powerpc mpc85xx mpc8536ds freescale - MPC8536DS:SPIFLASH -MPC8540ADS powerpc mpc85xx mpc8540ads freescale -MPC8541CDS powerpc mpc85xx mpc8541cds freescale - MPC8541CDS -MPC8541CDS_legacy powerpc mpc85xx mpc8541cds freescale - MPC8541CDS:LEGACY -MPC8544DS powerpc mpc85xx mpc8544ds freescale -MPC8548CDS powerpc mpc85xx mpc8548cds freescale - MPC8548CDS -MPC8548CDS_36BIT powerpc mpc85xx mpc8548cds freescale - MPC8548CDS:36BIT -MPC8548CDS_legacy powerpc mpc85xx mpc8548cds freescale - MPC8548CDS:LEGACY -MPC8555CDS powerpc mpc85xx mpc8555cds freescale - MPC8555CDS -MPC8555CDS_legacy powerpc mpc85xx mpc8555cds freescale - MPC8555CDS:LEGACY -MPC8560ADS powerpc mpc85xx mpc8560ads freescale -MPC8568MDS powerpc mpc85xx mpc8568mds freescale -MPC8569MDS powerpc mpc85xx mpc8569mds freescale - MPC8569MDS -MPC8569MDS_ATM powerpc mpc85xx mpc8569mds freescale - MPC8569MDS:ATM -MPC8569MDS_NAND powerpc mpc85xx mpc8569mds freescale - MPC8569MDS:NAND -MPC8572DS powerpc mpc85xx mpc8572ds freescale - MPC8572DS -MPC8572DS_36BIT powerpc mpc85xx mpc8572ds freescale - MPC8572DS:36BIT -MPC8572DS_NAND powerpc mpc85xx mpc8572ds freescale - MPC8572DS:NAND -C29XPCIE powerpc mpc85xx c29xpcie freescale - C29XPCIE:C29XPCIE,36BIT -C29XPCIE_SPIFLASH powerpc mpc85xx c29xpcie freescale - C29XPCIE:C29XPCIE,36BIT,SPIFLASH -P1010RDB_36BIT_NAND powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT,NAND -P1010RDB_36BIT_NAND_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT,NAND_SECBOOT,SECURE_BOOT -P1010RDB_36BIT_NOR powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT -P1010RDB_36BIT_NOR_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT,SECURE_BOOT -P1010RDB_36BIT_SDCARD powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT,SDCARD -P1010RDB_36BIT_SPIFLASH powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT,SPIFLASH -P1010RDB_36BIT_SPIFLASH_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,36BIT,SPIFLASH,SECURE_BOOT -P1010RDB_NAND powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,NAND -P1010RDB_NAND_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,NAND_SECBOOT,SECURE_BOOT -P1010RDB_NOR powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB -P1010RDB_NOR_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,SECURE_BOOT -P1010RDB_SDCARD powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,SDCARD -P1010RDB_SPIFLASH powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,SPIFLASH -P1010RDB_SPIFLASH_SECBOOT powerpc mpc85xx p1010rdb freescale - P1010RDB:P1010RDB,SPIFLASH,SECURE_BOOT -P1011RDB powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1011RDB -P1011RDB_36BIT powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1011RDB,36BIT -P1011RDB_36BIT_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1011RDB,36BIT,SDCARD -P1011RDB_36BIT_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1011RDB,36BIT,SPIFLASH -P1011RDB_NAND powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1011RDB,NAND -P1011RDB_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1011RDB,SDCARD -P1011RDB_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1011RDB,SPIFLASH -P1020MBG-PC powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020MBG -P1020MBG-PC_36BIT powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020MBG,36BIT -P1020MBG-PC_36BIT_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020MBG,SDCARD,36BIT -P1020MBG-PC_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020MBG,SDCARD -P1020RDB powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1020RDB -P1020RDB_36BIT powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1020RDB,36BIT -P1020RDB_36BIT_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1020RDB,36BIT,SDCARD -P1020RDB_36BIT_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1020RDB,36BIT,SPIFLASH -P1020RDB_NAND powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1020RDB,NAND -P1020RDB-PC powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB_PC -P1020RDB-PC_36BIT powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB_PC,36BIT -P1020RDB-PC_36BIT_NAND powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB_PC,36BIT,NAND -P1020RDB-PC_36BIT_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB_PC,36BIT,SDCARD -P1020RDB-PC_36BIT_SPIFLASH powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB_PC,36BIT,SPIFLASH -P1020RDB-PC_NAND powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB_PC,NAND -P1020RDB-PC_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB_PC,SDCARD -P1020RDB-PC_SPIFLASH powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB_PC,SPIFLASH -P1020RDB_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1020RDB,SDCARD -P1020RDB_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P1020RDB,SPIFLASH -P1020RDB-PD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB_PD -P1020RDB-PD_NAND powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB_PD,NAND -P1020RDB-PD_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB_PD,SDCARD -P1020RDB-PD_SPIFLASH powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020RDB_PD,SPIFLASH -P1020UTM-PC powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020UTM -P1020UTM-PC_36BIT powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020UTM,36BIT -P1020UTM-PC_36BIT_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020UTM,36BIT,SDCARD -P1020UTM-PC_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1020UTM,SDCARD -P1021RDB-PC powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1021RDB -P1021RDB-PC_36BIT powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1021RDB,36BIT -P1021RDB-PC_36BIT_NAND powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1021RDB,36BIT,NAND -P1021RDB-PC_36BIT_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1021RDB,36BIT,SDCARD -P1021RDB-PC_36BIT_SPIFLASH powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1021RDB,36BIT,SPIFLASH -P1021RDB-PC_NAND powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1021RDB,NAND -P1021RDB-PC_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1021RDB,SDCARD -P1021RDB-PC_SPIFLASH powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1021RDB,SPIFLASH -P1022DS powerpc mpc85xx p1022ds freescale -P1022DS_NAND powerpc mpc85xx p1022ds freescale - P1022DS:NAND -P1022DS_36BIT_NAND powerpc mpc85xx p1022ds freescale - P1022DS:36BIT,NAND -P1022DS_SPIFLASH powerpc mpc85xx p1022ds freescale - P1022DS:SPIFLASH -P1022DS_36BIT_SPIFLASH powerpc mpc85xx p1022ds freescale - P1022DS:36BIT,SPIFLASH -P1022DS_SDCARD powerpc mpc85xx p1022ds freescale - P1022DS:SDCARD -P1022DS_36BIT_SDCARD powerpc mpc85xx p1022ds freescale - P1022DS:36BIT,SDCARD -P1022DS_36BIT powerpc mpc85xx p1022ds freescale - P1022DS:36BIT -P1023RDB powerpc mpc85xx p1023rdb freescale - P1023RDB -P1023RDS powerpc mpc85xx p1023rds freescale - P1023RDS -P1023RDS_NAND powerpc mpc85xx p1023rds freescale - P1023RDS:NAND -P1024RDB powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1024RDB -P1024RDB_36BIT powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1024RDB,36BIT -P1024RDB_NAND powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1024RDB,NAND -P1024RDB_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1024RDB,SDCARD -P1024RDB_SPIFLASH powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1024RDB,SPIFLASH -P1025RDB powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1025RDB -P1025RDB_36BIT powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1025RDB,36BIT -P1025RDB_NAND powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1025RDB,NAND -P1025RDB_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1025RDB,SDCARD -P1025RDB_SPIFLASH powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1025RDB,SPIFLASH -TWR-P1025 powerpc mpc85xx p1_twr freescale - p1_twr:TWR_P1025 -P2010RDB powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2010RDB -P2010RDB_36BIT powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2010RDB,36BIT -P2010RDB_36BIT_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2010RDB,36BIT,SDCARD -P2010RDB_36BIT_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2010RDB,36BIT,SPIFLASH -P2010RDB_NAND powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2010RDB,NAND -P2010RDB_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2010RDB,SDCARD -P2010RDB_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2010RDB,SPIFLASH -P2020COME_SDCARD powerpc mpc85xx p2020come freescale - P2020COME:SDCARD -P2020COME_SPIFLASH powerpc mpc85xx p2020come freescale - P2020COME:SPIFLASH -P2020DS powerpc mpc85xx p2020ds freescale -P2020DS_36BIT powerpc mpc85xx p2020ds freescale - P2020DS:36BIT -P2020DS_DDR2 powerpc mpc85xx p2020ds freescale - P2020DS:DDR2 -P2020DS_SDCARD powerpc mpc85xx p2020ds freescale - P2020DS:SDCARD -P2020DS_SPIFLASH powerpc mpc85xx p2020ds freescale - P2020DS:SPIFLASH -P2020RDB powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020RDB -P2020RDB_36BIT powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020RDB,36BIT -P2020RDB_36BIT_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020RDB,36BIT,SDCARD -P2020RDB_36BIT_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020RDB,36BIT,SPIFLASH -P2020RDB_NAND powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020RDB,NAND -P2020RDB-PC powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P2020RDB -P2020RDB-PC_36BIT powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P2020RDB,36BIT -P2020RDB-PC_36BIT_NAND powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P2020RDB,36BIT,NAND -P2020RDB-PC_36BIT_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P2020RDB,36BIT,SDCARD -P2020RDB-PC_36BIT_SPIFLASH powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P2020RDB,36BIT,SPIFLASH -P2020RDB-PC_NAND powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P2020RDB,NAND -P2020RDB-PC_SDCARD powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P2020RDB,SDCARD -P2020RDB-PC_SPIFLASH powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P2020RDB,SPIFLASH -P2020RDB_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020RDB,SDCARD -P2020RDB_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020RDB,SPIFLASH -P2041RDB powerpc mpc85xx p2041rdb freescale -P2041RDB_NAND powerpc mpc85xx p2041rdb freescale - P2041RDB:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 -P2041RDB_SDCARD powerpc mpc85xx p2041rdb freescale - P2041RDB:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 -P2041RDB_SECURE_BOOT powerpc mpc85xx p2041rdb freescale - P2041RDB:SECURE_BOOT -P2041RDB_SPIFLASH powerpc mpc85xx p2041rdb freescale - P2041RDB:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -P2041RDB_SRIO_PCIE_BOOT powerpc mpc85xx p2041rdb freescale - P2041RDB:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 -P3041DS powerpc mpc85xx corenet_ds freescale -P3041DS_NAND powerpc mpc85xx corenet_ds freescale - P3041DS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 -P3041DS_SDCARD powerpc mpc85xx corenet_ds freescale - P3041DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 -P3041DS_SECURE_BOOT powerpc mpc85xx corenet_ds freescale - P3041DS:SECURE_BOOT -P3041DS_SPIFLASH powerpc mpc85xx corenet_ds freescale - P3041DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -P3041DS_SRIO_PCIE_BOOT powerpc mpc85xx corenet_ds freescale - P3041DS:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 -P4080DS powerpc mpc85xx corenet_ds freescale -P4080DS_SDCARD powerpc mpc85xx corenet_ds freescale - P4080DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 -P4080DS_SECURE_BOOT powerpc mpc85xx corenet_ds freescale - P4080DS:SECURE_BOOT -P4080DS_SPIFLASH powerpc mpc85xx corenet_ds freescale - P4080DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -P4080DS_SRIO_PCIE_BOOT powerpc mpc85xx corenet_ds freescale - P4080DS:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 -P5020DS powerpc mpc85xx corenet_ds freescale -P5020DS_NAND powerpc mpc85xx corenet_ds freescale - P5020DS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 -P5020DS_SDCARD powerpc mpc85xx corenet_ds freescale - P5020DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 -P5020DS_SECURE_BOOT powerpc mpc85xx corenet_ds freescale - P5020DS:SECURE_BOOT -P5020DS_SPIFLASH powerpc mpc85xx corenet_ds freescale - P5020DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -P5020DS_SRIO_PCIE_BOOT powerpc mpc85xx corenet_ds freescale - P5020DS:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 -P5040DS powerpc mpc85xx corenet_ds freescale -P5040DS_NAND powerpc mpc85xx corenet_ds freescale - P5040DS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 -P5040DS_SDCARD powerpc mpc85xx corenet_ds freescale - P5040DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 -P5040DS_SPIFLASH powerpc mpc85xx corenet_ds freescale - P5040DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -BSC9131RDB_SPIFLASH powerpc mpc85xx bsc9131rdb freescale - BSC9131RDB:BSC9131RDB,SPIFLASH -BSC9131RDB_SPIFLASH_SYSCLK100 powerpc mpc85xx bsc9131rdb freescale - BSC9131RDB:BSC9131RDB,SPIFLASH,SYS_CLK_100 -BSC9131RDB_NAND powerpc mpc85xx bsc9131rdb freescale - BSC9131RDB:BSC9131RDB,NAND -BSC9131RDB_NAND_SYSCLK100 powerpc mpc85xx bsc9131rdb freescale - BSC9131RDB:BSC9131RDB,NAND,SYS_CLK_100 -BSC9132QDS_NOR_DDRCLK100 powerpc mpc85xx bsc9132qds freescale - BSC9132QDS:BSC9132QDS,SYS_CLK_100_DDR_100 -BSC9132QDS_NOR_DDRCLK133 powerpc mpc85xx bsc9132qds freescale - BSC9132QDS:BSC9132QDS,SYS_CLK_100_DDR_133 -BSC9132QDS_NAND_DDRCLK100 powerpc mpc85xx bsc9132qds freescale - BSC9132QDS:BSC9132QDS,NAND,SYS_CLK_100_DDR_100 -BSC9132QDS_NAND_DDRCLK133 powerpc mpc85xx bsc9132qds freescale - BSC9132QDS:BSC9132QDS,NAND,SYS_CLK_100_DDR_133 -BSC9132QDS_SDCARD_DDRCLK100 powerpc mpc85xx bsc9132qds freescale - BSC9132QDS:BSC9132QDS,SDCARD,SYS_CLK_100_DDR_100 -BSC9132QDS_SDCARD_DDRCLK133 powerpc mpc85xx bsc9132qds freescale - BSC9132QDS:BSC9132QDS,SDCARD,SYS_CLK_100_DDR_133 -BSC9132QDS_SPIFLASH_DDRCLK100 powerpc mpc85xx bsc9132qds freescale - BSC9132QDS:BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_100 -BSC9132QDS_SPIFLASH_DDRCLK133 powerpc mpc85xx bsc9132qds freescale - BSC9132QDS:BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_133 -controlcenterd_36BIT_SDCARD powerpc mpc85xx p1022 gdsys - controlcenterd:36BIT,SDCARD -controlcenterd_36BIT_SDCARD_DEVELOP powerpc mpc85xx p1022 gdsys - controlcenterd:36BIT,SDCARD,DEVELOP -controlcenterd_TRAILBLAZER powerpc mpc85xx p1022 gdsys - controlcenterd:TRAILBLAZER,SPIFLASH -controlcenterd_TRAILBLAZER_DEVELOP powerpc mpc85xx p1022 gdsys - controlcenterd:TRAILBLAZER,SPIFLASH,DEVELOP -stxgp3 powerpc mpc85xx stxgp3 stx -stxssa powerpc mpc85xx stxssa stx - stxssa -stxssa_4M powerpc mpc85xx stxssa stx - stxssa:STXSSA_4M -T4240QDS powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4240 -T4240EMU powerpc mpc85xx t4qds freescale - T4240EMU:PPC_T4240 -T4240QDS_SDCARD powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4240,RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 -T4240QDS_SPIFLASH powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4240,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -T4240QDS_SRIO_PCIE_BOOT powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4240,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 -T4160QDS powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4160 -T4160QDS_SDCARD powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4160,RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 -T4160QDS_SPIFLASH powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4160,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -B4860QDS powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4860 -B4860QDS_NAND powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4860,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 -B4860QDS_SPIFLASH powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4860,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -B4860QDS_SRIO_PCIE_BOOT powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4860,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 -B4420QDS powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4420 -B4420QDS_NAND powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4420,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 -B4420QDS_SPIFLASH powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4420,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 -xpedite520x powerpc mpc85xx - xes -xpedite537x powerpc mpc85xx - xes -xpedite550x powerpc mpc85xx - xes -sbc8641d powerpc mpc86xx -MPC8610HPCD powerpc mpc86xx mpc8610hpcd freescale -MPC8641HPCN powerpc mpc86xx mpc8641hpcn freescale - MPC8641HPCN -MPC8641HPCN_36BIT powerpc mpc86xx mpc8641hpcn freescale - MPC8641HPCN:PHYS_64BIT -xpedite517x powerpc mpc86xx - xes -Adder powerpc mpc8xx adder -Adder87x powerpc mpc8xx adder - - Adder -AdderII powerpc mpc8xx adder - - Adder:MPC852T -AdderUSB powerpc mpc8xx adder - - Adder -ADS860 powerpc mpc8xx fads -cogent_mpc8xx powerpc mpc8xx cogent -ESTEEM192E powerpc mpc8xx esteem192e -FADS823 powerpc mpc8xx fads -FADS850SAR powerpc mpc8xx fads -FADS860T powerpc mpc8xx fads -FLAGADM powerpc mpc8xx flagadm -GEN860T powerpc mpc8xx gen860t -GEN860T_SC powerpc mpc8xx gen860t - - GEN860T:SC -GENIETV powerpc mpc8xx genietv -hermes powerpc mpc8xx -ICU862 powerpc mpc8xx icu862 -ICU862_100MHz powerpc mpc8xx icu862 - - ICU862:100MHz -IP860 powerpc mpc8xx ip860 -IVML24 powerpc mpc8xx ivm - - IVML24:IVML24_16M -IVML24_128 powerpc mpc8xx ivm - - IVML24:IVML24_32M -IVML24_256 powerpc mpc8xx ivm - - IVML24:IVML24_64M -IVMS8 powerpc mpc8xx ivm - - IVMS8:IVMS8_16M -IVMS8_128 powerpc mpc8xx ivm - - IVMS8:IVMS8_32M -IVMS8_256 powerpc mpc8xx ivm - - IVMS8:IVMS8_64M -lwmon powerpc mpc8xx -MBX powerpc mpc8xx mbx8xx -MBX860T powerpc mpc8xx mbx8xx -MPC86xADS powerpc mpc8xx fads -MPC885ADS powerpc mpc8xx fads -NETPHONE powerpc mpc8xx netphone - - NETPHONE:NETPHONE_VERSION=1 -NETPHONE_V2 powerpc mpc8xx netphone - - NETPHONE:NETPHONE_VERSION=2 -NETTA powerpc mpc8xx netta - - NETTA -NETTA2 powerpc mpc8xx netta2 - - NETTA2:NETTA2_VERSION=1 -NETTA2_V2 powerpc mpc8xx netta2 - - NETTA2:NETTA2_VERSION=2 -NETTA_6412 powerpc mpc8xx netta - - NETTA:NETTA_6412=1 -NETTA_6412_SWAPHOOK powerpc mpc8xx netta - - NETTA:NETTA_6412=1,NETTA_SWAPHOOK=1 -NETTA_ISDN powerpc mpc8xx netta - - NETTA:NETTA_ISDN=1 -NETTA_ISDN_6412 powerpc mpc8xx netta - - NETTA:NETTA_ISDN=1,NETTA_6412=1 -NETTA_ISDN_6412_SWAPHOOK powerpc mpc8xx netta - - NETTA:NETTA_ISDN=1,NETTA_6412=1,NETTA_SWAPHOOK=1 -NETTA_ISDN_SWAPHOOK powerpc mpc8xx netta - - NETTA:NETTA_ISDN=1,NETTA_SWAPHOOK=1 -NETTA_SWAPHOOK powerpc mpc8xx netta - - NETTA:NETTA_SWAPHOOK=1 -NETVIA powerpc mpc8xx netvia - - NETVIA:NETVIA_VERSION=1 -NETVIA_V2 powerpc mpc8xx netvia - - NETVIA:NETVIA_VERSION=2 -NX823 powerpc mpc8xx nx823 -quantum powerpc mpc8xx -R360MPI powerpc mpc8xx r360mpi -RBC823 powerpc mpc8xx rbc823 -RPXClassic powerpc mpc8xx -RPXlite powerpc mpc8xx -RPXlite_DW powerpc mpc8xx RPXlite_dw - - RPXlite_DW -RPXlite_DW_64 powerpc mpc8xx RPXlite_dw - - RPXlite_DW:RPXlite_64MHz -RPXlite_DW_64_LCD powerpc mpc8xx RPXlite_dw - - RPXlite_DW:RPXlite_64MHz,LCD,NEC_NL6448BC20 -RPXlite_DW_LCD powerpc mpc8xx RPXlite_dw - - RPXlite_DW:LCD,NEC_NL6448BC20 -RPXlite_DW_NVRAM powerpc mpc8xx RPXlite_dw - - RPXlite_DW:ENV_IS_IN_NVRAM -RPXlite_DW_NVRAM_64 powerpc mpc8xx RPXlite_dw - - RPXlite_DW:RPXlite_64MHz,ENV_IS_IN_NVRAM -RPXlite_DW_NVRAM_64_LCD powerpc mpc8xx RPXlite_dw - - RPXlite_DW:RPXlite_64MHz,LCD,NEC_NL6448BC20,ENV_IS_IN_NVRAM -RPXlite_DW_NVRAM_LCD powerpc mpc8xx RPXlite_dw - - RPXlite_DW:LCD,NEC_NL6448BC20,ENV_IS_IN_NVRAM -RRvision powerpc mpc8xx -RRvision_LCD powerpc mpc8xx RRvision - - RRvision:LCD,SHARP_LQ104V7DS01 -spc1920 powerpc mpc8xx -SPD823TS powerpc mpc8xx spd8xx -svm_sc8xx powerpc mpc8xx -SXNI855T powerpc mpc8xx sixnet -v37 powerpc mpc8xx -MHPC powerpc mpc8xx mhpc eltec -TOP860 powerpc mpc8xx top860 emk -KUP4K powerpc mpc8xx kup4k kup -KUP4X powerpc mpc8xx kup4x kup -ELPT860 powerpc mpc8xx elpt860 LEOX -uc100 powerpc mpc8xx - manroland -QS823 powerpc mpc8xx qs850 snmc -QS850 powerpc mpc8xx qs850 snmc -QS860T powerpc mpc8xx qs860t snmc -stxxtc powerpc mpc8xx stxxtc stx -FPS850L powerpc mpc8xx tqm8xx tqc -FPS860L powerpc mpc8xx tqm8xx tqc -NSCU powerpc mpc8xx tqm8xx tqc -SM850 powerpc mpc8xx tqm8xx tqc -TK885D powerpc mpc8xx tqm8xx tqc -TQM823L powerpc mpc8xx tqm8xx tqc -TQM823L_LCD powerpc mpc8xx tqm8xx tqc - TQM823L:LCD,NEC_NL6448BC20 -TQM823M powerpc mpc8xx tqm8xx tqc -TQM850L powerpc mpc8xx tqm8xx tqc -TQM850M powerpc mpc8xx tqm8xx tqc -TQM855L powerpc mpc8xx tqm8xx tqc -TQM855M powerpc mpc8xx tqm8xx tqc -TQM860L powerpc mpc8xx tqm8xx tqc -TQM860M powerpc mpc8xx tqm8xx tqc -TQM862L powerpc mpc8xx tqm8xx tqc -TQM862M powerpc mpc8xx tqm8xx tqc -TQM866M powerpc mpc8xx tqm8xx tqc -TQM885D powerpc mpc8xx tqm8xx tqc -TTTech powerpc mpc8xx tqm8xx tqc - TQM823L:LCD,SHARP_LQ104V7DS01 -virtlab2 powerpc mpc8xx tqm8xx tqc -wtk powerpc mpc8xx tqm8xx tqc - TQM823L:LCD,SHARP_LQ065T9DR51U -csb272 powerpc ppc4xx -csb472 powerpc ppc4xx -G2000 powerpc ppc4xx g2000 -JSE powerpc ppc4xx jse -korat powerpc ppc4xx -korat_perm powerpc ppc4xx korat - - korat:KORAT_PERMANENT -lwmon5 powerpc ppc4xx -lcd4_lwmon5 powerpc ppc4xx lwmon5 - - lwmon5:LCD4_LWMON5 -pcs440ep powerpc ppc4xx -quad100hd powerpc ppc4xx -sbc405 powerpc ppc4xx -sc3 powerpc ppc4xx -t3corp powerpc ppc4xx -W7OLMC powerpc ppc4xx w7o -W7OLMG powerpc ppc4xx w7o -zeus powerpc ppc4xx -acadia powerpc ppc4xx - amcc -acadia_nand powerpc ppc4xx acadia amcc - acadia:NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 -arches powerpc ppc4xx canyonlands amcc - canyonlands:ARCHES -bamboo powerpc ppc4xx - amcc -bamboo_nand powerpc ppc4xx bamboo amcc - bamboo:NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 -bluestone powerpc ppc4xx - amcc -bubinga powerpc ppc4xx - amcc -canyonlands powerpc ppc4xx canyonlands amcc - canyonlands:CANYONLANDS -canyonlands_nand powerpc ppc4xx canyonlands amcc - canyonlands:CANYONLANDS,NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 -ebony powerpc ppc4xx - amcc -glacier powerpc ppc4xx canyonlands amcc - canyonlands:GLACIER -glacier_nand powerpc ppc4xx canyonlands amcc - canyonlands:GLACIER,NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 -haleakala powerpc ppc4xx kilauea amcc - kilauea:HALEAKALA -haleakala_nand powerpc ppc4xx kilauea amcc - kilauea:NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 -katmai powerpc ppc4xx - amcc -kilauea powerpc ppc4xx kilauea amcc - kilauea:KILAUEA -kilauea_nand powerpc ppc4xx kilauea amcc - kilauea:NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 -luan powerpc ppc4xx - amcc -makalu powerpc ppc4xx - amcc -ocotea powerpc ppc4xx - amcc -rainier powerpc ppc4xx sequoia amcc - sequoia:RAINIER -rainier_nand powerpc ppc4xx sequoia amcc - sequoia:RAINIER,NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 -rainier_ramboot powerpc ppc4xx sequoia amcc - sequoia:RAINIER,SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/sequoia/u-boot-ram.lds -redwood powerpc ppc4xx - amcc -sequoia powerpc ppc4xx sequoia amcc - sequoia:SEQUOIA -sequoia_nand powerpc ppc4xx sequoia amcc - sequoia:SEQUOIA,NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 -sequoia_ramboot powerpc ppc4xx sequoia amcc - sequoia:SEQUOIA,SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/sequoia/u-boot-ram.lds -sycamore powerpc ppc4xx walnut amcc - walnut -taihu powerpc ppc4xx - amcc -taishan powerpc ppc4xx - amcc -walnut powerpc ppc4xx walnut amcc -yellowstone powerpc ppc4xx yosemite amcc - yosemite:YELLOWSTONE -yosemite powerpc ppc4xx yosemite amcc - yosemite:YOSEMITE -yucca powerpc ppc4xx - amcc -fx12mm powerpc ppc4xx fx12mm avnet - fx12mm:SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,INIT_TLB=board/xilinx/ppc405-generic/init.o -fx12mm_flash powerpc ppc4xx fx12mm avnet - fx12mm:SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC,INIT_TLB=board/xilinx/ppc405-generic/init.o -v5fx30teval powerpc ppc4xx v5fx30teval avnet - v5fx30teval:SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,BOOT_FROM_XMD=1,INIT_TLB=board/xilinx/ppc440-generic/init.o -v5fx30teval_flash powerpc ppc4xx v5fx30teval avnet - v5fx30teval:SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC,INIT_TLB=board/xilinx/ppc440-generic/init.o -CRAYL1 powerpc ppc4xx L1 cray -CATcenter powerpc ppc4xx PPChameleonEVB dave - CATcenter:PPCHAMELEON_MODULE_MODEL=1 -CATcenter_25 powerpc ppc4xx PPChameleonEVB dave - CATcenter:PPCHAMELEON_MODULE_MODEL=1,PPCHAMELEON_CLK_25 -CATcenter_33 powerpc ppc4xx PPChameleonEVB dave - CATcenter:PPCHAMELEON_MODULE_MODEL=1,PPCHAMELEON_CLK_33 -PPChameleonEVB powerpc ppc4xx PPChameleonEVB dave -PPChameleonEVB_BA_25 powerpc ppc4xx PPChameleonEVB dave - PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=0,PPCHAMELEON_CLK_25 -PPChameleonEVB_BA_33 powerpc ppc4xx PPChameleonEVB dave - PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=0,PPCHAMELEON_CLK_33 -PPChameleonEVB_HI_25 powerpc ppc4xx PPChameleonEVB dave - PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=2,PPCHAMELEON_CLK_25 -PPChameleonEVB_HI_33 powerpc ppc4xx PPChameleonEVB dave - PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=2,PPCHAMELEON_CLK_33 -PPChameleonEVB_ME_25 powerpc ppc4xx PPChameleonEVB dave - PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=1,PPCHAMELEON_CLK_25 -PPChameleonEVB_ME_33 powerpc ppc4xx PPChameleonEVB dave - PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=1,PPCHAMELEON_CLK_33 -APC405 powerpc ppc4xx apc405 esd -AR405 powerpc ppc4xx ar405 esd -ASH405 powerpc ppc4xx ash405 esd -CMS700 powerpc ppc4xx cms700 esd -CPCI2DP powerpc ppc4xx cpci2dp esd -CPCI405 powerpc ppc4xx cpci405 esd -CPCI4052 powerpc ppc4xx cpci405 esd -CPCI405AB powerpc ppc4xx cpci405 esd -CPCI405DT powerpc ppc4xx cpci405 esd -CPCIISER4 powerpc ppc4xx cpciiser4 esd -DP405 powerpc ppc4xx dp405 esd -DU405 powerpc ppc4xx du405 esd -DU440 powerpc ppc4xx du440 esd -HH405 powerpc ppc4xx hh405 esd -HUB405 powerpc ppc4xx hub405 esd -OCRTC powerpc ppc4xx ocrtc esd -PCI405 powerpc ppc4xx pci405 esd -PLU405 powerpc ppc4xx plu405 esd -PMC405 powerpc ppc4xx pmc405 esd -PMC405DE powerpc ppc4xx pmc405de esd -PMC440 powerpc ppc4xx pmc440 esd -VOH405 powerpc ppc4xx voh405 esd -VOM405 powerpc ppc4xx vom405 esd -WUH405 powerpc ppc4xx wuh405 esd -devconcenter powerpc ppc4xx intip gdsys - intip:DEVCONCENTER -dlvision powerpc ppc4xx - gdsys -dlvision-10g powerpc ppc4xx 405ep gdsys -gdppc440etx powerpc ppc4xx - gdsys -intip powerpc ppc4xx intip gdsys - intip:INTIB -io powerpc ppc4xx 405ep gdsys -io64 powerpc ppc4xx 405ex gdsys -iocon powerpc ppc4xx 405ep gdsys -neo powerpc ppc4xx 405ep gdsys -icon powerpc ppc4xx - mosaixtech -MIP405 powerpc ppc4xx mip405 mpl -MIP405T powerpc ppc4xx mip405 mpl - MIP405:MIP405T -PIP405 powerpc ppc4xx pip405 mpl -alpr powerpc ppc4xx - prodrive -p3p440 powerpc ppc4xx - prodrive -KAREF powerpc ppc4xx karef sandburst -METROBOX powerpc ppc4xx metrobox sandburst -xpedite1000 powerpc ppc4xx - xes -ml507 powerpc ppc4xx ml507 xilinx - ml507:SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,BOOT_FROM_XMD=1,INIT_TLB=board/xilinx/ppc440-generic/init.o -ml507_flash powerpc ppc4xx ml507 xilinx - ml507:SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC,INIT_TLB=board/xilinx/ppc440-generic/init.o -xilinx-ppc405-generic powerpc ppc4xx ppc405-generic xilinx - xilinx-ppc405-generic:SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000 -xilinx-ppc405-generic_flash powerpc ppc4xx ppc405-generic xilinx - xilinx-ppc405-generic:SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC -xilinx-ppc440-generic powerpc ppc4xx ppc440-generic xilinx - xilinx-ppc440-generic:SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,BOOT_FROM_XMD=1 -xilinx-ppc440-generic_flash powerpc ppc4xx ppc440-generic xilinx - xilinx-ppc440-generic:SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC -sandbox sandbox sandbox sandbox sandbox - -rsk7203 sh sh2 rsk7203 renesas - -rsk7264 sh sh2 rsk7264 renesas - -rsk7269 sh sh2 rsk7269 renesas - -mpr2 sh sh3 mpr2 - - -ms7720se sh sh3 ms7720se - - -shmin sh sh3 shmin - - -espt sh sh4 espt - - -ms7722se sh sh4 ms7722se - - -ms7750se sh sh4 ms7750se - - -ap325rxa sh sh4 ap325rxa renesas - -ecovec sh sh4 ecovec renesas - -MigoR sh sh4 MigoR renesas - -r2dplus sh sh4 r2dplus renesas - -r7780mp sh sh4 r7780mp renesas - -sh7752evb sh sh4 sh7752evb renesas - -sh7757lcr sh sh4 sh7757lcr renesas - -sh7763rdp sh sh4 sh7763rdp renesas - -sh7785lcr sh sh4 sh7785lcr renesas - -sh7785lcr_32bit sh sh4 sh7785lcr renesas - sh7785lcr:SH_32BIT=1 -r0p7734 sh sh4 r0p7734 renesas - -ap_sh4a_4a sh sh4 ap_sh4a_4a alphaproject - -grsim_leon2 sparc leon2 - gaisler -gr_cpci_ax2000 sparc leon3 - gaisler -gr_ep2s60 sparc leon3 - gaisler -grsim sparc leon3 - gaisler -gr_xc3s_1500 sparc leon3 - gaisler -coreboot-x86 x86 x86 coreboot chromebook-x86 coreboot coreboot:SYS_TEXT_BASE=0x01110000 -# Target ARCH CPU Board name Vendor SoC Options -######################################################################################################################## +Active arm arm1136 - armltd integrator integratorcp_cm1136 integratorcp:CM1136 Linus Walleij linus.walleij@linaro.org +Active arm arm1136 mx31 - - imx31_phycore - - +Active arm arm1136 mx31 davedenx - qong - Wolfgang Denk wd@denx.de +Active arm arm1136 mx31 freescale - mx31pdk - Fabio Estevam fabio.estevam@freescale.com +Active arm arm1136 mx31 hale - tt01 - Helmut Raiger helmut.raiger@hale.at +Active arm arm1136 mx31 logicpd - imx31_litekit - - +Active arm arm1136 mx35 - - woodburn - Stefano Babic sbabic@denx.de +Active arm arm1136 mx35 - woodburn woodburn_sd woodburn_sd:IMX_CONFIG=board/woodburn/imximage.cfg - +Active arm arm1136 mx35 CarMediaLab - flea3 - Stefano Babic sbabic@denx.de +Active arm arm1136 mx35 freescale - mx35pdk - Stefano Babic sbabic@denx.de +Active arm arm1176 bcm2835 raspberrypi rpi_b rpi_b - Stephen Warren swarren@wwwdotorg.org +Active arm arm1176 tnetv107x ti tnetv107xevm tnetv107x_evm - Chan-Taek Park c-park@ti.com +Active arm arm720t - armltd integrator integratorap_cm720t integratorap:CM720T Linus Walleij linus.walleij@linaro.org +Active arm arm920t - armltd integrator integratorap_cm920t integratorap:CM920T Linus Walleij linus.walleij@linaro.org +Active arm arm920t - armltd integrator integratorcp_cm920t integratorcp:CM920T Linus Walleij linus.walleij@linaro.org +Active arm arm920t a320 faraday - a320evb - Po-Yu Chuang ratbert@faraday-tech.com +Active arm arm920t at91 atmel at91rm9200ek at91rm9200ek at91rm9200ek Andreas Bießmann andreas.devel@gmail.com +Active arm arm920t at91 atmel at91rm9200ek at91rm9200ek_ram at91rm9200ek:RAMBOOT Andreas Bießmann andreas.devel@gmail.com +Active arm arm920t at91 BuS eb_cpux9k2 eb_cpux9k2 eb_cpux9k2 Jens Scharsig esw@bus-elektronik.de +Active arm arm920t at91 BuS eb_cpux9k2 eb_cpux9k2_ram eb_cpux9k2:RAMBOOT Jens Scharsig esw@bus-elektronik.de +Active arm arm920t at91 eukrea cpuat91 cpuat91 cpuat91 Eric Benard eric@eukrea.com +Active arm arm920t at91 eukrea cpuat91 cpuat91_ram cpuat91:RAMBOOT Eric Benard eric@eukrea.com +Active arm arm920t imx - - mx1ads - - +Active arm arm920t imx - - scb9328 - Torsten Koschorrek koschorrek@synertronixx.de +Active arm arm920t ks8695 - - cm4008 - Greg Ungerer greg.ungerer@opengear.com +Active arm arm920t ks8695 - - cm41xx - - +Active arm arm920t s3c24x0 friendlyarm mini2440 mini2440 - Gabriel Huau contact@huau-gabriel.fr +Active arm arm920t s3c24x0 mpl vcma9 VCMA9 - David Müller d.mueller@elsoft.ch +Active arm arm920t s3c24x0 samsung - smdk2410 - David Müller d.mueller@elsoft.ch +Active arm arm926ejs - armltd integrator integratorap_cm926ejs integratorap:CM926EJ_S Linus Walleij linus.walleij@linaro.org +Active arm arm926ejs - armltd integrator integratorcp_cm926ejs integratorcp:CM924EJ_S Linus Walleij linus.walleij@linaro.org +Active arm arm926ejs armada100 Marvell - aspenite - Prafulla Wadaskar prafulla@marvell.com +Active arm arm926ejs armada100 Marvell - gplugd - Ajay Bhargav ajay.bhargav@einfochips.com +Active arm arm926ejs at91 - - afeb9260 - Sergey Lapin slapin@ossfans.org +Active arm arm926ejs at91 atmel at91sam9260ek at91sam9260ek_dataflash_cs0 at91sam9260ek:AT91SAM9260,SYS_USE_DATAFLASH_CS0 Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9260ek at91sam9260ek_dataflash_cs1 at91sam9260ek:AT91SAM9260,SYS_USE_DATAFLASH_CS1 Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9260ek at91sam9260ek_nandflash at91sam9260ek:AT91SAM9260,SYS_USE_NANDFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9260ek at91sam9g20ek_2mmc_nandflash at91sam9260ek:AT91SAM9G20,AT91SAM9G20EK_2MMC,SYS_USE_NANDFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9260ek at91sam9g20ek_dataflash_cs0 at91sam9260ek:AT91SAM9G20,SYS_USE_DATAFLASH_CS0 Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9260ek at91sam9g20ek_dataflash_cs1 at91sam9260ek:AT91SAM9G20,SYS_USE_DATAFLASH_CS1 Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9260ek at91sam9g20ek_mmc at91sam9260ek:AT91SAM9G20,SYS_USE_MMC Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9260ek at91sam9g20ek_nandflash at91sam9260ek:AT91SAM9G20,SYS_USE_NANDFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9260ek at91sam9xeek_dataflash_cs0 at91sam9260ek:AT91SAM9XE,SYS_USE_DATAFLASH_CS0 Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9260ek at91sam9xeek_dataflash_cs1 at91sam9260ek:AT91SAM9XE,SYS_USE_DATAFLASH_CS1 Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9260ek at91sam9xeek_nandflash at91sam9260ek:AT91SAM9XE,SYS_USE_NANDFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9261ek at91sam9261ek_dataflash_cs0 at91sam9261ek:AT91SAM9261,SYS_USE_DATAFLASH_CS0 Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9261ek at91sam9261ek_dataflash_cs3 at91sam9261ek:AT91SAM9261,SYS_USE_DATAFLASH_CS3 Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9261ek at91sam9261ek_nandflash at91sam9261ek:AT91SAM9261,SYS_USE_NANDFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9261ek at91sam9g10ek_dataflash_cs0 at91sam9261ek:AT91SAM9G10,SYS_USE_DATAFLASH_CS0 Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9261ek at91sam9g10ek_dataflash_cs3 at91sam9261ek:AT91SAM9G10,SYS_USE_DATAFLASH_CS3 Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9261ek at91sam9g10ek_nandflash at91sam9261ek:AT91SAM9G10,SYS_USE_NANDFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9263ek at91sam9263ek_dataflash at91sam9263ek:AT91SAM9263,SYS_USE_DATAFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9263ek at91sam9263ek_dataflash_cs0 at91sam9263ek:AT91SAM9263,SYS_USE_DATAFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9263ek at91sam9263ek_nandflash at91sam9263ek:AT91SAM9263,SYS_USE_NANDFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9263ek at91sam9263ek_norflash at91sam9263ek:AT91SAM9263,SYS_USE_NORFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9263ek at91sam9263ek_norflash_boot at91sam9263ek:AT91SAM9263,SYS_USE_BOOT_NORFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9m10g45ek at91sam9m10g45ek_nandflash at91sam9m10g45ek:AT91SAM9M10G45,SYS_USE_NANDFLASH Bo Shenvoice.shen@atmel.com +Active arm arm926ejs at91 atmel at91sam9n12ek at91sam9n12ek_mmc at91sam9n12ek:AT91SAM9N12,SYS_USE_MMC Josh Wu josh.wu@atmel.com +Active arm arm926ejs at91 atmel at91sam9n12ek at91sam9n12ek_nandflash at91sam9n12ek:AT91SAM9N12,SYS_USE_NANDFLASH Josh Wu josh.wu@atmel.com +Active arm arm926ejs at91 atmel at91sam9n12ek at91sam9n12ek_spiflash at91sam9n12ek:AT91SAM9N12,SYS_USE_SPIFLASH Josh Wu josh.wu@atmel.com +Active arm arm926ejs at91 atmel at91sam9rlek at91sam9rlek_dataflash at91sam9rlek:AT91SAM9RL,SYS_USE_DATAFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9rlek at91sam9rlek_nandflash at91sam9rlek:AT91SAM9RL,SYS_USE_NANDFLASH Stelian Pop stelian@popies.net +Active arm arm926ejs at91 atmel at91sam9x5ek at91sam9x5ek_dataflash at91sam9x5ek:AT91SAM9X5,SYS_USE_DATAFLASH Bo Shen voice.shen@atmel.com +Active arm arm926ejs at91 atmel at91sam9x5ek at91sam9x5ek_mmc at91sam9x5ek:AT91SAM9X5,SYS_USE_MMC Bo Shen voice.shen@atmel.com +Active arm arm926ejs at91 atmel at91sam9x5ek at91sam9x5ek_nandflash at91sam9x5ek:AT91SAM9X5,SYS_USE_NANDFLASH Bo Shen voice.shen@atmel.com +Active arm arm926ejs at91 atmel at91sam9x5ek at91sam9x5ek_spiflash at91sam9x5ek:AT91SAM9X5,SYS_USE_SPIFLASH Bo Shen voice.shen@atmel.com +Active arm arm926ejs at91 bluewater - snapper9260 snapper9260:AT91SAM9260 Ryan Mallon ryan@bluewatersys.com +Active arm arm926ejs at91 bluewater snapper9260 snapper9g20 snapper9260:AT91SAM9G20 Ryan Mallon ryan@bluewatersys.com +Active arm arm926ejs at91 BuS vl_ma2sc vl_ma2sc - Jens Scharsig esw@bus-elektronik.de +Active arm arm926ejs at91 BuS vl_ma2sc vl_ma2sc_ram vl_ma2sc:RAMLOAD Jens Scharsig esw@bus-elektronik.de +Active arm arm926ejs at91 calao sbc35_a9g20 sbc35_a9g20_eeprom sbc35_a9g20:AT91SAM9G20,SYS_USE_EEPROM Albin Tonnerre albin.tonnerre@free-electrons.com +Active arm arm926ejs at91 calao sbc35_a9g20 sbc35_a9g20_nandflash sbc35_a9g20:AT91SAM9G20,SYS_USE_NANDFLASH Albin Tonnerre albin.tonnerre@free-electrons.com +Active arm arm926ejs at91 calao tny_a9260 tny_a9260_eeprom tny_a9260:AT91SAM9260,SYS_USE_EEPROM Albin Tonnerre albin.tonnerre@free-electrons.com +Active arm arm926ejs at91 calao tny_a9260 tny_a9260_nandflash tny_a9260:AT91SAM9260,SYS_USE_NANDFLASH Albin Tonnerre albin.tonnerre@free-electrons.com +Active arm arm926ejs at91 calao tny_a9260 tny_a9g20_eeprom tny_a9260:AT91SAM9G20,SYS_USE_EEPROM Albin Tonnerre albin.tonnerre@free-electrons.com +Active arm arm926ejs at91 calao tny_a9260 tny_a9g20_nandflash tny_a9260:AT91SAM9G20,SYS_USE_NANDFLASH Albin Tonnerre albin.tonnerre@free-electrons.com +Active arm arm926ejs at91 egnite ethernut5 ethernut5 ethernut5:AT91SAM9XE egnite GmbH info@egnite.de +Active arm arm926ejs at91 emk top9000 top9000eval_xe top9000:EVAL9000 Reinhard Meyer reinhard.meyer@emk-elektronik.de +Active arm arm926ejs at91 emk top9000 top9000su_xe top9000:SU9000 Reinhard Meyer reinhard.meyer@emk-elektronik.de +Active arm