[U-Boot] [PATCH 3/7 v2] integrator: do not test first part of the memory
When booting from Flash, the Integrator remaps its flash memory from 0x24000000 to 0x00000000, and starts executing it at 0x00000000. This ROM thus hides the RAM underneath and first 0x40000 bytes of the memory cannot be tested by get_ram_size(). So let's test from 0x40000 to the end of detected memory instead.
Signed-off-by: Linus Walleij linus.walleij@linaro.org --- ChangeLog v1->v2: - Rebased to U-Boot ARM HEAD at Alberts request, see message 4EA1C8E7.7090105@aribaud.net --- board/armltd/integrator/integrator.c | 19 +++++++++++++++---- 1 files changed, 15 insertions(+), 4 deletions(-)
diff --git a/board/armltd/integrator/integrator.c b/board/armltd/integrator/integrator.c index c8d2bc7..83f047c 100644 --- a/board/armltd/integrator/integrator.c +++ b/board/armltd/integrator/integrator.c @@ -86,6 +86,15 @@ int misc_init_r (void) return (0); }
+/* + * The Integrator remaps the Flash memory to 0x00000000 and executes U-Boot + * from there, which means we cannot test the RAM underneath the ROM at this + * point. It will be unmapped later on, when we are executing from the + * relocated in RAM U-Boot. We simply assume that this RAM is usable if the + * RAM on higher addresses works fine. + */ +#define REMAPPED_FLASH_SZ 0x40000 + int dram_init (void) { gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; @@ -111,15 +120,17 @@ extern void dram_query(void); * */ sdram_shift = ((cm_reg_sdram & 0x0000001C)/4)%4; - gd->bd->bi_dram[0].size = 0x01000000 << sdram_shift; - gd->ram_size = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, + gd->ram_size = get_ram_size((long *) CONFIG_SYS_SDRAM_BASE + + REMAPPED_FLASH_SZ, 0x01000000 << sdram_shift); } #else - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - gd->ram_size = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, + gd->ram_size = get_ram_size((long *) CONFIG_SYS_SDRAM_BASE + + REMAPPED_FLASH_SZ, PHYS_SDRAM_1_SIZE); #endif /* CM_SPD_DETECT */ + /* We only have one bank of RAM, set it to whatever was detected */ + gd->bd->bi_dram[0].size = gd->ram_size;
return 0; }
Hi Linus,
Signed-off-by: Linus Walleijlinus.walleij@linaro.org
ChangeLog v1->v2:
- The Integrator remaps the Flash memory to 0x00000000 and executes U-Boot
- from there, which means we cannot test the RAM underneath the ROM at this
- point. It will be unmapped later on, when we are executing from the
- relocated in RAM U-Boot. We simply assume that this RAM is usable if the
- RAM on higher addresses works fine.
- int dram_init (void) { gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE;
@@ -111,15 +120,17 @@ extern void dram_query(void); * */ sdram_shift = ((cm_reg_sdram& 0x0000001C)/4)%4;
- gd->bd->bi_dram[0].size = 0x01000000<< sdram_shift;
- gd->ram_size = get_ram_size((long *) CONFIG_SYS_SDRAM_BASE +
} #elseREMAPPED_FLASH_SZ, 0x01000000<< sdram_shift);
return 0; }
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Linus Walleij