arm926ejs at91 esd meesc meesc meesc:AT91SAM9263,SYS_USE_NANDFLASH Daniel Gorsulowski daniel.gorsulowski@esd.eu +Active arm arm926ejs at91 esd meesc meesc_dataflash meesc:AT91SAM9263,SYS_USE_DATAFLASH Daniel Gorsulowski daniel.gorsulowski@esd.eu +Active arm arm926ejs at91 esd otc570 otc570 otc570:AT91SAM9263,SYS_USE_NANDFLASH Daniel Gorsulowski daniel.gorsulowski@esd.eu +Active arm arm926ejs at91 esd otc570 otc570_dataflash otc570:AT91SAM9263,SYS_USE_DATAFLASH Daniel Gorsulowski daniel.gorsulowski@esd.eu +Active arm arm926ejs at91 eukrea cpu9260 cpu9260 cpu9260:CPU9260 Eric Benard eric@eukrea.com +Active arm arm926ejs at91 eukrea cpu9260 cpu9260_128M cpu9260:CPU9260,CPU9260_128M Eric Benard eric@eukrea.com +Active arm arm926ejs at91 eukrea cpu9260 cpu9260_nand cpu9260:CPU9260,NANDBOOT Eric Benard eric@eukrea.com +Active arm arm926ejs at91 eukrea cpu9260 cpu9260_nand_128M cpu9260:CPU9260,CPU9260_128M,NANDBOOT Eric Benard eric@eukrea.com +Active arm arm926ejs at91 eukrea cpu9260 cpu9G20 cpu9260:CPU9G20 Eric Benard eric@eukrea.com +Active arm arm926ejs at91 eukrea cpu9260 cpu9G20_128M cpu9260:CPU9G20,CPU9G20_128M Eric Benard eric@eukrea.com +Active arm arm926ejs at91 eukrea cpu9260 cpu9G20_nand cpu9260:CPU9G20,NANDBOOT Eric Benard eric@eukrea.com +Active arm arm926ejs at91 eukrea cpu9260 cpu9G20_nand_128M cpu9260:CPU9G20,CPU9G20_128M,NANDBOOT Eric Benard eric@eukrea.com +Active arm arm926ejs at91 ronetix pm9261 pm9261 pm9261:AT91SAM9261 Ilko Iliev iliev@ronetix.at +Active arm arm926ejs at91 ronetix pm9263 pm9263 pm9263:AT91SAM9263 Ilko Iliev iliev@ronetix.at +Active arm arm926ejs at91 ronetix pm9g45 pm9g45 pm9g45:AT91SAM9G45 Ilko Iliev iliev@ronetix.at +Active arm arm926ejs at91 taskit stamp9g20 portuxg20 stamp9g20:AT91SAM9G20,PORTUXG20 Markus Hubig mhubig@imko.de +Active arm arm926ejs at91 taskit stamp9g20 stamp9g20 stamp9g20:AT91SAM9G20 Markus Hubig mhubig@imko.de +Active arm arm926ejs davinci ait cam_enc_4xx cam_enc_4xx cam_enc_4xx Heiko Schocher hs@denx.de +Active arm arm926ejs davinci Barix ipam390 ipam390 - Heiko Schocher hs@denx.de +Active arm arm926ejs davinci davinci da8xxevm da830evm - Nick Thompson nick.thompson@gefanuc.com +Active arm arm926ejs davinci davinci da8xxevm da850_am18xxevm da850evm:DA850_AM18X_EVM,MAC_ADDR_IN_EEPROM,SYS_I2C_EEPROM_ADDR_LEN=2,SYS_I2C_EEPROM_ADDR=0x50 Sudhakar Rajashekhara sudhakar.raj@ti.com +Active arm arm926ejs davinci davinci da8xxevm da850evm da850evm:MAC_ADDR_IN_SPIFLASH Sudhakar Rajashekhara sudhakar.raj@ti.com +Active arm arm926ejs davinci davinci da8xxevm da850evm_direct_nor da850evm:MAC_ADDR_IN_SPIFLASH,USE_NOR,DIRECT_NOR_BOOT Sudhakar Rajashekhara sudhakar.raj@ti.com +Active arm arm926ejs davinci davinci da8xxevm hawkboard - Syed Mohammed Khasim sm.khasim@gmail.com:Sughosh Ganu urwithsughosh@gmail.com +Active arm arm926ejs davinci davinci da8xxevm hawkboard_uart hawkboard:UART_U_BOOT Syed Mohammed Khasim sm.khasim@gmail.com:Sughosh Ganu urwithsughosh@gmail.com +Active arm arm926ejs davinci davinci dm355evm davinci_dm355evm - Sandeep Paulraj s-paulraj@ti.com +Active arm arm926ejs davinci davinci dm355leopard davinci_dm355leopard - Sandeep Paulraj s-paulraj@ti.com +Active arm arm926ejs davinci davinci dm365evm davinci_dm365evm - Sandeep Paulraj s-paulraj@ti.com +Active arm arm926ejs davinci davinci dm6467evm davinci_dm6467evm davinci_dm6467evm:REFCLK_FREQ=27000000 Sandeep Paulraj s-paulraj@ti.com +Active arm arm926ejs davinci davinci dm6467evm davinci_dm6467Tevm davinci_dm6467evm:DAVINCI_DM6467TEVM,REFCLK_FREQ=33000000 Sandeep Paulraj s-paulraj@ti.com +Active arm arm926ejs davinci davinci dvevm davinci_dvevm - - +Active arm arm926ejs davinci davinci ea20 ea20 - Stefano Babic sbabic@denx.de +Active arm arm926ejs davinci davinci schmoogie davinci_schmoogie - - +Active arm arm926ejs davinci davinci sffsdr davinci_sffsdr - - +Active arm arm926ejs davinci davinci sonata davinci_sonata - - +Active arm arm926ejs davinci enbw enbw_cmc enbw_cmc - Heiko Schocher hs@denx.de +Active arm arm926ejs davinci omicron calimain calimain - Manfred Rudigier manfred.rudigier@omicron.at:Christian Riesch christian.riesch@omicron.at +Active arm arm926ejs kirkwood buffalo lsxl lschlv2 lsxl:LSCHLV2 Michael Walle michael@walle.cc +Active arm arm926ejs kirkwood buffalo lsxl lsxhl lsxl:LSXHL Michael Walle michael@walle.cc +Active arm arm926ejs kirkwood cloudengines - pogo_e02 - Dave Purdy david.c.purdy@gmail.com +Active arm arm926ejs kirkwood d-link - dns325 - Stefan Herbrechtsmeier stefan@code.herbrechtsmeier.net +Active arm arm926ejs kirkwood iomega - iconnect - Luka Perkov luka@openwrt.org +Active arm arm926ejs kirkwood karo tk71 tk71 - - +Active arm arm926ejs kirkwood keymile km_arm km_kirkwood km_kirkwood:KM_KIRKWOOD Valentin Longchamp valentin.longchamp@keymile.com +Active arm arm926ejs kirkwood keymile km_arm km_kirkwood_pci km_kirkwood:KM_KIRKWOOD_PCI Valentin Longchamp valentin.longchamp@keymile.com +Active arm arm926ejs kirkwood keymile km_arm kmcoge5un km_kirkwood:KM_COGE5UN Valentin Longchamp valentin.longchamp@keymile.com +Active arm arm926ejs kirkwood keymile km_arm kmnusa km_kirkwood:KM_NUSA Valentin Longchamp valentin.longchamp@keymile.com +Active arm arm926ejs kirkwood keymile km_arm kmsuv31 km_kirkwood:KM_SUV31 Valentin Longchamp valentin.longchamp@keymile.com +Active arm arm926ejs kirkwood keymile km_arm mgcoge3un km_kirkwood:KM_MGCOGE3UN Valentin Longchamp valentin.longchamp@keymile.com +Active arm arm926ejs kirkwood keymile km_arm portl2 km_kirkwood:KM_PORTL2 Valentin Longchamp valentin.longchamp@keymile.com +Active arm arm926ejs kirkwood LaCie net2big_v2 d2net_v2 lacie_kw:D2NET_V2 - +Active arm arm926ejs kirkwood LaCie net2big_v2 net2big_v2 lacie_kw:NET2BIG_V2 Simon Guinot simon.guinot@sequanux.org +Active arm arm926ejs kirkwood LaCie netspace_v2 inetspace_v2 lacie_kw:INETSPACE_V2 Simon Guinot simon.guinot@sequanux.org +Active arm arm926ejs kirkwood LaCie netspace_v2 netspace_lite_v2 lacie_kw:NETSPACE_LITE_V2 - +Active arm arm926ejs kirkwood LaCie netspace_v2 netspace_max_v2 lacie_kw:NETSPACE_MAX_V2 Simon Guinot simon.guinot@sequanux.org +Active arm arm926ejs kirkwood LaCie netspace_v2 netspace_mini_v2 lacie_kw:NETSPACE_MINI_V2 - +Active arm arm926ejs kirkwood LaCie netspace_v2 netspace_v2 lacie_kw:NETSPACE_V2 Simon Guinot simon.guinot@sequanux.org +Active arm arm926ejs kirkwood LaCie wireless_space wireless_space - - +Active arm arm926ejs kirkwood Marvell - dreamplug - Jason Cooper u-boot@lakedaemon.net +Active arm arm926ejs kirkwood Marvell - guruplug - Siddarth Gore gores@marvell.com +Active arm arm926ejs kirkwood Marvell - mv88f6281gtw_ge - Prafulla Wadaskar prafulla@marvell.com +Active arm arm926ejs kirkwood Marvell - rd6281a - Prafulla Wadaskar prafulla@marvell.com +Active arm arm926ejs kirkwood Marvell - sheevaplug - Prafulla Wadaskar prafulla@marvell.com +Active arm arm926ejs kirkwood Marvell openrd openrd_base openrd:BOARD_IS_OPENRD_BASE Prafulla Wadaskar prafulla@marvell.com +Active arm arm926ejs kirkwood Marvell openrd openrd_client openrd:BOARD_IS_OPENRD_CLIENT - +Active arm arm926ejs kirkwood Marvell openrd openrd_ultimate openrd:BOARD_IS_OPENRD_ULTIMATE - +Active arm arm926ejs kirkwood raidsonic ib62x0 ib62x0 - Luka Perkov luka@openwrt.org +Active arm arm926ejs kirkwood Seagate - dockstar - Eric Cooper ecc@cmu.edu +Active arm arm926ejs kirkwood Seagate - goflexhome - Suriyan Ramasami suriyan.r@gmail.com +Active arm arm926ejs lpc32xx timll devkit3250 devkit3250 - Vladimir Zapolskiy vz@mleia.com +Active arm arm926ejs mb86r0x syteco jadecpu jadecpu - Matthias Weisser weisserm@arcor.de +Active arm arm926ejs mx25 freescale mx25pdk mx25pdk mx25pdk:IMX_CONFIG=board/freescale/mx25pdk/imximage.cfg Fabio Estevam fabio.estevam@freescale.com +Active arm arm926ejs mx25 karo tx25 tx25 - John Rigby jcrigby@gmail.com +Active arm arm926ejs mx25 syteco zmx25 zmx25 - Matthias Weisser weisserm@arcor.de +Active arm arm926ejs mx27 logicpd imx27lite imx27lite - Wolfgang Denk wd@denx.de +Active arm arm926ejs mx27 logicpd imx27lite magnesium - Heiko Schocher hs@denx.de +Active arm arm926ejs mxs bluegiga apx4devkit apx4devkit apx4devkit Lauri Hintsala lauri.hintsala@bluegiga.com +Active arm arm926ejs mxs denx m28evk m28evk m28evk Marek Vasut marek.vasut@gmail.com +Active arm arm926ejs mxs freescale mx23evk mx23evk mx23evk Otavio Salvador otavio@ossystems.com.br +Active arm arm926ejs mxs freescale mx28evk mx28evk mx28evk:ENV_IS_IN_MMC Fabio Estevam fabio.estevam@freescale.com +Active arm arm926ejs mxs freescale mx28evk mx28evk_auart_console mx28evk:MXS_AUART,MXS_AUART_BASE=MXS_UARTAPP3_BASE,ENV_IS_IN_MMC Fabio Estevam fabio.estevam@freescale.com +Active arm arm926ejs mxs freescale mx28evk mx28evk_nand mx28evk:ENV_IS_IN_NAND Fabio Estevam fabio.estevam@freescale.com +Active arm arm926ejs mxs olimex mx23_olinuxino mx23_olinuxino mx23_olinuxino Marek Vasut marek.vasut@gmail.com +Active arm arm926ejs mxs schulercontrol sc_sps_1 sc_sps_1 - Marek Vasut marek.vasut@gmail.com +Active arm arm926ejs nomadik st nhk8815 nhk8815 - Nomadik Linux Team STN_WMM_nomadik_linux@list.st.com:Alessandro Rubini rubini@unipv.it +Active arm arm926ejs nomadik st nhk8815 nhk8815_onenand nhk8815:BOOT_ONENAND Nomadik Linux Team STN_WMM_nomadik_linux@list.st.com:Alessandro Rubini rubini@unipv.it +Active arm arm926ejs omap ti - omap5912osk - Rishi Bhattacharya rishi@ti.com +Active arm arm926ejs omap ti omap730p2 omap730p2 omap730p2:CS3_BOOT Dave Peverley dpeverley@mpc-data.co.uk +Active arm arm926ejs omap ti omap730p2 omap730p2_cs0boot omap730p2:CS0_BOOT Dave Peverley dpeverley@mpc-data.co.uk +Active arm arm926ejs omap ti omap730p2 omap730p2_cs3boot omap730p2:CS3_BOOT Dave Peverley dpeverley@mpc-data.co.uk +Active arm arm926ejs orion5x LaCie - edminiv2 - Albert ARIBAUD albert.u.boot@aribaud.net +Active arm arm926ejs pantheon Marvell - dkb - Lei Wen leiwen@marvell.com +Active arm arm926ejs spear spear - x600 x600 Stefan Roese sr@denx.de +Active arm arm926ejs spear spear spear300 spear300 spear3xx_evb:spear300 Vipin Kumar vipin.kumar@st.com +Active arm arm926ejs spear spear spear300 spear300_nand spear3xx_evb:spear300,nand - +Active arm arm926ejs spear spear spear300 spear300_usbtty spear3xx_evb:spear300,usbtty - +Active arm arm926ejs spear spear spear300 spear300_usbtty_nand spear3xx_evb:spear300,usbtty,nand - +Active arm arm926ejs spear spear spear310 spear310 spear3xx_evb:spear310 Vipin Kumar vipin.kumar@st.com +Active arm arm926ejs spear spear spear310 spear310_nand spear3xx_evb:spear310,nand - +Active arm arm926ejs spear spear spear310 spear310_pnor spear3xx_evb:spear310,FLASH_PNOR - +Active arm arm926ejs spear spear spear310 spear310_usbtty spear3xx_evb:spear310,usbtty - +Active arm arm926ejs spear spear spear310 spear310_usbtty_nand spear3xx_evb:spear310,usbtty,nand - +Active arm arm926ejs spear spear spear310 spear310_usbtty_pnor spear3xx_evb:spear310,usbtty,FLASH_PNOR - +Active arm arm926ejs spear spear spear320 spear320 spear3xx_evb:spear320 Vipin Kumar vipin.kumar@st.com +Active arm arm926ejs spear spear spear320 spear320_nand spear3xx_evb:spear320,nand - +Active arm arm926ejs spear spear spear320 spear320_pnor spear3xx_evb:spear320,FLASH_PNOR - +Active arm arm926ejs spear spear spear320 spear320_usbtty spear3xx_evb:spear320,usbtty - +Active arm arm926ejs spear spear spear320 spear320_usbtty_nand spear3xx_evb:spear320,usbtty,nand - +Active arm arm926ejs spear spear spear320 spear320_usbtty_pnor spear3xx_evb:spear320,usbtty,FLASH_PNOR - +Active arm arm926ejs spear spear spear600 spear600 spear6xx_evb:spear600 Vipin Kumar vipin.kumar@st.com +Active arm arm926ejs spear spear spear600 spear600_nand spear6xx_evb:spear600,nand - +Active arm arm926ejs spear spear spear600 spear600_usbtty spear6xx_evb:spear600,usbtty - +Active arm arm926ejs spear spear spear600 spear600_usbtty_nand spear6xx_evb:spear600,usbtty,nand - +Active arm arm926ejs versatile armltd versatile versatileab versatile:ARCH_VERSATILE_AB - +Active arm arm926ejs versatile armltd versatile versatilepb versatile:ARCH_VERSATILE_PB - +Active arm arm926ejs versatile armltd versatile versatileqemu versatile:ARCH_VERSATILE_QEMU,ARCH_VERSATILE_PB - +Active arm arm946es - armltd integrator integratorap_cm946es integratorap:CM946ES Linus Walleij linus.walleij@linaro.org +Active arm arm946es - armltd integrator integratorcp_cm946es integratorcp:CM946ES Linus Walleij linus.walleij@linaro.org +Active arm armv7 - armltd vexpress vexpress_ca15_tc2 - - +Active arm armv7 - armltd vexpress vexpress_ca5x2 - Matt Waddel matt.waddel@linaro.org +Active arm armv7 - armltd vexpress vexpress_ca9x4 - Matt Waddel matt.waddel@linaro.org +Active arm armv7 am33xx isee igep0033 igep0033 - Enric Balletbo i Serra eballetbo@iseebcn.com +Active arm armv7 am33xx phytec pcm051 pcm051 pcm051 Lars Poeschel poeschel@lemonage.de +Active arm armv7 am33xx siemens dxr2 dxr2 - Roger Meier r.meier@siemens.com +Active arm armv7 am33xx siemens pxm2 pxm2 - Roger Meier r.meier@siemens.com +Active arm armv7 am33xx siemens rut rut - Roger Meier r.meier@siemens.com +Active arm armv7 am33xx ti am335x am335x_boneblack am335x_evm:SERIAL1,CONS_INDEX=1,EMMC_BOOT Tom Rini trini@ti.com +Active arm armv7 am33xx ti am335x am335x_evm am335x_evm:SERIAL1,CONS_INDEX=1,NAND Tom Rini trini@ti.com +Active arm armv7 am33xx ti am335x am335x_evm_nor am335x_evm:SERIAL1,CONS_INDEX=1,NAND,NOR Tom Rini trini@ti.com +Active arm armv7 am33xx ti am335x am335x_evm_norboot am335x_evm:SERIAL1,CONS_INDEX=1,NOR,NOR_BOOT Tom Rini trini@ti.com +Active arm armv7 am33xx ti am335x am335x_evm_spiboot am335x_evm:SERIAL1,CONS_INDEX=1,SPI_BOOT Tom Rini trini@ti.com +Active arm armv7 am33xx ti am335x am335x_evm_uart1 am335x_evm:SERIAL2,CONS_INDEX=1,NAND Tom Rini trini@ti.com +Active arm armv7 am33xx ti am335x am335x_evm_uart2 am335x_evm:SERIAL3,CONS_INDEX=1,NAND Tom Rini trini@ti.com +Active arm armv7 am33xx ti am335x am335x_evm_uart3 am335x_evm:SERIAL4,CONS_INDEX=1,NAND Tom Rini trini@ti.com +Active arm armv7 am33xx ti am335x am335x_evm_uart4 am335x_evm:SERIAL5,CONS_INDEX=1,NAND Tom Rini trini@ti.com +Active arm armv7 am33xx ti am335x am335x_evm_uart5 am335x_evm:SERIAL6,CONS_INDEX=1,NAND Tom Rini trini@ti.com +Active arm armv7 am33xx ti am335x am335x_evm_usbspl am335x_evm:SERIAL1,CONS_INDEX=1,NAND,SPL_USBETH_SUPPORT Tom Rini trini@ti.com +Active arm armv7 am33xx ti am43xx am43xx_evm am43xx_evm:SERIAL1,CONS_INDEX=1 - +Active arm armv7 am33xx ti ti814x ti814x_evm - Matt Porter mporter@ti.com +Active arm armv7 am33xx ti ti816x ti816x_evm - - +Active arm armv7 at91 atmel sama5d3xek sama5d3xek_mmc sama5d3xek:SAMA5D3,SYS_USE_MMC Bo Shen voice.shen@atmel.com +Active arm armv7 at91 atmel sama5d3xek sama5d3xek_nandflash sama5d3xek:SAMA5D3,SYS_USE_NANDFLASH Bo Shen voice.shen@atmel.com +Active arm armv7 at91 atmel sama5d3xek sama5d3xek_spiflash sama5d3xek:SAMA5D3,SYS_USE_SERIALFLASH Bo Shen voice.shen@atmel.com +Active arm armv7 exynos samsung arndale arndale - Inderpal Singh inderpal.singh@linaro.org +Active arm armv7 exynos samsung origen origen - Chander Kashyap k.chander@samsung.com +Active arm armv7 exynos samsung smdk5250 smdk5250 - Chander Kashyap k.chander@samsung.com +Active arm armv7 exynos samsung smdk5250 snow - Rajeshwari Shinde rajeshwari.s@samsung.com +Active arm armv7 exynos samsung smdkv310 smdkv310 - Chander Kashyap k.chander@samsung.com +Active arm armv7 exynos samsung trats trats - Lukasz Majewski l.majewski@samsung.com +Active arm armv7 exynos samsung universal_c210 s5pc210_universal - Minkyu Kang mk7.kang@samsung.com +Active arm armv7 highbank - highbank highbank - Rob Herring rob.herring@calxeda.com +Active arm armv7 mx5 denx m53evk m53evk m53evk:IMX_CONFIG=board/denx/m53evk/imximage.cfg Marek Vasut marek.vasut@gmail.com +Active arm armv7 mx5 esg ima3-mx53 ima3-mx53 ima3-mx53:IMX_CONFIG=board/esg/ima3-mx53/imximage.cfg - +Active arm armv7 mx5 freescale mx51evk mx51evk mx51evk:IMX_CONFIG=board/freescale/mx51evk/imximage.cfg Stefano Babic sbabic@denx.de +Active arm armv7 mx5 freescale mx53ard mx53ard mx53ard:IMX_CONFIG=board/freescale/mx53ard/imximage_dd3.cfg Fabio Estevam fabio.estevam@freescale.com +Active arm armv7 mx5 freescale mx53evk mx53evk mx53evk:IMX_CONFIG=board/freescale/mx53evk/imximage.cfg Jason Liu r64343@freescale.com +Active arm armv7 mx5 freescale mx53loco mx53loco mx53loco:IMX_CONFIG=board/freescale/mx53loco/imximage.cfg Jason Liu r64343@freescale.com +Active arm armv7 mx5 freescale mx53smd mx53smd mx53smd:IMX_CONFIG=board/freescale/mx53smd/imximage.cfg Fabio Estevam fabio.estevam@freescale.com +Active arm armv7 mx5 genesi mx51_efikamx mx51_efikamx mx51_efikamx:MACH_TYPE=MACH_TYPE_MX51_EFIKAMX,IMX_CONFIG=board/genesi/mx51_efikamx/imximage_mx.cfg - +Active arm armv7 mx5 genesi mx51_efikamx mx51_efikasb mx51_efikamx:MACH_TYPE=MACH_TYPE_MX51_EFIKASB,IMX_CONFIG=board/genesi/mx51_efikamx/imximage_sb.cfg - +Active arm armv7 mx5 ttcontrol vision2 vision2 vision2:IMX_CONFIG=board/ttcontrol/vision2/imximage_hynix.cfg Stefano Babic sbabic@denx.de +Active arm armv7 mx6 - wandboard wandboard_dl wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024 Fabio Estevam fabio.estevam@freescale.com +Active arm armv7 mx6 - wandboard wandboard_quad wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048 Fabio Estevam fabio.estevam@freescale.com +Active arm armv7 mx6 - wandboard wandboard_solo wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512 Fabio Estevam fabio.estevam@freescale.com +Active arm armv7 mx6 boundary nitrogen6x mx6qsabrelite nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,SABRELITE Eric Nelson eric.nelson@boundarydevices.com +Active arm armv7 mx6 boundary nitrogen6x nitrogen6dl nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024 Eric Nelson eric.nelson@boundarydevices.com +Active arm armv7 mx6 boundary nitrogen6x nitrogen6dl2g nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg,MX6DL,DDR_MB=2048 Eric Nelson eric.nelson@boundarydevices.com +Active arm armv7 mx6 boundary nitrogen6x nitrogen6q nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024 Eric Nelson eric.nelson@boundarydevices.com +Active arm armv7 mx6 boundary nitrogen6x nitrogen6q2g nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048 Eric Nelson eric.nelson@boundarydevices.com +Active arm armv7 mx6 boundary nitrogen6x nitrogen6s nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512 Eric Nelson eric.nelson@boundarydevices.com +Active arm armv7 mx6 boundary nitrogen6x nitrogen6s1g nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024 Eric Nelson eric.nelson@boundarydevices.com +Active arm armv7 mx6 congatec cgtqmx6eval cgtqmx6qeval cgtqmx6eval:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg,MX6Q Leo Sartre lsartre@adeneo-embedded.com +Active arm armv7 mx6 freescale mx6qarm2 mx6qarm2 mx6qarm2:IMX_CONFIG=board/freescale/mx6qarm2/imximage.cfg Jason Liu r64343@freescale.com +Active arm armv7 mx6 freescale mx6qsabreauto mx6qsabreauto mx6qsabreauto:IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg,MX6Q Fabio Estevam fabio.estevam@freescale.com +Active arm armv7 mx6 freescale mx6sabresd mx6dlsabresd mx6sabresd:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL Fabio Estevam fabio.estevam@freescale.com +Active arm armv7 mx6 freescale mx6sabresd mx6qsabresd mx6sabresd:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg,MX6Q Fabio Estevam fabio.estevam@freescale.com +Active arm armv7 mx6 freescale mx6slevk mx6slevk mx6slevk:IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL Fabio Estevam fabio.estevam@freescale.com +Active arm armv7 mx6 freescale titanium titanium titanium:IMX_CONFIG=board/freescale/titanium/imximage.cfg Stefan Roese sr@denx.de +Active arm armv7 omap3 - overo omap3_overo - Steve Sakoman sakoman@gmail.com +Active arm armv7 omap3 - pandora omap3_pandora - Grazvydas Ignotas notasas@gmail.com +Active arm armv7 omap3 8dtech eco5pk eco5pk - Raphael Assenat raph@8d.com +Active arm armv7 omap3 comelit dig297 dig297 - Luca Ceresoli luca.ceresoli@comelit.it +Active arm armv7 omap3 compulab cm_t35 cm_t35 - Igor Grinberg grinberg@compulab.co.il +Active arm armv7 omap3 corscience tricorder tricorder - Thomas Weber weber@corscience.de +Active arm armv7 omap3 htkw mcx mcx - Ilya Yanok yanok@emcraft.com +Active arm armv7 omap3 isee igep00x0 igep0020 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0020,BOOT_ONENAND Enric Balletbo i Serra eballetbo@iseebcn.com +Active arm armv7 omap3 isee igep00x0 igep0020_nand igep00x0:MACH_TYPE=MACH_TYPE_IGEP0020,BOOT_NAND - +Active arm armv7 omap3 isee igep00x0 igep0030 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_ONENAND Enric Balletbo i Serra eballetbo@iseebcn.com +Active arm armv7 omap3 isee igep00x0 igep0030_nand igep00x0:MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_NAND - +Active arm armv7 omap3 isee igep00x0 igep0032 igep00x0:MACH_TYPE=MACH_TYPE_IGEP0032,BOOT_ONENAND Enric Balletbo i Serra eballetbo@iseebcn.com +Active arm armv7 omap3 logicpd am3517evm am3517_evm - Vaibhav Hiremath hvaibhav@ti.com +Active arm armv7 omap3 logicpd omap3som omap3_logic - Peter Barada peter.barada@logicpd.com +Active arm armv7 omap3 logicpd zoom1 omap3_zoom1 - Nishanth Menon nm@ti.com +Active arm armv7 omap3 logicpd zoom2 omap3_zoom2 - Tom Rix Tom.Rix@windriver.com +Active arm armv7 omap3 matrix_vision mvblx omap3_mvblx - Michael Jones michael.jones@matrix-vision.de +Active arm armv7 omap3 nokia rx51 nokia_rx51 - Pali Rohár pali.rohar@gmail.com +Active arm armv7 omap3 technexion twister twister - Stefano Babic sbabic@denx.de +Active arm armv7 omap3 teejet mt_ventoux mt_ventoux - Stefano Babic sbabic@denx.de +Active arm armv7 omap3 ti am3517crane am3517_crane - Nagendra T S nagendra@mistralsolutions.com +Active arm armv7 omap3 ti beagle omap3_beagle - Tom Rini trini@ti.com +Active arm armv7 omap3 ti evm omap3_evm - Tom Rini trini@ti.com +Active arm armv7 omap3 ti evm omap3_evm_quick_mmc - - +Active arm armv7 omap3 ti evm omap3_evm_quick_nand - - +Active arm armv7 omap3 ti sdp3430 omap3_sdp3430 - Nishanth Menon nm@ti.com +Active arm armv7 omap3 timll devkit8000 devkit8000 - Thomas Weber weber@corscience.de +Active arm armv7 omap4 ti panda omap4_panda - Sricharan R r.sricharan@ti.com +Active arm armv7 omap4 ti sdp4430 omap4_sdp4430 - Sricharan R r.sricharan@ti.com +Active arm armv7 omap5 ti dra7xx dra7xx_evm - Lokesh Vutla lokeshvutla@ti.com +Active arm armv7 omap5 ti omap5_uevm omap5_uevm - - +Active arm armv7 rmobile atmark-techno armadillo-800eva armadillo-800eva - Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com +Active arm armv7 rmobile kmc kzm9g kzm9g - Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com:Tetsuyuki Kobayashi koba@kmckk.co.jp +Active arm armv7 s5pc1xx samsung goni s5p_goni - Minkyu Kang mk7.kang@samsung.com +Active arm armv7 s5pc1xx samsung smdkc100 smdkc100 - Minkyu Kang mk7.kang@samsung.com +Active arm armv7 socfpga altera socfpga socfpga_cyclone5 - - +Active arm armv7 u8500 st-ericsson snowball snowball - Mathieu Poirier mathieu.poirier@linaro.org +Active arm armv7 u8500 st-ericsson u8500 u8500_href - - +Active arm armv7 vf610 freescale vf610twr vf610twr vf610twr:IMX_CONFIG=board/freescale/vf610twr/imximage.cfg Alison Wang b18965@freescale.com +Active arm armv7 zynq xilinx zynq zynq - Michal Simek monstr@monstr.eu +Active arm armv7 zynq xilinx zynq zynq_dcc zynq:ZYNQ_DCC Michal Simek monstr@monstr.eu +Active arm armv7:arm720t tegra114 nvidia dalmore dalmore - Tom Warren twarren@nvidia.com +Active arm armv7:arm720t tegra20 avionic-design medcom-wide medcom-wide - Thierry Reding thierry.reding@avionic-design.de +Active arm armv7:arm720t tegra20 avionic-design plutux plutux - Thierry Reding thierry.reding@avionic-design.de +Active arm armv7:arm720t tegra20 avionic-design tec tec - Thierry Reding thierry.reding@avionic-design.de +Active arm armv7:arm720t tegra20 compal paz00 paz00 - Tom Warren twarren@nvidia.com:Stephen Warren swarren@nvidia.com +Active arm armv7:arm720t tegra20 compulab trimslice trimslice - Tom Warren twarren@nvidia.com:Stephen Warren swarren@nvidia.com +Active arm armv7:arm720t tegra20 nvidia harmony harmony - Tom Warren twarren@nvidia.com +Active arm armv7:arm720t tegra20 nvidia seaboard seaboard - Tom Warren twarren@nvidia.com +Active arm armv7:arm720t tegra20 nvidia ventana ventana - Tom Warren twarren@nvidia.com:Stephen Warren swarren@nvidia.com +Active arm armv7:arm720t tegra20 nvidia whistler whistler - Tom Warren twarren@nvidia.com:Stephen Warren swarren@nvidia.com +Active arm armv7:arm720t tegra20 toradex colibri_t20_iris colibri_t20_iris - Lucas Stach dev@lynxeye.de +Active arm armv7:arm720t tegra30 nvidia beaver beaver - Tom Warren twarren@nvidia.com:Stephen Warren swarren@nvidia.com +Active arm armv7:arm720t tegra30 nvidia cardhu cardhu - Tom Warren twarren@nvidia.com +Active arm ixp - - - actux2 - Michael Schwingen michael@schwingen.org +Active arm ixp - - - actux3 - Michael Schwingen michael@schwingen.org +Active arm ixp - - - actux4 - Michael Schwingen michael@schwingen.org +Active arm ixp - - - dvlhost - Michael Schwingen michael@schwingen.org +Active arm ixp - - actux1 actux1_4_16 actux1:FLASH2X2 Michael Schwingen michael@schwingen.org +Active arm ixp - - actux1 actux1_4_32 actux1:FLASH2X2,RAM_32MB Michael Schwingen michael@schwingen.org +Active arm ixp - - actux1 actux1_8_16 actux1:FLASH1X8 Michael Schwingen michael@schwingen.org +Active arm ixp - - actux1 actux1_8_32 actux1:FLASH1X8,RAM_32MB Michael Schwingen michael@schwingen.org +Active arm ixp - prodrive pdnb3 pdnb3 - Stefan Roese sr@denx.de +Active arm ixp - prodrive pdnb3 scpu pdnb3:SCPU Stefan Roese sr@denx.de +Active arm pxa - - - balloon3 - Marek Vasut marek.vasut@gmail.com +Active arm pxa - - - h2200 - Lukasz Dalek luk0104@gmail.com +Active arm pxa - - - palmld - Marek Vasut marek.vasut@gmail.com +Active arm pxa - - - palmtc - Marek Vasut marek.vasut@gmail.com +Active arm pxa - - - palmtreo680 - Mike Dunn mikedunn@newsguy.com +Active arm pxa - - - pxa255_idp - Cliff Brake cliff.brake@gmail.com +Active arm pxa - - - trizepsiv - Stefano Babic sbabic@denx.de +Active arm pxa - - - xaeniax - - +Active arm pxa - - - zipitz2 - Marek Vasut marek.vasut@gmail.com +Active arm pxa - - trizepsiv polaris trizepsiv:POLARIS Stefano Babic sbabic@denx.de +Active arm pxa - - vpac270 vpac270_nor_128 vpac270:NOR,RAM_128M Marek Vasut marek.vasut@gmail.com +Active arm pxa - - vpac270 vpac270_nor_256 vpac270:NOR,RAM_256M Marek Vasut marek.vasut@gmail.com +Active arm pxa - - vpac270 vpac270_ond_256 vpac270:ONENAND,RAM_256M Marek Vasut marek.vasut@gmail.com +Active arm pxa - icpdas lp8x4x lp8x4x - Sergey Yanovich ynvich@gmail.com +Active arm pxa - toradex - colibri_pxa270 - Marek Vasut marek.vasut@gmail.com +Active arm sa1100 - - - jornada - Kristoffer Ericson kristoffer.ericson@gmail.com +Active avr32 at32ap at32ap700x atmel - atngw100 - Haavard Skinnemoen haavard.skinnemoen@atmel.com +Active avr32 at32ap at32ap700x atmel - atngw100mkii - Andreas Bießmann andreas.devel@googlemail.com +Active avr32 at32ap at32ap700x atmel atstk1000 atstk1002 - Haavard Skinnemoen haavard.skinnemoen@atmel.com +Active avr32 at32ap at32ap700x atmel atstk1000 atstk1003 - Haavard Skinnemoen haavard.skinnemoen@atmel.com +Active avr32 at32ap at32ap700x atmel atstk1000 atstk1004 - Haavard Skinnemoen haavard.skinnemoen@atmel.com +Active avr32 at32ap at32ap700x atmel atstk1000 atstk1006 - Haavard Skinnemoen haavard.skinnemoen@atmel.com +Active avr32 at32ap at32ap700x earthlcd - favr-32-ezkit - Hans-Christian Egtvedt hans-christian.egtvedt@atmel.com +Active avr32 at32ap at32ap700x in-circuit - grasshopper - Andreas Bießmann andreas.devel@googlemail.com +Active avr32 at32ap at32ap700x mimc - mimc200 - Mark Jackson mpfj@mimc.co.uk +Active avr32 at32ap at32ap700x miromico - hammerhead - Julien May julien.may@miromico.ch:Alex Raimondi alex.raimondi@miromico.ch +Active blackfin blackfin - - - bct-brettl2 - Peter Meerwald devel@bct-electronic.com +Active blackfin blackfin - - - bf506f-ezkit - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf518f-ezbrd - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf525-ucr2 - Haitao Zhang hzhang@ucrobotics.com:Chong Huang chuang@ucrobotics.com +Active blackfin blackfin - - - bf526-ezbrd - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf527-ad7160-eval - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf527-ezkit - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf527-sdp - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf533-ezkit - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf533-stamp - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf537-minotaur - Martin Strubel strubel@section5.ch +Active blackfin blackfin - - - bf537-pnav - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf537-srv1 - Martin Strubel strubel@section5.ch +Active blackfin blackfin - - - bf537-stamp - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf538f-ezkit - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf548-ezkit - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf561-acvilon - Anton Shurpin shurpin.aa@niistt.ru:Valentin Yakovenkov yakovenkov@niistt.ru +Active blackfin blackfin - - - bf561-ezkit - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - bf609-ezkit - Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active blackfin blackfin - - - blackstamp - Wojtek Skulski skulski@pas.rochester.edu:Wojtek Skulski info@skutek.com:Benjamin Matthews mben12@gmail.com +Active blackfin blackfin - - - blackvme - Wojtek Skulski skulski@pas.rochester.edu:Wojtek Skulski info@skutek.com:Benjamin Matthews mben12@gmail.com +Active blackfin blackfin - - - br4 - Dimitar Penev dpn@switchfin.org +Active blackfin blackfin - - - cm-bf527 - Bluetechnix Tinyboards bluetechnix@blackfin.uclinux.org +Active blackfin blackfin - - - cm-bf533 - Bluetechnix Tinyboards bluetechnix@blackfin.uclinux.org +Active blackfin blackfin - - - cm-bf537e - Bluetechnix Tinyboards bluetechnix@blackfin.uclinux.org +Active blackfin blackfin - - - cm-bf537u - Bluetechnix Tinyboards bluetechnix@blackfin.uclinux.org +Active blackfin blackfin - - - cm-bf548 - Bluetechnix Tinyboards bluetechnix@blackfin.uclinux.org +Active blackfin blackfin - - - cm-bf561 - Bluetechnix Tinyboards bluetechnix@blackfin.uclinux.org +Active blackfin blackfin - - - dnp5370 - M.Hasewinkel (MHA) info@ssv-embedded.de +Active blackfin blackfin - - - ibf-dsp561 - I-SYST Micromodule support@i-syst.com +Active blackfin blackfin - - - ip04 - Brent Kandetzki brentk@teleco.com +Active blackfin blackfin - - - pr1 - Dimitar Penev dpn@switchfin.org +Active blackfin blackfin - - - tcm-bf518 - Bluetechnix Tinyboards bluetechnix@blackfin.uclinux.org +Active blackfin blackfin - - - tcm-bf537 - Bluetechnix Tinyboards bluetechnix@blackfin.uclinux.org +Active blackfin blackfin - - bf527-ezkit bf527-ezkit-v2 bf527-ezkit:BF527_EZKIT_REV_2_1 Sonic Zhang sonic.adi@gmail.com:Blackfin Team u-boot-devel@blackfin.uclinux.org +Active m68k mcf5227x - freescale m52277evb M52277EVB M52277EVB:SYS_SPANSION_BOOT,SYS_TEXT_BASE=0x00000000 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf5227x - freescale m52277evb M52277EVB_stmicro M52277EVB:CF_SBF,SYS_STMICRO_BOOT,SYS_TEXT_BASE=0x43E00000 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf523x - freescale m5235evb M5235EVB M5235EVB:SYS_TEXT_BASE=0xFFE00000 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf523x - freescale m5235evb M5235EVB_Flash32 M5235EVB:NORFLASH_PS32BIT,SYS_TEXT_BASE=0xFFC00000 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf52x2 - - - idmr - - +Active m68k mcf52x2 - - cobra5272 cobra5272 - - +Active m68k mcf52x2 - BuS eb_cpu5282 eb_cpu5282 eb_cpu5282:SYS_TEXT_BASE=0xFF000000,SYS_MONITOR_BASE=0xFF000400 Jens Scharsig esw@bus-elektronik.de +Active m68k mcf52x2 - BuS eb_cpu5282 eb_cpu5282_internal eb_cpu5282:SYS_TEXT_BASE=0xF0000000,SYS_MONITOR_BASE=0xF0000418 Jens Scharsig esw@bus-elektronik.de +Active m68k mcf52x2 - esd tasreg TASREG - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active m68k mcf52x2 - freescale m5208evbe M5208EVBE - - +Active m68k mcf52x2 - freescale m5249evb M5249EVB - - +Active m68k mcf52x2 - freescale m5253demo M5253DEMO - TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf52x2 - freescale m5253evbe M5253EVBE - Hayden Fraser Hayden.Fraser@freescale.com +Active m68k mcf52x2 - freescale m5271evb M5271EVB - - +Active m68k mcf52x2 - freescale m5272c3 M5272C3 - - +Active m68k mcf52x2 - freescale m5275evb M5275EVB - - +Active m68k mcf52x2 - freescale m5282evb M5282EVB - - +Active m68k mcf532x - astro mcf5373l astro_mcf5373l - Wolfgang Wegner w.wegner@astro-kom.de +Active m68k mcf532x - freescale m53017evb M53017EVB - TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf532x - freescale m5329evb M5329AFEE M5329EVB:NANDFLASH_SIZE=0 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf532x - freescale m5329evb M5329BFEE M5329EVB:NANDFLASH_SIZE=16 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf532x - freescale m5373evb M5373EVB M5373EVB:NANDFLASH_SIZE=16 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf5445x - freescale m54418twr M54418TWR M54418TWR:CF_SBF,SYS_SERIAL_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=50000000 - +Active m68k mcf5445x - freescale m54418twr M54418TWR_nand_mii M54418TWR:SYS_NAND_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=25000000 - +Active m68k mcf5445x - freescale m54418twr M54418TWR_nand_rmii M54418TWR:SYS_NAND_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=50000000 - +Active m68k mcf5445x - freescale m54418twr M54418TWR_nand_rmii_lowfreq M54418TWR:SYS_NAND_BOOT,LOW_MCFCLK,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=50000000 - +Active m68k mcf5445x - freescale m54418twr M54418TWR_serial_mii M54418TWR:CF_SBF,SYS_SERIAL_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=25000000 - +Active m68k mcf5445x - freescale m54418twr M54418TWR_serial_rmii M54418TWR:CF_SBF,SYS_SERIAL_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSRC=50000000 - +Active m68k mcf5445x - freescale m54451evb M54451EVB M54451EVB:SYS_TEXT_BASE=0x00000000,SYS_INPUT_CLKSRC=24000000 - +Active m68k mcf5445x - freescale m54451evb M54451EVB_stmicro M54451EVB:CF_SBF,SYS_STMICRO_BOOT,SYS_TEXT_BASE=0x47e00000,SYS_INPUT_CLKSRC=24000000 - +Active m68k mcf5445x - freescale m54455evb M54455EVB M54455EVB:SYS_ATMEL_BOOT,SYS_TEXT_BASE=0x04000000,SYS_INPUT_CLKSRC=33333333 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf5445x - freescale m54455evb M54455EVB_a66 M54455EVB:SYS_ATMEL_BOOT,SYS_TEXT_BASE=0x04000000,SYS_INPUT_CLKSRC=66666666 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf5445x - freescale m54455evb M54455EVB_i66 M54455EVB:SYS_INTEL_BOOT,SYS_TEXT_BASE=0x00000000,SYS_INPUT_CLKSRC=66666666 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf5445x - freescale m54455evb M54455EVB_intel M54455EVB:SYS_INTEL_BOOT,SYS_TEXT_BASE=0x00000000,SYS_INPUT_CLKSRC=33333333 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf5445x - freescale m54455evb M54455EVB_stm33 M54455EVB:SYS_STMICRO_BOOT,CF_SBF,SYS_TEXT_BASE=0x4FE00000,SYS_INPUT_CLKSRC=33333333 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m547xevb M5475AFE M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m547xevb M5475BFE M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m547xevb M5475CFE M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16,SYS_VIDEO,SYS_USBCTRL TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m547xevb M5475DFE M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_USBCTRL TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m547xevb M5475EFE M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_VIDEO,SYS_USBCTRL TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m547xevb M5475FFE M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=32,SYS_VIDEO,SYS_USBCTRL,SYS_DRAMSZ1=64 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m547xevb M5475GFE M5475EVB:SYS_BUSCLK=133333333,SYS_BOOTSZ=4,SYS_DRAMSZ=64 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m548xevb M5485AFE M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m548xevb M5485BFE M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m548xevb M5485CFE M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16,SYS_VIDEO,SYS_USBCTRL TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m548xevb M5485DFE M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_USBCTRL TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m548xevb M5485EFE M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_VIDEO,SYS_USBCTRL TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m548xevb M5485FFE M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=32,SYS_VIDEO,SYS_USBCTRL,SYS_DRAMSZ1=64 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m548xevb M5485GFE M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=4,SYS_DRAMSZ=64 TsiChung Liew Tsi-Chung.Liew@freescale.com +Active m68k mcf547x_8x - freescale m548xevb M5485HFE M5485EVB:SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16,SYS_VIDEO TsiChung Liew Tsi-Chung.Liew@freescale.com +Active microblaze microblaze - xilinx microblaze-generic microblaze-generic - Michal Simek monstr@monstr.eu +Active mips mips32 - - qemu-malta qemu_malta qemu-malta:MIPS32,SYS_BIG_ENDIAN - +Active mips mips32 - - qemu-malta qemu_maltael qemu-malta:MIPS32,SYS_LITTLE_ENDIAN - +Active mips mips32 - - qemu-mips qemu_mips qemu-mips:SYS_BIG_ENDIAN Vlad Lungu vlad.lungu@windriver.com +Active mips mips32 - - qemu-mips qemu_mipsel qemu-mips:SYS_LITTLE_ENDIAN - +Active mips mips32 - micronas vct vct_platinum vct:VCT_PLATINUM - +Active mips mips32 - micronas vct vct_platinum_onenand vct:VCT_PLATINUM,VCT_ONENAND - +Active mips mips32 - micronas vct vct_platinum_onenand_small vct:VCT_PLATINUM,VCT_ONENAND,VCT_SMALL_IMAGE - +Active mips mips32 - micronas vct vct_platinum_small vct:VCT_PLATINUM,VCT_SMALL_IMAGE - +Active mips mips32 - micronas vct vct_platinumavc vct:VCT_PLATINUMAVC - +Active mips mips32 - micronas vct vct_platinumavc_onenand vct:VCT_PLATINUMAVC,VCT_ONENAND - +Active mips mips32 - micronas vct vct_platinumavc_onenand_small vct:VCT_PLATINUMAVC,VCT_ONENAND,VCT_SMALL_IMAGE - +Active mips mips32 - micronas vct vct_platinumavc_small vct:VCT_PLATINUMAVC,VCT_SMALL_IMAGE - +Active mips mips32 - micronas vct vct_premium vct:VCT_PREMIUM - +Active mips mips32 - micronas vct vct_premium_onenand vct:VCT_PREMIUM,VCT_ONENAND - +Active mips mips32 - micronas vct vct_premium_onenand_small vct:VCT_PREMIUM,VCT_ONENAND,VCT_SMALL_IMAGE - +Active mips mips32 - micronas vct vct_premium_small vct:VCT_PREMIUM,VCT_SMALL_IMAGE - +Active mips mips32 au1x00 - dbau1x00 dbau1000 dbau1x00:DBAU1000 Thomas Lange thomas@corelatus.se +Active mips mips32 au1x00 - dbau1x00 dbau1100 dbau1x00:DBAU1100 Thomas Lange thomas@corelatus.se +Active mips mips32 au1x00 - dbau1x00 dbau1500 dbau1x00:DBAU1500 Thomas Lange thomas@corelatus.se +Active mips mips32 au1x00 - dbau1x00 dbau1550 dbau1x00:DBAU1550 Thomas Lange thomas@corelatus.se +Active mips mips32 au1x00 - dbau1x00 dbau1550_el dbau1x00:DBAU1550,SYS_LITTLE_ENDIAN Thomas Lange thomas@corelatus.se +Active mips mips32 au1x00 - pb1x00 pb1000 pb1x00:PB1000 - +Active mips mips32 incaip - incaip incaip - Wolfgang Denk wd@denx.de +Active mips mips32 incaip - incaip incaip_100MHz incaip:CPU_CLOCK_RATE=100000000 Wolfgang Denk wd@denx.de +Active mips mips32 incaip - incaip incaip_133MHz incaip:CPU_CLOCK_RATE=133000000 Wolfgang Denk wd@denx.de +Active mips mips32 incaip - incaip incaip_150MHz incaip:CPU_CLOCK_RATE=150000000 Wolfgang Denk wd@denx.de +Active mips mips64 - - qemu-mips qemu_mips64 qemu-mips64:SYS_BIG_ENDIAN - +Active mips mips64 - - qemu-mips qemu_mips64el qemu-mips64:SYS_LITTLE_ENDIAN - +Active nds32 n1213 ag101 AndesTech adp-ag101 adp-ag101 - Andes uboot@andestech.com +Active nds32 n1213 ag101 AndesTech adp-ag101p adp-ag101p - Andes uboot@andestech.com +Active nds32 n1213 ag102 AndesTech adp-ag102 adp-ag102 - Andes uboot@andestech.com +Active nios2 nios2 - altera nios2-generic nios2-generic - Scott McNutt smcnutt@psyent.com +Active nios2 nios2 - psyent pci5441 PCI5441 - Scott McNutt smcnutt@psyent.com +Active nios2 nios2 - psyent pk1c20 PK1C20 - Scott McNutt smcnutt@psyent.com +Active openrisc or1200 - openrisc openrisc-generic openrisc-generic - Stefan Kristiansson stefan.kristiansson@saunalahti.fi +Active powerpc 74xx_7xx - - - ppmc7xx - - +Active powerpc 74xx_7xx - - evb64260 P3G4 - Wolfgang Denk wd@denx.de +Active powerpc 74xx_7xx - - evb64260 ZUMA - Nye Liu nyet@zumanetworks.com +Active powerpc 74xx_7xx - eltec elppc ELPPC - - +Active powerpc 74xx_7xx - esd cpci750 CPCI750 - Reinhard Arlt reinhard.arlt@esd-electronics.com +Active powerpc 74xx_7xx - freescale mpc7448hpc2 mpc7448hpc2 - Roy Zang tie-fei.zang@freescale.com +Active powerpc 74xx_7xx - Marvell db64360 DB64360 - - +Active powerpc 74xx_7xx - Marvell db64460 DB64460 - - +Active powerpc 74xx_7xx - prodrive p3mx p3m7448 p3mx:P3M7448 Stefan Roese sr@denx.de +Active powerpc 74xx_7xx - prodrive p3mx p3m750 p3mx:P3M750 Stefan Roese sr@denx.de +Active powerpc mpc512x - - - pdm360ng - Michael Weiss michael.weiss@ifm.com +Active powerpc mpc512x - davedenx - aria - Wolfgang Denk wd@denx.de +Active powerpc mpc512x - esd - mecp5123 - Reinhard Arlt reinhard.arlt@esd-electronics.com +Active powerpc mpc512x - freescale mpc5121ads mpc5121ads - - +Active powerpc mpc512x - freescale mpc5121ads mpc5121ads_rev2 mpc5121ads:MPC5121ADS_REV2 - +Active powerpc mpc512x - ifm ac14xx ac14xx - Anatolij Gustschin agust@denx.de +Active powerpc mpc5xx - - cmi cmi_mpc5xx - - +Active powerpc mpc5xx - mpl pati PATI - - +Active powerpc mpc5xxx - - - canmb - - +Active powerpc mpc5xxx - - - cm5200 - - +Active powerpc mpc5xxx - - - inka4x0 - Detlev Zundel dzu@denx.de +Active powerpc mpc5xxx - - - ipek01 - Wolfgang Grandegger wg@denx.de +Active powerpc mpc5xxx - - - jupiter - Heiko Schocher hs@denx.de +Active powerpc mpc5xxx - - - motionpro - - +Active powerpc mpc5xxx - - - munices - - +Active powerpc mpc5xxx - - - v38b - - +Active powerpc mpc5xxx - - a3m071 a3m071 - Stefan Roese sr@denx.de +Active powerpc mpc5xxx - - a3m071 a4m2k a3m071:A4M2K Stefan Roese sr@denx.de +Active powerpc mpc5xxx - - a4m072 a4m072 - Sergei Poselenov sposelenov@emcraft.com +Active powerpc mpc5xxx - - bc3450 BC3450 - - +Active powerpc mpc5xxx - - galaxy5200 galaxy5200 galaxy5200:galaxy5200 Eric Millbrandt emillbrandt@dekaresearch.com +Active powerpc mpc5xxx - - galaxy5200 galaxy5200_LOWBOOT galaxy5200:galaxy5200_LOWBOOT Eric Millbrandt emillbrandt@dekaresearch.com +Active powerpc mpc5xxx - - icecube icecube_5200 IceCube Wolfgang Denk wd@denx.de +Active powerpc mpc5xxx - - icecube icecube_5200_DDR IceCube:MPC5200_DDR - +Active powerpc mpc5xxx - - icecube icecube_5200_DDR_LOWBOOT IceCube:SYS_TEXT_BASE=0xFF800000,MPC5200_DDR - +Active powerpc mpc5xxx - - icecube icecube_5200_DDR_LOWBOOT08 IceCube:SYS_TEXT_BASE=0xFF800000,MPC5200_DDR - +Active powerpc mpc5xxx - - icecube icecube_5200_LOWBOOT IceCube:SYS_TEXT_BASE=0xFF000000 - +Active powerpc mpc5xxx - - icecube icecube_5200_LOWBOOT08 IceCube:SYS_TEXT_BASE=0xFF800000 - +Active powerpc mpc5xxx - - icecube Lite5200 IceCube - +Active powerpc mpc5xxx - - icecube Lite5200_LOWBOOT IceCube:SYS_TEXT_BASE=0xFF000000 - +Active powerpc mpc5xxx - - icecube Lite5200_LOWBOOT08 IceCube:SYS_TEXT_BASE=0xFF800000 - +Active powerpc mpc5xxx - - icecube lite5200b IceCube:MPC5200_DDR,LITE5200B - +Active powerpc mpc5xxx - - icecube lite5200b_LOWBOOT IceCube:MPC5200_DDR,LITE5200B,SYS_TEXT_BASE=0xFF000000 - +Active powerpc mpc5xxx - - icecube lite5200b_PM IceCube:MPC5200_DDR,LITE5200B,LITE5200B_PM - +Active powerpc mpc5xxx - - mcc200 mcc200 mcc200 - +Active powerpc mpc5xxx - - mcc200 mcc200_COM12 mcc200:CONSOLE_COM12 - +Active powerpc mpc5xxx - - mcc200 mcc200_COM12_highboot mcc200:CONSOLE_COM12,SYS_TEXT_BASE=0xFFF00000 - +Active powerpc mpc5xxx - - mcc200 mcc200_COM12_highboot_SDRAM mcc200:CONSOLE_COM12,SYS_TEXT_BASE=0xFFF00000,MCC200_SDRAM - +Active powerpc mpc5xxx - - mcc200 mcc200_COM12_SDRAM mcc200:CONSOLE_COM12,MCC200_SDRAM - +Active powerpc mpc5xxx - - mcc200 mcc200_highboot mcc200:SYS_TEXT_BASE=0xFFF00000 - +Active powerpc mpc5xxx - - mcc200 mcc200_highboot_SDRAM mcc200:SYS_TEXT_BASE=0xFFF00000,MCC200_SDRAM - +Active powerpc mpc5xxx - - mcc200 mcc200_SDRAM mcc200:MCC200_SDRAM - +Active powerpc mpc5xxx - - mcc200 prs200 mcc200:PRS200,MCC200_SDRAM - +Active powerpc mpc5xxx - - mcc200 prs200_DDR mcc200:PRS200 - +Active powerpc mpc5xxx - - mcc200 prs200_highboot mcc200:PRS200,SYS_TEXT_BASE=0xFFF00000,MCC200_SDRAM - +Active powerpc mpc5xxx - - mcc200 prs200_highboot_DDR mcc200:PRS200,SYS_TEXT_BASE=0xFFF00000 - +Active powerpc mpc5xxx - - pm520 PM520 - Josef Wagner Wagner@Microsys.de +Active powerpc mpc5xxx - - pm520 PM520_DDR PM520:MPC5200_DDR Josef Wagner Wagner@Microsys.de +Active powerpc mpc5xxx - - pm520 PM520_ROMBOOT PM520:BOOT_ROM Josef Wagner Wagner@Microsys.de +Active powerpc mpc5xxx - - pm520 PM520_ROMBOOT_DDR PM520:MPC5200_DDR,BOOT_ROM Josef Wagner Wagner@Microsys.de +Active powerpc mpc5xxx - - total5200 Total5200 Total5200:TOTAL5200_REV=1 - +Active powerpc mpc5xxx - - total5200 Total5200_lowboot Total5200:TOTAL5200_REV=1,SYS_TEXT_BASE=0xFE000000 - +Active powerpc mpc5xxx - - total5200 Total5200_Rev2 Total5200:TOTAL5200_REV=2 - +Active powerpc mpc5xxx - - total5200 Total5200_Rev2_lowboot Total5200:TOTAL5200_REV=2,SYS_TEXT_BASE=0xFE000000 - +Active powerpc mpc5xxx - emk top5200 EVAL5200 TOP5200:EVAL5200 Reinhard Meyer reinhard.meyer@emk-elektronik.de +Active powerpc mpc5xxx - emk top5200 MINI5200 TOP5200:MINI5200 Reinhard Meyer reinhard.meyer@emk-elektronik.de +Active powerpc mpc5xxx - emk top5200 TOP5200 TOP5200:TOP5200 Reinhard Meyer reinhard.meyer@emk-elektronik.de +Active powerpc mpc5xxx - esd - cpci5200 - Reinhard Arlt reinhard.arlt@esd-electronics.com +Active powerpc mpc5xxx - esd - mecp5200 - Reinhard Arlt reinhard.arlt@esd-electronics.com +Active powerpc mpc5xxx - esd - pf5200 - Reinhard Arlt reinhard.arlt@esd-electronics.com +Active powerpc mpc5xxx - ifm o2dnt2 O2D o2d Anatolij Gustschin agust@denx.de +Active powerpc mpc5xxx - ifm o2dnt2 O2D300 o2d300 Anatolij Gustschin agust@denx.de +Active powerpc mpc5xxx - ifm o2dnt2 O2DNT2 o2dnt2 Anatolij Gustschin agust@denx.de +Active powerpc mpc5xxx - ifm o2dnt2 O2DNT2_RAMBOOT o2dnt2:SYS_TEXT_BASE=0x00100000 Anatolij Gustschin agust@denx.de +Active powerpc mpc5xxx - ifm o2dnt2 O2I o2i Anatolij Gustschin agust@denx.de +Active powerpc mpc5xxx - ifm o2dnt2 O2MNT o2mnt Anatolij Gustschin agust@denx.de +Active powerpc mpc5xxx - ifm o2dnt2 O2MNT_O2M110 o2mnt:IFM_SENSOR_TYPE="O2M110" Anatolij Gustschin agust@denx.de +Active powerpc mpc5xxx - ifm o2dnt2 O2MNT_O2M112 o2mnt:IFM_SENSOR_TYPE="O2M112" Anatolij Gustschin agust@denx.de +Active powerpc mpc5xxx - ifm o2dnt2 O2MNT_O2M113 o2mnt:IFM_SENSOR_TYPE="O2M113" Anatolij Gustschin agust@denx.de +Active powerpc mpc5xxx - ifm o2dnt2 O3DNT o3dnt Anatolij Gustschin agust@denx.de +Active powerpc mpc5xxx - intercontrol digsy_mtc digsy_mtc - Werner Pfister Pfister_Werner@intercontrol.de +Active powerpc mpc5xxx - intercontrol digsy_mtc digsy_mtc_RAMBOOT digsy_mtc:SYS_TEXT_BASE=0x00100000 Werner Pfister Pfister_Werner@intercontrol.de +Active powerpc mpc5xxx - intercontrol digsy_mtc digsy_mtc_rev5 digsy_mtc:DIGSY_REV5 Werner Pfister Pfister_Werner@intercontrol.de +Active powerpc mpc5xxx - intercontrol digsy_mtc digsy_mtc_rev5_RAMBOOT digsy_mtc:SYS_TEXT_BASE=0x00100000,DIGSY_REV5 Werner Pfister Pfister_Werner@intercontrol.de +Active powerpc mpc5xxx - manroland - hmi1001 - - +Active powerpc mpc5xxx - manroland - mucmc52 - Heiko Schocher hs@denx.de +Active powerpc mpc5xxx - manroland - uc101 - Heiko Schocher hs@denx.de +Active powerpc mpc5xxx - matrix_vision mvbc_p MVBC_P MVBC_P:MVBC_P Andre Schwarz andre.schwarz@matrix-vision.de +Active powerpc mpc5xxx - matrix_vision mvsmr MVSMR - Andre Schwarz andre.schwarz@matrix-vision.de +Active powerpc mpc5xxx - phytec pcm030 pcm030 pcm030 Jon Smirl jonsmirl@gmail.com +Active powerpc mpc5xxx - phytec pcm030 pcm030_LOWBOOT pcm030:SYS_TEXT_BASE=0xFF000000 Jon Smirl jonsmirl@gmail.com +Active powerpc mpc5xxx - tqc tqm5200 aev - - +Active powerpc mpc5xxx - tqc tqm5200 cam5200 TQM5200:CAM5200,TQM5200S,TQM5200_B - +Active powerpc mpc5xxx - tqc tqm5200 cam5200_niosflash TQM5200:CAM5200,TQM5200S,TQM5200_B,CAM5200_NIOSFLASH - +Active powerpc mpc5xxx - tqc tqm5200 charon charon Heiko Schocher hs@denx.de +Active powerpc mpc5xxx - tqc tqm5200 fo300 TQM5200:FO300 - +Active powerpc mpc5xxx - tqc tqm5200 MiniFAP TQM5200:MINIFAP - +Active powerpc mpc5xxx - tqc tqm5200 TB5200 - - +Active powerpc mpc5xxx - tqc tqm5200 TB5200_B TB5200:TQM5200_B - +Active powerpc mpc5xxx - tqc tqm5200 TQM5200 TQM5200: - +Active powerpc mpc5xxx - tqc tqm5200 TQM5200_B TQM5200:TQM5200_B - +Active powerpc mpc5xxx - tqc tqm5200 TQM5200_B_HIGHBOOT TQM5200:TQM5200_B,SYS_TEXT_BASE=0xFFF00000 - +Active powerpc mpc5xxx - tqc tqm5200 TQM5200_STK100 TQM5200:STK52XX_REV100 - +Active powerpc mpc5xxx - tqc tqm5200 TQM5200S TQM5200:TQM5200_B,TQM5200S - +Active powerpc mpc5xxx - tqc tqm5200 TQM5200S_HIGHBOOT TQM5200:TQM5200_B,TQM5200S,SYS_TEXT_BASE=0xFFF00000 - +Active powerpc mpc824x - - - utx8245 - Greg Allen gallen@arlut.utexas.edu +Active powerpc mpc824x - - a3000 A3000 - - +Active powerpc mpc824x - - cpc45 CPC45 CPC45 Josef Wagner Wagner@Microsys.de +Active powerpc mpc824x - - cpc45 CPC45_ROMBOOT CPC45:BOOT_ROM Josef Wagner Wagner@Microsys.de +Active powerpc mpc824x - - cu824 CU824 - Wolfgang Denk wd@denx.de +Active powerpc mpc824x - - eXalion eXalion - Torsten Demke torsten.demke@fci.com +Active powerpc mpc824x - - hidden_dragon HIDDEN_DRAGON - Yusdi Santoso yusdi_santoso@adaptec.com +Active powerpc mpc824x - - linkstation linkstation_HGLAN linkstation:HGLAN=1 Guennadi Liakhovetski g.liakhovetski@gmx.de +Active powerpc mpc824x - - musenki MUSENKI - Jim Thompson jim@musenki.com +Active powerpc mpc824x - - mvblue MVBLUE - - +Active powerpc mpc824x - - pn62 PN62 - Wolfgang Grandegger wg@denx.de +Active powerpc mpc824x - - sandpoint Sandpoint8240 - Wolfgang Denk wd@denx.de +Active powerpc mpc824x - - sandpoint Sandpoint8245 - Jim Thompson jim@musenki.com +Active powerpc mpc824x - etin - debris - Sangmoon Kim dogoil@etinsys.com +Active powerpc mpc824x - etin - kvme080 - Sangmoon Kim dogoil@etinsys.com +Active powerpc mpc8260 - - - atc - Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - - - ep8260 - Frank Panno fpanno@delphintech.com +Active powerpc mpc8260 - - - ep82xxm - - +Active powerpc mpc8260 - - - gw8260 - Oliver Brown obrown@adventnetworks.com +Active powerpc mpc8260 - - - hymod - Murray Jensen Murray.Jensen@csiro.au +Active powerpc mpc8260 - - - ppmc8260 - Brad Kemp Brad.Kemp@seranoa.com +Active powerpc mpc8260 - - - sacsng - Jerry Van Baren gerald.vanbaren@smiths-aerospace.com +Active powerpc mpc8260 - - cogent cogent_mpc8260 - Murray Jensen Murray.Jensen@csiro.au +Active powerpc mpc8260 - - cpu86 CPU86 CPU86 Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - - cpu86 CPU86_ROMBOOT CPU86:BOOT_ROM Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - - cpu87 CPU87 CPU87 - +Active powerpc mpc8260 - - cpu87 CPU87_ROMBOOT CPU87:BOOT_ROM - +Active powerpc mpc8260 - - ep8248 ep8248 - Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - - ep8248 ep8248E ep8248 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - - ids8247 IDS8247 - Heiko Schocher hs@denx.de +Active powerpc mpc8260 - - iphase4539 IPHASE4539 - Wolfgang Grandegger wg@denx.de +Active powerpc mpc8260 - - ispan ISPAN - Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - - ispan ISPAN_REVB ISPAN:SYS_REV_B Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - - muas3001 muas3001 - Heiko Schocher hs@denx.de +Active powerpc mpc8260 - - muas3001 muas3001_dev muas3001:MUAS_DEV_BOARD Heiko Schocher hs@denx.de +Active powerpc mpc8260 - - pm826 PM825 PM826:PCI,SYS_TEXT_BASE=0xFF000000 Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - - pm826 PM825_BIGFLASH PM826:PCI,FLASH_32MB,SYS_TEXT_BASE=0x40000000 Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - - pm826 PM825_ROMBOOT PM826:PCI,BOOT_ROM,SYS_TEXT_BASE=0xFF800000 Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - - pm826 PM825_ROMBOOT_BIGFLASH PM826:PCI,BOOT_ROM,FLASH_32MB,SYS_TEXT_BASE=0xFF800000 Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - - pm826 PM826 PM826:SYS_TEXT_BASE=0xFF000000 Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - - pm826 PM826_BIGFLASH PM826:FLASH_32MB,SYS_TEXT_BASE=0x40000000 Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - - pm826 PM826_ROMBOOT PM826:BOOT_ROM,SYS_TEXT_BASE=0xFF800000 Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - - pm826 PM826_ROMBOOT_BIGFLASH PM826:BOOT_ROM,FLASH_32MB,SYS_TEXT_BASE=0xFF800000 Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - - pm828 PM828 PM828 - +Active powerpc mpc8260 - - pm828 PM828_PCI PM828:PCI - +Active powerpc mpc8260 - - pm828 PM828_ROMBOOT PM828:BOOT_ROM,SYS_TEXT_BASE=0xFF800000 - +Active powerpc mpc8260 - - pm828 PM828_ROMBOOT_PCI PM828:PCI,BOOT_ROM,SYS_TEXT_BASE=0xFF800000 - +Active powerpc mpc8260 - - rattler Rattler Rattler Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - - rattler Rattler8248 Rattler:MPC8248 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - - zpc1900 ZPC1900 - Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads MPC8260ADS MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads MPC8260ADS_33MHz MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS,8260_CLKIN=33000000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads MPC8260ADS_33MHz_lowboot MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS,8260_CLKIN=33000000,SYS_TEXT_BASE=0xFF800000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads MPC8260ADS_40MHz MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS,8260_CLKIN=40000000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads MPC8260ADS_40MHz_lowboot MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS,8260_CLKIN=40000000,SYS_TEXT_BASE=0xFF800000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads MPC8260ADS_lowboot MPC8260ADS:ADSTYPE=CONFIG_SYS_8260ADS,SYS_TEXT_BASE=0xFF800000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads MPC8272ADS MPC8260ADS:ADSTYPE=CONFIG_SYS_8272ADS Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads MPC8272ADS_lowboot MPC8260ADS:ADSTYPE=CONFIG_SYS_8272ADS,SYS_TEXT_BASE=0xFF800000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads PQ2FADS MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads PQ2FADS-VR MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,8260_CLKIN=66000000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads PQ2FADS-VR_lowboot MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,8260_CLKIN=66000000,SYS_TEXT_BASE=0xFF800000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads PQ2FADS-ZU MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads PQ2FADS-ZU_66MHz MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,8260_CLKIN=66000000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads PQ2FADS-ZU_66MHz_lowboot MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,8260_CLKIN=66000000,SYS_TEXT_BASE=0xFF800000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads PQ2FADS-ZU_lowboot MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,SYS_TEXT_BASE=0xFF800000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8260ads PQ2FADS_lowboot MPC8260ADS:ADSTYPE=CONFIG_SYS_PQ2FADS,SYS_TEXT_BASE=0xFF800000 Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8260 - freescale mpc8266ads MPC8266ADS - Rune Torgersen runet@innovsys.com +Active powerpc mpc8260 - funkwerk vovpn-gw VoVPN-GW_66MHz VoVPN-GW:CLKIN_66MHz - +Active powerpc mpc8260 - keymile km82xx mgcoge km82xx:MGCOGE Holger Brunck holger.brunck@keymile.com +Active powerpc mpc8260 - keymile km82xx mgcoge3ne km82xx:MGCOGE3NE Holger Brunck holger.brunck@keymile.com +Active powerpc mpc8260 - tqc tqm8260 TQM8255_AA TQM8260:MPC8255,300MHz Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - tqc tqm8260 TQM8260_AA TQM8260:MPC8260,200MHz Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - tqc tqm8260 TQM8260_AB TQM8260:MPC8260,200MHz,L2_CACHE,BUSMODE_60x Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - tqc tqm8260 TQM8260_AC TQM8260:MPC8260,200MHz,L2_CACHE,BUSMODE_60x Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - tqc tqm8260 TQM8260_AD TQM8260:MPC8260,300MHz,BUSMODE_60x Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - tqc tqm8260 TQM8260_AE TQM8260:MPC8260,266MHz Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - tqc tqm8260 TQM8260_AF TQM8260:MPC8260,300MHz,BUSMODE_60x Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - tqc tqm8260 TQM8260_AG TQM8260:MPC8260,300MHz Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - tqc tqm8260 TQM8260_AH TQM8260:MPC8260,300MHz,L2_CACHE,BUSMODE_60x Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - tqc tqm8260 TQM8260_AI TQM8260:MPC8260,300MHz,BUSMODE_60x Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - tqc tqm8260 TQM8265_AA TQM8260:MPC8265,300MHz,BUSMODE_60x Wolfgang Denk wd@denx.de +Active powerpc mpc8260 - tqc tqm8272 TQM8272 - - +Active powerpc mpc83xx - - - mpc8308_p1m - Ilya Yanok yanok@emcraft.com +Active powerpc mpc83xx - - sbc8349 sbc8349 sbc8349 Paul Gortmaker paul.gortmaker@windriver.com +Active powerpc mpc83xx - - sbc8349 sbc8349_PCI_33 sbc8349:PCI,PCI_33M Paul Gortmaker paul.gortmaker@windriver.com +Active powerpc mpc83xx - - sbc8349 sbc8349_PCI_66 sbc8349:PCI,PCI_66M Paul Gortmaker paul.gortmaker@windriver.com +Active powerpc mpc83xx - - ve8313 ve8313 - Heiko Schocher hs@denx.de +Active powerpc mpc83xx - esd vme8349 caddy2 vme8349:CADDY2 Reinhard Arlt reinhard.arlt@esd-electronics.com +Active powerpc mpc83xx - esd vme8349 vme8349 vme8349 Reinhard Arlt reinhard.arlt@esd-electronics.com +Active powerpc mpc83xx - freescale mpc8308rdb MPC8308RDB - Ilya Yanok yanok@emcraft.com +Active powerpc mpc83xx - freescale mpc8313erdb MPC8313ERDB_33 MPC8313ERDB:SYS_33MHZ - +Active powerpc mpc83xx - freescale mpc8313erdb MPC8313ERDB_66 MPC8313ERDB:SYS_66MHZ - +Active powerpc mpc83xx - freescale mpc8313erdb MPC8313ERDB_NAND_33 MPC8313ERDB:SYS_33MHZ,NAND - +Active powerpc mpc83xx - freescale mpc8313erdb MPC8313ERDB_NAND_66 MPC8313ERDB:SYS_66MHZ,NAND - +Active powerpc mpc83xx - freescale mpc8315erdb MPC8315ERDB MPC8315ERDB Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8315erdb MPC8315ERDB_NAND MPC8315ERDB:NAND_U_BOOT Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8323erdb MPC8323ERDB - Michael Barkowski michael.barkowski@freescale.com +Active powerpc mpc83xx - freescale mpc832xemds MPC832XEMDS MPC832XEMDS: Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc832xemds MPC832XEMDS_ATM MPC832XEMDS:PQ_MDS_PIB=1,PQ_MDS_PIB_ATM=1 Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc832xemds MPC832XEMDS_HOST_33 MPC832XEMDS:PCI,PCI_33M,PQ_MDS_PIB=1 Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc832xemds MPC832XEMDS_HOST_66 MPC832XEMDS:PCI,PCI_66M,PQ_MDS_PIB=1 Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc832xemds MPC832XEMDS_SLAVE MPC832XEMDS:PCI,PCISLAVE Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8349emds MPC8349EMDS - Kim Phillips kim.phillips@freescale.com +Active powerpc mpc83xx - freescale mpc8349itx MPC8349ITX MPC8349ITX:MPC8349ITX - +Active powerpc mpc83xx - freescale mpc8349itx MPC8349ITX_LOWBOOT MPC8349ITX:MPC8349ITX,SYS_TEXT_BASE=0xFE000000 - +Active powerpc mpc83xx - freescale mpc8349itx MPC8349ITXGP MPC8349ITX:MPC8349ITXGP,SYS_TEXT_BASE=0xFE000000 - +Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_33 MPC8360EMDS:CLKIN_33MHZ Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_33_ATM MPC8360EMDS:CLKIN_33MHZ,PQ_MDS_PIB=1,PQ_MDS_PIB_ATM=1 Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_33_HOST_33 MPC8360EMDS:CLKIN_33MHZ,PCI,PCI_33M,PQ_MDS_PIB=1 Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_33_HOST_66 MPC8360EMDS:CLKIN_33MHZ,PCI,PCI_66M,PQ_MDS_PIB=1 Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_33_SLAVE MPC8360EMDS:CLKIN_33MHZ,PCI,PCISLAVE Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_66 MPC8360EMDS:CLKIN_66MHZ Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_66_ATM MPC8360EMDS:CLKIN_66MHZ,PQ_MDS_PIB=1,PQ_MDS_PIB_ATM=1 Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_66_HOST_33 MPC8360EMDS:CLKIN_66MHZ,PCI,PCI_33M,PQ_MDS_PIB=1 Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_66_HOST_66 MPC8360EMDS:CLKIN_66MHZ,PCI,PCI_66M,PQ_MDS_PIB=1 Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8360emds MPC8360EMDS_66_SLAVE MPC8360EMDS:CLKIN_66MHZ,PCI,PCISLAVE Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc8360erdk MPC8360ERDK MPC8360ERDK Anton Vorontsov avorontsov@ru.mvista.com +Active powerpc mpc83xx - freescale mpc8360erdk MPC8360ERDK_33 MPC8360ERDK:CLKIN_33MHZ Anton Vorontsov avorontsov@ru.mvista.com +Active powerpc mpc83xx - freescale mpc8360erdk MPC8360ERDK_66 MPC8360ERDK Anton Vorontsov avorontsov@ru.mvista.com +Active powerpc mpc83xx - freescale mpc837xemds MPC837XEMDS MPC837XEMDS Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc837xemds MPC837XEMDS_HOST MPC837XEMDS:PCI Dave Liu daveliu@freescale.com +Active powerpc mpc83xx - freescale mpc837xerdb MPC837XERDB - Joe D'Abbraccio ljd015@freescale.com +Active powerpc mpc83xx - keymile km83xx kmcoge5ne km8360:KMCOGE5NE Holger Brunck holger.brunck@keymile.com +Active powerpc mpc83xx - keymile km83xx kmeter1 km8360:KMETER1 Holger Brunck holger.brunck@keymile.com +Active powerpc mpc83xx - keymile km83xx kmopti2 tuxx1:KMOPTI2 Holger Brunck holger.brunck@keymile.com +Active powerpc mpc83xx - keymile km83xx kmsupx5 tuxx1:KMSUPX5 Heiko Schocher hs@denx.de +Active powerpc mpc83xx - keymile km83xx kmvect1 suvd3:KMVECT1 Holger Brunck holger.brunck@keymile.com +Active powerpc mpc83xx - keymile km83xx suvd3 suvd3:SUVD3 Holger Brunck holger.brunck@keymile.com +Active powerpc mpc83xx - keymile km83xx tuge1 tuxx1:TUGE1 Holger Brunck holger.brunck@keymile.com +Active powerpc mpc83xx - keymile km83xx tuxx1 tuxx1:TUXX1 Holger Brunck holger.brunck@keymile.com +Active powerpc mpc83xx - matrix_vision mergerbox MERGERBOX - Andre Schwarz andre.schwarz@matrix-vision.de +Active powerpc mpc83xx - matrix_vision mvblm7 MVBLM7 - Andre Schwarz andre.schwarz@matrix-vision.de +Active powerpc mpc83xx - sheldon simpc8313 SIMPC8313_LP SIMPC8313:NAND_LP Ron Madrid info@sheldoninst.com +Active powerpc mpc83xx - sheldon simpc8313 SIMPC8313_SP SIMPC8313:NAND_SP Ron Madrid info@sheldoninst.com +Active powerpc mpc83xx - tqc tqm834x TQM834x - - +Active powerpc mpc85xx - - sbc8548 sbc8548 sbc8548 Paul Gortmaker paul.gortmaker@windriver.com +Active powerpc mpc85xx - - sbc8548 sbc8548_PCI_33 sbc8548:PCI,33 Paul Gortmaker paul.gortmaker@windriver.com +Active powerpc mpc85xx - - sbc8548 sbc8548_PCI_33_PCIE sbc8548:PCI,33,PCIE Paul Gortmaker paul.gortmaker@windriver.com +Active powerpc mpc85xx - - sbc8548 sbc8548_PCI_66 sbc8548:PCI,66 Paul Gortmaker paul.gortmaker@windriver.com +Active powerpc mpc85xx - - sbc8548 sbc8548_PCI_66_PCIE sbc8548:PCI,66,PCIE Paul Gortmaker paul.gortmaker@windriver.com +Active powerpc mpc85xx - - socrates socrates - - +Active powerpc mpc85xx - exmeritus hww1u1a HWW1U1A - Kyle Moffett Kyle.D.Moffett@boeing.com +Active powerpc mpc85xx - freescale b4860qds B4420QDS B4860QDS:PPC_B4420 - +Active powerpc mpc85xx - freescale b4860qds B4420QDS_NAND B4860QDS:PPC_B4420,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale b4860qds B4420QDS_SPIFLASH B4860QDS:PPC_B4420,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale b4860qds B4860QDS B4860QDS:PPC_B4860 - +Active powerpc mpc85xx - freescale b4860qds B4860QDS_NAND B4860QDS:PPC_B4860,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale b4860qds B4860QDS_SPIFLASH B4860QDS:PPC_B4860,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale b4860qds B4860QDS_SRIO_PCIE_BOOT B4860QDS:PPC_B4860,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale bsc9131rdb BSC9131RDB_NAND BSC9131RDB:BSC9131RDB,NAND Poonam Aggrwal poonam.aggrwal@freescale.com +Active powerpc mpc85xx - freescale bsc9131rdb BSC9131RDB_NAND_SYSCLK100 BSC9131RDB:BSC9131RDB,NAND,SYS_CLK_100 Poonam Aggrwal poonam.aggrwal@freescale.com +Active powerpc mpc85xx - freescale bsc9131rdb BSC9131RDB_SPIFLASH BSC9131RDB:BSC9131RDB,SPIFLASH Poonam Aggrwal poonam.aggrwal@freescale.com +Active powerpc mpc85xx - freescale bsc9131rdb BSC9131RDB_SPIFLASH_SYSCLK100 BSC9131RDB:BSC9131RDB,SPIFLASH,SYS_CLK_100 Poonam Aggrwal poonam.aggrwal@freescale.com +Active powerpc mpc85xx - freescale bsc9132qds BSC9132QDS_NAND_DDRCLK100 BSC9132QDS:BSC9132QDS,NAND,SYS_CLK_100_DDR_100 Naveen Burmi NaveenBurmi@freescale.com +Active powerpc mpc85xx - freescale bsc9132qds BSC9132QDS_NAND_DDRCLK133 BSC9132QDS:BSC9132QDS,NAND,SYS_CLK_100_DDR_133 Naveen Burmi NaveenBurmi@freescale.com +Active powerpc mpc85xx - freescale bsc9132qds BSC9132QDS_NOR_DDRCLK100 BSC9132QDS:BSC9132QDS,SYS_CLK_100_DDR_100 Naveen Burmi NaveenBurmi@freescale.com +Active powerpc mpc85xx - freescale bsc9132qds BSC9132QDS_NOR_DDRCLK133 BSC9132QDS:BSC9132QDS,SYS_CLK_100_DDR_133 Naveen Burmi NaveenBurmi@freescale.com +Active powerpc mpc85xx - freescale bsc9132qds BSC9132QDS_SDCARD_DDRCLK100 BSC9132QDS:BSC9132QDS,SDCARD,SYS_CLK_100_DDR_100 Naveen Burmi NaveenBurmi@freescale.com +Active powerpc mpc85xx - freescale bsc9132qds BSC9132QDS_SDCARD_DDRCLK133 BSC9132QDS:BSC9132QDS,SDCARD,SYS_CLK_100_DDR_133 Naveen Burmi NaveenBurmi@freescale.com +Active powerpc mpc85xx - freescale bsc9132qds BSC9132QDS_SPIFLASH_DDRCLK100 BSC9132QDS:BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_100 Naveen Burmi NaveenBurmi@freescale.com +Active powerpc mpc85xx - freescale bsc9132qds BSC9132QDS_SPIFLASH_DDRCLK133 BSC9132QDS:BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_133 Naveen Burmi NaveenBurmi@freescale.com +Active powerpc mpc85xx - freescale c29xpcie C29XPCIE C29XPCIE:C29XPCIE,36BIT Po Liu po.liu@freescale.com +Active powerpc mpc85xx - freescale c29xpcie C29XPCIE_SPIFLASH C29XPCIE:C29XPCIE,36BIT,SPIFLASH Po Liu po.liu@freescale.com +Active powerpc mpc85xx - freescale corenet_ds P3041DS - - +Active powerpc mpc85xx - freescale corenet_ds P3041DS_NAND P3041DS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P3041DS_SDCARD P3041DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P3041DS_SECURE_BOOT P3041DS:SECURE_BOOT - +Active powerpc mpc85xx - freescale corenet_ds P3041DS_SPIFLASH P3041DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P3041DS_SRIO_PCIE_BOOT P3041DS:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P4080DS - - +Active powerpc mpc85xx - freescale corenet_ds P4080DS_SDCARD P4080DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P4080DS_SECURE_BOOT P4080DS:SECURE_BOOT - +Active powerpc mpc85xx - freescale corenet_ds P4080DS_SPIFLASH P4080DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P4080DS_SRIO_PCIE_BOOT P4080DS:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P5020DS - - +Active powerpc mpc85xx - freescale corenet_ds P5020DS_NAND P5020DS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P5020DS_SDCARD P5020DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P5020DS_SECURE_BOOT P5020DS:SECURE_BOOT - +Active powerpc mpc85xx - freescale corenet_ds P5020DS_SPIFLASH P5020DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P5020DS_SRIO_PCIE_BOOT P5020DS:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P5040DS - - +Active powerpc mpc85xx - freescale corenet_ds P5040DS_NAND P5040DS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P5040DS_SDCARD P5040DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale corenet_ds P5040DS_SPIFLASH P5040DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale mpc8536ds MPC8536DS MPC8536DS - +Active powerpc mpc85xx - freescale mpc8536ds MPC8536DS_36BIT MPC8536DS:36BIT - +Active powerpc mpc85xx - freescale mpc8536ds MPC8536DS_NAND MPC8536DS:NAND - +Active powerpc mpc85xx - freescale mpc8536ds MPC8536DS_SDCARD MPC8536DS:SDCARD - +Active powerpc mpc85xx - freescale mpc8536ds MPC8536DS_SPIFLASH MPC8536DS:SPIFLASH - +Active powerpc mpc85xx - freescale mpc8540ads MPC8540ADS - Kumar Gala kumar.gala@freescale.com +Active powerpc mpc85xx - freescale mpc8541cds MPC8541CDS MPC8541CDS Kumar Gala kumar.gala@freescale.com +Active powerpc mpc85xx - freescale mpc8541cds MPC8541CDS_legacy MPC8541CDS:LEGACY Kumar Gala kumar.gala@freescale.com +Active powerpc mpc85xx - freescale mpc8544ds MPC8544DS - - +Active powerpc mpc85xx - freescale mpc8548cds MPC8548CDS MPC8548CDS - +Active powerpc mpc85xx - freescale mpc8548cds MPC8548CDS_36BIT MPC8548CDS:36BIT - +Active powerpc mpc85xx - freescale mpc8548cds MPC8548CDS_legacy MPC8548CDS:LEGACY - +Active powerpc mpc85xx - freescale mpc8555cds MPC8555CDS MPC8555CDS Kumar Gala kumar.gala@freescale.com +Active powerpc mpc85xx - freescale mpc8555cds MPC8555CDS_legacy MPC8555CDS:LEGACY Kumar Gala kumar.gala@freescale.com +Active powerpc mpc85xx - freescale mpc8560ads MPC8560ADS - Kumar Gala kumar.gala@freescale.com +Active powerpc mpc85xx - freescale mpc8568mds MPC8568MDS - - +Active powerpc mpc85xx - freescale mpc8569mds MPC8569MDS MPC8569MDS - +Active powerpc mpc85xx - freescale mpc8569mds MPC8569MDS_ATM MPC8569MDS:ATM - +Active powerpc mpc85xx - freescale mpc8569mds MPC8569MDS_NAND MPC8569MDS:NAND - +Active powerpc mpc85xx - freescale mpc8572ds MPC8572DS MPC8572DS - +Active powerpc mpc85xx - freescale mpc8572ds MPC8572DS_36BIT MPC8572DS:36BIT - +Active powerpc mpc85xx - freescale mpc8572ds MPC8572DS_NAND MPC8572DS:NAND - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_36BIT_NAND P1010RDB:P1010RDB,36BIT,NAND - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_36BIT_NAND_SECBOOT P1010RDB:P1010RDB,36BIT,NAND_SECBOOT,SECURE_BOOT - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_36BIT_NOR P1010RDB:P1010RDB,36BIT - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_36BIT_NOR_SECBOOT P1010RDB:P1010RDB,36BIT,SECURE_BOOT - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_36BIT_SDCARD P1010RDB:P1010RDB,36BIT,SDCARD - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_36BIT_SPIFLASH P1010RDB:P1010RDB,36BIT,SPIFLASH - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_36BIT_SPIFLASH_SECBOOT P1010RDB:P1010RDB,36BIT,SPIFLASH,SECURE_BOOT - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_NAND P1010RDB:P1010RDB,NAND - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_NAND_SECBOOT P1010RDB:P1010RDB,NAND_SECBOOT,SECURE_BOOT - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_NOR P1010RDB:P1010RDB - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_NOR_SECBOOT P1010RDB:P1010RDB,SECURE_BOOT - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_SDCARD P1010RDB:P1010RDB,SDCARD - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_SPIFLASH P1010RDB:P1010RDB,SPIFLASH - +Active powerpc mpc85xx - freescale p1010rdb P1010RDB_SPIFLASH_SECBOOT P1010RDB:P1010RDB,SPIFLASH,SECURE_BOOT - +Active powerpc mpc85xx - freescale p1022ds P1022DS - Timur Tabi timur@freescale.com +Active powerpc mpc85xx - freescale p1022ds P1022DS_36BIT P1022DS:36BIT Timur Tabi timur@freescale.com +Active powerpc mpc85xx - freescale p1022ds P1022DS_36BIT_NAND P1022DS:36BIT,NAND Timur Tabi timur@freescale.com +Active powerpc mpc85xx - freescale p1022ds P1022DS_36BIT_SDCARD P1022DS:36BIT,SDCARD Timur Tabi timur@freescale.com +Active powerpc mpc85xx - freescale p1022ds P1022DS_36BIT_SPIFLASH P1022DS:36BIT,SPIFLASH Timur Tabi timur@freescale.com +Active powerpc mpc85xx - freescale p1022ds P1022DS_NAND P1022DS:NAND Timur Tabi timur@freescale.com +Active powerpc mpc85xx - freescale p1022ds P1022DS_SDCARD P1022DS:SDCARD Timur Tabi timur@freescale.com +Active powerpc mpc85xx - freescale p1022ds P1022DS_SPIFLASH P1022DS:SPIFLASH Timur Tabi timur@freescale.com +Active powerpc mpc85xx - freescale p1023rdb P1023RDB P1023RDB - +Active powerpc mpc85xx - freescale p1023rds P1023RDS P1023RDS Roy Zang tie-fei.zang@freescale.com +Active powerpc mpc85xx - freescale p1023rds P1023RDS_NAND P1023RDS:NAND Roy Zang tie-fei.zang@freescale.com +Active powerpc mpc85xx - freescale p1_p2_rdb P1011RDB P1_P2_RDB:P1011RDB - +Active powerpc mpc85xx - freescale p1_p2_rdb P1011RDB_36BIT P1_P2_RDB:P1011RDB,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb P1011RDB_36BIT_SDCARD P1_P2_RDB:P1011RDB,36BIT,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb P1011RDB_36BIT_SPIFLASH P1_P2_RDB:P1011RDB,36BIT,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb P1011RDB_NAND P1_P2_RDB:P1011RDB,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb P1011RDB_SDCARD P1_P2_RDB:P1011RDB,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb P1011RDB_SPIFLASH P1_P2_RDB:P1011RDB,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb P1020RDB P1_P2_RDB:P1020RDB - +Active powerpc mpc85xx - freescale p1_p2_rdb P1020RDB_36BIT P1_P2_RDB:P1020RDB,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb P1020RDB_36BIT_SDCARD P1_P2_RDB:P1020RDB,36BIT,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb P1020RDB_36BIT_SPIFLASH P1_P2_RDB:P1020RDB,36BIT,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb P1020RDB_NAND P1_P2_RDB:P1020RDB,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb P1020RDB_SDCARD P1_P2_RDB:P1020RDB,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb P1020RDB_SPIFLASH P1_P2_RDB:P1020RDB,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb P2010RDB P1_P2_RDB:P2010RDB - +Active powerpc mpc85xx - freescale p1_p2_rdb P2010RDB_36BIT P1_P2_RDB:P2010RDB,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb P2010RDB_36BIT_SDCARD P1_P2_RDB:P2010RDB,36BIT,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb P2010RDB_36BIT_SPIFLASH P1_P2_RDB:P2010RDB,36BIT,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb P2010RDB_NAND P1_P2_RDB:P2010RDB,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb P2010RDB_SDCARD P1_P2_RDB:P2010RDB,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb P2010RDB_SPIFLASH P1_P2_RDB:P2010RDB,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb P2020RDB P1_P2_RDB:P2020RDB Poonam Aggrwal poonam.aggrwal@freescale.com +Active powerpc mpc85xx - freescale p1_p2_rdb P2020RDB_36BIT P1_P2_RDB:P2020RDB,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb P2020RDB_36BIT_SDCARD P1_P2_RDB:P2020RDB,36BIT,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb P2020RDB_36BIT_SPIFLASH P1_P2_RDB:P2020RDB,36BIT,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb P2020RDB_NAND P1_P2_RDB:P2020RDB,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb P2020RDB_SDCARD P1_P2_RDB:P2020RDB,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb P2020RDB_SPIFLASH P1_P2_RDB:P2020RDB,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020MBG-PC p1_p2_rdb_pc:P1020MBG - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020MBG-PC_36BIT p1_p2_rdb_pc:P1020MBG,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020MBG-PC_36BIT_SDCARD p1_p2_rdb_pc:P1020MBG,SDCARD,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020MBG-PC_SDCARD p1_p2_rdb_pc:P1020MBG,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020RDB-PC p1_p2_rdb_pc:P1020RDB_PC - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020RDB-PC_36BIT p1_p2_rdb_pc:P1020RDB_PC,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020RDB-PC_36BIT_NAND p1_p2_rdb_pc:P1020RDB_PC,36BIT,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020RDB-PC_36BIT_SDCARD p1_p2_rdb_pc:P1020RDB_PC,36BIT,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020RDB-PC_36BIT_SPIFLASH p1_p2_rdb_pc:P1020RDB_PC,36BIT,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020RDB-PC_NAND p1_p2_rdb_pc:P1020RDB_PC,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020RDB-PC_SDCARD p1_p2_rdb_pc:P1020RDB_PC,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020RDB-PC_SPIFLASH p1_p2_rdb_pc:P1020RDB_PC,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020RDB-PD p1_p2_rdb_pc:P1020RDB_PD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020RDB-PD_NAND p1_p2_rdb_pc:P1020RDB_PD,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020RDB-PD_SDCARD p1_p2_rdb_pc:P1020RDB_PD,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020RDB-PD_SPIFLASH p1_p2_rdb_pc:P1020RDB_PD,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020UTM-PC p1_p2_rdb_pc:P1020UTM - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020UTM-PC_36BIT p1_p2_rdb_pc:P1020UTM,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020UTM-PC_36BIT_SDCARD p1_p2_rdb_pc:P1020UTM,36BIT,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1020UTM-PC_SDCARD p1_p2_rdb_pc:P1020UTM,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1021RDB-PC p1_p2_rdb_pc:P1021RDB - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1021RDB-PC_36BIT p1_p2_rdb_pc:P1021RDB,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1021RDB-PC_36BIT_NAND p1_p2_rdb_pc:P1021RDB,36BIT,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1021RDB-PC_36BIT_SDCARD p1_p2_rdb_pc:P1021RDB,36BIT,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1021RDB-PC_36BIT_SPIFLASH p1_p2_rdb_pc:P1021RDB,36BIT,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1021RDB-PC_NAND p1_p2_rdb_pc:P1021RDB,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1021RDB-PC_SDCARD p1_p2_rdb_pc:P1021RDB,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1021RDB-PC_SPIFLASH p1_p2_rdb_pc:P1021RDB,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1024RDB p1_p2_rdb_pc:P1024RDB - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1024RDB_36BIT p1_p2_rdb_pc:P1024RDB,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1024RDB_NAND p1_p2_rdb_pc:P1024RDB,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1024RDB_SDCARD p1_p2_rdb_pc:P1024RDB,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1024RDB_SPIFLASH p1_p2_rdb_pc:P1024RDB,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1025RDB p1_p2_rdb_pc:P1025RDB - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1025RDB_36BIT p1_p2_rdb_pc:P1025RDB,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1025RDB_NAND p1_p2_rdb_pc:P1025RDB,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1025RDB_SDCARD p1_p2_rdb_pc:P1025RDB,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P1025RDB_SPIFLASH p1_p2_rdb_pc:P1025RDB,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P2020RDB-PC p1_p2_rdb_pc:P2020RDB - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P2020RDB-PC_36BIT p1_p2_rdb_pc:P2020RDB,36BIT - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P2020RDB-PC_36BIT_NAND p1_p2_rdb_pc:P2020RDB,36BIT,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P2020RDB-PC_36BIT_SDCARD p1_p2_rdb_pc:P2020RDB,36BIT,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P2020RDB-PC_36BIT_SPIFLASH p1_p2_rdb_pc:P2020RDB,36BIT,SPIFLASH - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P2020RDB-PC_NAND p1_p2_rdb_pc:P2020RDB,NAND - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P2020RDB-PC_SDCARD p1_p2_rdb_pc:P2020RDB,SDCARD - +Active powerpc mpc85xx - freescale p1_p2_rdb_pc P2020RDB-PC_SPIFLASH p1_p2_rdb_pc:P2020RDB,SPIFLASH - +Active powerpc mpc85xx - freescale p1_twr TWR-P1025 p1_twr:TWR_P1025 - +Active powerpc mpc85xx - freescale p2020come P2020COME_SDCARD P2020COME:SDCARD Ira W. Snyder iws@ovro.caltech.edu +Active powerpc mpc85xx - freescale p2020come P2020COME_SPIFLASH P2020COME:SPIFLASH Ira W. Snyder iws@ovro.caltech.edu +Active powerpc mpc85xx - freescale p2020ds P2020DS - - +Active powerpc mpc85xx - freescale p2020ds P2020DS_36BIT P2020DS:36BIT - +Active powerpc mpc85xx - freescale p2020ds P2020DS_DDR2 P2020DS:DDR2 - +Active powerpc mpc85xx - freescale p2020ds P2020DS_SDCARD P2020DS:SDCARD - +Active powerpc mpc85xx - freescale p2020ds P2020DS_SPIFLASH P2020DS:SPIFLASH - +Active powerpc mpc85xx - freescale p2041rdb P2041RDB - - +Active powerpc mpc85xx - freescale p2041rdb P2041RDB_NAND P2041RDB:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale p2041rdb P2041RDB_SDCARD P2041RDB:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale p2041rdb P2041RDB_SECURE_BOOT P2041RDB:SECURE_BOOT - +Active powerpc mpc85xx - freescale p2041rdb P2041RDB_SPIFLASH P2041RDB:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale p2041rdb P2041RDB_SRIO_PCIE_BOOT P2041RDB:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale t4qds T4160QDS T4240QDS:PPC_T4160 - +Active powerpc mpc85xx - freescale t4qds T4160QDS_SDCARD T4240QDS:PPC_T4160,RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale t4qds T4160QDS_SPIFLASH T4240QDS:PPC_T4160,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale t4qds T4240EMU T4240EMU:PPC_T4240 York Sun yorksun@freescale.com +Active powerpc mpc85xx - freescale t4qds T4240QDS T4240QDS:PPC_T4240 - +Active powerpc mpc85xx - freescale t4qds T4240QDS_SDCARD T4240QDS:PPC_T4240,RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale t4qds T4240QDS_SPIFLASH T4240QDS:PPC_T4240,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - freescale t4qds T4240QDS_SRIO_PCIE_BOOT T4240QDS:PPC_T4240,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 - +Active powerpc mpc85xx - gdsys p1022 controlcenterd_36BIT_SDCARD controlcenterd:36BIT,SDCARD Dirk Eibach eibach@gdsys.de +Active powerpc mpc85xx - gdsys p1022 controlcenterd_36BIT_SDCARD_DEVELOP controlcenterd:36BIT,SDCARD,DEVELOP Dirk Eibach eibach@gdsys.de +Active powerpc mpc85xx - gdsys p1022 controlcenterd_TRAILBLAZER controlcenterd:TRAILBLAZER,SPIFLASH Dirk Eibach eibach@gdsys.de +Active powerpc mpc85xx - gdsys p1022 controlcenterd_TRAILBLAZER_DEVELOP controlcenterd:TRAILBLAZER,SPIFLASH,DEVELOP Dirk Eibach eibach@gdsys.de +Active powerpc mpc85xx - stx stxgp3 stxgp3 - Dan Malek dan@embeddedalley.com +Active powerpc mpc85xx - stx stxssa stxssa stxssa Dan Malek dan@embeddedalley.com +Active powerpc mpc85xx - stx stxssa stxssa_4M stxssa:STXSSA_4M Dan Malek dan@embeddedalley.com +Active powerpc mpc85xx - xes - xpedite520x - - +Active powerpc mpc85xx - xes - xpedite537x - - +Active powerpc mpc85xx - xes - xpedite550x - - +Active powerpc mpc86xx - - - sbc8641d - Paul Gortmaker paul.gortmaker@windriver.com +Active powerpc mpc86xx - freescale mpc8610hpcd MPC8610HPCD - - +Active powerpc mpc86xx - freescale mpc8641hpcn MPC8641HPCN MPC8641HPCN Kumar Gala kumar.gala@freescale.com +Active powerpc mpc86xx - freescale mpc8641hpcn MPC8641HPCN_36BIT MPC8641HPCN:PHYS_64BIT Kumar Gala kumar.gala@freescale.com +Active powerpc mpc86xx - xes - xpedite517x - - +Active powerpc mpc8xx - - - hermes - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - - lwmon - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - - quantum - - +Active powerpc mpc8xx - - - RRvision - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - - spc1920 - - +Active powerpc mpc8xx - - - svm_sc8xx - John Zhan zhanz@sinovee.com +Active powerpc mpc8xx - - - v37 - - +Active powerpc mpc8xx - - adder Adder - Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8xx - - adder Adder87x Adder Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8xx - - adder AdderII Adder:MPC852T Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8xx - - adder AdderUSB Adder Yuli Barcohen yuli@arabellasw.com +Active powerpc mpc8xx - - cogent cogent_mpc8xx - Murray Jensen Murray.Jensen@csiro.au +Active powerpc mpc8xx - - esteem192e ESTEEM192E - Conn Clark clark@esteem.com +Active powerpc mpc8xx - - fads MPC86xADS - - +Active powerpc mpc8xx - - fads MPC885ADS - - +Active powerpc mpc8xx - - flagadm FLAGADM - Kári Davíðsson kd@flaga.is +Active powerpc mpc8xx - - gen860t GEN860T - Keith Outwater Keith_Outwater@mvis.com +Active powerpc mpc8xx - - gen860t GEN860T_SC GEN860T:SC Keith Outwater Keith_Outwater@mvis.com +Active powerpc mpc8xx - - icu862 ICU862 - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - icu862 ICU862_100MHz ICU862:100MHz Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - ip860 IP860 - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - ivm IVML24 IVML24:IVML24_16M Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - ivm IVML24_128 IVML24:IVML24_32M Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - ivm IVML24_256 IVML24:IVML24_64M Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - ivm IVMS8 IVMS8:IVMS8_16M Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - ivm IVMS8_128 IVMS8:IVMS8_32M Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - ivm IVMS8_256 IVMS8:IVMS8_64M Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - netphone NETPHONE NETPHONE:NETPHONE_VERSION=1 - +Active powerpc mpc8xx - - netphone NETPHONE_V2 NETPHONE:NETPHONE_VERSION=2 - +Active powerpc mpc8xx - - netta NETTA NETTA - +Active powerpc mpc8xx - - netta NETTA_6412 NETTA:NETTA_6412=1 - +Active powerpc mpc8xx - - netta NETTA_6412_SWAPHOOK NETTA:NETTA_6412=1,NETTA_SWAPHOOK=1 - +Active powerpc mpc8xx - - netta NETTA_ISDN NETTA:NETTA_ISDN=1 - +Active powerpc mpc8xx - - netta NETTA_ISDN_6412 NETTA:NETTA_ISDN=1,NETTA_6412=1 - +Active powerpc mpc8xx - - netta NETTA_ISDN_6412_SWAPHOOK NETTA:NETTA_ISDN=1,NETTA_6412=1,NETTA_SWAPHOOK=1 - +Active powerpc mpc8xx - - netta NETTA_ISDN_SWAPHOOK NETTA:NETTA_ISDN=1,NETTA_SWAPHOOK=1 - +Active powerpc mpc8xx - - netta NETTA_SWAPHOOK NETTA:NETTA_SWAPHOOK=1 - +Active powerpc mpc8xx - - netta2 NETTA2 NETTA2:NETTA2_VERSION=1 - +Active powerpc mpc8xx - - netta2 NETTA2_V2 NETTA2:NETTA2_VERSION=2 - +Active powerpc mpc8xx - - netvia NETVIA NETVIA:NETVIA_VERSION=1 Pantelis Antoniou panto@intracom.gr +Active powerpc mpc8xx - - netvia NETVIA_V2 NETVIA:NETVIA_VERSION=2 Pantelis Antoniou panto@intracom.gr +Active powerpc mpc8xx - - r360mpi R360MPI - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - rbc823 RBC823 - - +Active powerpc mpc8xx - - RPXlite_dw RPXlite_DW RPXlite_DW - +Active powerpc mpc8xx - - RPXlite_dw RPXlite_DW_64 RPXlite_DW:RPXlite_64MHz - +Active powerpc mpc8xx - - RPXlite_dw RPXlite_DW_64_LCD RPXlite_DW:RPXlite_64MHz,LCD,NEC_NL6448BC20 - +Active powerpc mpc8xx - - RPXlite_dw RPXlite_DW_LCD RPXlite_DW:LCD,NEC_NL6448BC20 - +Active powerpc mpc8xx - - RPXlite_dw RPXlite_DW_NVRAM RPXlite_DW:ENV_IS_IN_NVRAM - +Active powerpc mpc8xx - - RPXlite_dw RPXlite_DW_NVRAM_64 RPXlite_DW:RPXlite_64MHz,ENV_IS_IN_NVRAM - +Active powerpc mpc8xx - - RPXlite_dw RPXlite_DW_NVRAM_64_LCD RPXlite_DW:RPXlite_64MHz,LCD,NEC_NL6448BC20,ENV_IS_IN_NVRAM - +Active powerpc mpc8xx - - RPXlite_dw RPXlite_DW_NVRAM_LCD RPXlite_DW:LCD,NEC_NL6448BC20,ENV_IS_IN_NVRAM - +Active powerpc mpc8xx - - RRvision RRvision_LCD RRvision:LCD,SHARP_LQ104V7DS01 Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - - sixnet SXNI855T - Dave Ellis DGE@sixnetio.com +Active powerpc mpc8xx - - spd8xx SPD823TS - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - eltec mhpc MHPC - Frank Gottschling fgottschling@eltec.de +Active powerpc mpc8xx - emk top860 TOP860 - Reinhard Meyer reinhard.meyer@emk-elektronik.de +Active powerpc mpc8xx - kup kup4k KUP4K - Klaus Heydeck heydeck@kieback-peter.de +Active powerpc mpc8xx - kup kup4x KUP4X - Klaus Heydeck heydeck@kieback-peter.de +Active powerpc mpc8xx - LEOX elpt860 ELPT860 - The LEOX team team@leox.org +Active powerpc mpc8xx - manroland - uc100 - Stefan Roese sr@denx.de +Active powerpc mpc8xx - snmc qs850 QS823 - - +Active powerpc mpc8xx - snmc qs850 QS850 - - +Active powerpc mpc8xx - snmc qs860t QS860T - - +Active powerpc mpc8xx - stx stxxtc stxxtc - Dan Malek dan@embeddedalley.com +Active powerpc mpc8xx - tqc tqm8xx FPS850L - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - tqc tqm8xx FPS860L - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - tqc tqm8xx NSCU - - +Active powerpc mpc8xx - tqc tqm8xx SM850 - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - tqc tqm8xx TK885D - - +Active powerpc mpc8xx - tqc tqm8xx TQM823L - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - tqc tqm8xx TQM823L_LCD TQM823L:LCD,NEC_NL6448BC20 Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - tqc tqm8xx TQM823M - - +Active powerpc mpc8xx - tqc tqm8xx TQM850L - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - tqc tqm8xx TQM850M - - +Active powerpc mpc8xx - tqc tqm8xx TQM855L - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - tqc tqm8xx TQM855M - - +Active powerpc mpc8xx - tqc tqm8xx TQM860L - Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - tqc tqm8xx TQM860M - - +Active powerpc mpc8xx - tqc tqm8xx TQM862L - - +Active powerpc mpc8xx - tqc tqm8xx TQM862M - - +Active powerpc mpc8xx - tqc tqm8xx TQM866M - - +Active powerpc mpc8xx - tqc tqm8xx TQM885D - - +Active powerpc mpc8xx - tqc tqm8xx TTTech TQM823L:LCD,SHARP_LQ104V7DS01 Wolfgang Denk wd@denx.de +Active powerpc mpc8xx - tqc tqm8xx virtlab2 - - +Active powerpc mpc8xx - tqc tqm8xx wtk TQM823L:LCD,SHARP_LQ065T9DR51U Wolfgang Denk wd@denx.de +Active powerpc ppc4xx - - - csb272 - Tolunay Orkun torkun@nextio.com +Active powerpc ppc4xx - - - csb472 - Tolunay Orkun torkun@nextio.com +Active powerpc ppc4xx - - - korat - Larry Johnson lrj@acm.org +Active powerpc ppc4xx - - - lwmon5 - Stefan Roese sr@denx.de +Active powerpc ppc4xx - - - pcs440ep - Stefan Roese sr@denx.de +Active powerpc ppc4xx - - - quad100hd - Gary Jennejohn garyj@denx.de +Active powerpc ppc4xx - - - sbc405 - - +Active powerpc ppc4xx - - - sc3 - Heiko Schocher hs@denx.de +Active powerpc ppc4xx - - - t3corp - Stefan Roese sr@denx.de +Active powerpc ppc4xx - - - zeus - Stefan Roese sr@denx.de +Active powerpc ppc4xx - - g2000 G2000 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - - jse JSE - Stephen Williams steve@icarus.com +Active powerpc ppc4xx - - korat korat_perm korat:KORAT_PERMANENT Larry Johnson lrj@acm.org +Active powerpc ppc4xx - - lwmon5 lcd4_lwmon5 lwmon5:LCD4_LWMON5 Stefan Roese sr@denx.de +Active powerpc ppc4xx - - w7o W7OLMC - Erik Theisen etheisen@mindspring.com +Active powerpc ppc4xx - - w7o W7OLMG - Erik Theisen etheisen@mindspring.com +Active powerpc ppc4xx - amcc - acadia - Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc - bamboo - Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc - bluestone - Tirumala Marri tmarri@apm.com +Active powerpc ppc4xx - amcc - bubinga - - +Active powerpc ppc4xx - amcc - ebony - Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc - katmai - Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc - luan - John Otken jotken@softadvances.com +Active powerpc ppc4xx - amcc - makalu - Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc - ocotea - Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc - redwood - Feng Kan fkan@amcc.com +Active powerpc ppc4xx - amcc - taihu - John Otken jotken@softadvances.com +Active powerpc ppc4xx - amcc - taishan - Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc - yucca - - +Active powerpc ppc4xx - amcc acadia acadia_nand acadia:NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc bamboo bamboo_nand bamboo:NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc canyonlands arches canyonlands:ARCHES Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc canyonlands canyonlands canyonlands:CANYONLANDS Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc canyonlands canyonlands_nand canyonlands:CANYONLANDS,NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc canyonlands glacier canyonlands:GLACIER Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc canyonlands glacier_nand canyonlands:GLACIER,NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc kilauea haleakala kilauea:HALEAKALA Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc kilauea haleakala_nand kilauea:NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc kilauea kilauea kilauea:KILAUEA Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc kilauea kilauea_nand kilauea:NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc sequoia rainier sequoia:RAINIER Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc sequoia rainier_nand sequoia:RAINIER,NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc sequoia rainier_ramboot sequoia:RAINIER,SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/sequoia/u-boot-ram.lds Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc sequoia sequoia sequoia:SEQUOIA Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc sequoia sequoia_nand sequoia:SEQUOIA,NAND_U_BOOT,SYS_TEXT_BASE=0x01000000 Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc sequoia sequoia_ramboot sequoia:SEQUOIA,SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/sequoia/u-boot-ram.lds Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc walnut sycamore walnut Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc walnut walnut - Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc yosemite yellowstone yosemite:YELLOWSTONE Stefan Roese sr@denx.de +Active powerpc ppc4xx - amcc yosemite yosemite yosemite:YOSEMITE Stefan Roese sr@denx.de +Active powerpc ppc4xx - avnet fx12mm fx12mm fx12mm:SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,INIT_TLB=board/xilinx/ppc405-generic/init.o Georg Schardt schardt@team-ctech.de +Active powerpc ppc4xx - avnet fx12mm fx12mm_flash fx12mm:SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC,INIT_TLB=board/xilinx/ppc405-generic/init.o Georg Schardt schardt@team-ctech.de +Active powerpc ppc4xx - avnet v5fx30teval v5fx30teval v5fx30teval:SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,BOOT_FROM_XMD=1,INIT_TLB=board/xilinx/ppc440-generic/init.o Ricardo Ribalda ricardo.ribalda@uam.es +Active powerpc ppc4xx - avnet v5fx30teval v5fx30teval_flash v5fx30teval:SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC,INIT_TLB=board/xilinx/ppc440-generic/init.o Ricardo Ribalda ricardo.ribalda@uam.es +Active powerpc ppc4xx - cray L1 CRAYL1 - David Updegraff dave@cray.com +Active powerpc ppc4xx - dave PPChameleonEVB CATcenter CATcenter:PPCHAMELEON_MODULE_MODEL=1 - +Active powerpc ppc4xx - dave PPChameleonEVB CATcenter_25 CATcenter:PPCHAMELEON_MODULE_MODEL=1,PPCHAMELEON_CLK_25 - +Active powerpc ppc4xx - dave PPChameleonEVB CATcenter_33 CATcenter:PPCHAMELEON_MODULE_MODEL=1,PPCHAMELEON_CLK_33 - +Active powerpc ppc4xx - dave PPChameleonEVB PPChameleonEVB - Andrea "llandre" Marson andrea.marson@dave-tech.it +Active powerpc ppc4xx - dave PPChameleonEVB PPChameleonEVB_BA_25 PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=0,PPCHAMELEON_CLK_25 Andrea "llandre" Marson andrea.marson@dave-tech.it +Active powerpc ppc4xx - dave PPChameleonEVB PPChameleonEVB_BA_33 PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=0,PPCHAMELEON_CLK_33 Andrea "llandre" Marson andrea.marson@dave-tech.it +Active powerpc ppc4xx - dave PPChameleonEVB PPChameleonEVB_HI_25 PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=2,PPCHAMELEON_CLK_25 Andrea "llandre" Marson andrea.marson@dave-tech.it +Active powerpc ppc4xx - dave PPChameleonEVB PPChameleonEVB_HI_33 PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=2,PPCHAMELEON_CLK_33 Andrea "llandre" Marson andrea.marson@dave-tech.it +Active powerpc ppc4xx - dave PPChameleonEVB PPChameleonEVB_ME_25 PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=1,PPCHAMELEON_CLK_25 Andrea "llandre" Marson andrea.marson@dave-tech.it +Active powerpc ppc4xx - dave PPChameleonEVB PPChameleonEVB_ME_33 PPChameleonEVB:PPCHAMELEON_MODULE_MODEL=1,PPCHAMELEON_CLK_33 Andrea "llandre" Marson andrea.marson@dave-tech.it +Active powerpc ppc4xx - esd apc405 APC405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd ar405 AR405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd ash405 ASH405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd cms700 CMS700 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd cpci2dp CPCI2DP - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd cpci405 CPCI405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd cpci405 CPCI4052 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd cpci405 CPCI405AB - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd cpci405 CPCI405DT - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd cpciiser4 CPCIISER4 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd dp405 DP405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd du405 DU405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd du440 DU440 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd hh405 HH405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd hub405 HUB405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd ocrtc OCRTC - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd pci405 PCI405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd plu405 PLU405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd pmc405 PMC405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd pmc405de PMC405DE - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd pmc440 PMC440 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd voh405 VOH405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd vom405 VOM405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - esd wuh405 WUH405 - Matthias Fuchs matthias.fuchs@esd-electronics.com +Active powerpc ppc4xx - gdsys - dlvision - Dirk Eibach eibach@gdsys.de +Active powerpc ppc4xx - gdsys - gdppc440etx - Dirk Eibach eibach@gdsys.de +Active powerpc ppc4xx - gdsys 405ep dlvision-10g - Dirk Eibach eibach@gdsys.de +Active powerpc ppc4xx - gdsys 405ep io - Dirk Eibach eibach@gdsys.de +Active powerpc ppc4xx - gdsys 405ep iocon - Dirk Eibach eibach@gdsys.de +Active powerpc ppc4xx - gdsys 405ep neo - Dirk Eibach eibach@gdsys.de +Active powerpc ppc4xx - gdsys 405ex io64 - Dirk Eibach eibach@gdsys.de +Active powerpc ppc4xx - gdsys intip devconcenter intip:DEVCONCENTER Dirk Eibach eibach@gdsys.de +Active powerpc ppc4xx - gdsys intip intip intip:INTIB Dirk Eibach eibach@gdsys.de +Active powerpc ppc4xx - mosaixtech - icon - Stefan Roese sr@denx.de +Active powerpc ppc4xx - mpl mip405 MIP405 - Denis Peter d.peter@mpl.ch +Active powerpc ppc4xx - mpl mip405 MIP405T MIP405:MIP405T Denis Peter d.peter@mpl.ch +Active powerpc ppc4xx - mpl pip405 PIP405 - Denis Peter d.peter@mpl.ch +Active powerpc ppc4xx - prodrive - alpr - Stefan Roese sr@denx.de +Active powerpc ppc4xx - prodrive - p3p440 - Stefan Roese sr@denx.de +Active powerpc ppc4xx - sandburst karef KAREF - Travis Sawyer (travis.sawyer@sandburst.com> +Active powerpc ppc4xx - sandburst metrobox METROBOX - Travis Sawyer (travis.sawyer@sandburst.com> +Active powerpc ppc4xx - xes - xpedite1000 - Peter Tyser ptyser@xes-inc.com +Active powerpc ppc4xx - xilinx ml507 ml507 ml507:SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,BOOT_FROM_XMD=1,INIT_TLB=board/xilinx/ppc440-generic/init.o Ricardo Ribalda ricardo.ribalda@uam.es +Active powerpc ppc4xx - xilinx ml507 ml507_flash ml507:SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC,INIT_TLB=board/xilinx/ppc440-generic/init.o Ricardo Ribalda ricardo.ribalda@uam.es +Active powerpc ppc4xx - xilinx ppc405-generic xilinx-ppc405-generic xilinx-ppc405-generic:SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000 Ricardo Ribalda ricardo.ribalda@uam.es +Active powerpc ppc4xx - xilinx ppc405-generic xilinx-ppc405-generic_flash xilinx-ppc405-generic:SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC Ricardo Ribalda ricardo.ribalda@uam.es +Active powerpc ppc4xx - xilinx ppc440-generic xilinx-ppc440-generic xilinx-ppc440-generic:SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,BOOT_FROM_XMD=1 Ricardo Ribalda ricardo.ribalda@uam.es +Active powerpc ppc4xx - xilinx ppc440-generic xilinx-ppc440-generic_flash xilinx-ppc440-generic:SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC Ricardo Ribalda ricardo.ribalda@uam.es +Active sandbox sandbox - sandbox sandbox sandbox - Simon Glass sjg@chromium.org +Active sh sh2 - renesas rsk7203 rsk7203 - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org +Active sh sh2 - renesas rsk7264 rsk7264 - Phil Edworthy phil.edworthy@renesas.com +Active sh sh2 - renesas rsk7269 rsk7269 - - +Active sh sh3 - - mpr2 mpr2 - Mark Jonas mark.jonas@de.bosch.com +Active sh sh3 - - ms7720se ms7720se - Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com +Active sh sh3 - - shmin shmin - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org +Active sh sh4 - - espt espt - - +Active sh sh4 - - ms7722se ms7722se - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org +Active sh sh4 - - ms7750se ms7750se - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org +Active sh sh4 - alphaproject ap_sh4a_4a ap_sh4a_4a - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org +Active sh sh4 - renesas ap325rxa ap325rxa - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org +Active sh sh4 - renesas ecovec ecovec - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org +Active sh sh4 - renesas MigoR MigoR - - +Active sh sh4 - renesas r0p7734 r0p7734 - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org +Active sh sh4 - renesas r2dplus r2dplus - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org +Active sh sh4 - renesas r7780mp r7780mp - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org +Active sh sh4 - renesas sh7752evb sh7752evb - - +Active sh sh4 - renesas sh7757lcr sh7757lcr - - +Active sh sh4 - renesas sh7763rdp sh7763rdp - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org +Active sh sh4 - renesas sh7785lcr sh7785lcr - - +Active sh sh4 - renesas sh7785lcr sh7785lcr_32bit sh7785lcr:SH_32BIT=1 - +Active sparc leon2 - gaisler - grsim_leon2 - - +Active sparc leon3 - gaisler - gr_cpci_ax2000 - - +Active sparc leon3 - gaisler - gr_ep2s60 - - +Active sparc leon3 - gaisler - gr_xc3s_1500 - - +Active sparc leon3 - gaisler - grsim - - +Active x86 x86 coreboot chromebook-x86 coreboot coreboot-x86 coreboot:SYS_TEXT_BASE=0x01110000 - +Orphan arm arm1136 mx31 - imx31_phycore imx31_phycore_eet imx31_phycore:IMX31_PHYCORE_EET (resigned) Guennadi Liakhovetski g.liakhovetski@gmx.de +Orphan arm arm1136 mx31 freescale - mx31ads - (resigned) Guennadi Liakhovetski g.liakhovetski@gmx.de +Orphan arm arm925t - ti - omap1510inn - Kshitij Gupta kshitij@ti.com +Orphan arm pxa - - - lubbock - (dead address) Kyle Harris kharris@nexus-tech.net +Orphan powerpc 74xx_7xx - - evb64260 EVB64260 EVB64260 - +Orphan powerpc 74xx_7xx - - evb64260 EVB64260_750CX EVB64260 Eran Man eran@nbase.co.il +Orphan powerpc mpc824x - - mousse MOUSSE - - +Orphan powerpc mpc8260 - - - rsdproto - - +Orphan powerpc mpc8260 - - rpxsuper RPXsuper - - +Orphan powerpc mpc8xx - - - RPXClassic - - +Orphan powerpc mpc8xx - - - RPXlite - - +Orphan powerpc mpc8xx - - fads ADS860 - - +Orphan powerpc mpc8xx - - fads FADS823 - - +Orphan powerpc mpc8xx - - fads FADS850SAR - - +Orphan powerpc mpc8xx - - fads FADS860T - - +Orphan powerpc mpc8xx - - genietv GENIETV - - +Orphan powerpc mpc8xx - - mbx8xx MBX - - +Orphan powerpc mpc8xx - - mbx8xx MBX860T - - +Orphan powerpc mpc8xx - - nx823 NX823 - - diff --git a/mkconfig b/mkconfig index 816ae3d..1d06c8e 100755 --- a/mkconfig +++ b/mkconfig @@ -23,10 +23,11 @@ options=""
if [ ( $# -eq 2 ) -a ( "$1" = "-A" ) ] ; then # Automatic mode - line=`egrep -i "^[[:space:]]*${2}[[:space:]]" boards.cfg` || { + line=`awk '($0 !~ /^#/ && $7 ~ /^'"$2"'$/) { print $1, $2, $3, $4, $5, $6, $7, $8 }' boards.cfg` + if [ -z "$line" ] ; then echo "make: *** No rule to make target `$2_config'. Stop." >&2 exit 1 - } + fi
set ${line} # add default board name if needed @@ -37,44 +38,44 @@ while [ $# -gt 0 ] ; do case "$1" in --) shift ; break ;; -a) shift ; APPEND=yes ;; - -n) shift ; BOARD_NAME="${1%_config}" ; shift ;; + -n) shift ; BOARD_NAME="${7%_config}" ; shift ;; -t) shift ; TARGETS="`echo $1 | sed 's:_: :g'` ${TARGETS}" ; shift ;; *) break ;; esac done
-[ $# -lt 4 ] && exit 1 -[ $# -gt 7 ] && exit 1 +[ $# -lt 7 ] && exit 1 +[ $# -gt 8 ] && exit 1
# Strip all options and/or _config suffixes -CONFIG_NAME="${1%_config}" +CONFIG_NAME="${7%_config}"
-[ "${BOARD_NAME}" ] || BOARD_NAME="${1%_config}" +[ "${BOARD_NAME}" ] || BOARD_NAME="${7%_config}"
arch="$2" cpu=`echo $3 | awk 'BEGIN {FS = ":"} ; {print $1}'` spl_cpu=`echo $3 | awk 'BEGIN {FS = ":"} ; {print $2}'` -if [ "$4" = "-" ] ; then +if [ "$6" = "-" ] ; then board=${BOARD_NAME} else - board="$4" + board="$6" fi -[ $# -gt 4 ] && [ "$5" != "-" ] && vendor="$5" -[ $# -gt 5 ] && [ "$6" != "-" ] && soc="$6" -[ $# -gt 6 ] && [ "$7" != "-" ] && { +[ "$5" != "-" ] && vendor="$5" +[ "$4" != "-" ] && soc="$4" +[ $# -gt 7 ] && [ "$8" != "-" ] && { # check if we have a board config name in the options field # the options field mave have a board config name and a list # of options, both separated by a colon (':'); the options are # separated by commas (','). # # Check for board name - tmp="${7%:*}" + tmp="${8%:*}" if [ "$tmp" ] ; then CONFIG_NAME="$tmp" fi # Check if we only have a colon... - if [ "${tmp}" != "$7" ] ; then - options=${7#*:} + if [ "${tmp}" != "$8" ] ; then + options=${8#*:} TARGETS="`echo ${options} | sed 's:,: :g'` ${TARGETS}" fi } diff --git a/tools/buildman/board.py b/tools/buildman/board.py index cc7b5d0..a388896 100644 --- a/tools/buildman/board.py +++ b/tools/buildman/board.py @@ -63,7 +63,7 @@ class Boards: for upto in range(len(fields)): if fields[upto] == '-': fields[upto] = '' - while len(fields) < 7: + while len(fields) < 9: fields.append('')
board = Board(*fields) diff --git a/tools/reformat.py b/tools/reformat.py new file mode 100755 index 0000000..ff6633f --- /dev/null +++ b/tools/reformat.py @@ -0,0 +1,132 @@ +#! /usr/bin/python +######################################################################## +# +# reorder and reformat a file in columns +# +# this utility takes lines from its standard input and reproduces them, +# partially reordered and reformatted, on its standard output. +# +# It has the same effect as a 'sort | column -t', with the exception +# that empty lines, as well as lines which start with a '#' sign, are +# not affected, i.e. they keep their position and formatting, and act +# as separators, i.e. the parts before and after them are each sorted +# separately (but overall field widths are computed across the whole +# input). +# +# Options: +# -i: +# --ignore-case: +# Do not consider case when sorting. +# -d: +# --default: +# What to chage empty fields to. +# -s <N>: +# --split=<N>: +# Treat only the first N whitespace sequences as separators. +# line content after the Nth separator will count as only one +# field even if it contains whitespace. +# Example : '-s 2' causes input 'a b c d e' to be split into +# three fields, 'a', 'b', and 'c d e'. +# +# boards.cfg requires -ids 6. +# +######################################################################## + +import sys, getopt, locale + +# ensure we sort using the C locale. + +locale.setlocale(locale.LC_ALL, 'C') + +# check options + +maxsplit = 0 +ignore_case = 0 +default_field ='' + +try: + opts, args = getopt.getopt(sys.argv[1:], "id:s:", + ["ignore-case","default","split="]) +except getopt.GetoptError as err: + print str(err) # will print something like "option -a not recognized" + sys.exit(2) + +for o, a in opts: + if o in ("-s", "--split"): + maxsplit = eval(a) + elif o in ("-i", "--ignore-case"): + ignore_case = 1 + elif o in ("-d", "--default"): + default_field = a + else: + assert False, "unhandled option" + +# collect all lines from standard input and, for the ones which must be +# reformatted and sorted, count their fields and compute each field's +# maximum size + +input_lines = [] +field_width = [] + +for line in sys.stdin: + # remove final end of line + input_line = line.strip('\n') + if (len(input_line)>0) and (input_line[0] != '#'): + # sortable line: split into fields + fields = input_line.split(None,maxsplit) + # if there are new fields, top up field_widths + for f in range(len(field_width), len(fields)): + field_width.append(0) + # compute the maximum witdh of each field + for f in range(len(fields)): + field_width[f] = max(field_width[f],len(fields[f])) + # collect the line for next stage + input_lines.append(input_line) + +# run through collected input lines, collect the ones which must be +# reformatted and sorted, and whenever a non-reformattable, non-sortable +# line is met, sort the collected lines before it and append them to the +# output lines, then add the non-sortable line too. + +output_lines = [] +sortable_lines = [] +for input_line in input_lines: + if (len(input_line)>0) and (input_line[0] != '#'): + # this line should be reformatted and sorted + input_fields = input_line.split(None,maxsplit) + output_fields = []; + # reformat each field to this field's column width + for f in range(len(input_fields)): + output_field = input_fields[f]; + output_fields.append(output_field.ljust(field_width[f])) + # any missing field is set to default if it exists + if default_field != '': + for f in range(len(input_fields),len(field_width)): + output_fields.append(default_field.ljust(field_width[f])) + # join fields using two spaces, like column -t would + output_line = ' '.join(output_fields); + # collect line for later + sortable_lines.append(output_line) + else: + # this line is non-sortable + # sort collected sortable lines + if ignore_case!=0: + sortable_lines.sort(key=lambda x: str.lower(locale.strxfrm(x))) + else: + sortable_lines.sort(key=lambda x: locale.strxfrm(x)) + # append sortable lines to the final output + output_lines.extend(sortable_lines) + sortable_lines = [] + # append non-sortable line to the final output + output_lines.append(input_line) +# maybe we had sortable lines pending, so append them to the final output +if ignore_case!=0: + sortable_lines.sort(key=lambda x: str.lower(locale.strxfrm(x))) +else: + sortable_lines.sort(key=lambda x: locale.strxfrm(x)) +output_lines.extend(sortable_lines) + +# run through output lines and print them, except rightmost whitespace + +for output_line in output_lines: + print output_line.rstrip()
On Wed, Sep 11, 2013 at 03:52:51PM +0200, Albert ARIBAUD wrote:
Put all informations about targets, including state (active or orphan) and maintainers, in boards.cfg; remove MAINTAINERS; adjust the build system accordingly.
Signed-off-by: Albert ARIBAUD albert.u.boot@aribaud.net
V2:
- updated with latest boards.cfg/MAINTAINER info
- fixed wrong maintainer(s) for orphan boards
- fixed wrong maintainer(s) for base:options case
- fixed lingering misuses of boards.cfg and MAINTAINERS
V1:
- initial submission from squashed RFC patch series
MAINTAINERS | 1412 ---------------------------- MAKEALL | 51 +- Makefile | 2 +- README | 6 +- boards.cfg | 2345 ++++++++++++++++++++++++----------------------- mkconfig | 31 +- tools/buildman/board.py | 2 +- tools/reformat.py | 132 +++ 8 files changed, 1350 insertions(+), 2631 deletions(-) delete mode 100644 MAINTAINERS create mode 100755 tools/reformat.py
Hello Albert, Tom.
Commit 27af930e9 added Active/Orphan status in the first column of boards.cfg.
Could you tell the definition of "Active" and "Orphan".
At first I imagined Orphan means a board without maintainer. But the maintainer information is missing from lots of Active boards. So I could not find the difference between Active and Orphan.
Best Regards Masahiro Yamada
Hi Masahiro,
On Tue, 17 Sep 2013 09:55:00 +0900, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
Hello Albert, Tom.
I have listed as "Orphan" any board mentioned in the "unknown / orphan" sections of the original MAINTAINERS file.
If you look at the original MAINTAINERS, you'll see that some boards were listed under a maintainer e-mail, and some boards were listed under "unknown / orphan"; but not all boards were listed.
I set the board state in the new board.cfg to "Orphan" if and only if the board was listed in such an "unknown / orphan" section, and to "Active in any other case". This implies that:
- some boards were present in the old boards.cfg but not listed in MAINTAINERS (e.g. sh7785lcr), which means there are "Active" boards which do not have a maintainer;
- some "unknown / orphan" boards had a "last known maintainer address" specified (e.g. EVB64260_750CX), which means there are "Orphan" boards which have a maintainer listed.
IOW, a board's state (Active or Orphan) has no formal relationship with this board having maintainers or not; the state only determines whether this board should be built (Active) or not (Orphan).
Note that I have verified that ./MAKEALL -a arm built the same boards, although I have not verified this for other architectures; and that ./MAKEALL -m listed the same boards and maintainers (or more exactly, listed the same boards and attributed the correct maintainers, as some of the old ./MAKEALL -m output was incorrect), at meast for ARM and PowerPC.
Amicalement,
Hello Albert
To sum up things, boards have actually 3 states:
(1) Active: had a maintainer in the original MAINTAINERS file
(2) Orphan: listed under unknown/orphan in the original MAINTAINERS file
(3) maybe Active, maybe Orphan: not mentioned in the original MAINTAINERS file
You pushed both (1) and (3) into Active state in the new boards.cfg although many boards in (3) might not have a maintainer.
In such a case, what is the meaning to categorize into Active or Orphan?
I think unknown/orphan stands for "no maintainers" in the original MAINTAINERS file. Now you recongnize this as "Should not be built". Is this the same meaning?
In my opinion, 'Orphan' might be a misleading term for the latter. Active / Dead ?
How abount reconsidering a bit more about this categorization?
Hi Masahiro,
On Fri, 27 Sep 2013 20:05:35 +0900, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
Hello Albert
As far as I can tell, it is the same meaning -- by that I mean I compared the build counts before and after the change and found no difference.
Note that if a board was found orphan, it means that there was an attempt to contact the maintainer and it failed. And if there was an attempt to contact the maintainer, chances are it was because the board had issues.
If you feel that there should be a renaming, feel free to submit patches. The only risk I see is that the name "Active" is used by the makefiles to find out which boards it should build, so if you change that in boards.cfg, you'll have to change it in the makefile(s) too.
Amicalement,
Albert ARIBAUD
Masahiro Yamada
